# # ChangeLog for dhcpcd in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 05/18/24 19:15:08 Tue, 17 Dec 2013 13:04:28 GMT Sebastian Huber [7758fcc] * dhcpcd/dhcpcd.c (modified) DHCPCD(8): Add MASTER_ONLY option Tue, 17 Dec 2013 13:06:35 GMT Sebastian Huber [9cc83a7] * dhcpcd/script.h (modified) DHCPCD(8): Disable script support Tue, 21 Jan 2014 15:14:42 GMT Sebastian Huber [f724741] * dhcpcd/dhcpcd.c (modified) * dhcpcd/if-options.c (modified) DHCPCD(8): Add getopt_long_r() support Tue, 17 Dec 2013 13:05:00 GMT Sebastian Huber [61d281e] * dhcpcd/dhcpcd.c (modified) DHCPCD(8): Add RTEMS program support Tue, 17 Dec 2013 13:10:37 GMT Sebastian Huber [e6d558f] * dhcpcd/compat/pselect.c (modified) DHCPCD(8): Use select() instead of pselect() Thu, 30 Jan 2014 12:44:49 GMT Sebastian Huber [ec37843] * dhcpcd/config.h (added) DHCPCD(8): Add config.h Fri, 24 Jan 2014 10:12:52 GMT Sebastian Huber [f7fe399] * dhcpcd/namespace.h (added) DHCPCD(8): Add namespace header Thu, 30 Jan 2014 12:49:34 GMT Sebastian Huber [5638ae8] * dhcpcd/dhcpcd-embedded.c (added) * dhcpcd/dhcpcd-embedded.h (added) DHCPCD(8): Add automatically generated files Thu, 30 Jan 2014 12:29:46 GMT Sebastian Huber [f2ed769] * dhcpcd/GNUmakefile (added) * dhcpcd/Makefile (added) * dhcpcd/Makefile.inc (added) * dhcpcd/README (added) * dhcpcd/arp.c (added) * dhcpcd/arp.h (added) * dhcpcd/auth.c (added) * dhcpcd/auth.h (added) * dhcpcd/bpf-filter.h (added) * dhcpcd/bpf.c (added) * dhcpcd/common.c (added) * dhcpcd/common.h (added) * dhcpcd/compat/arc4random.c (added) * dhcpcd/compat/arc4random.h (added) * dhcpcd/compat/closefrom.c (added) * dhcpcd/compat/closefrom.h (added) * dhcpcd/compat/getline.c (added) * dhcpcd/compat/getline.h (added) * dhcpcd/compat/linkaddr.c (added) * dhcpcd/compat/pollts.c (added) * dhcpcd/compat/pollts.h (added) * dhcpcd/compat/posix_spawn.c (added) * dhcpcd/compat/posix_spawn.h (added) * dhcpcd/compat/pselect.c (added) * dhcpcd/compat/strlcpy.c (added) * dhcpcd/compat/strlcpy.h (added) * dhcpcd/configure (added) * dhcpcd/control.c (added) * dhcpcd/control.h (added) * dhcpcd/crypt/crypt.h (added) * dhcpcd/crypt/hmac_md5.c (added) * dhcpcd/crypt/md5.c (added) * dhcpcd/crypt/md5.h (added) * dhcpcd/defs.h (added) * dhcpcd/dev.c (added) * dhcpcd/dev.h (added) * dhcpcd/dev/Makefile (added) * dhcpcd/dev/udev.c (added) * dhcpcd/dhcp-common.c (added) * dhcpcd/dhcp-common.h (added) * dhcpcd/dhcp.c (added) * dhcpcd/dhcp.h (added) * dhcpcd/dhcp6.c (added) * dhcpcd/dhcp6.h (added) * dhcpcd/dhcpcd-definitions.conf (added) * dhcpcd/dhcpcd-embedded.h.in (added) * dhcpcd/dhcpcd-hooks/01-test (added) * dhcpcd/dhcpcd-hooks/02-dump (added) * dhcpcd/dhcpcd-hooks/10-mtu (added) * dhcpcd/dhcpcd-hooks/10-wpa_supplicant (added) * dhcpcd/dhcpcd-hooks/15-timezone (added) * dhcpcd/dhcpcd-hooks/20-resolv.conf (added) * dhcpcd/dhcpcd-hooks/29-lookup-hostname (added) * dhcpcd/dhcpcd-hooks/30-hostname (added) * dhcpcd/dhcpcd-hooks/50-dhcpcd-compat (added) * dhcpcd/dhcpcd-hooks/50-ntp.conf (added) * dhcpcd/dhcpcd-hooks/50-yp.conf (added) * dhcpcd/dhcpcd-hooks/50-ypbind (added) * dhcpcd/dhcpcd-hooks/Makefile (added) * dhcpcd/dhcpcd-run-hooks.8.in (added) * dhcpcd/dhcpcd-run-hooks.in (added) * dhcpcd/dhcpcd.8.in (added) * dhcpcd/dhcpcd.c (added) * dhcpcd/dhcpcd.conf (added) * dhcpcd/dhcpcd.conf.5.in (added) * dhcpcd/dhcpcd.h (added) * dhcpcd/duid.c (added) * dhcpcd/duid.h (added) * dhcpcd/eloop.c (added) * dhcpcd/eloop.h (added) * dhcpcd/genembedc (added) * dhcpcd/genembedh (added) * dhcpcd/if-bsd.c (added) * dhcpcd/if-linux-wireless.c (added) * dhcpcd/if-linux.c (added) * dhcpcd/if-options.c (added) * dhcpcd/if-options.h (added) * dhcpcd/if-pref.c (added) * dhcpcd/if-pref.h (added) * dhcpcd/ipv4.c (added) * dhcpcd/ipv4.h (added) * dhcpcd/ipv4ll.c (added) * dhcpcd/ipv4ll.h (added) * dhcpcd/ipv6.c (added) * dhcpcd/ipv6.h (added) * dhcpcd/ipv6nd.c (added) * dhcpcd/ipv6nd.h (added) * dhcpcd/lpf.c (added) * dhcpcd/net.c (added) * dhcpcd/net.h (added) * dhcpcd/platform-bsd.c (added) * dhcpcd/platform-linux.c (added) * dhcpcd/platform.h (added) * dhcpcd/script.c (added) * dhcpcd/script.h (added) * dhcpcd/test/Makefile (added) * dhcpcd/test/test.c (added) * dhcpcd/test/test.h (added) * dhcpcd/test/test_hmac_md5.c (added) DHCPCD(8): Import Import DHCPCD(8) from: ...
