source: rtems-libbsd
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @d62a3df   Jan 17, 2018, 12:28:45 PM Sebastian Huber sdk_dpaa: Port to RTEMS Update #3277. 5-freebsd-12
(edit) @f5ed3aa   Oct 27, 2017, 9:50:01 AM Sebastian Huber sdk_dpaa: Import from QorIQ SDK Linux … 5-freebsd-12
(edit) @0f6ff4a   Jan 10, 2018, 2:08:19 PM Sebastian Huber dpaa: QMan portal only initialization Update #3277. 5-freebsd-12
(edit) @a7d252c   Jan 12, 2018, 12:22:10 PM Sebastian Huber dpaa: Add and use bman_new_pool_for_bpid() Update #3277. 5-freebsd-12
(edit) @95fe5b1   Jan 10, 2018, 12:19:01 PM Sebastian Huber dpaa: Use device tree throughout in BMan init Update #3277. 5-freebsd-12
(edit) @1342fad   Jan 17, 2018, 12:49:44 PM Sebastian Huber dpaa: Add and use SDK_DPAA_COMPAT_STATIC Update #3277. 5-freebsd-12
(edit) @34b7ccc   Jan 9, 2018, 10:45:31 AM Sebastian Huber dpaa: Support FQ_TYPE_RX_PCD Update #3277. 5-freebsd-12
(edit) @bdf99316   Jan 12, 2018, 12:23:24 PM Sebastian Huber dpaa: Disable unused bman_pool members Update #3277. 5-freebsd-12
(edit) @2fba1e4   Jan 23, 2018, 9:48:19 AM Sebastian Huber dpaa: Remove unused configuration defines Update #3277. 5-freebsd-12
(edit) @cfc149b   Jan 10, 2018, 1:11:57 PM Sebastian Huber linux/of_irq.h: Generalize of_irq_to_resource() Determine interrupt … 5-freebsd-12
(edit) @e4923c8   Jan 17, 2018, 1:30:44 PM Sebastian Huber linux/of_address.h: of_address_to_resource() Translate address in … 5-freebsd-12
(edit) @0f1d2f6   Jan 10, 2018, 12:18:05 PM Sebastian Huber linux/of_address.h: Add of_translate_address() Update #3277. 5-freebsd-12
(edit) @81fc57d   Jan 17, 2018, 1:14:30 PM Sebastian Huber linux/of.h: Add of_find_node_by_path() Update #3277. 5-freebsd-12
(edit) @44fca38   Jan 17, 2018, 1:14:10 PM Sebastian Huber linux/of.h: Add of_read_number() Update #3277. 5-freebsd-12
(edit) @26ce2ac   Jan 17, 2018, 1:13:53 PM Sebastian Huber linux/of.h: Add of_n_size_cells() Update #3277. 5-freebsd-12
(edit) @0d421d8   Jan 17, 2018, 1:13:34 PM Sebastian Huber linux/of.h: Add of_n_addr_cells() Update #3277. 5-freebsd-12
(edit) @066b536   Jan 17, 2018, 12:26:11 PM Sebastian Huber linux/sort.h: New file Update #3277. 5-freebsd-12
(edit) @583216a   Jan 16, 2018, 12:07:36 PM Sebastian Huber linux/smp.h: Avoid function call overhead Update #3277. 5-freebsd-12
(edit) @fe05886   Nov 2, 2017, 1:29:57 PM Sebastian Huber linux/compiler.h: Define cold Update #3277. 5-freebsd-12
(edit) @2253814   Jan 23, 2018, 10:52:50 AM Sebastian Huber Add rtems_bsd_ifconfig() 5-freebsd-12
(edit) @13c4093   Jan 17, 2018, 10:48:36 AM Sebastian Huber ehci_mpc83xx.c: Fix for qoriq hypervisor guest 5-freebsd-12
(edit) @ea121a0   Jan 16, 2018, 12:06:39 PM Sebastian Huber ZONE(9): Avoid function call overhead 5-freebsd-12
