@de5791b
07/13/17 06:31:46 |
Sebastian Huber |
dpaa: Add "libbsd,dedicated-portal" to QMan portals
By default, the …
55-freebsd-126-freebsd-12
@e818128
06/23/17 09:39:26 |
Sebastian Huber |
dpaa: Add "libbsd,dequeue" to QMan portals
The dequeue support for …
@3cfc31c
07/11/17 12:53:42 |
Sebastian Huber |
dpaa: Set portal interrupt affinity
@ef1655c
07/10/17 07:19:10 |
Sebastian Huber |
Update to Linux 4.12
Linux baseline …
@e3dc39e
06/27/17 10:51:07 |
Sebastian Huber |
dpaa: Add <soc/fsl/dpaa.h>
@9789434
06/27/17 07:31:34 |
Sebastian Huber |
linux: Move upper_32_bits() and lower_32_bits()
@65d6fa2
06/27/17 07:31:11 |
Sebastian Huber |
linux: Make Linux types available in user-space
@0de65a8
06/27/17 07:30:44 |
Sebastian Huber |
linux: Include missing <sys/errno.h>
@9cc419f
06/27/17 06:36:05 |
Sebastian Huber |
Install Linux header files
@33d82be1
06/27/17 06:34:53 |
Sebastian Huber |
waf: Install arch-specific header files
@e846288
06/21/17 12:35:19 |
Sebastian Huber |
Add rtems_bsd_set_if_input()
@07c8680
05/24/17 11:16:11 |
Sebastian Huber |
dpaa: Get c45 ids
@03d1426
05/24/17 11:15:14 |
Sebastian Huber |
dpaa: No error if MII attach failed
@9da83e7
05/24/17 06:32:09 |
Sebastian Huber |
dpaa: Support c45 phys
@66e83e0e
05/19/17 07:47:45 |
Sebastian Huber |
soc/qbman: Simplify bman_release()
Get the affine portal only once …
@1908686
05/19/17 07:41:16 |
Sebastian Huber |
soc/qman: Do not enable stashing without PAMU
Do not enable stashing …
@e2d48f5
05/19/17 07:31:15 |
Sebastian Huber |
dpaa: Implement GENMASK() similar to Linux
@7f1f428
05/18/17 12:19:09 |
Sebastian Huber |
qman_api.c: Prevent false clearing of IRQ status
Adding …
@69a5677
05/18/17 09:53:08 |
Sebastian Huber |
dpaa: Disable QMAN_VOLATILE_FLAG_WAIT_INT
@96da40c
05/18/17 09:50:43 |
Sebastian Huber |
dpaa: Avoid QMan work queue
@ed254d58
05/18/17 06:13:07 |
Sebastian Huber |
dpaa: Use receive checksum offload
@3471177
05/18/17 05:44:00 |
Sebastian Huber |
dpaa: Enable preemption in qm_mr_process_task()
@b3a6ad0
05/18/17 05:28:22 |
Sebastian Huber |
dpaa: Disable unused CGR code
@cf40770
05/18/17 05:27:33 |
Sebastian Huber |
Linux update to 4.12-rc1+
Linux baseline …
@721b1c1
05/17/17 07:25:39 |
Sebastian Huber |
qbman: Fix platform_get_irq() error checks
@cd089b9
05/05/17 06:47:39 |
Sebastian Huber |
Linux update to 4.11-rc5
Linux baseline …
@28ee86a
04/27/16 09:58:19 |
Sebastian Huber |
Import DPAA driver snapshot
Imported from Freescale Linux repository
@b2b2e1a
10/20/17 10:51:20 |
Sebastian Huber |
powerpc: Fix warnings
@43fdf50
05/16/17 09:27:12 |
Sebastian Huber |
Import CRC32 support from FreeBSD
@64163f3
05/17/17 08:23:56 |
Sebastian Huber |
Initialize BSD user extension earlier
@f7f3c4b
05/10/17 09:31:29 |
Sebastian Huber |
blist: Import from FreeBSD
@238e275
04/06/17 13:09:42 |
Sebastian Huber |
scripts: Support CPU-dependent RTEMS source files
@23d6e50
04/03/17 13:18:09 |
Sebastian Huber |
scripts: Support Linux import
@fa4ec51
04/03/17 13:12:18 |
Sebastian Huber |
