# # ChangeLog for freebsd-userspace in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 05/17/24 20:13:27 Thu, 13 Sep 2012 19:52:42 GMT Jennifer Averett [4ffe3f4] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/resolv/h_errno.c (added) Added h_errno methods to userspace. Thu, 13 Sep 2012 19:03:35 GMT Jennifer Averett [99dc0d7] * freebsd-userspace/lib/libc/db/recno/rec_close.c (modified) * libbsd.txt (modified) rec_close.c: Removed usage of munmap() method. Note that there is a ... Thu, 13 Sep 2012 17:07:37 GMT Jennifer Averett [ef97f34] * freebsd-userspace/Makefile (modified) Merge branch 'master' of ssh://git.rtems.org/data/git/rtems-libbsd Thu, 13 Sep 2012 17:07:02 GMT Jennifer Averett [bf4a338] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/resolv/mtctxres.c (added) Added resolv/mtctxres.c to userspace for ___mtctxres(). Thu, 13 Sep 2012 16:56:22 GMT Jennifer Averett [afcd88e] * freebsd-userspace/Makefile (modified) * freebsd-userspace/rtems/rtems-syslog-initialize.c (added) Added rtems_bsdnet_log_host_address and its initialization to userspace. Thu, 13 Sep 2012 14:28:23 GMT Joel Sherrill [40b4210] * freebsd-userspace/Makefile (modified) freebsd-userspace/Makefile: Compile generated nsparser.c Wed, 12 Sep 2012 22:11:22 GMT Joel Sherrill [210671a] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/resolv/res_findzonecut.c (added) Merge branch 'master' of ssh://git.rtems.org/data/git/rtems-libbsd Wed, 12 Sep 2012 22:09:48 GMT Joel Sherrill [c52d922] * .gitignore (modified) * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/net/nsdispatch.c (added) * freebsd-userspace/lib/libc/net/nslexer.l (added) * freebsd-userspace/lib/libc/net/nsparser.h (added) * freebsd-userspace/lib/libc/net/nsparser.y (added) * freebsd-userspace/lib/libc/net/nss_backends.h (added) nsdispatch.c: New file added along with required dependencies This ... Wed, 12 Sep 2012 19:20:15 GMT Jennifer Averett [5a95703] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/resolv/res_findzonecut.c (added) Added res_findzonecut2 to user space. Wed, 12 Sep 2012 19:05:27 GMT Jennifer Averett [8c92f71] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/resolv/res_state.c (added) Added __res_state to user space. Wed, 12 Sep 2012 15:59:41 GMT Jennifer Averett [e4e1746] * freebsd-userspace/Makefile (modified) * freebsd-userspace/include/mpool.h (added) * freebsd-userspace/lib/libc/db/btree/bt_close.c (added) * freebsd-userspace/lib/libc/db/btree/bt_conv.c (added) * freebsd-userspace/lib/libc/db/btree/bt_debug.c (added) * freebsd-userspace/lib/libc/db/btree/bt_delete.c (added) * freebsd-userspace/lib/libc/db/btree/bt_get.c (added) * freebsd-userspace/lib/libc/db/btree/bt_open.c (added) * freebsd-userspace/lib/libc/db/btree/bt_overflow.c (added) * freebsd-userspace/lib/libc/db/btree/bt_page.c (added) * freebsd-userspace/lib/libc/db/btree/bt_put.c (added) * freebsd-userspace/lib/libc/db/btree/bt_search.c (added) * freebsd-userspace/lib/libc/db/btree/bt_seq.c (added) * freebsd-userspace/lib/libc/db/btree/bt_split.c (added) * freebsd-userspace/lib/libc/db/btree/bt_utils.c (added) * freebsd-userspace/lib/libc/db/btree/btree.h (added) * freebsd-userspace/lib/libc/db/btree/extern.h (added) * freebsd-userspace/lib/libc/db/db/db.c (added) * freebsd-userspace/lib/libc/db/mpool/mpool-compat.c (added) * freebsd-userspace/lib/libc/db/mpool/mpool.c (added) * freebsd-userspace/lib/libc/db/recno/extern.h (added) * freebsd-userspace/lib/libc/db/recno/rec_close.c (added) * freebsd-userspace/lib/libc/db/recno/rec_delete.c (added) * freebsd-userspace/lib/libc/db/recno/rec_get.c (added) * freebsd-userspace/lib/libc/db/recno/rec_open.c (added) * freebsd-userspace/lib/libc/db/recno/rec_put.c (added) * freebsd-userspace/lib/libc/db/recno/rec_search.c (added) * freebsd-userspace/lib/libc/db/recno/rec_seq.c (added) * freebsd-userspace/lib/libc/db/recno/rec_utils.c (added) * freebsd-userspace/lib/libc/db/recno/recno.h (added) Added userspace db files. Wed, 12 Sep 2012 15:48:11 GMT Jennifer Averett [97d85af] * freebsd-userspace/rtems/include/namespace.h (modified) namespace.h: Added fileio methods and _sigprocmask Rearranged ... Wed, 12 Sep 2012 13:51:04 GMT Joel Sherrill [d73df24] * freebsd-userspace/rtems/include/namespace.h (modified) namespace.h: Add some pthread rwlock and mutex methods Wed, 12 Sep 2012 00:13:52 GMT Joel Sherrill [0d928a0] * freebsd-userspace/Makefile (modified) * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/lib/libc/nameser/ns_samedomain.c (added) nameser/ns_samedomain.c: New file Tue, 11 Sep 2012 21:05:36 GMT Joel Sherrill [7d017b5] * freebsd-userspace/local/port_before.h (modified) local/port_before.h: Make more like FreeBSD version Tue, 11 Sep 2012 16:56:44 GMT Jennifer Averett [060d28d] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/stdio/fgetln.3 (added) * freebsd-userspace/lib/libc/stdio/fgetln.c (added) * freebsd-userspace/lib/libc/stdio/local.h (added) Added fgetln() Tue, 11 Sep 2012 00:03:41 GMT Joel Sherrill [0f2ea18] * freebsd-userspace/Makefile (modified) * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/lib/libc/net/name6.c (added) lib/libc/net/name6.c: New file netshell01 needed the following ... Fri, 07 Sep 2012 18:29:57 GMT Joel Sherrill [c4c01b8] * freebsd-userspace/rtems/include/namespace.h (modified) namespace.h: Remove nsdispatch. File missing - not name issue Fri, 07 Sep 2012 18:29:18 GMT Joel Sherrill [3bed89a] * freebsd-userspace/lib/libc/isc/eventlib_p.h (added) freebsd-userspace/lib/libc/isc/eventlib_p.h: New file Fri, 07 Sep 2012 18:28:01 GMT Joel Sherrill [5d3848d] * freebsd-userspace/lib/libc/isc/ev_streams.c (added) * freebsd-userspace/lib/libc/isc/ev_timers.c (added) lib/libc/isc/ev*.c: New files lib/libc/isc/ev_streams.c ... Fri, 07 Sep 2012 18:19:21 GMT Joel Sherrill [e6fe77e] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/include/libc_private.h (modified) * freebsd-userspace/rtems/include/namespace.h (modified) * testsuite/netshell01/Makefile (modified) freebsd-userspace/Makefile: Resolve conflict so ifconfig and netstat ... Fri, 07 Sep 2012 18:16:22 GMT Jennifer Averett [ebbe3cc] * freebsd-userspace/Makefile (modified) * freebsd-userspace/commands/sbin/ifconfig/af_atalk.c (added) * freebsd-userspace/commands/sbin/ifconfig/af_inet.c (added) * freebsd-userspace/commands/sbin/ifconfig/af_inet6.c (added) * freebsd-userspace/commands/sbin/ifconfig/af_ipx.c (added) * freebsd-userspace/commands/sbin/ifconfig/af_link.c (added) * freebsd-userspace/commands/sbin/ifconfig/af_nd6.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifbridge.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifcarp.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifclone.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifconfig.8 (added) * freebsd-userspace/commands/sbin/ifconfig/ifconfig.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifconfig.h (added) * freebsd-userspace/commands/sbin/ifconfig/ifgif.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifgre.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifgroup.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifieee80211.c (added) * freebsd-userspace/commands/sbin/ifconfig/iflagg.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifmac.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifmedia.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifpfsync.c (added) * freebsd-userspace/commands/sbin/ifconfig/ifvlan.c (added) * freebsd-userspace/commands/sbin/ifconfig/regdomain.c (added) * freebsd-userspace/commands/sbin/ifconfig/regdomain.h (added) * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/include/sys/mman.h (added) Added the ifconfig command. Fri, 07 Sep 2012 17:50:18 GMT Joel Sherrill [f1710b6] * freebsd-userspace/commands/usr.bin/netstat/atalk.c (added) * freebsd-userspace/commands/usr.bin/netstat/bpf.c (added) * freebsd-userspace/commands/usr.bin/netstat/if.c (added) * freebsd-userspace/commands/usr.bin/netstat/inet.c (added) * freebsd-userspace/commands/usr.bin/netstat/inet6.c (added) * freebsd-userspace/commands/usr.bin/netstat/ipsec.c (added) * freebsd-userspace/commands/usr.bin/netstat/ipx.c (added) * freebsd-userspace/commands/usr.bin/netstat/main.c (added) * freebsd-userspace/commands/usr.bin/netstat/mbuf.c (added) * freebsd-userspace/commands/usr.bin/netstat/mroute.c (added) * freebsd-userspace/commands/usr.bin/netstat/mroute6.c (added) * freebsd-userspace/commands/usr.bin/netstat/netgraph.c (added) * freebsd-userspace/commands/usr.bin/netstat/netstat.1 (added) * freebsd-userspace/commands/usr.bin/netstat/netstat.h (added) * freebsd-userspace/commands/usr.bin/netstat/pfkey.c (added) * freebsd-userspace/commands/usr.bin/netstat/route.c (added) * freebsd-userspace/commands/usr.bin/netstat/sctp.c (added) * freebsd-userspace/commands/usr.bin/netstat/unix.c (added) netstat: New command - Almost completely compiles Currently disable ... Fri, 07 Sep 2012 17:49:22 GMT Joel Sherrill [53ad1b2] * freebsd-userspace/rtems/include/rtems/netcmds-config.h (added) netcmds-config.h: New file. Use it in test Fri, 07 Sep 2012 17:48:11 GMT Joel Sherrill [48db7fb] * freebsd-userspace/from-freebsd.sh (modified) from-freebsd.sh: Add sys/socketvar.h Fri, 07 Sep 2012 17:47:36 GMT Joel Sherrill [61e67f8] * freebsd-userspace/include/sys/socketvar.h (added) sys/socketvar.h: New wrapper file Fri, 07 Sep 2012 17:43:13 GMT Joel Sherrill [f25ce7a] * freebsd-userspace/lib/libc/include/namespace.h (deleted) * freebsd-userspace/lib/libc/include/un-namespace.h (deleted) * freebsd-userspace/rtems/include/namespace.h (added) * freebsd-userspace/rtems/include/un-namespace.h (added) libc namespace.h: Use RTEMS specific versions FreeBSD adds an _ ... Thu, 06 Sep 2012 20:50:30 GMT Joel Sherrill [a1cc6f4] * freebsd-userspace/rtems/include/freebsd/stdint.h (added) freebsd/stdint.h: Add user space wrapper for freebsd/sys/stdint.h Thu, 06 Sep 2012 18:08:06 GMT Joel Sherrill [e1fc84b] * freebsd-userspace/Makefile (modified) * freebsd-userspace/commands/sbin/dhclient/alloc.c (added) * freebsd-userspace/commands/sbin/dhclient/bpf.c (added) * freebsd-userspace/commands/sbin/dhclient/clparse.c (added) * freebsd-userspace/commands/sbin/dhclient/conflex.c (added) * freebsd-userspace/commands/sbin/dhclient/convert.c (added) * freebsd-userspace/commands/sbin/dhclient/dhclient-script (added) * freebsd-userspace/commands/sbin/dhclient/dhclient-script.8 (added) * freebsd-userspace/commands/sbin/dhclient/dhclient.8 (added) * freebsd-userspace/commands/sbin/dhclient/dhclient.c (added) * freebsd-userspace/commands/sbin/dhclient/dhclient.conf (added) * freebsd-userspace/commands/sbin/dhclient/dhclient.conf.5 (added) * freebsd-userspace/commands/sbin/dhclient/dhclient.leases.5 (added) * freebsd-userspace/commands/sbin/dhclient/dhcp-options.5 (added) * freebsd-userspace/commands/sbin/dhclient/dhcp.h (added) * freebsd-userspace/commands/sbin/dhclient/dhcpd.h (added) * freebsd-userspace/commands/sbin/dhclient/dhctoken.h (added) * freebsd-userspace/commands/sbin/dhclient/dispatch.c (added) * freebsd-userspace/commands/sbin/dhclient/errwarn.c (added) * freebsd-userspace/commands/sbin/dhclient/hash.c (added) * freebsd-userspace/commands/sbin/dhclient/inet.c (added) * freebsd-userspace/commands/sbin/dhclient/options.c (added) * freebsd-userspace/commands/sbin/dhclient/packet.c (added) * freebsd-userspace/commands/sbin/dhclient/parse.c (added) * freebsd-userspace/commands/sbin/dhclient/privsep.c (added) * freebsd-userspace/commands/sbin/dhclient/privsep.h (added) * freebsd-userspace/commands/sbin/dhclient/tables.c (added) * freebsd-userspace/commands/sbin/dhclient/tree.c (added) * freebsd-userspace/commands/sbin/dhclient/tree.h (added) dhclient: New files Thu, 06 Sep 2012 17:20:27 GMT Joel Sherrill [4e18d8b] * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/include/net/ethernet.h (added) * freebsd-userspace/include/net/if_arp.h (added) * freebsd-userspace/include/netinet/igmp.h (added) * freebsd-userspace/include/netinet/in_systm.h (added) * freebsd-userspace/include/netinet/ip.h (added) * freebsd-userspace/include/netinet/ip_icmp.h (added) * freebsd-userspace/include/netinet/tcp.h (added) * freebsd-userspace/include/netinet/udp.h (added) * freebsd-userspace/include/poll.h (added) libc *.h: Add multiple user space .h file wrappers Thu, 06 Sep 2012 15:36:47 GMT Joel Sherrill [9dd5921] * .gitignore (modified) * freebsd-userspace/Makefile (modified) * freebsd-userspace/commands/sbin/route/keywords (added) * freebsd-userspace/commands/sbin/route/route.8 (added) * freebsd-userspace/commands/sbin/route/route.c (added) * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/include/netatalk/at.h (added) * freebsd-userspace/include/netinet/if_ether.h (added) Merge branch 'master' of ssh://git.rtems.org/data/git/rtems-libbsd Thu, 06 Sep 2012 15:35:02 GMT Joel Sherrill [7b1b5b8] * freebsd-userspace/commands/sbin/ping/ping.c (modified) * freebsd-userspace/commands/sbin/ping6/ping6.c (modified) * freebsd-userspace/lib/libc/inet/inet_addr.c (modified) * freebsd-userspace/lib/libc/inet/inet_cidr_ntop.c (modified) * freebsd-userspace/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd-userspace/lib/libc/inet/inet_lnaof.c (modified) * freebsd-userspace/lib/libc/inet/inet_makeaddr.c (modified) * freebsd-userspace/lib/libc/inet/inet_net_ntop.c (modified) * freebsd-userspace/lib/libc/inet/inet_net_pton.c (modified) * freebsd-userspace/lib/libc/inet/inet_neta.c (modified) * freebsd-userspace/lib/libc/inet/inet_netof.c (modified) * freebsd-userspace/lib/libc/inet/inet_network.c (modified) * freebsd-userspace/lib/libc/inet/inet_ntoa.c (modified) * freebsd-userspace/lib/libc/inet/inet_ntop.c (modified) * freebsd-userspace/lib/libc/inet/inet_pton.c (modified) * freebsd-userspace/lib/libc/inet/nsap_addr.c (modified) * freebsd-userspace/rtems/syslog.c (modified) Revert patches moving include of port_local.h to top of file This ... Thu, 06 Sep 2012 15:19:13 GMT Jennifer Averett [bd2941b] * .gitignore (modified) * freebsd-userspace/Makefile (modified) * freebsd-userspace/commands/sbin/route/keywords (added) * freebsd-userspace/commands/sbin/route/route.8 (added) * freebsd-userspace/commands/sbin/route/route.c (added) * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/include/netatalk/at.h (added) * freebsd-userspace/include/netinet/if_ether.h (added) route: Added files for the route command. Wed, 05 Sep 2012 18:24:06 GMT Joel Sherrill [324dde6] * freebsd-userspace/Makefile (modified) Makefile: Add err.c Wed, 05 Sep 2012 18:23:23 GMT Joel Sherrill [9054adf] * freebsd-userspace/lib/libc/gen/err.3 (added) * freebsd-userspace/lib/libc/gen/err.c (added) libc/gen/err.[3c]: New files Wed, 05 Sep 2012 18:22:23 GMT Joel Sherrill [05abe2c] * freebsd-userspace/rtems/syslog.c (modified) rtems/syslog.c: Include port_before.h first Wed, 05 Sep 2012 18:21:22 GMT Joel Sherrill [aef6891] * freebsd-userspace/lib/libc/inet/inet_addr.c (modified) * freebsd-userspace/lib/libc/inet/inet_cidr_ntop.c (modified) * freebsd-userspace/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd-userspace/lib/libc/inet/inet_lnaof.c (modified) * freebsd-userspace/lib/libc/inet/inet_makeaddr.c (modified) * freebsd-userspace/lib/libc/inet/inet_net_ntop.c (modified) * freebsd-userspace/lib/libc/inet/inet_net_pton.c (modified) * freebsd-userspace/lib/libc/inet/inet_neta.c (modified) * freebsd-userspace/lib/libc/inet/inet_netof.c (modified) * freebsd-userspace/lib/libc/inet/inet_network.c (modified) * freebsd-userspace/lib/libc/inet/inet_ntoa.c (modified) * freebsd-userspace/lib/libc/inet/inet_ntop.c (modified) * freebsd-userspace/lib/libc/inet/inet_pton.c (modified) * freebsd-userspace/lib/libc/inet/nsap_addr.c (modified) libc/inet/*.c: Include port_before.h first Wed, 05 Sep 2012 18:20:15 GMT Joel Sherrill [b0cd1b9] * freebsd-userspace/lib/libc/net/getaddrinfo.c (modified) getaddrinfo.c: Use freebsd/ to ully specify kernel .h files Wed, 05 Sep 2012 18:17:06 GMT Joel Sherrill [f3e8e10] * freebsd-userspace/include/err.h (modified) err.h: For rtems include Wed, 05 Sep 2012 18:15:58 GMT Joel Sherrill [dafaba3] * freebsd-userspace/commands/sbin/ping6/ping6.c (modified) ping6.c: Add include of port_before.h