source: rtems-libbsd
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @b16eca9   Sep 22, 2017, 7:41:17 AM Christian.Mauderer rtemsbsd/if-atsam: Copy from RTEMS. Copied from RTEMS commit … 5-freebsd-12
(edit) @894c965   Sep 15, 2017, 10:46:57 AM Sebastian Huber Support reference counting for file descriptors Close #3132. 5-freebsd-12
(edit) @666a568   Aug 25, 2017, 12:23:18 PM Sebastian Huber Include missing <string.h> and <limits.h> Fix warnings. Update … 5-freebsd-12
(edit) @34ff390   Aug 10, 2017, 1:03:44 PM Sebastian Huber BUS_SPACE(9): 64-bit support Update #3082. 5-freebsd-12
(edit) @885ac75   Aug 23, 2017, 8:54:04 AM Sebastian Huber openssl: Workaround for ARM-specific files Update #3110. 5-freebsd-12
(edit) @301ee6e   Aug 22, 2017, 3:51:40 PM Sebastian Huber Remove strtoimax() and strtoumax() This is now provided by Newlib. 5-freebsd-12
(edit) @1f7037d   Aug 1, 2017, 12:32:08 PM 1473996754 Port openssl to RTEMS. 5-freebsd-12
(edit) @6bed520   Aug 1, 2017, 12:31:19 PM 1473996754 Import openssl from FreeBSD. 5-freebsd-12
(edit) @8d2dbd3   Aug 11, 2017, 5:27:13 AM oss waf: Move glob operator to builder.py This allows a finer decision … 5-freebsd-12
(edit) @307b324   Aug 11, 2017, 5:27:12 AM christian.mauderer waf_generator: Copy headers if necessary. There are some cases, where … 5-freebsd-12
(edit) @097ccba   Aug 1, 2017, 7:21:32 AM 1473996754 Enable the WEP encrypted WiFi?. Now rtems can connnect WiFi? via WEP on … 5-freebsd-12
(edit) @47169ea   Aug 1, 2017, 7:21:31 AM 1473996754 Port rtl8188eu driver to RTEMS. Now USB dongle rtl8188eu can work as … 5-freebsd-12
(edit) @6e328c3   Jul 28, 2017, 6:44:52 AM Sebastian Huber KQUEUE(2): Add missing file handler 5-freebsd-12
(edit) @17ab62c   Jul 28, 2017, 6:42:42 AM Sebastian Huber PIPE(2): Add missing file handler 5-freebsd-12
(edit) @0913210   Jul 28, 2017, 6:36:33 AM Sebastian Huber SOCKET(2): Add missing file handler 5-freebsd-12
(edit) @b43517b   Jul 18, 2017, 6:31:03 AM Sebastian Huber ohci: Fix for BSP_USB_OTG_TRANSCEIVER_I2C_ADDR 5-freebsd-12
(edit) @658f9b8   Jul 17, 2017, 1:32:52 PM Christian.Mauderer dev/rtwn: Import new files from FreeBSD. 5-freebsd-12
(edit) @9121570   Jul 13, 2017, 2:24:05 AM 1473996754 Port am335x usb driver to RTEMS. Add FDT and umass support for am335x … 5-freebsd-12
(edit) @bd3c01a   Jul 13, 2017, 2:24:04 AM 1473996754 Import am335x usb driver file from FreeBSD. 5-freebsd-12
(edit) @83574df   Jul 11, 2017, 8:42:32 AM Sebastian Huber termios: Interrupt server API changes 5-freebsd-12
(edit) @378b5c2   May 9, 2017, 12:09:49 PM Sebastian Huber Use LOG_EMERG for panic() 5-freebsd-12
(edit) @9128d20   May 10, 2017, 12:39:19 PM Sebastian Huber libkern.h: Add ffsll() 5-freebsd-12
(edit) @127296c   Jul 10, 2017, 6:24:56 AM Sebastian Huber libkern.h: Avoid conflict with <strings.h> 5-freebsd-12
(edit) @e3e88e1   Jun 26, 2017, 7:36:56 AM Sebastian Huber Add CONTRIBUTING.md 5-freebsd-12
