@1f6caf3
10/18/13 10:52:28 |
Sebastian Huber |
commands01: New test
4.1155-freebsd-126-freebsd-12freebsd-9.3
@51c48bf
10/31/13 08:51:36 |
Sebastian Huber |
IFCONFIG(8): Avoid write to const string
@56e9de9
10/22/13 08:04:33 |
Sebastian Huber |
IFCONFIG(8): Wrap exit()
@b833cc4
10/22/13 08:03:10 |
Sebastian Huber |
IFCONFIG(8): Fix some resource leaks
@60618d5
10/18/13 14:30:27 |
Sebastian Huber |
IFCONFIG(8): Initialize global variables in ctors
@8ff186f
10/18/13 14:47:43 |
Sebastian Huber |
IFCONFIG(8): Fix isdigit() and isprint() usage
@13b50b3
10/18/13 14:13:41 |
Sebastian Huber |
IFCONFIG(8): Add const qualifier
@c14bb23
10/21/13 12:12:20 |
Sebastian Huber |
IFCONFIG(8): Disable IEEE80211 support
This module depends on a XML …
@43148f0
10/18/13 13:56:31 |
Sebastian Huber |
IFCONFIG(8): Avoid JAIL(3)
@4e14ded
10/18/13 13:52:13 |
Sebastian Huber |
IFCONFIG(8): Workaround for struct option confict
@9a3fa15
10/21/13 11:47:22 |
Sebastian Huber |
Use unmodified FreeBSD versions for port_*.h
@cdf6024
10/21/13 11:57:22 |
Sebastian Huber |
Add MAC support functions
WARNING: They are not thread-safe! This is …
@d02c998
10/18/13 09:30:52 |
Sebastian Huber |
ROUTE(8): Adjust port to RTEMS
@dfc416e
10/18/13 09:15:53 |
Sebastian Huber |
ROUTE(8): Free dynamic memory
@2a08d43
10/15/13 14:39:53 |
Sebastian Huber |
ROUTE(8): Add and use context
There is no point in aiming for long …
@ffcd542
10/18/13 12:12:17 |
Sebastian Huber |
Move TIMEOUT(9) and ZONE(9) initialization
Delete most of virtual …
@a9be4b0
10/17/13 13:30:31 |
Sebastian Huber |
Move shell items to separate file
@d01564c
10/17/13 08:38:34 |
Sebastian Huber |
Move program control to thread structure
@c333bab
10/17/13 08:46:42 |
Sebastian Huber |
Simplify getopt() to getopt_r() translation
@c804e500
10/17/13 08:31:30 |
Sebastian Huber |
Update from latest FreeBSD version
@1bbb359
10/23/13 07:47:26 |
Sebastian Huber |
Avoid NULL pointer access
@57f2002
10/15/13 13:36:59 |
Sebastian Huber |
Add sysctl(), etc. prototypes
@9d9bfaf
10/14/13 14:14:19 |
Sebastian Huber |
Use send/recv functions from FreeBSD
Use recvfrom(), recvmsg(), …
@ec702ab
10/14/13 12:55:04 |
Sebastian Huber |
Use socket read() and write() from FreeBSD
@8989c11
10/14/13 11:24:10 |
Sebastian Huber |
Use getsockname() from FreeBSD
@0beab1e
10/14/13 11:09:15 |
Sebastian Huber |
Use getpeername() from FreeBSD
@ac78dd2
10/14/13 10:53:43 |
Sebastian Huber |
Use getsockopt() and setsockopt() from FreeBSD
@7c2b59c
10/14/13 09:41:14 |
Sebastian Huber |
Use accept() from FreeBSD
@7c36251
10/14/13 08:04:29 |
Sebastian Huber |
Use listen() from FreeBSD
@6676de4
10/14/13 07:48:56 |
Sebastian Huber |
Use connect() from FreeBSD
@e5393a3
10/11/13 15:32:49 |
Sebastian Huber |
Use socket ioctl() from FreeBSD
@468b08e
10/11/13 14:44:48 |
Sebastian Huber |
Use bind() from FreeBSD
@6ffb9b9
10/11/13 12:48:13 |
Sebastian Huber |
Use shutdown() from FreeBSD
@bada2f7
10/15/13 12:05:50 |
Sebastian Huber |
Add socket fstat() support
@609df33
10/11/13 11:20:26 |
Sebastian Huber |
Use send() and recv() from FreeBSD
@caf8ede
10/10/13 09:29:33 |
Sebastian Huber |
Import socket() implementation from FreeBSD
Add new test syscalls01.
