@2275776
02/06/18 08:29:49 |
Sebastian Huber |
dwc_otg: Default to USB host mode
In case no "dr_mode" property is …
55-freebsd-126-freebsd-12
@b79c025
02/06/18 08:28:02 |
Sebastian Huber |
dwc_otg: Add compatibility string, constify
Support device tree of …
@bcaa8a2
02/05/18 15:45:59 |
Sebastian Huber |
dw_mmc: Properly init/reset DMA
@138bf25
02/05/18 15:45:20 |
Sebastian Huber |
dw_mmc: Add MMCBR_IVAR_TIMING
@c30fa94
02/05/18 12:57:11 |
Sebastian Huber |
Add device tree support for Altera/Intel? Cyclone V
Close #3290.
@9906c4a
02/05/18 11:05:52 |
Sebastian Huber |
tests: Fix configuration dependencies
@0f9258f
11/29/17 14:26:17 |
Sebastian Huber |
linux/percpu.h: Fix for uni-processor config
@a0633c5
01/15/18 13:41:58 |
Sebastian Huber |
SLEEPQUEUE(9): Update due to API changes
Update #3264.
@8b3da13
01/08/18 12:55:36 |
Sebastian Huber |
termios: Update due to API changes
Update #2843.
@327f4e1
01/11/18 13:30:49 |
Sebastian Huber |
sdk_dpaa: What to do with tail queue drop?
The issue is this:
static …
@d62a3df
01/17/18 12:28:45 |
Sebastian Huber |
sdk_dpaa: Port to RTEMS
Update #3277.
@f5ed3aa
10/27/17 09:50:01 |
Sebastian Huber |
sdk_dpaa: Import from QorIQ SDK Linux
@0f6ff4a
01/10/18 14:08:19 |
Sebastian Huber |
dpaa: QMan portal only initialization
Update #3277.
@a7d252c
01/12/18 12:22:10 |
Sebastian Huber |
dpaa: Add and use bman_new_pool_for_bpid()
Update #3277.
@95fe5b1
01/10/18 12:19:01 |
Sebastian Huber |
dpaa: Use device tree throughout in BMan init
Update #3277.
@1342fad0
01/17/18 12:49:44 |
Sebastian Huber |
dpaa: Add and use SDK_DPAA_COMPAT_STATIC
Update #3277.
@34b7ccc
01/09/18 10:45:31 |
Sebastian Huber |
dpaa: Support FQ_TYPE_RX_PCD
Update #3277.
@bdf99316
01/12/18 12:23:24 |
Sebastian Huber |
dpaa: Disable unused bman_pool members
Update #3277.
@2fba1e4
01/23/18 09:48:19 |
Sebastian Huber |
dpaa: Remove unused configuration defines
Update #3277.
@cfc149b
01/10/18 13:11:57 |
Sebastian Huber |
linux/of_irq.h: Generalize of_irq_to_resource()
Determine interrupt …
@e4923c8
01/17/18 13:30:44 |
Sebastian Huber |
linux/of_address.h: of_address_to_resource()
Translate address in …
@0f1d2f6
01/10/18 12:18:05 |
Sebastian Huber |
linux/of_address.h: Add of_translate_address()
Update #3277.
@81fc57d
01/17/18 13:14:30 |
Sebastian Huber |
linux/of.h: Add of_find_node_by_path()
Update #3277.
@44fca38
01/17/18 13:14:10 |
Sebastian Huber |
linux/of.h: Add of_read_number()
Update #3277.
@26ce2ac
01/17/18 13:13:53 |
Sebastian Huber |
linux/of.h: Add of_n_size_cells()
Update #3277.
@0d421d8
01/17/18 13:13:34 |
Sebastian Huber |
linux/of.h: Add of_n_addr_cells()
Update #3277.
@066b536
01/17/18 12:26:11 |
Sebastian Huber |
linux/sort.h: New file
Update #3277.
@583216a
01/16/18 12:07:36 |
Sebastian Huber |
linux/smp.h: Avoid function call overhead
Update #3277.
@fe05886
11/02/17 13:29:57 |
Sebastian Huber |
linux/compiler.h: Define cold
Update #3277.
