@c418b7a
11/10/16 13:58:58 |
Sebastian Huber |
Fix mbuf_jumbo_alloc()
55-freebsd-126-freebsd-12freebsd-9.3
@7614758
11/14/16 09:17:55 |
Sebastian Huber |
Revert "rtems-kernel-page: Panic on recursive reclaim"
This attempt …
@e49f301
11/10/16 09:49:43 |
Sebastian Huber |
Fix default network memory configuration
@6517105
11/10/16 09:38:04 |
Sebastian Huber |
@6254bf4
11/09/16 09:26:17 |
Sebastian Huber |
SDHCI(4): Delete
Delete heavily modified SDHCI(4) support. It must …
@c00312a
10/24/16 07:05:34 |
Sebastian Huber |
Provide O_CLOEXEC
@8090fa0
10/24/16 07:01:28 |
Sebastian Huber |
Provide CLOCK_UPTIME
@71a0436
10/24/16 11:29:03 |
Sebastian Huber |
Add thread fences to <machine/atomic.h>
@cc8f00d
11/09/16 08:56:01 |
Sebastian Huber |
Fix warnings for linker sets
@520ab22
06/28/16 06:35:06 |
Sebastian Huber |
Modify rtems_bsd_set_vprintf_handler()
Return previous …
@6ff1baa
10/27/16 06:30:37 |
Sebastian Huber |
Add empty <machine/_kernel_lock.h>
@8b0bcb8
11/09/16 07:53:20 |
Sebastian Huber |
rtems-bsd-mutex: Optimize
Inline SMP lock acquire/release. Avoid …
@617dc0f
11/09/16 07:15:22 |
Sebastian Huber |
Really robust linker sets
The previous attempt to fix this issue …
@0b08247
11/03/16 10:18:27 |
Sebastian Huber |
rtems-bsd-mutex: Update due to API changes
@ed499fa
10/26/16 12:38:23 |
Sebastian Huber |
More robust linker sets
See also:
@cf88298
10/26/16 12:14:05 |
Sebastian Huber |
Prepare copyiniov() for FreeBSD update
@ade8f56
10/26/16 12:04:36 |
Sebastian Huber |
devfs: Fix includes
@632e278
10/21/16 09:05:29 |
Christian.Mauderer |
rtemsbsd: Add reallocf to rtems_bsd_program.
@0ba4197
10/24/16 06:07:56 |
Sebastian Huber |
Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h>
@f0aaa04
10/21/16 13:38:58 |
Sebastian Huber |
Provide CLOCK_MONOTONIC_FAST
@7eb064c
10/24/16 06:06:27 |
Sebastian Huber |
Make <sys/proc.h> self-sufficient
@390e133
10/24/16 06:02:13 |
Sebastian Huber |
Make <machine/atomic.h> available to user space
Enables use of …
@95a12a2
10/07/16 07:01:02 |
Sebastian Huber |
Fix FreeBSD source file reverse conversion
@a9d38f5
10/07/16 05:24:30 |
Sebastian Huber |
Remove AppleTalk? support
Prepare update to FreeBSD 11.
@40f202da
10/13/16 05:21:48 |
Sebastian Huber |
pfctl: Update due to linker set API changes
@f5f9e16
10/07/16 05:24:02 |
Sebastian Huber |
nexus-devices: Support arm/lpc24xx
@335bb97
10/07/16 05:23:33 |
Sebastian Huber |
testsuite: Fix warnings
@e11f8e3
10/07/16 05:09:48 |
Sebastian Huber |
ohci: Fixes due to USB stack update
@e3881ee
09/28/16 13:34:46 |
Sebastian Huber |
nexus-devices: Add arm/atsamv BSP section
@ec5b97b
09/28/16 13:33:50 |
Sebastian Huber |
usb01: Simplify test program
@8eb8883
09/28/16 13:00:00 |
Sebastian Huber |
Split rtemsbsd/rtems/rtems-program.c
This improves garbage collection …
@10e9e05
09/28/16 12:46:55 |
Sebastian Huber |
Split rtems-bsd-kernel-program.c
Separate kernel and user space parts.
