@edc4bf9
05/13/19 09:19:05 |
Sebastian Huber |
Separate libbsd and RTEMS clock ticks
5-freebsd-126-freebsd-12
@f6075e1
05/13/19 09:14:21 |
Sebastian Huber |
Fix USB_DEBUG redefinition warnings
@510d1c9
05/13/19 09:13:49 |
Sebastian Huber |
Include missing <stdlib.h> to fix warnings
@061e279
05/13/19 08:55:38 |
Sebastian Huber |
Remove unused maxusers
@d1ad14f
05/13/19 08:35:19 |
Sebastian Huber |
Remove jail/prison functions from namespace
@0a8c0ce
05/13/19 08:33:19 |
Sebastian Huber |
Remove dangerous weak definition of getentropy()
All BSP supporting …
@2f9d60c
05/13/19 08:11:39 |
Sebastian Huber |
Add hostname related sysctls conditionally
This helps to the reduce …
@6f0b15e
05/13/19 08:09:55 |
Sebastian Huber |
usb: Undefine USB_DEBUG
In contrast to some other USB options which …
@70769b8
05/13/19 07:45:34 |
Sebastian Huber |
Add wrapper for abort()
@99efa82
05/10/19 12:14:57 |
Sebastian Huber |
Add USB mass storage only build set
@49c75e3
05/10/19 13:59:04 |
Sebastian Huber |
Use static inline functions for jail and prison
This helps the …
@6e5c632
05/13/19 07:31:17 |
Sebastian Huber |
Fix zero-copy mbuf support
In 2017 there was a change in the mbuf API.
@3549a12
05/13/19 07:19:44 |
Sebastian Huber |
IFCONFIG(8): Fix write to const string
@647dd08
04/11/19 07:33:39 |
Sebastian Huber |
Update due to API changes
@9723b63
03/29/19 07:55:37 |
Sebastian Huber |
nfsclient: Fix for 64-bit targets
The use of the serporid structure …
@24c05c8
03/28/19 12:37:37 |
Sebastian Huber |
openssl02: Fix includes
@5ae5e07
03/29/19 06:03:41 |
Sebastian Huber |
BPF(9): Disable legacy timestamp support
@94691f5
03/29/19 06:04:26 |
Sebastian Huber |
Revert "Add BURN_BRIDGES global kernel option"
This reverts commit …
@b5cc3f6
03/28/19 10:33:31 |
Sebastian Huber |
@616e1d4
03/28/19 10:34:10 |
Sebastian Huber |
BPF(9): Fix timestamps
@481397f
03/28/19 06:57:49 |
Sebastian Huber |
Update to FreeBSD stable/12 2019-03-27
Git mirror commit …
@29f11aa
03/28/19 06:47:34 |
Sebastian Huber |
openssl/apps: Add missing newline
This is necessary to get a …
@0abad45
03/28/19 06:49:53 |
Sebastian Huber |
CONTRIBUTING: Fix sed command example
@2334ebf
03/28/19 06:36:44 |
Sebastian Huber |
build: Add RTEMS test library
Update #3199.
@9ed6c971
03/26/19 10:08:47 |
christian.mauderer |
bin/openssl: Port to RTEMS.
@0a699e7
03/28/19 06:13:59 |
bin/openssl: Import from FreeBSD.
@eb1d30a
03/11/19 06:23:29 |
Sebastian Huber |
Update to FreeBSD stable/12 2019-03-11
Git mirror commit …
@d542c19
03/11/19 08:33:28 |
Sebastian Huber |
tcpdump: Move static variables to special section
This fixes some …
@c0776e6
03/11/19 08:32:53 |
Sebastian Huber |
tcpdump: Remove superfluous static variable
@d8a584d
03/11/19 08:29:19 |
Sebastian Huber |
tcpdump: Use stack variables
@4a8e4d9
03/11/19 08:16:02 |
Sebastian Huber |
tcpdump: Constify
@5f28ab2
03/11/19 07:08:08 |
Sebastian Huber |
rcconf02: Reduce maximum connection counts
This avoids a file …
@5f68b00
03/01/19 12:12:02 |
Sebastian Huber |
Remove unused file
@88f21b5
02/18/19 09:39:50 |
Sebastian Huber |
build: Make it possible to disable the tests
@3e483fb
02/18/19 09:05:32 |
Sebastian Huber |
Build C++ kernel-space compatibility file
@d8e4874
02/18/19 09:04:53 |
Sebastian Huber |
C++ compatibility for some kernel-space headers
@2a60dfb
02/18/19 09:03:57 |
Sebastian Huber |
Fix atomic_load_32()
@44c5fe2
02/18/19 09:01:09 |
Sebastian Huber |
builder.py: Accept C++ source files
@3017f66
02/12/19 13:18:33 |
Sebastian Huber |
Remove <linux/rbtree.h>
It is already provided by RTEMS.