@2253814
01/23/18 10:52:50 |
Sebastian Huber |
Add rtems_bsd_ifconfig()
@13c4093
01/17/18 10:48:36 |
Sebastian Huber |
ehci_mpc83xx.c: Fix for qoriq hypervisor guest
@ea121a0
01/16/18 12:06:39 |
Sebastian Huber |
ZONE(9): Avoid function call overhead
@4e17f14
01/08/18 12:54:29 |
Sebastian Huber |
DEVICE(9): Fix BUS_ACCESSOR()
@4e3a5d3
12/22/17 12:18:25 |
Sebastian Huber |
openssl: Remove superfluous file
@b1649d6
11/29/17 14:26:54 |
Sebastian Huber |
Add rtems_bsd_initialize_dhcp()
@9569b39
11/17/17 13:23:55 |
Christian.Mauderer |
at91_mci: Fix for 32k buffer.
@c360b1a
11/17/17 09:49:59 |
Sebastian Huber |
Revert "RWLOCK(9): Add reader/writer lock implementation"
This was …
@b5822c2
11/17/17 09:49:31 |
Sebastian Huber |
Revert "SX(9): Implement with reader/writer lock"
This was …
@cc7a8d8
11/15/17 10:49:09 |
Sebastian Huber |
@97a98f6
11/14/17 11:57:01 |
Sebastian Huber |
@344b8e6
11/16/17 07:17:03 |
Sebastian Huber |
LOCKING(9): Remove dead code (DDB)
@3f23fcd
11/16/17 07:15:37 |
Sebastian Huber |
LOCKING(9): Remove dead code (KDTRACE_HOOKS)
@9c1490a
11/14/17 12:06:39 |
Sebastian Huber |
LOCKING(9): Update to current FreeBSD version
@b03a1c0
11/15/17 12:24:29 |
Sebastian Huber |
Fix file descriptor reference counting in accept()
Update #3132.
@06f06d4
11/10/17 13:19:29 |
Sebastian Huber |
Fix warning
@4525674
11/10/17 13:04:48 |
Sebastian Huber |
tcpdump: Fix import/export
@9521c08
11/09/17 13:35:13 |
wpa_supplicant: Use arc4random instead of getentropy.
@bc4bb2e
10/17/17 17:22:36 |
gordon |
Update wpa_supplicant/hostapd for 2017-01 vulnerability release.
@bdc4f21
11/08/17 13:11:09 |
wpa: Port to new files to RTEMS.
@b0f0b2f
11/08/17 13:10:40 |
wpa: Import all files for KRACK patch.
@a506ba9
11/08/17 10:25:59 |
at91_mci: Add timing to read_ivar.
@e7f3260
11/08/17 09:44:48 |
freebsd/bus: Check return value of bus_accessor.
@ec29b2a
11/07/17 15:17:55 |
at91_mci: Port to RTEMS and adapt for atsam.
@ea5880a
08/23/16 11:16:53 |
Sebastian Huber |
at91_mci: Import from FreeBSD
@5892207
11/07/17 14:15:38 |
saf1761_otg: Port to RTEMS.
@cf8e1d4
04/11/17 08:36:12 |
usb/saf1761: Import from FreeBSD.
Import the files for the SAF1761 …
@ddd16bc
11/07/17 10:54:39 |
dhcpcd: Don't ignore interface on transient errors.
In case of WPA on …
@e5abb31
11/08/17 11:43:39 |
libbsd.txt: Describe current state of WLAN.
@bed8742
11/03/17 10:08:48 |
wpa_supplicant: Fix getopt.
@79ad952
11/02/17 14:07:23 |
wpa_supplicant: Include rtems-bsd-program.h.
@4613db0
11/02/17 13:34:35 |
wpa_supplicant: Add lock.
@ee0c369
11/02/17 13:08:10 |
wpa_supplicant: Move forking command into own file.
The malloc …
@ce2262e
10/12/17 12:16:09 |
1473996754 |
Add wpa_supplicant_fork command.
Add fork command for wpa supplicant …
@0aa7e63
10/12/17 12:16:08 |
1473996754 |
Add wpa_supplicant command in test suite.
Add wpa supplicant command …
@8f2267b
10/12/17 12:16:07 |
1473996754 |
Port wpa supplicant to RTEMS.
Add wpa_supplicant lib support and …
@9c9d11b
08/01/17 12:43:41 |
1473996754 |
Import wpa from FreeBSD
@847de24
11/10/17 12:32:14 |
Sebastian Huber |
Fix build for non-FDT platforms
@7c68f4e
11/08/17 13:43:32 |
1473996754 |
Port BBB sd driver files to RTEMS.
