@41880b2
04/18/12 15:40:39 |
Sebastian Huber |
Move M_IOV to reduce dependencies
4.1155-freebsd-126-freebsd-12freebsd-9.3
@29c954f
04/18/12 15:30:25 |
Jennifer Averett |
Added empty method for pgsigio.
@1e3e818
04/18/12 15:02:17 |
Sebastian Huber |
Hide device sysctl and resource functions
@b086b5c
04/18/12 15:27:54 |
Sebastian Huber |
Use format of other RTEMS machine header files
@e2b2fc6
04/18/12 15:22:44 |
Sebastian Huber |
Remove superfluous include, format
@2f52893
04/18/12 15:14:02 |
Sebastian Huber |
Move bswap64()
Add copyright notice of FreeBSD …
@89466ac
04/18/12 15:16:37 |
Jennifer Averett |
Removed rtems-bsd-subr.c
@0287267
04/18/12 15:03:59 |
Jennifer Averett |
Moved uio_yield implementation into bsd file.
@f084ec7
04/18/12 14:48:49 |
Joel Sherrill |
Add generic implementation of bswap64
@d8c5df7
04/18/12 14:46:21 |
Jennifer Averett |
Moved rtems-bsd-cyclecount.c to cpu.h
@2da0777
04/18/12 12:59:28 |
Sebastian Huber |
Add BUS_DMA(9) support for mbufs
@60ed795
04/18/12 12:55:02 |
Sebastian Huber |
Hide most error number definitions
@e3501b5
04/18/12 12:00:54 |
Sebastian Huber |
Add parts of the UCRED(9) implementation
@c2b6395
04/18/12 11:58:05 |
Sebastian Huber |
Removed file
In this file the copyright information was wrong. It …
@c03e095
04/18/12 09:23:38 |
Sebastian Huber |
Add "Core FreeBSD APIs and RTEMS Replacements"
@01e57a9
04/17/12 19:43:48 |
Jennifer Averett |
Added rtems version of get_cyclecount().
@b6c71ea
04/17/12 19:31:21 |
Jennifer Averett |
Added chgsbsize() method.
@67b8f0a
04/17/12 18:59:34 |
Jennifer Averett |
Added rtems unique version of uio_yield()
@785af86
04/17/12 18:32:56 |
Jennifer Averett |
Added back in a couple of methods.
@90cdcae
04/17/12 18:16:36 |
Jennifer Averett |
Commented out unused methods to resolve linker errors.
@400b74d
04/17/12 15:19:55 |
Sebastian Huber |
Fix NoConverter? class inheritance
@508747e
04/17/12 15:19:30 |
Sebastian Huber |
Add missing header file
@14f35e6
04/17/12 15:08:05 |
Sebastian Huber |
@837df26
04/17/12 14:54:29 |
Sebastian Huber |
Add PCI and PCIB interface files
@68df607
04/17/12 14:07:34 |
Sebastian Huber |
Use MIPS in_cksum.c for SPARC
@c57eebb
04/17/12 14:39:46 |
Jennifer Averett |
Added method to help resolve linker issue.
@d558a43
04/17/12 14:38:54 |
Jennifer Averett |
Added methods to resolve linker errors.
@30e98a2
04/17/12 14:00:18 |
Jennifer Averett |
Added variables from kern_environment to remove linker errors.
@a67b3a9
04/17/12 12:43:27 |
Sebastian Huber |
Include proper headers, format and use vprintk()
@4794481
04/17/12 09:39:36 |
Sebastian Huber |
in_cksum() support for SPARC
@edd344a
04/17/12 09:54:31 |
Sebastian Huber |
Simplify
@e4b9989
04/16/12 18:22:45 |
Jennifer Averett |
Addded resource_XXX methods to resolve linker issues.
@d9e838b
04/16/12 17:39:58 |
Jennifer Averett |
Added get_cyclecount() method.
@8f6d129
04/16/12 17:27:49 |
Jennifer Averett |
moved taskqueue_enqueue_fast from a define to a method to resolve …
@0ff1733
04/16/12 17:12:09 |
Jennifer Averett |
Added calls to force the linkage of RealTek? and EtherExpress? Nics.
