source: rtems-libbsd
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @59338de   12/12/16 11:23:40 Christian.Mauderer Port USB and USB WLAN. 55-freebsd-126-freebsd-12
(edit) @d145449   11/14/16 12:30:48 Christian.Mauderer Import USB and USB WLAN from FreeBSD. 55-freebsd-126-freebsd-12
(edit) @66eb143   12/12/16 12:09:09 Christian.Mauderer firmware: Port to RTEMS. 55-freebsd-126-freebsd-12
(edit) @2e8dd24   11/16/16 12:20:05 Christian.Mauderer firmware: Import from FreeBSD. 55-freebsd-126-freebsd-12
(edit) @efc782b   12/12/16 11:31:33 Christian.Mauderer Port IEEE 802.11. 55-freebsd-126-freebsd-12
(edit) @a241ea8   11/14/16 12:46:13 Christian.Mauderer Import IEEE 802.11 from FreeBSD. 55-freebsd-126-freebsd-12
(edit) @172f2ac   01/12/17 13:56:23 Sebastian Huber Use thread name support Update #2858. 55-freebsd-126-freebsd-12
(edit) @fb288fa   01/11/17 13:15:31 Sebastian Huber ROUTE(8): Disable routing socket timeout support FIXME: This reverts … 55-freebsd-126-freebsd-12
(edit) @f11bfc2   01/11/17 13:01:17 Sebastian Huber rtems-bsd-mutex: Add SMP lock debug support 55-freebsd-126-freebsd-12
(edit) @e5ef01e   01/11/17 10:52:41 Sebastian Huber rtems-bsd-mutex: Update due to API changes 55-freebsd-126-freebsd-12
(edit) @9e8ce9ae   01/10/17 13:41:23 Sebastian Huber pf: Some fixes after the update 55-freebsd-126-freebsd-12
(edit) @774f19f   01/10/17 13:40:29 Sebastian Huber devfs: Fix typo 55-freebsd-126-freebsd-12
(edit) @851722b   01/10/17 13:00:53 Sebastian Huber Declare feature_present() 55-freebsd-126-freebsd-12
(edit) @3dff21a   01/10/17 13:00:20 Sebastian Huber Remove obsolete PF files 55-freebsd-126-freebsd-12
(edit) @64c663c   01/10/17 07:04:58 Sebastian Huber ARP(8): Port to RTEMS 55-freebsd-126-freebsd-12
(edit) @246b61e   01/10/17 06:58:50 Sebastian Huber ARP(8): Import from FreeBSD 55-freebsd-126-freebsd-12
(edit) @0577772   01/09/17 13:47:04 Sebastian Huber Update to FreeBSD head 2017-01-09 Git mirror commit … 55-freebsd-126-freebsd-12
(edit) @75b706f   12/09/16 13:19:03 Sebastian Huber Update to FreeBSD head 2016-12-10 Git mirror commit … 55-freebsd-126-freebsd-12
(edit) @c4e89a9   11/10/16 12:52:08 Sebastian Huber VMSTAT(8): Port to RTEMS 55-freebsd-126-freebsd-12
(edit) @dba2dfc   11/10/16 12:25:27 Sebastian Huber VMSTAT(8): Import from FreeBSD 55-freebsd-126-freebsd-12
(edit) @2360b08   09/07/15 06:33:16 Sebastian Huber if_dwc: Invalidate read buffer again This may prevent problems in … 55-freebsd-126-freebsd-12
(edit) @3ef41be   01/10/17 08:16:17 Sebastian Huber if_dwc: Use explicit cache operations 55-freebsd-126-freebsd-12
(edit) @0436d64   01/09/17 10:43:40 Sebastian Huber if_dwc: Reduce DMA descriptor count 55-freebsd-126-freebsd-12
(edit) @88dad3b   01/09/17 10:41:24 Sebastian Huber if_dwc: Use rtems_bsd_get_mac_address() 55-freebsd-126-freebsd-12
(edit) @f8ed8cd   03/26/15 14:21:07 Sebastian Huber if_dwc: Add nexus device support 55-freebsd-126-freebsd-12
(edit) @c07da01   09/07/15 06:34:34 Sebastian Huber if_dwc: Fix a possible interrupt starvation 55-freebsd-126-freebsd-12
(edit) @051b634   04/07/15 11:54:23 Sebastian Huber if_dwc: Avoid mbuf use after free 55-freebsd-126-freebsd-12
(edit) @b99c023   03/30/15 12:30:04 Sebastian Huber if_dwc: Checksum offload 55-freebsd-126-freebsd-12
(edit) @5deeb69   03/27/15 13:16:40 Sebastian Huber if_dwc: Avoid tx defrag if possible Drop packets in case of resource … 55-freebsd-126-freebsd-12
(edit) @d9ff828   03/30/15 09:51:36 Sebastian Huber if_dwc: Simplify tx desc setup 55-freebsd-126-freebsd-12
(edit) @9410212   03/30/15 07:51:18 Sebastian Huber if_dwc: Fix transmit starvation 55-freebsd-126-freebsd-12
(edit) @6cd057d   01/10/17 07:52:14 Sebastian Huber if_dwc: Fix IFCOUNTER_IPACKETS statistics Input packets are counted … 55-freebsd-126-freebsd-12
(edit) @ec2e4b1   01/09/17 12:24:33 Sebastian Huber if_dwc: Fix IFCOUNTER_OPACKETS statistics Output packets are counted … 55-freebsd-126-freebsd-12
(edit) @e392c989   03/27/15 10:14:44 Sebastian Huber if_dwc: Move interrupt handler install 55-freebsd-126-freebsd-12
(edit) @46f0b8b   01/09/17 08:41:29 Sebastian Huber Enable multi-cast routing support 55-freebsd-126-freebsd-12
(edit) @95a3ba8   01/09/17 07:50:55 Sebastian Huber NETSTAT(1): Fix name list initialization 55-freebsd-126-freebsd-12
