@91a7527
09/27/17 07:55:41 |
Sebastian Huber |
ffec: Support more rgmii variants
55-freebsd-126-freebsd-12
@95b102f
08/22/17 15:44:27 |
Sebastian Huber |
ffec: Port to RTEMS
@807b5bb
08/04/17 12:52:32 |
Sebastian Huber |
ffec: Import from FreeBSD
@b469163
09/22/17 12:40:51 |
Sebastian Huber |
Generalize bsp_fdt_map_intr()
Update #3090.
@c6f4aa6
09/22/17 07:41:20 |
Christian.Mauderer |
if_atsam: Allow fixed MII settings.
@0190cfd
09/22/17 07:41:19 |
if_atsam: Move statistics to sysctl.
@80a7fe6
09/22/17 07:41:18 |
if-atsam: Port to rtems-libbsd.
@b16eca9
09/22/17 07:41:17 |
rtemsbsd/if-atsam: Copy from RTEMS.
Copied from RTEMS commit …
@894c965
09/15/17 10:46:57 |
Sebastian Huber |
Support reference counting for file descriptors
Close #3132.
@666a568
08/25/17 12:23:18 |
Sebastian Huber |
Include missing <string.h> and <limits.h>
Fix warnings.
Update …
@34ff390
08/10/17 13:03:44 |
Sebastian Huber |
BUS_SPACE(9): 64-bit support
Update #3082.
@885ac75
08/23/17 08:54:04 |
Sebastian Huber |
openssl: Workaround for ARM-specific files
Update #3110.
@301ee6e
08/22/17 15:51:40 |
Sebastian Huber |
Remove strtoimax() and strtoumax()
This is now provided by Newlib.
@1f7037d
08/01/17 12:32:08 |
1473996754 |
Port openssl to RTEMS.
@6bed520
08/01/17 12:31:19 |
1473996754 |
Import openssl from FreeBSD.
@8d2dbd3
08/11/17 05:27:13 |
oss |
waf: Move glob operator to builder.py
This allows a finer decision …
@307b324
08/11/17 05:27:12 |
christian.mauderer |
waf_generator: Copy headers if necessary.
There are some cases, where …
@097ccba
08/01/17 07:21:32 |
1473996754 |
Enable the WEP encrypted WiFi?.
Now rtems can connnect WiFi? via WEP on …
@47169ea
08/01/17 07:21:31 |
1473996754 |
Port rtl8188eu driver to RTEMS.
Now USB dongle rtl8188eu can work as …
@6e328c3
07/28/17 06:44:52 |
Sebastian Huber |
KQUEUE(2): Add missing file handler
@17ab62c
07/28/17 06:42:42 |
Sebastian Huber |
PIPE(2): Add missing file handler
@0913210
07/28/17 06:36:33 |
Sebastian Huber |
SOCKET(2): Add missing file handler
@b43517b
07/18/17 06:31:03 |
Sebastian Huber |
ohci: Fix for BSP_USB_OTG_TRANSCEIVER_I2C_ADDR
@658f9b8
07/17/17 13:32:52 |
dev/rtwn: Import new files from FreeBSD.
@9121570
07/13/17 02:24:05 |
1473996754 |
Port am335x usb driver to RTEMS.
Add FDT and umass support for am335x …
@bd3c01a
07/13/17 02:24:04 |
1473996754 |
Import am335x usb driver file from FreeBSD.
