@0395c5d
04/03/17 12:10:37 |
Sebastian Huber |
ppp: Update due to API changes
55-freebsd-126-freebsd-12
@0732183
03/14/17 06:15:34 |
Sebastian Huber |
Fix SOCK_CLOEXEC with socket() and socketpair()
Remove SOCK_CLOEXEC …
@5f3722a
03/08/17 08:05:05 |
Sebastian Huber |
if_tsec: Enable FDT support
@c1205ee
03/02/17 15:29:11 |
Sebastian Huber |
FDT(4): Port to RTEMS
@f0dd0c5
03/02/17 15:28:14 |
Sebastian Huber |
FDT(4): Import from FreeBSD
@517e229
03/06/17 06:41:44 |
Sebastian Huber |
media01: Add cpuinfo command
@18a623e
03/06/17 11:07:32 |
Sebastian Huber |
Provide strtoq() and strtouq()
@08f4881
03/06/17 11:07:13 |
Sebastian Huber |
NETSTAT(1): Disable unused functions
@6bc5190
03/06/17 11:06:38 |
Sebastian Huber |
Disable unused pfil_try_rlock()
@5268338
03/06/17 11:06:19 |
Sebastian Huber |
Provide sbuf_hexdump()
@57ba8ad
03/06/17 11:05:54 |
Sebastian Huber |
Avoid kern_unsetenv()
@ae9e46d
03/01/17 09:49:05 |
Sebastian Huber |
Fix dw_mmc dependencies
@045ff6e
02/21/17 14:26:31 |
Sebastian Huber |
Add poll() and select() support for Termios
@631fb98
02/21/17 11:57:34 |
Sebastian Huber |
netshell01: Add license, fix format
@5e093a5
02/22/17 10:49:33 |
Sebastian Huber |
SLEEPQUEUE(9): Fix absolute timeouts
The FreeBSD kernel timeouts are …
@2a5d001
02/21/17 07:34:58 |
Sebastian Huber |
C11/C++11 are the default for the RTEMS 4.12 GCC
@284ff16
02/21/17 07:34:09 |
Sebastian Huber |
Update due to configuration API changes
@a739190
02/14/17 10:55:18 |
Sebastian Huber |
SYSCTL(8): Fix command line option processing
@9f2205a
01/30/17 16:58:16 |
kevin-kirspel |
Port LPC32XX Ethernet and USB OHCI to RTEMS
@803a495
01/30/17 16:58:15 |
kevin-kirspel |
Adding LPC32XX ethernet driver support
@5382f639
01/30/17 16:58:24 |
kevin-kirspel |
Add support for LPC32XX cache
@ea395a7
01/30/17 16:58:18 |
kevin-kirspel |
Add ordered Nexus devices
Add support for ordering the initialization …
@2c4840f
02/13/17 07:38:45 |
Sebastian Huber |
README.waf: Change BSP, add QEMU command line
@1fd5083
01/31/17 08:50:45 |
Sebastian Huber |
SLEEPQUEUE(9): Add wmesg to thread wait info
@ee94f8a
01/31/17 08:49:49 |
Sebastian Huber |
rtems-bsd-mutex: Use thread queue name
@c6b85e8
01/17/17 10:01:44 |
Christian.Mauderer |
userspace tools: Regenerate headers.
@46d0378
01/17/17 11:00:55 |
userspace-header-gen: Don't generate first array size.
@120caa6
12/14/16 13:10:18 |
testsuite/commands01: Add wlanstats call.
@ecda181
12/09/16 10:51:50 |
freebsd/wlanstats: Port to FreeBSD.
@d415406
12/09/16 08:15:24 |
freebsd/wlanstats: Import from FreeBSD.
@d686d7b
11/30/16 15:41:12 |
wlan/run: Add firmware.
@edf32f2
11/18/16 10:13:11 |
rtwn: Port to RTEMS
@0cbb715
11/22/16 09:41:47 |
rtwn: Import from FreeBSD.
@9bc41d0
12/12/16 09:51:42 |
lib80211/regdomain: Port to RTEMS.