scripts: Generalize names
@d61f731
04/03/17 13:16:56 |
Sebastian Huber |
Add Linux submodule
@62c8ca0
05/18/17 07:35:46 |
Sebastian Huber |
Fix INVARIANTS support
@5be4f06
10/20/17 10:52:37 |
Sebastian Huber |
Add CPUINFO command to default network init
@1e554b81
11/23/16 13:06:26 |
Sebastian Huber |
media01: Scale with processor count
@91fb6e3
11/21/16 13:57:57 |
Sebastian Huber |
rtems-kernel-page: Reclaim pages earlier
@7533adc
11/10/16 13:58:22 |
Sebastian Huber |
rtems-kernel-page: Add used pages counter
@5ede682
11/14/16 09:17:10 |
Sebastian Huber |
ZONE(9): Use recursive lock for the UMA drain
@be708ff
11/21/16 13:56:59 |
Sebastian Huber |
ZONE(9): Reduce BUCKET_MAX to 128
Reduces the worst-case …
@b988014
04/26/16 13:02:00 |
Sebastian Huber |
ZONE(9): Fix uma_zone_set_max()
Account for items provided for …
@a8e84c6
02/14/17 10:48:46 |
Sebastian Huber |
DEVICE(9): Avoid NULL pointer access
@fd34b52
10/20/17 11:59:14 |
Sebastian Huber |
tests: Remove obsolete config defines
@7ec4d87
10/20/17 12:50:14 |
Sebastian Huber |
dhcpcd: Honour file descriptor maximum
@9a583a9
10/17/17 11:56:20 |
Sebastian Huber |
SLEEPQUEUE(9): Update due to API changes
Update #3117.
Update #3182.
@79ec6b9
10/16/17 07:49:09 |
Sebastian Huber |
Install libpcap header files
@c79946a
10/12/17 07:38:16 |
Sebastian Huber |
BPF(9): Remove RTEMS-specifics
@1043048
10/10/17 10:55:06 |
Sebastian Huber |
tcpdump: Update to FreeBSD head 2017-04-04
Update tcpdump from Git …
@cd7d52d
10/10/17 12:35:40 |
Sebastian Huber |
Update CONTRIBUTING.md
@acf428e
10/10/17 10:51:26 |
Sebastian Huber |
user-space: Define O_DIRECTORY
@a53da0d
10/10/17 12:03:11 |
Sebastian Huber |
userspace-header-gen.py: Python 3 compatibility
@97c5f8e8
10/09/17 07:59:36 |
Sebastian Huber |
Update libpcap to FreeBSD head 2017-04-04
Update libpcap from Git …
@67cbb9d
10/09/17 11:47:45 |
Sebastian Huber |
Regenerate libbsd_waf.py
@d18c643
10/02/17 07:57:04 |
Christian.Mauderer |
Allow to set optimization level during configure.
This allows to set …
@a70edfc
09/27/17 07:37:38 |
Sebastian Huber |
ffec: Add wmb() to descriptor updates
@7f7a339
09/27/17 07:33:41 |
Sebastian Huber |
ffec: Support up to three interrupt requests
@e2e4bf4
09/27/17 07:42:10 |
Sebastian Huber |
ffec: Avoid AXI bus issues due to a MAC reset
@ba0b059
09/27/17 07:54:56 |
Sebastian Huber |
ffec: Add FECFLAG_AVB variant flag
This flag is analogous to the …
@1378632
09/27/17 07:23:06 |
Sebastian Huber |
ffec: Increase descriptor ring alignment
For optimal performance a …
@9c34735
09/27/17 07:38:28 |
Sebastian Huber |
ffec: Use explicit cache synchronization
@91a7527
09/27/17 07:55:41 |
Sebastian Huber |
ffec: Support more rgmii variants
@95b102f
08/22/17 15:44:27 |
Sebastian Huber |
ffec: Port to RTEMS
@807b5bb
08/04/17 12:52:32 |
Sebastian Huber |
ffec: Import from FreeBSD
@b469163
09/22/17 12:40:51 |
Sebastian Huber |
Generalize bsp_fdt_map_intr()
Update #3090.
@c6f4aa6
09/22/17 07:41:20 |
if_atsam: Allow fixed MII settings.