(edit) @9db59c7   Jun 22, 2017, 4:56:52 AM Sebastian Huber Remove unused inet_* weak references This change requires a Newlib … 5-freebsd-12
(edit) @b83012a   Jun 16, 2017, 5:31:51 AM Sebastian Huber Remove unused inet_* weak references This change requires a Newlib … 5-freebsd-12
(edit) @3c967ca   Jun 8, 2017, 11:15:12 AM Sebastian Huber Use <sys/lock.h> provided by Newlib 5-freebsd-12
(edit) @0237319   May 23, 2017, 11:18:31 AM Sebastian Huber Update due to Newlib 2017-06-07 changes The following files are now … 5-freebsd-12
(edit) @29c0cff   May 17, 2017, 12:40:37 PM kevin-kirspel Update scripts to include support for input devices - USB Keyboard, … 5-freebsd-12
(edit) @427ee3e   May 17, 2017, 12:40:36 PM kevin-kirspel Redirect FREEBSD's kern_yield to RTEMS sched_yield 5-freebsd-12
(edit) @15a4321   May 17, 2017, 12:40:35 PM kevin-kirspel Add tests for USB keyboard and mouse as well as EVDEV 5-freebsd-12
(edit) @9d4afe9   May 17, 2017, 12:40:34 PM kevin-kirspel Add keyboard driver set variable 5-freebsd-12
(edit) @e28a8d0   May 17, 2017, 12:40:33 PM kevin-kirspel Add LPC32XX touch screen driver 5-freebsd-12
(edit) @fb2aa6e   May 17, 2017, 12:40:32 PM kevin-kirspel Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h 5-freebsd-12
(edit) @18cf428   May 17, 2017, 12:40:31 PM kevin-kirspel Modify FREEBSD EVDEV driver for use in RTEMS 5-freebsd-12
(edit) @b51279b   May 17, 2017, 12:40:30 PM kevin-kirspel Modify FREEBSD USB keyboard drivers for use in RTEMS 5-freebsd-12
(edit) @a7415b7   May 17, 2017, 12:40:29 PM kevin-kirspel Add USB UGEN support for RTEMS 5-freebsd-12
(edit) @3e7de30   May 17, 2017, 12:40:28 PM kevin-kirspel Add FREEBSD USB input device files 5-freebsd-12
(edit) @41d2784   May 17, 2017, 12:40:27 PM kevin-kirspel Add FREEBSD keyboard driver files 5-freebsd-12
(edit) @67de3b5   May 17, 2017, 12:40:26 PM kevin-kirspel Adding EVDEV FREEBSD files 5-freebsd-12
(edit) @817cbf7   May 12, 2017, 12:16:27 PM kevin-kirspel devfs: Fix some issues Fix issue with cdev private data usage with … 5-freebsd-12
(edit) @6afe73d   May 12, 2017, 12:16:26 PM kevin-kirspel Updating scripts for USB Serial Drivers 5-freebsd-12
(edit) @534017c   May 12, 2017, 12:16:25 PM kevin-kirspel Adding USB Serial test 5-freebsd-12
(edit) @5040ee5   May 12, 2017, 12:16:24 PM kevin-kirspel Update USB Serial Driver for use with RTEMS 5-freebsd-12
(edit) @746d74b   May 12, 2017, 12:16:23 PM kevin-kirspel Add USB headers to support USB Serial drivers 5-freebsd-12
(edit) @286c391   May 12, 2017, 12:16:22 PM kevin-kirspel Adding FREEBSD USB Serial Drivers 5-freebsd-12
(edit) @9d52d91   May 4, 2017, 12:28:01 PM kevin-kirspel Updating scripts for FREEBSD TTY support 5-freebsd-12
(edit) @333bfb6   May 4, 2017, 12:28:00 PM kevin-kirspel Adding test cases for FREEBSD termios support through tty 5-freebsd-12
(edit) @880a17c   May 4, 2017, 12:27:59 PM kevin-kirspel Adding RTEMS support for FREEBSD TTY 5-freebsd-12
