@5b4394f
05/06/16 19:40:49 |
Sebastian Huber |
Add namespace support for kvm
55-freebsd-126-freebsd-12freebsd-9.3
@5b1f20b
05/06/16 19:22:38 |
Sebastian Huber |
Rename files for kernel namespace script
This makes it easier to …
@81e5ff4
05/06/16 12:49:15 |
Sebastian Huber |
Add kernel namespace exception for mbstat
@edb5e4b
05/06/16 12:32:58 |
Sebastian Huber |
Add kernel namespace exceptions
These names correspond to sysctls.
@f9a697a
05/06/16 12:32:28 |
Sebastian Huber |
media01: Add sysctl command
@b8f127e
05/06/16 12:10:40 |
Sebastian Huber |
Update kernel namespace
@356f59c
05/06/16 10:16:19 |
Sebastian Huber |
kvprintf: Add support for %m
@54a577d
05/04/16 11:04:42 |
Sebastian Huber |
subr_prf.c: Port to RTEMS
@d4402dd
05/04/16 11:20:45 |
Sebastian Huber |
bcd.c: Import from FreeBSD
@469db42
05/04/16 10:51:55 |
Sebastian Huber |
subr_prf.c: Import from FreeBSD
@cf72971
05/06/16 11:28:25 |
Sebastian Huber |
README.waf: Make set-up steps self contained
@b39854a
05/06/16 09:10:12 |
Sebastian Huber |
README.waf: Add steps to clone and bootstrap RTEMS
@ff6534b
05/06/16 08:26:04 |
Sebastian Huber |
README.waf: Master branch must use 4.12
@4835d26
05/06/16 08:25:31 |
Sebastian Huber |
README.waf: Typo
@28c973a
05/06/16 07:31:20 |
Sebastian Huber |
Add "How to import code from FreeBSD"
@0f5dd1c
05/06/16 05:27:25 |
Sebastian Huber |
Add script to create the kernel namespace header
@ee9991f
05/06/16 06:55:35 |
Sebastian Huber |
Partially revert 27aedffc1bd8e41f4e06a3326a5b95c54ca38b79
@ffbac33
05/06/16 06:04:51 |
Sebastian Huber |
Revert "Move network-config.h to the top of the testsuite include …
@542c981
05/06/16 05:57:46 |
Sebastian Huber |
ZONE(9): Fix mp_maxid definition
@a51d0fea
05/06/16 05:44:21 |
Chris Johns |
Move network-config.h to the top of the testsuite include path.
@83eb07c
05/06/16 05:06:08 |
Chris Johns |
Add sbin/sysctl
@c60deba
05/06/16 05:00:32 |
Chris Johns |
Fix sysctl support.
@7a79eec
05/06/16 04:40:12 |
Chris Johns |
The maxid is not the number of cpus.
@27aedffc
05/04/16 09:45:19 |
Sebastian Huber |
default-network-init.h: Fix warnings
@e58b898
04/28/16 08:29:55 |
Sebastian Huber |
telnetd: Use syslog() instead of printk()
@5338089
05/04/16 06:24:11 |
Chris Johns |
Fix coding to be CamelCase.
@4b127e7
05/04/16 06:01:08 |
Chris Johns |
Add RealTek? Gig PHY.
@a1a2e10
05/04/16 06:00:15 |
Chris Johns |
Add tcpdump to the test shell commands.
@1e8c93c
05/04/16 05:59:16 |
Chris Johns |
Add some doco on reverse and forward movement of the code.
@f478e3c
05/04/16 05:58:25 |
Chris Johns |
Add sys/rpc so it is installed.
@f3f816c
04/28/16 03:34:11 |
Chris Johns |
Add nexus devices for default-init.
@b8d1fe0
04/27/16 03:22:04 |
Chris Johns |
pc386: Add RealTek? network driver to the nexus bus.
@7b8f336
04/27/16 03:21:20 |
Chris Johns |
Remove debug output.