@0190cfd
09/22/17 07:41:19 |
if_atsam: Move statistics to sysctl.
@80a7fe6
09/22/17 07:41:18 |
if-atsam: Port to rtems-libbsd.
@b16eca9
09/22/17 07:41:17 |
rtemsbsd/if-atsam: Copy from RTEMS.
Copied from RTEMS commit …
@894c965
09/15/17 10:46:57 |
Sebastian Huber |
Support reference counting for file descriptors
Close #3132.
@666a568
08/25/17 12:23:18 |
Sebastian Huber |
Include missing <string.h> and <limits.h>
Fix warnings.
Update …
@34ff390
08/10/17 13:03:44 |
Sebastian Huber |
BUS_SPACE(9): 64-bit support
Update #3082.
@885ac75
08/23/17 08:54:04 |
Sebastian Huber |
openssl: Workaround for ARM-specific files
Update #3110.
@301ee6e
08/22/17 15:51:40 |
Sebastian Huber |
Remove strtoimax() and strtoumax()
This is now provided by Newlib.
@1f7037d
08/01/17 12:32:08 |
1473996754 |
Port openssl to RTEMS.
@6bed520
08/01/17 12:31:19 |
1473996754 |
Import openssl from FreeBSD.
@8d2dbd3
08/11/17 05:27:13 |
oss |
waf: Move glob operator to builder.py
This allows a finer decision …
@307b324
08/11/17 05:27:12 |
christian.mauderer |
waf_generator: Copy headers if necessary.
There are some cases, where …
@097ccba
08/01/17 07:21:32 |
1473996754 |
Enable the WEP encrypted WiFi?.
Now rtems can connnect WiFi? via WEP on …
@47169ea
08/01/17 07:21:31 |
1473996754 |
Port rtl8188eu driver to RTEMS.
Now USB dongle rtl8188eu can work as …
@6e328c3
07/28/17 06:44:52 |
Sebastian Huber |
KQUEUE(2): Add missing file handler
@17ab62c
07/28/17 06:42:42 |
Sebastian Huber |
PIPE(2): Add missing file handler
@0913210
07/28/17 06:36:33 |
Sebastian Huber |
SOCKET(2): Add missing file handler
@b43517b
07/18/17 06:31:03 |
Sebastian Huber |
ohci: Fix for BSP_USB_OTG_TRANSCEIVER_I2C_ADDR
@658f9b8
07/17/17 13:32:52 |
dev/rtwn: Import new files from FreeBSD.
@9121570
07/13/17 02:24:05 |
1473996754 |
Port am335x usb driver to RTEMS.
Add FDT and umass support for am335x …
@bd3c01a
07/13/17 02:24:04 |
1473996754 |
Import am335x usb driver file from FreeBSD.
@83574df
07/11/17 08:42:32 |
Sebastian Huber |
termios: Interrupt server API changes
@378b5c2
05/09/17 12:09:49 |
Sebastian Huber |
Use LOG_EMERG for panic()
@9128d20
05/10/17 12:39:19 |
Sebastian Huber |
libkern.h: Add ffsll()
@127296c
07/10/17 06:24:56 |
Sebastian Huber |
libkern.h: Avoid conflict with <strings.h>
@e3e88e1
06/26/17 07:36:56 |
Sebastian Huber |
Add CONTRIBUTING.md
@9db59c7
06/22/17 04:56:52 |
Sebastian Huber |
Remove unused inet_* weak references
This change requires a Newlib …
@b83012a
06/16/17 05:31:51 |
Sebastian Huber |
@3c967ca
06/08/17 11:15:12 |
Sebastian Huber |
Use <sys/lock.h> provided by Newlib
@0237319
05/23/17 11:18:31 |
Sebastian Huber |
Update due to Newlib 2017-06-07 changes
The following files are now …
@29c0cff
05/17/17 12:40:37 |
kevin-kirspel |
Update scripts to include support for input devices - USB Keyboard, …
@427ee3e
05/17/17 12:40:36 |
kevin-kirspel |
Redirect FREEBSD's kern_yield to RTEMS sched_yield
@15a4321
05/17/17 12:40:35 |
kevin-kirspel |
Add tests for USB keyboard and mouse as well as EVDEV
