source: rtems-libbsd
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @1372502   07/26/18 12:49:35 Sebastian Huber Make sure CALLOUT_DFRMIGRATION is not used This flag supports the … 55-freebsd-126-freebsd-12
(edit) @e37f03e   07/26/18 12:35:56 Sebastian Huber Make sure CALLOUT_PROCESSED is not used This flag is only used in … 55-freebsd-126-freebsd-12
(edit) @6d9d7b1   07/26/18 12:12:46 Sebastian Huber Critical bug fix for callouts FreeBSD has two callout executors, one … 55-freebsd-126-freebsd-12
(edit) @3df89c0   07/26/18 11:52:43 Sebastian Huber selectpollkqueue01: Invalidate file descriptor This is not a … 55-freebsd-126-freebsd-12
(edit) @6fb003f   07/26/18 10:03:45 Sebastian Huber Fix sporadic test failures via uma_timeout() 55-freebsd-126-freebsd-12
(edit) @94b5368   07/02/18 06:21:37 Sebastian Huber Avoid malloc() in getsockaddr() The getsockaddr() function is used to … 55-freebsd-126-freebsd-12
(edit) @e6f6b5e   07/04/18 05:19:01 lou.nick BPF(9): Pass flags to bpfopen() 55-freebsd-126-freebsd-12
(edit) @a1e4757   07/02/18 07:16:14 Sebastian Huber syscalls01: Fix sporadic test failures 55-freebsd-126-freebsd-12
(edit) @a07eb67   06/18/18 11:22:49 christian.mauderer rtems_waf: Fix show-commands option. 55-freebsd-126-freebsd-12
(edit) @aad7461   06/18/18 11:06:47 christian.mauderer rtems_waf: Move to the public repositories. For an update from an … 55-freebsd-126-freebsd-12
(edit) @f8cf074   05/30/18 11:34:36 christian.mauderer beagle: Disable WiFi? if libbsd is build without it. Update #3351. 55-freebsd-126-freebsd-12
(edit) @e1d62e8   05/17/18 18:35:19 christian.mauderer waf: Fix python3 compatibility. 55-freebsd-126-freebsd-12
(edit) @b2eb48c   05/02/18 07:01:32 Sebastian Huber dhcpcd: Add hooks 55-freebsd-126-freebsd-12
(edit) @8bd38d6   05/02/18 06:58:48 Sebastian Huber dhcpcd: Add rtems_dhcpcd_start() Use it throughout to start the DHCP … 55-freebsd-126-freebsd-12
(edit) @bd09f9f   05/03/18 06:18:24 Sebastian Huber rc_conf: Do not create directories used by dhcpcd The dhcpcd will … 55-freebsd-126-freebsd-12
(edit) @9c570da   05/03/18 06:17:59 Sebastian Huber rc_conf: Include missing header files 55-freebsd-126-freebsd-12
(edit) @dd35ec5   05/02/18 09:25:18 christian.mauderer waf: Allow to add libs per test. Update #3419. 55-freebsd-126-freebsd-12
(edit) @a779a3b   05/02/18 09:56:39 christian.mauderer pfctl: Undef INET6 to avoid warning. 55-freebsd-126-freebsd-12
(edit) @338f300   04/25/18 14:28:00 christian.mauderer buildset: Add minimal and everything config. This adds two new … 55-freebsd-126-freebsd-12
(edit) @4eb2502   04/26/18 14:10:09 christian.mauderer tcpdump: Remove unused file. 55-freebsd-126-freebsd-12
(edit) @93f1904   04/25/18 12:51:07 christian.mauderer waf: Generate a rtems/bsd/modules.h The generated file defines a … 55-freebsd-126-freebsd-12
(edit) @1588cf1   05/02/18 12:59:48 christian.mauderer waf: Fix source code generators. There have been some bugs with the … 55-freebsd-126-freebsd-12
(edit) @821976e   04/25/18 10:50:26 christian.mauderer waf: Fix usage of build-include from config. 55-freebsd-126-freebsd-12
(edit) @634b3bf   05/02/18 08:35:35 Sebastian Huber rtems-debugger: Remove files They are now in the main RTEMS sources. … 55-freebsd-126-freebsd-12
