@3f23fcd
11/16/17 07:15:37 |
Sebastian Huber |
LOCKING(9): Remove dead code (KDTRACE_HOOKS)
55-freebsd-126-freebsd-12
@9c1490a
11/14/17 12:06:39 |
Sebastian Huber |
LOCKING(9): Update to current FreeBSD version
@b03a1c0
11/15/17 12:24:29 |
Sebastian Huber |
Fix file descriptor reference counting in accept()
Update #3132.
@06f06d4
11/10/17 13:19:29 |
Sebastian Huber |
Fix warning
@4525674
11/10/17 13:04:48 |
Sebastian Huber |
tcpdump: Fix import/export
@9521c08
11/09/17 13:35:13 |
Christian.Mauderer |
wpa_supplicant: Use arc4random instead of getentropy.
@bc4bb2e
10/17/17 17:22:36 |
gordon |
Update wpa_supplicant/hostapd for 2017-01 vulnerability release.
@bdc4f21
11/08/17 13:11:09 |
wpa: Port to new files to RTEMS.
@b0f0b2f
11/08/17 13:10:40 |
wpa: Import all files for KRACK patch.
@a506ba9
11/08/17 10:25:59 |
at91_mci: Add timing to read_ivar.
@e7f3260
11/08/17 09:44:48 |
freebsd/bus: Check return value of bus_accessor.
@ec29b2a
11/07/17 15:17:55 |
at91_mci: Port to RTEMS and adapt for atsam.
@ea5880a
08/23/16 11:16:53 |
Sebastian Huber |
at91_mci: Import from FreeBSD
@5892207
11/07/17 14:15:38 |
saf1761_otg: Port to RTEMS.
@cf8e1d4
04/11/17 08:36:12 |
usb/saf1761: Import from FreeBSD.
Import the files for the SAF1761 …
@ddd16bc
11/07/17 10:54:39 |
dhcpcd: Don't ignore interface on transient errors.
In case of WPA on …
@e5abb31
11/08/17 11:43:39 |
libbsd.txt: Describe current state of WLAN.
@bed8742
11/03/17 10:08:48 |
wpa_supplicant: Fix getopt.
@79ad952
11/02/17 14:07:23 |
wpa_supplicant: Include rtems-bsd-program.h.
@4613db0
11/02/17 13:34:35 |
wpa_supplicant: Add lock.
@ee0c369
11/02/17 13:08:10 |
wpa_supplicant: Move forking command into own file.
The malloc …
@ce2262e
10/12/17 12:16:09 |
1473996754 |
Add wpa_supplicant_fork command.
Add fork command for wpa supplicant …
@0aa7e63
10/12/17 12:16:08 |
1473996754 |
Add wpa_supplicant command in test suite.
Add wpa supplicant command …
@8f2267b
10/12/17 12:16:07 |
1473996754 |
Port wpa supplicant to RTEMS.
Add wpa_supplicant lib support and …
@9c9d11b
08/01/17 12:43:41 |
1473996754 |
Import wpa from FreeBSD
@847de24
11/10/17 12:32:14 |
Sebastian Huber |
Fix build for non-FDT platforms
@7c68f4e
11/08/17 13:43:32 |
1473996754 |
Port BBB sd driver files to RTEMS.
So BBB can mount and read eMMC and …
@7e52ab9
11/08/17 13:43:31 |
1473996754 |
Import BBB sd driver files from FreeBSD.
@896f068
11/10/17 10:53:07 |
Sebastian Huber |
tests/syscalls01: Fix shutdown() test
The socket must be connected …
@23cd284
11/10/17 10:48:51 |
Sebastian Huber |
Add rtems_bsd_ifconfig_lo0()
@eeeda4b
11/10/17 10:17:13 |
Sebastian Huber |
tests/syscall01: Update error values
FreeBSD changed the error values.
@057656b
11/10/17 10:15:35 |
Sebastian Huber |
Disable HHOOK(9) support for sockets
Support was only partly disabled …
@72d5fa1
11/10/17 10:01:39 |
Sebastian Huber |
Fix reference counting for file descriptors
Update #3132.
@b15a719
11/09/17 13:28:55 |
Sebastian Huber |
Change RTEMS version to 5
Update #3220.