Wed, 05 Sep 2012 18:15:40 GMT Joel Sherrill [3604a25] * freebsd-userspace/commands/sbin/ping/ping.c (modified) ping.c: Add include of port_before.h and rtems shell glue Sat, 01 Sep 2012 18:36:46 GMT Joel Sherrill [c77d779] * freebsd-userspace/Makefile (modified) userspace Makefile: Do not build old style NIC configuration Sat, 01 Sep 2012 14:46:13 GMT Joel Sherrill [c1e56a5] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/resolv/res_debug.h (added) * freebsd-userspace/lib/libc/resolv/res_send.c (modified) * freebsd-userspace/local/port_before.h (modified) * freebsd-userspace/rtems/include/isc/eventlib.h (added) res_send.c: Now compiles This required adding ISC .h files and ... Sat, 01 Sep 2012 14:36:41 GMT Joel Sherrill [236e427] * freebsd-userspace/Makefile (modified) * freebsd-userspace/lib/libc/resolv/res_update.c (modified) * freebsd-userspace/local/port_before.h (modified) * freebsd-userspace/rtems/include/isc/app.h (added) * freebsd-userspace/rtems/include/isc/assertions.h (added) * freebsd-userspace/rtems/include/isc/boolean.h (added) * freebsd-userspace/rtems/include/isc/buffer.h (added) * freebsd-userspace/rtems/include/isc/dst.h (added) * freebsd-userspace/rtems/include/isc/error.h (added) * freebsd-userspace/rtems/include/isc/formatcheck.h (added) * freebsd-userspace/rtems/include/isc/int.h (added) * freebsd-userspace/rtems/include/isc/interfaceiter.h (added) * freebsd-userspace/rtems/include/isc/ipv6.h (added) * freebsd-userspace/rtems/include/isc/lang.h (added) * freebsd-userspace/rtems/include/isc/lib.h (added) * freebsd-userspace/rtems/include/isc/list.h (added) * freebsd-userspace/rtems/include/isc/magic.h (added) * freebsd-userspace/rtems/include/isc/mem.h (added) * freebsd-userspace/rtems/include/isc/msgcat.h (added) * freebsd-userspace/rtems/include/isc/msgs.h (added) * freebsd-userspace/rtems/include/isc/mutex.h (added) * freebsd-userspace/rtems/include/isc/net.h (added) * freebsd-userspace/rtems/include/isc/netaddr.h (added) * freebsd-userspace/rtems/include/isc/netscope.h (added) * freebsd-userspace/rtems/include/isc/offset.h (added) * freebsd-userspace/rtems/include/isc/once.h (added) * freebsd-userspace/rtems/include/isc/platform.h (added) * freebsd-userspace/rtems/include/isc/print.h (added) * freebsd-userspace/rtems/include/isc/region.h (added) * freebsd-userspace/rtems/include/isc/result.h (added) * freebsd-userspace/rtems/include/isc/sockaddr.h (added) * freebsd-userspace/rtems/include/isc/strerror.h (added) * freebsd-userspace/rtems/include/isc/string.h (added) * freebsd-userspace/rtems/include/isc/types.h (added) * freebsd-userspace/rtems/include/isc/util.h (added) res_mkupdate.c: Add isc/*.h and define _LIBC This patch enabled a ... Sat, 01 Sep 2012 00:33:20 GMT Joel Sherrill [234dfb8] * freebsd-userspace/commands/sbin/ping/ping.c (modified) * freebsd-userspace/commands/sbin/ping6/ping6.c (modified) ping/ping6: Use getopt_r and make main unique for RTEMS Sat, 01 Sep 2012 00:22:33 GMT Joel Sherrill [1f877f9] * freebsd-userspace/Makefile (modified) * freebsd-userspace/commands/sbin/ping/ping.8 (added) * freebsd-userspace/commands/sbin/ping/ping.c (added) * freebsd-userspace/commands/sbin/ping6/ping6.8 (added) * freebsd-userspace/commands/sbin/ping6/ping6.c (added) * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/include/err.h (added) * freebsd-userspace/include/netinet/icmp6.h (added) * freebsd-userspace/include/netinet/ip6.h (added) * freebsd-userspace/include/sysexits.h (added) commands ping/ping6: Add initial ports of FreeBSD ping and pin6 ports ... Fri, 24 Aug 2012 20:37:39 GMT Joel Sherrill [ee77212] * freebsd-userspace/Makefile (modified) * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/lib/libc/net/getaddrinfo.c (added) getaddrinfo.c: New file Fri, 24 Aug 2012 20:30:32 GMT Joel Sherrill [650e421] * freebsd-userspace/rtems/include/rpc/rpc.h (moved) rpc/rpc.h: Move to correct location Mon, 06 Aug 2012 00:10:35 GMT Joel Sherrill [cd450d2] * freebsd-userspace/rtems/include/rpc.h (moved) * freebsd-userspace/rtems/include/rpc/clnt.h (moved) * services/librpc/include/rpc/clnt.h (deleted) * services/librpc/include/rpc/rpc_com.h (modified) * services/librpc/include/rpc/svc.h (deleted) * services/librpc/src/rpc/auth_none.c (modified) * services/librpc/src/rpc/auth_unix.c (modified) * services/librpc/src/rpc/authunix_prot.c (modified) * services/librpc/src/rpc/bindresvport.c (modified) * services/librpc/src/rpc/clnt_generic.c (modified) * services/librpc/src/rpc/clnt_perror.c (modified) * services/librpc/src/rpc/clnt_raw.c (modified) * services/librpc/src/rpc/clnt_simple.c (modified) * services/librpc/src/rpc/clnt_tcp.c (modified) * services/librpc/src/rpc/clnt_udp.c (modified) * services/librpc/src/rpc/get_myaddress.c (modified) * services/librpc/src/rpc/getrpcent.c (modified) * services/librpc/src/rpc/getrpcport.c (modified) * services/librpc/src/rpc/netname.c (modified) * services/librpc/src/rpc/netnamer.c (modified) * services/librpc/src/rpc/pmap_clnt.c (modified) * services/librpc/src/rpc/pmap_getmaps.c (modified) * services/librpc/src/rpc/pmap_getport.c (modified) * services/librpc/src/rpc/pmap_prot.c (modified) * services/librpc/src/rpc/pmap_prot2.c (modified) * services/librpc/src/rpc/pmap_rmt.c (modified) * services/librpc/src/rpc/rpc.3 (modified) * services/librpc/src/rpc/rpc_callmsg.c (modified) * services/librpc/src/rpc/rpc_commondata.c (modified) * services/librpc/src/rpc/rpc_dtablesize.c (modified) * services/librpc/src/rpc/rpc_prot.c (modified) * services/librpc/src/rpc/rpcdname.c (modified) * services/librpc/src/rpc/rtems_portmapper.c (modified) * services/librpc/src/rpc/rtems_rpc.c (modified) * services/librpc/src/rpc/rtime.c (modified) * services/librpc/src/rpc/svc.c (modified) * services/librpc/src/rpc/svc_auth.c (modified) * services/librpc/src/rpc/svc_auth_unix.c (modified) * services/librpc/src/rpc/svc_raw.c (modified) * services/librpc/src/rpc/svc_run.c (modified) * services/librpc/src/rpc/svc_simple.c (modified) * services/librpc/src/rpc/svc_tcp.c (modified) * services/librpc/src/rpc/svc_udp.c (modified) * services/librpc/src/xdr/xdr.c (modified) * services/librpc/src/xdr/xdr_array.c (modified) * services/librpc/src/xdr/xdr_float.c (modified) * services/librpc/src/xdr/xdr_mem.c (modified) * services/librpc/src/xdr/xdr_rec.c (modified) * services/librpc/src/xdr/xdr_reference.c (modified) * services/librpc/src/xdr/xdr_sizeof.c (modified) * services/librpc/src/xdr/xdr_stdio.c (modified) librpc: now compiles Fri, 03 Aug 2012 13:40:27 GMT Joel Sherrill [116c6cf] * freebsd-userspace/rtems/include/netdb.h (moved) * services/ftpfs/Makefile (added) * services/ftpfs/ftpfs.c (added) * services/ftpfs/include/rtems/ftpfs.h (added) ftpfs: Add to services Sat, 28 Jul 2012 12:11:56 GMT Joel Sherrill [1912d73] * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/include/arpa/ftp.h (added) from-freebsd.sh: Add arpa/ftp.h, clean up syslog.h a bit Sat, 28 Jul 2012 11:39:41 GMT Joel Sherrill [a4713c6] * freebsd-userspace/Makefile (modified) * freebsd-userspace/rtems/include/sys/syslog.h (moved) * freebsd-userspace/rtems/syslog.c (added) Add syslog functionality from old TCP/IP stack. Fri, 27 Jul 2012 13:08:37 GMT Joel Sherrill [97cc960] * freebsd-userspace/rtems/include/rtems/rtems_bsdnet.h (added) rtems_bsdnert.h: Add old configuration Fri, 27 Jul 2012 13:06:47 GMT Joel Sherrill [e71c52a] * freebsd-userspace/include/include/arpa/inet.h (deleted) * freebsd-userspace/include/include/arpa/nameser.h (deleted) * freebsd-userspace/include/net/if.h (modified) * freebsd-userspace/include/net/if_dl.h (modified) * freebsd-userspace/include/net/if_types.h (modified) * freebsd-userspace/include/net/in.h (modified) * freebsd-userspace/include/net/route.h (modified) * freebsd-userspace/include/netinet/in.h (modified) * freebsd-userspace/include/sys/select.h (added) * freebsd-userspace/include/sys/socket.h (modified) * freebsd-userspace/include/sys/sysctl.h (modified) various publis .h: Add include This makes them ... Fri, 27 Jul 2012 13:05:15 GMT Joel Sherrill [b27d875] * freebsd-userspace/Makefile (modified) Makefile: Correct so not rebuilding all every time Fri, 27 Jul 2012 12:45:06 GMT Joel Sherrill [bd6dd6e] * freebsd-userspace/Makefile (modified) * freebsd-userspace/rtems/rtems-net-setup.c (modified) * rtemsbsd/freebsd/machine/rtems-bsd-config.h (modified) net-setup: Add routing and old stack's configuration This allows ... Sat, 14 Jul 2012 19:05:58 GMT Joel Sherrill [aa8c37d] * freebsd-userspace/include/rpc/rpcb_prot.h (deleted) rpcb_prot.h: Remove generated file Wed, 11 Jul 2012 22:54:57 GMT Joel Sherrill [1543249] * freebsd-userspace/Makefile (modified) * freebsd-userspace/local/port_before.h (modified) port_before.h: Add _ALIGNBYTES and enable getservent.c Wed, 11 Jul 2012 22:38:09 GMT Joel Sherrill [939b12b] * freebsd-userspace/Makefile (modified) * freebsd-userspace/from-freebsd.sh (modified) Makefile: Enable most files to build Wed, 11 Jul 2012 22:37:54 GMT Joel Sherrill [2f14df7] * freebsd-userspace/local/port_before.h (modified) port_before.h: Ensure enough BSD types are defined Wed, 11 Jul 2012 22:36:34 GMT Joel Sherrill [a98a274] * freebsd-userspace/lib/libc/net/gethostbydns.c (modified) gethostbydns.c: dprintf conflicts with POSIX - rename to DPRINTF ... Wed, 11 Jul 2012 22:36:15 GMT Joel Sherrill [cac1c86] * freebsd-userspace/include/rpc/rpcb_prot.h (added) rpcb_prot.h: Add generated file Wed, 11 Jul 2012 22:35:10 GMT Joel Sherrill [822aae2c] * freebsd-userspace/include/arpa/nameser.h (modified) * freebsd-userspace/include/arpa/nameser_compat.h (modified) arpa/nameser*.h: Reneable BIND_4_COMPAT and include FreeBSD endian.h Wed, 11 Jul 2012 21:01:37 GMT Joel Sherrill [028aaaf] * freebsd-userspace/Makefile (modified) * freebsd-userspace/from-freebsd.sh (modified) * freebsd-userspace/include/netconfig.h (added) * freebsd-userspace/include/res_update.h (added) * freebsd-userspace/include/rpc/auth.h (added) * freebsd-userspace/include/rpc/auth_des.h (added) * freebsd-userspace/include/rpc/auth_unix.h (added) * freebsd-userspace/include/rpc/clnt.h (added) * freebsd-userspace/include/rpc/clnt_soc.h (added) * freebsd-userspace/include/rpc/clnt_stat.h (added) * freebsd-userspace/include/rpc/pmap_clnt.h (added) * freebsd-userspace/include/rpc/pmap_prot.h (added) * freebsd-userspace/include/rpc/rpc.h (added) * freebsd-userspace/include/rpc/rpc_msg.h (added) * freebsd-userspace/include/rpc/rpcb_clnt.h (added) * freebsd-userspace/include/rpc/rpcb_prot.x (added) * freebsd-userspace/include/rpc/rpcent.h (added) * freebsd-userspace/include/rpc/svc.h (added) * freebsd-userspace/include/rpc/svc_auth.h (added) * freebsd-userspace/include/rpc/svc_soc.h (added) * freebsd-userspace/include/rpc/xdr.h (added) * freebsd-userspace/lib/libc/gen/gethostname.c (added) * freebsd-userspace/lib/libc/nameser/ns_name.c (added) * freebsd-userspace/lib/libc/nameser/ns_netint.c (added) * freebsd-userspace/lib/libc/nameser/ns_parse.c (added) * freebsd-userspace/lib/libc/nameser/ns_print.c (added) * freebsd-userspace/lib/libc/nameser/ns_ttl.c (added) * freebsd-userspace/lib/libc/net/if_indextoname.c (added) * freebsd-userspace/lib/libc/net/if_nameindex.c (added) * freebsd-userspace/lib/libc/net/linkaddr.c (added) * freebsd-userspace/lib/libc/net/map_v4v6.c (added) * freebsd-userspace/lib/libc/net/rcmd.c (added) * freebsd-userspace/lib/libc/net/recv.c (added) * freebsd-userspace/lib/libc/net/send.c (added) * freebsd-userspace/lib/libc/resolv/herror.c (added) * freebsd-userspace/lib/libc/resolv/res_comp.c (added) * freebsd-userspace/lib/libc/resolv/res_data.c (added) * freebsd-userspace/lib/libc/resolv/res_debug.c (added) * freebsd-userspace/lib/libc/resolv/res_init.c (added) * freebsd-userspace/lib/libc/resolv/res_mkquery.c (added) * freebsd-userspace/lib/libc/resolv/res_mkupdate.c (added) * freebsd-userspace/lib/libc/resolv/res_private.h (added) * freebsd-userspace/lib/libc/resolv/res_query.c (added) * freebsd-userspace/lib/libc/resolv/res_send.c (added) * freebsd-userspace/lib/libc/resolv/res_update.c (added) * freebsd-userspace/lib/libc/string/strsep.c (added) * freebsd-userspace/sys/rpc/types.h (added) * freebsd-userspace/sys/sys/_null.h (added) * freebsd-userspace/sys/sys/un.h (added) freebsd-userspace: All files in old libnetworking/libc now present ... Wed, 11 Jul 2012 19:34:10 GMT Joel Sherrill [e25eda8] * freebsd-userspace/rtems/rtems-net-setup.c (added) Add RTEMS Network Setup Helper Wed, 11 Jul 2012 19:31:26 GMT Joel Sherrill [079c3f2] * freebsd-userspace/Makefile (modified) userspace: Add install support Wed, 11 Jul 2012 18:23:45 GMT Joel Sherrill [1b13f69] * freebsd-userspace/Makefile (added) * freebsd-userspace/README (added) * freebsd-userspace/from-freebsd.sh (added) * freebsd-userspace/include/arpa/inet.h (added) * freebsd-userspace/include/arpa/nameser.h (added) * freebsd-userspace/include/arpa/nameser_compat.h (added) * freebsd-userspace/include/db.h (added) * freebsd-userspace/include/ifaddrs.h (added) * freebsd-userspace/include/include/arpa/inet.h (added) * freebsd-userspace/include/include/arpa/nameser.h (added) * freebsd-userspace/include/net/if.h (added) * freebsd-userspace/include/net/if_dl.h (added) * freebsd-userspace/include/net/if_types.h (added) * freebsd-userspace/include/net/in.h (added) * freebsd-userspace/include/net/route.h (added) * freebsd-userspace/include/netdb.h (added) * freebsd-userspace/include/netinet/in.h (added) * freebsd-userspace/include/nsswitch.h (added) * freebsd-userspace/include/resolv.h (added) * freebsd-userspace/include/sys/socket.h (added) * freebsd-userspace/include/sys/sysctl.h (added) * freebsd-userspace/lib/libc/include/libc_private.h (added) * freebsd-userspace/lib/libc/include/namespace.h (added) * freebsd-userspace/lib/libc/include/nss_tls.h (added) * freebsd-userspace/lib/libc/include/reentrant.h (added) * freebsd-userspace/lib/libc/include/resolv_mt.h (added) * freebsd-userspace/lib/libc/include/un-namespace.h (added) * freebsd-userspace/lib/libc/inet/inet_addr.c (added) * freebsd-userspace/lib/libc/inet/inet_cidr_ntop.c (added) * freebsd-userspace/lib/libc/inet/inet_cidr_pton.c (added) * freebsd-userspace/lib/libc/inet/inet_lnaof.c (added) * freebsd-userspace/lib/libc/inet/inet_makeaddr.c (added) * freebsd-userspace/lib/libc/inet/inet_net_ntop.c (added) * freebsd-userspace/lib/libc/inet/inet_net_pton.c (added) * freebsd-userspace/lib/libc/inet/inet_neta.c (added) * freebsd-userspace/lib/libc/inet/inet_netof.c (added) * freebsd-userspace/lib/libc/inet/inet_network.c (added) * freebsd-userspace/lib/libc/inet/inet_ntoa.c (added) * freebsd-userspace/lib/libc/inet/inet_ntop.c (added) * freebsd-userspace/lib/libc/inet/inet_pton.c (added) * freebsd-userspace/lib/libc/inet/nsap_addr.c (added) * freebsd-userspace/lib/libc/net/base64.c (added) * freebsd-userspace/lib/libc/net/ether_addr.c (added) * freebsd-userspace/lib/libc/net/gethostbydns.c (added) * freebsd-userspace/lib/libc/net/gethostbyht.c (added) * freebsd-userspace/lib/libc/net/gethostbynis.c (added) * freebsd-userspace/lib/libc/net/gethostnamadr.c (added) * freebsd-userspace/lib/libc/net/getifaddrs.c (added) * freebsd-userspace/lib/libc/net/getifmaddrs.c (added) * freebsd-userspace/lib/libc/net/getnameinfo.c (added) * freebsd-userspace/lib/libc/net/getnetbydns.c (added) * freebsd-userspace/lib/libc/net/getnetbyht.c (added) * freebsd-userspace/lib/libc/net/getnetbynis.c (added) * freebsd-userspace/lib/libc/net/getnetnamadr.c (added) * freebsd-userspace/lib/libc/net/getproto.c (added) * freebsd-userspace/lib/libc/net/getprotoent.c (added) * freebsd-userspace/lib/libc/net/getprotoname.c (added) * freebsd-userspace/lib/libc/net/getservent.c (added) * freebsd-userspace/lib/libc/net/netdb_private.h (added) * freebsd-userspace/lib/libc/net/res_config.h (added) * freebsd-userspace/local/port_after.h (added) * freebsd-userspace/local/port_before.h (added) * freebsd-userspace/local/pthread_np.h (added) * freebsd-userspace/local/sys/_pthreadtypes.h (added) * freebsd-userspace/local/syslog.h (added) * freebsd-userspace/sys/net/ethernet.h (added) * freebsd-userspace/sys/sys/syslog.h (added) FreeBSD user space support - First additions This requires a full ...