(edit) @4a8f953   May 4, 2017, 12:27:58 PM kevin-kirspel Updating FREEBSD for tty support 5-freebsd-12
(edit) @567cce1   May 4, 2017, 12:27:57 PM kevin-kirspel Updating STTY command for use in RTEMS shell 5-freebsd-12
(edit) @f6c52e0   May 4, 2017, 12:27:56 PM kevin-kirspel Adding tty support files from FREEBSD tree 5-freebsd-12
(edit) @67cd18e   May 4, 2017, 12:27:55 PM kevin-kirspel Adding stty command files from FREEBSD tree 5-freebsd-12
(edit) @53914f2   Apr 27, 2017, 4:58:09 AM Chris Johns rc_conf: Move the defaultroute_delay to the defaultroute processing. … 5-freebsd-12
(edit) @4437573   Apr 27, 2017, 3:57:28 AM Chris Johns rc_conf: Add support for ifconfig_<interface>_alias[0-9]+. The … 5-freebsd-12
(edit) @43c65f5   Apr 26, 2017, 7:39:38 AM Chris Johns rc_conf: Do not use a local variable for the rc_conf context. If a … 5-freebsd-12
(edit) @145a821   Apr 26, 2017, 7:38:50 AM Chris Johns rc_conf: Minor clean up in the net services. 5-freebsd-12
(edit) @334019d   Mar 2, 2017, 3:45:31 PM Sebastian Huber nexus-devices: Use FDT for qoriq BSPs 5-freebsd-12
(edit) @de8a76d   Apr 4, 2017, 7:36:57 AM Sebastian Huber Update to FreeBSD head 2017-04-04 Git mirror commit … 5-freebsd-12
(edit) @3360232   Jan 17, 2017, 11:50:11 AM Sebastian Huber Enable bridging by default 5-freebsd-12
(edit) @0395c5d   Apr 3, 2017, 12:10:37 PM Sebastian Huber ppp: Update due to API changes 5-freebsd-12
(edit) @0732183   Mar 14, 2017, 6:15:34 AM Sebastian Huber Fix SOCK_CLOEXEC with socket() and socketpair() Remove SOCK_CLOEXEC … 5-freebsd-12
(edit) @5f3722a   Mar 8, 2017, 8:05:05 AM Sebastian Huber if_tsec: Enable FDT support 5-freebsd-12
(edit) @c1205ee   Mar 2, 2017, 3:29:11 PM Sebastian Huber FDT(4): Port to RTEMS 5-freebsd-12
(edit) @f0dd0c5   Mar 2, 2017, 3:28:14 PM Sebastian Huber FDT(4): Import from FreeBSD 5-freebsd-12
(edit) @517e229   Mar 6, 2017, 6:41:44 AM Sebastian Huber media01: Add cpuinfo command 5-freebsd-12
(edit) @18a623e   Mar 6, 2017, 11:07:32 AM Sebastian Huber Provide strtoq() and strtouq() 5-freebsd-12
(edit) @08f4881   Mar 6, 2017, 11:07:13 AM Sebastian Huber NETSTAT(1): Disable unused functions 5-freebsd-12
(edit) @6bc5190   Mar 6, 2017, 11:06:38 AM Sebastian Huber Disable unused pfil_try_rlock() 5-freebsd-12
(edit) @5268338   Mar 6, 2017, 11:06:19 AM Sebastian Huber Provide sbuf_hexdump() 5-freebsd-12
(edit) @57ba8ad   Mar 6, 2017, 11:05:54 AM Sebastian Huber Avoid kern_unsetenv() 5-freebsd-12
(edit) @ae9e46d   Mar 1, 2017, 9:49:05 AM Sebastian Huber Fix dw_mmc dependencies 5-freebsd-12
(edit) @045ff6e   Feb 21, 2017, 2:26:31 PM Sebastian Huber Add poll() and select() support for Termios 5-freebsd-12
(edit) @631fb98   Feb 21, 2017, 11:57:34 AM Sebastian Huber netshell01: Add license, fix format 5-freebsd-12
(edit) @5e093a5   Feb 22, 2017, 10:49:33 AM Sebastian Huber SLEEPQUEUE(9): Fix absolute timeouts The FreeBSD kernel timeouts are … 5-freebsd-12