(edit) @443a058   04/30/18 09:07:05 Sebastian Huber Use network services from RTEMS Close #3419. 55-freebsd-126-freebsd-12
(edit) @b1404f2   04/30/18 11:35:25 Sebastian Huber Add DHCP clientid to test default network init 55-freebsd-126-freebsd-12
(edit) @ef5d536   04/27/18 08:14:44 Sebastian Huber at91_mci: Simplify XDMA usage 55-freebsd-126-freebsd-12
(edit) @d45899b   04/27/18 06:39:22 Sebastian Huber at91_mci: Get rid of bounce buffer 55-freebsd-126-freebsd-12
(edit) @3fac9e9   04/26/18 13:23:08 Sebastian Huber at91_mci: Use real interrupt Execute at91_mci_intr() in interrupt … 55-freebsd-126-freebsd-12
(edit) @c7e162a   04/26/18 13:19:42 Sebastian Huber mmc: Optimize mmc_wait_for_req() Use a self-contained RTEMS binary … 55-freebsd-126-freebsd-12
(edit) @4b14263   04/26/18 09:14:39 Sebastian Huber at91_mci: Fix use of BOARD_MCK 55-freebsd-126-freebsd-12
(edit) @f092186   04/26/18 09:14:10 Sebastian Huber at91_mci: Fix use of pre-processor defines 55-freebsd-126-freebsd-12
(edit) @854427b   04/06/18 08:35:42 christian.mauderer waf: Add configurations with different modules. Update #3351 55-freebsd-126-freebsd-12
(edit) @fedd993   04/06/18 07:37:35 christian.mauderer freebsd-to-rtems.py: Use all modules. Update #3351 55-freebsd-126-freebsd-12
(edit) @494b156   04/06/18 07:42:29 christian.mauderer waf: Remove module without sources. There are no imported sources for … 55-freebsd-126-freebsd-12
(edit) @a6a6d54   03/27/18 07:31:49 christian.mauderer waf: Fix freebsd-to-rtems.py. Update #3351 55-freebsd-126-freebsd-12
(edit) @d797c5d   03/26/18 04:14:53 Chris Johns waf: Refactor libbsd.py to support per module generation. This change … 55-freebsd-126-freebsd-12
(edit) @f7a09b5   03/26/18 04:14:52 Chris Johns waf: Support building from libbsd.py directly from waf. Remove the … 55-freebsd-126-freebsd-12
(edit) @8189ea8   03/27/18 12:42:31 Sebastian Huber CRYPTO(4): Port to RTEMS 55-freebsd-126-freebsd-12
(edit) @6600368   03/27/18 11:25:16 Sebastian Huber CRYPTO(4): Import from FreeBSD 55-freebsd-126-freebsd-12
(edit) @b8f7836   03/27/18 12:41:50 Sebastian Huber DEVFS(5): Fix warning 55-freebsd-126-freebsd-12
(edit) @8993827   03/27/18 12:40:19 Sebastian Huber DEVFS(5): Properly initialize fp->f_cdevpriv 55-freebsd-126-freebsd-12
(edit) @7ec935e   03/23/18 06:58:18 christian.mauderer vprintf: Add handler that mutes all output. This adds a vprintf … 55-freebsd-126-freebsd-12
(edit) @d300a34   03/23/18 08:14:34 Sebastian Huber Silence rtems_bsd_ifconfig() 55-freebsd-126-freebsd-12
(edit) @b3d1e6a   03/21/18 08:23:17 christian.mauderer config.inc: Remove unused values. 55-freebsd-126-freebsd-12
(edit) @b2a210c   03/15/18 08:09:31 christian.mauderer if_atsam: Add checksum offload. 55-freebsd-126-freebsd-12
(edit) @67c35b9   03/13/18 14:02:55 christian.mauderer openssl: Provide deprecated functions. Some applications (like the … 55-freebsd-126-freebsd-12
(edit) @eae664e   03/12/18 13:38:46 Sebastian Huber mutex: Use panic() after ISR lock release Using panic() with … 55-freebsd-126-freebsd-12
(edit) @2275776   02/06/18 08:29:49 Sebastian Huber dwc_otg: Default to USB host mode In case no "dr_mode" property is … 55-freebsd-126-freebsd-12
