# # ChangeLog for freebsd/sys in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 05/21/24 14:37:18 Mon, 28 Oct 2013 11:04:06 GMT Sebastian Huber [bae343a] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/sys/systm.h (modified) * rtemsbsd/rtems/rtems-bsd-subr_param.c (deleted) Use compile-time constant for vm_guest Mon, 28 Oct 2013 09:45:22 GMT Sebastian Huber [ea87228] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/subr_taskqueue.c (added) * libbsd.txt (modified) * rtemsbsd/rtems/rtems-bsd-taskqueue.c (deleted) TASKQUEUE(9): Use FreeBSD implementation Mon, 28 Oct 2013 08:54:33 GMT Sebastian Huber [08264c8] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-syspoll.c (deleted) * testsuite/syscalls01/test_main.c (modified) Use poll() from FreeBSD Fri, 25 Oct 2013 13:09:17 GMT Sebastian Huber [3e29388] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-chunk.h (added) * rtemsbsd/rtems/rtems-bsd-chunk.c (added) * rtemsbsd/rtems/rtems-bsd-page.c (deleted) ZONE(9): Add and use red-black tree chunk alloc Thu, 24 Oct 2013 12:46:25 GMT Sebastian Huber [11b7f58] * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) Fix errno conflict Newlib defines errno as #define errno ... Thu, 24 Oct 2013 09:49:55 GMT Sebastian Huber [6ca6aa8] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_proc.c (deleted) * freebsd/sys/kern/kern_resource.c (deleted) Delete kern_proc.c and kern_resource.c Thu, 24 Oct 2013 09:37:44 GMT Sebastian Huber [53441c0] * freebsd/sys/sys/systm.h (modified) * rtemsbsd/include/machine/rtems-bsd-symbols.h (modified) Move pause() define to Thu, 24 Oct 2013 09:36:09 GMT Sebastian Huber [b3193b8] * freebsd/sys/sys/libkern.h (modified) * rtemsbsd/include/machine/rtems-bsd-symbols.h (modified) Move strdup() define to Thu, 24 Oct 2013 09:11:32 GMT Sebastian Huber [150d4d6] * freebsd/sys/kern/kern_module.c (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/include/machine/rtems-bsd-support.h (added) * rtemsbsd/rtems/rtems-bsd-cam.c (modified) * rtemsbsd/rtems/rtems-bsd-condvar.c (modified) * rtemsbsd/rtems/rtems-bsd-delay.c (modified) * rtemsbsd/rtems/rtems-bsd-malloc.c (modified) * rtemsbsd/rtems/rtems-bsd-mutex.c (modified) * rtemsbsd/rtems/rtems-bsd-rwlock.c (modified) * rtemsbsd/rtems/rtems-bsd-shell.c (modified) * rtemsbsd/rtems/rtems-bsd-signal.c (modified) * rtemsbsd/rtems/rtems-bsd-sx.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) Move content to new Thu, 24 Oct 2013 08:44:22 GMT Sebastian Huber [12b57ad] * freebsd/sys/sys/malloc.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/include/machine/rtems-bsd-symbols.h (modified) Move malloc defines to Thu, 24 Oct 2013 08:39:07 GMT Sebastian Huber [6cdf009] * freebsd/sys/sys/systm.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) Remove setenv() declaration (conficts ) Thu, 24 Oct 2013 08:36:52 GMT Sebastian Huber [40f2158a] * freebsd/sys/sys/libkern.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) Remove abs() and labs() definitions Confict with . Thu, 24 Oct 2013 08:29:30 GMT Sebastian Huber [99378e2] * freebsd/sys/sys/libkern.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) Remove gets() declaration (conflicts ) Thu, 24 Oct 2013 08:17:20 GMT Sebastian Huber [ea49a89] * freebsd/sys/sys/kernel.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) Move ticks definition Thu, 24 Oct 2013 06:55:46 GMT Sebastian Huber [5d288bc] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/sys/smp.h (modified) * rtemsbsd/rtems/rtems-bsd-smp.c (deleted) Use compile-time constants for exactly one CPU Thu, 24 Oct 2013 06:54:58 GMT Sebastian Huber [87fdc14] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/include/net/zlib.h (added) * freebsd/sys/net/zlib.c (deleted) * freebsd/sys/net/zlib.h (deleted) Use RTEMS provides zlib Wed, 23 Oct 2013 14:10:26 GMT Sebastian Huber [facf9dc] * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/sys/file.h (modified) * testsuite/syscalls01/test_main.c (modified) Use select() from FreeBSD Wed, 23 Oct 2013 07:47:09 GMT Sebastian Huber [f9c2714] * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/systm.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/include/machine/rtems-bsd-thread.h (modified) * rtemsbsd/rtems/rtems-bsd-kern_synch.c (modified) * rtemsbsd/rtems/rtems-bsd-mutex.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) SLEEP(8): New implementation Tue, 22 Oct 2013 08:55:49 GMT Sebastian Huber [616f6000] * freebsd-to-rtems.py (modified) * freebsd/sys/sys/md5.h (deleted) * rtemsbsd/include/sys/md5.h (added) Map to RTEMS Fri, 18 Oct 2013 12:12:17 GMT Sebastian Huber [ffcd542] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm_extern.h (added) * rtemsbsd/include/machine/vmparam.h (moved) * rtemsbsd/rtems/rtems-bsd-vm_glue.c (deleted) * testsuite/timeout01/init.c (modified) * testsuite/timeout01/timeout_helper.c (modified) * testsuite/timeout01/timeout_helper.h (modified) Move TIMEOUT(9) and ZONE(9) initialization Delete most of virtual ... Thu, 17 Oct 2013 08:38:34 GMT Sebastian Huber [d01564c] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/include/err.h (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/usr.bin/netstat/main.c (modified) * rtemsbsd/include/machine/rtems-bsd-program.h (added) * rtemsbsd/rtems/rtems-bsd-program.c (added) * rtemsbsd/rtems/rtems-getprogname.c (deleted) * testsuite/syscalls01/test_main.c (modified) Move program control to thread structure Wed, 23 Oct 2013 07:47:26 GMT Sebastian Huber [1bbb359] * freebsd/sys/kern/kern_sysctl.c (modified) Avoid NULL pointer access Tue, 15 Oct 2013 13:36:59 GMT Sebastian Huber [57f2002] * freebsd/sys/sys/sysctl.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-sysctl.c (modified) * rtemsbsd/rtems/rtems-bsd-sysctlbyname.c (modified) * rtemsbsd/rtems/rtems-bsd-sysctlnametomib.c (modified) Add sysctl(), etc. prototypes Mon, 14 Oct 2013 14:14:19 GMT Sebastian Huber [9d9bfaf] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (deleted) * testsuite/syscalls01/test_main.c (modified) Use send/recv functions from FreeBSD Use recvfrom(), recvmsg(), ... Mon, 14 Oct 2013 12:55:04 GMT Sebastian Huber [ec702ab] * freebsd/sys/kern/sys_socket.c (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use socket read() and write() from FreeBSD Mon, 14 Oct 2013 11:24:10 GMT Sebastian Huber [8989c11] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use getsockname() from FreeBSD Mon, 14 Oct 2013 11:09:15 GMT Sebastian Huber [0beab1e] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use getpeername() from FreeBSD Mon, 14 Oct 2013 10:53:43 GMT Sebastian Huber [ac78dd2] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use getsockopt() and setsockopt() from FreeBSD Mon, 14 Oct 2013 09:41:14 GMT Sebastian Huber [7c2b59c] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use accept() from FreeBSD Mon, 14 Oct 2013 08:04:29 GMT Sebastian Huber [7c36251] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use listen() from FreeBSD Mon, 14 Oct 2013 07:48:56 GMT Sebastian Huber [6676de4] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use connect() from FreeBSD Fri, 11 Oct 2013 15:32:49 GMT Sebastian Huber [e5393a3] * freebsd/sys/kern/sys_socket.c (modified) * testsuite/syscalls01/test_main.c (modified) Use socket ioctl() from FreeBSD Fri, 11 Oct 2013 14:44:48 GMT Sebastian Huber [468b08e] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use bind() from FreeBSD Fri, 11 Oct 2013 12:48:13 GMT Sebastian Huber [6ffb9b9] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (modified) Use shutdown() from FreeBSD Tue, 15 Oct 2013 12:05:50 GMT Sebastian Huber [bada2f7] * freebsd/sys/kern/sys_socket.c (modified) * testsuite/syscalls01/test_main.c (modified) Add socket fstat() support Thu, 10 Oct 2013 09:29:33 GMT Sebastian Huber [caf8ede] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/sys_socket.c (added) * freebsd/sys/kern/uipc_syscalls.c (added) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/sysproto.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * testsuite/syscalls01/test_main.c (added) Import socket() implementation from FreeBSD Add new test syscalls01. Thu, 10 Oct 2013 14:11:02 GMT Sebastian Huber [69b29a0] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/contrib/pf/net/pf.c (modified) * freebsd/sys/contrib/pf/net/pf_ioctl.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_prot.c (deleted) * freebsd/sys/kern/kern_resource.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/ipfw/ip_fw2.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/ucred.h (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/rtems/rtems-bsd-jail.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) * rtemsbsd/rtems/rtems-bsd-thread0-ucred.c (deleted) Disable user credentials and use default values Thu, 10 Oct 2013 13:00:20 GMT Sebastian Huber [cc5f4b2] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/contrib/pf/net/pf_ioctl.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/sigio.h (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/rtems/rtems-bsd-descrip.c (deleted) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) Use default PID value for all process identifiers Thu, 10 Oct 2013 12:45:09 GMT Sebastian Huber [549488b] * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/sys/proc.h (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) Disable alternative routing tables Thu, 10 Oct 2013 12:33:05 GMT Sebastian Huber [3842b81] * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/sys/proc.h (modified) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) Delete struct proc p_mtx lock Usage of this lock is highly ... Thu, 10 Oct 2013 12:32:36 GMT Sebastian Huber [0bcf341] * freebsd/sys/sys/proc.h (modified) Delete unused struct proc fields Mon, 14 Oct 2013 13:01:13 GMT Sebastian Huber [db2e97f] * freebsd/sys/sys/systm.h (modified) * rtemsbsd/include/machine/rtems-bsd-symbols.h (modified) * rtemsbsd/rtems/rtems-bsd-support.c (modified) Disable cold boot indicator Thu, 10 Oct 2013 12:31:21 GMT Sebastian Huber [5003e8f] * freebsd/sys/kern/kern_resource.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) Avoid references to lim_cur() Thu, 10 Oct 2013 11:27:01 GMT Sebastian Huber [c9db0f5] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/proc.h (modified) * rtemsbsd/rtems/rtems-bsd-get-file.c (added) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) Use RTEMS API for file handling Thu, 10 Oct 2013 08:32:52 GMT Sebastian Huber [8eb42e8] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/kern_descrip.c (deleted) * freebsd/sys/kern/sys_generic.c (modified) Avoid references to kern_descrip.c Use the standard RTEMS file ... Fri, 11 Oct 2013 13:08:39 GMT Sebastian Huber [032b3b7] * freebsd-to-rtems.py (modified) * freebsd/sys/sys/fcntl.h (deleted) * rtemsbsd/include/rtems/bsd/sys/_types.h (modified) Use Newlib provided Thu, 10 Oct 2013 08:30:04 GMT Sebastian Huber [ebabe9b] * freebsd-to-rtems.py (modified) * freebsd/sys/sys/sysproto.h (added) * rtemsbsd/include/sys/sysproto.h (deleted) Import from FreeBSD Thu, 10 Oct 2013 09:32:42 GMT Sebastian Huber [cd75897] * freebsd-to-rtems.py (modified) * freebsd/sys/security/audit/audit.h (added) * rtemsbsd/include/security/audit/audit.h (deleted) Import from FreeBSD Thu, 10 Oct 2013 08:29:36 GMT Sebastian Huber [3fc7c89] * freebsd/sys/net/route.c (modified) Disable setfib() syscall Thu, 10 Oct 2013 08:40:46 GMT Sebastian Huber [cc2298f] * freebsd/sys/sys/mbuf.h (modified) Fix warning in Thu, 10 Oct 2013 08:31:04 GMT Sebastian Huber [7c801d1] * freebsd/sys/sys/refcount.h (modified) Fix warnings in Wed, 09 Oct 2013 06:56:49 GMT Sebastian Huber [ab415f9] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_process.h (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/proc.h (modified) * rtemsbsd/include/machine/pcpu.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/include/machine/rtems-bsd-thread.h (added) * rtemsbsd/rtems/rtems-bsd-init-with-irq.c (modified) * rtemsbsd/rtems/rtems-bsd-init.c (modified) * rtemsbsd/rtems/rtems-bsd-mutex.c (modified) * rtemsbsd/rtems/rtems-bsd-panic.c (modified) * rtemsbsd/rtems/rtems-bsd-shell.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/swi01/init.c (modified) * testsuite/thread01/test_main.c (added) * testsuite/timeout01/init.c (modified) * testsuite/usb01/init.c (modified) Use extension to attach a struct thread to threads Add test thread01. Wed, 09 Oct 2013 12:03:56 GMT Sebastian Huber [d652c3b] * freebsd/sys/net/netisr.c (modified) * freebsd/sys/sys/pcpu.h (modified) * libbsd.txt (modified) Avoid per-CPU NETISR(9) SMP support should be enabled once the new ... Wed, 09 Oct 2013 20:52:54 GMT Sebastian Huber [e599318] * .gitignore (modified) * Makefile (modified) * config.inc (modified) * freebsd-to-rtems.py (modified) * freebsd-userspace/Makefile (deleted) * freebsd-userspace/README (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient-script (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient-script.8 (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient.8 (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient.conf (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient.conf.5 (deleted) * freebsd-userspace/commands/sbin/dhclient/dhclient.leases.5 (deleted) * freebsd-userspace/commands/sbin/dhclient/dhcp-options.5 (deleted) * freebsd-userspace/commands/sbin/ifconfig/af_ipx.c (deleted) * freebsd-userspace/commands/sbin/ifconfig/ifconfig.8 (deleted) * freebsd-userspace/commands/sbin/ifconfig/regdomain.c (deleted) * freebsd-userspace/commands/sbin/ping/ping.8 (deleted) * freebsd-userspace/commands/sbin/ping6/ping6.8 (deleted) * freebsd-userspace/commands/sbin/route/route.8 (deleted) * freebsd-userspace/commands/usr.bin/netstat/ipx.c (deleted) * freebsd-userspace/commands/usr.bin/netstat/netgraph.c (deleted) * freebsd-userspace/commands/usr.bin/netstat/netstat.1 (deleted) * freebsd-userspace/from-freebsd.sh (deleted) * freebsd-userspace/include/net/in.h (deleted) * freebsd-userspace/lib/libc/gen/err.3 (deleted) * freebsd-userspace/lib/libc/net/Makefile (deleted) * freebsd-userspace/lib/libc/net/nsparser.h (deleted) * freebsd-userspace/lib/libc/stdio/fgetln.3 (deleted) * freebsd-userspace/lib/libc/stdlib/strtonum.3 (deleted) * freebsd-userspace/lib/libc_r/uthread/uthread_kern.c (deleted) * freebsd-userspace/lib/libc_r/uthread/uthread_select.c (deleted) * freebsd-userspace/lib/libipsec/Makefile (deleted) * freebsd-userspace/lib/libipsec/ipsec_set_policy.3 (deleted) * freebsd-userspace/lib/libipsec/ipsec_strerror.3 (deleted) * freebsd-userspace/lib/libipsec/test-policy.c (deleted) * freebsd-userspace/lib/libkvm/kvm.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getcptime.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_geterr.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getfiles.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getloadavg.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getpcpu.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getprocs.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_getswapinfo.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_nlist.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_open.3 (deleted) * freebsd-userspace/lib/libkvm/kvm_read.3 (deleted) * freebsd-userspace/lib/libmemstat/libmemstat.3 (deleted) * freebsd-userspace/lib/libutil/expand_number.3 (deleted) * freebsd-userspace/lib/libutil/humanize_number.3 (deleted) * freebsd-userspace/lib/libutil/trimdomain.3 (deleted) * freebsd-userspace/local/pthread_np.h (deleted) * freebsd-userspace/rtems/include/freebsd/stdint.h (deleted) * freebsd-userspace/rtems/include/isc/app.h (deleted) * freebsd-userspace/rtems/include/isc/assertions.h (deleted) * freebsd-userspace/rtems/include/isc/boolean.h (deleted) * freebsd-userspace/rtems/include/isc/buffer.h (deleted) * freebsd-userspace/rtems/include/isc/dst.h (deleted) * freebsd-userspace/rtems/include/isc/error.h (deleted) * freebsd-userspace/rtems/include/isc/formatcheck.h (deleted) * freebsd-userspace/rtems/include/isc/int.h (deleted) * freebsd-userspace/rtems/include/isc/interfaceiter.h (deleted) * freebsd-userspace/rtems/include/isc/ipv6.h (deleted) * freebsd-userspace/rtems/include/isc/lang.h (deleted) * freebsd-userspace/rtems/include/isc/lib.h (deleted) * freebsd-userspace/rtems/include/isc/magic.h (deleted) * freebsd-userspace/rtems/include/isc/mem.h (deleted) * freebsd-userspace/rtems/include/isc/msgcat.h (deleted) * freebsd-userspace/rtems/include/isc/msgs.h (deleted) * freebsd-userspace/rtems/include/isc/mutex.h (deleted) * freebsd-userspace/rtems/include/isc/net.h (deleted) * freebsd-userspace/rtems/include/isc/netaddr.h (deleted) * freebsd-userspace/rtems/include/isc/netscope.h (deleted) * freebsd-userspace/rtems/include/isc/offset.h (deleted) * freebsd-userspace/rtems/include/isc/once.h (deleted) * freebsd-userspace/rtems/include/isc/print.h (deleted) * freebsd-userspace/rtems/include/isc/region.h (deleted) * freebsd-userspace/rtems/include/isc/result.h (deleted) * freebsd-userspace/rtems/include/isc/sockaddr.h (deleted) * freebsd-userspace/rtems/include/isc/strerror.h (deleted) * freebsd-userspace/rtems/include/isc/string.h (deleted) * freebsd-userspace/rtems/include/isc/types.h (deleted) * freebsd-userspace/rtems/include/isc/util.h (deleted) * freebsd-userspace/rtems/include/pthread_private.h (deleted) * freebsd-userspace/rtems/rtems-get_curthread.c (deleted) * freebsd-userspace/rtems/rtems-uthread_init.c (deleted) * freebsd-userspace/sys/net/ethernet.h (deleted) * freebsd/include/arpa/inet.h (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/arpa/nameser_compat.h (modified) * freebsd/include/db.h (modified) * freebsd/include/err.h (modified) * freebsd/include/netdb.h (modified) * freebsd/include/nsswitch.h (modified) * freebsd/include/res_update.h (modified) * freebsd/include/resolv.h (modified) * freebsd/include/rpcsvc/nis_db.h (added) * freebsd/include/rpcsvc/nis_tags.h (added) * freebsd/include/rpcsvc/nislib.h (added) * freebsd/include/rpcsvc/yp_prot.h (added) * freebsd/include/rpcsvc/ypclnt.h (added) * freebsd/kern/kern_condvar.c (deleted) * freebsd/lib/libc/db/btree/bt_close.c (modified) * freebsd/lib/libc/db/btree/bt_conv.c (modified) * freebsd/lib/libc/db/btree/bt_debug.c (modified) * freebsd/lib/libc/db/btree/bt_delete.c (modified) * freebsd/lib/libc/db/btree/bt_get.c (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_overflow.c (modified) * freebsd/lib/libc/db/btree/bt_page.c (modified) * freebsd/lib/libc/db/btree/bt_put.c (modified) * freebsd/lib/libc/db/btree/bt_search.c (modified) * freebsd/lib/libc/db/btree/bt_seq.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/btree/bt_utils.c (modified) * freebsd/lib/libc/db/db/db.c (modified) * freebsd/lib/libc/db/mpool/mpool.c (modified) * freebsd/lib/libc/db/recno/rec_close.c (modified) * freebsd/lib/libc/db/recno/rec_delete.c (modified) * freebsd/lib/libc/db/recno/rec_get.c (modified) * freebsd/lib/libc/db/recno/rec_open.c (modified) * freebsd/lib/libc/db/recno/rec_put.c (modified) * freebsd/lib/libc/db/recno/rec_search.c (modified) * freebsd/lib/libc/db/recno/rec_seq.c (modified) * freebsd/lib/libc/db/recno/rec_utils.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/include/isc/eventlib.h (modified) * freebsd/lib/libc/include/isc/platform.h (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/port_before.h (modified) * freebsd/lib/libc/include/resolv_mt.h (modified) * freebsd/lib/libc/include/spinlock.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_cidr_ntop.c (modified) * freebsd/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_net_ntop.c (modified) * freebsd/lib/libc/inet/inet_net_pton.c (modified) * freebsd/lib/libc/inet/inet_neta.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) * freebsd/lib/libc/inet/nsap_addr.c (modified) * freebsd/lib/libc/isc/ev_streams.c (modified) * freebsd/lib/libc/isc/eventlib_p.h (modified) * freebsd/lib/libc/nameser/ns_name.c (modified) * freebsd/lib/libc/nameser/ns_parse.c (modified) * freebsd/lib/libc/nameser/ns_print.c (modified) * freebsd/lib/libc/nameser/ns_samedomain.c (modified) * freebsd/lib/libc/net/base64.c (modified) * freebsd/lib/libc/net/ether_addr.c (modified) * freebsd/lib/libc/net/gai_strerror.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/gethostnamadr.c (modified) * freebsd/lib/libc/net/getifaddrs.c (modified) * freebsd/lib/libc/net/getifmaddrs.c (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbyht.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getnetnamadr.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/if_indextoname.c (modified) * freebsd/lib/libc/net/if_nameindex.c (modified) * freebsd/lib/libc/net/if_nametoindex.c (modified) * freebsd/lib/libc/net/linkaddr.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/recv.c (modified) * freebsd/lib/libc/net/send.c (modified) * freebsd/lib/libc/resolv/h_errno.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/mtctxres.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_mkupdate.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_state.c (modified) * freebsd/lib/libc/resolv/res_update.