@c64806c
11/09/17 13:28:37 |
Sebastian Huber |
tests/mutex01: Fix mtx_recursed() usage
@6fbcf2e
11/09/17 13:28:17 |
Sebastian Huber |
tests/program01: Fix test name
@45149ec
10/26/17 13:02:24 |
Sebastian Huber |
Fix general PowerPC build
@936b597
10/26/17 06:43:53 |
Sebastian Huber |
ffec: Fix comment
Update #3090.
@a8a9cf1
10/25/17 08:17:23 |
Sebastian Huber |
ffec: Add checksum offload
Update #3090.
@0323c28
10/25/17 06:01:27 |
Sebastian Huber |
ffec: Add interrupt coalescing support
Code is an adapted from the …
@fd5ee57
10/25/17 11:25:15 |
Sebastian Huber |
ffec: Increase buffer descriptor count to 512
Update #3090.
@0cb4075
10/24/17 10:17:00 |
Sebastian Huber |
ffec: Defragment transmit mbuf only if necessary
Use structure …
@798d308
10/24/17 12:11:56 |
Sebastian Huber |
ffec: Fix NULL pointer access
Update #3090.
@b8fdbe2
10/04/17 12:15:59 |
Sebastian Huber |
ffec: Use RACC[SHIFT16]
This avoids the move of entire receive frames …
@2fcf5aa
10/24/17 10:19:28 |
Sebastian Huber |
rtems-bsd-mutex: Update due to API changes
Update #3117.
@445d59e
10/24/17 06:15:06 |
Sebastian Huber |
Remove ability to synchronize with Linux
@1dd58e4
10/24/17 06:14:26 |
Sebastian Huber |
Remove Linux submodule
@fb84af0
10/24/17 05:42:36 |
Sebastian Huber |
Fix install arch-specific header files
@a677fe9
10/23/17 07:11:15 |
Sebastian Huber |
dpaa: Use only one FMan MAC SGT zone
@b1fd51c
10/20/17 12:55:13 |
Sebastian Huber |
dpaa: Reduce receive buffer seed
Seed the receive buffers of each …
@33356a8
08/23/17 08:08:16 |
Sebastian Huber |
dpaa: Improve QMan portal initialization
Be less dependent on the …
@24866e6
08/23/17 07:59:31 |
Sebastian Huber |
dpaa: Reduce PFDR space from 32MiB to 16MiB
@de5791b
07/13/17 06:31:46 |
Sebastian Huber |
dpaa: Add "libbsd,dedicated-portal" to QMan portals
By default, the …
@e818128
06/23/17 09:39:26 |
Sebastian Huber |
dpaa: Add "libbsd,dequeue" to QMan portals
The dequeue support for …
@3cfc31c
07/11/17 12:53:42 |
Sebastian Huber |
dpaa: Set portal interrupt affinity
@ef1655c
07/10/17 07:19:10 |
Sebastian Huber |
Update to Linux 4.12
Linux baseline …
@e3dc39e
06/27/17 10:51:07 |
Sebastian Huber |
dpaa: Add <soc/fsl/dpaa.h>
@9789434
06/27/17 07:31:34 |
Sebastian Huber |
linux: Move upper_32_bits() and lower_32_bits()
@65d6fa2
06/27/17 07:31:11 |
Sebastian Huber |
linux: Make Linux types available in user-space
@0de65a8
06/27/17 07:30:44 |
Sebastian Huber |
linux: Include missing <sys/errno.h>
@9cc419f
06/27/17 06:36:05 |
Sebastian Huber |
Install Linux header files
@33d82be1
06/27/17 06:34:53 |
Sebastian Huber |
waf: Install arch-specific header files
@e846288
06/21/17 12:35:19 |
Sebastian Huber |
Add rtems_bsd_set_if_input()
@07c8680
05/24/17 11:16:11 |
Sebastian Huber |
dpaa: Get c45 ids
@03d1426
05/24/17 11:15:14 |
Sebastian Huber |
dpaa: No error if MII attach failed
@9da83e7
05/24/17 06:32:09 |
Sebastian Huber |
dpaa: Support c45 phys
@66e83e0e
05/19/17 07:47:45 |
Sebastian Huber |