@6053efd
04/16/12 17:04:31 |
Jennifer Averett |
Added thread0 variable to resolve linker error.
@a7bbe3f
04/16/12 16:58:01 |
Jennifer Averett |
Added _rw_try_upgrade & _rw_try_upgrade to resolve linker errors.
@a824229
04/16/12 16:50:33 |
Jennifer Averett |
Forgot to add Makefile and freebsd-to-rtems.py to rmlock commit.
@c4117bb
04/16/12 16:00:02 |
Joel Sherrill |
Add libkern/fls.c for fls() - Find last bit set
@459afb1
04/16/12 14:10:35 |
Jennifer Averett |
Implemented a version of rmlock using rwlock.
@362782e
04/16/12 10:43:49 |
Sebastian Huber |
Explain why we need the interrupt server
@8a4f070
04/16/12 10:23:55 |
Sebastian Huber |
Elaborate RTEMS libbsd initialization
@a3d2498
04/16/12 09:57:45 |
Sebastian Huber |
Add SVN checkout command description
@63a3476
04/06/12 17:29:02 |
Jennifer Averett |
Added in knote_enqueue.
@251480e
04/05/12 20:24:27 |
Jennifer Averett |
Added in a header file and some defines to resolve linker errors.
@e664034
04/05/12 20:07:16 |
Jennifer Averett |
Comment out unused methods that were generating linker errors.
@508e3df
04/05/12 19:13:24 |
Jennifer Averett |
Added uipc_XXx methods.
@74109fe
04/05/12 19:02:46 |
Joel Sherrill |
link01 - Add .gitnore
@10c59c7
04/05/12 19:01:54 |
Joel Sherrill |
link01 - Produce undefined list from relocatable and link errors
This …
@c613894
04/05/12 18:42:26 |
Jennifer Averett |
Added pci_XXX methods.
@39292ce
04/05/12 18:04:52 |
Jennifer Averett |
Added tcp_hc_XXX methods.
@2385258
04/05/12 17:49:15 |
Jennifer Averett |
Added rmon_XXX methods.
@7730088
04/05/12 17:42:40 |
Jennifer Averett |
Added sbuf_XXX methods.
@b783f05
04/05/12 17:06:30 |
Jennifer Averett |
Added prison_check_af and jailed methods.
@aa34b6b
04/05/12 16:43:32 |
Joel Sherrill |
link01 - add undefined.txt to CLEAN_ADDITIONS
@3c05977
04/05/12 15:55:30 |
Jennifer Averett |
Added knlist_XXX and knote_XXX methods.
@b2e05ef
04/05/12 15:00:36 |
Jennifer Averett |
Added ratecheck methods as part of RealTek? Nic integration.
@a792664
04/05/12 13:24:45 |
Joel Sherrill |
link01 - Add list of undefined symbols
@c4f90c7
04/04/12 22:57:47 |
Joel Sherrill |
Add SYSCTL_NODE(_security,...,_bsd,...)
@772d929
04/04/12 22:47:18 |
Joel Sherrill |
Add _ALIGN macro based on one in libmisc/shell/fts.c
@dc4c490
04/04/12 22:38:25 |
Joel Sherrill |
Add tvtohz() implementation in new file
@493efad
04/04/12 21:31:31 |
Joel Sherrill |
Add hogticks
@ed3790d
04/04/12 21:31:00 |
Joel Sherrill |
Enable copyinuio
@00ded52
04/04/12 20:07:21 |
Joel Sherrill |
kern_subr.c - Enable uiomove for rtems
@5d21d7a
04/04/12 20:05:02 |
Joel Sherrill |
rtems-bsd-sync.c: Add RTEMS_VIOLATE_KERNEL_VISIBILITY
@1747b0c
04/04/12 19:33:16 |
Jennifer Averett |
Added _bsd_realloc method.
@6618e3e
04/04/12 19:10:52 |
Jennifer Averett |
Added empty prison_check method to resolve linker error with RealTek? Nic.
@d75b748
04/04/12 19:08:31 |
Jennifer Averett |
Added cr_XXX methods to resolve linker errors with RealTek? Nic.