@83574df
07/11/17 08:42:32 |
Sebastian Huber |
termios: Interrupt server API changes
@378b5c2
05/09/17 12:09:49 |
Sebastian Huber |
Use LOG_EMERG for panic()
@9128d20
05/10/17 12:39:19 |
Sebastian Huber |
libkern.h: Add ffsll()
@127296c
07/10/17 06:24:56 |
Sebastian Huber |
libkern.h: Avoid conflict with <strings.h>
@e3e88e1
06/26/17 07:36:56 |
Sebastian Huber |
Add CONTRIBUTING.md
@9db59c7
06/22/17 04:56:52 |
Sebastian Huber |
Remove unused inet_* weak references
This change requires a Newlib …
@b83012a
06/16/17 05:31:51 |
Sebastian Huber |
@3c967ca
06/08/17 11:15:12 |
Sebastian Huber |
Use <sys/lock.h> provided by Newlib
@0237319
05/23/17 11:18:31 |
Sebastian Huber |
Update due to Newlib 2017-06-07 changes
The following files are now …
@29c0cff
05/17/17 12:40:37 |
kevin-kirspel |
Update scripts to include support for input devices - USB Keyboard, …
@427ee3e
05/17/17 12:40:36 |
kevin-kirspel |
Redirect FREEBSD's kern_yield to RTEMS sched_yield
@15a4321
05/17/17 12:40:35 |
kevin-kirspel |
Add tests for USB keyboard and mouse as well as EVDEV
@9d4afe9
05/17/17 12:40:34 |
kevin-kirspel |
Add keyboard driver set variable
@e28a8d0
05/17/17 12:40:33 |
kevin-kirspel |
Add LPC32XX touch screen driver
@fb2aa6e
05/17/17 12:40:32 |
kevin-kirspel |
Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h
@18cf428
05/17/17 12:40:31 |
kevin-kirspel |
Modify FREEBSD EVDEV driver for use in RTEMS
@b51279b
05/17/17 12:40:30 |
kevin-kirspel |
Modify FREEBSD USB keyboard drivers for use in RTEMS
@a7415b7
05/17/17 12:40:29 |
kevin-kirspel |
Add USB UGEN support for RTEMS
@3e7de30
05/17/17 12:40:28 |
kevin-kirspel |
Add FREEBSD USB input device files
@41d2784
05/17/17 12:40:27 |
kevin-kirspel |
Add FREEBSD keyboard driver files
@67de3b5
05/17/17 12:40:26 |
kevin-kirspel |
Adding EVDEV FREEBSD files
@817cbf7
05/12/17 12:16:27 |
kevin-kirspel |
devfs: Fix some issues
Fix issue with cdev private data usage with …
@6afe73d
05/12/17 12:16:26 |
kevin-kirspel |
Updating scripts for USB Serial Drivers
@534017c
05/12/17 12:16:25 |
kevin-kirspel |
Adding USB Serial test
@5040ee5
05/12/17 12:16:24 |
kevin-kirspel |
Update USB Serial Driver for use with RTEMS
@746d74b
05/12/17 12:16:23 |
kevin-kirspel |
Add USB headers to support USB Serial drivers
@286c391
05/12/17 12:16:22 |
kevin-kirspel |
Adding FREEBSD USB Serial Drivers
@9d52d91
05/04/17 12:28:01 |
kevin-kirspel |
Updating scripts for FREEBSD TTY support
@333bfb6
05/04/17 12:28:00 |
kevin-kirspel |
Adding test cases for FREEBSD termios support through tty
@880a17c
05/04/17 12:27:59 |
kevin-kirspel |
Adding RTEMS support for FREEBSD TTY
@4a8f953
05/04/17 12:27:58 |
kevin-kirspel |
Updating FREEBSD for tty support
@567cce1
05/04/17 12:27:57 |
kevin-kirspel |
Updating STTY command for use in RTEMS shell
@f6c52e0
05/04/17 12:27:56 |
kevin-kirspel |
Adding tty support files from FREEBSD tree
@67cd18e
05/04/17 12:27:55 |
kevin-kirspel |
Adding stty command files from FREEBSD tree
@53914f2
04/27/17 04:58:09 |
Chris Johns |
rc_conf: Move the defaultroute_delay to the defaultroute processing.
@4437573
04/27/17 03:57:28 |
Chris Johns |
rc_conf: Add support for ifconfig_<interface>_alias[0-9]+.
The …
@43c65f5
04/26/17 07:39:38 |
Chris Johns |
rc_conf: Do not use a local variable for the rc_conf context.
If a …
@145a821
04/26/17 07:38:50 |
Chris Johns |
rc_conf: Minor clean up in the net services.
