@514a0e5
07/11/12 19:25:18 |
Joel Sherrill |
Build freebsd-userspace
4.1155-freebsd-126-freebsd-12freebsd-9.3
@9fc8b41
07/11/12 18:10:31 |
soh_cah_toa |
Removed in_cksum_arm.S file.
@2f50f0a
07/11/12 13:49:13 |
Jennifer Averett |
Added nexus_setup_intr support and did some cleanup.
@237c763
07/10/12 16:58:29 |
Joel Sherrill |
Makefile: Do not install contrib .h files until proven needed
They …
@842c238
07/09/12 22:21:36 |
Joel Sherrill |
Makefile: updated to probably install architecture specific .h files
@dbda808
07/06/12 15:57:12 |
Joel Sherrill |
Put CPU specific bus_space routines into separate files
The code in …
@d972692
07/02/12 14:54:00 |
Jennifer Averett |
Add a couple of isa header files.
@348f0a0
06/29/12 20:06:34 |
Jennifer Averett |
Added missing header file.
@36ebd68
06/29/12 17:42:00 |
Jennifer Averett |
Added legacy in order to get pcib to work correctly and resoleved fxp …
@58ea5ee
06/11/12 14:42:08 |
Jennifer Averett |
Added pcib.
@20b5ca1
05/30/12 16:49:04 |
Jennifer Averett |
Added support for initialization of uihashinit().
@fb4c8a9
05/23/12 19:53:12 |
Jennifer Averett |
Added pcib for Nics.
@2f18089
05/17/12 13:37:48 |
Jennifer Averett |
Resolved issues with pc386 build.
@ee6b343
05/10/12 13:06:10 |
christian.mauderer |
Provide SWI(9) and TIMEOUT(9)
@a4d8e19
05/10/12 13:51:10 |
Sebastian Huber |
Move rtems_bsd_thread0_ucred
@b95c989
05/09/12 18:55:00 |
Jennifer Averett |
Added subr_unit.c needed for addtional Nics.
@2dbdc7c
05/09/12 17:28:53 |
Jennifer Averett |
Added EtherExpress?, tulip, and Broadcom Nics.
BCM570x, E1000, and …
@be8032d
05/02/12 15:27:59 |
Jennifer Averett |
Added stubs for funsetown() and fsetown()
@4c0c5fd
04/26/12 13:05:52 |
Sebastian Huber |
Remove proc0 creation
@74587c3
04/19/12 18:25:28 |
Jennifer Averett |
Merged rtems-bsd-uma.c back into uma_core.c
The majority of this file …
@2ba7772
04/19/12 10:04:26 |
Sebastian Huber |
Add kern_linker.c and dependencies
@d167ea5
04/19/12 07:22:28 |
Sebastian Huber |
Add dependency generation
@a2ec332
04/18/12 19:10:44 |
Jennifer Averett |
Merged the rtems version of resource back to kern_resource and added …
@fdd321c
04/18/12 17:00:33 |
Jennifer Averett |
Added an RTEMS specific version of routines needed from copyinout.c
@fd8fe3f
04/18/12 16:07:04 |
Joel Sherrill |
Add rtems-bsd-timeout.c to Makefile
@89466ac
04/18/12 15:16:37 |
Jennifer Averett |
Removed rtems-bsd-subr.c
@d8c5df7
04/18/12 14:46:21 |
Jennifer Averett |
Moved rtems-bsd-cyclecount.c to cpu.h
@2da0777
04/18/12 12:59:28 |
Sebastian Huber |
Add BUS_DMA(9) support for mbufs
@c2b6395
04/18/12 11:58:05 |
Sebastian Huber |
Removed file
In this file the copyright information was wrong. It …
@01e57a9
04/17/12 19:43:48 |
Jennifer Averett |
Added rtems version of get_cyclecount().
@b6c71ea
04/17/12 19:31:21 |
Jennifer Averett |
Added chgsbsize() method.
