@946611a
11/25/14 12:14:46 |
Sebastian Huber |
e1000phy: Import from FreeBSD
4.1155-freebsd-126-freebsd-12freebsd-9.3
@6a73f64
11/25/14 11:54:56 |
Sebastian Huber |
if_cgem: Use rtems_bsd_get_mac_address()
@dec6b67
11/25/14 14:20:45 |
Sebastian Huber |
if_cgem: Enable hardware checksum assist
@911f517
11/25/14 11:54:35 |
Sebastian Huber |
if_cgem: Use explicit cache operations
@cd179c4
11/25/14 11:53:42 |
Sebastian Huber |
if_cgem: Add volatile to rx/tx desc rings
@8c3823e
11/25/14 11:53:04 |
Sebastian Huber |
if_cgem: Silence warning
@d65c5e5
01/20/15 10:04:00 |
Sebastian Huber |
if_cgem: Add nexus device support
@4ff97c8
11/20/14 14:23:05 |
Sebastian Huber |
if_cgem: Disable device sysctls
@14ecf75d
11/20/14 06:59:45 |
Sebastian Huber |
if_cgem: Workaround for missing FDT support
@a09f00e
11/20/14 06:58:17 |
Sebastian Huber |
if_cgem: Workaround for if_inc_counter()
@b8e0c66
11/20/14 06:57:05 |
Sebastian Huber |
if_cgem: Import from FreeBSD
@8cdd142
01/21/15 13:24:38 |
Sebastian Huber |
Add rtems_bsd_get_mac_address()
@eebe576
11/25/14 11:51:56 |
Sebastian Huber |
ZONE(9): Honor cache alignment
@fb683f7
11/25/14 11:50:29 |
Sebastian Huber |
BUS_DMA(9): Support BUS_DMA_COHERENT
@33a15c3
01/20/15 07:57:36 |
Sebastian Huber |
Add and use rtems_bsd_get_task_stack_size()
@91ea7ea
01/20/15 07:39:06 |
Sebastian Huber |
Add and use rtems_bsd_get_task_priority()
@e6405ea
11/10/14 07:27:55 |
Sebastian Huber |
HOSTNAME(1): Add -m flag
@026abfb
11/10/14 07:27:32 |
Sebastian Huber |
Add rtems_mdns_gethostname()
@4153ebe
11/10/14 07:26:15 |
Sebastian Huber |
Do not set mulitcast hostname in sethostname()
@0bed8d9
11/06/14 07:59:37 |
Sebastian Huber |
Fix spelling
@7a3fe8e
11/06/14 07:28:06 |
Sebastian Huber |
Add rtems_mdns_sethostname()
Use it to set the multi-cast hostname of …
@50e82a6
11/05/14 13:27:18 |
Sebastian Huber |
HOSTNAME(1): Import from FreeBSD
@c622a5e
11/03/14 15:06:07 |
Sebastian Huber |
foobarclient: Use rtems_mdns_initialize()
@7ba9b7f
11/03/14 14:53:46 |
Sebastian Huber |
Add mDNS support for name service dispatcher
@b94c5ec
11/03/14 14:21:06 |
Sebastian Huber |
NSDISPATCH(3): Add rtems_nss_register_module()
@f90fdf3
11/03/14 14:19:56 |
Sebastian Huber |
NSDISPATCH(3): Fix warning
@ffbee8a
11/03/14 08:18:14 |
Sebastian Huber |
Add rtems_bsd_force_select_timeout()
@d496d66
11/04/14 10:56:59 |
Sebastian Huber |
mDNS: Avoid uninitialized memory
Use calloc() instead of malloc().
