@d45899b
04/27/18 06:39:22 |
Sebastian Huber |
at91_mci: Get rid of bounce buffer
55-freebsd-126-freebsd-12
@3fac9e9
04/26/18 13:23:08 |
Sebastian Huber |
at91_mci: Use real interrupt
Execute at91_mci_intr() in interrupt …
@c7e162a
04/26/18 13:19:42 |
Sebastian Huber |
mmc: Optimize mmc_wait_for_req()
Use a self-contained RTEMS binary …
@4b14263
04/26/18 09:14:39 |
Sebastian Huber |
at91_mci: Fix use of BOARD_MCK
@f092186
04/26/18 09:14:10 |
Sebastian Huber |
at91_mci: Fix use of pre-processor defines
@854427b
04/06/18 08:35:42 |
christian.mauderer |
waf: Add configurations with different modules.
Update #3351
@fedd993
04/06/18 07:37:35 |
freebsd-to-rtems.py: Use all modules.
Update #3351
@494b156
04/06/18 07:42:29 |
waf: Remove module without sources.
There are no imported sources for …
@a6a6d54
03/27/18 07:31:49 |
waf: Fix freebsd-to-rtems.py.
Update #3351
@d797c5d
03/26/18 04:14:53 |
Chris Johns |
waf: Refactor libbsd.py to support per module generation.
This change …
@f7a09b5
03/26/18 04:14:52 |
Chris Johns |
waf: Support building from libbsd.py directly from waf.
Remove the …
@8189ea8
03/27/18 12:42:31 |
Sebastian Huber |
CRYPTO(4): Port to RTEMS
@6600368
03/27/18 11:25:16 |
Sebastian Huber |
CRYPTO(4): Import from FreeBSD
@b8f7836
03/27/18 12:41:50 |
Sebastian Huber |
DEVFS(5): Fix warning
@8993827
03/27/18 12:40:19 |
Sebastian Huber |
DEVFS(5): Properly initialize fp->f_cdevpriv
@7ec935e
03/23/18 06:58:18 |
vprintf: Add handler that mutes all output.
This adds a vprintf …
@d300a34
03/23/18 08:14:34 |
Sebastian Huber |
Silence rtems_bsd_ifconfig()
@b3d1e6a
03/21/18 08:23:17 |
config.inc: Remove unused values.
@b2a210c
03/15/18 08:09:31 |
if_atsam: Add checksum offload.
@67c35b9
03/13/18 14:02:55 |
openssl: Provide deprecated functions.
Some applications (like the …
@eae664e
03/12/18 13:38:46 |
Sebastian Huber |
mutex: Use panic() after ISR lock release
Using panic() with …
@2275776
02/06/18 08:29:49 |
Sebastian Huber |
dwc_otg: Default to USB host mode
In case no "dr_mode" property is …
@b79c025
02/06/18 08:28:02 |
Sebastian Huber |
dwc_otg: Add compatibility string, constify
Support device tree of …
@bcaa8a2
02/05/18 15:45:59 |
Sebastian Huber |
dw_mmc: Properly init/reset DMA
@138bf25
02/05/18 15:45:20 |
Sebastian Huber |
dw_mmc: Add MMCBR_IVAR_TIMING
@c30fa94
02/05/18 12:57:11 |
Sebastian Huber |
Add device tree support for Altera/Intel? Cyclone V
Close #3290.
@9906c4a
02/05/18 11:05:52 |
Sebastian Huber |
tests: Fix configuration dependencies
@0f9258f
11/29/17 14:26:17 |
Sebastian Huber |
linux/percpu.h: Fix for uni-processor config
@a0633c5
01/15/18 13:41:58 |
Sebastian Huber |
SLEEPQUEUE(9): Update due to API changes
Update #3264.
@8b3da13
01/08/18 12:55:36 |
Sebastian Huber |
termios: Update due to API changes
Update #2843.
@327f4e1
01/11/18 13:30:49 |
Sebastian Huber |
sdk_dpaa: What to do with tail queue drop?
The issue is this:
static …
@d62a3df
01/17/18 12:28:45 |
Sebastian Huber |
sdk_dpaa: Port to RTEMS
Update #3277.