So BBB can mount and read eMMC and …
@7e52ab9
11/08/17 13:43:31 |
1473996754 |
Import BBB sd driver files from FreeBSD.
@896f068
11/10/17 10:53:07 |
Sebastian Huber |
tests/syscalls01: Fix shutdown() test
The socket must be connected …
@23cd284
11/10/17 10:48:51 |
Sebastian Huber |
Add rtems_bsd_ifconfig_lo0()
@eeeda4b
11/10/17 10:17:13 |
Sebastian Huber |
tests/syscall01: Update error values
FreeBSD changed the error values.
@057656b
11/10/17 10:15:35 |
Sebastian Huber |
Disable HHOOK(9) support for sockets
Support was only partly disabled …
@72d5fa1
11/10/17 10:01:39 |
Sebastian Huber |
Fix reference counting for file descriptors
Update #3132.
@b15a719
11/09/17 13:28:55 |
Sebastian Huber |
Change RTEMS version to 5
Update #3220.
@c64806c
11/09/17 13:28:37 |
Sebastian Huber |
tests/mutex01: Fix mtx_recursed() usage
@6fbcf2e
11/09/17 13:28:17 |
Sebastian Huber |
tests/program01: Fix test name
@45149ec
10/26/17 13:02:24 |
Sebastian Huber |
Fix general PowerPC build
@936b597
10/26/17 06:43:53 |
Sebastian Huber |
ffec: Fix comment
Update #3090.
@a8a9cf1
10/25/17 08:17:23 |
Sebastian Huber |
ffec: Add checksum offload
Update #3090.
@0323c28
10/25/17 06:01:27 |
Sebastian Huber |
ffec: Add interrupt coalescing support
Code is an adapted from the …
@fd5ee57
10/25/17 11:25:15 |
Sebastian Huber |
ffec: Increase buffer descriptor count to 512
Update #3090.
@0cb4075
10/24/17 10:17:00 |
Sebastian Huber |
ffec: Defragment transmit mbuf only if necessary
Use structure …
@798d308
10/24/17 12:11:56 |
Sebastian Huber |
ffec: Fix NULL pointer access
Update #3090.
@b8fdbe2
10/04/17 12:15:59 |
Sebastian Huber |
ffec: Use RACC[SHIFT16]
This avoids the move of entire receive frames …
@2fcf5aa
10/24/17 10:19:28 |
Sebastian Huber |
rtems-bsd-mutex: Update due to API changes
Update #3117.
@445d59e
10/24/17 06:15:06 |
Sebastian Huber |
Remove ability to synchronize with Linux
@1dd58e4
10/24/17 06:14:26 |
Sebastian Huber |
Remove Linux submodule
@fb84af0
10/24/17 05:42:36 |
Sebastian Huber |
Fix install arch-specific header files
@a677fe9
10/23/17 07:11:15 |
Sebastian Huber |
dpaa: Use only one FMan MAC SGT zone
@b1fd51c
10/20/17 12:55:13 |
Sebastian Huber |
dpaa: Reduce receive buffer seed
Seed the receive buffers of each …
@33356a8
08/23/17 08:08:16 |
Sebastian Huber |
dpaa: Improve QMan portal initialization
Be less dependent on the …
@24866e6
08/23/17 07:59:31 |
Sebastian Huber |
dpaa: Reduce PFDR space from 32MiB to 16MiB
@de5791b
07/13/17 06:31:46 |
Sebastian Huber |
dpaa: Add "libbsd,dedicated-portal" to QMan portals
By default, the …
@e818128
06/23/17 09:39:26 |
Sebastian Huber |
dpaa: Add "libbsd,dequeue" to QMan portals
The dequeue support for …
@3cfc31c
07/11/17 12:53:42 |
Sebastian Huber |
dpaa: Set portal interrupt affinity
@ef1655c
07/10/17 07:19:10 |
Sebastian Huber |
Update to Linux 4.12
Linux baseline …
@e3dc39e
06/27/17 10:51:07 |
Sebastian Huber |
dpaa: Add <soc/fsl/dpaa.h>
@9789434
06/27/17 07:31:34 |
Sebastian Huber |
linux: Move upper_32_bits() and lower_32_bits()
@65d6fa2
06/27/17 07:31:11 |
Sebastian Huber |
linux: Make Linux types available in user-space