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libipsec/ipsec_dump_policy.c (modified) * freebsd/lib/libipsec/ipsec_get_policylen.c (modified) * freebsd/lib/libipsec/ipsec_strerror.c (modified) * freebsd/lib/libipsec/pfkey.c (modified) * freebsd/lib/libipsec/pfkey_dump.c (modified) * freebsd/lib/libipsec/policy_parse.y (modified) * freebsd/lib/libipsec/policy_token.l (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/lib/libmemstat/memstat.h (modified) * freebsd/lib/libmemstat/memstat_all.c (modified) * freebsd/lib/libmemstat/memstat_malloc.c (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/expand_number.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/lib/libutil/trimdomain.c (modified) * freebsd/net/ethernet.h (deleted) * freebsd/net/if.h (deleted) * freebsd/net/if_arp.h (deleted) * freebsd/net/if_dl.h (deleted) * freebsd/net/if_types.h (deleted) * freebsd/net/route.h (deleted) * freebsd/netatalk/at.h (deleted) * freebsd/netinet/icmp6.h (deleted) * freebsd/netinet/if_ether.h (deleted) * freebsd/netinet/igmp.h (deleted) * freebsd/netinet/in.h (deleted) * freebsd/netinet/in_cksum.c (deleted) * freebsd/netinet/ip.h (deleted) * freebsd/netinet/ip6.h (deleted) * freebsd/netinet/ip_icmp.h (deleted) * freebsd/netinet/tcp.h (deleted) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/dhclient/privsep.h (modified) * freebsd/sbin/ifconfig/af_atalk.c (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifcarp.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifconfig.h (modified) * freebsd/sbin/ifconfig/ifgif.c (modified) * freebsd/sbin/ifconfig/ifgre.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmac.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/ifconfig/ifvlan.c (modified) * freebsd/sbin/ifconfig/regdomain.h (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/arm/arm/in_cksum.c (modified) * freebsd/sys/arm/arm/legacy.c (added) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/arm/include/machine/in_cksum.h (modified) * freebsd/sys/arm/include/machine/legacyvar.h (modified) * freebsd/sys/arm/pci/pci_bus.c (modified) * freebsd/sys/avr/avr/in_cksum.c (added) * freebsd/sys/avr/avr/legacy.c (added) * freebsd/sys/avr/include/machine/in_cksum.h (modified) * freebsd/sys/avr/include/machine/legacyvar.h (added) * freebsd/sys/avr/include/machine/pci_cfgreg.h (moved) * freebsd/sys/avr/pci/pci_bus.c (modified) * freebsd/sys/bfin/bfin/in_cksum.c (added) * freebsd/sys/bfin/bfin/legacy.c (added) * freebsd/sys/bfin/include/machine/in_cksum.h (modified) * freebsd/sys/bfin/include/machine/legacyvar.h (added) * freebsd/sys/bfin/include/machine/pci_cfgreg.h (added) * freebsd/sys/bfin/pci/pci_bus.c (added) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/bsm/audit_kevents.h (modified) * freebsd/sys/cam/ata/ata_all.h (modified) * freebsd/sys/cam/cam.c (modified) * freebsd/sys/cam/cam.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_xpt_sim.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/cam/scsi/scsi_da.h (modified) * freebsd/sys/contrib/altq/altq/altq.h (modified) * freebsd/sys/contrib/altq/altq/altq_cbq.c (modified) * freebsd/sys/contrib/altq/altq/altq_cbq.h (modified) * freebsd/sys/contrib/altq/altq/altq_cdnr.c (modified) * freebsd/sys/contrib/altq/altq/altq_cdnr.h (modified) * freebsd/sys/contrib/altq/altq/altq_classq.h (modified) * freebsd/sys/contrib/altq/altq/altq_hfsc.c (modified) * freebsd/sys/contrib/altq/altq/altq_hfsc.h (modified) * freebsd/sys/contrib/altq/altq/altq_priq.c (modified) * freebsd/sys/contrib/altq/altq/altq_priq.h (modified) * freebsd/sys/contrib/altq/altq/altq_red.c (modified) * freebsd/sys/contrib/altq/altq/altq_red.h (modified) * freebsd/sys/contrib/altq/altq/altq_rio.c (modified) * freebsd/sys/contrib/altq/altq/altq_rio.h (modified) * freebsd/sys/contrib/altq/altq/altq_rmclass.c (modified) * freebsd/sys/contrib/altq/altq/altq_rmclass.h (modified) * freebsd/sys/contrib/altq/altq/altq_rmclass_debug.h (modified) * freebsd/sys/contrib/altq/altq/altq_subr.c (modified) * freebsd/sys/contrib/altq/altq/altq_var.h (modified) * freebsd/sys/contrib/altq/altq/altqconf.h (modified) * freebsd/sys/contrib/altq/altq/if_altq.h (modified) * freebsd/sys/contrib/pf/net/if_pflog.c (modified) * freebsd/sys/contrib/pf/net/if_pflog.h (modified) * freebsd/sys/contrib/pf/net/if_pfsync.c (modified) * freebsd/sys/contrib/pf/net/if_pfsync.h (modified) * freebsd/sys/contrib/pf/net/pf.c (modified) * freebsd/sys/contrib/pf/net/pf_if.c (modified) * freebsd/sys/contrib/pf/net/pf_ioctl.c (modified) * freebsd/sys/contrib/pf/net/pf_mtag.h (modified) * freebsd/sys/contrib/pf/net/pf_norm.c (modified) * freebsd/sys/contrib/pf/net/pf_osfp.c (modified) * freebsd/sys/contrib/pf/net/pf_ruleset.c (modified) * freebsd/sys/contrib/pf/net/pf_subr.c (modified) * freebsd/sys/contrib/pf/net/pf_table.c (modified) * freebsd/sys/contrib/pf/net/pfvar.h (modified) * freebsd/sys/contrib/pf/netinet/in4_cksum.c (modified) * freebsd/sys/crypto/blowfish/bf_ecb.c (modified) * freebsd/sys/crypto/blowfish/bf_enc.c (modified) * freebsd/sys/crypto/blowfish/bf_skey.c (modified) * freebsd/sys/crypto/camellia/camellia-api.c (modified) * freebsd/sys/crypto/camellia/camellia.c (modified) * freebsd/sys/crypto/des/des_ecb.c (modified) * freebsd/sys/crypto/des/des_enc.c (modified) * freebsd/sys/crypto/des/des_locl.h (modified) * freebsd/sys/crypto/des/des_setkey.c (modified) * freebsd/sys/crypto/rc4/rc4.c (modified) * freebsd/sys/crypto/rc4/rc4.h (modified) * freebsd/sys/crypto/rijndael/rijndael-alg-fst.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.h (modified) * freebsd/sys/crypto/rijndael/rijndael-api.c (modified) * freebsd/sys/crypto/sha1.c (modified) * freebsd/sys/crypto/sha1.h (modified) * freebsd/sys/crypto/sha2/sha2.c (modified) * freebsd/sys/crypto/sha2/sha2.h (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bce/if_bcereg.h (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.h (modified) * freebsd/sys/dev/e1000/e1000_82540.c (modified) * freebsd/sys/dev/e1000/e1000_82541.c (modified) * freebsd/sys/dev/e1000/e1000_82541.h (modified) * freebsd/sys/dev/e1000/e1000_82542.c (modified) * freebsd/sys/dev/e1000/e1000_82543.c (modified) * freebsd/sys/dev/e1000/e1000_82543.h (modified) * freebsd/sys/dev/e1000/e1000_82571.c (modified) * freebsd/sys/dev/e1000/e1000_82571.h (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_api.h (modified) * freebsd/sys/dev/e1000/e1000_defines.h (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.h (modified) * freebsd/sys/dev/e1000/e1000_mac.c (modified) * freebsd/sys/dev/e1000/e1000_mac.h (modified) * freebsd/sys/dev/e1000/e1000_manage.c (modified) * freebsd/sys/dev/e1000/e1000_manage.h (modified) * freebsd/sys/dev/e1000/e1000_mbx.c (modified) * freebsd/sys/dev/e1000/e1000_mbx.h (modified) * freebsd/sys/dev/e1000/e1000_nvm.c (modified) * freebsd/sys/dev/e1000/e1000_nvm.h (modified) * freebsd/sys/dev/e1000/e1000_osdep.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/e1000_phy.c (modified) * freebsd/sys/dev/e1000/e1000_phy.h (modified) * freebsd/sys/dev/e1000/e1000_regs.h (modified) * freebsd/sys/dev/e1000/e1000_vf.c (modified) * freebsd/sys/dev/e1000/e1000_vf.h (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_igb.c (modified) * freebsd/sys/dev/e1000/if_lem.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/led/led.c (modified) * freebsd/sys/dev/mii/brgphy.c (modified) * freebsd/sys/dev/mii/brgphyreg.h (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mii/icsphyreg.h (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/mii/mii.h (modified) * freebsd/sys/dev/mii/mii_physubr.c (modified) * freebsd/sys/dev/mii/miivar.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/random/harvest.c (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/smc/if_smcreg.h (modified) * freebsd/sys/dev/smc/if_smcvar.h (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ehci.h (modified) * freebsd/sys/dev/usb/controller/ehcireg.h (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/ohci.h (modified) * freebsd/sys/dev/usb/controller/ohcireg.h (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.h (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/ufm_ioctl.h (modified) * freebsd/sys/dev/usb/usb.h (modified) * freebsd/sys/dev/usb/usb_bus.h (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_busdma.h (modified) * freebsd/sys/dev/usb/usb_cdc.h (modified) * freebsd/sys/dev/usb/usb_controller.h (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_core.h (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_debug.h (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_dev.h (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_device.h (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_dynamic.h (modified) * freebsd/sys/dev/usb/usb_endian.h (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_freebsd.h (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_generic.h (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_hub.h (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_mbuf.h (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_msctest.h (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_process.h (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_request.h (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_transfer.h (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/dev/usb/usb_util.h (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/dev/usb/usbdi_util.h (modified) * freebsd/sys/dev/usb/usbhid.h (modified) * freebsd/sys/fs/devfs/devfs_int.h (modified) * freebsd/sys/h8300/h8300/in_cksum.c (added) * freebsd/sys/h8300/h8300/legacy.c (added) * freebsd/sys/h8300/include/machine/in_cksum.h (modified) * freebsd/sys/h8300/include/machine/legacyvar.h (added) * freebsd/sys/h8300/include/machine/pci_cfgreg.h (added) * freebsd/sys/h8300/pci/pci_bus.c (added) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/i386/i386/legacy.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/in_cksum.h (modified) * freebsd/sys/i386/include/machine/legacyvar.h (added) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/i386/include/machine/pci_cfgreg.h (added) * freebsd/sys/i386/include/machine/specialreg.h (modified) * freebsd/sys/i386/pci/pci_bus.c (added) * freebsd/sys/ioccom.h (deleted) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/isa/pnpvar.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_descrip.c (modified) * freebsd/sys/kern/kern_environment.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_ntptime.c (modified) * freebsd/sys/kern/kern_proc.c (modified) * freebsd/sys/kern/kern_prot.c (modified) * freebsd/sys/kern/kern_resource.c (modified) * freebsd/sys/kern/kern_subr.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_tc.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_bufring.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_rman.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/libkern/arc4random.c (modified) * freebsd/sys/libkern/fls.c (modified) * freebsd/sys/libkern/inet_ntoa.c (modified) * freebsd/sys/libkern/random.c (modified) * freebsd/sys/lm32/include/machine/in_cksum.h (added) * freebsd/sys/lm32/include/machine/legacyvar.h (added) * freebsd/sys/lm32/include/machine/pci_cfgreg.h (added) * freebsd/sys/lm32/lm32/in_cksum.c (added) * freebsd/sys/lm32/lm32/legacy.c (added) * freebsd/sys/lm32/pci/pci_bus.c (added) * freebsd/sys/m32c/include/machine/in_cksum.h (added) * freebsd/sys/m32c/include/machine/legacyvar.h (added) * freebsd/sys/m32c/include/machine/pci_cfgreg.h (added) * freebsd/sys/m32c/m32c/in_cksum.c (added) * freebsd/sys/m32c/m32c/legacy.c (added) * freebsd/sys/m32c/pci/pci_bus.c (added) * freebsd/sys/m32r/include/machine/in_cksum.h (added) * freebsd/sys/m32r/include/machine/legacyvar.h (added) * freebsd/sys/m32r/include/machine/pci_cfgreg.h (added) * freebsd/sys/m32r/m32r/in_cksum.c (added) * freebsd/sys/m32r/m32r/legacy.c (added) * freebsd/sys/m32r/pci/pci_bus.c (added) * freebsd/sys/m68k/include/machine/in_cksum.h (moved) * freebsd/sys/m68k/include/machine/legacyvar.h (added) * freebsd/sys/m68k/include/machine/pci_cfgreg.h (added) * freebsd/sys/m68k/m68k/in_cksum.c (added) * freebsd/sys/m68k/m68k/legacy.c (added) * freebsd/sys/m68k/pci/pci_bus.c (added) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/mips/include/machine/in_cksum.h (added) * freebsd/sys/mips/include/machine/legacyvar.h (added) * freebsd/sys/mips/include/machine/pci_cfgreg.h (added) * freebsd/sys/mips/mips/in_cksum.c (modified) * freebsd/sys/mips/mips/legacy.c (added) * freebsd/sys/mips/pci/pci_bus.c (added) * freebsd/sys/mman.h (deleted) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf.h (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_buffer.h (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bpf_jitter.h (modified) * freebsd/sys/net/bpf_zerocopy.h (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/bridgestp.h (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/fddi.h (modified) * freebsd/sys/net/firewire.h (modified) * freebsd/sys/net/flowtable.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if.h (modified) * freebsd/sys/net/if_arc.h (modified) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_atmsubr.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_bridgevar.h (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_dl.h (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_ef.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_faith.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gif.h (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_llc.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_mib.c (modified) * freebsd/sys/net/if_sppp.h (modified) * freebsd/sys/net/if_spppfr.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_stf.h (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tap.h (modified) * freebsd/sys/net/if_tapvar.h (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_tun.h (modified) * freebsd/sys/net/if_types.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/iso88025.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/netisr.h (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfkeyv2.h (modified) * freebsd/sys/net/ppp_defs.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/radix_mpath.h (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_cb.h (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net/slcompress.h (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net/zlib.c (modified) * freebsd/sys/net/zlib.h (modified) * freebsd/sys/net80211/_ieee80211.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_acl.c (modified) * freebsd/sys/net80211/ieee80211_action.c (modified) * freebsd/sys/net80211/ieee80211_action.h (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.h (modified) * freebsd/sys/net80211/ieee80211_ageq.c (modified) * freebsd/sys/net80211/ieee80211_ageq.h (modified) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_amrr.h (modified) * freebsd/sys/net80211/ieee80211_crypto.c (modified) * freebsd/sys/net80211/ieee80211_crypto.h (modified) * freebsd/sys/net80211/ieee80211_crypto_ccmp.c (modified) * freebsd/sys/net80211/ieee80211_crypto_none.c (modified) * freebsd/sys/net80211/ieee80211_crypto_tkip.c (modified) * freebsd/sys/net80211/ieee80211_crypto_wep.c (modified) * freebsd/sys/net80211/ieee80211_ddb.c (modified) * freebsd/sys/net80211/ieee80211_dfs.c (modified) * freebsd/sys/net80211/ieee80211_dfs.h (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_hostap.h (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.h (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_mesh.h (modified) * freebsd/sys/net80211/ieee80211_monitor.c (modified) * freebsd/sys/net80211/ieee80211_monitor.h (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_node.h (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_phy.c (modified) * freebsd/sys/net80211/ieee80211_phy.h (modified) * freebsd/sys/net80211/ieee80211_power.c (modified) * freebsd/sys/net80211/ieee80211_power.h (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_radiotap.c (modified) * freebsd/sys/net80211/ieee80211_radiotap.h (modified) * freebsd/sys/net80211/ieee80211_ratectl.c (modified) * freebsd/sys/net80211/ieee80211_ratectl_none.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.h (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.h (modified) * freebsd/sys/net80211/ieee80211_scan.c (modified) * freebsd/sys/net80211/ieee80211_scan.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.h (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_superg.h (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_tdma.h (modified) * freebsd/sys/net80211/ieee80211_var.h (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/net80211/ieee80211_wds.h (modified) * freebsd/sys/net80211/ieee80211_xauth.c (modified) * freebsd/sys/netatalk/aarp.c (modified) * freebsd/sys/netatalk/aarp.h (modified) * freebsd/sys/netatalk/at.h (modified) * freebsd/sys/netatalk/at_control.c (modified) * freebsd/sys/netatalk/at_extern.h (modified) * freebsd/sys/netatalk/at_proto.c (modified) * freebsd/sys/netatalk/at_rmx.c (modified) * freebsd/sys/netatalk/at_var.h (modified) * freebsd/sys/netatalk/ddp.h (modified) * freebsd/sys/netatalk/ddp_input.c (modified) * freebsd/sys/netatalk/ddp_output.c (modified) * freebsd/sys/netatalk/ddp_pcb.c (modified) * freebsd/sys/netatalk/ddp_pcb.h (modified) * freebsd/sys/netatalk/ddp_usrreq.c (modified) * freebsd/sys/netatalk/ddp_var.h (modified) * freebsd/sys/netatalk/endian.h (modified) * freebsd/sys/netatalk/phase2.h (modified) * freebsd/sys/netinet/accf_data.c (modified) * freebsd/sys/netinet/accf_dns.c (modified) * freebsd/sys/netinet/accf_http.c (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/if_atm.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/if_ether.h (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp.h (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in.h (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_gif.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_rmx.c (modified) * freebsd/sys/netinet/in_systm.h (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_divert.h (modified) * freebsd/sys/netinet/ip_ecn.c (modified) * freebsd/sys/netinet/ip_ecn.h (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_icmp.h (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_ipsec.c (modified) * freebsd/sys/netinet/ip_ipsec.h (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_mroute.h (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_options.h (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/ipfw/dn_heap.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_fifo.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_prio.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_qfq.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_rr.c (modified) * freebsd/sys/netinet/ipfw/dn_sched_wf2q.c (modified) * freebsd/sys/netinet/ipfw/ip_dn_glue.c (modified) * freebsd/sys/netinet/ipfw/ip_dn_io.c (modified) * freebsd/sys/netinet/ipfw/ip_dummynet.c (modified) * freebsd/sys/netinet/ipfw/ip_fw2.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_log.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_pfil.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netinet/ipfw/ip_fw_table.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias.h (modified) * freebsd/sys/netinet/libalias/alias_cuseeme.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_dummy.c (modified) * freebsd/sys/netinet/libalias/alias_ftp.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_pptp.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/libalias/alias_skinny.c (modified) * freebsd/sys/netinet/libalias/alias_smedia.c (modified) * freebsd/sys/netinet/libalias/alias_util.c (modified) * freebsd/sys/netinet/pim.h (modified) * freebsd/sys/netinet/pim_var.h (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_asconf.h (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_bsd_addr.h (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_cc_functions.h (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_crc32.c (modified) * freebsd/sys/netinet/sctp_crc32.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_lock_bsd.h (modified) * freebsd/sys/netinet/sctp_os.h (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_peeloff.c (modified) * freebsd/sys/netinet/sctp_peeloff.h (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_sysctl.h (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_timer.h (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_debug.h (modified) * freebsd/sys/netinet/tcp_fsm.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_hostcache.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_lro.h (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_offload.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/tcpip.h (modified) * freebsd/sys/netinet/toedev.h (modified) * freebsd/sys/netinet/udp.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6.h (modified) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_gif.h (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_ifattach.h (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_ipsec.c (modified) * freebsd/sys/netinet6/ip6_ipsec.h (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_mroute.h (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/ip6protosw.