@f5ed3aa
10/27/17 09:50:01 |
Sebastian Huber |
sdk_dpaa: Import from QorIQ SDK Linux
@0f6ff4a
01/10/18 14:08:19 |
Sebastian Huber |
dpaa: QMan portal only initialization
Update #3277.
@a7d252c
01/12/18 12:22:10 |
Sebastian Huber |
dpaa: Add and use bman_new_pool_for_bpid()
Update #3277.
@95fe5b1
01/10/18 12:19:01 |
Sebastian Huber |
dpaa: Use device tree throughout in BMan init
Update #3277.
@1342fad0
01/17/18 12:49:44 |
Sebastian Huber |
dpaa: Add and use SDK_DPAA_COMPAT_STATIC
Update #3277.
@34b7ccc
01/09/18 10:45:31 |
Sebastian Huber |
dpaa: Support FQ_TYPE_RX_PCD
Update #3277.
@bdf99316
01/12/18 12:23:24 |
Sebastian Huber |
dpaa: Disable unused bman_pool members
Update #3277.
@2fba1e4
01/23/18 09:48:19 |
Sebastian Huber |
dpaa: Remove unused configuration defines
Update #3277.
@cfc149b
01/10/18 13:11:57 |
Sebastian Huber |
linux/of_irq.h: Generalize of_irq_to_resource()
Determine interrupt …
@e4923c8
01/17/18 13:30:44 |
Sebastian Huber |
linux/of_address.h: of_address_to_resource()
Translate address in …
@0f1d2f6
01/10/18 12:18:05 |
Sebastian Huber |
linux/of_address.h: Add of_translate_address()
Update #3277.
@81fc57d
01/17/18 13:14:30 |
Sebastian Huber |
linux/of.h: Add of_find_node_by_path()
Update #3277.
@44fca38
01/17/18 13:14:10 |
Sebastian Huber |
linux/of.h: Add of_read_number()
Update #3277.
@26ce2ac
01/17/18 13:13:53 |
Sebastian Huber |
linux/of.h: Add of_n_size_cells()
Update #3277.
@0d421d8
01/17/18 13:13:34 |
Sebastian Huber |
linux/of.h: Add of_n_addr_cells()
Update #3277.
@066b536
01/17/18 12:26:11 |
Sebastian Huber |
linux/sort.h: New file
Update #3277.
@583216a
01/16/18 12:07:36 |
Sebastian Huber |
linux/smp.h: Avoid function call overhead
Update #3277.
@fe05886
11/02/17 13:29:57 |
Sebastian Huber |
linux/compiler.h: Define cold
Update #3277.
@2253814
01/23/18 10:52:50 |
Sebastian Huber |
Add rtems_bsd_ifconfig()
@13c4093
01/17/18 10:48:36 |
Sebastian Huber |
ehci_mpc83xx.c: Fix for qoriq hypervisor guest
@ea121a0
01/16/18 12:06:39 |
Sebastian Huber |
ZONE(9): Avoid function call overhead
@4e17f14
01/08/18 12:54:29 |
Sebastian Huber |
DEVICE(9): Fix BUS_ACCESSOR()
@4e3a5d3
12/22/17 12:18:25 |
Sebastian Huber |
openssl: Remove superfluous file
@b1649d6
11/29/17 14:26:54 |
Sebastian Huber |
Add rtems_bsd_initialize_dhcp()
@9569b39
11/17/17 13:23:55 |
Christian.Mauderer |
at91_mci: Fix for 32k buffer.
@c360b1a
11/17/17 09:49:59 |
Sebastian Huber |
Revert "RWLOCK(9): Add reader/writer lock implementation"
This was …
@b5822c2
11/17/17 09:49:31 |
Sebastian Huber |
Revert "SX(9): Implement with reader/writer lock"
This was …
@cc7a8d8
11/15/17 10:49:09 |
Sebastian Huber |
@97a98f6
11/14/17 11:57:01 |
Sebastian Huber |
@344b8e6
11/16/17 07:17:03 |
Sebastian Huber |
LOCKING(9): Remove dead code (DDB)
@3f23fcd
11/16/17 07:15:37 |
Sebastian Huber |
LOCKING(9): Remove dead code (KDTRACE_HOOKS)
@9c1490a
11/14/17 12:06:39 |
Sebastian Huber |
LOCKING(9): Update to current FreeBSD version
@b03a1c0
11/15/17 12:24:29 |
Sebastian Huber |
Fix file descriptor reference counting in accept()
Update #3132.