@334019d
03/02/17 15:45:31 |
Sebastian Huber |
nexus-devices: Use FDT for qoriq BSPs
@de8a76d
04/04/17 07:36:57 |
Sebastian Huber |
Update to FreeBSD head 2017-04-04
Git mirror commit …
@3360232
01/17/17 11:50:11 |
Sebastian Huber |
Enable bridging by default
@0395c5d
04/03/17 12:10:37 |
Sebastian Huber |
ppp: Update due to API changes
@0732183
03/14/17 06:15:34 |
Sebastian Huber |
Fix SOCK_CLOEXEC with socket() and socketpair()
Remove SOCK_CLOEXEC …
@5f3722a
03/08/17 08:05:05 |
Sebastian Huber |
if_tsec: Enable FDT support
@c1205ee
03/02/17 15:29:11 |
Sebastian Huber |
FDT(4): Port to RTEMS
@f0dd0c5
03/02/17 15:28:14 |
Sebastian Huber |
FDT(4): Import from FreeBSD
@517e229
03/06/17 06:41:44 |
Sebastian Huber |
media01: Add cpuinfo command
@18a623e
03/06/17 11:07:32 |
Sebastian Huber |
Provide strtoq() and strtouq()
@08f4881
03/06/17 11:07:13 |
Sebastian Huber |
NETSTAT(1): Disable unused functions
@6bc5190
03/06/17 11:06:38 |
Sebastian Huber |
Disable unused pfil_try_rlock()
@5268338
03/06/17 11:06:19 |
Sebastian Huber |
Provide sbuf_hexdump()
@57ba8ad
03/06/17 11:05:54 |
Sebastian Huber |
Avoid kern_unsetenv()
@ae9e46d
03/01/17 09:49:05 |
Sebastian Huber |
Fix dw_mmc dependencies
@045ff6e
02/21/17 14:26:31 |
Sebastian Huber |
Add poll() and select() support for Termios
@631fb98
02/21/17 11:57:34 |
Sebastian Huber |
netshell01: Add license, fix format
@5e093a5
02/22/17 10:49:33 |
Sebastian Huber |
SLEEPQUEUE(9): Fix absolute timeouts
The FreeBSD kernel timeouts are …
@2a5d001
02/21/17 07:34:58 |
Sebastian Huber |
C11/C++11 are the default for the RTEMS 4.12 GCC
@284ff16
02/21/17 07:34:09 |
Sebastian Huber |
Update due to configuration API changes
@a739190
02/14/17 10:55:18 |
Sebastian Huber |
SYSCTL(8): Fix command line option processing
@9f2205a
01/30/17 16:58:16 |
kevin-kirspel |
Port LPC32XX Ethernet and USB OHCI to RTEMS
@803a495
01/30/17 16:58:15 |
kevin-kirspel |
Adding LPC32XX ethernet driver support
@5382f639
01/30/17 16:58:24 |
kevin-kirspel |
Add support for LPC32XX cache
@ea395a7
01/30/17 16:58:18 |
kevin-kirspel |
Add ordered Nexus devices
Add support for ordering the initialization …
@2c4840f
02/13/17 07:38:45 |
Sebastian Huber |
README.waf: Change BSP, add QEMU command line
@1fd5083
01/31/17 08:50:45 |
Sebastian Huber |
SLEEPQUEUE(9): Add wmesg to thread wait info
@ee94f8a
01/31/17 08:49:49 |
Sebastian Huber |
rtems-bsd-mutex: Use thread queue name
@c6b85e8
01/17/17 10:01:44 |
userspace tools: Regenerate headers.
@46d0378
01/17/17 11:00:55 |
userspace-header-gen: Don't generate first array size.
@120caa6
12/14/16 13:10:18 |
testsuite/commands01: Add wlanstats call.
@ecda181
12/09/16 10:51:50 |
freebsd/wlanstats: Port to FreeBSD.
@d415406
12/09/16 08:15:24 |
freebsd/wlanstats: Import from FreeBSD.
@d686d7b
11/30/16 15:41:12 |
wlan/run: Add firmware.
@edf32f2
11/18/16 10:13:11 |
rtwn: Port to RTEMS
@0cbb715
11/22/16 09:41:47 |
rtwn: Import from FreeBSD.