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6.h (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/pim6_var.h (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/raw_ip6.h (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/scope6_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/tcp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_var.h (modified) * freebsd/sys/netipsec/ah.h (modified) * freebsd/sys/netipsec/ah_var.h (modified) * freebsd/sys/netipsec/esp.h (modified) * freebsd/sys/netipsec/esp_var.h (modified) * freebsd/sys/netipsec/ipcomp.h (modified) * freebsd/sys/netipsec/ipcomp_var.h (modified) * freebsd/sys/netipsec/ipip_var.h (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec6.h (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key.h (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/key_debug.h (modified) * freebsd/sys/netipsec/key_var.h (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/keysock.h (modified) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_ipip.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/nios2/include/machine/in_cksum.h (added) * freebsd/sys/nios2/include/machine/legacyvar.h (added) * freebsd/sys/nios2/include/machine/pci_cfgreg.h (added) * freebsd/sys/nios2/nios2/in_cksum.c (added) * freebsd/sys/nios2/nios2/legacy.c (added) * freebsd/sys/nios2/pci/pci_bus.c (added) * freebsd/sys/opencrypto/cast.c (modified) * freebsd/sys/opencrypto/cast.h (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/cryptosoft.h (modified) * freebsd/sys/opencrypto/deflate.c (modified) * freebsd/sys/opencrypto/deflate.h (modified) * freebsd/sys/opencrypto/rmd160.c (modified) * freebsd/sys/opencrypto/skipjack.c (modified) * freebsd/sys/opencrypto/xform.c (modified) * freebsd/sys/opencrypto/xform.h (modified) * freebsd/sys/powerpc/include/machine/cpufunc.h (modified) * freebsd/sys/powerpc/include/machine/in_cksum.h (moved) * freebsd/sys/powerpc/include/machine/legacyvar.h (added) * freebsd/sys/powerpc/include/machine/pci_cfgreg.h (added) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/powerpc/pci/pci_bus.c (added) * freebsd/sys/powerpc/powerpc/in_cksum.c (modified) * freebsd/sys/powerpc/powerpc/legacy.c (added) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/security/mac/mac_framework.h (modified) * freebsd/sys/sh/include/machine/in_cksum.h (added) * freebsd/sys/sh/include/machine/legacyvar.h (added) * freebsd/sys/sh/include/machine/pci_cfgreg.h (added) * freebsd/sys/sh/pci/pci_bus.c (added) * freebsd/sys/sh/sh/in_cksum.c (added) * freebsd/sys/sh/sh/legacy.c (added) * freebsd/sys/socket.h (deleted) * freebsd/sys/socketvar.h (deleted) * freebsd/sys/sparc/include/machine/in_cksum.h (added) * freebsd/sys/sparc/include/machine/legacyvar.h (added) * freebsd/sys/sparc/include/machine/pci_cfgreg.h (added) * freebsd/sys/sparc/pci/pci_bus.c (added) * freebsd/sys/sparc/sparc/in_cksum.c (added) * freebsd/sys/sparc/sparc/legacy.c (added) * freebsd/sys/sparc64/include/machine/asi.h (modified) * freebsd/sys/sparc64/include/machine/cpufunc.h (modified) * freebsd/sys/sparc64/include/machine/in_cksum.h (added) * freebsd/sys/sparc64/include/machine/legacyvar.h (added) * freebsd/sys/sparc64/include/machine/pci_cfgreg.h (added) * freebsd/sys/sparc64/include/machine/pstate.h (modified) * freebsd/sys/sparc64/pci/pci_bus.c (added) * freebsd/sys/sparc64/sparc64/in_cksum.c (modified) * freebsd/sys/sparc64/sparc64/legacy.c (added) * freebsd/sys/sys/_bus_dma.h (modified) * freebsd/sys/sys/_lock.h (modified) * freebsd/sys/sys/_lockmgr.h (modified) * freebsd/sys/sys/_mutex.h (modified) * freebsd/sys/sys/_rmlock.h (modified) * freebsd/sys/sys/_rwlock.h (modified) * freebsd/sys/sys/_semaphore.h (modified) * freebsd/sys/sys/_sigset.h (modified) * freebsd/sys/sys/_sx.h (modified) * freebsd/sys/sys/_task.h (modified) * freebsd/sys/sys/_timeval.h (modified) * freebsd/sys/sys/acl.h (modified) * freebsd/sys/sys/aio.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/bitstring.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/condvar.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/cpu.h (modified) * freebsd/sys/sys/ctype.h (modified) * freebsd/sys/sys/domain.h (modified) * freebsd/sys/sys/endian.h (modified) * freebsd/sys/sys/event.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/fcntl.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/filio.h (modified) * freebsd/sys/sys/hash.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/kenv.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/kobj.h (modified) * freebsd/sys/sys/kthread.h (modified) * freebsd/sys/sys/ktr.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/limits.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/linker_set.h (modified) * freebsd/sys/sys/lock_profile.h (modified) * freebsd/sys/sys/lockmgr.h (modified) * freebsd/sys/sys/mac.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/md5.h (modified) * freebsd/sys/sys/mman.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mqueue.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/osd.h (modified) * freebsd/sys/sys/pciio.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/poll.h (modified) * freebsd/sys/sys/priority.h (modified) * freebsd/sys/sys/priv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/protosw.h (modified) * freebsd/sys/sys/queue.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/rman.h (modified) * freebsd/sys/sys/rmlock.h (modified) * freebsd/sys/sys/rtprio.h (modified) * freebsd/sys/sys/runq.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/select.h (modified) * freebsd/sys/sys/selinfo.h (modified) * freebsd/sys/sys/sf_buf.h (modified) * freebsd/sys/sys/sigio.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socket.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockio.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/sockstate.h (modified) * freebsd/sys/sys/stddef.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/syslog.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/timepps.h (modified) * freebsd/sys/sys/timetc.h (modified) * freebsd/sys/sys/timex.h (modified) * freebsd/sys/sys/tree.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/ttycom.h (modified) * freebsd/sys/sys/ttydevsw.h (modified) * freebsd/sys/sys/ttydisc.h (modified) * freebsd/sys/sys/ttyhook.h (modified) * freebsd/sys/sys/ttyqueue.h (modified) * freebsd/sys/sys/ucred.h (modified) * freebsd/sys/sys/un.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sysctl.h (deleted) * freebsd/sys/syslimits.h (deleted) * freebsd/sys/syslog.h (deleted) * freebsd/sys/uio.h (deleted) * freebsd/sys/v850/include/machine/in_cksum.h (moved) * freebsd/sys/v850/include/machine/legacyvar.h (added) * freebsd/sys/v850/include/machine/pci_cfgreg.h (added) * freebsd/sys/v850/pci/pci_bus.c (added) * freebsd/sys/v850/v850/in_cksum.c (added) * freebsd/sys/v850/v850/legacy.c (added) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/time.h (deleted) * freebsd/usr.bin/netstat/atalk.c (modified) * freebsd/usr.bin/netstat/bpf.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mbuf.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * rtemsbsd/bfin/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/freebsd/machine/_align.h (deleted) * rtemsbsd/freebsd/machine/_stdint.h (deleted) * rtemsbsd/freebsd/machine/_types.h (deleted) * rtemsbsd/freebsd/machine/param.h (deleted) * rtemsbsd/freebsd/machine/resource.h (deleted) * rtemsbsd/freebsd/machine/rtems-bsd-select.h (deleted) * rtemsbsd/freebsd/sys/_iovec.h (deleted) * rtemsbsd/freebsd/sys/cdefs.h (deleted) * rtemsbsd/freebsd/sys/signal.h (deleted) * rtemsbsd/freebsd/sys/uio.h (deleted) * rtemsbsd/h8300/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/include/machine/_bus.h (modified) * rtemsbsd/include/machine/_limits.h (modified) * rtemsbsd/include/machine/bus.h (modified) * rtemsbsd/include/machine/bus_dma.h (modified) * rtemsbsd/include/machine/bus_space-i386.h (modified) * rtemsbsd/include/machine/elf.h (modified) * rtemsbsd/include/machine/mutex.h (modified) * rtemsbsd/include/machine/pcb.h (modified) * rtemsbsd/include/machine/resource.h (modified) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (modified) * rtemsbsd/include/machine/rtems-bsd-config.h.in (modified) * rtemsbsd/include/machine/rtems-bsd-devicet.h (modified) * rtemsbsd/include/machine/rtems-bsd-endian.h (added) * rtemsbsd/include/machine/rtems-bsd-param.h (moved) * rtemsbsd/include/machine/rtems-bsd-symbols.h (modified) * rtemsbsd/include/machine/rtems-bsd-syscall-api.h (added) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) * rtemsbsd/include/machine/smp.h (modified) * rtemsbsd/include/machine/vm.h (modified) * rtemsbsd/include/poll.h (modified) * rtemsbsd/include/pthread_np.h (moved) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/include/rtems/bsd/local/vnode_if.h (modified) * rtemsbsd/include/rtems/bsd/sys/_types.h (modified) * rtemsbsd/include/rtems/bsd/sys/errno.h (modified) * rtemsbsd/include/rtems/bsd/sys/lock.h (modified) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/include/rtems/bsd/sys/resource.h (modified) * rtemsbsd/include/rtems/bsd/sys/time.h (modified) * rtemsbsd/include/rtems/bsd/sys/timespec.h (modified) * rtemsbsd/include/rtems/bsd/sys/types.h (modified) * rtemsbsd/include/rtems/bsd/sys/unistd.h (modified) * rtemsbsd/include/sys/_pthreadtypes.h (modified) * rtemsbsd/include/sys/signalvar.h (modified) * rtemsbsd/include/vm/vm_extern.h (moved) * rtemsbsd/include/vm/vm_kern.h (moved) * rtemsbsd/include/vm/vm_object.h (moved) * rtemsbsd/include/vm/vm_page.h (moved) * rtemsbsd/lm32/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/local/bus_if.c (modified) * rtemsbsd/local/cryptodev_if.c (modified) * rtemsbsd/local/device_if.c (modified) * rtemsbsd/local/miibus_if.c (modified) * rtemsbsd/local/pci_if.c (modified) * rtemsbsd/local/pcib_if.c (modified) * rtemsbsd/local/usb_if.c (modified) * rtemsbsd/m32c/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/m32r/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/m68k/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/nios2/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/rtems/ipsec_get_policylen.c (modified) * rtemsbsd/rtems/kvm_private.h (modified) * rtemsbsd/rtems/rtems-bsd-assert.c (modified) * rtemsbsd/rtems/rtems-bsd-autoconf.c (modified) * rtemsbsd/rtems/rtems-bsd-bus-dma-mbuf.c (modified) * rtemsbsd/rtems/rtems-bsd-bus-dma.c (modified) * rtemsbsd/rtems/rtems-bsd-cam.c (modified) * rtemsbsd/rtems/rtems-bsd-condvar.c (modified) * rtemsbsd/rtems/rtems-bsd-conf.c (modified) * rtemsbsd/rtems/rtems-bsd-copyinout.c (modified) * rtemsbsd/rtems/rtems-bsd-delay.c (modified) * rtemsbsd/rtems/rtems-bsd-descrip.c (modified) * rtemsbsd/rtems/rtems-bsd-generic.c (modified) * rtemsbsd/rtems/rtems-bsd-init-with-irq.c (modified) * rtemsbsd/rtems/rtems-bsd-init.c (modified) * rtemsbsd/rtems/rtems-bsd-jail.c (modified) * rtemsbsd/rtems/rtems-bsd-lock.c (modified) * rtemsbsd/rtems/rtems-bsd-log.c (modified) * rtemsbsd/rtems/rtems-bsd-malloc.c (modified) * rtemsbsd/rtems/rtems-bsd-mutex.c (modified) * rtemsbsd/rtems/rtems-bsd-nexus.c (modified) * rtemsbsd/rtems/rtems-bsd-page.c (modified) * rtemsbsd/rtems/rtems-bsd-panic.c (modified) * rtemsbsd/rtems/rtems-bsd-pci_bus.c (added) * rtemsbsd/rtems/rtems-bsd-pci_cfgreg.c (modified) * rtemsbsd/rtems/rtems-bsd-rwlock.c (modified) * rtemsbsd/rtems/rtems-bsd-shell.c (modified) * rtemsbsd/rtems/rtems-bsd-signal.c (modified) * rtemsbsd/rtems/rtems-bsd-smp.c (modified) * rtemsbsd/rtems/rtems-bsd-subr_param.c (modified) * rtemsbsd/rtems/rtems-bsd-support.c (modified) * rtemsbsd/rtems/rtems-bsd-sx.c (modified) * rtemsbsd/rtems/rtems-bsd-synch.c (modified) * rtemsbsd/rtems/rtems-bsd-syscall-api.c (added) * rtemsbsd/rtems/rtems-bsd-syscalls.c (modified) * rtemsbsd/rtems/rtems-bsd-sysctl.c (modified) * rtemsbsd/rtems/rtems-bsd-sysctlbyname.c (modified) * rtemsbsd/rtems/rtems-bsd-sysctlnametomib.c (modified) * rtemsbsd/rtems/rtems-bsd-taskqueue.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) * rtemsbsd/rtems/rtems-bsd-thread0-ucred.c (modified) * rtemsbsd/rtems/rtems-bsd-timesupport.c (modified) * rtemsbsd/rtems/rtems-bsd-vm_glue.c (modified) * rtemsbsd/rtems/rtems-net-setup.c (modified) * rtemsbsd/rtems/rtems-syspoll.c (modified) * rtemsbsd/rtems/rtems-uthread_kqueue.c (modified) * rtemsbsd/rtems/syslog.c (modified) * rtemsbsd/sh/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/sparc/include/freebsd/machine/cpufunc.h (deleted) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc24xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (modified) * rtemsbsd/v850/include/freebsd/machine/cpufunc.h (deleted) * services/librpc/src/rpc/auth_none.c (modified) * services/librpc/src/rpc/auth_unix.c (modified) * services/librpc/src/rpc/authunix_prot.c (modified) * services/librpc/src/rpc/bindresvport.c (modified) * services/librpc/src/rpc/clnt_generic.c (modified) * services/librpc/src/rpc/clnt_perror.c (modified) * services/librpc/src/rpc/clnt_raw.c (modified) * services/librpc/src/rpc/clnt_simple.c (modified) * services/librpc/src/rpc/clnt_tcp.c (modified) * services/librpc/src/rpc/clnt_udp.c (modified) * services/librpc/src/rpc/get_myaddress.c (modified) * services/librpc/src/rpc/getrpcent.c (modified) * services/librpc/src/rpc/getrpcport.c (modified) * services/librpc/src/rpc/netname.c (modified) * services/librpc/src/rpc/netnamer.c (modified) * services/librpc/src/rpc/pmap_clnt.c (modified) * services/librpc/src/rpc/pmap_getmaps.c (modified) * services/librpc/src/rpc/pmap_getport.c (modified) * services/librpc/src/rpc/pmap_prot.c (modified) * services/librpc/src/rpc/pmap_prot2.c (modified) * services/librpc/src/rpc/rpc_callmsg.c (modified) * services/librpc/src/rpc/rpc_commondata.c (modified) * services/librpc/src/rpc/rpc_dtablesize.c (modified) * services/librpc/src/rpc/rpc_prot.c (modified) * services/librpc/src/rpc/rpcdname.c (modified) * services/librpc/src/rpc/rtems_portmapper.c (modified) * services/librpc/src/rpc/rtems_rpc.c (modified) * services/librpc/src/rpc/rtime.c (modified) * services/librpc/src/rpc/svc.c (modified) * services/librpc/src/rpc/svc_auth.c (modified) * services/librpc/src/rpc/svc_auth_unix.c (modified) * services/librpc/src/rpc/svc_raw.c (modified) * services/librpc/src/rpc/svc_run.c (modified) * services/librpc/src/rpc/svc_simple.c (modified) * services/librpc/src/rpc/svc_tcp.c (modified) * services/librpc/src/rpc/svc_udp.c (modified) * services/librpc/src/xdr/xdr.c (modified) * services/librpc/src/xdr/xdr_array.c (modified) * services/librpc/src/xdr/xdr_float.c (modified) * services/librpc/src/xdr/xdr_mem.c (modified) * services/librpc/src/xdr/xdr_rec.c (modified) * services/librpc/src/xdr/xdr_reference.c (modified) * services/librpc/src/xdr/xdr_sizeof.c (modified) * services/librpc/src/xdr/xdr_stdio.c (modified) * testsuite/Makefile (deleted) * testsuite/include/rtems/bsd/test/default-init.h (moved) * testsuite/include/rtems/bsd/test/nic-sysinit.h (modified) * testsuite/init01/.gitignore (deleted) * testsuite/init01/Makefile (deleted) * testsuite/init01/test_main.c (modified) * testsuite/loopback01/.gitignore (deleted) * testsuite/loopback01/Makefile (deleted) * testsuite/loopback01/test_main.c (modified) * testsuite/mghttpd01/.gitignore (deleted) * testsuite/mghttpd01/Makefile (deleted) * testsuite/netshell01/.gitignore (deleted) * testsuite/netshell01/Makefile (deleted) * testsuite/netshell01/test_main.c (modified) * testsuite/swi01/Makefile (deleted) * testsuite/swi01/init.c (modified) * testsuite/swi01/swi_test.c (modified) * testsuite/timeout01/Makefile (deleted) * testsuite/timeout01/init.c (modified) * testsuite/timeout01/timeout_helper.c (modified) * testsuite/timeout01/timeout_test.c (modified) * testsuite/usb01/Makefile (deleted) * testsuite/usb01/init.c (modified) * testsuite/usb01/usb-sysinit.h (modified) Update files to match FreeBSD layout Add compatibility with Newlib ... Wed, 09 Oct 2013 20:42:09 GMT Sebastian Huber [bceabc9] * freebsd/include/arpa/ftp.h (moved) * freebsd/include/arpa/inet.h (moved) * freebsd/include/arpa/nameser.h (moved) * freebsd/include/arpa/nameser_compat.h (moved) * freebsd/include/db.h (moved) * freebsd/include/err.h (moved) * freebsd/include/ifaddrs.h (moved) * freebsd/include/mpool.h (moved) * freebsd/include/netconfig.h (moved) * freebsd/include/netdb.h (moved) * freebsd/include/nlist.h (moved) * freebsd/include/nsswitch.h (moved) * freebsd/include/res_update.h (moved) * freebsd/include/resolv.h (moved) * freebsd/include/rpc/auth.h (moved) * freebsd/include/rpc/auth_des.h (moved) * freebsd/include/rpc/auth_unix.h (moved) * freebsd/include/rpc/clnt.h (moved) * freebsd/include/rpc/clnt_soc.h (moved) * freebsd/include/rpc/clnt_stat.h (moved) * freebsd/include/rpc/pmap_clnt.h (moved) * freebsd/include/rpc/pmap_prot.h (moved) * freebsd/include/rpc/rpc.h (moved) * freebsd/include/rpc/rpc_msg.h (moved) * freebsd/include/rpc/rpcb_clnt.h (moved) * freebsd/include/rpc/rpcb_prot.x (moved) * freebsd/include/rpc/rpcent.h (moved) * freebsd/include/rpc/svc.h (moved) * freebsd/include/rpc/svc_auth.h (moved) * freebsd/include/rpc/svc_soc.h (moved) * freebsd/include/rpc/xdr.h (moved) * freebsd/include/sysexits.h (moved) * freebsd/lib/libc/db/btree/bt_close.c (moved) * freebsd/lib/libc/db/btree/bt_conv.c (moved) * freebsd/lib/libc/db/btree/bt_debug.c (moved) * freebsd/lib/libc/db/btree/bt_delete.c (moved) * freebsd/lib/libc/db/btree/bt_get.c (moved) * freebsd/lib/libc/db/btree/bt_open.c (moved) * freebsd/lib/libc/db/btree/bt_overflow.c (moved) * freebsd/lib/libc/db/btree/bt_page.c (moved) * freebsd/lib/libc/db/btree/bt_put.c (moved) * freebsd/lib/libc/db/btree/bt_search.c (moved) * freebsd/lib/libc/db/btree/bt_seq.c (moved) * freebsd/lib/libc/db/btree/bt_split.c (moved) * freebsd/lib/libc/db/btree/bt_utils.c (moved) * freebsd/lib/libc/db/btree/btree.h (moved) * freebsd/lib/libc/db/btree/extern.h (moved) * freebsd/lib/libc/db/db/db.c (moved) * freebsd/lib/libc/db/mpool/mpool-compat.c (moved) * freebsd/lib/libc/db/mpool/mpool.c (moved) * freebsd/lib/libc/db/recno/extern.h (moved) * freebsd/lib/libc/db/recno/rec_close.c (moved) * freebsd/lib/libc/db/recno/rec_delete.c (moved) * freebsd/lib/libc/db/recno/rec_get.c (moved) * freebsd/lib/libc/db/recno/rec_open.c (moved) * freebsd/lib/libc/db/recno/rec_put.c (moved) * freebsd/lib/libc/db/recno/rec_search.c (moved) * freebsd/lib/libc/db/recno/rec_seq.c (moved) * freebsd/lib/libc/db/recno/rec_utils.c (moved) * freebsd/lib/libc/db/recno/recno.h (moved) * freebsd/lib/libc/gen/err.c (moved) * freebsd/lib/libc/gen/gethostname.c (moved) * freebsd/lib/libc/include/isc/eventlib.h (moved) * freebsd/lib/libc/include/isc/list.h (moved) * freebsd/lib/libc/include/isc/platform.h (moved) * freebsd/lib/libc/include/libc_private.h (moved) * freebsd/lib/libc/include/namespace.h (moved) * freebsd/lib/libc/include/nss_tls.h (moved) * freebsd/lib/libc/include/port_after.h (moved) * freebsd/lib/libc/include/port_before.h (moved) * freebsd/lib/libc/include/reentrant.h (moved) * freebsd/lib/libc/include/resolv_mt.h (moved) * freebsd/lib/libc/include/spinlock.h (moved) * freebsd/lib/libc/include/un-namespace.h (moved) * freebsd/lib/libc/inet/inet_addr.c (moved) * freebsd/lib/libc/inet/inet_cidr_ntop.c (moved) * freebsd/lib/libc/inet/inet_cidr_pton.c (moved) * freebsd/lib/libc/inet/inet_lnaof.c (moved) * freebsd/lib/libc/inet/inet_makeaddr.c (moved) * freebsd/lib/libc/inet/inet_net_ntop.c (moved) * freebsd/lib/libc/inet/inet_net_pton.c (moved) * freebsd/lib/libc/inet/inet_neta.c (moved) * freebsd/lib/libc/inet/inet_netof.c (moved) * freebsd/lib/libc/inet/inet_network.c (moved) * freebsd/lib/libc/inet/inet_ntoa.c (moved) * freebsd/lib/libc/inet/inet_ntop.c (moved) * freebsd/lib/libc/inet/inet_pton.c (moved) * freebsd/lib/libc/inet/nsap_addr.c (moved) * freebsd/lib/libc/isc/ev_streams.c (moved) * freebsd/lib/libc/isc/ev_timers.c (moved) * freebsd/lib/libc/isc/eventlib_p.h (moved) * freebsd/lib/libc/nameser/ns_name.c (moved) * freebsd/lib/libc/nameser/ns_netint.c (moved) * freebsd/lib/libc/nameser/ns_parse.c (moved) * freebsd/lib/libc/nameser/ns_print.c (moved) * freebsd/lib/libc/nameser/ns_samedomain.c (moved) * freebsd/lib/libc/nameser/ns_ttl.c (moved) * freebsd/lib/libc/net/base64.c (moved) * freebsd/lib/libc/net/ether_addr.c (moved) * freebsd/lib/libc/net/gai_strerror.c (moved) * freebsd/lib/libc/net/getaddrinfo.c (moved) * freebsd/lib/libc/net/gethostbydns.c (moved) * freebsd/lib/libc/net/gethostbyht.c (moved) * freebsd/lib/libc/net/gethostbynis.c (moved) * freebsd/lib/libc/net/gethostnamadr.c (moved) * freebsd/lib/libc/net/getifaddrs.c (moved) * freebsd/lib/libc/net/getifmaddrs.c (moved) * freebsd/lib/libc/net/getnameinfo.c (moved) * freebsd/lib/libc/net/getnetbydns.c (moved) * freebsd/lib/libc/net/getnetbyht.c (moved) * freebsd/lib/libc/net/getnetbynis.c (moved) * freebsd/lib/libc/net/getnetnamadr.c (moved) * freebsd/lib/libc/net/getproto.c (moved) * freebsd/lib/libc/net/getprotoent.c (moved) * freebsd/lib/libc/net/getprotoname.c (moved) * freebsd/lib/libc/net/getservent.c (moved) * freebsd/lib/libc/net/if_indextoname.c (moved) * freebsd/lib/libc/net/if_nameindex.c (moved) * freebsd/lib/libc/net/if_nametoindex.c (moved) * freebsd/lib/libc/net/linkaddr.c (moved) * freebsd/lib/libc/net/map_v4v6.c (moved) * freebsd/lib/libc/net/name6.c (moved) * freebsd/lib/libc/net/netdb_private.h (moved) * freebsd/lib/libc/net/nsdispatch.c (moved) * freebsd/lib/libc/net/nslexer.l (moved) * freebsd/lib/libc/net/nsparser.y (moved) * freebsd/lib/libc/net/nss_backends.h (moved) * freebsd/lib/libc/net/rcmd.c (moved) * freebsd/lib/libc/net/recv.c (moved) * freebsd/lib/libc/net/res_config.h (moved) * freebsd/lib/libc/net/send.c (moved) * freebsd/lib/libc/resolv/h_errno.c (moved) * freebsd/lib/libc/resolv/herror.c (moved) * freebsd/lib/libc/resolv/mtctxres.c (moved) * freebsd/lib/libc/resolv/res_comp.c (moved) * freebsd/lib/libc/resolv/res_data.c (moved) * freebsd/lib/libc/resolv/res_debug.c (moved) * freebsd/lib/libc/resolv/res_debug.h (moved) * freebsd/lib/libc/resolv/res_findzonecut.c (moved) * freebsd/lib/libc/resolv/res_init.c (moved) * freebsd/lib/libc/resolv/res_mkquery.c (moved) * freebsd/lib/libc/resolv/res_mkupdate.c (moved) * freebsd/lib/libc/resolv/res_private.h (moved) * freebsd/lib/libc/resolv/res_query.c (moved) * freebsd/lib/libc/resolv/res_send.c (moved) * freebsd/lib/libc/resolv/res_state.c (moved) * freebsd/lib/libc/resolv/res_update.c (moved) * freebsd/lib/libc/stdio/fgetln.c (moved) * freebsd/lib/libc/stdio/local.h (moved) * freebsd/lib/libc/stdlib/strtonum.c (moved) * freebsd/lib/libc/string/strsep.c (moved) * freebsd/lib/libipsec/ipsec_dump_policy.c (moved) * freebsd/lib/libipsec/ipsec_get_policylen.c (moved) * freebsd/lib/libipsec/ipsec_strerror.c (moved) * freebsd/lib/libipsec/ipsec_strerror.h (moved) * freebsd/lib/libipsec/libpfkey.h (moved) * freebsd/lib/libipsec/pfkey.c (moved) * freebsd/lib/libipsec/pfkey_dump.c (moved) * freebsd/lib/libipsec/policy_parse.y (moved) * freebsd/lib/libipsec/policy_token.l (moved) * freebsd/lib/libkvm/kvm.h (moved) * freebsd/lib/libmemstat/memstat.c (moved) * freebsd/lib/libmemstat/memstat.h (moved) * freebsd/lib/libmemstat/memstat_all.c (moved) * freebsd/lib/libmemstat/memstat_internal.h (moved) * freebsd/lib/libmemstat/memstat_malloc.c (moved) * freebsd/lib/libmemstat/memstat_uma.c (moved) * freebsd/lib/libutil/expand_number.c (moved) * freebsd/lib/libutil/humanize_number.c (moved) * freebsd/lib/libutil/libutil.h (moved) * freebsd/lib/libutil/trimdomain.c (moved) * freebsd/sbin/dhclient/alloc.c (moved) * freebsd/sbin/dhclient/bpf.c (moved) * freebsd/sbin/dhclient/clparse.c (moved) * freebsd/sbin/dhclient/conflex.c (moved) * freebsd/sbin/dhclient/convert.c (moved) * freebsd/sbin/dhclient/dhclient.c (moved) * freebsd/sbin/dhclient/dhcp.h (moved) * freebsd/sbin/dhclient/dhcpd.h (moved) * freebsd/sbin/dhclient/dhctoken.h (moved) * freebsd/sbin/dhclient/dispatch.c (moved) * freebsd/sbin/dhclient/errwarn.c (moved) * freebsd/sbin/dhclient/hash.c (moved) * freebsd/sbin/dhclient/inet.c (moved) * freebsd/sbin/dhclient/options.c (moved) * freebsd/sbin/dhclient/packet.c (moved) * freebsd/sbin/dhclient/parse.c (moved) * freebsd/sbin/dhclient/privsep.c (moved) * freebsd/sbin/dhclient/privsep.h (moved) * freebsd/sbin/dhclient/tables.c (moved) * freebsd/sbin/dhclient/tree.c (moved) * freebsd/sbin/dhclient/tree.h (moved) * freebsd/sbin/ifconfig/af_atalk.c (moved) * freebsd/sbin/ifconfig/af_inet.c (moved) * freebsd/sbin/ifconfig/af_inet6.c (moved) * freebsd/sbin/ifconfig/af_link.c (moved) * freebsd/sbin/ifconfig/af_nd6.c (moved) * freebsd/sbin/ifconfig/ifbridge.c (moved) * freebsd/sbin/ifconfig/ifcarp.c (moved) * freebsd/sbin/ifconfig/ifclone.c (moved) * freebsd/sbin/ifconfig/ifconfig.c (moved) * freebsd/sbin/ifconfig/ifconfig.h (moved) * freebsd/sbin/ifconfig/ifgif.c (moved) * freebsd/sbin/ifconfig/ifgre.c (moved) * freebsd/sbin/ifconfig/ifgroup.c (moved) * freebsd/sbin/ifconfig/ifieee80211.c (moved) * freebsd/sbin/ifconfig/iflagg.c (moved) * freebsd/sbin/ifconfig/ifmac.c (moved) * freebsd/sbin/ifconfig/ifmedia.c (moved) * freebsd/sbin/ifconfig/ifpfsync.c (moved) * freebsd/sbin/ifconfig/ifvlan.c (moved) * freebsd/sbin/ifconfig/regdomain.h (moved) * freebsd/sbin/ping/ping.c (moved) * freebsd/sbin/ping6/ping6.c (moved) * freebsd/sbin/route/keywords (moved) * freebsd/sbin/route/route.c (moved) * freebsd/sys/arm/arm/in_cksum.c (moved) * freebsd/sys/arm/include/machine/cpufunc.h (moved) * freebsd/sys/arm/include/machine/in_cksum.h (moved) * freebsd/sys/arm/include/machine/legacyvar.h (moved) * freebsd/sys/arm/include/machine/pci_cfgreg.h (moved) * freebsd/sys/arm/pci/pci_bus.c (moved) * freebsd/sys/avr/include/machine/in_cksum.h (moved) * freebsd/sys/avr/pci/pci_bus.c (moved) * freebsd/sys/bfin/include/machine/in_cksum.h (moved) * freebsd/sys/bsm/audit.h (moved) * freebsd/sys/bsm/audit_kevents.h (moved) * freebsd/sys/cam/ata/ata_all.h (moved) * freebsd/sys/cam/cam.c (moved) * freebsd/sys/cam/cam.h (moved) * freebsd/sys/cam/cam_ccb.h (moved) * freebsd/sys/cam/cam_debug.h (moved) * freebsd/sys/cam/cam_periph.h (moved) * freebsd/sys/cam/cam_sim.h (moved) * freebsd/sys/cam/cam_xpt.h (moved) * freebsd/sys/cam/cam_xpt_sim.h (moved) * freebsd/sys/cam/scsi/scsi_all.c (moved) * freebsd/sys/cam/scsi/scsi_all.h (moved) * freebsd/sys/cam/scsi/scsi_da.h (moved) * freebsd/sys/contrib/altq/altq/altq.h (moved) * freebsd/sys/contrib/altq/altq/altq_cbq.c (moved) * freebsd/sys/contrib/altq/altq/altq_cbq.h (moved) * freebsd/sys/contrib/altq/altq/altq_cdnr.c (moved) * freebsd/sys/contrib/altq/altq/altq_cdnr.h (moved) * freebsd/sys/contrib/altq/altq/altq_classq.h (moved) * freebsd/sys/contrib/altq/altq/altq_hfsc.c (moved) * freebsd/sys/contrib/altq/altq/altq_hfsc.h (moved) * freebsd/sys/contrib/altq/altq/altq_priq.c (moved) * freebsd/sys/contrib/altq/altq/altq_priq.h (moved) * freebsd/sys/contrib/altq/altq/altq_red.c (moved) * freebsd/sys/contrib/altq/altq/altq_red.h (moved) * freebsd/sys/contrib/altq/altq/altq_rio.c (moved) * freebsd/sys/contrib/altq/altq/altq_rio.h (moved) * freebsd/sys/contrib/altq/altq/altq_rmclass.c (moved) * freebsd/sys/contrib/altq/altq/altq_rmclass.h (moved) * freebsd/sys/contrib/altq/altq/altq_rmclass_debug.h (moved) * freebsd/sys/contrib/altq/altq/altq_subr.c (moved) * freebsd/sys/contrib/altq/altq/altq_var.h (moved) * freebsd/sys/contrib/altq/altq/altqconf.h (moved) * freebsd/sys/contrib/altq/altq/if_altq.h (moved) * freebsd/sys/contrib/pf/net/if_pflog.c (moved) * freebsd/sys/contrib/pf/net/if_pflog.h (moved) * freebsd/sys/contrib/pf/net/if_pfsync.c (moved) * freebsd/sys/contrib/pf/net/if_pfsync.h (moved) * freebsd/sys/contrib/pf/net/pf.c (moved) * freebsd/sys/contrib/pf/net/pf_if.c (moved) * freebsd/sys/contrib/pf/net/pf_ioctl.c (moved) * freebsd/sys/contrib/pf/net/pf_mtag.h (moved) * freebsd/sys/contrib/pf/net/pf_norm.c (moved) * freebsd/sys/contrib/pf/net/pf_osfp.c (moved) * freebsd/sys/contrib/pf/net/pf_ruleset.c (moved) * freebsd/sys/contrib/pf/net/pf_subr.c (moved) * freebsd/sys/contrib/pf/net/pf_table.c (moved) * freebsd/sys/contrib/pf/net/pfvar.h (moved) * freebsd/sys/contrib/pf/netinet/in4_cksum.c (moved) * freebsd/sys/crypto/blowfish/bf_ecb.c (moved) * freebsd/sys/crypto/blowfish/bf_enc.c (moved) * freebsd/sys/crypto/blowfish/bf_locl.h (moved) * freebsd/sys/crypto/blowfish/bf_pi.h (moved) * freebsd/sys/crypto/blowfish/bf_skey.c (moved) * freebsd/sys/crypto/blowfish/blowfish.h (moved) * freebsd/sys/crypto/camellia/camellia-api.c (moved) * freebsd/sys/crypto/camellia/camellia.c (moved) * freebsd/sys/crypto/camellia/camellia.h (moved) * freebsd/sys/crypto/des/des.h (moved) * freebsd/sys/crypto/des/des_ecb.c (moved) * freebsd/sys/crypto/des/des_enc.c (moved) * freebsd/sys/crypto/des/des_locl.h (moved) * freebsd/sys/crypto/des/des_setkey.c (moved) * freebsd/sys/crypto/des/podd.h (moved) * freebsd/sys/crypto/des/sk.h (moved) * freebsd/sys/crypto/des/spr.h (moved) * freebsd/sys/crypto/rc4/rc4.c (moved) * freebsd/sys/crypto/rc4/rc4.h (moved) * freebsd/sys/crypto/rijndael/rijndael-alg-fst.c (moved) * freebsd/sys/crypto/rijndael/rijndael-api-fst.c (moved) * freebsd/sys/crypto/rijndael/rijndael-api-fst.h (moved) * freebsd/sys/crypto/rijndael/rijndael-api.c (moved) * freebsd/sys/crypto/rijndael/rijndael.h (moved) * freebsd/sys/crypto/rijndael/rijndael_local.h (moved) * freebsd/sys/crypto/sha1.c (moved) * freebsd/sys/crypto/sha1.h (moved) * freebsd/sys/crypto/sha2/sha2.c (moved) * freebsd/sys/crypto/sha2/sha2.h (moved) * freebsd/sys/dev/bce/if_bce.c (moved) * freebsd/sys/dev/bce/if_bcefw.h (moved) * freebsd/sys/dev/bce/if_bcereg.h (moved) * freebsd/sys/dev/bfe/if_bfe.c (moved) * freebsd/sys/dev/bfe/if_bfereg.h (moved) * freebsd/sys/dev/bge/if_bge.c (moved) * freebsd/sys/dev/bge/if_bgereg.h (moved) * freebsd/sys/dev/dc/dcphy.c (moved) * freebsd/sys/dev/dc/if_dc.c (moved) * freebsd/sys/dev/dc/if_dcreg.h (moved) * freebsd/sys/dev/dc/pnphy.c (moved) * freebsd/sys/dev/e1000/e1000_80003es2lan.c (moved) * freebsd/sys/dev/e1000/e1000_80003es2lan.h (moved) * freebsd/sys/dev/e1000/e1000_82540.c (moved) * freebsd/sys/dev/e1000/e1000_82541.c (moved) * freebsd/sys/dev/e1000/e1000_82541.h (moved) * freebsd/sys/dev/e1000/e1000_82542.c (moved) * freebsd/sys/dev/e1000/e1000_82543.c (moved) * freebsd/sys/dev/e1000/e1000_82543.h (moved) * freebsd/sys/dev/e1000/e1000_82571.c (moved) * freebsd/sys/dev/e1000/e1000_82571.h (moved) * freebsd/sys/dev/e1000/e1000_82575.c (moved) * freebsd/sys/dev/e1000/e1000_82575.h (moved) * freebsd/sys/dev/e1000/e1000_api.c (moved) * freebsd/sys/dev/e1000/e1000_api.h (moved) * freebsd/sys/dev/e1000/e1000_defines.h (moved) * freebsd/sys/dev/e1000/e1000_hw.h (moved) * freebsd/sys/dev/e1000/e1000_ich8lan.c (moved) * freebsd/sys/dev/e1000/e1000_ich8lan.h (moved) * freebsd/sys/dev/e1000/e1000_mac.c (moved) * freebsd/sys/dev/e1000/e1000_mac.h (moved) * freebsd/sys/dev/e1000/e1000_manage.c (moved) * freebsd/sys/dev/e1000/e1000_manage.h (moved) * freebsd/sys/dev/e1000/e1000_mbx.c (moved) * freebsd/sys/dev/e1000/e1000_mbx.h (moved) * freebsd/sys/dev/e1000/e1000_nvm.c (moved) * freebsd/sys/dev/e1000/e1000_nvm.h (moved) * freebsd/sys/dev/e1000/e1000_osdep.c (moved) * freebsd/sys/dev/e1000/e1000_osdep.h (moved) * freebsd/sys/dev/e1000/e1000_phy.c (moved) * freebsd/sys/dev/e1000/e1000_phy.h (moved) * freebsd/sys/dev/e1000/e1000_regs.h (moved) * freebsd/sys/dev/e1000/e1000_vf.c (moved) * freebsd/sys/dev/e1000/e1000_vf.h (moved) * freebsd/sys/dev/e1000/if_em.c (moved) * freebsd/sys/dev/e1000/if_em.h (moved) * freebsd/sys/dev/e1000/if_igb.c (moved) * freebsd/sys/dev/e1000/if_igb.h (moved) * freebsd/sys/dev/e1000/if_lem.c (moved) * freebsd/sys/dev/e1000/if_lem.h (moved) * freebsd/sys/dev/fxp/if_fxp.c (moved) * freebsd/sys/dev/fxp/if_fxpreg.h (moved) * freebsd/sys/dev/fxp/if_fxpvar.h (moved) * freebsd/sys/dev/fxp/rcvbundl.h (moved) * freebsd/sys/dev/led/led.c (moved) * freebsd/sys/dev/led/led.h (moved) * freebsd/sys/dev/mii/brgphy.c (moved) * freebsd/sys/dev/mii/brgphyreg.h (moved) * freebsd/sys/dev/mii/icsphy.c (moved) * freebsd/sys/dev/mii/icsphyreg.h (moved) * freebsd/sys/dev/mii/mii.c (moved) * freebsd/sys/dev/mii/mii.h (moved) * freebsd/sys/dev/mii/mii_physubr.c (moved) * freebsd/sys/dev/mii/miivar.h (moved) * freebsd/sys/dev/pci/pci.c (moved) * freebsd/sys/dev/pci/pci_pci.c (moved) * freebsd/sys/dev/pci/pci_private.h (moved) * freebsd/sys/dev/pci/pci_user.c (moved) * freebsd/sys/dev/pci/pcib_private.h (moved) * freebsd/sys/dev/pci/pcireg.h (moved) * freebsd/sys/dev/pci/pcivar.h (moved) * freebsd/sys/dev/random/harvest.c (moved) * freebsd/sys/dev/random/randomdev_soft.h (moved) * freebsd/sys/dev/re/if_re.c (moved) * freebsd/sys/dev/smc/if_smc.c (moved) * freebsd/sys/dev/smc/if_smcreg.h (moved) * freebsd/sys/dev/smc/if_smcvar.h (moved) * freebsd/sys/dev/usb/controller/ehci.c (moved) * freebsd/sys/dev/usb/controller/ehci.h (moved) * freebsd/sys/dev/usb/controller/ehcireg.h (moved) * freebsd/sys/dev/usb/controller/ohci.c (moved) * freebsd/sys/dev/usb/controller/ohci.h (moved) * freebsd/sys/dev/usb/controller/ohcireg.h (moved) * freebsd/sys/dev/usb/controller/usb_controller.c (moved) * freebsd/sys/dev/usb/quirk/usb_quirk.c (moved) * freebsd/sys/dev/usb/quirk/usb_quirk.h (moved) * freebsd/sys/dev/usb/storage/umass.c (moved) * freebsd/sys/dev/usb/ufm_ioctl.h (moved) * freebsd/sys/dev/usb/usb.h (moved) * freebsd/sys/dev/usb/usb_bus.h (moved) * freebsd/sys/dev/usb/usb_busdma.c (moved) * freebsd/sys/dev/usb/usb_busdma.h (moved) * freebsd/sys/dev/usb/usb_cdc.h (moved) * freebsd/sys/dev/usb/usb_controller.h (moved) * freebsd/sys/dev/usb/usb_core.c (moved) * freebsd/sys/dev/usb/usb_core.h (moved) * freebsd/sys/dev/usb/usb_debug.c (moved) * freebsd/sys/dev/usb/usb_debug.h (moved) * freebsd/sys/dev/usb/usb_dev.c (moved) * freebsd/sys/dev/usb/usb_dev.h (moved) * freebsd/sys/dev/usb/usb_device.c (moved) * freebsd/sys/dev/usb/usb_device.h (moved) * freebsd/sys/dev/usb/usb_dynamic.c (moved) * freebsd/sys/dev/usb/usb_dynamic.h (moved) * freebsd/sys/dev/usb/usb_endian.h (moved) * freebsd/sys/dev/usb/usb_error.c (moved) * freebsd/sys/dev/usb/usb_freebsd.h (moved) * freebsd/sys/dev/usb/usb_generic.c (moved) * freebsd/sys/dev/usb/usb_generic.h (moved) * freebsd/sys/dev/usb/usb_handle_request.c (moved) * freebsd/sys/dev/usb/usb_hid.c (moved) * freebsd/sys/dev/usb/usb_hub.c (moved) * freebsd/sys/dev/usb/usb_hub.h (moved) * freebsd/sys/dev/usb/usb_ioctl.h (moved) * freebsd/sys/dev/usb/usb_lookup.c (moved) * freebsd/sys/dev/usb/usb_mbuf.c (moved) * freebsd/sys/dev/usb/usb_mbuf.h (moved) * freebsd/sys/dev/usb/usb_msctest.c (moved) * freebsd/sys/dev/usb/usb_msctest.h (moved) * freebsd/sys/dev/usb/usb_parse.c (moved) * freebsd/sys/dev/usb/usb_process.c (moved) * freebsd/sys/dev/usb/usb_process.h (moved) * freebsd/sys/dev/usb/usb_request.c (moved) * freebsd/sys/dev/usb/usb_request.h (moved) * freebsd/sys/dev/usb/usb_transfer.c (moved) * freebsd/sys/dev/usb/usb_transfer.h (moved) * freebsd/sys/dev/usb/usb_util.c (moved) * freebsd/sys/dev/usb/usb_util.h (moved) * freebsd/sys/dev/usb/usbdi.h (moved) * freebsd/sys/dev/usb/usbdi_util.h (moved) * freebsd/sys/dev/usb/usbhid.h (moved) * freebsd/sys/fs/devfs/devfs_int.h (moved) * freebsd/sys/h8300/include/machine/in_cksum.h (moved) * freebsd/sys/i386/i386/in_cksum.c (moved) * freebsd/sys/i386/i386/legacy.c (moved) * freebsd/sys/i386/include/machine/cpufunc.h (moved) * freebsd/sys/i386/include/machine/in_cksum.h (moved) * freebsd/sys/i386/include/machine/intr_machdep.h (moved) * freebsd/sys/i386/include/machine/md_var.h (moved) * freebsd/sys/i386/include/machine/specialreg.h (moved) * freebsd/sys/isa/isavar.h (moved) * freebsd/sys/isa/pnpvar.h (moved) * freebsd/sys/kern/init_main.c (moved) * freebsd/sys/kern/kern_descrip.c (moved) * freebsd/sys/kern/kern_environment.c (moved) * freebsd/sys/kern/kern_event.c (moved) * freebsd/sys/kern/kern_intr.c (moved) * freebsd/sys/kern/kern_linker.c (moved) * freebsd/sys/kern/kern_mbuf.c (moved) * freebsd/sys/kern/kern_mib.c (moved) * freebsd/sys/kern/kern_module.c (moved) * freebsd/sys/kern/kern_mtxpool.c (moved) * freebsd/sys/kern/kern_ntptime.c (moved) * freebsd/sys/kern/kern_proc.c (moved) * freebsd/sys/kern/kern_prot.c (moved) * freebsd/sys/kern/kern_resource.c (moved) * freebsd/sys/kern/kern_subr.c (moved) * freebsd/sys/kern/kern_sysctl.c (moved) * freebsd/sys/kern/kern_tc.c (moved) * freebsd/sys/kern/kern_time.c (moved) * freebsd/sys/kern/kern_timeout.c (moved) * freebsd/sys/kern/subr_bufring.c (moved) * freebsd/sys/kern/subr_bus.c (moved) * freebsd/sys/kern/subr_eventhandler.c (moved) * freebsd/sys/kern/subr_hints.c (moved) * freebsd/sys/kern/subr_kobj.c (moved) * freebsd/sys/kern/subr_module.c (moved) * freebsd/sys/kern/subr_rman.c (moved) * freebsd/sys/kern/subr_sbuf.c (moved) * freebsd/sys/kern/subr_unit.c (moved) * freebsd/sys/kern/sys_generic.c (moved) * freebsd/sys/kern/uipc_accf.c (moved) * freebsd/sys/kern/uipc_domain.c (moved) * freebsd/sys/kern/uipc_mbuf.c (moved) * freebsd/sys/kern/uipc_mbuf2.c (moved) * freebsd/sys/kern/uipc_sockbuf.c (moved) * freebsd/sys/kern/uipc_socket.c (moved) * freebsd/sys/libkern/arc4random.c (moved) * freebsd/sys/libkern/fls.c (moved) * freebsd/sys/libkern/inet_ntoa.c (moved) * freebsd/sys/libkern/random.c (moved) * freebsd/sys/mips/include/machine/cpufunc.h (moved) * freebsd/sys/mips/include/machine/cpuregs.h (moved) * freebsd/sys/mips/mips/in_cksum.c (moved) * freebsd/sys/net/bpf.c (moved) * freebsd/sys/net/bpf.h (moved) * freebsd/sys/net/bpf_buffer.c (moved) * freebsd/sys/net/bpf_buffer.h (moved) * freebsd/sys/net/bpf_filter.c (moved) * freebsd/sys/net/bpf_jitter.c (moved) * freebsd/sys/net/bpf_jitter.h (moved) * freebsd/sys/net/bpf_zerocopy.h (moved) * freebsd/sys/net/bpfdesc.h (moved) * freebsd/sys/net/bridgestp.c (moved) * freebsd/sys/net/bridgestp.h (moved) * freebsd/sys/net/ethernet.h (moved) * freebsd/sys/net/fddi.h (moved) * freebsd/sys/net/firewire.h (moved) * freebsd/sys/net/flowtable.h (moved) * freebsd/sys/net/ieee8023ad_lacp.c (moved) * freebsd/sys/net/ieee8023ad_lacp.h (moved) * freebsd/sys/net/if.c (moved) * freebsd/sys/net/if.h (moved) * freebsd/sys/net/if_arc.h (moved) * freebsd/sys/net/if_arcsubr.c (moved) * freebsd/sys/net/if_arp.h (moved) * freebsd/sys/net/if_atm.h (moved) * freebsd/sys/net/if_atmsubr.c (moved) * freebsd/sys/net/if_bridge.c (moved) * freebsd/sys/net/if_bridgevar.h (moved) * freebsd/sys/net/if_clone.c (moved) * freebsd/sys/net/if_clone.h (moved) * freebsd/sys/net/if_dead.c (moved) * freebsd/sys/net/if_disc.c (moved) * freebsd/sys/net/if_dl.h (moved) * freebsd/sys/net/if_edsc.c (moved) * freebsd/sys/net/if_ef.c (moved) * freebsd/sys/net/if_enc.c (moved) * freebsd/sys/net/if_enc.h (moved) * freebsd/sys/net/if_epair.c (moved) * freebsd/sys/net/if_ethersubr.c (moved) * freebsd/sys/net/if_faith.c (moved) * freebsd/sys/net/if_fddisubr.c (moved) * freebsd/sys/net/if_fwsubr.c (moved) * freebsd/sys/net/if_gif.c (moved) * freebsd/sys/net/if_gif.h (moved) * freebsd/sys/net/if_gre.c (moved) * freebsd/sys/net/if_gre.h (moved) * freebsd/sys/net/if_iso88025subr.c (moved) * freebsd/sys/net/if_lagg.c (moved) * freebsd/sys/net/if_lagg.h (moved) * freebsd/sys/net/if_llatbl.c (moved) * freebsd/sys/net/if_llatbl.h (moved) * freebsd/sys/net/if_llc.h (moved) * freebsd/sys/net/if_loop.c (moved) * freebsd/sys/net/if_media.c (moved) * freebsd/sys/net/if_media.h (moved) * freebsd/sys/net/if_mib.c (moved) * freebsd/sys/net/if_mib.h (moved) * freebsd/sys/net/if_sppp.h (moved) * freebsd/sys/net/if_spppfr.c (moved) * freebsd/sys/net/if_spppsubr.c (moved) * freebsd/sys/net/if_stf.c (moved) * freebsd/sys/net/if_stf.h (moved) * freebsd/sys/net/if_tap.c (moved) * freebsd/sys/net/if_tap.h (moved) * freebsd/sys/net/if_tapvar.h (moved) * freebsd/sys/net/if_tun.c (moved) * freebsd/sys/net/if_tun.h (moved) * freebsd/sys/net/if_types.h (moved) * freebsd/sys/net/if_var.h (moved) * freebsd/sys/net/if_vlan.c (moved) * freebsd/sys/net/if_vlan_var.h (moved) * freebsd/sys/net/iso88025.h (moved) * freebsd/sys/net/netisr.c (moved) * freebsd/sys/net/netisr.h (moved) * freebsd/sys/net/pfil.c (moved) * freebsd/sys/net/pfil.h (moved) * freebsd/sys/net/pfkeyv2.h (moved) * freebsd/sys/net/ppp_defs.h (moved) * freebsd/sys/net/radix.c (moved) * freebsd/sys/net/radix.h (moved) * freebsd/sys/net/radix_mpath.c (moved) * freebsd/sys/net/radix_mpath.h (moved) * freebsd/sys/net/raw_cb.c (moved) * freebsd/sys/net/raw_cb.h (moved) * freebsd/sys/net/raw_usrreq.c (moved) * freebsd/sys/net/route.c (moved) * freebsd/sys/net/route.h (moved) * freebsd/sys/net/rtsock.c (moved) * freebsd/sys/net/slcompress.c (moved) * freebsd/sys/net/slcompress.h (moved) * freebsd/sys/net/vnet.h (moved) * freebsd/sys/net/zlib.c (moved) * freebsd/sys/net/zlib.h (moved) * freebsd/sys/net80211/_ieee80211.h (moved) * freebsd/sys/net80211/ieee80211.c (moved) * freebsd/sys/net80211/ieee80211.h (moved) * freebsd/sys/net80211/ieee80211_acl.c (moved) * freebsd/sys/net80211/ieee80211_action.c (moved) * freebsd/sys/net80211/ieee80211_action.h (moved) * freebsd/sys/net80211/ieee80211_adhoc.c (moved) * freebsd/sys/net80211/ieee80211_adhoc.h (moved) * freebsd/sys/net80211/ieee80211_ageq.c (moved) * freebsd/sys/net80211/ieee80211_ageq.h (moved) * freebsd/sys/net80211/ieee80211_amrr.c (moved) * freebsd/sys/net80211/ieee80211_amrr.h (moved) * freebsd/sys/net80211/ieee80211_crypto.c (moved) * freebsd/sys/net80211/ieee80211_crypto.h (moved) * freebsd/sys/net80211/ieee80211_crypto_ccmp.c (moved) * freebsd/sys/net80211/ieee80211_crypto_none.c (moved) * freebsd/sys/net80211/ieee80211_crypto_tkip.c (moved) * freebsd/sys/net80211/ieee80211_crypto_wep.c (moved) * freebsd/sys/net80211/ieee80211_ddb.c (moved) * freebsd/sys/net80211/ieee80211_dfs.c (moved) * freebsd/sys/net80211/ieee80211_dfs.h (moved) * freebsd/sys/net80211/ieee80211_freebsd.c (moved) * freebsd/sys/net80211/ieee80211_freebsd.h (moved) * freebsd/sys/net80211/ieee80211_hostap.c (moved) * freebsd/sys/net80211/ieee80211_hostap.h (moved) * freebsd/sys/net80211/ieee80211_ht.c (moved) * freebsd/sys/net80211/ieee80211_ht.h (moved) * freebsd/sys/net80211/ieee80211_hwmp.c (moved) * freebsd/sys/net80211/ieee80211_input.c (moved) * freebsd/sys/net80211/ieee80211_input.h (moved) * freebsd/sys/net80211/ieee80211_ioctl.c (moved) * freebsd/sys/net80211/ieee80211_ioctl.h (moved) * freebsd/sys/net80211/ieee80211_mesh.c (moved) * freebsd/sys/net80211/ieee80211_mesh.h (moved) * freebsd/sys/net80211/ieee80211_monitor.c (moved) * freebsd/sys/net80211/ieee80211_monitor.h (moved) * freebsd/sys/net80211/ieee80211_node.c (moved) * freebsd/sys/net80211/ieee80211_node.h (moved) * freebsd/sys/net80211/ieee80211_output.c (moved) * freebsd/sys/net80211/ieee80211_phy.c (moved) * freebsd/sys/net80211/ieee80211_phy.h (moved) * freebsd/sys/net80211/ieee80211_power.c (moved) * freebsd/sys/net80211/ieee80211_power.h (moved) * freebsd/sys/net80211/ieee80211_proto.c (moved) * freebsd/sys/net80211/ieee80211_proto.h (moved) * freebsd/sys/net80211/ieee80211_radiotap.c (moved) * freebsd/sys/net80211/ieee80211_radiotap.h (moved) * freebsd/sys/net80211/ieee80211_ratectl.c (moved) * freebsd/sys/net80211/ieee80211_ratectl.h (moved) * freebsd/sys/net80211/ieee80211_ratectl_none.c (moved) * freebsd/sys/net80211/ieee80211_regdomain.c (moved) * freebsd/sys/net80211/ieee80211_regdomain.h (moved) * freebsd/sys/net80211/ieee80211_rssadapt.c (moved) * freebsd/sys/net80211/ieee80211_rssadapt.h (moved) * freebsd/sys/net80211/ieee80211_scan.c (moved) * freebsd/sys/net80211/ieee80211_scan.h (moved) * freebsd/sys/net80211/ieee80211_scan_sta.c (moved) * freebsd/sys/net80211/ieee80211_sta.c (moved) * freebsd/sys/net80211/ieee80211_sta.h (moved) * freebsd/sys/net80211/ieee80211_superg.c (moved) * freebsd/sys/net80211/ieee80211_superg.h (moved) * freebsd/sys/net80211/ieee80211_tdma.c (moved) * freebsd/sys/net80211/ieee80211_tdma.h (moved) * freebsd/sys/net80211/ieee80211_var.h (moved) * freebsd/sys/net80211/ieee80211_wds.c (moved) * freebsd/sys/net80211/ieee80211_wds.h (moved) * freebsd/sys/net80211/ieee80211_xauth.c (moved) * freebsd/sys/netatalk/aarp.c (moved) * freebsd/sys/netatalk/aarp.h (moved) * freebsd/sys/netatalk/at.h (moved) * freebsd/sys/netatalk/at_control.c (moved) * freebsd/sys/netatalk/at_extern.h (moved) * freebsd/sys/netatalk/at_proto.c (moved) * freebsd/sys/netatalk/at_rmx.c (moved) * freebsd/sys/netatalk/at_var.h (moved) * freebsd/sys/netatalk/ddp.h (moved) * freebsd/sys/netatalk/ddp_input.c (moved) * freebsd/sys/netatalk/ddp_output.c (moved) * freebsd/sys/netatalk/ddp_pcb.c (moved) * freebsd/sys/netatalk/ddp_pcb.h (moved) * freebsd/sys/netatalk/ddp_usrreq.c (moved) * freebsd/sys/netatalk/ddp_var.h (moved) * freebsd/sys/netatalk/endian.h (moved) * freebsd/sys/netatalk/phase2.h (moved) * freebsd/sys/netinet/accf_data.c (moved) * freebsd/sys/netinet/accf_dns.c (moved) * freebsd/sys/netinet/accf_http.c (moved) * freebsd/sys/netinet/icmp6.h (moved) * freebsd/sys/netinet/icmp_var.h (moved) * freebsd/sys/netinet/if_atm.c (moved) * freebsd/sys/netinet/if_atm.h (moved) * freebsd/sys/netinet/if_ether.c (moved) * freebsd/sys/netinet/if_ether.h (moved) * freebsd/sys/netinet/igmp.c (moved) * freebsd/sys/netinet/igmp.h (moved) * freebsd/sys/netinet/igmp_var.h (moved) * freebsd/sys/netinet/in.c (moved) * freebsd/sys/netinet/in.h (moved) * freebsd/sys/netinet/in_gif.c (moved) * freebsd/sys/netinet/in_gif.h (moved) * freebsd/sys/netinet/in_mcast.c (moved) * freebsd/sys/netinet/in_pcb.c (moved) * freebsd/sys/netinet/in_pcb.h (moved) * freebsd/sys/netinet/in_proto.c (moved) * freebsd/sys/netinet/in_rmx.c (moved) * freebsd/sys/netinet/in_systm.h (moved) * freebsd/sys/netinet/in_var.h (moved) * freebsd/sys/netinet/ip.h (moved) * freebsd/sys/netinet/ip6.h (moved) * freebsd/sys/netinet/ip_carp.c (moved) * freebsd/sys/netinet/ip_carp.h (moved) * freebsd/sys/netinet/ip_divert.c (moved) * freebsd/sys/netinet/ip_divert.h (moved) * freebsd/sys/netinet/ip_dummynet.h (moved) * freebsd/sys/netinet/ip_ecn.c (moved) * freebsd/sys/netinet/ip_ecn.h (moved) * freebsd/sys/netinet/ip_encap.c (moved) * freebsd/sys/netinet/ip_encap.h (moved) * freebsd/sys/netinet/ip_fastfwd.c (moved) * freebsd/sys/netinet/ip_fw.h (moved) * freebsd/sys/netinet/ip_gre.c (moved) * freebsd/sys/netinet/ip_gre.h (moved) * freebsd/sys/netinet/ip_icmp.c (moved) * freebsd/sys/netinet/ip_icmp.h (moved) * freebsd/sys/netinet/ip_id.c (moved) * freebsd/sys/netinet/ip_input.c (moved) * freebsd/sys/netinet/ip_ipsec.c (moved) * freebsd/sys/netinet/ip_ipsec.h (moved) * freebsd/sys/netinet/ip_mroute.c (moved) * freebsd/sys/netinet/ip_mroute.h (moved) * freebsd/sys/netinet/ip_options.c (moved) * freebsd/sys/netinet/ip_options.h (moved) * freebsd/sys/netinet/ip_output.c (moved) * freebsd/sys/netinet/ip_var.h (moved) * freebsd/sys/netinet/ipfw/dn_heap.c (moved) * freebsd/sys/netinet/ipfw/dn_heap.h (moved) * freebsd/sys/netinet/ipfw/dn_sched.h (moved) * freebsd/sys/netinet/ipfw/dn_sched_fifo.c (moved) * freebsd/sys/netinet/ipfw/dn_sched_prio.c (moved) * freebsd/sys/netinet/ipfw/dn_sched_qfq.c (moved) * freebsd/sys/netinet/ipfw/dn_sched_rr.c (moved) * freebsd/sys/netinet/ipfw/dn_sched_wf2q.c (moved) * freebsd/sys/netinet/ipfw/ip_dn_glue.c (moved) * freebsd/sys/netinet/ipfw/ip_dn_io.c (moved) * freebsd/sys/netinet/ipfw/ip_dn_private.h (moved) * freebsd/sys/netinet/ipfw/ip_dummynet.c (moved) * freebsd/sys/netinet/ipfw/ip_fw2.c (moved) * freebsd/sys/netinet/ipfw/ip_fw_log.c (moved) * freebsd/sys/netinet/ipfw/ip_fw_nat.c (moved) * freebsd/sys/netinet/ipfw/ip_fw_pfil.c (moved) * freebsd/sys/netinet/ipfw/ip_fw_private.h (moved) * freebsd/sys/netinet/ipfw/ip_fw_sockopt.c (moved) * freebsd/sys/netinet/ipfw/ip_fw_table.c (moved) * freebsd/sys/netinet/libalias/alias.c (moved) * freebsd/sys/netinet/libalias/alias.h (moved) * freebsd/sys/netinet/libalias/alias_cuseeme.c (moved) * freebsd/sys/netinet/libalias/alias_db.c (moved) * freebsd/sys/netinet/libalias/alias_dummy.c (moved) * freebsd/sys/netinet/libalias/alias_ftp.c (moved) * freebsd/sys/netinet/libalias/alias_irc.c (moved) * freebsd/sys/netinet/libalias/alias_local.h (moved) * freebsd/sys/netinet/libalias/alias_mod.c (moved) * freebsd/sys/netinet/libalias/alias_mod.h (moved) * freebsd/sys/netinet/libalias/alias_nbt.c (moved) * freebsd/sys/netinet/libalias/alias_pptp.c (moved) * freebsd/sys/netinet/libalias/alias_proxy.c (moved) * freebsd/sys/netinet/libalias/alias_sctp.c (moved) * freebsd/sys/netinet/libalias/alias_sctp.h (moved) * freebsd/sys/netinet/libalias/alias_skinny.c (moved) * freebsd/sys/netinet/libalias/alias_smedia.c (moved) * freebsd/sys/netinet/libalias/alias_util.c (moved) * freebsd/sys/netinet/pim.h (moved) * freebsd/sys/netinet/pim_var.h (moved) * freebsd/sys/netinet/raw_ip.c (moved) * freebsd/sys/netinet/sctp.h (moved) * freebsd/sys/netinet/sctp_asconf.c (moved) * freebsd/sys/netinet/sctp_asconf.h (moved) * freebsd/sys/netinet/sctp_auth.c (moved) * freebsd/sys/netinet/sctp_auth.h (moved) * freebsd/sys/netinet/sctp_bsd_addr.c (moved) * freebsd/sys/netinet/sctp_bsd_addr.h (moved) * freebsd/sys/netinet/sctp_cc_functions.c (moved) * freebsd/sys/netinet/sctp_cc_functions.h (moved) * freebsd/sys/netinet/sctp_constants.h (moved) * freebsd/sys/netinet/sctp_crc32.c (moved) * freebsd/sys/netinet/sctp_crc32.h (moved) * freebsd/sys/netinet/sctp_header.h (moved) * freebsd/sys/netinet/sctp_indata.c (moved) * freebsd/sys/netinet/sctp_indata.h (moved) * freebsd/sys/netinet/sctp_input.c (moved) * freebsd/sys/netinet/sctp_input.h (moved) * freebsd/sys/netinet/sctp_lock_bsd.h (moved) * freebsd/sys/netinet/sctp_os.h (moved) * freebsd/sys/netinet/sctp_os_bsd.h (moved) * freebsd/sys/netinet/sctp_output.c (moved) * freebsd/sys/netinet/sctp_output.h (moved) * freebsd/sys/netinet/sctp_pcb.c (moved) * freebsd/sys/netinet/sctp_pcb.h (moved) * freebsd/sys/netinet/sctp_peeloff.c (moved) * freebsd/sys/netinet/sctp_peeloff.h (moved) * freebsd/sys/netinet/sctp_structs.h (moved) * freebsd/sys/netinet/sctp_sysctl.c (moved) * freebsd/sys/netinet/sctp_sysctl.h (moved) * freebsd/sys/netinet/sctp_timer.c (moved) * freebsd/sys/netinet/sctp_timer.h (moved) * freebsd/sys/netinet/sctp_uio.h (moved) * freebsd/sys/netinet/sctp_usrreq.c (moved) * freebsd/sys/netinet/sctp_var.h (moved) * freebsd/sys/netinet/sctputil.c (moved) * freebsd/sys/netinet/sctputil.h (moved) * freebsd/sys/netinet/tcp.h (moved) * freebsd/sys/netinet/tcp_debug.c (moved) * freebsd/sys/netinet/tcp_debug.h (moved) * freebsd/sys/netinet/tcp_fsm.h (moved) * freebsd/sys/netinet/tcp_hostcache.c (moved) * freebsd/sys/netinet/tcp_hostcache.h (moved) * freebsd/sys/netinet/tcp_input.c (moved) * freebsd/sys/netinet/tcp_lro.c (moved) * freebsd/sys/netinet/tcp_lro.h (moved) * freebsd/sys/netinet/tcp_offload.c (moved) * freebsd/sys/netinet/tcp_offload.h (moved) * freebsd/sys/netinet/tcp_output.c (moved) * freebsd/sys/netinet/tcp_reass.c (moved) * freebsd/sys/netinet/tcp_sack.c (moved) * freebsd/sys/netinet/tcp_seq.h (moved) * freebsd/sys/netinet/tcp_subr.c (moved) * freebsd/sys/netinet/tcp_syncache.c (moved) * freebsd/sys/netinet/tcp_syncache.h (moved) * freebsd/sys/netinet/tcp_timer.c (moved) * freebsd/sys/netinet/tcp_timer.h (moved) * freebsd/sys/netinet/tcp_timewait.c (moved) * freebsd/sys/netinet/tcp_usrreq.c (moved) * freebsd/sys/netinet/tcp_var.h (moved) * freebsd/sys/netinet/tcpip.h (moved) * freebsd/sys/netinet/toedev.h (moved) * freebsd/sys/netinet/udp.h (moved) * freebsd/sys/netinet/udp_usrreq.c (moved) * freebsd/sys/netinet/udp_var.h (moved) * freebsd/sys/netinet6/dest6.c (moved) * freebsd/sys/netinet6/frag6.c (moved) * freebsd/sys/netinet6/icmp6.c (moved) * freebsd/sys/netinet6/icmp6.h (moved) * freebsd/sys/netinet6/in6.c (moved) * freebsd/sys/netinet6/in6.h (moved) * freebsd/sys/netinet6/in6_cksum.c (moved) * freebsd/sys/netinet6/in6_gif.c (moved) * freebsd/sys/netinet6/in6_gif.h (moved) * freebsd/sys/netinet6/in6_ifattach.c (moved) * freebsd/sys/netinet6/in6_ifattach.h (moved) * freebsd/sys/netinet6/in6_mcast.c (moved) * freebsd/sys/netinet6/in6_pcb.c (moved) * freebsd/sys/netinet6/in6_pcb.h (moved) * freebsd/sys/netinet6/in6_proto.c (moved) * freebsd/sys/netinet6/in6_rmx.c (moved) * freebsd/sys/netinet6/in6_src.c (moved) * freebsd/sys/netinet6/in6_var.h (moved) * freebsd/sys/netinet6/ip6.h (moved) * freebsd/sys/netinet6/ip6_ecn.h (moved) * freebsd/sys/netinet6/ip6_forward.c (moved) * freebsd/sys/netinet6/ip6_id.c (moved) * freebsd/sys/netinet6/ip6_input.c (moved) * freebsd/sys/netinet6/ip6_ipsec.c (moved) * freebsd/sys/netinet6/ip6_ipsec.h (moved) * freebsd/sys/netinet6/ip6_mroute.c (moved) * freebsd/sys/netinet6/ip6_mroute.h (moved) * freebsd/sys/netinet6/ip6_output.c (moved) * freebsd/sys/netinet6/ip6_var.h (moved) * freebsd/sys/netinet6/ip6protosw.h (moved) * freebsd/sys/netinet6/mld6.c (moved) * freebsd/sys/netinet6/mld6.h (moved) * freebsd/sys/netinet6/mld6_var.h (moved) * freebsd/sys/netinet6/nd6.c (moved) * freebsd/sys/netinet6/nd6.h (moved) * freebsd/sys/netinet6/nd6_nbr.c (moved) * freebsd/sys/netinet6/nd6_rtr.c (moved) * freebsd/sys/netinet6/pim6.h (moved) * freebsd/sys/netinet6/pim6_var.h (moved) * freebsd/sys/netinet6/raw_ip6.c (moved) * freebsd/sys/netinet6/raw_ip6.h (moved) * freebsd/sys/netinet6/route6.c (moved) * freebsd/sys/netinet6/scope6.c (moved) * freebsd/sys/netinet6/scope6_var.h (moved) * freebsd/sys/netinet6/sctp6_usrreq.c (moved) * freebsd/sys/netinet6/sctp6_var.h (moved) * freebsd/sys/netinet6/tcp6_var.h (moved) * freebsd/sys/netinet6/udp6_usrreq.c (moved) * freebsd/sys/netinet6/udp6_var.h (moved) * freebsd/sys/netipsec/ah.h (moved) * freebsd/sys/netipsec/ah_var.h (moved) * freebsd/sys/netipsec/esp.h (moved) * freebsd/sys/netipsec/esp_var.h (moved) * freebsd/sys/netipsec/ipcomp.h (moved) * freebsd/sys/netipsec/ipcomp_var.h (moved) * freebsd/sys/netipsec/ipip_var.h (moved) * freebsd/sys/netipsec/ipsec.c (moved) * freebsd/sys/netipsec/ipsec.h (moved) * freebsd/sys/netipsec/ipsec6.h (moved) * freebsd/sys/netipsec/ipsec_input.c (moved) * freebsd/sys/netipsec/ipsec_mbuf.c (moved) * freebsd/sys/netipsec/ipsec_output.c (moved) * freebsd/sys/netipsec/key.c (moved) * freebsd/sys/netipsec/key.h (moved) * freebsd/sys/netipsec/key_debug.c (moved) * freebsd/sys/netipsec/key_debug.h (moved) * freebsd/sys/netipsec/key_var.h (moved) * freebsd/sys/netipsec/keydb.h (moved) * freebsd/sys/netipsec/keysock.c (moved) * freebsd/sys/netipsec/keysock.h (moved) * freebsd/sys/netipsec/xform.h (moved) * freebsd/sys/netipsec/xform_ah.c (moved) * freebsd/sys/netipsec/xform_esp.c (moved) * freebsd/sys/netipsec/xform_ipcomp.c (moved) * freebsd/sys/netipsec/xform_ipip.c (moved) * freebsd/sys/netipsec/xform_tcp.c (moved) * freebsd/sys/opencrypto/cast.c (moved) * freebsd/sys/opencrypto/cast.h (moved) * freebsd/sys/opencrypto/castsb.h (moved) * freebsd/sys/opencrypto/criov.c (moved) * freebsd/sys/opencrypto/crypto.c (moved) * freebsd/sys/opencrypto/cryptodev.c (moved) * freebsd/sys/opencrypto/cryptodev.h (moved) * freebsd/sys/opencrypto/cryptosoft.c (moved) * freebsd/sys/opencrypto/cryptosoft.h (moved) * freebsd/sys/opencrypto/deflate.c (moved) * freebsd/sys/opencrypto/deflate.h (moved) * freebsd/sys/opencrypto/rmd160.c (moved) * freebsd/sys/opencrypto/rmd160.h (moved) * freebsd/sys/opencrypto/skipjack.c (moved) * freebsd/sys/opencrypto/skipjack.h (moved) * freebsd/sys/opencrypto/xform.c (moved) * freebsd/sys/opencrypto/xform.h (moved) * freebsd/sys/pci/if_rlreg.h (moved) * freebsd/sys/powerpc/include/machine/cpufunc.h (moved) * freebsd/sys/powerpc/include/machine/psl.h (moved) * freebsd/sys/powerpc/include/machine/spr.h (moved) * freebsd/sys/powerpc/powerpc/in_cksum.c (moved) * freebsd/sys/rpc/types.h (moved) * freebsd/sys/security/mac/mac_framework.h (moved) * freebsd/sys/sparc64/include/machine/asi.h (moved) * freebsd/sys/sparc64/include/machine/cpufunc.h (moved) * freebsd/sys/sparc64/include/machine/pstate.h (moved) * freebsd/sys/sparc64/sparc64/in_cksum.c (moved) * freebsd/sys/sys/_bus_dma.h (moved) * freebsd/sys/sys/_lock.h (moved) * freebsd/sys/sys/_lockmgr.h (moved) * freebsd/sys/sys/_mutex.h (moved) * freebsd/sys/sys/_null.h (moved) * freebsd/sys/sys/_rmlock.h (moved) * freebsd/sys/sys/_rwlock.h (moved) * freebsd/sys/sys/_semaphore.h (moved) * freebsd/sys/sys/_sigset.h (moved) * freebsd/sys/sys/_sx.h (moved) * freebsd/sys/sys/_task.h (moved) * freebsd/sys/sys/_timeval.h (moved) * freebsd/sys/sys/acl.h (moved) * freebsd/sys/sys/aio.h (moved) * freebsd/sys/sys/ata.h (moved) * freebsd/sys/sys/bitstring.h (moved) * freebsd/sys/sys/buf.h (moved) * freebsd/sys/sys/buf_ring.h (moved) * freebsd/sys/sys/bufobj.h (moved) * freebsd/sys/sys/bus.h (moved) * freebsd/sys/sys/bus_dma.h (moved) * freebsd/sys/sys/callout.h (moved) * freebsd/sys/sys/condvar.h (moved) * freebsd/sys/sys/conf.h (moved) * freebsd/sys/sys/cpu.h (moved) * freebsd/sys/sys/ctype.h (moved) * freebsd/sys/sys/domain.h (moved) * freebsd/sys/sys/endian.h (moved) * freebsd/sys/sys/event.h (moved) * freebsd/sys/sys/eventhandler.h (moved) * freebsd/sys/sys/eventvar.h (moved) * freebsd/sys/sys/fcntl.h (moved) * freebsd/sys/sys/file.h (moved) * freebsd/sys/sys/filedesc.h (moved) * freebsd/sys/sys/filio.h (moved) * freebsd/sys/sys/fnv_hash.h (moved) * freebsd/sys/sys/hash.h (moved) * freebsd/sys/sys/interrupt.h (moved) * freebsd/sys/sys/jail.h (moved) * freebsd/sys/sys/kenv.h (moved) * freebsd/sys/sys/kernel.h (moved) * freebsd/sys/sys/kobj.h (moved) * freebsd/sys/sys/kthread.h (moved) * freebsd/sys/sys/ktr.h (moved) * freebsd/sys/sys/libkern.h (moved) * freebsd/sys/sys/limits.h (moved) * freebsd/sys/sys/linker.h (moved) * freebsd/sys/sys/linker_set.h (moved) * freebsd/sys/sys/lock_profile.h (moved) * freebsd/sys/sys/lockmgr.h (moved) * freebsd/sys/sys/lockstat.h (moved) * freebsd/sys/sys/mac.h (moved) * freebsd/sys/sys/malloc.h (moved) * freebsd/sys/sys/mbuf.h (moved) * freebsd/sys/sys/md5.h (moved) * freebsd/sys/sys/mman.h (moved) * freebsd/sys/sys/module.h (moved) * freebsd/sys/sys/mount.h (moved) * freebsd/sys/sys/mqueue.h (moved) * freebsd/sys/sys/mutex.h (moved) * freebsd/sys/sys/nlist_aout.h (moved) * freebsd/sys/sys/osd.h (moved) * freebsd/sys/sys/pciio.h (moved) * freebsd/sys/sys/pcpu.h (moved) * freebsd/sys/sys/poll.h (moved) * freebsd/sys/sys/priority.h (moved) * freebsd/sys/sys/priv.h (moved) * freebsd/sys/sys/proc.h (moved) * freebsd/sys/sys/protosw.h (moved) * freebsd/sys/sys/queue.h (moved) * freebsd/sys/sys/random.h (moved) * freebsd/sys/sys/reboot.h (moved) * freebsd/sys/sys/refcount.h (moved) * freebsd/sys/sys/resourcevar.h (moved) * freebsd/sys/sys/rman.h (moved) * freebsd/sys/sys/rmlock.h (moved) * freebsd/sys/sys/rtprio.h (moved) * freebsd/sys/sys/runq.h (moved) * freebsd/sys/sys/rwlock.h (moved) * freebsd/sys/sys/sbuf.h (moved) * freebsd/sys/sys/sdt.h (moved) * freebsd/sys/sys/select.h (moved) * freebsd/sys/sys/selinfo.h (moved) * freebsd/sys/sys/sf_buf.h (moved) * freebsd/sys/sys/sigio.h (moved) * freebsd/sys/sys/smp.h (moved) * freebsd/sys/sys/sockbuf.h (moved) * freebsd/sys/sys/socket.h (moved) * freebsd/sys/sys/socketvar.h (moved) * freebsd/sys/sys/sockio.h (moved) * freebsd/sys/sys/sockopt.h (moved) * freebsd/sys/sys/sockstate.h (moved) * freebsd/sys/sys/stddef.h (moved) * freebsd/sys/sys/stdint.h (moved) * freebsd/sys/sys/sx.h (moved) * freebsd/sys/sys/sysctl.h (moved) * freebsd/sys/sys/syslog.h (moved) * freebsd/sys/sys/systm.h (moved) * freebsd/sys/sys/taskqueue.h (moved) * freebsd/sys/sys/timepps.h (moved) * freebsd/sys/sys/timetc.h (moved) * freebsd/sys/sys/timex.h (moved) * freebsd/sys/sys/tree.h (moved) * freebsd/sys/sys/tty.h (moved) * freebsd/sys/sys/ttycom.h (moved) * freebsd/sys/sys/ttydevsw.h (moved) * freebsd/sys/sys/ttydisc.h (moved) * freebsd/sys/sys/ttyhook.h (moved) * freebsd/sys/sys/ttyqueue.h (moved) * freebsd/sys/sys/ucred.h (moved) * freebsd/sys/sys/un.h (moved) * freebsd/sys/sys/user.h (moved) * freebsd/sys/sys/vmmeter.h (moved) * freebsd/sys/vm/uma.h (moved) * freebsd/sys/vm/uma_core.c (moved) * freebsd/sys/vm/uma_dbg.h (moved) * freebsd/sys/vm/uma_int.h (moved) * freebsd/sys/vm/vm.h (moved) * freebsd/usr.bin/netstat/atalk.c (moved) * freebsd/usr.bin/netstat/bpf.c (moved) * freebsd/usr.bin/netstat/if.c (moved) * freebsd/usr.bin/netstat/inet.c (moved) * freebsd/usr.bin/netstat/inet6.c (moved) * freebsd/usr.bin/netstat/ipsec.c (moved) * freebsd/usr.bin/netstat/main.c (moved) * freebsd/usr.bin/netstat/mbuf.c (moved) * freebsd/usr.bin/netstat/mroute.c (moved) * freebsd/usr.bin/netstat/mroute6.c (moved) * freebsd/usr.bin/netstat/netstat.h (moved) * freebsd/usr.bin/netstat/pfkey.c (moved) * freebsd/usr.bin/netstat/route.c (moved) * freebsd/usr.bin/netstat/sctp.c (moved) * freebsd/usr.bin/netstat/unix.c (moved) * rtemsbsd/include/cam/cam_queue.h (moved) * rtemsbsd/include/ddb/db_sym.h (moved) * rtemsbsd/include/ddb/ddb.h (moved) * rtemsbsd/include/geom/geom_disk.h (moved) * rtemsbsd/include/local/pmap.h (moved) * rtemsbsd/include/machine/_bus.h (moved) * rtemsbsd/include/machine/_limits.h (moved) * rtemsbsd/include/machine/atomic.h (moved) * rtemsbsd/include/machine/bus.h (moved) * rtemsbsd/include/machine/bus_dma.h (moved) * rtemsbsd/include/machine/bus_space-i386.h (moved) * rtemsbsd/include/machine/bus_space-simple_memory.h (moved) * rtemsbsd/include/machine/clock.h (moved) * rtemsbsd/include/machine/cpu.h (moved) * rtemsbsd/include/machine/cpufunc.h (moved) * rtemsbsd/include/machine/elf.h (moved) * rtemsbsd/include/machine/mutex.h (moved) * rtemsbsd/include/machine/pcb.h (moved) * rtemsbsd/include/machine/pcpu.h (moved) * rtemsbsd/include/machine/proc.h (moved) * rtemsbsd/include/machine/resource.h (moved) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (moved) * rtemsbsd/include/machine/rtems-bsd-cache.h (moved) * rtemsbsd/include/machine/rtems-bsd-config.h.in (moved) * rtemsbsd/include/machine/rtems-bsd-devicet.h (moved) * rtemsbsd/include/machine/rtems-bsd-symbols.h (moved) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (moved) * rtemsbsd/include/machine/rtems-bsd-taskqueue.h (moved) * rtemsbsd/include/machine/runq.h (moved) * rtemsbsd/include/machine/signal.h (moved) * rtemsbsd/include/machine/smp.h (moved) * rtemsbsd/include/machine/stdarg.h (moved) * rtemsbsd/include/machine/ucontext.h (moved) * rtemsbsd/include/machine/vm.h (moved) * rtemsbsd/include/netgraph/ng_ipfw.h (moved) * rtemsbsd/include/poll.h (moved) * rtemsbsd/include/rtems/bsd/bsd.h (moved) * rtemsbsd/include/rtems/bsd/local/bus_if.h (moved) * rtemsbsd/include/rtems/bsd/local/cryptodev_if.h (moved) * rtemsbsd/include/rtems/bsd/local/device_if.h (moved) * rtemsbsd/include/rtems/bsd/local/linker_if.h (moved) * rtemsbsd/include/rtems/bsd/local/miibus_if.h (moved) * rtemsbsd/include/rtems/bsd/local/miidevs.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_altq.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_atalk.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_bce.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_bootp.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_bpf.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_bus.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_cam.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_carp.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_compat.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_config.