Search:
Preferences
About Trac
Wiki
Timeline
Roadmap
View Tickets
Search
Context Navigation
View Latest Revision
Notice:
We have migrated to GitLab launching 2024-05-01 see here:
https://gitlab.rtems.org/
source:
rtems-libbsd
freebsd-to-rtems.py
Revision Log Mode:
Stop on copy
Follow copies
Show only adds and deletes
View log starting at
and back to
Show at most
revisions per page.
Show full log messages
Legend:
Added
Modified
Copied or renamed
Diff
Rev
Age
Author
Log Message
(edit)
@287453d
03/08/12 20:13:25
Joel Sherrill
freebsd-to-rtems.py - Only copy if new version of file is different
4.11
5
5-freebsd-12
6-freebsd-12
freebsd-9.3
(edit)
@24600f2
03/08/12 18:52:46
Joel Sherrill
All RTEMS files should now be under RTEMS - Also add "Makefile …
4.11
5
5-freebsd-12
6-freebsd-12
freebsd-9.3
(edit)
@1e8830f0
03/08/12 17:21:45
Joel Sherrill
More comments. Attempt to support forward/revert selection from …
4.11
5
5-freebsd-12
6-freebsd-12
freebsd-9.3
(edit)
@3616a06
03/08/12 17:05:16
Joel Sherrill
Remove leading rtems/ directory from paths under rtemsbsd
4.11
5
5-freebsd-12
6-freebsd-12
freebsd-9.3
(edit)
@a803d120
03/08/12 16:04:36
Joel Sherrill
freebsd-to-rtems.py Enhancements + dry-run mode + early-exit mode …
4.11
5
5-freebsd-12
6-freebsd-12
freebsd-9.3
(edit)
@b9c291c
03/08/12 14:57:16
Joel Sherrill
Generate without rtems/ on includes
4.11
5
5-freebsd-12
6-freebsd-12
freebsd-9.3
(edit)
@63e8969
03/07/12 22:54:28
Joel Sherrill
Modifications to separate RTEMS BSD files from FreeBSD files
4.11
5
5-freebsd-12
6-freebsd-12
freebsd-9.3
(add)
@294ae20
03/07/12 22:17:18
Sebastian Huber
Initial version.
4.11
5
5-freebsd-12
6-freebsd-12
freebsd-9.3
Note:
See
TracRevisionLog
for help on using the revision log.
Download in other formats:
RSS Feed
ChangeLog
