# # ChangeLog for README.waf in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 03/28/24 23:24:12 Fri, 06 Apr 2018 08:35:42 GMT Christian Mauderer [854427b] * CONTRIBUTING.md (modified) * README.waf (modified) * builder.py (modified) * buildset/default.ini (added) * buildset/sample.ini (added) * libbsd.py (modified) * rtems_waf (modified) * waf_libbsd.py (modified) * wscript (modified) waf: Add configurations with different modules. Update #3351 Mon, 13 Feb 2017 07:38:45 GMT Sebastian Huber [2c4840f] * README.waf (modified) README.waf: Change BSP, add QEMU command line Fri, 06 May 2016 11:28:25 GMT Sebastian Huber [cf72971] * README.waf (modified) README.waf: Make set-up steps self contained Fri, 06 May 2016 09:10:12 GMT Sebastian Huber [b39854a] * README.waf (modified) README.waf: Add steps to clone and bootstrap RTEMS Fri, 06 May 2016 08:26:04 GMT Sebastian Huber [ff6534b] * README.waf (modified) README.waf: Master branch must use 4.12 Fri, 06 May 2016 08:25:31 GMT Sebastian Huber [4835d26] * README.waf (modified) README.waf: Typo Sat, 23 Apr 2016 07:37:27 GMT Chris Johns [e1e10cd] * README.waf (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/sys/systm.h (modified) * libbsd_waf.py (modified) * waf_generator.py (modified) * wscript (modified) waf: Add the ability to set FreeBSD options on the configure command ... Mon, 18 Apr 2016 01:07:14 GMT Chris Johns [68bf405] * README.waf (modified) * rtems_waf (modified) Update the rtems_waf submodule. Mon, 18 Apr 2016 00:53:20 GMT Chris Johns [97c5024a] * README.waf (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * libbsd.txt (modified) * rtems_waf (modified) * waf_generator.py (modified) * wscript (modified) Add RTEMS version support, update all python to 2 and 3. Add ... Sun, 24 May 2015 02:31:06 GMT Chris Johns [11ec988] * README.waf (modified) waf: Update the README.waf with better documentation. Wed, 20 May 2015 23:29:50 GMT Chris Johns [aca5496] * README.waf (modified) waf: Change to show how to only update the rtems_waf submodule. Wed, 20 May 2015 08:21:38 GMT Chris Johns [b14fd1f] * README.waf (added) Add a README for using waf.