@06f06d4
11/10/17 13:19:29 |
Sebastian Huber |
Fix warning
@4525674
11/10/17 13:04:48 |
Sebastian Huber |
tcpdump: Fix import/export
@9521c08
11/09/17 13:35:13 |
wpa_supplicant: Use arc4random instead of getentropy.
@bc4bb2e
10/17/17 17:22:36 |
gordon |
Update wpa_supplicant/hostapd for 2017-01 vulnerability release.
@bdc4f21
11/08/17 13:11:09 |
wpa: Port to new files to RTEMS.
@b0f0b2f
11/08/17 13:10:40 |
wpa: Import all files for KRACK patch.
@a506ba9
11/08/17 10:25:59 |
at91_mci: Add timing to read_ivar.
@e7f3260
11/08/17 09:44:48 |
freebsd/bus: Check return value of bus_accessor.
@ec29b2a
11/07/17 15:17:55 |
at91_mci: Port to RTEMS and adapt for atsam.
@ea5880a
08/23/16 11:16:53 |
Sebastian Huber |
at91_mci: Import from FreeBSD
@5892207
11/07/17 14:15:38 |
saf1761_otg: Port to RTEMS.
@cf8e1d4
04/11/17 08:36:12 |
usb/saf1761: Import from FreeBSD.
Import the files for the SAF1761 …
@ddd16bc
11/07/17 10:54:39 |
dhcpcd: Don't ignore interface on transient errors.
In case of WPA on …
@e5abb31
11/08/17 11:43:39 |
libbsd.txt: Describe current state of WLAN.
@bed8742
11/03/17 10:08:48 |
wpa_supplicant: Fix getopt.
@79ad952
11/02/17 14:07:23 |
wpa_supplicant: Include rtems-bsd-program.h.
@4613db0
11/02/17 13:34:35 |
wpa_supplicant: Add lock.
@ee0c369
11/02/17 13:08:10 |
wpa_supplicant: Move forking command into own file.
The malloc …
@ce2262e
10/12/17 12:16:09 |
1473996754 |
Add wpa_supplicant_fork command.
Add fork command for wpa supplicant …
@0aa7e63
10/12/17 12:16:08 |
1473996754 |
Add wpa_supplicant command in test suite.
Add wpa supplicant command …
@8f2267b
10/12/17 12:16:07 |
1473996754 |
Port wpa supplicant to RTEMS.
Add wpa_supplicant lib support and …
@9c9d11b
08/01/17 12:43:41 |
1473996754 |
Import wpa from FreeBSD
@847de24
11/10/17 12:32:14 |
Sebastian Huber |
Fix build for non-FDT platforms
@7c68f4e
11/08/17 13:43:32 |
1473996754 |
Port BBB sd driver files to RTEMS.
So BBB can mount and read eMMC and …
@7e52ab9
11/08/17 13:43:31 |
1473996754 |
Import BBB sd driver files from FreeBSD.
@896f068
11/10/17 10:53:07 |
Sebastian Huber |
tests/syscalls01: Fix shutdown() test
The socket must be connected …
@23cd284
11/10/17 10:48:51 |
Sebastian Huber |
Add rtems_bsd_ifconfig_lo0()
@eeeda4b
11/10/17 10:17:13 |
Sebastian Huber |
tests/syscall01: Update error values
FreeBSD changed the error values.
@057656b
11/10/17 10:15:35 |
Sebastian Huber |
Disable HHOOK(9) support for sockets
Support was only partly disabled …
@72d5fa1
11/10/17 10:01:39 |
Sebastian Huber |
Fix reference counting for file descriptors
Update #3132.
@b15a719
11/09/17 13:28:55 |
Sebastian Huber |
Change RTEMS version to 5
Update #3220.
@c64806c
11/09/17 13:28:37 |
Sebastian Huber |
tests/mutex01: Fix mtx_recursed() usage
@6fbcf2e
11/09/17 13:28:17 |
Sebastian Huber |
tests/program01: Fix test name
@45149ec
10/26/17 13:02:24 |
Sebastian Huber |
Fix general PowerPC build
@936b597
10/26/17 06:43:53 |
Sebastian Huber |
ffec: Fix comment
Update #3090.