@a736dda
10/31/14 09:37:34 |
Sebastian Huber |
nexus-devices: Only register fec0
This makes testing of IPv4LL a bit …
@94c3128
10/31/14 09:24:42 |
Sebastian Huber |
ffec: Accept all mulitcast frames
@7f4fb17
10/31/14 09:41:39 |
Sebastian Huber |
foobarserver: Set hostname
@7f9f0df
10/31/14 09:41:17 |
Sebastian Huber |
foobarclient: Set and advertise hostname
@54ed537
10/24/14 07:46:53 |
Sebastian Huber |
Support sethostname() and gethostname()
@feffbc2
10/16/14 13:12:19 |
Sebastian Huber |
Fix mount table location chain corruption
Do not add a location twice …
@43dc972
10/16/14 05:29:37 |
Sebastian Huber |
doc: Add network interface link up/down hint
@d5eac12
10/09/14 12:34:13 |
Sebastian Huber |
SYSLOG(3): Replace implementation
Avoid potential buffer overflows on …
@403d0b8
10/09/14 06:19:50 |
Sebastian Huber |
testsuite: Fix lo0 ifconfig error
Avoid "ifa_del_loopback_route: …
@573b4cd6
10/08/14 06:04:59 |
Sebastian Huber |
ppp: Port to new stack
@70fa95a
09/30/14 12:46:12 |
Sebastian Huber |
ppp: Import from RTEMS sources
@04a64b1
10/08/14 09:48:02 |
Sebastian Huber |
testsuite: Add DEFAULT_NETWORK_NO_INTERFACE_0
@263c947
10/08/14 05:49:36 |
Sebastian Huber |
testsuite: Make similar to default-network-init.h
@6cfc98d
10/01/14 12:20:42 |
Sebastian Huber |
nexus: Use a linker set for the devices
@d43544e
10/01/14 09:20:43 |
Sebastian Huber |
nexus: Fix resouce allocation
@9cea6da
10/01/14 11:19:35 |
Sebastian Huber |
Generalize linker sets
Add ability to create linker sets for items …
@454d682
10/01/14 11:41:57 |
Sebastian Huber |
Delete obsolete _bsd_nexus_devices
@a2a3a01
10/01/14 08:28:11 |
Sebastian Huber |
Provide new rtems_bsdnet_rtrequest()
Delete superfluous code.
@5a2f280
10/01/14 06:59:38 |
Sebastian Huber |
arpa/nameser_compat.h: Use proper endian defines
@74a133d
09/30/14 13:13:55 |
Sebastian Huber |
Makefile: Remove superfluous include path
@77345d4
09/30/14 07:52:42 |
Sebastian Huber |
usb01: Update due to API changes
@bd2e540
09/29/14 06:40:22 |
Sebastian Huber |
UMA(9): Disable unused uma_large_malloc()
@b8021fd
09/29/14 06:38:09 |
Sebastian Huber |
critical_enter/exit(): Use inline function
@6604dc8
09/25/14 08:48:14 |
Sebastian Huber |
Delete rtems_bsd_thread_chain
Rely on RTEMS object registration for …
@ccbc70d
09/24/14 14:28:25 |
Sebastian Huber |
BSD_ASSERT(): Optimize
@8176af1
09/24/14 13:41:16 |
Sebastian Huber |
rtems_bsd_mutex: Optimize
@54a4e3c
09/24/14 08:53:00 |
Sebastian Huber |
PING(8): Default to three packets
In the standard RTEMS shell it is …
@efb82b8
09/24/14 08:23:43 |
Sebastian Huber |
IFCONFIG(8): Default to AF_INET for RTEMS
Avoid errors due to …
@be43b79
09/22/14 11:42:26 |
Sebastian Huber |
Replace RTEMS objects with custom implementation
Performance analysis …
@6b475ce
09/23/14 05:14:19 |
Sebastian Huber |
Include missing header file
@9a937f4
09/22/14 13:06:55 |
Sebastian Huber |
Disable IPsec
IPsec has a significant performance impact. Disable it …
@e01f6e0
09/22/14 14:49:18 |
Sebastian Huber |
CONDVAR(9): Use lock class
@dce8247
09/22/14 14:24:34 |
Sebastian Huber |
Import and use subr_lock.c
@71d8a27
09/19/14 05:06:12 |
Sebastian Huber |
Install missing header files