@67b8f0a
04/17/12 18:59:34 |
Jennifer Averett |
Added rtems unique version of uio_yield()
@400b74d
04/17/12 15:19:55 |
Sebastian Huber |
Fix NoConverter? class inheritance
@14f35e6
04/17/12 15:08:05 |
Sebastian Huber |
Add missing header file
@837df26
04/17/12 14:54:29 |
Sebastian Huber |
Add PCI and PCIB interface files
@68df607
04/17/12 14:07:34 |
Sebastian Huber |
Use MIPS in_cksum.c for SPARC
@d558a43
04/17/12 14:38:54 |
Jennifer Averett |
Added methods to resolve linker errors.
@30e98a2
04/17/12 14:00:18 |
Jennifer Averett |
Added variables from kern_environment to remove linker errors.
@4794481
04/17/12 09:39:36 |
Sebastian Huber |
in_cksum() support for SPARC
@edd344a
04/17/12 09:54:31 |
Sebastian Huber |
Simplify
@e4b9989
04/16/12 18:22:45 |
Jennifer Averett |
Addded resource_XXX methods to resolve linker issues.
@d9e838b
04/16/12 17:39:58 |
Jennifer Averett |
Added get_cyclecount() method.
@a824229
04/16/12 16:50:33 |
Jennifer Averett |
Forgot to add Makefile and freebsd-to-rtems.py to rmlock commit.
@c4117bb
04/16/12 16:00:02 |
Joel Sherrill |
Add libkern/fls.c for fls() - Find last bit set
@459afb1
04/16/12 14:10:35 |
Jennifer Averett |
Implemented a version of rmlock using rwlock.
@251480e
04/05/12 20:24:27 |
Jennifer Averett |
Added in a header file and some defines to resolve linker errors.
@508e3df
04/05/12 19:13:24 |
Jennifer Averett |
Added uipc_XXx methods.
@c613894
04/05/12 18:42:26 |
Jennifer Averett |
Added pci_XXX methods.
@39292ce
04/05/12 18:04:52 |
Jennifer Averett |
Added tcp_hc_XXX methods.
@2385258
04/05/12 17:49:15 |
Jennifer Averett |
Added rmon_XXX methods.
@7730088
04/05/12 17:42:40 |
Jennifer Averett |
Added sbuf_XXX methods.
@3c05977
04/05/12 15:55:30 |
Jennifer Averett |
Added knlist_XXX and knote_XXX methods.
@b2e05ef
04/05/12 15:00:36 |
Jennifer Averett |
Added ratecheck methods as part of RealTek? Nic integration.
@dc4c490
04/04/12 22:38:25 |
Joel Sherrill |
Add tvtohz() implementation in new file
@d75b748
04/04/12 19:08:31 |
Jennifer Averett |
Added cr_XXX methods to resolve linker errors with RealTek? Nic.
@8960780
04/02/12 17:13:22 |
Jennifer Averett |
Add methods to reaolve linker issues.
@ce0b530
04/02/12 14:30:23 |
Jennifer Averett |
Add globals to resolve linker conflicts.
@e3f2b51
03/30/12 16:49:26 |
Joel Sherrill |
Add freebsd/machine/elf.h as empty. Improve message for empty file.
@4ac7089
03/30/12 16:43:45 |
Joel Sherrill |
Make verbose print again for copying files
@962b220
03/30/12 16:31:00 |
Jennifer Averett |
Added Methods and stub file to remove warnings when linking with …
@f6289b3
03/30/12 14:57:23 |
Jennifer Averett |
Resolve linker error with RealTek? Nic (arc4random)
@134df2e
03/29/12 17:46:14 |
Jennifer Averett |
Resolve warnings from taskqueue when linking with RealTek? Nic.
@d1528ff
03/28/12 16:40:08 |
Jennifer Averett |
Added log and prison methods to resolve linker errors for RealTek? Nic.
@27ae2dfc
03/27/12 18:58:38 |
Jennifer Averett |
Added kern_mib.c to resolve linker error when pulling in RealTek? Nic.
@a52104c
03/26/12 14:51:49 |
julien.delange |
e1000 driver now compiles with fewer modifications
- Change some …
@918638f
03/26/12 08:15:09 |
Sebastian Huber |
New USB device specific controller files
@da162c8
03/22/12 14:58:40 |
Jennifer Averett |
Added taskqueue to resolve linking issues with the RealTek? Nic.