@69b29a0
10/10/13 14:11:02 |
Sebastian Huber |
Disable user credentials and use default values
@cc5f4b2
10/10/13 13:00:20 |
Sebastian Huber |
Use default PID value for all process identifiers
@549488b
10/10/13 12:45:09 |
Sebastian Huber |
Disable alternative routing tables
@3842b81
10/10/13 12:33:05 |
Sebastian Huber |
Delete struct proc p_mtx lock
Usage of this lock is highly dangerous …
@0bcf341
10/10/13 12:32:36 |
Sebastian Huber |
Delete unused struct proc fields
@db2e97f
10/14/13 13:01:13 |
Sebastian Huber |
Disable cold boot indicator
@5003e8f
10/10/13 12:31:21 |
Sebastian Huber |
Avoid references to lim_cur()
@c9db0f5
10/10/13 11:27:01 |
Sebastian Huber |
Use RTEMS API for file handling
@8eb42e8
10/10/13 08:32:52 |
Sebastian Huber |
Avoid references to kern_descrip.c
Use the standard RTEMS file …
@032b3b7
10/11/13 13:08:39 |
Sebastian Huber |
Use Newlib provided <sys/fcntl.h>
@ebabe9b
10/10/13 08:30:04 |
Sebastian Huber |
Import <sys/sysproto.h> from FreeBSD
@cd75897
10/10/13 09:32:42 |
Sebastian Huber |
Import <security/audit/audit.h> from FreeBSD
@3931b6e
10/10/13 11:23:44 |
Sebastian Huber |
Provide socklen_t, use size_t for socklen_t
@3fc7c89
10/10/13 08:29:36 |
Sebastian Huber |
Disable setfib() syscall
@a434fc8
10/10/13 09:28:11 |
Sebastian Huber |
Add empty files
@cc2298f
10/10/13 08:40:46 |
Sebastian Huber |
Fix warning in <sys/mbuf.h>
@7c801d1
10/10/13 08:31:04 |
Sebastian Huber |
Fix warnings in <sys/refcount.h>
@025d8f2
10/21/13 14:21:28 |
Sebastian Huber |
testsuite: Enable stack checker
Increase init task stack size.
@ed2ce44
10/10/13 07:31:18 |
Sebastian Huber |
Makefile: Generate map file
@ab415f9
10/09/13 06:56:49 |
Sebastian Huber |
Use extension to attach a struct thread to threads
Add test thread01.
@a1e0a41
10/09/13 13:41:09 |
Sebastian Huber |
Make default test initialization task preemptive
@f3b2913
10/09/13 12:29:38 |
Sebastian Huber |
Move core system initialization references
@58c4fda8
10/09/13 12:27:56 |
Sebastian Huber |
Do not run interactive netshell01 test
@a9f141a
10/09/13 07:00:44 |
Sebastian Huber |
Change license to BSD
@d652c3b
10/09/13 12:03:56 |
Sebastian Huber |
Avoid per-CPU NETISR(9)
SMP support should be enabled once the new …
@e599318
10/09/13 20:52:54 |
Sebastian Huber |
Update files to match FreeBSD layout
Add compatibility with Newlib …
@bceabc9
10/09/13 20:42:09 |
Sebastian Huber |
Move files to match FreeBSD layout
@e8b7066
10/01/13 14:23:35 |
Sebastian Huber |
Add FreeBSD sources as a submodule
The current version corresponds to …
@82800c5
09/20/13 14:30:30 |
Sebastian Huber |
Update due to header file changes
@83cb10f
09/20/13 14:08:34 |
Sebastian Huber |
There is no main thread in RTEMS
The resolv module has a questionable …
@937461c
09/20/13 13:09:10 |
Sebastian Huber |
Avoid per-CPU features
@e3dd7a4
09/20/13 13:05:01 |
Sebastian Huber |
Avoid usage of stack_t type
@a71a325
09/20/13 13:02:54 |
Sebastian Huber |
Use empty <sys/ucontext.h>
@473437c
09/20/13 13:01:27 |
Sebastian Huber |
@a3dde3e
09/20/13 10:52:44 |
Sebastian Huber |
Update due to Newlib <sys/cdefs.h> changes
@fabbca4
04/18/13 08:38:13 |
Sebastian Huber |
Add protocol definition
@efa254b
04/18/13 08:37:22 |
Sebastian Huber |
Fix YACC command
The '-d' and '-o' options conflict.