@a29a71b
09/18/14 11:01:54 |
Sebastian Huber |
netstat: Initialize more global variables
@705d1bf
09/18/14 11:01:25 |
Sebastian Huber |
netstat: Fix invalid free()
@8babd8c
09/18/14 11:00:16 |
Sebastian Huber |
Fix cr_cansee*() to see everything
@6766ee9
09/18/14 10:59:24 |
Sebastian Huber |
Makefile: Add -fno-strict-aliasing
@4236e3d
09/18/14 08:43:37 |
Sebastian Huber |
ftpd01: Start shell only once
@15f19af
09/18/14 07:51:41 |
Sebastian Huber |
telnetd01: New test
@b78c1d2
09/18/14 07:47:57 |
Sebastian Huber |
telnetd: Avoid rtems_bsdnet_config
@a197a48
09/18/14 07:49:32 |
Sebastian Huber |
telnetd: Import from RTEMS sources
@e96e008
08/29/14 09:15:00 |
Sebastian Huber |
nexus: Add DISABLE_INTERRUPT_EXTENSION
Add an easy way to avoid the …
@7e982cf
08/29/14 09:01:39 |
Sebastian Huber |
Add file to ensure some C++ compatibility
@62bdb6a
08/29/14 09:05:19 |
Sebastian Huber |
C++ compatibility for some kernel headers
@b7ea2dd
08/28/14 20:42:43 |
Sebastian Huber |
@3d01336
08/28/14 20:31:47 |
Sebastian Huber |
Fix library creation
Delete library and create it from scratch to …
@8e2e9b3
08/27/14 13:00:09 |
Sebastian Huber |
Update due to rbtree API changes
@ead7fdc
05/16/14 11:35:21 |
Sebastian Huber |
doc: Clarify initialization
@14ba206
05/16/14 11:10:03 |
Sebastian Huber |
doc: Clarify test run
@da96928
05/16/14 11:04:35 |
Sebastian Huber |
doc: Clarify linkcmds sections
@9d955bc
05/14/14 09:57:56 |
Christian.Mauderer |
doc: Fix link and header
@b6d5758
05/14/14 07:19:25 |
Sebastian Huber |
Add some installation hints
@7100108
04/17/14 07:45:42 |
Sebastian Huber |
Update due to workspace allocation changes
@9219a29
04/17/14 07:45:20 |
Sebastian Huber |
Update due to shell API changes
@a271e91
04/17/14 07:45:03 |
Sebastian Huber |
Update due to chain API changes
@772eff7
04/17/14 07:44:39 |
Sebastian Huber |
Update due to CORE mutex API changes
@45b110f
01/30/14 15:39:30 |
Sebastian Huber |
Fix legacy MCF548X FEC interface driver
@e21bf0d
01/30/14 15:39:10 |
Sebastian Huber |
ftpd01: Use DHCP
@821ae67
01/30/14 14:59:15 |
Sebastian Huber |
ZONE(9): Make sure the chunks are properly aligned
@4c3433b
01/24/14 15:37:21 |
Sebastian Huber |
Documentation
@bc78466
01/24/14 14:49:10 |
Sebastian Huber |
Add Makefile.todo
@0543f16
01/23/14 14:28:23 |
Sebastian Huber |
mDNS: Use mutex for mDNSPosix platform
@f7205c1
01/23/14 14:27:19 |
Sebastian Huber |
mDNS: mDNSShared/mDNSDebug.c
Avoid reference to ProgramName?.
@7222726
01/23/14 14:09:02 |
Sebastian Huber |
mDNS: mDNSShared/dnssd_clientshim.c
Fix typos. Include missing …
@406a2f4
01/23/14 13:59:37 |
Sebastian Huber |
mDNS: AnonInfoAnswersQuestion?: Fix stack usage
The mDNSexport is …
@3951c97
01/22/14 08:43:51 |
Sebastian Huber |
mDNS: Add basic support
@9449f15
01/30/14 12:52:13 |
Sebastian Huber |
mDNS: Import
The sources can be obtained via:
@7758fcc
12/17/13 13:04:28 |
Sebastian Huber |
DHCPCD(8): Add MASTER_ONLY option
@9cc83a7
12/17/13 13:06:35 |
Sebastian Huber |
DHCPCD(8): Disable script support
@f724741
01/21/14 15:14:42 |
Sebastian Huber |
DHCPCD(8): Add getopt_long_r() support
@61d281e
12/17/13 13:05:00 |
Sebastian Huber |
DHCPCD(8): Add RTEMS program support
