# # ChangeLog for dhcpcd in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/30/24 17:37:45 Fri, 20 Oct 2017 12:50:14 GMT Sebastian Huber [7ec4d87] * dhcpcd/compat/pselect.c (modified) dhcpcd: Honour file descriptor maximum Thu, 07 Apr 2016 07:48:12 GMT Sebastian Huber [2017a6d] * builder.py (modified) * dhcpcd/config.h (modified) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/pcap/pcap.h (modified) * freebsd/contrib/tcpdump/tcpdump-stdinc.h (modified) * freebsd/lib/libc/include/isc/eventlib.h (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_update.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/contrib/altq/altq/altq_cbq.c (modified) * freebsd/sys/contrib/altq/altq/altq_red.c (modified) * freebsd/sys/contrib/altq/altq/altq_rmclass.c (modified) * freebsd/sys/contrib/pf/net/if_pfsync.c (modified) * freebsd/sys/contrib/pf/net/pf.c (modified) * freebsd/sys/contrib/pf/net/pf_if.c (modified) * freebsd/sys/contrib/pf/net/pf_ioctl.c (modified) * freebsd/sys/contrib/pf/net/pf_lb.c (modified) * freebsd/sys/contrib/pf/net/pf_norm.c (modified) * freebsd/sys/contrib/pf/net/pf_subr.c (modified) * freebsd/sys/crypto/blowfish/bf_skey.c (modified) * freebsd/sys/crypto/sha1.c (modified) * freebsd/sys/crypto/sha2/sha2.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/libkern/arc4random.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/if.h (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_faith.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ipfw/ip_dn_glue.c (modified) * freebsd/sys/netinet/ipfw/ip_dn_io.c (modified) * freebsd/sys/netinet/ipfw/ip_dummynet.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netpfil/ipfw/ip_dn_glue.c (modified) * freebsd/sys/netpfil/ipfw/ip_dn_io.c (modified) * freebsd/sys/netpfil/ipfw/ip_dummynet.c (modified) * freebsd/sys/opencrypto/xform.c (modified) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/include/rtems/bsd/sys/time.h (deleted) Directly use provided by Newlib Tue, 17 Dec 2013 13:04:28 GMT Sebastian Huber [7758fcc] * dhcpcd/dhcpcd.c (modified) DHCPCD(8): Add MASTER_ONLY option Tue, 17 Dec 2013 13:06:35 GMT Sebastian Huber [9cc83a7] * dhcpcd/script.h (modified) DHCPCD(8): Disable script support Tue, 21 Jan 2014 15:14:42 GMT Sebastian Huber [f724741] * dhcpcd/dhcpcd.c (modified) * dhcpcd/if-options.c (modified) DHCPCD(8): Add getopt_long_r() support Tue, 17 Dec 2013 13:05:00 GMT Sebastian Huber [61d281e] * dhcpcd/dhcpcd.c (modified) DHCPCD(8): Add RTEMS program support Tue, 17 Dec 2013 13:10:37 GMT Sebastian Huber [e6d558f] * dhcpcd/compat/pselect.c (modified) DHCPCD(8): Use select() instead of pselect() Thu, 30 Jan 2014 12:44:49 GMT Sebastian Huber [ec37843] * dhcpcd/config.h (added) DHCPCD(8): Add config.h Fri, 24 Jan 2014 10:12:52 GMT Sebastian Huber [f7fe399] * dhcpcd/namespace.h (added) DHCPCD(8): Add namespace header Thu, 30 Jan 2014 12:49:34 GMT Sebastian Huber [5638ae8] * dhcpcd/dhcpcd-embedded.c (added) * dhcpcd/dhcpcd-embedded.h (added) DHCPCD(8): Add automatically generated files Thu, 30 Jan 2014 12:29:46 GMT Sebastian Huber [f2ed769] * dhcpcd/GNUmakefile (added) * dhcpcd/Makefile (added) * dhcpcd/Makefile.inc (added) * dhcpcd/README (added) * dhcpcd/arp.c (added) * dhcpcd/arp.h (added) * dhcpcd/auth.c (added) * dhcpcd/auth.h (added) * dhcpcd/bpf-filter.h (added) * dhcpcd/bpf.c (added) * dhcpcd/common.c (added) * dhcpcd/common.h (added) * dhcpcd/compat/arc4random.c (added) * dhcpcd/compat/arc4random.h (added) * dhcpcd/compat/closefrom.c (added) * dhcpcd/compat/closefrom.h (added) * dhcpcd/compat/getline.c (added) * dhcpcd/compat/getline.h (added) * dhcpcd/compat/linkaddr.c (added) * dhcpcd/compat/pollts.c (added) * dhcpcd/compat/pollts.h (added) * dhcpcd/compat/posix_spawn.c (added) * dhcpcd/compat/posix_spawn.h (added) * dhcpcd/compat/pselect.c (added) * dhcpcd/compat/strlcpy.c (added) * dhcpcd/compat/strlcpy.h (added) * dhcpcd/configure (added) * dhcpcd/control.c (added) * dhcpcd/control.h (added) * dhcpcd/crypt/crypt.h (added) * dhcpcd/crypt/hmac_md5.c (added) * dhcpcd/crypt/md5.c (added) * dhcpcd/crypt/md5.h (added) * dhcpcd/defs.h (added) * dhcpcd/dev.c (added) * dhcpcd/dev.h (added) * dhcpcd/dev/Makefile (added) * dhcpcd/dev/udev.c (added) * dhcpcd/dhcp-common.c (added) * dhcpcd/dhcp-common.h (added) * dhcpcd/dhcp.c (added) * dhcpcd/dhcp.h (added) * dhcpcd/dhcp6.c (added) * dhcpcd/dhcp6.h (added) * dhcpcd/dhcpcd-definitions.conf (added) * dhcpcd/dhcpcd-embedded.h.in (added) * dhcpcd/dhcpcd-hooks/01-test (added) * dhcpcd/dhcpcd-hooks/02-dump (added) * dhcpcd/dhcpcd-hooks/10-mtu (added) * dhcpcd/dhcpcd-hooks/10-wpa_supplicant (added) * dhcpcd/dhcpcd-hooks/15-timezone (added) * dhcpcd/dhcpcd-hooks/20-resolv.conf (added) * dhcpcd/dhcpcd-hooks/29-lookup-hostname (added) * dhcpcd/dhcpcd-hooks/30-hostname (added) * dhcpcd/dhcpcd-hooks/50-dhcpcd-compat (added) * dhcpcd/dhcpcd-hooks/50-ntp.conf (added) * dhcpcd/dhcpcd-hooks/50-yp.conf (added) * dhcpcd/dhcpcd-hooks/50-ypbind (added) * dhcpcd/dhcpcd-hooks/Makefile (added) * dhcpcd/dhcpcd-run-hooks.8.in (added) * dhcpcd/dhcpcd-run-hooks.in (added) * dhcpcd/dhcpcd.8.in (added) * dhcpcd/dhcpcd.c (added) * dhcpcd/dhcpcd.conf (added) * dhcpcd/dhcpcd.conf.5.in (added) * dhcpcd/dhcpcd.h (added) * dhcpcd/duid.c (added) * dhcpcd/duid.h (added) * dhcpcd/eloop.c (added) * dhcpcd/eloop.h (added) * dhcpcd/genembedc (added) * dhcpcd/genembedh (added) * dhcpcd/if-bsd.c (added) * dhcpcd/if-linux-wireless.c (added) * dhcpcd/if-linux.c (added) * dhcpcd/if-options.c (added) * dhcpcd/if-options.h (added) * dhcpcd/if-pref.c (added) * dhcpcd/if-pref.h (added) * dhcpcd/ipv4.c (added) * dhcpcd/ipv4.h (added) * dhcpcd/ipv4ll.c (added) * dhcpcd/ipv4ll.h (added) * dhcpcd/ipv6.c (added) * dhcpcd/ipv6.h (added) * dhcpcd/ipv6nd.c (added) * dhcpcd/ipv6nd.h (added) * dhcpcd/lpf.c (added) * dhcpcd/net.c (added) * dhcpcd/net.h (added) * dhcpcd/platform-bsd.c (added) * dhcpcd/platform-linux.c (added) * dhcpcd/platform.h (added) * dhcpcd/script.c (added) * dhcpcd/script.h (added) * dhcpcd/test/Makefile (added) * dhcpcd/test/test.c (added) * dhcpcd/test/test.h (added) * dhcpcd/test/test_hmac_md5.c (added) DHCPCD(8): Import Import DHCPCD(8) from: ...