@85ea3b9
04/18/13 08:36:37 |
Sebastian Huber |
Ignore more files
@e00f10c
11/26/12 15:49:24 |
Jennifer Averett |
Remove empty version of timespec.h and limits.h
@0bde19e
11/26/12 15:47:09 |
Jennifer Averett |
Switch to a version of select that is closer to bsd's version.
@9d3ac2b
11/26/12 15:24:57 |
Jennifer Averett |
Add custom limits.h and timespec.h
These will be needed for added a …
@0bc8807
11/05/12 15:15:12 |
Sebastian Huber |
CAM: Update due to API changes
@09087dc
10/26/12 13:58:31 |
Jennifer Averett |
ping: Remove unnecessary ifdef
@af0a8ea
10/25/12 14:03:28 |
Joel Sherrill |
netstat/kvm: Disable debug prints
@e0b40b0a
10/25/12 14:02:38 |
Joel Sherrill |
netstat/netstat.h: Add macro so rt_tables is in private namespace
@2b640ee
10/24/12 23:14:32 |
Joel Sherrill |
uipc_domain.c: Correct max_linkhdr
@5f600dd
10/24/12 20:40:19 |
Joel Sherrill |
netstat: Enable use of kvm again
The code committed has some debug …
@34e1fb2
10/24/12 20:38:22 |
Joel Sherrill |
Add support for kvm.h in RTEMS terms
The implementation uses an array …
@5e93bed
10/24/12 20:37:49 |
Joel Sherrill |
Tool patches: Add newlib patch needed
@9257b31
10/24/12 20:03:50 |
Jennifer Averett |
Added -g option to Makefile.
@240093f
10/24/12 20:02:37 |
Jennifer Averett |
ping: corrected argument get to work with rtems.
@cb50354
10/24/12 20:01:23 |
Jennifer Averett |
_sx_xlock(): Added check for not in interrupt.
@d4515a8
10/23/12 21:49:40 |
Joel Sherrill |
kern_time: Disable some routines RTEMS has
@6f23b75
10/23/12 21:49:17 |
Joel Sherrill |
netstat: Use rtems_clock_get_uptime() instead of BSD specific method
@bea701c
10/23/12 21:48:54 |
Joel Sherrill |
netstat: Add macros to assist use of getopt_r()
@8ddbc30
10/23/12 19:21:34 |
Joel Sherrill |
rtems-bsd-sx.c: Disable check for interruptible blocking until it is …
@df900d3
10/23/12 19:20:32 |
Joel Sherrill |
Commands: Build with IPV6 enabled
@d422d0d
10/23/12 19:16:33 |
Jennifer Averett |
Merge branch 'master' of ssh://git.rtems.org/data/git/rtems-libbsd
@2df6b31
10/23/12 19:13:08 |
Jennifer Averett |
netstat: Added exit funtionality.
@e26cd8d
10/23/12 18:36:45 |
Joel Sherrill |
route: Add macros to assist use of getopt_r()
@68e0948
10/23/12 18:31:30 |
Joel Sherrill |
Makefile: Conditionalize IPV6 files and build some commands as .rel
@cc2aec4
10/23/12 18:31:04 |
Joel Sherrill |
.gitignore: Add .rel
@25f7f0f
10/23/12 15:57:30 |
Joel Sherrill |
ifconfig.c: Correct for getopt_r()
@346810a
10/22/12 19:43:57 |
Joel Sherrill |
netstat/if.c: Use POSIX not BSD signals