@4e07ea5
04/27/16 12:18:36 |
Sebastian Huber |
Prevent invalid optimizations for linker sets
@33724a2
04/27/16 07:56:15 |
Sebastian Huber |
Delete unused services directory
@23c7ab4
04/27/16 07:52:58 |
Sebastian Huber |
Delete dummy IRQ support
Architectures and BSPs which want to use …
@5784e6d
04/27/16 07:45:26 |
Sebastian Huber |
rtems/bsd/bsd.h: Documentation
@3c7fdb2
04/27/16 02:11:31 |
Chris Johns |
libbsd: Remove sys/select.h and sys/_sigset.h.
@f1fcdba
04/27/16 02:03:17 |
Chris Johns |
waf: Refector the builder to work with Python3 and UTF-8 source files. …
@5b93cc8
04/26/16 13:00:44 |
Sebastian Huber |
Add root bus support functions
@5edcb9e
01/08/16 07:16:58 |
Sebastian Huber |
media01: Add telnetd
@00c8792
10/30/15 07:03:57 |
Sebastian Huber |
Initialize interrupt server early
This enables its use before the …
@55d372f
10/30/15 07:01:30 |
Sebastian Huber |
Declare flsll()
@fa69a12
10/30/15 07:00:59 |
Sebastian Huber |
Dummy PHOLD() and PRELE()
@5d37f0e
04/26/16 04:31:38 |
Chris Johns |
waf: Check for no FreeBSD options being supplied.
@7d0050d
04/25/16 09:24:22 |
Sebastian Huber |
Fix fp initializaiton in kern_sendit()
Bug introduced by …
@e1e10cd
04/23/16 07:37:27 |
Chris Johns |
waf: Add the ability to set FreeBSD options on the configure command …
@051ef30
04/20/16 08:22:39 |
Chris Johns |
waf: Move the generated content to libbsd_waf.py.
@5529f7d
04/18/16 12:50:50 |
Sebastian Huber |
swi01: Move include to avoid type conflict
@22257c7
04/18/16 12:50:39 |
Sebastian Huber |
Avoid use of cap_rights_t
@c5fde49
04/18/16 12:47:49 |
Sebastian Huber |
intrmask_t: Provide dummy type definition
@ce8c7bb
04/18/16 12:47:04 |
Sebastian Huber |
kvm: Include missing header file
@a438f52
04/18/16 12:46:23 |
Sebastian Huber |
fnv_hash.h: Disable unused 64-bit functions
@982f72f
04/18/16 12:45:19 |
Sebastian Huber |
syslog: Include missing header file
@87bff39
04/18/16 12:20:29 |
Sebastian Huber |
dhclient: Avoid SIZE_T_MAX
Use SIZE_MAX instead of SIZE_T_MAX to …
@68bf405
04/18/16 01:07:14 |
Chris Johns |
Update the rtems_waf submodule.
@00a7956
04/18/16 01:02:00 |
Chris Johns |
Remove the makefile generator.
@97c5024a
04/18/16 00:53:20 |
Chris Johns |
Add RTEMS version support, update all python to 2 and 3.
Add support …
@891a756
04/07/16 12:00:13 |
Sebastian Huber |
libkern.h: Deal with latest <stdlib.h> of Newlib
@42f085d
04/06/16 13:16:18 |
Sebastian Huber |
sys/time.h: Delete superfluous declaration
Provided by RTEMS …
@58c1bf6
04/06/16 12:55:56 |
Sebastian Huber |
rtems-bsd-mutex: Update due to API changes
@c5abeb5
04/06/16 12:54:32 |
Sebastian Huber |
rtems-bsd-mutex: Fix mtx_destroy()
@652b024
03/18/16 09:35:42 |
Sebastian Huber |
ftpd: Resolve function name conflict
Visible with Newlib …
@a336c46
03/14/16 08:25:04 |
Sebastian Huber |
Update due to Watchdog Handler changes
@96bf77b
02/02/16 07:04:33 |
Sebastian Huber |
Fix heap corruption in UNIX domain socket connect
Update #2558.
@9f81109
01/18/16 11:17:46 |
Sebastian Huber |
Update due to chain API changes
@c2864c2
01/08/16 07:17:38 |
Sebastian Huber |
Use Newlib provided <sys/select.h>
@c04e7c2
01/05/16 09:18:43 |
hselasky |
Fix for directly connected FULL or LOW speed USB devices.