@299d4ba
09/28/16 12:39:32 |
Sebastian Huber |
Build rtems-bsd-shell-pfctl.c
@d9fe061
09/28/16 11:23:16 |
Sebastian Huber |
Split rtems-bsd-shell-netcmds.c
This improves garbage collection by …
@2c563ed
09/23/16 07:54:49 |
Sebastian Huber |
if_ffec_mcf548x.c: Fix include order
@02d344f4
09/22/16 05:22:42 |
Sebastian Huber |
@2c44b51
09/22/16 05:21:54 |
Sebastian Huber |
Use _Thread_Get_priority()
@7f75b56
09/07/16 13:43:44 |
Sebastian Huber |
Port getdomainname() to RTEMS
@a439410
09/07/16 13:42:36 |
Sebastian Huber |
Import getdomainname()
@8e65e1b
08/23/16 13:51:45 |
Sebastian Huber |
usb: Update to FreeBSD trunk 2016-08-23
FreeBSD trunk, 2016-08-23, …
@7c77211
08/23/16 13:37:01 |
Sebastian Huber |
doc: Update rules to modify FreeBSD code
@0c24e06
08/23/16 12:22:26 |
Sebastian Huber |
mmc: Update to FreeBSD trunk 2016-08-23
@a971614
08/19/16 09:18:52 |
Sebastian Huber |
@69355c3
08/16/16 06:52:07 |
devfs: Add some notes on implementation.
@6634edb
08/16/16 06:52:06 |
devfs: Create path.
@ab7739a
08/12/16 03:55:37 |
Chris Johns |
rc.conf/net: Let interface option appear on a DHCP ifconfig_ line.
An …
@c83cf5c
08/12/16 02:19:48 |
Chris Johns |
nfsclient: Only parse for options when present.
@691ed15
08/11/16 07:01:42 |
Sebastian Huber |
rtems-bsd-mutex: Use _Thread_queue_Surrender()
@26a8cee
08/11/16 07:41:49 |
Chris Johns |
e1000phy: Provide local support for Marvell's 88E1512 PHY.
This PHY …
@62c4755
08/10/16 06:04:16 |
Sebastian Huber |
doc: Add FreeBSD import version section
@bc9e939
08/04/16 11:20:04 |
pf: Add configuration via rc.conf.
@6cfb5c2
08/08/16 14:11:21 |
pf: Improve documentation regarding stack.
@61e2e1b
08/08/16 13:53:39 |
rc.conf: Use more stack for the rc worker.
Most of the tests run with …
@a8d016c
08/04/16 06:30:44 |
testsuite/pf01: Remove pflog-module from test.
This module is not …
@32a3dd1
08/04/16 06:02:24 |
pf: Add RTEMS_BSD_CONFIG_FIREWALL_xxx options.
@0717607
08/05/16 10:00:47 |
if_ffec_mcf548x: Init when interface is set to UP.
Call the driver …
@9907ae4
08/04/16 12:13:20 |
netstat: Don't init vars if they are not defined.
The variables are …
@2fb3a36
08/04/16 12:12:17 |
freebsd: Add constant ipv6 addresses from vars.c.
This is necessary …
@7aaa9a1
08/03/16 11:27:11 |
testsuite/pf02: Add interactive pf test.
@f1941b2
07/12/16 11:41:39 |
libbsd.txt: Add section describing PF.
@f71cbd0
07/06/16 14:06:54 |
libbsd.txt: Add guide for user space tools.
@df222eb
07/22/16 12:50:09 |
testsuite/pf01: Test pfctl and pf.
@7f86f6a
07/22/16 12:49:49 |
pfctl: Add rtems_bsd_command_pfctl.
@c79290a
07/05/16 14:08:38 |
pfctl: build files.