@a124a75
02/12/19 13:17:52 |
Sebastian Huber |
Remove obsolete <rtems/pty.h>
@180ff44
02/12/19 13:15:39 |
Sebastian Huber |
mghttpd: Remove
The mghttpd is already provided by RTEMS.
@1ce4034
02/12/19 07:29:55 |
Sebastian Huber |
ZONE(9): Fix UMA_PCPU_ALLOC_SIZE
Using CACHE_LINE_SIZE for …
@556ec29
02/11/19 14:26:17 |
Sebastian Huber |
Update to FreeBSD stable/12 2019-02-11
Git mirror commit …
@0b177c7
02/11/19 14:19:30 |
Sebastian Huber |
atomic.h: Add atomic_fetchadd_64()
@d7504f8
02/05/19 13:15:47 |
Sebastian Huber |
atomic.h: Add atomic_load_32()
@4a8bc9e
02/04/19 13:56:37 |
Sebastian Huber |
Update to FreeBSD stable/12 2019-02-04
Git mirror commit …
@a5b385b
01/29/19 09:57:36 |
Sebastian Huber |
Update to FreeBSD stable/12 2019-01-29
Git mirror commit …
@0c9e63d
01/22/19 13:02:47 |
Sebastian Huber |
Remove obsolete file
@6e94aeb
01/22/19 12:52:31 |
Sebastian Huber |
Update README.waf and rename it to README.md
Convert it to Markdown …
@34cb55d
01/15/19 14:35:11 |
Sebastian Huber |
Fix INVARIANTS support
@1354d9b
01/21/19 09:13:58 |
Sebastian Huber |
Update to FreeBSD stable/12 2019-01-21
Git mirror commit …
@aec8db0
01/21/19 08:45:46 |
Sebastian Huber |
Update to FreeBSD stable/12 2019-01-16
Git mirror commit …
@66c9481
01/15/19 06:56:36 |
Sebastian Huber |
dpaa: Use if_transmit instead of legacy if_start
This avoids a lock …
@06e155a
01/14/19 12:08:08 |
Sebastian Huber |
dpaa: Fix FMan MAC SGT zone alignment
@8ae22c4
12/19/18 21:53:54 |
freebsd/if_cpsw: Port.
55-freebsd-126-freebsd-12
@736d651
12/19/18 21:53:53 |
freebsd/if_cpsw: Import.
@d7c7d6e
12/20/18 09:31:35 |
Sebastian Huber |
Fix locking issue in epoch_sysinit()
The …
@91566dd
12/18/18 18:54:20 |
waf: Update to waf-2.0.13.
This fixes a problem with python 3.7.
@e3b5952
12/19/18 09:28:42 |
SLEEPQUEUE(9): Fix typo that prevent non-SMP build.
@1b47c61
12/14/18 09:36:10 |
Sebastian Huber |
SLEEPQUEUE(9): SMP only cache line alignment
@8d5fc9d
11/27/18 08:07:53 |
Sebastian Huber |
blist: Fix u_daddr_t for 32-bit targets
The daddr_t is defined in …
@e0b4edbd
11/06/18 14:42:44 |
Sebastian Huber |
Update to FreeBSD head 2018-11-15
Git mirror commit …
@d4bf70e
11/15/18 09:06:00 |
Sebastian Huber |
Disable or make static kern_* functions
@70555d5
11/15/18 08:18:18 |
Sebastian Huber |
mutex: Avoid NULL pointer access in panic()
@9f2c3ce
11/15/18 07:23:17 |
Sebastian Huber |
Fix locking issue in epoch_watchdog()
The …
@9f87c45
11/13/18 09:17:29 |
Sebastian Huber |
Include missing <sys/types.h>
Update #3598.