@bce3e5e
11/18/16 13:59:56 |
lib80211/regdomain: Import from FreeBSD.
@20fa599
11/18/16 10:11:27 |
firmware-gen.py: Add script to generate firmware c files.
@e9a8b5a
11/17/16 08:15:27 |
wlan ratectl and sta: Call init.
@5c3223f
11/16/16 15:29:17 |
ifconfig/wlan, expat, lib80211: Port to RTEMS.
@2389539
11/16/16 14:02:20 |
ifconfig/wlan, expat, lib80211: Import from FreeBSD.
@59338de
12/12/16 11:23:40 |
Port USB and USB WLAN.
@d145449
11/14/16 12:30:48 |
Import USB and USB WLAN from FreeBSD.
@66eb143
12/12/16 12:09:09 |
firmware: Port to RTEMS.
@2e8dd24
11/16/16 12:20:05 |
firmware: Import from FreeBSD.
@efc782b
12/12/16 11:31:33 |
Port IEEE 802.11.
@a241ea8
11/14/16 12:46:13 |
Import IEEE 802.11 from FreeBSD.
@172f2ac
01/12/17 13:56:23 |
Sebastian Huber |
Use thread name support
Update #2858.
@fb288fa
01/11/17 13:15:31 |
Sebastian Huber |
ROUTE(8): Disable routing socket timeout support
FIXME: This reverts …
@f11bfc2
01/11/17 13:01:17 |
Sebastian Huber |
rtems-bsd-mutex: Add SMP lock debug support
@e5ef01e
01/11/17 10:52:41 |
Sebastian Huber |
rtems-bsd-mutex: Update due to API changes
@9e8ce9ae
01/10/17 13:41:23 |
Sebastian Huber |
pf: Some fixes after the update
@774f19f
01/10/17 13:40:29 |
Sebastian Huber |
devfs: Fix typo
@851722b
01/10/17 13:00:53 |
Sebastian Huber |
Declare feature_present()
@3dff21a
01/10/17 13:00:20 |
Sebastian Huber |
Remove obsolete PF files
@64c663c
01/10/17 07:04:58 |
Sebastian Huber |
ARP(8): Port to RTEMS
@246b61e
01/10/17 06:58:50 |
Sebastian Huber |
ARP(8): Import from FreeBSD
@0577772
01/09/17 13:47:04 |
Sebastian Huber |
Update to FreeBSD head 2017-01-09
Git mirror commit …
@75b706f
12/09/16 13:19:03 |
Sebastian Huber |
Update to FreeBSD head 2016-12-10
Git mirror commit …
@c4e89a9
11/10/16 12:52:08 |
Sebastian Huber |
VMSTAT(8): Port to RTEMS
@dba2dfc
11/10/16 12:25:27 |
Sebastian Huber |
VMSTAT(8): Import from FreeBSD
@2360b08
09/07/15 06:33:16 |
Sebastian Huber |
if_dwc: Invalidate read buffer again
This may prevent problems in …
@3ef41be
01/10/17 08:16:17 |
Sebastian Huber |
if_dwc: Use explicit cache operations
@0436d64
01/09/17 10:43:40 |
Sebastian Huber |
if_dwc: Reduce DMA descriptor count
@88dad3b
01/09/17 10:41:24 |
Sebastian Huber |
if_dwc: Use rtems_bsd_get_mac_address()
@f8ed8cd
03/26/15 14:21:07 |
Sebastian Huber |
if_dwc: Add nexus device support
@c07da01
09/07/15 06:34:34 |
Sebastian Huber |
if_dwc: Fix a possible interrupt starvation
@051b634
04/07/15 11:54:23 |
Sebastian Huber |
if_dwc: Avoid mbuf use after free
@b99c023
03/30/15 12:30:04 |
Sebastian Huber |
if_dwc: Checksum offload
@5deeb69
03/27/15 13:16:40 |
Sebastian Huber |
if_dwc: Avoid tx defrag if possible
Drop packets in case of resource …
@d9ff828
03/30/15 09:51:36 |
Sebastian Huber |