@aa53ae9
03/22/12 14:20:21 |
Jennifer Averett |
Removed system smp.h file.
@60cf5cd
03/22/12 14:15:35 |
Jennifer Averett |
Added random and harvest files to resolve missing methods when linking …
@471e6f9
03/22/12 13:44:35 |
Jennifer Averett |
Added uipc_domain.c to resolve missing symbols when linking the …
@5ad09a1
03/22/12 13:02:26 |
Joel Sherrill |
Add DEC Tulip, Broadcomm (bce, bfe, bge), and SMC 9111x NICs
@0f09b72
03/22/12 12:44:07 |
Joel Sherrill |
Add smp variables used by e1000 and remove unneeded ifdefs
+ added …
@7fa65ca
03/21/12 22:07:52 |
Joel Sherrill |
Add E1000 driver
@cd07c7a
03/21/12 16:47:01 |
Jennifer Averett |
Added Nic E1000 files without processing
The file processing …
@f4e3138
03/20/12 14:02:18 |
Jennifer Averett |
Added Intel EtherExpress? Pro/100B PCI Fast Ethernet driver.
@3d7f69c
03/20/12 13:14:59 |
Jennifer Averett |
Added RealTek? nic.
@3f7b966
03/12/12 17:23:59 |
Jennifer Averett |
Make socantsendmore() available which required sys/aio.h
@e1da9dc
03/12/12 13:34:29 |
Joel Sherrill |
Fix dry run bug and change name of filesChanged variable
@7326d96
03/12/12 12:58:24 |
Joel Sherrill |
Add diff mode to freebsd-to-rtems.py
@654f842
03/12/12 11:49:31 |
Joel Sherrill |
Move dry run check so more actions are performed during dry run
@25b3317
03/09/12 22:38:01 |
Joel Sherrill |
Use $(MAKE) not make so -jN works
@4d771c5
03/09/12 22:10:56 |
Joel Sherrill |
freebsd-to-rtems.py - Revert mode now confirmed to work for source
@3939378
03/09/12 21:01:45 |
Jennifer Averett |
Add kern/subr_eventhandler.c to resolve more symbols
@af5db72
03/09/12 20:43:41 |
Jennifer Averett |
Use partial path to avoid seeing rtems in full path
@8f5adbc
03/09/12 16:21:17 |
Joel Sherrill |
Initial addition of documentation
@6434b4b
03/09/12 15:38:23 |
Joel Sherrill |
Add other architecture specific in_cksum routines
+ arm, i386, …
@fcce4d2
03/09/12 15:19:06 |
Joel Sherrill |
Add time support files from FreeBSD to build to resolve more symbols
@9df9609
03/09/12 15:04:44 |
Joel Sherrill |
Initial addition of target specific files
+ This was needed for …
@0d436c7
03/08/12 22:54:51 |
Joel Sherrill |
netipsec/ipsec.c was in header file list not C file list
@b55081a
03/08/12 21:54:05 |
Joel Sherrill |
kern/kern_subr.c added for hashinit
More undefined symbols resulted.
@287453d
03/08/12 20:13:25 |
Joel Sherrill |
freebsd-to-rtems.py - Only copy if new version of file is different
@24600f2
03/08/12 18:52:46 |
Joel Sherrill |
All RTEMS files should now be under RTEMS
- Also add "Makefile …
@1e8830f0
03/08/12 17:21:45 |
Joel Sherrill |
More comments. Attempt to support forward/revert selection from …
@3616a06
03/08/12 17:05:16 |
Joel Sherrill |
Remove leading rtems/ directory from paths under rtemsbsd
@a803d120
03/08/12 16:04:36 |
Joel Sherrill |
freebsd-to-rtems.py Enhancements
+ dry-run mode
+ early-exit mode …
@b9c291c
03/08/12 14:57:16 |
Joel Sherrill |
Generate without rtems/ on includes
@63e8969
03/07/12 22:54:28 |
Joel Sherrill |
Modifications to separate RTEMS BSD files from FreeBSD files
@294ae20
03/07/12 22:17:18 |
Sebastian Huber |
Initial version.
