source: rtems-libbsd
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @335bb97   10/07/16 05:23:33 Sebastian Huber testsuite: Fix warnings 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e11f8e3   10/07/16 05:09:48 Sebastian Huber ohci: Fixes due to USB stack update 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e3881ee   09/28/16 13:34:46 Sebastian Huber nexus-devices: Add arm/atsamv BSP section 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ec5b97b   09/28/16 13:33:50 Sebastian Huber usb01: Simplify test program 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @8eb8883   09/28/16 13:00:00 Sebastian Huber Split rtemsbsd/rtems/rtems-program.c This improves garbage collection … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @10e9e05   09/28/16 12:46:55 Sebastian Huber Split rtems-bsd-kernel-program.c Separate kernel and user space parts. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @299d4ba   09/28/16 12:39:32 Sebastian Huber Build rtems-bsd-shell-pfctl.c 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @d9fe061   09/28/16 11:23:16 Sebastian Huber Split rtems-bsd-shell-netcmds.c This improves garbage collection by … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @2c563ed   09/23/16 07:54:49 Sebastian Huber if_ffec_mcf548x.c: Fix include order 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @02d344f4   09/22/16 05:22:42 Sebastian Huber rtems-bsd-mutex: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @2c44b51   09/22/16 05:21:54 Sebastian Huber Use _Thread_Get_priority() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7f75b56   09/07/16 13:43:44 Sebastian Huber Port getdomainname() to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a439410   09/07/16 13:42:36 Sebastian Huber Import getdomainname() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @8e65e1b   08/23/16 13:51:45 Sebastian Huber usb: Update to FreeBSD trunk 2016-08-23 FreeBSD trunk, 2016-08-23, … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7c77211   08/23/16 13:37:01 Sebastian Huber doc: Update rules to modify FreeBSD code 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @0c24e06   08/23/16 12:22:26 Sebastian Huber mmc: Update to FreeBSD trunk 2016-08-23 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a971614   08/19/16 09:18:52 Sebastian Huber doc: Update rules to modify FreeBSD code 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @69355c3   08/16/16 06:52:07 Christian.Mauderer devfs: Add some notes on implementation. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6634edb   08/16/16 06:52:06 Christian.Mauderer devfs: Create path. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ab7739a   08/12/16 03:55:37 Chris Johns rc.conf/net: Let interface option appear on a DHCP ifconfig_ line. An … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c83cf5c   08/12/16 02:19:48 Chris Johns nfsclient: Only parse for options when present. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @691ed15   08/11/16 07:01:42 Sebastian Huber rtems-bsd-mutex: Use _Thread_queue_Surrender() 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @26a8cee   08/11/16 07:41:49 Chris Johns e1000phy: Provide local support for Marvell's 88E1512 PHY. This PHY … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @62c4755   08/10/16 06:04:16 Sebastian Huber doc: Add FreeBSD import version section 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @bc9e939   08/04/16 11:20:04 Christian.Mauderer pf: Add configuration via rc.conf. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6cfb5c2   08/08/16 14:11:21 Christian.Mauderer pf: Improve documentation regarding stack. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @61e2e1b   08/08/16 13:53:39 Christian.Mauderer rc.conf: Use more stack for the rc worker. Most of the tests run with … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a8d016c   08/04/16 06:30:44 Christian.Mauderer testsuite/pf01: Remove pflog-module from test. This module is not … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @32a3dd1   08/04/16 06:02:24 Christian.Mauderer pf: Add RTEMS_BSD_CONFIG_FIREWALL_xxx options. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @0717607   08/05/16 10:00:47 Christian.Mauderer if_ffec_mcf548x: Init when interface is set to UP. Call the driver … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9907ae4   08/04/16 12:13:20 Christian.Mauderer netstat: Don't init vars if they are not defined. The variables are … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @2fb3a36   08/04/16 12:12:17 Christian.Mauderer freebsd: Add constant ipv6 addresses from vars.c. This is necessary … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7aaa9a1   08/03/16 11:27:11 Christian.Mauderer testsuite/pf02: Add interactive pf test. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f1941b2   07/12/16 11:41:39 Christian.Mauderer libbsd.txt: Add section describing PF. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f71cbd0   07/06/16 14:06:54 Christian.Mauderer libbsd.txt: Add guide for user space tools. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @df222eb   07/22/16 12:50:09 Christian.Mauderer testsuite/pf01: Test pfctl and pf. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7f86f6a   07/22/16 12:49:49 Christian.Mauderer pfctl: Add rtems_bsd_command_pfctl. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c79290a   07/05/16 14:08:38 Christian.Mauderer pfctl: build files. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @09ce54e   07/22/16 12:36:19 Christian.Mauderer pfctl: Add yacc generated file. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @d79524e   07/05/16 14:31:43 Christian.Mauderer pfctl: Adapt for RTEMS. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @686583c   07/29/16 14:04:42 Christian.Mauderer pfctl: Use static where possible. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c70221c   07/06/16 07:50:51 Christian.Mauderer pfctl: Add const and move static variables. Note: This should be … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b6252fb   07/05/16 14:31:43 Christian.Mauderer pfctl: Match prototype. Note: This should be upstreamed into BSD. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6e9a8ea   07/05/16 14:07:37 Christian.Mauderer pfctl: Import sources from FreeBSD. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @21abaef   07/15/16 05:32:56 Christian.Mauderer freebsd: Don't use new wrappers for old ports. Some of the commands … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @d31a365   07/14/16 09:01:43 Christian.Mauderer rtemsbsd: Add wrapper for open, fopen, malloc, ... Add the following … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @3d91340   07/15/16 09:39:48 Christian.Mauderer rtemsbsd: Add call to program with a data restore This adds the … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @fa43d6a   07/14/16 13:34:13 Christian.Mauderer testsuite/syscalls01: Split out program01 part. This allows to use … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a9bd422   06/27/16 12:29:53 Christian.Mauderer testsuite/pf01: Add test that links PF. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @8dacfe4   06/28/16 13:13:09 Christian.Mauderer testsuite/cdev01: Add test for cdev functions. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9a01ebf   06/28/16 15:27:08 Christian.Mauderer kern_conf.c: Adapt for RTEMS. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @6c0cfc2   06/29/16 08:22:03 Christian.Mauderer kern_conf.c: Import from FreeBSD. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b5db332   06/30/16 05:55:27 Christian.Mauderer rtemsbsd/devfs: Add. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @bf7faad   06/28/16 06:32:30 Sebastian Huber rtems-bsd-mutex: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b6c170f   07/28/16 02:19:01 Chris Johns kern/sleepqueue: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a0ea5f8   07/28/16 02:17:08 Chris Johns Revert "kern/sleepqueue: Update due to API changes" This reverts … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @1bf6529   07/28/16 02:16:09 Chris Johns kern/sleepqueue: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @e5aa554   07/27/16 06:51:53 Sebastian Huber rtems-bsd-mutex: Update due to API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9510012   07/18/16 22:12:17 Chris Johns config: Fix telnetd configuration warning. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ac0e5bf   07/09/16 04:43:03 Chris Johns Update to bring in the --show-commands fix. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b8c7bf9   07/06/16 07:08:07 Chris Johns Set syslog priority to 'debug' for all tests. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @761ae78   06/30/16 03:32:29 Chris Johns Make the license message viewable with a verbose option. The license … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @34f6271   07/01/16 06:43:56 Chris Johns Provide empty RTEMS_BSD_CFGDECL_.* defines if not used. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @4dec435   07/01/16 06:36:13 Chris Johns Add a wait for key press to test rccof02. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @65c65bb   07/01/16 05:49:52 Chris Johns Add telnetd as service to rc.conf. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @fc26479   06/30/16 03:35:37 Chris Johns Add ftpd initailize comment. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f01b1f72   06/30/16 01:42:49 Chris Johns Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. The domain allocator … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @dc5b267   06/29/16 23:25:13 Chris Johns Fix wording and spelling. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @573b1982   06/29/16 23:19:52 Chris Johns Add DHCP support to rc.conf. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @912b685   06/29/16 23:19:06 Chris Johns Make the LibBSD PID match getpid(). 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c980a04   06/29/16 23:18:21 Chris Johns Fix fomatting and C++ guard. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @45960a3   06/29/16 23:17:21 Chris Johns Add rtems_get_route to fetch a specific route from the routing tables. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @4a2b844   06/29/16 23:14:55 Chris Johns Default syslog priority to INFO. Add rtems_setlogpriority to configure … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @90873cc   06/28/16 03:32:01 Chris Johns Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c2ec5f1   06/28/16 03:31:11 Chris Johns Print the service when starting. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f588325   06/28/16 03:30:44 Chris Johns Change the Nexus bus to defines and have the BSP declare them. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @ace5fb6   06/27/16 11:31:03 Chris Johns Enable the Cadence cgem device syctls. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @591bd2d   06/27/16 11:27:01 Chris Johns Revert "Enable the Cadence cgem device syctls." This reverts commit … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9362e76   06/27/16 11:25:38 Chris Johns Enable the Cadence cgem device syctls. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9835790   06/27/16 11:24:03 Chris Johns Enable device sysctl. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @39a650e   06/27/16 06:45:18 Chris Johns Add VDE and QEMU doco. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @459d67d   06/27/16 03:35:08 Chris Johns Move the Nexus bus driver decls available to users. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @7439724   06/27/16 03:25:48 Chris Johns Add a services base test. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @55c564a   06/27/16 03:24:43 Chris Johns Refactor rc.conf processing to be services based. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c6713d1   06/27/16 03:15:11 Chris Johns Add DEFAULT_NETWORK_PAGE_MBUFS_SIZE to allow per BSP allocation domain … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @9edacb6   06/27/16 03:12:39 Chris Johns Fix spelling. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @b23da31   06/27/16 03:12:06 Chris Johns Change LibBSD to use shared interrupts. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @130fa35   06/27/16 03:09:04 Chris Johns Make the domain allocation size global to allow it to set in tests. … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a0e49f9   06/27/16 03:07:54 Chris Johns Add functions used the bridge and tap interfaces. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @c991d65   06/23/16 12:18:17 Sebastian Huber Update due to RTEMS printer API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @32fd702   06/23/16 12:06:21 Sebastian Huber Update due to RTEMS printer API changes 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @628512a   06/20/16 00:07:08 Chris Johns Update rtems_waf to pick up the long command line fix. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @616be5c   06/16/16 07:08:37 Chris Johns Pick up white space fix. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @32ceb14   06/16/16 03:32:28 Chris Johns Add support for long command lines and fix some shell rules on Windows. 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @5851034   06/15/16 05:49:24 Sebastian Huber reentrant.h: There is no main thread in RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @d6ad59d   06/13/16 09:59:04 Sebastian Huber libbsd.txt: Clarify xilinx_zynq_a9_qemu usage 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @58c4e1c5   06/10/16 12:11:40 Sebastian Huber nfsclient: Port to LibBSD 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @4464594   06/09/16 09:31:27 Sebastian Huber nfsclient: Import from RTEMS RTEMS Git commit … 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @a037da6   06/09/16 09:48:16 Sebastian Huber XDR(3): Port to RTEMS 55-freebsd-126-freebsd-12freebsd-9.3
(edit) @f41a394   06/09/16 09:46:09 Sebastian Huber XDR(3): Import from FreeBSD 55-freebsd-126-freebsd-12freebsd-9.3