(edit) @b79c025   02/06/18 08:28:02 Sebastian Huber dwc_otg: Add compatibility string, constify Support device tree of … 55-freebsd-126-freebsd-12
(edit) @bcaa8a2   02/05/18 15:45:59 Sebastian Huber dw_mmc: Properly init/reset DMA 55-freebsd-126-freebsd-12
(edit) @138bf25   02/05/18 15:45:20 Sebastian Huber dw_mmc: Add MMCBR_IVAR_TIMING 55-freebsd-126-freebsd-12
(edit) @c30fa94   02/05/18 12:57:11 Sebastian Huber Add device tree support for Altera/Intel? Cyclone V Close #3290. 55-freebsd-126-freebsd-12
(edit) @9906c4a   02/05/18 11:05:52 Sebastian Huber tests: Fix configuration dependencies 55-freebsd-126-freebsd-12
(edit) @0f9258f   11/29/17 14:26:17 Sebastian Huber linux/percpu.h: Fix for uni-processor config 55-freebsd-126-freebsd-12
(edit) @a0633c5   01/15/18 13:41:58 Sebastian Huber SLEEPQUEUE(9): Update due to API changes Update #3264. 55-freebsd-126-freebsd-12
(edit) @8b3da13   01/08/18 12:55:36 Sebastian Huber termios: Update due to API changes Update #2843. 55-freebsd-126-freebsd-12
(edit) @327f4e1   01/11/18 13:30:49 Sebastian Huber sdk_dpaa: What to do with tail queue drop? The issue is this: static … 55-freebsd-126-freebsd-12
(edit) @d62a3df   01/17/18 12:28:45 Sebastian Huber sdk_dpaa: Port to RTEMS Update #3277. 55-freebsd-126-freebsd-12
(edit) @f5ed3aa   10/27/17 09:50:01 Sebastian Huber sdk_dpaa: Import from QorIQ SDK Linux … 55-freebsd-126-freebsd-12
(edit) @0f6ff4a   01/10/18 14:08:19 Sebastian Huber dpaa: QMan portal only initialization Update #3277. 55-freebsd-126-freebsd-12
(edit) @a7d252c   01/12/18 12:22:10 Sebastian Huber dpaa: Add and use bman_new_pool_for_bpid() Update #3277. 55-freebsd-126-freebsd-12
(edit) @95fe5b1   01/10/18 12:19:01 Sebastian Huber dpaa: Use device tree throughout in BMan init Update #3277. 55-freebsd-126-freebsd-12
(edit) @1342fad0   01/17/18 12:49:44 Sebastian Huber dpaa: Add and use SDK_DPAA_COMPAT_STATIC Update #3277. 55-freebsd-126-freebsd-12
(edit) @34b7ccc   01/09/18 10:45:31 Sebastian Huber dpaa: Support FQ_TYPE_RX_PCD Update #3277. 55-freebsd-126-freebsd-12
(edit) @bdf99316   01/12/18 12:23:24 Sebastian Huber dpaa: Disable unused bman_pool members Update #3277. 55-freebsd-126-freebsd-12
(edit) @2fba1e4   01/23/18 09:48:19 Sebastian Huber dpaa: Remove unused configuration defines Update #3277. 55-freebsd-126-freebsd-12
(edit) @cfc149b   01/10/18 13:11:57 Sebastian Huber linux/of_irq.h: Generalize of_irq_to_resource() Determine interrupt … 55-freebsd-126-freebsd-12
(edit) @e4923c8   01/17/18 13:30:44 Sebastian Huber linux/of_address.h: of_address_to_resource() Translate address in … 55-freebsd-126-freebsd-12
(edit) @0f1d2f6   01/10/18 12:18:05 Sebastian Huber linux/of_address.h: Add of_translate_address() Update #3277. 55-freebsd-126-freebsd-12
(edit) @81fc57d   01/17/18 13:14:30 Sebastian Huber linux/of.h: Add of_find_node_by_path() Update #3277. 55-freebsd-126-freebsd-12
(edit) @44fca38   01/17/18 13:14:10 Sebastian Huber linux/of.h: Add of_read_number() Update #3277. 55-freebsd-126-freebsd-12
(edit) @26ce2ac   01/17/18 13:13:53 Sebastian Huber linux/of.h: Add of_n_size_cells() Update #3277. 55-freebsd-126-freebsd-12