(edit) @4e17f14   Jan 8, 2018, 12:54:29 PM Sebastian Huber DEVICE(9): Fix BUS_ACCESSOR() 5-freebsd-12
(edit) @4e3a5d3   Dec 22, 2017, 12:18:25 PM Sebastian Huber openssl: Remove superfluous file 5-freebsd-12
(edit) @b1649d6   Nov 29, 2017, 2:26:54 PM Sebastian Huber Add rtems_bsd_initialize_dhcp() 5-freebsd-12
(edit) @9569b39   Nov 17, 2017, 1:23:55 PM Christian.Mauderer at91_mci: Fix for 32k buffer. 5-freebsd-12
(edit) @c360b1a   Nov 17, 2017, 9:49:59 AM Sebastian Huber Revert "RWLOCK(9): Add reader/writer lock implementation" This was … 5-freebsd-12
(edit) @b5822c2   Nov 17, 2017, 9:49:31 AM Sebastian Huber Revert "SX(9): Implement with reader/writer lock" This was … 5-freebsd-12
(edit) @cc7a8d8   Nov 15, 2017, 10:49:09 AM Sebastian Huber SX(9): Implement with reader/writer lock 5-freebsd-12
(edit) @97a98f6   Nov 14, 2017, 11:57:01 AM Sebastian Huber RWLOCK(9): Add reader/writer lock implementation 5-freebsd-12
(edit) @344b8e6   Nov 16, 2017, 7:17:03 AM Sebastian Huber LOCKING(9): Remove dead code (DDB) 5-freebsd-12
(edit) @3f23fcd   Nov 16, 2017, 7:15:37 AM Sebastian Huber LOCKING(9): Remove dead code (KDTRACE_HOOKS) 5-freebsd-12
(edit) @9c1490a   Nov 14, 2017, 12:06:39 PM Sebastian Huber LOCKING(9): Update to current FreeBSD version 5-freebsd-12
(edit) @b03a1c0   Nov 15, 2017, 12:24:29 PM Sebastian Huber Fix file descriptor reference counting in accept() Update #3132. 5-freebsd-12
(edit) @06f06d4   Nov 10, 2017, 1:19:29 PM Sebastian Huber Fix warning 5-freebsd-12
(edit) @4525674   Nov 10, 2017, 1:04:48 PM Sebastian Huber tcpdump: Fix import/export 5-freebsd-12
(edit) @9521c08   Nov 9, 2017, 1:35:13 PM Christian.Mauderer wpa_supplicant: Use arc4random instead of getentropy. 5-freebsd-12
(edit) @bc4bb2e   Oct 17, 2017, 5:22:36 PM gordon Update wpa_supplicant/hostapd for 2017-01 vulnerability release. … 5-freebsd-12
(edit) @bdc4f21   Nov 8, 2017, 1:11:09 PM Christian.Mauderer wpa: Port to new files to RTEMS. 5-freebsd-12
(edit) @b0f0b2f   Nov 8, 2017, 1:10:40 PM Christian.Mauderer wpa: Import all files for KRACK patch. 5-freebsd-12
(edit) @a506ba9   Nov 8, 2017, 10:25:59 AM Christian.Mauderer at91_mci: Add timing to read_ivar. 5-freebsd-12
(edit) @e7f3260   Nov 8, 2017, 9:44:48 AM Christian.Mauderer freebsd/bus: Check return value of bus_accessor. 5-freebsd-12
(edit) @ec29b2a   Nov 7, 2017, 3:17:55 PM Christian.Mauderer at91_mci: Port to RTEMS and adapt for atsam. 5-freebsd-12
(edit) @ea5880a   Aug 23, 2016, 11:16:53 AM Sebastian Huber at91_mci: Import from FreeBSD 5-freebsd-12
(edit) @5892207   Nov 7, 2017, 2:15:38 PM Christian.Mauderer saf1761_otg: Port to RTEMS. 5-freebsd-12
(edit) @cf8e1d4   Apr 11, 2017, 8:36:12 AM Christian.Mauderer usb/saf1761: Import from FreeBSD. Import the files for the SAF1761 … 5-freebsd-12