if_dwc: Simplify tx desc setup
@9410212
03/30/15 07:51:18 |
Sebastian Huber |
if_dwc: Fix transmit starvation
@6cd057d
01/10/17 07:52:14 |
Sebastian Huber |
if_dwc: Fix IFCOUNTER_IPACKETS statistics
Input packets are counted …
@ec2e4b1
01/09/17 12:24:33 |
Sebastian Huber |
if_dwc: Fix IFCOUNTER_OPACKETS statistics
Output packets are counted …
@e392c989
03/27/15 10:14:44 |
Sebastian Huber |
if_dwc: Move interrupt handler install
@46f0b8b
01/09/17 08:41:29 |
Sebastian Huber |
Enable multi-cast routing support
@95a3ba8
01/09/17 07:50:55 |
Sebastian Huber |
NETSTAT(1): Fix name list initialization
@b86b097
10/24/16 11:30:37 |
Sebastian Huber |
Fix warings in <sys/seq.h>
@11750f1
10/24/16 11:14:35 |
Sebastian Huber |
Fix warnings in <sys/refcount.h>
@2956924
10/24/16 10:00:55 |
Sebastian Huber |
Fix atomic ops in <sys/buf_ring.h>
@c40e45b
10/07/16 13:10:20 |
Sebastian Huber |
Update to FreeBSD head 2016-08-23
Git mirror commit …
@8c0eeba
08/10/16 13:20:42 |
userspace-header-gen.py: Simplify program ports
@750b2d4
01/09/17 13:54:21 |
Sebastian Huber |
Workaround for <sys/event.h> update
55-freebsd-126-freebsd-12freebsd-9.3
@fbfdc2b
12/23/16 14:01:43 |
Sebastian Huber |
Update due to Newlib 2.5.0
@b1580fb
12/21/16 19:01:28 |
kevin-kirspel |
PIPE(2): Port to RTEMS
@6959fac
12/21/16 19:01:26 |
kevin-kirspel |
PIPE(2): Import from FreeBSD
@546b38d
12/15/16 08:43:23 |
Sebastian Huber |
Add BRIDGE(4) support to configuration
@e3dac66
12/07/16 06:15:02 |
Sebastian Huber |
pfctl: Update due to linker set API changes
@afda2c7
11/29/16 05:13:52 |
Chris Johns |
debugger: Set the fd to -1 to indicate being disconnected.
@f7a4107
11/28/16 03:23:15 |
Chris Johns |
Add a RTEMS Debugger TCP remote transport.
The patch also adds …
@269b559
11/24/16 11:01:28 |
Sebastian Huber |
ftpd: Use floating-point tasks due to syslog()
@cfec446
11/23/16 13:17:25 |
Sebastian Huber |
SLEEPQUEUE(9): Properly remove timeout timer
@616ffa96
11/23/16 13:16:05 |
Sebastian Huber |
Use _Thread_Dispatch_direct()
@87e3b46
11/23/16 13:13:48 |
Sebastian Huber |
@34545ad
10/25/16 08:19:23 |
Sebastian Huber |
Use -Wno-pointer-sign
Pointer sign warnings are quite common in …
@b01ce52
11/10/16 12:25:58 |
Sebastian Huber |
Fix errno redefined warning
@c418b7a
11/10/16 13:58:58 |
Sebastian Huber |
Fix mbuf_jumbo_alloc()
@7614758
11/14/16 09:17:55 |
Sebastian Huber |
Revert "rtems-kernel-page: Panic on recursive reclaim"
This attempt …
@e49f301
11/10/16 09:49:43 |
Sebastian Huber |
Fix default network memory configuration
@6517105
11/10/16 09:38:04 |
Sebastian Huber |
@6254bf4
11/09/16 09:26:17 |
Sebastian Huber |
SDHCI(4): Delete
Delete heavily modified SDHCI(4) support. It must …
@c00312a
10/24/16 07:05:34 |
Sebastian Huber |
Provide O_CLOEXEC