@4ed04cb
10/26/18 21:13:47 |
joel |
Add waf 2.0.1 for parity with examples-v2
@afc0c81
10/25/18 07:40:18 |
Sebastian Huber |
openssl01: Call standard initialization functions
@a707913
10/25/18 06:39:13 |
Sebastian Huber |
openssl01: New test
@b3169c2
10/23/18 06:22:44 |
Sebastian Huber |
Update to FreeBSD head 2018-10-23
Git mirror commit …
@2ce13cf6
10/25/18 05:50:39 |
Sebastian Huber |
Update rtems_waf
Update #3551.
@a1e3251
10/24/18 09:35:31 |
Sebastian Huber |
libxo: Use program wrappers for exit(), etc.
@ed5e02a
10/23/18 09:08:11 |
Sebastian Huber |
Fix redefinition warnings
@dbb2407
10/23/18 10:11:54 |
Sebastian Huber |
ZONE(9): Disable UMA_ZONE_NUMA
There is no NUMA support in RTEMS …
@1aeb727
10/23/18 05:37:11 |
Sebastian Huber |
pppd: Fix use of uninitialized stack variables
@b151e8a
10/17/18 09:31:35 |
Sebastian Huber |
ppp01: Use novj option on host side
The VJ compression seems to be …
@c464b9e4
10/16/18 10:54:08 |
Sebastian Huber |
mDNSResponder: Fix for update to v765.1.2
In the update to v765.1.2 …
@91b858d
10/16/18 09:24:10 |
Sebastian Huber |
mDNSResponder: Fix use of uninitialized variables
@4a5f546
10/11/18 05:25:34 |
Sebastian Huber |
Fix dhcpcd.conf content
Do not write '\0' characters to the file. …
@8ee0aa1
10/10/18 12:40:47 |
Sebastian Huber |
PING(8): Honour file descriptor maximum
@175c1f8
10/10/18 12:12:51 |
Sebastian Huber |
Increase file descriptors in default network cfg
Make sure we can …
@91327bd
10/10/18 10:12:08 |
Sebastian Huber |
Use global stdout for kernel output and syslog()
@f949b43
10/10/18 09:37:37 |
Sebastian Huber |
Fix syslog() priority handling
Ths syslog priority is a mask not a level.
@1e77a45
10/04/18 10:06:44 |
Sebastian Huber |
saf1761_otg: Use real interrupt handler
The USB_BUS_SPIN_LOCK() is …
@f9d4e1d
10/04/18 12:10:10 |
Sebastian Huber |
rtwn: Align mbuf to avoid realignment in rx path
See ieee80211_realign().
@2eae88b
10/02/18 08:30:51 |
Sebastian Huber |
Fix typo (RTEMS_BSD_MODULE_NET80211)
@38c1a41
10/02/18 05:10:02 |
Sebastian Huber |
telnetd: Update due to API changes
Update #3526.
@446f887
10/02/18 05:07:05 |
Sebastian Huber |
mDNSResponder: Do not use SO_RECV_ANYIF socket opt
This socket option …
@b54bd95
09/28/18 16:08:22 |
Sebastian Huber |
fsl_sdhci.c: Fix missing include error
Update #3525.
@61575f5
09/20/18 12:27:17 |
Add PHY-driver for KSZ8091RNB with 50MHz.
This adds a driver for the …
@8645b550
09/27/18 05:27:39 |
Sebastian Huber |
Update #3525.
@b382502
09/19/18 06:22:14 |
Sebastian Huber |
fsl_sdhci.c: Port to RTEMS
Update #3525.
@6721f56
09/18/18 04:56:53 |
Sebastian Huber |
fsl_sdhci.c: Import from FreeBSD
Update #3525.
@06dd40e
09/24/18 11:45:52 |
Sebastian Huber |
imx/imx_gpio.c: Port to RTEMS
Update #3525.
@7e8e177
09/24/18 11:29:40 |
Sebastian Huber |
imx/imx_gpio.c: Import from FreeBSD
Update #3525.
@13840c1
09/24/18 11:40:35 |
Sebastian Huber |
Update gpio interface
Update #3525.
@b42dea9
09/25/18 07:27:50 |
Sebastian Huber |
CONFIG_INTRHOOK(9): Port to RTEMS
Some device drivers (e.g. MMC) need …
@6c51e62
09/25/18 07:57:43 |
Sebastian Huber |
media01: Improve output messages
Use a single printf() call to avoid …
@7aba2a4
09/24/18 06:01:19 |
Sebastian Huber |
ck: Install header files
Update #3472.
@6103496
09/14/18 11:33:34 |
Sebastian Huber |
if_ffec_mpc8xx: Fix incoming data invalidation
With a write-back …