@09ce54e
07/22/16 12:36:19 |
pfctl: Add yacc generated file.
@d79524e
07/05/16 14:31:43 |
pfctl: Adapt for RTEMS.
@686583c
07/29/16 14:04:42 |
pfctl: Use static where possible.
@c70221c
07/06/16 07:50:51 |
pfctl: Add const and move static variables.
Note: This should be …
@b6252fb
07/05/16 14:31:43 |
pfctl: Match prototype.
Note: This should be upstreamed into BSD.
@6e9a8ea
07/05/16 14:07:37 |
pfctl: Import sources from FreeBSD.
@21abaef
07/15/16 05:32:56 |
freebsd: Don't use new wrappers for old ports.
Some of the commands …
@d31a365
07/14/16 09:01:43 |
rtemsbsd: Add wrapper for open, fopen, malloc, ...
Add the following …
@3d91340
07/15/16 09:39:48 |
rtemsbsd: Add call to program with a data restore
This adds the …
@fa43d6a
07/14/16 13:34:13 |
testsuite/syscalls01: Split out program01 part.
This allows to use …
@a9bd422
06/27/16 12:29:53 |
testsuite/pf01: Add test that links PF.
@8dacfe4
06/28/16 13:13:09 |
testsuite/cdev01: Add test for cdev functions.
@9a01ebf
06/28/16 15:27:08 |
kern_conf.c: Adapt for RTEMS.
@6c0cfc2
06/29/16 08:22:03 |
kern_conf.c: Import from FreeBSD.
@b5db332
06/30/16 05:55:27 |
rtemsbsd/devfs: Add.
@bf7faad
06/28/16 06:32:30 |
Sebastian Huber |
@b6c170f
07/28/16 02:19:01 |
Chris Johns |
kern/sleepqueue: Update due to API changes
@a0ea5f8
07/28/16 02:17:08 |
Chris Johns |
Revert "kern/sleepqueue: Update due to API changes"
This reverts …
@1bf6529
07/28/16 02:16:09 |
Chris Johns |
@e5aa554
07/27/16 06:51:53 |
Sebastian Huber |
@9510012
07/18/16 22:12:17 |
Chris Johns |
config: Fix telnetd configuration warning.
@ac0e5bf
07/09/16 04:43:03 |
Chris Johns |
Update to bring in the --show-commands fix.
@b8c7bf9
07/06/16 07:08:07 |
Chris Johns |
Set syslog priority to 'debug' for all tests.
@761ae78
06/30/16 03:32:29 |
Chris Johns |
Make the license message viewable with a verbose option.
The license …
@34f6271
07/01/16 06:43:56 |
Chris Johns |
Provide empty RTEMS_BSD_CFGDECL_.* defines if not used.
@4dec435
07/01/16 06:36:13 |
Chris Johns |
Add a wait for key press to test rccof02.
@65c65bb
07/01/16 05:49:52 |
Chris Johns |
Add telnetd as service to rc.conf.
@fc26479
06/30/16 03:35:37 |
Chris Johns |
Add ftpd initailize comment.
@f01b1f72
06/30/16 01:42:49 |
Chris Johns |
Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE.
The domain allocator …
@dc5b267
06/29/16 23:25:13 |
Chris Johns |
Fix wording and spelling.
@573b1982
06/29/16 23:19:52 |
Chris Johns |
Add DHCP support to rc.conf.
@912b685
06/29/16 23:19:06 |
Chris Johns |
Make the LibBSD PID match getpid().
@c980a04
06/29/16 23:18:21 |
Chris Johns |
Fix fomatting and C++ guard.
@45960a3
06/29/16 23:17:21 |
Chris Johns |
Add rtems_get_route to fetch a specific route from the routing tables.
@4a2b844
06/29/16 23:14:55 |
Chris Johns |
Default syslog priority to INFO. Add rtems_setlogpriority to configure …
@90873cc
06/28/16 03:32:01 |
Chris Johns |
Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up.