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_cpu.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ddb.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_device_polling.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ef.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_enc.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_hwpmc_hooks.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_inet.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_inet6.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_init_path.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ipdivert.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ipdn.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ipfw.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ipsec.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ipstealth.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ipx.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_kdb.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_kdtrace.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ktrace.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_mbuf_profiling.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_mbuf_stress_test.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_mpath.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_mrouting.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_natm.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_netgraph.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_ntp.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_param.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_pf.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_posix.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_printf.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_route.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_scsi.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_sctp.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_tcpdebug.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_tdma.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_usb.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_vlan.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_wlan.h (moved) * rtemsbsd/include/rtems/bsd/local/opt_zero.h (moved) * rtemsbsd/include/rtems/bsd/local/pci_if.h (moved) * rtemsbsd/include/rtems/bsd/local/pcib_if.h (moved) * rtemsbsd/include/rtems/bsd/local/usb_if.h (moved) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (moved) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (moved) * rtemsbsd/include/rtems/bsd/local/vnode_if.h (moved) * rtemsbsd/include/rtems/bsd/local/vnode_if_newproto.h (moved) * rtemsbsd/include/rtems/bsd/local/vnode_if_typedef.h (moved) * rtemsbsd/include/rtems/bsd/sys/_types.h (moved) * rtemsbsd/include/rtems/bsd/sys/errno.h (moved) * rtemsbsd/include/rtems/bsd/sys/lock.h (moved) * rtemsbsd/include/rtems/bsd/sys/param.h (moved) * rtemsbsd/include/rtems/bsd/sys/resource.h (moved) * rtemsbsd/include/rtems/bsd/sys/time.h (moved) * rtemsbsd/include/rtems/bsd/sys/timespec.h (moved) * rtemsbsd/include/rtems/bsd/sys/types.h (moved) * rtemsbsd/include/rtems/bsd/sys/unistd.h (moved) * rtemsbsd/include/rtems/netcmds-config.h (moved) * rtemsbsd/include/rtems/rtems_bsdnet.h (moved) * rtemsbsd/include/security/audit/audit.h (moved) * rtemsbsd/include/sys/_pthreadtypes.h (moved) * rtemsbsd/include/sys/bio.h (moved) * rtemsbsd/include/sys/copyright.h (moved) * rtemsbsd/include/sys/cpuset.h (moved) * rtemsbsd/include/sys/exec.h (moved) * rtemsbsd/include/sys/fail.h (moved) * rtemsbsd/include/sys/namei.h (moved) * rtemsbsd/include/sys/signalvar.h (moved) * rtemsbsd/include/sys/sleepqueue.h (moved) * rtemsbsd/include/sys/syscallsubr.h (moved) * rtemsbsd/include/sys/sysent.h (moved) * rtemsbsd/include/sys/sysproto.h (moved) * rtemsbsd/include/sys/ucontext.h (moved) * rtemsbsd/include/sys/vnode.h (moved) * rtemsbsd/include/syslog.h (moved) * rtemsbsd/include/vm/pmap.h (moved) * rtemsbsd/include/vm/vm_map.h (moved) * rtemsbsd/include/vm/vm_param.h (moved) * rtemsbsd/local/bus_if.c (moved) * rtemsbsd/local/cryptodev_if.c (moved) * rtemsbsd/local/device_if.c (moved) * rtemsbsd/local/miibus_if.c (moved) * rtemsbsd/local/pci_if.c (moved) * rtemsbsd/local/pcib_if.c (moved) * rtemsbsd/local/usb_if.c (moved) * rtemsbsd/rtems/generate_kvm_symbols (moved) * rtemsbsd/rtems/ipsec_get_policylen.c (moved) * rtemsbsd/rtems/kvm_private.h (moved) * rtemsbsd/rtems/rtems-bsd-assert.c (moved) * rtemsbsd/rtems/rtems-bsd-autoconf.c (moved) * rtemsbsd/rtems/rtems-bsd-bus-dma-mbuf.c (moved) * rtemsbsd/rtems/rtems-bsd-bus-dma.c (moved) * rtemsbsd/rtems/rtems-bsd-cam.c (moved) * rtemsbsd/rtems/rtems-bsd-condvar.c (moved) * rtemsbsd/rtems/rtems-bsd-conf.c (moved) * rtemsbsd/rtems/rtems-bsd-copyinout.c (moved) * rtemsbsd/rtems/rtems-bsd-delay.c (moved) * rtemsbsd/rtems/rtems-bsd-descrip.c (moved) * rtemsbsd/rtems/rtems-bsd-generic.c (moved) * rtemsbsd/rtems/rtems-bsd-init-with-irq.c (moved) * rtemsbsd/rtems/rtems-bsd-init.c (moved) * rtemsbsd/rtems/rtems-bsd-jail.c (moved) * rtemsbsd/rtems/rtems-bsd-lock.c (moved) * rtemsbsd/rtems/rtems-bsd-log.c (moved) * rtemsbsd/rtems/rtems-bsd-malloc.c (moved) * rtemsbsd/rtems/rtems-bsd-mutex.c (moved) * rtemsbsd/rtems/rtems-bsd-newproc.c (moved) * rtemsbsd/rtems/rtems-bsd-nexus.c (moved) * rtemsbsd/rtems/rtems-bsd-page.c (moved) * rtemsbsd/rtems/rtems-bsd-panic.c (moved) * rtemsbsd/rtems/rtems-bsd-pci_cfgreg.c (moved) * rtemsbsd/rtems/rtems-bsd-rwlock.c (moved) * rtemsbsd/rtems/rtems-bsd-shell.c (moved) * rtemsbsd/rtems/rtems-bsd-signal.c (moved) * rtemsbsd/rtems/rtems-bsd-smp.c (moved) * rtemsbsd/rtems/rtems-bsd-subr_param.c (moved) * rtemsbsd/rtems/rtems-bsd-support.c (moved) * rtemsbsd/rtems/rtems-bsd-sx.c (moved) * rtemsbsd/rtems/rtems-bsd-synch.c (moved) * rtemsbsd/rtems/rtems-bsd-syscalls.c (moved) * rtemsbsd/rtems/rtems-bsd-sysctl.c (moved) * rtemsbsd/rtems/rtems-bsd-sysctlbyname.c (moved) * rtemsbsd/rtems/rtems-bsd-sysctlnametomib.c (moved) * rtemsbsd/rtems/rtems-bsd-taskqueue.c (moved) * rtemsbsd/rtems/rtems-bsd-thread.c (moved) * rtemsbsd/rtems/rtems-bsd-thread0-ucred.c (moved) * rtemsbsd/rtems/rtems-bsd-timesupport.c (moved) * rtemsbsd/rtems/rtems-bsd-vm_glue.c (moved) * rtemsbsd/rtems/rtems-getprogname.c (moved) * rtemsbsd/rtems/rtems-kvm.c (moved) * rtemsbsd/rtems/rtems-net-setup.c (moved) * rtemsbsd/rtems/rtems-shell.c (moved) * rtemsbsd/rtems/rtems-syslog-initialize.c (moved) * rtemsbsd/rtems/rtems-syspoll.c (moved) * rtemsbsd/rtems/rtems-uthread_kevent.c (moved) * rtemsbsd/rtems/rtems-uthread_kqueue.c (moved) * rtemsbsd/rtems/syslog.c (moved) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (moved) * rtemsbsd/sys/dev/usb/controller/ohci_lpc24xx.c (moved) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (moved) * testsuite/include/rtems/bsd/test/nic-sysinit.h (moved) Move files to match FreeBSD layout Fri, 20 Sep 2013 13:05:01 GMT Sebastian Huber [e3dd7a4] * freebsd/sys/proc.h (modified) Avoid usage of stack_t type Fri, 20 Sep 2013 13:02:54 GMT Sebastian Huber [a71a325] * freebsd-to-rtems.py (modified) * freebsd/sys/ucontext.h (modified) Use empty Fri, 20 Sep 2013 10:52:44 GMT Sebastian Huber [a3dde3e] * freebsd/sys/linker_set.h (modified) * rtemsbsd/freebsd/machine/rtems-bsd-config.h.in (modified) Update due to Newlib changes Mon, 26 Nov 2012 15:49:24 GMT Jennifer Averett [e00f10c] * freebsd/sys/limits.h (deleted) * freebsd/sys/timespec.h (deleted) Remove empty version of timespec.h and limits.h Mon, 26 Nov 2012 15:47:09 GMT Jennifer Averett [0bde19e] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd-userspace/Makefile (modified) * freebsd-userspace/commands/sbin/ping/ping.c (modified) * freebsd-userspace/lib/libc_r/uthread/uthread_kern.c (added) * freebsd-userspace/lib/libc_r/uthread/uthread_select.c (added) * freebsd-userspace/rtems/include/pthread_private.h (added) * freebsd-userspace/rtems/rtems-get_curthread.c (added) * freebsd-userspace/rtems/rtems-syspoll.c (added) * freebsd-userspace/rtems/rtems-uthread_init.c (added) * freebsd/kern/kern_condvar.c (added) * freebsd/kern/kern_descrip.c (added) * freebsd/kern/kern_mtxpool.c (added) * freebsd/kern/kern_subr.c (modified) * freebsd/kern/kern_time.c (modified) * freebsd/kern/sys_generic.c (added) * freebsd/sys/buf.h (added) * freebsd/sys/mqueue.h (added) * freebsd/sys/proc.h (modified) * freebsd/sys/tty.h (added) * freebsd/sys/ttydevsw.h (added) * freebsd/sys/ttydisc.h (added) * freebsd/sys/ttyhook.h (added) * freebsd/sys/ttyqueue.h (added) * freebsd/sys/user.h (added) * rtemsbsd/src/rtems-bsd-condvar.c (modified) * rtemsbsd/src/rtems-bsd-thread.c (modified) Switch to a version of select that is closer to bsd's version. Fri, 07 Sep 2012 16:41:09 GMT Jennifer Averett [af4b6f2] * freebsd-to-rtems.py (modified) * freebsd/sys/mman.h (added) Added mman.h This will be needed when the ifconfig command is added. Wed, 05 Sep 2012 18:11:21 GMT Joel Sherrill [fa3526a] * freebsd/sys/signalvar.h (deleted) freebsd/sys/signalvar.h: Use empty file from previous commit Wed, 05 Sep 2012 17:50:34 GMT Joel Sherrill [4c0dbd3] * freebsd/sys/signal.h (deleted) freebsd/sys/signal.h: use standard This patch ... Wed, 05 Sep 2012 17:49:23 GMT Joel Sherrill [1c6a8e8] * freebsd/sys/cdefs.h (deleted) freebsd/sys/cdefs.h: use standard This patch assumes ... Wed, 05 Sep 2012 17:48:38 GMT Joel Sherrill [25ed473] * freebsd/sys/aio.h (modified) aio.h: Disable unused field Sat, 01 Sep 2012 14:24:33 GMT Joel Sherrill [21e0e4e] * freebsd/sys/_iovec.h (modified) _iovec.h: Improve comments Sat, 01 Sep 2012 00:21:34 GMT Joel Sherrill [b4cf93e] * freebsd/sys/_iovec.h (modified) _iovec.h: Ensure only one definition of struct iovec Tue, 17 Jul 2012 13:20:46 GMT Jennifer Averett [325120c] * freebsd/sys/pcpu.h (modified) * rtemsbsd/src/rtems-bsd-syscalls.c (modified) Fix curthread so it returns a valid value. Tue, 17 Jul 2012 13:12:42 GMT Jennifer Averett [fbdd6b6] * freebsd/sys/priv.h (modified) Fix priv_check methods to return passing value. Wed, 23 May 2012 19:36:24 GMT Jennifer Averett [ae53d9e] * freebsd/sys/conf.h (modified) Commented out elements of the cdev struct which were unused This was ... Thu, 10 May 2012 13:06:10 GMT Christian Mauderer [ee6b343] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_intr.c (modified) * freebsd/kern/kern_timeout.c (added) * freebsd/sys/callout.h (modified) * freebsd/sys/mutex.h (modified) * freebsd/sys/sleepqueue.h (added) * rtemsbsd/freebsd/machine/rtems-bsd-symbols.h (modified) * rtemsbsd/src/rtems-bsd-callout.c (deleted) * rtemsbsd/src/rtems-bsd-shell.c (modified) * rtemsbsd/src/rtems-bsd-timeout.c (deleted) * testsuite/swi01/Makefile (added) * testsuite/swi01/init.c (added) * testsuite/swi01/swi_test.c (added) * testsuite/swi01/swi_test.h (added) * testsuite/timeout01/Makefile (added) * testsuite/timeout01/init.c (added) * testsuite/timeout01/timeout_helper.c (added) * testsuite/timeout01/timeout_helper.h (added) * testsuite/timeout01/timeout_test.c (added) * testsuite/timeout01/timeout_test.h (added) Provide SWI(9) and TIMEOUT(9) Tue, 01 May 2012 18:52:03 GMT Jennifer Averett [73a8881] * freebsd/kern/init_main.c (modified) * freebsd/netinet/tcp_syncache.c (modified) * freebsd/sys/proc.h (modified) Added rtems_bsd_thread0_ucred as a single global ucred. Tue, 01 May 2012 18:12:00 GMT Jennifer Averett [c1dd641] * freebsd/sys/systm.h (modified) Added a define of 0 for bootverbose. Thu, 26 Apr 2012 13:05:52 GMT Sebastian Huber [4c0c5fd] * freebsd-to-rtems.py (modified) * freebsd/kern/init_main.c (modified) * freebsd/sys/proc.h (modified) * freebsd/sys/vmmeter.h (added) * freebsd/vm/vm_map.h (added) * freebsd/vm/vm_param.h (added) * rtemsbsd/src/rtems-bsd-mutex.c (modified) * rtemsbsd/src/rtems-bsd-synch.c (modified) * rtemsbsd/src/rtems-bsd-thread.c (modified) Remove proc0 creation Thu, 26 Apr 2012 13:47:49 GMT Christian Mauderer [9ee7689] * freebsd/kern/uipc_socket.c (modified) * freebsd/netinet/sctp_output.c (modified) * freebsd/sys/proc.h (modified) Remove rusage dependencies Wed, 18 Apr 2012 15:14:02 GMT Sebastian Huber [2f52893] * freebsd/sys/endian.h (modified) * rtemsbsd/freebsd/machine/endian.h (modified) Move __bswap64() Add copyright notice of FreeBSD ... Wed, 18 Apr 2012 14:48:49 GMT Joel Sherrill [f084ec7] * freebsd/sys/endian.h (modified) Add generic implementation of __bswap64 Wed, 18 Apr 2012 12:55:02 GMT Sebastian Huber [60ed795] * freebsd/sys/errno.h (modified) Hide most error number definitions Tue, 17 Apr 2012 15:19:30 GMT Sebastian Huber [508747e] * freebsd/sys/kenv.h (added) Add missing header file Mon, 16 Apr 2012 14:10:35 GMT Jennifer Averett [459afb1] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_ntptime.c (added) * freebsd/sys/_rmlock.h (modified) * freebsd/sys/rmlock.h (modified) * rtemsbsd/src/rtems-bsd-lock.c (modified) * rtemsbsd/src/rtems-bsd-rmlock.c (deleted) * rtemsbsd/src/rtems-bsd-timeout.c (added) Implemented a version of rmlock using rwlock. Thu, 05 Apr 2012 20:24:27 GMT Jennifer Averett [251480e] * freebsd-to-rtems.py (modified) * freebsd/kern/kern_event.c (modified) * freebsd/sys/eventvar.h (added) Added in a header file and some defines to resolve linker errors. Thu, 05 Apr 2012 18:42:26 GMT Jennifer Averett [c613894] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/dev/pci/pci.c (added) * freebsd/sys/pciio.h (added) Added pci_XXX methods. Wed, 04 Apr 2012 22:47:18 GMT Joel Sherrill [772d929] * freebsd/sys/param.h (modified) Add _ALIGN macro based on one in libmisc/shell/fts.c Mon, 26 Mar 2012 18:37:01 GMT Joel Sherrill [2a478f7] * freebsd/sys/vnode.h (added) sys/vnode.h added as empty file Thu, 22 Mar 2012 14:58:40 GMT Jennifer Averett [da162c8] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/smp.h (added) * rtemsbsd/freebsd/machine/rtems-bsd-taskqueue.h (added) * rtemsbsd/src/rtems-bsd-taskqueue.c (added) Added taskqueue to resolve linking issues with the RealTek Nic. Thu, 22 Mar 2012 14:20:21 GMT Jennifer Averett [aa53ae9] * freebsd-to-rtems.py (modified) * freebsd/sys/smp.h (deleted) Removed system smp.h file. Mon, 12 Mar 2012 17:23:59 GMT Jennifer Averett [3f7b966] * freebsd-to-rtems.py (modified) * freebsd/kern/uipc_sockbuf.c (added) * freebsd/sys/aio.h (added) Make socantsendmore() available which required sys/aio.h Fri, 09 Mar 2012 15:19:06 GMT Joel Sherrill [fcce4d2] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_tc.c (added) * freebsd/local/opt_ntp.h (added) * freebsd/sys/timepps.h (added) * freebsd/sys/timetc.h (added) * freebsd/sys/timex.h (added) Add time support files from FreeBSD to build to resolve more symbols ... Thu, 08 Mar 2012 21:54:05 GMT Joel Sherrill [b55081a] * Changes (modified) * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/kern/kern_subr.c (added) * freebsd/sys/mutex.h (modified) kern/kern_subr.c added for hashinit More undefined symbols resulted. Thu, 08 Mar 2012 14:56:25 GMT Joel Sherrill [03d4faf] * Makefile (modified) * contrib/altq/freebsd/altq/altq.h (moved) * contrib/altq/freebsd/altq/altq_cbq.c (moved) * contrib/altq/freebsd/altq/altq_cbq.h (moved) * contrib/altq/freebsd/altq/altq_cdnr.c (moved) * contrib/altq/freebsd/altq/altq_cdnr.h (moved) * contrib/altq/freebsd/altq/altq_classq.h (moved) * contrib/altq/freebsd/altq/altq_hfsc.c (moved) * contrib/altq/freebsd/altq/altq_hfsc.h (moved) * contrib/altq/freebsd/altq/altq_priq.c (moved) * contrib/altq/freebsd/altq/altq_priq.h (moved) * contrib/altq/freebsd/altq/altq_red.c (moved) * contrib/altq/freebsd/altq/altq_red.h (moved) * contrib/altq/freebsd/altq/altq_rio.c (moved) * contrib/altq/freebsd/altq/altq_rio.h (moved) * contrib/altq/freebsd/altq/altq_rmclass.c (moved) * contrib/altq/freebsd/altq/altq_rmclass.h (moved) * contrib/altq/freebsd/altq/altq_rmclass_debug.h (moved) * contrib/altq/freebsd/altq/altq_subr.c (moved) * contrib/altq/freebsd/altq/altq_var.h (moved) * contrib/altq/freebsd/altq/altqconf.h (moved) * contrib/altq/freebsd/altq/if_altq.h (moved) * contrib/pf/freebsd/net/if_pflog.c (moved) * contrib/pf/freebsd/net/if_pflog.h (moved) * contrib/pf/freebsd/net/if_pfsync.c (moved) * contrib/pf/freebsd/net/if_pfsync.h (moved) * contrib/pf/freebsd/net/pf.c (moved) * contrib/pf/freebsd/net/pf_if.c (moved) * contrib/pf/freebsd/net/pf_ioctl.c (moved) * contrib/pf/freebsd/net/pf_mtag.h (moved) * contrib/pf/freebsd/net/pf_norm.c (moved) * contrib/pf/freebsd/net/pf_osfp.c (moved) * contrib/pf/freebsd/net/pf_ruleset.c (moved) * contrib/pf/freebsd/net/pf_subr.c (moved) * contrib/pf/freebsd/net/pf_table.c (moved) * contrib/pf/freebsd/net/pfvar.h (moved) * contrib/pf/freebsd/netinet/in4_cksum.c (moved) * freebsd/bsm/audit.h (modified) * freebsd/cam/ata/ata_all.h (modified) * freebsd/cam/cam.c (modified) * freebsd/cam/cam.h (modified) * freebsd/cam/cam_ccb.h (modified) * freebsd/cam/cam_periph.h (modified) * freebsd/cam/cam_xpt_sim.h (modified) * freebsd/cam/scsi/scsi_all.c (modified) * freebsd/cam/scsi/scsi_all.h (modified) * freebsd/cam/scsi/scsi_da.h (modified) * freebsd/crypto/blowfish/bf_ecb.c (modified) * freebsd/crypto/blowfish/bf_enc.c (modified) * freebsd/crypto/blowfish/bf_skey.c (modified) * freebsd/crypto/camellia/camellia-api.c (modified) * freebsd/crypto/camellia/camellia.c (modified) * freebsd/crypto/des/des_ecb.c (modified) * freebsd/crypto/des/des_enc.c (modified) * freebsd/crypto/des/des_locl.h (modified) * freebsd/crypto/des/des_setkey.c (modified) * freebsd/crypto/rc4/rc4.c (modified) * freebsd/crypto/rijndael/rijndael-alg-fst.c (modified) * freebsd/crypto/rijndael/rijndael-api-fst.c (modified) * freebsd/crypto/rijndael/rijndael-api-fst.h (modified) * freebsd/crypto/rijndael/rijndael-api.c (modified) * freebsd/crypto/sha1.c (modified) * freebsd/crypto/sha2/sha2.c (modified) * freebsd/crypto/sha2/sha2.h (modified) * freebsd/dev/mii/icsphy.c (modified) * freebsd/dev/mii/mii.c (modified) * freebsd/dev/mii/mii_physubr.c (modified) * freebsd/dev/mii/miivar.h (modified) * freebsd/dev/usb/controller/ehci.c (modified) * freebsd/dev/usb/controller/ohci.c (modified) * freebsd/dev/usb/controller/ohci_lpc3250.c (modified) * freebsd/dev/usb/controller/usb_controller.c (modified) * freebsd/dev/usb/quirk/usb_quirk.c (modified) * freebsd/dev/usb/storage/umass.c (modified) * freebsd/dev/usb/ufm_ioctl.h (modified) * freebsd/dev/usb/usb.h (modified) * freebsd/dev/usb/usb_busdma.c (modified) * freebsd/dev/usb/usb_busdma.h (modified) * freebsd/dev/usb/usb_core.c (modified) * freebsd/dev/usb/usb_debug.c (modified) * freebsd/dev/usb/usb_dev.c (modified) * freebsd/dev/usb/usb_dev.h (modified) * freebsd/dev/usb/usb_device.c (modified) * freebsd/dev/usb/usb_dynamic.c (modified) * freebsd/dev/usb/usb_endian.h (modified) * freebsd/dev/usb/usb_error.c (modified) * freebsd/dev/usb/usb_generic.c (modified) * freebsd/dev/usb/usb_handle_request.c (modified) * freebsd/dev/usb/usb_hid.c (modified) * freebsd/dev/usb/usb_hub.c (modified) * freebsd/dev/usb/usb_ioctl.h (modified) * freebsd/dev/usb/usb_lookup.c (modified) * freebsd/dev/usb/usb_mbuf.c (modified) * freebsd/dev/usb/usb_msctest.c (modified) * freebsd/dev/usb/usb_parse.c (modified) * freebsd/dev/usb/usb_process.c (modified) * freebsd/dev/usb/usb_process.h (modified) * freebsd/dev/usb/usb_request.c (modified) * freebsd/dev/usb/usb_transfer.c (modified) * freebsd/dev/usb/usb_util.c (modified) * freebsd/dev/usb/usbdi.h (modified) * freebsd/dev/usb/usbhid.h (modified) * freebsd/fs/devfs/devfs_int.h (modified) * freebsd/kern/init_main.c (modified) * freebsd/kern/kern_mbuf.c (modified) * freebsd/kern/kern_module.c (modified) * freebsd/kern/kern_sysctl.c (modified) * freebsd/kern/subr_bus.c (modified) * freebsd/kern/subr_kobj.c (modified) * freebsd/kern/uipc_mbuf.c (modified) * freebsd/kern/uipc_mbuf2.c (modified) * freebsd/kern/uipc_socket.c (modified) * freebsd/local/bus_if.c (modified) * freebsd/local/cryptodev_if.c (modified) * freebsd/local/device_if.c (modified) * freebsd/local/miibus_if.c (modified) * freebsd/local/usb_if.c (modified) * freebsd/local/vnode_if.h (modified) * freebsd/net/bpf.c (modified) * freebsd/net/bpf_buffer.c (modified) * freebsd/net/bpf_filter.c (modified) * freebsd/net/bpf_jitter.c (modified) * freebsd/net/bpfdesc.h (modified) * freebsd/net/bridgestp.c (modified) * freebsd/net/bridgestp.h (modified) * freebsd/net/ethernet.h (modified) * freebsd/net/ieee8023ad_lacp.c (modified) * freebsd/net/if.c (modified) * freebsd/net/if.h (modified) * freebsd/net/if_arcsubr.c (modified) * freebsd/net/if_atmsubr.c (modified) * freebsd/net/if_bridge.c (modified) * freebsd/net/if_bridgevar.h (modified) * freebsd/net/if_clone.c (modified) * freebsd/net/if_dead.c (modified) * freebsd/net/if_disc.c (modified) * freebsd/net/if_dl.h (modified) * freebsd/net/if_edsc.c (modified) * freebsd/net/if_ef.c (modified) * freebsd/net/if_enc.c (modified) * freebsd/net/if_epair.c (modified) * freebsd/net/if_ethersubr.c (modified) * freebsd/net/if_faith.c (modified) * freebsd/net/if_fddisubr.c (modified) * freebsd/net/if_fwsubr.c (modified) * freebsd/net/if_gif.c (modified) * freebsd/net/if_gif.h (modified) * freebsd/net/if_gre.c (modified) * freebsd/net/if_gre.h (modified) * freebsd/net/if_iso88025subr.c (modified) * freebsd/net/if_lagg.c (modified) * freebsd/net/if_llatbl.c (modified) * freebsd/net/if_llatbl.h (modified) * freebsd/net/if_loop.c (modified) * freebsd/net/if_media.c (modified) * freebsd/net/if_media.h (modified) * freebsd/net/if_mib.c (modified) * freebsd/net/if_spppfr.c (modified) * freebsd/net/if_spppsubr.c (modified) * freebsd/net/if_stf.c (modified) * freebsd/net/if_tap.c (modified) * freebsd/net/if_tun.c (modified) * freebsd/net/if_var.h (modified) * freebsd/net/if_vlan.c (modified) * freebsd/net/netisr.c (modified) * freebsd/net/pfil.c (modified) * freebsd/net/pfil.h (modified) * freebsd/net/radix.c (modified) * freebsd/net/radix.h (modified) * freebsd/net/radix_mpath.c (modified) * freebsd/net/raw_cb.c (modified) * freebsd/net/raw_cb.h (modified) * freebsd/net/raw_usrreq.c (modified) * freebsd/net/route.c (modified) * freebsd/net/route.h (modified) * freebsd/net/rtsock.c (modified) * freebsd/net/slcompress.c (modified) * freebsd/net/vnet.h (modified) * freebsd/net/zlib.c (modified) * freebsd/net/zlib.h (modified) * freebsd/net80211/ieee80211.c (modified) * freebsd/net80211/ieee80211_acl.c (modified) * freebsd/net80211/ieee80211_action.c (modified) * freebsd/net80211/ieee80211_adhoc.c (modified) * freebsd/net80211/ieee80211_ageq.c (modified) * freebsd/net80211/ieee80211_amrr.c (modified) * freebsd/net80211/ieee80211_crypto.c (modified) * freebsd/net80211/ieee80211_crypto_ccmp.c (modified) * freebsd/net80211/ieee80211_crypto_none.c (modified) * freebsd/net80211/ieee80211_crypto_tkip.c (modified) * freebsd/net80211/ieee80211_crypto_wep.c (modified) * freebsd/net80211/ieee80211_ddb.c (modified) * freebsd/net80211/ieee80211_dfs.c (modified) * freebsd/net80211/ieee80211_freebsd.c (modified) * freebsd/net80211/ieee80211_freebsd.h (modified) * freebsd/net80211/ieee80211_hostap.c (modified) * freebsd/net80211/ieee80211_ht.c (modified) * freebsd/net80211/ieee80211_hwmp.c (modified) * freebsd/net80211/ieee80211_input.c (modified) * freebsd/net80211/ieee80211_ioctl.c (modified) * freebsd/net80211/ieee80211_ioctl.h (modified) * freebsd/net80211/ieee80211_mesh.c (modified) * freebsd/net80211/ieee80211_monitor.c (modified) * freebsd/net80211/ieee80211_node.c (modified) * freebsd/net80211/ieee80211_node.h (modified) * freebsd/net80211/ieee80211_output.c (modified) * freebsd/net80211/ieee80211_phy.c (modified) * freebsd/net80211/ieee80211_power.c (modified) * freebsd/net80211/ieee80211_proto.c (modified) * freebsd/net80211/ieee80211_radiotap.c (modified) * freebsd/net80211/ieee80211_ratectl.c (modified) * freebsd/net80211/ieee80211_ratectl_none.c (modified) * freebsd/net80211/ieee80211_regdomain.c (modified) * freebsd/net80211/ieee80211_rssadapt.c (modified) * freebsd/net80211/ieee80211_scan.c (modified) * freebsd/net80211/ieee80211_scan_sta.c (modified) * freebsd/net80211/ieee80211_sta.c (modified) * freebsd/net80211/ieee80211_superg.c (modified) * freebsd/net80211/ieee80211_tdma.c (modified) * freebsd/net80211/ieee80211_var.h (modified) * freebsd/net80211/ieee80211_wds.c (modified) * freebsd/net80211/ieee80211_xauth.c (modified) * freebsd/netinet/accf_data.c (modified) * freebsd/netinet/accf_dns.c (modified) * freebsd/netinet/accf_http.c (modified) * freebsd/netinet/if_atm.c (modified) * freebsd/netinet/if_ether.c (modified) * freebsd/netinet/if_ether.h (modified) * freebsd/netinet/igmp.c (modified) * freebsd/netinet/in.c (modified) * freebsd/netinet/in.h (modified) * freebsd/netinet/in_cksum.c (modified) * freebsd/netinet/in_gif.c (modified) * freebsd/netinet/in_mcast.c (modified) * freebsd/netinet/in_pcb.c (modified) * freebsd/netinet/in_pcb.h (modified) * freebsd/netinet/in_proto.c (modified) * freebsd/netinet/in_rmx.c (modified) * freebsd/netinet/in_var.h (modified) * freebsd/netinet/ip.h (modified) * freebsd/netinet/ip_carp.c (modified) * freebsd/netinet/ip_divert.c (modified) * freebsd/netinet/ip_ecn.c (modified) * freebsd/netinet/ip_ecn.h (modified) * freebsd/netinet/ip_encap.c (modified) * freebsd/netinet/ip_fastfwd.c (modified) * freebsd/netinet/ip_gre.c (modified) * freebsd/netinet/ip_icmp.c (modified) * freebsd/netinet/ip_id.c (modified) * freebsd/netinet/ip_input.c (modified) * freebsd/netinet/ip_ipsec.c (modified) * freebsd/netinet/ip_mroute.c (modified) * freebsd/netinet/ip_options.c (modified) * freebsd/netinet/ip_output.c (modified) * freebsd/netinet/ip_var.h (modified) * freebsd/netinet/ipfw/dn_heap.c (modified) * freebsd/netinet/ipfw/dn_sched_fifo.c (modified) * freebsd/netinet/ipfw/dn_sched_prio.c (modified) * freebsd/netinet/ipfw/dn_sched_qfq.c (modified) * freebsd/netinet/ipfw/dn_sched_rr.c (modified) * freebsd/netinet/ipfw/dn_sched_wf2q.c (modified) * freebsd/netinet/ipfw/ip_dn_glue.c (modified) * freebsd/netinet/ipfw/ip_dn_io.c (modified) * freebsd/netinet/ipfw/ip_dummynet.c (modified) * freebsd/netinet/ipfw/ip_fw2.c (modified) * freebsd/netinet/ipfw/ip_fw_log.c (modified) * freebsd/netinet/ipfw/ip_fw_nat.c (modified) * freebsd/netinet/ipfw/ip_fw_pfil.c (modified) * freebsd/netinet/ipfw/ip_fw_sockopt.c (modified) * freebsd/netinet/ipfw/ip_fw_table.c (modified) * freebsd/netinet/libalias/alias.c (modified) * freebsd/netinet/libalias/alias.h (modified) * freebsd/netinet/libalias/alias_cuseeme.c (modified) * freebsd/netinet/libalias/alias_db.c (modified) * freebsd/netinet/libalias/alias_dummy.c (modified) * freebsd/netinet/libalias/alias_ftp.c (modified) * freebsd/netinet/libalias/alias_irc.c (modified) * freebsd/netinet/libalias/alias_local.h (modified) * freebsd/netinet/libalias/alias_mod.c (modified) * freebsd/netinet/libalias/alias_nbt.c (modified) * freebsd/netinet/libalias/alias_pptp.c (modified) * freebsd/netinet/libalias/alias_proxy.c (modified) * freebsd/netinet/libalias/alias_sctp.c (modified) * freebsd/netinet/libalias/alias_sctp.h (modified) * freebsd/netinet/libalias/alias_skinny.c (modified) * freebsd/netinet/libalias/alias_smedia.c (modified) * freebsd/netinet/libalias/alias_util.c (modified) * freebsd/netinet/pim.h (modified) * freebsd/netinet/raw_ip.c (modified) * freebsd/netinet/sctp.h (modified) * freebsd/netinet/sctp_asconf.c (modified) * freebsd/netinet/sctp_asconf.h (modified) * freebsd/netinet/sctp_auth.c (modified) * freebsd/netinet/sctp_auth.h (modified) * freebsd/netinet/sctp_bsd_addr.c (modified) * freebsd/netinet/sctp_bsd_addr.h (modified) * freebsd/netinet/sctp_cc_functions.c (modified) * freebsd/netinet/sctp_cc_functions.h (modified) * freebsd/netinet/sctp_constants.h (modified) * freebsd/netinet/sctp_crc32.c (modified) * freebsd/netinet/sctp_crc32.h (modified) * freebsd/netinet/sctp_header.h (modified) * freebsd/netinet/sctp_indata.c (modified) * freebsd/netinet/sctp_indata.h (modified) * freebsd/netinet/sctp_input.c (modified) * freebsd/netinet/sctp_input.h (modified) * freebsd/netinet/sctp_lock_bsd.h (modified) * freebsd/netinet/sctp_os.h (modified) * freebsd/netinet/sctp_os_bsd.h (modified) * freebsd/netinet/sctp_output.c (modified) * freebsd/netinet/sctp_output.h (modified) * freebsd/netinet/sctp_pcb.c (modified) * freebsd/netinet/sctp_pcb.h (modified) * freebsd/netinet/sctp_peeloff.c (modified) * freebsd/netinet/sctp_peeloff.h (modified) * freebsd/netinet/sctp_structs.h (modified) * freebsd/netinet/sctp_sysctl.c (modified) * freebsd/netinet/sctp_sysctl.h (modified) * freebsd/netinet/sctp_timer.c (modified) * freebsd/netinet/sctp_timer.h (modified) * freebsd/netinet/sctp_uio.h (modified) * freebsd/netinet/sctp_usrreq.c (modified) * freebsd/netinet/sctp_var.h (modified) * freebsd/netinet/sctputil.c (modified) * freebsd/netinet/sctputil.h (modified) * freebsd/netinet/tcp.h (modified) * freebsd/netinet/tcp_debug.c (modified) * freebsd/netinet/tcp_input.c (modified) * freebsd/netinet/tcp_lro.c (modified) * freebsd/netinet/tcp_offload.c (modified) * freebsd/netinet/tcp_output.c (modified) * freebsd/netinet/tcp_reass.c (modified) * freebsd/netinet/tcp_sack.c (modified) * freebsd/netinet/tcp_subr.c (modified) * freebsd/netinet/tcp_syncache.c (modified) * freebsd/netinet/tcp_timer.c (modified) * freebsd/netinet/tcp_timewait.c (modified) * freebsd/netinet/tcp_usrreq.c (modified) * freebsd/netinet/tcp_var.h (modified) * freebsd/netinet/udp_usrreq.c (modified) * freebsd/netinet6/dest6.c (modified) * freebsd/netinet6/frag6.c (modified) * freebsd/netinet6/icmp6.c (modified) * freebsd/netinet6/in6.c (modified) * freebsd/netinet6/in6_cksum.c (modified) * freebsd/netinet6/in6_gif.c (modified) * freebsd/netinet6/in6_ifattach.c (modified) * freebsd/netinet6/in6_mcast.c (modified) * freebsd/netinet6/in6_pcb.c (modified) * freebsd/netinet6/in6_proto.c (modified) * freebsd/netinet6/in6_rmx.c (modified) * freebsd/netinet6/in6_src.c (modified) * freebsd/netinet6/in6_var.h (modified) * freebsd/netinet6/ip6_forward.c (modified) * freebsd/netinet6/ip6_id.c (modified) * freebsd/netinet6/ip6_input.c (modified) * freebsd/netinet6/ip6_ipsec.c (modified) * freebsd/netinet6/ip6_mroute.c (modified) * freebsd/netinet6/ip6_output.c (modified) * freebsd/netinet6/mld6.c (modified) * freebsd/netinet6/nd6.c (modified) * freebsd/netinet6/nd6.h (modified) * freebsd/netinet6/nd6_nbr.c (modified) * freebsd/netinet6/nd6_rtr.c (modified) * freebsd/netinet6/raw_ip6.c (modified) * freebsd/netinet6/route6.c (modified) * freebsd/netinet6/scope6.c (modified) * freebsd/netinet6/sctp6_usrreq.c (modified) * freebsd/netinet6/sctp6_var.h (modified) * freebsd/netinet6/udp6_usrreq.c (modified) * freebsd/netipsec/ipsec.c (modified) * freebsd/netipsec/ipsec.h (modified) * freebsd/netipsec/ipsec6.h (modified) * freebsd/netipsec/ipsec_input.c (modified) * freebsd/netipsec/ipsec_mbuf.c (modified) * freebsd/netipsec/ipsec_output.c (modified) * freebsd/netipsec/key.c (modified) * freebsd/netipsec/key_debug.c (modified) * freebsd/netipsec/keydb.h (modified) * freebsd/netipsec/keysock.c (modified) * freebsd/netipsec/xform.h (modified) * freebsd/netipsec/xform_ah.c (modified) * freebsd/netipsec/xform_esp.c (modified) * freebsd/netipsec/xform_ipcomp.c (modified) * freebsd/netipsec/xform_ipip.c (modified) * freebsd/netipsec/xform_tcp.c (modified) * freebsd/opencrypto/cast.c (modified) * freebsd/opencrypto/criov.c (modified) * freebsd/opencrypto/crypto.c (modified) * freebsd/opencrypto/cryptodev.c (modified) * freebsd/opencrypto/cryptodev.h (modified) * freebsd/opencrypto/cryptosoft.c (modified) * freebsd/opencrypto/deflate.c (modified) * freebsd/opencrypto/deflate.h (modified) * freebsd/opencrypto/rmd160.c (modified) * freebsd/opencrypto/skipjack.c (modified) * freebsd/opencrypto/xform.c (modified) * freebsd/opencrypto/xform.h (modified) * freebsd/security/mac/mac_framework.h (modified) * freebsd/sys/_iovec.h (modified) * freebsd/sys/_lockmgr.h (modified) * freebsd/sys/_rmlock.h (modified) * freebsd/sys/_semaphore.h (modified) * freebsd/sys/_task.h (modified) * freebsd/sys/_types.h (modified) * freebsd/sys/acl.h (modified) * freebsd/sys/ata.h (modified) * freebsd/sys/buf_ring.h (modified) * freebsd/sys/bufobj.h (modified) * freebsd/sys/bus.h (modified) * freebsd/sys/bus_dma.h (modified) * freebsd/sys/callout.h (modified) * freebsd/sys/condvar.h (modified) * freebsd/sys/conf.h (modified) * freebsd/sys/cpu.h (modified) * freebsd/sys/endian.h (modified) * freebsd/sys/errno.h (modified) * freebsd/sys/event.h (modified) * freebsd/sys/eventhandler.h (modified) * freebsd/sys/fcntl.h (modified) * freebsd/sys/file.h (modified) * freebsd/sys/filedesc.h (modified) * freebsd/sys/filio.h (modified) * freebsd/sys/hash.h (modified) * freebsd/sys/interrupt.h (modified) * freebsd/sys/ioccom.h (modified) * freebsd/sys/jail.h (modified) * freebsd/sys/kernel.h (modified) * freebsd/sys/kthread.h (modified) * freebsd/sys/libkern.h (modified) * freebsd/sys/linker.h (modified) * freebsd/sys/lock.h (modified) * freebsd/sys/lock_profile.h (modified) * freebsd/sys/lockmgr.h (modified) * freebsd/sys/malloc.h (modified) * freebsd/sys/mbuf.h (modified) * freebsd/sys/md5.h (modified) * freebsd/sys/module.h (modified) * freebsd/sys/mount.h (modified) * freebsd/sys/mutex.h (modified) * freebsd/sys/osd.h (modified) * freebsd/sys/param.h (modified) * freebsd/sys/pcpu.h (modified) * freebsd/sys/poll.h (modified) * freebsd/sys/proc.h (modified) * freebsd/sys/queue.h (modified) * freebsd/sys/refcount.h (modified) * freebsd/sys/resource.h (modified) * freebsd/sys/resourcevar.h (modified) * freebsd/sys/rman.h (modified) * freebsd/sys/rmlock.h (modified) * freebsd/sys/rtprio.h (modified) * freebsd/sys/runq.h (modified) * freebsd/sys/rwlock.h (modified) * freebsd/sys/sbuf.h (modified) * freebsd/sys/selinfo.h (modified) * freebsd/sys/sf_buf.h (modified) * freebsd/sys/signal.h (modified) * freebsd/sys/signalvar.h (modified) * freebsd/sys/sockbuf.h (modified) * freebsd/sys/socket.h (modified) * freebsd/sys/socketvar.h (modified) * freebsd/sys/sockio.h (modified) * freebsd/sys/stddef.h (modified) * freebsd/sys/stdint.h (modified) * freebsd/sys/sx.h (modified) * freebsd/sys/sysctl.h (modified) * freebsd/sys/syslog.h (modified) * freebsd/sys/systm.h (modified) * freebsd/sys/taskqueue.h (modified) * freebsd/sys/time.h (modified) * freebsd/sys/tree.h (modified) * freebsd/sys/ttycom.h (modified) * freebsd/sys/types.h (modified) * freebsd/sys/ucontext.h (modified) * freebsd/sys/ucred.h (modified) * freebsd/sys/uio.h (modified) * freebsd/sys/unistd.h (modified) * freebsd/vm/uma.h (modified) Begin to trim rtems/ from include file paths - start with freebsd Thu, 08 Mar 2012 13:25:21 GMT Joel Sherrill [e2d2bf5] * freebsd/bsm/audit.h (moved) * freebsd/bsm/audit_kevents.h (moved) * freebsd/cam/ata/ata_all.h (moved) * freebsd/cam/cam.c (moved) * freebsd/cam/cam.h (moved) * freebsd/cam/cam_ccb.h (moved) * freebsd/cam/cam_debug.h (moved) * freebsd/cam/cam_periph.h (moved) * freebsd/cam/cam_queue.h (moved) * freebsd/cam/cam_sim.h (moved) * freebsd/cam/cam_xpt.h (moved) * freebsd/cam/cam_xpt_sim.h (moved) * freebsd/cam/scsi/scsi_all.c (moved) * freebsd/cam/scsi/scsi_all.h (moved) * freebsd/cam/scsi/scsi_da.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_cbq.c (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_cbq.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_cdnr.c (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_cdnr.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_classq.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_hfsc.c (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_hfsc.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_priq.c (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_priq.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_red.c (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_red.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_rio.c (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_rio.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_rmclass.c (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_rmclass.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_rmclass_debug.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_subr.c (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altq_var.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/altqconf.h (moved) * freebsd/contrib/altq/rtems/freebsd/altq/if_altq.h (moved) * freebsd/contrib/pf/rtems/freebsd/net/if_pflog.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/if_pflog.h (moved) * freebsd/contrib/pf/rtems/freebsd/net/if_pfsync.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/if_pfsync.h (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf_if.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf_ioctl.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf_mtag.h (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf_norm.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf_osfp.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf_ruleset.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf_subr.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/pf_table.c (moved) * freebsd/contrib/pf/rtems/freebsd/net/pfvar.h (moved) * freebsd/contrib/pf/rtems/freebsd/netinet/in4_cksum.c (moved) * freebsd/crypto/blowfish/bf_ecb.c (moved) * freebsd/crypto/blowfish/bf_enc.c (moved) * freebsd/crypto/blowfish/bf_locl.h (moved) * freebsd/crypto/blowfish/bf_pi.h (moved) * freebsd/crypto/blowfish/bf_skey.c (moved) * freebsd/crypto/blowfish/blowfish.h (moved) * freebsd/crypto/camellia/camellia-api.c (moved) * freebsd/crypto/camellia/camellia.c (moved) * freebsd/crypto/camellia/camellia.h (moved) * freebsd/crypto/des/des.h (moved) * freebsd/crypto/des/des_ecb.c (moved) * freebsd/crypto/des/des_enc.c (moved) * freebsd/crypto/des/des_locl.h (moved) * freebsd/crypto/des/des_setkey.c (moved) * freebsd/crypto/des/podd.h (moved) * freebsd/crypto/des/sk.h (moved) * freebsd/crypto/des/spr.h (moved) * freebsd/crypto/rc4/rc4.c (moved) * freebsd/crypto/rc4/rc4.h (moved) * freebsd/crypto/rijndael/rijndael-alg-fst.c (moved) * freebsd/crypto/rijndael/rijndael-api-fst.c (moved) * freebsd/crypto/rijndael/rijndael-api-fst.h (moved) * freebsd/crypto/rijndael/rijndael-api.c (moved) * freebsd/crypto/rijndael/rijndael.h (moved) * freebsd/crypto/rijndael/rijndael_local.h (moved) * freebsd/crypto/sha1.c (moved) * freebsd/crypto/sha1.h (moved) * freebsd/crypto/sha2/sha2.c (moved) * freebsd/crypto/sha2/sha2.h (moved) * freebsd/ddb/db_sym.h (moved) * freebsd/ddb/ddb.h (moved) * freebsd/dev/mii/icsphy.c (moved) * freebsd/dev/mii/icsphyreg.h (moved) * freebsd/dev/mii/mii.c (moved) * freebsd/dev/mii/mii.h (moved) * freebsd/dev/mii/mii_physubr.c (moved) * freebsd/dev/mii/miivar.h (moved) * freebsd/dev/pci/pcireg.h (moved) * freebsd/dev/pci/pcivar.h (moved) * freebsd/dev/usb/controller/ehci.c (moved) * freebsd/dev/usb/controller/ehci.h (moved) * freebsd/dev/usb/controller/ehcireg.h (moved) * freebsd/dev/usb/controller/ohci.c (moved) * freebsd/dev/usb/controller/ohci.h (moved) * freebsd/dev/usb/controller/ohci_lpc3250.c (moved) * freebsd/dev/usb/controller/ohcireg.h (moved) * freebsd/dev/usb/controller/usb_controller.c (moved) * freebsd/dev/usb/quirk/usb_quirk.c (moved) * freebsd/dev/usb/quirk/usb_quirk.h (moved) * freebsd/dev/usb/storage/umass.c (moved) * freebsd/dev/usb/ufm_ioctl.h (moved) * freebsd/dev/usb/usb.h (moved) * freebsd/dev/usb/usb_bus.h (moved) * freebsd/dev/usb/usb_busdma.c (moved) * freebsd/dev/usb/usb_busdma.h (moved) * freebsd/dev/usb/usb_cdc.h (moved) * freebsd/dev/usb/usb_controller.h (moved) * freebsd/dev/usb/usb_core.c (moved) * freebsd/dev/usb/usb_core.h (moved) * freebsd/dev/usb/usb_debug.c (moved) * freebsd/dev/usb/usb_debug.h (moved) * freebsd/dev/usb/usb_dev.c (moved) * freebsd/dev/usb/usb_dev.h (moved) * freebsd/dev/usb/usb_device.c (moved) * freebsd/dev/usb/usb_device.h (moved) * freebsd/dev/usb/usb_dynamic.c (moved) * freebsd/dev/usb/usb_dynamic.h (moved) * freebsd/dev/usb/usb_endian.h (moved) * freebsd/dev/usb/usb_error.c (moved) * freebsd/dev/usb/usb_freebsd.h (moved) * freebsd/dev/usb/usb_generic.c (moved) * freebsd/dev/usb/usb_generic.h (moved) * freebsd/dev/usb/usb_handle_request.c (moved) * freebsd/dev/usb/usb_hid.c (moved) * freebsd/dev/usb/usb_hub.c (moved) * freebsd/dev/usb/usb_hub.h (moved) * freebsd/dev/usb/usb_ioctl.h (moved) * freebsd/dev/usb/usb_lookup.c (moved) * freebsd/dev/usb/usb_mbuf.c (moved) * freebsd/dev/usb/usb_mbuf.h (moved) * freebsd/dev/usb/usb_msctest.c (moved) * freebsd/dev/usb/usb_msctest.h (moved) * freebsd/dev/usb/usb_parse.c (moved) * freebsd/dev/usb/usb_process.c (moved) * freebsd/dev/usb/usb_process.h (moved) * freebsd/dev/usb/usb_request.c (moved) * freebsd/dev/usb/usb_request.h (moved) * freebsd/dev/usb/usb_transfer.c (moved) * freebsd/dev/usb/usb_transfer.h (moved) * freebsd/dev/usb/usb_util.c (moved) * freebsd/dev/usb/usb_util.h (moved) * freebsd/dev/usb/usbdi.h (moved) * freebsd/dev/usb/usbdi_util.h (moved) * freebsd/dev/usb/usbhid.h (moved) * freebsd/fs/devfs/devfs_int.h (moved) * freebsd/geom/geom_disk.h (moved) * freebsd/kern/init_main.c (moved) * freebsd/kern/kern_mbuf.c (moved) * freebsd/kern/kern_module.c (moved) * freebsd/kern/kern_sysctl.c (moved) * freebsd/kern/subr_bus.c (moved) * freebsd/kern/subr_kobj.c (moved) * freebsd/kern/uipc_mbuf.c (moved) * freebsd/kern/uipc_mbuf2.c (moved) * freebsd/kern/uipc_socket.c (moved) * freebsd/local/bus_if.c (moved) * freebsd/local/bus_if.h (moved) * freebsd/local/cryptodev_if.c (moved) * freebsd/local/cryptodev_if.h (moved) * freebsd/local/device_if.c (moved) * freebsd/local/device_if.h (moved) * freebsd/local/miibus_if.c (moved) * freebsd/local/miibus_if.h (moved) * freebsd/local/miidevs.h (moved) * freebsd/local/opt_altq.h (moved) * freebsd/local/opt_atalk.h (moved) * freebsd/local/opt_bootp.h (moved) * freebsd/local/opt_bpf.h (moved) * freebsd/local/opt_bus.h (moved) * freebsd/local/opt_cam.h (moved) * freebsd/local/opt_carp.h (moved) * freebsd/local/opt_compat.h (moved) * freebsd/local/opt_config.h (moved) * freebsd/local/opt_cpu.h (moved) * freebsd/local/opt_ddb.h (moved) * freebsd/local/opt_device_polling.h (moved) * freebsd/local/opt_ef.h (moved) * freebsd/local/opt_enc.h (moved) * freebsd/local/opt_hwpmc_hooks.h (moved) * freebsd/local/opt_inet.h (moved) * freebsd/local/opt_inet6.h (moved) * freebsd/local/opt_init_path.h (moved) * freebsd/local/opt_ipdivert.h (moved) * freebsd/local/opt_ipdn.h (moved) * freebsd/local/opt_ipfw.h (moved) * freebsd/local/opt_ipsec.h (moved) * freebsd/local/opt_ipstealth.h (moved) * freebsd/local/opt_ipx.h (moved) * freebsd/local/opt_kdb.h (moved) * freebsd/local/opt_kdtrace.h (moved) * freebsd/local/opt_ktrace.h (moved) * freebsd/local/opt_mbuf_profiling.h (moved) * freebsd/local/opt_mbuf_stress_test.h (moved) * freebsd/local/opt_mpath.h (moved) * freebsd/local/opt_mrouting.h (moved) * freebsd/local/opt_natm.h (moved) * freebsd/local/opt_netgraph.h (moved) * freebsd/local/opt_param.h (moved) * freebsd/local/opt_pf.h (moved) * freebsd/local/opt_posix.h (moved) * freebsd/local/opt_printf.h (moved) * freebsd/local/opt_route.h (moved) * freebsd/local/opt_scsi.h (moved) * freebsd/local/opt_sctp.h (moved) * freebsd/local/opt_tcpdebug.h (moved) * freebsd/local/opt_tdma.h (moved) * freebsd/local/opt_usb.h (moved) * freebsd/local/opt_vlan.h (moved) * freebsd/local/opt_wlan.h (moved) * freebsd/local/opt_zero.h (moved) * freebsd/local/pmap.h (moved) * freebsd/local/usb_if.c (moved) * freebsd/local/usb_if.h (moved) * freebsd/local/usbdevs.h (moved) * freebsd/local/usbdevs_data.h (moved) * freebsd/local/vnode_if.h (moved) * freebsd/local/vnode_if_newproto.h (moved) * freebsd/local/vnode_if_typedef.h (moved) * freebsd/machine/cpu.h (moved) * freebsd/machine/elf.h (moved) * freebsd/machine/in_cksum.h (moved) * freebsd/machine/sf_buf.h (moved) * freebsd/net/bpf.c (moved) * freebsd/net/bpf.h (moved) * freebsd/net/bpf_buffer.c (moved) * freebsd/net/bpf_buffer.h (moved) * freebsd/net/bpf_filter.c (moved) * freebsd/net/bpf_jitter.c (moved) * freebsd/net/bpf_jitter.h (moved) * freebsd/net/bpf_zerocopy.h (moved) * freebsd/net/bpfdesc.h (moved) * freebsd/net/bridgestp.c (moved) * freebsd/net/bridgestp.h (moved) * freebsd/net/ethernet.h (moved) * freebsd/net/fddi.h (moved) * freebsd/net/firewire.h (moved) * freebsd/net/flowtable.h (moved) * freebsd/net/ieee8023ad_lacp.c (moved) * freebsd/net/ieee8023ad_lacp.h (moved) * freebsd/net/if.c (moved) * freebsd/net/if.h (moved) * freebsd/net/if_arc.h (moved) * freebsd/net/if_arcsubr.c (moved) * freebsd/net/if_arp.h (moved) * freebsd/net/if_atm.h (moved) * freebsd/net/if_atmsubr.c (moved) * freebsd/net/if_bridge.c (moved) * freebsd/net/if_bridgevar.h (moved) * freebsd/net/if_clone.c (moved) * freebsd/net/if_clone.h (moved) * freebsd/net/if_dead.c (moved) * freebsd/net/if_disc.c (moved) * freebsd/net/if_dl.h (moved) * freebsd/net/if_edsc.c (moved) * freebsd/net/if_ef.c (moved) * freebsd/net/if_enc.c (moved) * freebsd/net/if_enc.h (moved) * freebsd/net/if_epair.c (moved) * freebsd/net/if_ethersubr.c (moved) * freebsd/net/if_faith.c (moved) * freebsd/net/if_fddisubr.c (moved) * freebsd/net/if_fwsubr.c (moved) * freebsd/net/if_gif.c (moved) * freebsd/net/if_gif.h (moved) * freebsd/net/if_gre.c (moved) * freebsd/net/if_gre.h (moved) * freebsd/net/if_iso88025subr.c (moved) * freebsd/net/if_lagg.c (moved) * freebsd/net/if_lagg.h (moved) * freebsd/net/if_llatbl.c (moved) * freebsd/net/if_llatbl.h (moved) * freebsd/net/if_llc.h (moved) * freebsd/net/if_loop.c (moved) * freebsd/net/if_media.c (moved) * freebsd/net/if_media.h (moved) * freebsd/net/if_mib.c (moved) * freebsd/net/if_mib.h (moved) * freebsd/net/if_sppp.h (moved) * freebsd/net/if_spppfr.c (moved) * freebsd/net/if_spppsubr.c (moved) * freebsd/net/if_stf.c (moved) * freebsd/net/if_stf.h (moved) * freebsd/net/if_tap.c (moved) * freebsd/net/if_tap.h (moved) * freebsd/net/if_tapvar.h (moved) * freebsd/net/if_tun.c (moved) * freebsd/net/if_tun.h (moved) * freebsd/net/if_types.h (moved) * freebsd/net/if_var.h (moved) * freebsd/net/if_vlan.c (moved) * freebsd/net/if_vlan_var.h (moved) * freebsd/net/iso88025.h (moved) * freebsd/net/netisr.c (moved) * freebsd/net/netisr.h (moved) * freebsd/net/pfil.c (moved) * freebsd/net/pfil.h (moved) * freebsd/net/pfkeyv2.h (moved) * freebsd/net/ppp_defs.h (moved) * freebsd/net/radix.c (moved) * freebsd/net/radix.h (moved) * freebsd/net/radix_mpath.c (moved) * freebsd/net/radix_mpath.h (moved) * freebsd/net/raw_cb.c (moved) * freebsd/net/raw_cb.h (moved) * freebsd/net/raw_usrreq.c (moved) * freebsd/net/route.c (moved) * freebsd/net/route.h (moved) * freebsd/net/rtsock.c (moved) * freebsd/net/slcompress.c (moved) * freebsd/net/slcompress.h (moved) * freebsd/net/vnet.h (moved) * freebsd/net/zlib.c (moved) * freebsd/net/zlib.h (moved) * freebsd/net80211/_ieee80211.h (moved) * freebsd/net80211/ieee80211.c (moved) * freebsd/net80211/ieee80211.h (moved) * freebsd/net80211/ieee80211_acl.c (moved) * freebsd/net80211/ieee80211_action.c (moved) * freebsd/net80211/ieee80211_action.h (moved) * freebsd/net80211/ieee80211_adhoc.c (moved) * freebsd/net80211/ieee80211_adhoc.h (moved) * freebsd/net80211/ieee80211_ageq.c (moved) * freebsd/net80211/ieee80211_ageq.h (moved) * freebsd/net80211/ieee80211_amrr.c (moved) * freebsd/net80211/ieee80211_amrr.h (moved) * freebsd/net80211/ieee80211_crypto.c (moved) * freebsd/net80211/ieee80211_crypto.h (moved) * freebsd/net80211/ieee80211_crypto_ccmp.c (moved) * freebsd/net80211/ieee80211_crypto_none.c (moved) * freebsd/net80211/ieee80211_crypto_tkip.c (moved) * freebsd/net80211/ieee80211_crypto_wep.c (moved) * freebsd/net80211/ieee80211_ddb.c (moved) * freebsd/net80211/ieee80211_dfs.c (moved) * freebsd/net80211/ieee80211_dfs.h (moved) * freebsd/net80211/ieee80211_freebsd.c (moved) * freebsd/net80211/ieee80211_freebsd.h (moved) * freebsd/net80211/ieee80211_hostap.c (moved) * freebsd/net80211/ieee80211_hostap.h (moved) * freebsd/net80211/ieee80211_ht.c (moved) * freebsd/net80211/ieee80211_ht.h (moved) * freebsd/net80211/ieee80211_hwmp.c (moved) * freebsd/net80211/ieee80211_input.c (moved) * freebsd/net80211/ieee80211_input.h (moved) * freebsd/net80211/ieee80211_ioctl.c (moved) * freebsd/net80211/ieee80211_ioctl.h (moved) * freebsd/net80211/ieee80211_mesh.c (moved) * freebsd/net80211/ieee80211_mesh.h (moved) * freebsd/net80211/ieee80211_monitor.c (moved) * freebsd/net80211/ieee80211_monitor.h (moved) * freebsd/net80211/ieee80211_node.c (moved) * freebsd/net80211/ieee80211_node.h (moved) * freebsd/net80211/ieee80211_output.c (moved) * freebsd/net80211/ieee80211_phy.c (moved) * freebsd/net80211/ieee80211_phy.h (moved) * freebsd/net80211/ieee80211_power.c (moved) * freebsd/net80211/ieee80211_power.h (moved) * freebsd/net80211/ieee80211_proto.c (moved) * freebsd/net80211/ieee80211_proto.h (moved) * freebsd/net80211/ieee80211_radiotap.c (moved) * freebsd/net80211/ieee80211_radiotap.h (moved) * freebsd/net80211/ieee80211_ratectl.c (moved) * freebsd/net80211/ieee80211_ratectl.h (moved) * freebsd/net80211/ieee80211_ratectl_none.c (moved) * freebsd/net80211/ieee80211_regdomain.c (moved) * freebsd/net80211/ieee80211_regdomain.h (moved) * freebsd/net80211/ieee80211_rssadapt.c (moved) * freebsd/net80211/ieee80211_rssadapt.h (moved) * freebsd/net80211/ieee80211_scan.c (moved) * freebsd/net80211/ieee80211_scan.h (moved) * freebsd/net80211/ieee80211_scan_sta.c (moved) * freebsd/net80211/ieee80211_sta.c (moved) * freebsd/net80211/ieee80211_sta.h (moved) * freebsd/net80211/ieee80211_superg.c (moved) * freebsd/net80211/ieee80211_superg.h (moved) * freebsd/net80211/ieee80211_tdma.c (moved) * freebsd/net80211/ieee80211_tdma.h (moved) * freebsd/net80211/ieee80211_var.h (moved) * freebsd/net80211/ieee80211_wds.c (moved) * freebsd/net80211/ieee80211_wds.h (moved) * freebsd/net80211/ieee80211_xauth.c (moved) * freebsd/netgraph/ng_ipfw.h (moved) * freebsd/netinet/accf_data.c (moved) * freebsd/netinet/accf_dns.c (moved) * freebsd/netinet/accf_http.c (moved) * freebsd/netinet/icmp6.h (moved) * freebsd/netinet/icmp_var.h (moved) * freebsd/netinet/if_atm.c (moved) * freebsd/netinet/if_atm.h (moved) * freebsd/netinet/if_ether.c (moved) * freebsd/netinet/if_ether.h (moved) * freebsd/netinet/igmp.c (moved) * freebsd/netinet/igmp.h (moved) * freebsd/netinet/igmp_var.h (moved) * freebsd/netinet/in.c (moved) * freebsd/netinet/in.h (moved) * freebsd/netinet/in_cksum.c (moved) * freebsd/netinet/in_gif.c (moved) * freebsd/netinet/in_gif.h (moved) * freebsd/netinet/in_mcast.c (moved) * freebsd/netinet/in_pcb.c (moved) * freebsd/netinet/in_pcb.h (moved) * freebsd/netinet/in_proto.c (moved) * freebsd/netinet/in_rmx.c (moved) * freebsd/netinet/in_systm.h (moved) * freebsd/netinet/in_var.h (moved) * freebsd/netinet/ip.h (moved) * freebsd/netinet/ip6.h (moved) * freebsd/netinet/ip_carp.c (moved) * freebsd/netinet/ip_carp.h (moved) * freebsd/netinet/ip_divert.c (moved) * freebsd/netinet/ip_divert.h (moved) * freebsd/netinet/ip_dummynet.h (moved) * freebsd/netinet/ip_ecn.c (moved) * freebsd/netinet/ip_ecn.h (moved) * freebsd/netinet/ip_encap.c (moved) * freebsd/netinet/ip_encap.h (moved) * freebsd/netinet/ip_fastfwd.c (moved) * freebsd/netinet/ip_fw.h (moved) * freebsd/netinet/ip_gre.c (moved) * freebsd/netinet/ip_gre.h (moved) * freebsd/netinet/ip_icmp.c (moved) * freebsd/netinet/ip_icmp.h (moved) * freebsd/netinet/ip_id.c (moved) * freebsd/netinet/ip_input.c (moved) * freebsd/netinet/ip_ipsec.c (moved) * freebsd/netinet/ip_ipsec.h (moved) * freebsd/netinet/ip_mroute.c (moved) * freebsd/netinet/ip_mroute.h (moved) * freebsd/netinet/ip_options.c (moved) * freebsd/netinet/ip_options.h (moved) * freebsd/netinet/ip_output.c (moved) * freebsd/netinet/ip_var.h (moved) * freebsd/netinet/ipfw/dn_heap.c (moved) * freebsd/netinet/ipfw/dn_heap.h (moved) * freebsd/netinet/ipfw/dn_sched.h (moved) * freebsd/netinet/ipfw/dn_sched_fifo.c (moved) * freebsd/netinet/ipfw/dn_sched_prio.c (moved) * freebsd/netinet/ipfw/dn_sched_qfq.c (moved) * freebsd/netinet/ipfw/dn_sched_rr.c (moved) * freebsd/netinet/ipfw/dn_sched_wf2q.c (moved) * freebsd/netinet/ipfw/ip_dn_glue.c (moved) * freebsd/netinet/ipfw/ip_dn_io.c (moved) * freebsd/netinet/ipfw/ip_dn_private.h (moved) * freebsd/netinet/ipfw/ip_dummynet.c (moved) * freebsd/netinet/ipfw/ip_fw2.c (moved) * freebsd/netinet/ipfw/ip_fw_log.c (moved) * freebsd/netinet/ipfw/ip_fw_nat.c (moved) * freebsd/netinet/ipfw/ip_fw_pfil.c (moved) * freebsd/netinet/ipfw/ip_fw_private.h (moved) * freebsd/netinet/ipfw/ip_fw_sockopt.c (moved) * freebsd/netinet/ipfw/ip_fw_table.c (moved) * freebsd/netinet/libalias/alias.c (moved) * freebsd/netinet/libalias/alias.h (moved) * freebsd/netinet/libalias/alias_cuseeme.c (moved) * freebsd/netinet/libalias/alias_db.c (moved) * freebsd/netinet/libalias/alias_dummy.c (moved) * freebsd/netinet/libalias/alias_ftp.c (moved) * freebsd/netinet/libalias/alias_irc.c (moved) * freebsd/netinet/libalias/alias_local.h (moved) * freebsd/netinet/libalias/alias_mod.c (moved) * freebsd/netinet/libalias/alias_mod.h (moved) * freebsd/netinet/libalias/alias_nbt.c (moved) * freebsd/netinet/libalias/alias_pptp.c (moved) * freebsd/netinet/libalias/alias_proxy.c (moved) * freebsd/netinet/libalias/alias_sctp.c (moved) * freebsd/netinet/libalias/alias_sctp.h (moved) * freebsd/netinet/libalias/alias_skinny.c (moved) * freebsd/netinet/libalias/alias_smedia.c (moved) * freebsd/netinet/libalias/alias_util.c (moved) * freebsd/netinet/pim.h (moved) * freebsd/netinet/pim_var.h (moved) * freebsd/netinet/raw_ip.c (moved) * freebsd/netinet/sctp.h (moved) * freebsd/netinet/sctp_asconf.c (moved) * freebsd/netinet/sctp_asconf.h (moved) * freebsd/netinet/sctp_auth.c (moved) * freebsd/netinet/sctp_auth.h (moved) * freebsd/netinet/sctp_bsd_addr.c (moved) * freebsd/netinet/sctp_bsd_addr.h (moved) * freebsd/netinet/sctp_cc_functions.c (moved) * freebsd/netinet/sctp_cc_functions.h (moved) * freebsd/netinet/sctp_constants.h (moved) * freebsd/netinet/sctp_crc32.c (moved) * freebsd/netinet/sctp_crc32.h (moved) * freebsd/netinet/sctp_header.h (moved) * freebsd/netinet/sctp_indata.c (moved) * freebsd/netinet/sctp_indata.h (moved) * freebsd/netinet/sctp_input.c (moved) * freebsd/netinet/sctp_input.h (moved) * freebsd/netinet/sctp_lock_bsd.h (moved) * freebsd/netinet/sctp_os.h (moved) * freebsd/netinet/sctp_os_bsd.h (moved) * freebsd/netinet/sctp_output.c (moved) * freebsd/netinet/sctp_output.h (moved) * freebsd/netinet/sctp_pcb.c (moved) * freebsd/netinet/sctp_pcb.h (moved) * freebsd/netinet/sctp_peeloff.c (moved) * freebsd/netinet/sctp_peeloff.h (moved) * freebsd/netinet/sctp_structs.h (moved) * freebsd/netinet/sctp_sysctl.c (moved) * freebsd/netinet/sctp_sysctl.h (moved) * freebsd/netinet/sctp_timer.c (moved) * freebsd/netinet/sctp_timer.h (moved) * freebsd/netinet/sctp_uio.h (moved) * freebsd/netinet/sctp_usrreq.c (moved) * freebsd/netinet/sctp_var.h (moved) * freebsd/netinet/sctputil.c (moved) * freebsd/netinet/sctputil.h (moved) * freebsd/netinet/tcp.h (moved) * freebsd/netinet/tcp_debug.c (moved) * freebsd/netinet/tcp_debug.h (moved) * freebsd/netinet/tcp_fsm.h (moved) * freebsd/netinet/tcp_hostcache.h (moved) * freebsd/netinet/tcp_input.c (moved) * freebsd/netinet/tcp_lro.c (moved) * freebsd/netinet/tcp_lro.h (moved) * freebsd/netinet/tcp_offload.c (moved) * freebsd/netinet/tcp_offload.h (moved) * freebsd/netinet/tcp_output.c (moved) * freebsd/netinet/tcp_reass.c (moved) * freebsd/netinet/tcp_sack.c (moved) * freebsd/netinet/tcp_seq.h (moved) * freebsd/netinet/tcp_subr.c (moved) * freebsd/netinet/tcp_syncache.c (moved) * freebsd/netinet/tcp_syncache.h (moved) * freebsd/netinet/tcp_timer.c (moved) * freebsd/netinet/tcp_timer.h (moved) * freebsd/netinet/tcp_timewait.c (moved) * freebsd/netinet/tcp_usrreq.c (moved) * freebsd/netinet/tcp_var.h (moved) * freebsd/netinet/tcpip.h (moved) * freebsd/netinet/toedev.h (moved) * freebsd/netinet/udp.h (moved) * freebsd/netinet/udp_usrreq.c (moved) * freebsd/netinet/udp_var.h (moved) * freebsd/netinet6/dest6.c (moved) * freebsd/netinet6/frag6.c (moved) * freebsd/netinet6/icmp6.c (moved) * freebsd/netinet6/icmp6.h (moved) * freebsd/netinet6/in6.c (moved) * freebsd/netinet6/in6.h (moved) * freebsd/netinet6/in6_cksum.c (moved) * freebsd/netinet6/in6_gif.c (moved) * freebsd/netinet6/in6_gif.h (moved) * freebsd/netinet6/in6_ifattach.c (moved) * freebsd/netinet6/in6_ifattach.h (moved) * freebsd/netinet6/in6_mcast.c (moved) * freebsd/netinet6/in6_pcb.c (moved) * freebsd/netinet6/in6_pcb.h (moved) * freebsd/netinet6/in6_proto.c (moved) * freebsd/netinet6/in6_rmx.c (moved) * freebsd/netinet6/in6_src.c (moved) * freebsd/netinet6/in6_var.h (moved) * freebsd/netinet6/ip6.h (moved) * freebsd/netinet6/ip6_ecn.h (moved) * freebsd/netinet6/ip6_forward.c (moved) * freebsd/netinet6/ip6_id.c (moved) * freebsd/netinet6/ip6_input.c (moved) * freebsd/netinet6/ip6_ipsec.c (moved) * freebsd/netinet6/ip6_ipsec.h (moved) * freebsd/netinet6/ip6_mroute.c (moved) * freebsd/netinet6/ip6_mroute.h (moved) * freebsd/netinet6/ip6_output.c (moved) * freebsd/netinet6/ip6_var.h (moved) * freebsd/netinet6/ip6protosw.h (moved) * freebsd/netinet6/mld6.c (moved) * freebsd/netinet6/mld6.h (moved) * freebsd/netinet6/mld6_var.h (moved) * freebsd/netinet6/nd6.c (moved) * freebsd/netinet6/nd6.h (moved) * freebsd/netinet6/nd6_nbr.c (moved) * freebsd/netinet6/nd6_rtr.c (moved) * freebsd/netinet6/pim6.h (moved) * freebsd/netinet6/pim6_var.h (moved) * freebsd/netinet6/raw_ip6.c (moved) * freebsd/netinet6/raw_ip6.h (moved) * freebsd/netinet6/route6.c (moved) * freebsd/netinet6/scope6.c (moved) * freebsd/netinet6/scope6_var.h (moved) * freebsd/netinet6/sctp6_usrreq.c (moved) * freebsd/netinet6/sctp6_var.h (moved) * freebsd/netinet6/tcp6_var.h (moved) * freebsd/netinet6/udp6_usrreq.c (moved) * freebsd/netinet6/udp6_var.h (moved) * freebsd/netipsec/ah.h (moved) * freebsd/netipsec/ah_var.h (moved) * freebsd/netipsec/esp.h (moved) * freebsd/netipsec/esp_var.h (moved) * freebsd/netipsec/ipcomp.h (moved) * freebsd/netipsec/ipcomp_var.h (moved) * freebsd/netipsec/ipip_var.h (moved) * freebsd/netipsec/ipsec.c (moved) * freebsd/netipsec/ipsec.h (moved) * freebsd/netipsec/ipsec6.h (moved) * freebsd/netipsec/ipsec_input.c (moved) * freebsd/netipsec/ipsec_mbuf.c (moved) * freebsd/netipsec/ipsec_output.c (moved) * freebsd/netipsec/key.c (moved) * freebsd/netipsec/key.h (moved) * freebsd/netipsec/key_debug.c (moved) * freebsd/netipsec/key_debug.h (moved) * freebsd/netipsec/key_var.h (moved) * freebsd/netipsec/keydb.h (moved) * freebsd/netipsec/keysock.c (moved) * freebsd/netipsec/keysock.h (moved) * freebsd/netipsec/xform.h (moved) * freebsd/netipsec/xform_ah.c (moved) * freebsd/netipsec/xform_esp.c (moved) * freebsd/netipsec/xform_ipcomp.c (moved) * freebsd/netipsec/xform_ipip.c (moved) * freebsd/netipsec/xform_tcp.c (moved) * freebsd/opencrypto/cast.c (moved) * freebsd/opencrypto/cast.h (moved) * freebsd/opencrypto/castsb.h (moved) * freebsd/opencrypto/criov.c (moved) * freebsd/opencrypto/crypto.c (moved) * freebsd/opencrypto/cryptodev.c (moved) * freebsd/opencrypto/cryptodev.h (moved) * freebsd/opencrypto/cryptosoft.c (moved) * freebsd/opencrypto/cryptosoft.h (moved) * freebsd/opencrypto/deflate.c (moved) * freebsd/opencrypto/deflate.h (moved) * freebsd/opencrypto/rmd160.c (moved) * freebsd/opencrypto/rmd160.h (moved) * freebsd/opencrypto/skipjack.c (moved) * freebsd/opencrypto/skipjack.h (moved) * freebsd/opencrypto/xform.c (moved) * freebsd/opencrypto/xform.h (moved) * freebsd/security/audit/audit.h (moved) * freebsd/security/mac/mac_framework.h (moved) * freebsd/sys/_bus_dma.h (moved) * freebsd/sys/_iovec.h (moved) * freebsd/sys/_lock.h (moved) * freebsd/sys/_lockmgr.h (moved) * freebsd/sys/_mutex.h (moved) * freebsd/sys/_null.h (moved) * freebsd/sys/_pthreadtypes.h (moved) * freebsd/sys/_rmlock.h (moved) * freebsd/sys/_rwlock.h (moved) * freebsd/sys/_semaphore.h (moved) * freebsd/sys/_sigset.h (moved) * freebsd/sys/_sx.h (moved) * freebsd/sys/_task.h (moved) * freebsd/sys/_timeval.h (moved) * freebsd/sys/_types.h (moved) * freebsd/sys/acl.h (moved) * freebsd/sys/ata.h (moved) * freebsd/sys/bio.h (moved) * freebsd/sys/bitstring.h (moved) * freebsd/sys/buf_ring.h (moved) * freebsd/sys/bufobj.h (moved) * freebsd/sys/bus.h (moved) * freebsd/sys/bus_dma.h (moved) * freebsd/sys/callout.h (moved) * freebsd/sys/cdefs.h (moved) * freebsd/sys/condvar.h (moved) * freebsd/sys/conf.h (moved) * freebsd/sys/copyright.h (moved) * freebsd/sys/cpu.h (moved) * freebsd/sys/cpuset.h (moved) * freebsd/sys/ctype.h (moved) * freebsd/sys/domain.h (moved) * freebsd/sys/endian.h (moved) * freebsd/sys/errno.h (moved) * freebsd/sys/event.h (moved) * freebsd/sys/eventhandler.h (moved) * freebsd/sys/exec.h (moved) * freebsd/sys/fail.h (moved) * freebsd/sys/fcntl.h (moved) * freebsd/sys/file.h (moved) * freebsd/sys/filedesc.h (moved) * freebsd/sys/filio.h (moved) * freebsd/sys/fnv_hash.h (moved) * freebsd/sys/hash.h (moved) * freebsd/sys/interrupt.h (moved) * freebsd/sys/ioccom.h (moved) * freebsd/sys/jail.h (moved) * freebsd/sys/kernel.h (moved) * freebsd/sys/kobj.h (moved) * freebsd/sys/kthread.h (moved) * freebsd/sys/ktr.h (moved) * freebsd/sys/libkern.h (moved) * freebsd/sys/limits.h (moved) * freebsd/sys/linker.h (moved) * freebsd/sys/linker_set.h (moved) * freebsd/sys/lock.h (moved) * freebsd/sys/lock_profile.h (moved) * freebsd/sys/lockmgr.h (moved) * freebsd/sys/lockstat.h (moved) * freebsd/sys/mac.h (moved) * freebsd/sys/malloc.h (moved) * freebsd/sys/mbuf.h (moved) * freebsd/sys/md5.h (moved) * freebsd/sys/module.h (moved) * freebsd/sys/mount.h (moved) * freebsd/sys/mutex.h (moved) * freebsd/sys/namei.h (moved) * freebsd/sys/osd.h (moved) * freebsd/sys/param.h (moved) * freebsd/sys/pcpu.h (moved) * freebsd/sys/poll.h (moved) * freebsd/sys/priority.h (moved) * freebsd/sys/priv.h (moved) * freebsd/sys/proc.h (moved) * freebsd/sys/protosw.h (moved) * freebsd/sys/queue.h (moved) * freebsd/sys/random.h (moved) * freebsd/sys/reboot.h (moved) * freebsd/sys/refcount.h (moved) * freebsd/sys/resource.h (moved) * freebsd/sys/resourcevar.h (moved) * freebsd/sys/rman.h (moved) * freebsd/sys/rmlock.h (moved) * freebsd/sys/rtprio.h (moved) * freebsd/sys/runq.h (moved) * freebsd/sys/rwlock.h (moved) * freebsd/sys/sbuf.h (moved) * freebsd/sys/sched.h (moved) * freebsd/sys/sdt.h (moved) * freebsd/sys/select.h (moved) * freebsd/sys/selinfo.h (moved) * freebsd/sys/sf_buf.h (moved) * freebsd/sys/sigio.h (moved) * freebsd/sys/signal.h (moved) * freebsd/sys/signalvar.h (moved) * freebsd/sys/smp.h (moved) * freebsd/sys/sockbuf.h (moved) * freebsd/sys/socket.h (moved) * freebsd/sys/socketvar.h (moved) * freebsd/sys/sockio.h (moved) * freebsd/sys/sockopt.h (moved) * freebsd/sys/sockstate.h (moved) * freebsd/sys/stat.h (moved) * freebsd/sys/stddef.h (moved) * freebsd/sys/stdint.h (moved) * freebsd/sys/sx.h (moved) * freebsd/sys/syscallsubr.h (moved) * freebsd/sys/sysctl.h (moved) * freebsd/sys/sysent.h (moved) * freebsd/sys/syslimits.h (moved) * freebsd/sys/syslog.h (moved) * freebsd/sys/sysproto.h (moved) * freebsd/sys/systm.h (moved) * freebsd/sys/taskqueue.h (moved) * freebsd/sys/time.h (moved) * freebsd/sys/timespec.h (moved) * freebsd/sys/tree.h (moved) * freebsd/sys/ttycom.h (moved) * freebsd/sys/types.h (moved) * freebsd/sys/ucontext.h (moved) * freebsd/sys/ucred.h (moved) * freebsd/sys/uio.h (moved) * freebsd/sys/unistd.h (moved) * freebsd/time.h (moved) * freebsd/vm/uma.h (moved) * freebsd/vm/uma_dbg.h (moved) * freebsd/vm/uma_int.h (moved) Move rtems/freebsd to freebsd and contrib to freebsd/contrib