Found …
@1061324
11/18/15 08:47:10 |
Sebastian Huber |
NETSTAT(1): Avoid use of uninitialized memory
@cf9836e
11/18/15 08:24:19 |
Sebastian Huber |
Add .exe extension to test programs
@eb3b5db
11/18/15 08:23:39 |
Sebastian Huber |
Fix for RTEMS provided <sys/priority.h>
@33d8f3c7
11/17/15 14:28:06 |
Sebastian Huber |
Use RTEMS provided <sys/priority.h>
@39ac918
11/17/15 14:24:49 |
Sebastian Huber |
Use RTEMS provided <sys/ttycom.h>
@2dd7b49
11/17/15 14:13:44 |
Sebastian Huber |
Use RTEMS provided <sys/sockio.h>
@25ce3e8
11/17/15 14:04:54 |
Sebastian Huber |
Use RTEMS provided <sys/mman.h>
@c9f679f
11/17/15 14:02:33 |
Sebastian Huber |
Use RTEMS provided <sys/filio.h>
@d5b64f2
11/17/15 13:42:28 |
Sebastian Huber |
Use RTEMS provided <sys/endian.h>
@dd96574
11/16/15 08:51:44 |
Sebastian Huber |
SOCKETPAIR(2): Port to RTEMS
@330f9886
11/16/15 06:32:51 |
Sebastian Huber |
Update rtems_waf module for msys2 support
@d639c30
11/13/15 12:03:17 |
Sebastian Huber |
Update rtems_waf module for Python 3 compatibility
@7385d4a
11/13/15 10:19:37 |
Sebastian Huber |
@a76483d
11/13/15 09:58:45 |
Sebastian Huber |
Use latest rtems_waf
@06d8316
11/12/15 12:16:25 |
Sebastian Huber |
testsuite/ppp01: Avoid build error on SMP
@c689915
11/12/15 12:12:22 |
Sebastian Huber |
Use optimization level -O2
@d6c6017
11/12/15 12:10:03 |
Sebastian Huber |
@ba44613
11/12/15 12:01:32 |
Sebastian Huber |
dwc_otg: Port to RTEMS
@c5a141a
11/12/15 12:01:25 |
Sebastian Huber |
dwc_otg: Import from FreeBSD trunk 2015-11-10
@02279d6
11/12/15 12:01:12 |
Sebastian Huber |
USB: Update to FreeBSD trunk 2015-11-10
@c164446
11/10/15 09:19:04 |
Sebastian Huber |
Rename kernel space log() to _bsd_log()
This avoids a conflict with …
@524990c
10/30/15 13:14:46 |
Sebastian Huber |
Provide ffs() and ffsl() via builtins
@293fefa
10/30/15 13:14:15 |
Sebastian Huber |
testsuite: Add bdbuf configuration
@ac45be9
10/30/15 11:45:01 |
Sebastian Huber |
media01: Add mount etc. commands
@59c9a5f
10/14/15 11:01:03 |
Sebastian Huber |
NSDISPATCH(3): Add proper nsparser.h
Update nsparser.h to fit with …
@e78b3dc
10/01/15 07:47:05 |
Sebastian Huber |
doc: Qemu network
@613c341
10/01/15 06:03:19 |
Sebastian Huber |
doc: Add Qemu network setup
@556a07c
09/30/15 14:06:22 |
Sebastian Huber |
DELAY(): Use rtems_counter_delay_nanoseconds()
@880d929
09/30/15 12:56:24 |
Sebastian Huber |
tests: Increase stack size for dhcpcd
On i386 with optimization …
@36a16f5c
09/30/15 12:52:57 |
Sebastian Huber |
i386: Quick and dirty hack to get PCI working
@b168f69
09/29/15 09:00:58 |
Sebastian Huber |
BUS_SPACE(9): Use FreeBSD files for i386 arch
@4cf8982
09/29/15 08:44:04 |
Sebastian Huber |
Avoid pci_cfgreg.h rename
