@f1941b2
07/12/16 11:41:39 |
Christian.Mauderer |
libbsd.txt: Add section describing PF.
55-freebsd-126-freebsd-12freebsd-9.3
@f71cbd0
07/06/16 14:06:54 |
libbsd.txt: Add guide for user space tools.
@df222eb
07/22/16 12:50:09 |
testsuite/pf01: Test pfctl and pf.
@7f86f6a
07/22/16 12:49:49 |
pfctl: Add rtems_bsd_command_pfctl.
@c79290a
07/05/16 14:08:38 |
pfctl: build files.
@09ce54e
07/22/16 12:36:19 |
pfctl: Add yacc generated file.
@d79524e
07/05/16 14:31:43 |
pfctl: Adapt for RTEMS.
@686583c
07/29/16 14:04:42 |
pfctl: Use static where possible.
@c70221c
07/06/16 07:50:51 |
pfctl: Add const and move static variables.
Note: This should be …
@b6252fb
07/05/16 14:31:43 |
pfctl: Match prototype.
Note: This should be upstreamed into BSD.
@6e9a8ea
07/05/16 14:07:37 |
pfctl: Import sources from FreeBSD.
@21abaef
07/15/16 05:32:56 |
freebsd: Don't use new wrappers for old ports.
Some of the commands …
@d31a365
07/14/16 09:01:43 |
rtemsbsd: Add wrapper for open, fopen, malloc, ...
Add the following …
@3d91340
07/15/16 09:39:48 |
rtemsbsd: Add call to program with a data restore
This adds the …
@fa43d6a
07/14/16 13:34:13 |
testsuite/syscalls01: Split out program01 part.
This allows to use …
@a9bd422
06/27/16 12:29:53 |
testsuite/pf01: Add test that links PF.
@8dacfe4
06/28/16 13:13:09 |
testsuite/cdev01: Add test for cdev functions.
@9a01ebf
06/28/16 15:27:08 |
kern_conf.c: Adapt for RTEMS.
@6c0cfc2
06/29/16 08:22:03 |
kern_conf.c: Import from FreeBSD.
@b5db332
06/30/16 05:55:27 |
rtemsbsd/devfs: Add.
@bf7faad
06/28/16 06:32:30 |
Sebastian Huber |
rtems-bsd-mutex: Update due to API changes
@b6c170f
07/28/16 02:19:01 |
Chris Johns |
kern/sleepqueue: Update due to API changes
@a0ea5f8
07/28/16 02:17:08 |
Chris Johns |
Revert "kern/sleepqueue: Update due to API changes"
This reverts …
@1bf6529
07/28/16 02:16:09 |
Chris Johns |
@e5aa554
07/27/16 06:51:53 |
Sebastian Huber |
@9510012
07/18/16 22:12:17 |
Chris Johns |
config: Fix telnetd configuration warning.
@ac0e5bf
07/09/16 04:43:03 |
Chris Johns |
Update to bring in the --show-commands fix.
@b8c7bf9
07/06/16 07:08:07 |
Chris Johns |
Set syslog priority to 'debug' for all tests.
@761ae78
06/30/16 03:32:29 |
Chris Johns |
Make the license message viewable with a verbose option.
The license …
@34f6271
07/01/16 06:43:56 |
Chris Johns |
Provide empty RTEMS_BSD_CFGDECL_.* defines if not used.
@4dec435
07/01/16 06:36:13 |
Chris Johns |
Add a wait for key press to test rccof02.
@65c65bb
07/01/16 05:49:52 |
Chris Johns |
Add telnetd as service to rc.conf.
@fc26479
06/30/16 03:35:37 |
Chris Johns |
Add ftpd initailize comment.
@f01b1f72
06/30/16 01:42:49 |
Chris Johns |
Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE.
The domain allocator …
@dc5b267
06/29/16 23:25:13 |
Chris Johns |
Fix wording and spelling.
@573b1982
06/29/16 23:19:52 |
Chris Johns |
Add DHCP support to rc.conf.
@912b685
06/29/16 23:19:06 |
Chris Johns |
Make the LibBSD PID match getpid().
@c980a04
06/29/16 23:18:21 |
Chris Johns |
Fix fomatting and C++ guard.
@45960a3
06/29/16 23:17:21 |
Chris Johns |
Add rtems_get_route to fetch a specific route from the routing tables.
@4a2b844
06/29/16 23:14:55 |
Chris Johns |
Default syslog priority to INFO. Add rtems_setlogpriority to configure …
@90873cc
06/28/16 03:32:01 |
Chris Johns |
Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up.
@c2ec5f1
06/28/16 03:31:11 |
Chris Johns |
Print the service when starting.
@f588325
06/28/16 03:30:44 |
Chris Johns |
Change the Nexus bus to defines and have the BSP declare them.
@ace5fb6
06/27/16 11:31:03 |
Chris Johns |
Enable the Cadence cgem device syctls.
@591bd2d
06/27/16 11:27:01 |
Chris Johns |
Revert "Enable the Cadence cgem device syctls."
This reverts commit …
@9362e76
06/27/16 11:25:38 |
Chris Johns |
@9835790
06/27/16 11:24:03 |
Chris Johns |
Enable device sysctl.
@39a650e
06/27/16 06:45:18 |
Chris Johns |
Add VDE and QEMU doco.
@459d67d
06/27/16 03:35:08 |
Chris Johns |
Move the Nexus bus driver decls available to users.
@7439724
06/27/16 03:25:48 |
Chris Johns |
Add a services base test.
@55c564a
06/27/16 03:24:43 |
Chris Johns |
Refactor rc.conf processing to be services based.