(edit) @b86b097   10/24/16 11:30:37 Sebastian Huber Fix warings in <sys/seq.h> 55-freebsd-126-freebsd-12
(edit) @11750f1   10/24/16 11:14:35 Sebastian Huber Fix warnings in <sys/refcount.h> 55-freebsd-126-freebsd-12
(edit) @2956924   10/24/16 10:00:55 Sebastian Huber Fix atomic ops in <sys/buf_ring.h> 55-freebsd-126-freebsd-12
(edit) @c40e45b   10/07/16 13:10:20 Sebastian Huber Update to FreeBSD head 2016-08-23 Git mirror commit … 55-freebsd-126-freebsd-12
(edit) @8c0eeba   08/10/16 13:20:42 Christian.Mauderer userspace-header-gen.py: Simplify program ports 55-freebsd-126-freebsd-12
(edit) @750b2d4   01/09/17 13:54:21 Sebastian Huber Workaround for <sys/event.h> update 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @fbfdc2b   12/23/16 14:01:43 Sebastian Huber Update due to Newlib 2.5.0 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b1580fb   12/21/16 19:01:28 kevin-kirspel PIPE(2): Port to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6959fac   12/21/16 19:01:26 kevin-kirspel PIPE(2): Import from FreeBSD 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @546b38d   12/15/16 08:43:23 Sebastian Huber Add BRIDGE(4) support to configuration 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e3dac66   12/07/16 06:15:02 Sebastian Huber pfctl: Update due to linker set API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @afda2c7   11/29/16 05:13:52 Chris Johns debugger: Set the fd to -1 to indicate being disconnected. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f7a4107   11/28/16 03:23:15 Chris Johns Add a RTEMS Debugger TCP remote transport. The patch also adds … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @269b559   11/24/16 11:01:28 Sebastian Huber ftpd: Use floating-point tasks due to syslog() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @cfec446   11/23/16 13:17:25 Sebastian Huber SLEEPQUEUE(9): Properly remove timeout timer 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @616ffa96   11/23/16 13:16:05 Sebastian Huber Use _Thread_Dispatch_direct() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @87e3b46   11/23/16 13:13:48 Sebastian Huber rtems-bsd-mutex: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @34545ad   10/25/16 08:19:23 Sebastian Huber Use -Wno-pointer-sign Pointer sign warnings are quite common in … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b01ce52   11/10/16 12:25:58 Sebastian Huber Fix errno redefined warning 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c418b7a   11/10/16 13:58:58 Sebastian Huber Fix mbuf_jumbo_alloc() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7614758   11/14/16 09:17:55 Sebastian Huber Revert "rtems-kernel-page: Panic on recursive reclaim" This attempt … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e49f301   11/10/16 09:49:43 Sebastian Huber Fix default network memory configuration 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6517105   11/10/16 09:38:04 Sebastian Huber rtems-kernel-page: Panic on recursive reclaim 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6254bf4   11/09/16 09:26:17 Sebastian Huber SDHCI(4): Delete Delete heavily modified SDHCI(4) support. It must … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c00312a   10/24/16 07:05:34 Sebastian Huber Provide O_CLOEXEC 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @8090fa0   10/24/16 07:01:28 Sebastian Huber Provide CLOCK_UPTIME 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @71a0436   10/24/16 11:29:03 Sebastian Huber Add thread fences to <machine/atomic.h> 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @cc8f00d   11/09/16 08:56:01 Sebastian Huber Fix warnings for linker sets 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @520ab22   06/28/16 06:35:06 Sebastian Huber Modify rtems_bsd_set_vprintf_handler() Return previous … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6ff1baa   10/27/16 06:30:37 Sebastian Huber Add empty <machine/_kernel_lock.h> 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @8b0bcb8   11/09/16 07:53:20 Sebastian Huber rtems-bsd-mutex: Optimize Inline SMP lock acquire/release. Avoid … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @617dc0f   11/09/16 07:15:22 Sebastian Huber Really robust linker sets The previous attempt to fix this issue … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @0b08247   11/03/16 10:18:27 Sebastian Huber rtems-bsd-mutex: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ed499fa   10/26/16 12:38:23 Sebastian Huber More robust linker sets See also: … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @cf88298   10/26/16 12:14:05 Sebastian Huber Prepare copyiniov() for FreeBSD update 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ade8f56   10/26/16 12:04:36 Sebastian Huber devfs: Fix includes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @632e278   10/21/16 09:05:29 Christian.Mauderer rtemsbsd: Add reallocf to rtems_bsd_program. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @0ba4197   10/24/16 06:07:56 Sebastian Huber Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h> 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f0aaa04   10/21/16 13:38:58 Sebastian Huber Provide CLOCK_MONOTONIC_FAST 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7eb064c   10/24/16 06:06:27 Sebastian Huber Make <sys/proc.h> self-sufficient 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @390e133   10/24/16 06:02:13 Sebastian Huber Make <machine/atomic.h> available to user space Enables use of … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @95a12a2   10/07/16 07:01:02 Sebastian Huber Fix FreeBSD source file reverse conversion 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a9d38f5   10/07/16 05:24:30 Sebastian Huber Remove AppleTalk? support Prepare update to FreeBSD 11. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @40f202da   10/13/16 05:21:48 Sebastian Huber pfctl: Update due to linker set API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f5f9e16   10/07/16 05:24:02 Sebastian Huber nexus-devices: Support arm/lpc24xx 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @335bb97   10/07/16 05:23:33 Sebastian Huber testsuite: Fix warnings 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e11f8e3   10/07/16 05:09:48 Sebastian Huber ohci: Fixes due to USB stack update 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e3881ee   09/28/16 13:34:46 Sebastian Huber nexus-devices: Add arm/atsamv BSP section 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ec5b97b   09/28/16 13:33:50 Sebastian Huber usb01: Simplify test program 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @8eb8883   09/28/16 13:00:00 Sebastian Huber Split rtemsbsd/rtems/rtems-program.c This improves garbage collection … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @10e9e05   09/28/16 12:46:55 Sebastian Huber Split rtems-bsd-kernel-program.c Separate kernel and user space parts. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @299d4ba   09/28/16 12:39:32 Sebastian Huber Build rtems-bsd-shell-pfctl.c 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @d9fe061   09/28/16 11:23:16 Sebastian Huber Split rtems-bsd-shell-netcmds.c This improves garbage collection by … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @2c563ed   09/23/16 07:54:49 Sebastian Huber if_ffec_mcf548x.c: Fix include order 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @02d344f4   09/22/16 05:22:42 Sebastian Huber rtems-bsd-mutex: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @2c44b51   09/22/16 05:21:54 Sebastian Huber Use _Thread_Get_priority() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7f75b56   09/07/16 13:43:44 Sebastian Huber Port getdomainname() to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a439410   09/07/16 13:42:36 Sebastian Huber Import getdomainname() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @8e65e1b   08/23/16 13:51:45 Sebastian Huber usb: Update to FreeBSD trunk 2016-08-23 FreeBSD trunk, 2016-08-23, … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7c77211   08/23/16 13:37:01 Sebastian Huber doc: Update rules to modify FreeBSD code 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @0c24e06   08/23/16 12:22:26 Sebastian Huber mmc: Update to FreeBSD trunk 2016-08-23 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a971614   08/19/16 09:18:52 Sebastian Huber doc: Update rules to modify FreeBSD code 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @69355c3   08/16/16 06:52:07 Christian.Mauderer devfs: Add some notes on implementation. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6634edb   08/16/16 06:52:06 Christian.Mauderer devfs: Create path. 55-freebsd-126-freebsd-12freebsd-9.3