(edit) @2a5d001   Feb 21, 2017, 7:34:58 AM Sebastian Huber C11/C++11 are the default for the RTEMS 4.12 GCC 5-freebsd-12
(edit) @284ff16   Feb 21, 2017, 7:34:09 AM Sebastian Huber Update due to configuration API changes 5-freebsd-12
(edit) @a739190   Feb 14, 2017, 10:55:18 AM Sebastian Huber SYSCTL(8): Fix command line option processing 5-freebsd-12
(edit) @9f2205a   Jan 30, 2017, 4:58:16 PM kevin-kirspel Port LPC32XX Ethernet and USB OHCI to RTEMS 5-freebsd-12
(edit) @803a495   Jan 30, 2017, 4:58:15 PM kevin-kirspel Adding LPC32XX ethernet driver support 5-freebsd-12
(edit) @5382f639   Jan 30, 2017, 4:58:24 PM kevin-kirspel Add support for LPC32XX cache 5-freebsd-12
(edit) @ea395a7   Jan 30, 2017, 4:58:18 PM kevin-kirspel Add ordered Nexus devices Add support for ordering the initialization … 5-freebsd-12
(edit) @2c4840f   Feb 13, 2017, 7:38:45 AM Sebastian Huber README.waf: Change BSP, add QEMU command line 5-freebsd-12
(edit) @1fd5083   Jan 31, 2017, 8:50:45 AM Sebastian Huber SLEEPQUEUE(9): Add wmesg to thread wait info 5-freebsd-12
(edit) @ee94f8a   Jan 31, 2017, 8:49:49 AM Sebastian Huber rtems-bsd-mutex: Use thread queue name 5-freebsd-12
(edit) @c6b85e8   Jan 17, 2017, 10:01:44 AM Christian.Mauderer userspace tools: Regenerate headers. 5-freebsd-12
(edit) @46d0378   Jan 17, 2017, 11:00:55 AM Christian.Mauderer userspace-header-gen: Don't generate first array size. 5-freebsd-12
(edit) @120caa6   Dec 14, 2016, 1:10:18 PM Christian.Mauderer testsuite/commands01: Add wlanstats call. 5-freebsd-12
(edit) @ecda181   Dec 9, 2016, 10:51:50 AM Christian.Mauderer freebsd/wlanstats: Port to FreeBSD. 5-freebsd-12
(edit) @d415406   Dec 9, 2016, 8:15:24 AM Christian.Mauderer freebsd/wlanstats: Import from FreeBSD. 5-freebsd-12
(edit) @d686d7b   Nov 30, 2016, 3:41:12 PM Christian.Mauderer wlan/run: Add firmware. 5-freebsd-12
(edit) @edf32f2   Nov 18, 2016, 10:13:11 AM Christian.Mauderer rtwn: Port to RTEMS 5-freebsd-12
(edit) @0cbb715   Nov 22, 2016, 9:41:47 AM Christian.Mauderer rtwn: Import from FreeBSD. 5-freebsd-12
(edit) @9bc41d0   Dec 12, 2016, 9:51:42 AM Christian.Mauderer lib80211/regdomain: Port to RTEMS. 5-freebsd-12
(edit) @bce3e5e   Nov 18, 2016, 1:59:56 PM Christian.Mauderer lib80211/regdomain: Import from FreeBSD. 5-freebsd-12
(edit) @20fa599   Nov 18, 2016, 10:11:27 AM Christian.Mauderer firmware-gen.py: Add script to generate firmware c files. 5-freebsd-12
(edit) @e9a8b5a   Nov 17, 2016, 8:15:27 AM Christian.Mauderer wlan ratectl and sta: Call init. 5-freebsd-12
(edit) @5c3223f   Nov 16, 2016, 3:29:17 PM Christian.Mauderer ifconfig/wlan, expat, lib80211: Port to RTEMS. 5-freebsd-12
(edit) @2389539   Nov 16, 2016, 2:02:20 PM Christian.Mauderer ifconfig/wlan, expat, lib80211: Import from FreeBSD. 5-freebsd-12
(edit) @59338de   Dec 12, 2016, 11:23:40 AM Christian.Mauderer Port USB and USB WLAN. 5-freebsd-12