@c6713d1
06/27/16 03:15:11 |
Chris Johns |
Add DEFAULT_NETWORK_PAGE_MBUFS_SIZE to allow per BSP allocation domain …
@9edacb6
06/27/16 03:12:39 |
Chris Johns |
Fix spelling.
@b23da31
06/27/16 03:12:06 |
Chris Johns |
Change LibBSD to use shared interrupts.
@130fa35
06/27/16 03:09:04 |
Chris Johns |
Make the domain allocation size global to allow it to set in tests.
@a0e49f9
06/27/16 03:07:54 |
Chris Johns |
Add functions used the bridge and tap interfaces.
@c991d65
06/23/16 12:18:17 |
Sebastian Huber |
Update due to RTEMS printer API changes
@32fd702
06/23/16 12:06:21 |
Sebastian Huber |
@628512a
06/20/16 00:07:08 |
Chris Johns |
Update rtems_waf to pick up the long command line fix.
@616be5c
06/16/16 07:08:37 |
Chris Johns |
Pick up white space fix.
@32ceb14
06/16/16 03:32:28 |
Chris Johns |
Add support for long command lines and fix some shell rules on Windows.
@5851034
06/15/16 05:49:24 |
Sebastian Huber |
reentrant.h: There is no main thread in RTEMS
@d6ad59d
06/13/16 09:59:04 |
Sebastian Huber |
libbsd.txt: Clarify xilinx_zynq_a9_qemu usage
@58c4e1c5
06/10/16 12:11:40 |
Sebastian Huber |
nfsclient: Port to LibBSD
@4464594
06/09/16 09:31:27 |
Sebastian Huber |
nfsclient: Import from RTEMS
RTEMS Git commit …
@a037da6
06/09/16 09:48:16 |
Sebastian Huber |
XDR(3): Port to RTEMS
@f41a394
06/09/16 09:46:09 |
Sebastian Huber |
XDR(3): Import from FreeBSD
@9880635
06/09/16 08:48:05 |
Sebastian Huber |
RPC(3): Port to RTEMS
@60b1d40
06/09/16 08:23:57 |
Sebastian Huber |
RPC(3): Import from FreeBSD
@68d406b
06/09/16 09:19:09 |
Sebastian Huber |
ftpfs: Import from RTEMS
RTEMS Git commit …
@71f66e7
06/10/16 11:05:16 |
Sebastian Huber |
selectpollkqueue01: Add EVFILT_USER test case
@17232fe
06/09/16 12:38:31 |
Sebastian Huber |
Remove unused files
Files moved in FreeBSD to "sys/netpfil/ipfw".
@1bb23f0
06/09/16 11:55:48 |
Sebastian Huber |
libbsd.txt: Fix format
@ab5cd63
05/31/16 07:16:54 |
Chris Johns |
tests: Fix compile errors after tools upgrade.
@f9798ad
05/30/16 23:49:31 |
Chris Johns |
Add a stats report command.
The report shows the level of changes we …
@70d52b8
05/30/16 14:05:15 |
Sebastian Huber |
@b367591
04/18/16 12:46:03 |
Sebastian Huber |
Adjust <sys/stdint.h> for latest Newlib
@04762cf
04/27/16 08:28:49 |
Sebastian Huber |
Directly use <machine/endian.h> provided by Newlib
@b6f6deb
04/27/16 08:26:50 |
Sebastian Huber |
Directly use <sys/_types.h> provided by Newlib
@3d1e767
04/27/16 08:25:22 |
Sebastian Huber |
Directly use <sys/types.h> provided by Newlib
@2017a6d
04/07/16 07:48:12 |
Sebastian Huber |
Directly use <sys/time.h> provided by Newlib
@f575822
05/30/16 14:00:25 |
Sebastian Huber |
rtems-bsd-rc-conf.h: Add missing include
@f70f9f5
05/30/16 14:00:07 |
Sebastian Huber |
testsuite/rcconf01: Add missing include
@43a14eb
05/25/16 11:11:59 |
Sebastian Huber |
@92e9493
05/25/16 11:10:22 |
Sebastian Huber |
testsuite: Update due to API changes
@9546d90
05/25/16 11:09:58 |
Sebastian Huber |
@d8e6b4c
05/18/16 09:03:39 |
Chris Johns |
rc.conf: Add the net directives by default.
@84665b5
05/18/16 09:03:20 |
Chris Johns |
rc.conf: Fix the wild card regex for ifconfig_
@f9fa038
05/18/16 05:21:09 |
Chris Johns |
Fix memory leak in rc.conf processing.
@05d47ae
05/18/16 05:20:36 |
Chris Johns |
Clean up whitespace.
@c67debb
05/18/16 04:17:20 |
Chris Johns |
Add rc.conf documentation.
@f5c6651
05/18/16 03:49:17 |
Chris Johns |
Add support for rc.conf(5) initialisation.
Provide user support for …
@ac7b68c
05/11/16 02:22:29 |
Chris Johns |
Get rtems_waf fix for command expansion.
@44a82d0
05/07/16 05:32:44 |
Chris Johns |
Update rtems_waf with the latest fixes.
@5b4394f
05/06/16 19:40:49 |
Sebastian Huber |
Add namespace support for kvm
@5b1f20b
05/06/16 19:22:38 |
Sebastian Huber |
Rename files for kernel namespace script
This makes it easier to …
@81e5ff4
05/06/16 12:49:15 |
Sebastian Huber |
Add kernel namespace exception for mbstat
@edb5e4b
05/06/16 12:32:58 |
Sebastian Huber |
Add kernel namespace exceptions
These names correspond to sysctls.
@f9a697a
05/06/16 12:32:28 |
Sebastian Huber |
media01: Add sysctl command
@b8f127e
05/06/16 12:10:40 |
Sebastian Huber |
Update kernel namespace