soc/qbman: Simplify bman_release()
Get the affine portal only once …
@1908686
05/19/17 07:41:16 |
Sebastian Huber |
soc/qman: Do not enable stashing without PAMU
Do not enable stashing …
@e2d48f5
05/19/17 07:31:15 |
Sebastian Huber |
dpaa: Implement GENMASK() similar to Linux
@7f1f428
05/18/17 12:19:09 |
Sebastian Huber |
qman_api.c: Prevent false clearing of IRQ status
Adding …
@69a5677
05/18/17 09:53:08 |
Sebastian Huber |
dpaa: Disable QMAN_VOLATILE_FLAG_WAIT_INT
@96da40c
05/18/17 09:50:43 |
Sebastian Huber |
dpaa: Avoid QMan work queue
@ed254d58
05/18/17 06:13:07 |
Sebastian Huber |
dpaa: Use receive checksum offload
@3471177
05/18/17 05:44:00 |
Sebastian Huber |
dpaa: Enable preemption in qm_mr_process_task()
@b3a6ad0
05/18/17 05:28:22 |
Sebastian Huber |
dpaa: Disable unused CGR code
@cf40770
05/18/17 05:27:33 |
Sebastian Huber |
Linux update to 4.12-rc1+
Linux baseline …
@721b1c1
05/17/17 07:25:39 |
Sebastian Huber |
qbman: Fix platform_get_irq() error checks
@cd089b9
05/05/17 06:47:39 |
Sebastian Huber |
Linux update to 4.11-rc5
Linux baseline …
@28ee86a
04/27/16 09:58:19 |
Sebastian Huber |
Import DPAA driver snapshot
Imported from Freescale Linux repository
@b2b2e1a
10/20/17 10:51:20 |
Sebastian Huber |
powerpc: Fix warnings
@43fdf50
05/16/17 09:27:12 |
Sebastian Huber |
Import CRC32 support from FreeBSD
@64163f3
05/17/17 08:23:56 |
Sebastian Huber |
Initialize BSD user extension earlier
@f7f3c4b
05/10/17 09:31:29 |
Sebastian Huber |
blist: Import from FreeBSD
@238e275
04/06/17 13:09:42 |
Sebastian Huber |
scripts: Support CPU-dependent RTEMS source files
@23d6e50
04/03/17 13:18:09 |
Sebastian Huber |
scripts: Support Linux import
@fa4ec51
04/03/17 13:12:18 |
Sebastian Huber |
scripts: Generalize names
@d61f731
04/03/17 13:16:56 |
Sebastian Huber |
Add Linux submodule
@62c8ca0
05/18/17 07:35:46 |
Sebastian Huber |
Fix INVARIANTS support
@5be4f06
10/20/17 10:52:37 |
Sebastian Huber |
Add CPUINFO command to default network init
@1e554b81
11/23/16 13:06:26 |
Sebastian Huber |
media01: Scale with processor count
@91fb6e3
11/21/16 13:57:57 |
Sebastian Huber |
rtems-kernel-page: Reclaim pages earlier
@7533adc
11/10/16 13:58:22 |
Sebastian Huber |
rtems-kernel-page: Add used pages counter
@5ede682
11/14/16 09:17:10 |
Sebastian Huber |
ZONE(9): Use recursive lock for the UMA drain
@be708ff
11/21/16 13:56:59 |
Sebastian Huber |
ZONE(9): Reduce BUCKET_MAX to 128
Reduces the worst-case …
@b988014
04/26/16 13:02:00 |
Sebastian Huber |
ZONE(9): Fix uma_zone_set_max()
Account for items provided for …
@a8e84c6
02/14/17 10:48:46 |
Sebastian Huber |
DEVICE(9): Avoid NULL pointer access
@fd34b52
10/20/17 11:59:14 |
Sebastian Huber |
tests: Remove obsolete config defines
@7ec4d87
10/20/17 12:50:14 |
Sebastian Huber |
dhcpcd: Honour file descriptor maximum
@9a583a9
10/17/17 11:56:20 |
Sebastian Huber |
SLEEPQUEUE(9): Update due to API changes
Update #3117.
Update #3182.
@79ec6b9
10/16/17 07:49:09 |
Sebastian Huber |
Install libpcap header files