@8960780
04/02/12 17:13:22 |
Jennifer Averett |
Add methods to reaolve linker issues.
@6f539f7
04/02/12 15:23:40 |
Jennifer Averett |
@ce0b530
04/02/12 14:30:23 |
Jennifer Averett |
Add globals to resolve linker conflicts.
@761f597d
04/02/12 13:57:05 |
Jennifer Averett |
Added two prison methods to resolve linker errors.
@e3f2b51
03/30/12 16:49:26 |
Joel Sherrill |
Add freebsd/machine/elf.h as empty. Improve message for empty file.
@4ac7089
03/30/12 16:43:45 |
Joel Sherrill |
Make verbose print again for copying files
@d195d2d
03/30/12 16:36:33 |
Jennifer Averett |
Added methods back in to resolve link issues.
@962b220
03/30/12 16:31:00 |
Jennifer Averett |
Added Methods and stub file to remove warnings when linking with …
@777b87c
03/30/12 15:04:36 |
Jennifer Averett |
Resolve linker error with RealTek? Nic (forgot file arc4random)
@f6289b3
03/30/12 14:57:23 |
Jennifer Averett |
Resolve linker error with RealTek? Nic (arc4random)
@393a859
03/30/12 14:32:07 |
Jennifer Averett |
Add methods back in that were needed to link with RealTek? Nic.
@134df2e
03/29/12 17:46:14 |
Jennifer Averett |
Resolve warnings from taskqueue when linking with RealTek? Nic.
@d1528ff
03/28/12 16:40:08 |
Jennifer Averett |
Added log and prison methods to resolve linker errors for RealTek? Nic.
@336762e
03/27/12 22:07:19 |
Joel Sherrill |
Remove dummy symbols in link01 test
+ add symbol where needed
@55fbb18
03/27/12 20:26:10 |
Jennifer Averett |
Added empty/defaulted prison methods to for linking RealTek? Nic.
@334957b
03/27/12 20:00:44 |
Jennifer Averett |
Moved prison_free and prison_hold to rtems-bsd-jail.c
@884213d
03/27/12 19:06:16 |
Jennifer Averett |
Forgot to include Makefile in last commit.
@27ae2dfc
03/27/12 18:58:38 |
Jennifer Averett |
Added kern_mib.c to resolve linker error when pulling in RealTek? Nic.
@00ee241
03/27/12 18:51:45 |
Joel Sherrill |
Add example on SYSCTL_NODE expansion for _bsd_sysctlnet_children
@9fe8c97
03/27/12 18:42:16 |
Jennifer Averett |
Commented out methods to prevent linker errors.
Removed methods that …
@c976506
03/27/12 14:21:04 |
Joel Sherrill |
Add bootverbose
@4854583
03/27/12 13:53:56 |
Joel Sherrill |
Address prototype mismatch in FreeBSD code. Need to report upstream.
@2a478f7
03/26/12 18:37:01 |
Joel Sherrill |
sys/vnode.h added as empty file
@d1822e5
03/27/12 09:27:55 |
Sebastian Huber |
testsuite/usb01: Support multiple BSPs
@a52104c
03/26/12 14:51:49 |
julien.delange |
e1000 driver now compiles with fewer modifications
- Change some …
@8dce372
03/26/12 08:19:30 |
Sebastian Huber |
Use new block device API
@918638f
03/26/12 08:15:09 |
Sebastian Huber |
New USB device specific controller files
@96dca8a
03/23/12 20:07:00 |
julien.delange |
Use new fsync_or_fdatasync default
@3be460f
03/23/12 18:20:57 |
Jennifer Averett |
Added comments on how to force the inclusion of the RealTek? and …
@6f0e047
03/23/12 18:18:57 |
Jennifer Averett |
Added maxfiles, maxfilesperproc, cold, and dpcpu_off variables.
@592435f
03/23/12 18:11:22 |
Jennifer Averett |
Merge branch 'master' of ssh://git.rtems.org/data/git/rtems-libbsd
@129579c
03/23/12 18:09:05 |
Jennifer Averett |
Add M_IP6... symbols to resolve linker errors using the RealTek? Nic.