(edit) @0d421d8   01/17/18 13:13:34 Sebastian Huber linux/of.h: Add of_n_addr_cells() Update #3277. 55-freebsd-126-freebsd-12
(edit) @066b536   01/17/18 12:26:11 Sebastian Huber linux/sort.h: New file Update #3277. 55-freebsd-126-freebsd-12
(edit) @583216a   01/16/18 12:07:36 Sebastian Huber linux/smp.h: Avoid function call overhead Update #3277. 55-freebsd-126-freebsd-12
(edit) @fe05886   11/02/17 13:29:57 Sebastian Huber linux/compiler.h: Define cold Update #3277. 55-freebsd-126-freebsd-12
(edit) @2253814   01/23/18 10:52:50 Sebastian Huber Add rtems_bsd_ifconfig() 55-freebsd-126-freebsd-12
(edit) @13c4093   01/17/18 10:48:36 Sebastian Huber ehci_mpc83xx.c: Fix for qoriq hypervisor guest 55-freebsd-126-freebsd-12
(edit) @ea121a0   01/16/18 12:06:39 Sebastian Huber ZONE(9): Avoid function call overhead 55-freebsd-126-freebsd-12
(edit) @4e17f14   01/08/18 12:54:29 Sebastian Huber DEVICE(9): Fix BUS_ACCESSOR() 55-freebsd-126-freebsd-12
(edit) @4e3a5d3   12/22/17 12:18:25 Sebastian Huber openssl: Remove superfluous file 55-freebsd-126-freebsd-12
(edit) @b1649d6   11/29/17 14:26:54 Sebastian Huber Add rtems_bsd_initialize_dhcp() 55-freebsd-126-freebsd-12
(edit) @9569b39   11/17/17 13:23:55 Christian.Mauderer at91_mci: Fix for 32k buffer. 55-freebsd-126-freebsd-12
(edit) @c360b1a   11/17/17 09:49:59 Sebastian Huber Revert "RWLOCK(9): Add reader/writer lock implementation" This was … 55-freebsd-126-freebsd-12
(edit) @b5822c2   11/17/17 09:49:31 Sebastian Huber Revert "SX(9): Implement with reader/writer lock" This was … 55-freebsd-126-freebsd-12
(edit) @cc7a8d8   11/15/17 10:49:09 Sebastian Huber SX(9): Implement with reader/writer lock 55-freebsd-126-freebsd-12
(edit) @97a98f6   11/14/17 11:57:01 Sebastian Huber RWLOCK(9): Add reader/writer lock implementation 55-freebsd-126-freebsd-12
(edit) @344b8e6   11/16/17 07:17:03 Sebastian Huber LOCKING(9): Remove dead code (DDB) 55-freebsd-126-freebsd-12
(edit) @3f23fcd   11/16/17 07:15:37 Sebastian Huber LOCKING(9): Remove dead code (KDTRACE_HOOKS) 55-freebsd-126-freebsd-12
(edit) @9c1490a   11/14/17 12:06:39 Sebastian Huber LOCKING(9): Update to current FreeBSD version 55-freebsd-126-freebsd-12
(edit) @b03a1c0   11/15/17 12:24:29 Sebastian Huber Fix file descriptor reference counting in accept() Update #3132. 55-freebsd-126-freebsd-12
(edit) @06f06d4   11/10/17 13:19:29 Sebastian Huber Fix warning 55-freebsd-126-freebsd-12
(edit) @4525674   11/10/17 13:04:48 Sebastian Huber tcpdump: Fix import/export 55-freebsd-126-freebsd-12
(edit) @9521c08   11/09/17 13:35:13 Christian.Mauderer wpa_supplicant: Use arc4random instead of getentropy. 55-freebsd-126-freebsd-12
(edit) @bc4bb2e   10/17/17 17:22:36 gordon Update wpa_supplicant/hostapd for 2017-01 vulnerability release. … 55-freebsd-126-freebsd-12
(edit) @bdc4f21   11/08/17 13:11:09 Christian.Mauderer wpa: Port to new files to RTEMS. 55-freebsd-126-freebsd-12
(edit) @b0f0b2f   11/08/17 13:10:40 Christian.Mauderer wpa: Import all files for KRACK patch. 55-freebsd-126-freebsd-12
(edit) @a506ba9   11/08/17 10:25:59 Christian.Mauderer at91_mci: Add timing to read_ivar. 55-freebsd-126-freebsd-12
(edit) @e7f3260   11/08/17 09:44:48 Christian.Mauderer freebsd/bus: Check return value of bus_accessor. 55-freebsd-126-freebsd-12