(edit) @ddd16bc   Nov 7, 2017, 10:54:39 AM Christian.Mauderer dhcpcd: Don't ignore interface on transient errors. In case of WPA on … 5-freebsd-12
(edit) @e5abb31   Nov 8, 2017, 11:43:39 AM Christian.Mauderer libbsd.txt: Describe current state of WLAN. 5-freebsd-12
(edit) @bed8742   Nov 3, 2017, 10:08:48 AM Christian.Mauderer wpa_supplicant: Fix getopt. 5-freebsd-12
(edit) @79ad952   Nov 2, 2017, 2:07:23 PM Christian.Mauderer wpa_supplicant: Include rtems-bsd-program.h. 5-freebsd-12
(edit) @4613db0   Nov 2, 2017, 1:34:35 PM Christian.Mauderer wpa_supplicant: Add lock. 5-freebsd-12
(edit) @ee0c369   Nov 2, 2017, 1:08:10 PM Christian.Mauderer wpa_supplicant: Move forking command into own file. The malloc … 5-freebsd-12
(edit) @ce2262e   Oct 12, 2017, 12:16:09 PM 1473996754 Add wpa_supplicant_fork command. Add fork command for wpa supplicant … 5-freebsd-12
(edit) @0aa7e63   Oct 12, 2017, 12:16:08 PM 1473996754 Add wpa_supplicant command in test suite. Add wpa supplicant command … 5-freebsd-12
(edit) @8f2267b   Oct 12, 2017, 12:16:07 PM 1473996754 Port wpa supplicant to RTEMS. Add wpa_supplicant lib support and … 5-freebsd-12
(edit) @9c9d11b   Aug 1, 2017, 12:43:41 PM 1473996754 Import wpa from FreeBSD 5-freebsd-12
(edit) @847de24   Nov 10, 2017, 12:32:14 PM Sebastian Huber Fix build for non-FDT platforms 5-freebsd-12
(edit) @7c68f4e   Nov 8, 2017, 1:43:32 PM 1473996754 Port BBB sd driver files to RTEMS. So BBB can mount and read eMMC and … 5-freebsd-12
(edit) @7e52ab9   Nov 8, 2017, 1:43:31 PM 1473996754 Import BBB sd driver files from FreeBSD. 5-freebsd-12
(edit) @896f068   Nov 10, 2017, 10:53:07 AM Sebastian Huber tests/syscalls01: Fix shutdown() test The socket must be connected … 5-freebsd-12
(edit) @23cd284   Nov 10, 2017, 10:48:51 AM Sebastian Huber Add rtems_bsd_ifconfig_lo0() 5-freebsd-12
(edit) @eeeda4b   Nov 10, 2017, 10:17:13 AM Sebastian Huber tests/syscall01: Update error values FreeBSD changed the error values. 5-freebsd-12
(edit) @057656b   Nov 10, 2017, 10:15:35 AM Sebastian Huber Disable HHOOK(9) support for sockets Support was only partly disabled … 5-freebsd-12
(edit) @72d5fa1   Nov 10, 2017, 10:01:39 AM Sebastian Huber Fix reference counting for file descriptors Update #3132. 5-freebsd-12
(edit) @b15a719   Nov 9, 2017, 1:28:55 PM Sebastian Huber Change RTEMS version to 5 Update #3220. 5-freebsd-12
(edit) @c64806c   Nov 9, 2017, 1:28:37 PM Sebastian Huber tests/mutex01: Fix mtx_recursed() usage 5-freebsd-12
(edit) @6fbcf2e   Nov 9, 2017, 1:28:17 PM Sebastian Huber tests/program01: Fix test name 5-freebsd-12
(edit) @45149ec   Oct 26, 2017, 1:02:24 PM Sebastian Huber Fix general PowerPC build 5-freebsd-12
(edit) @936b597   Oct 26, 2017, 6:43:53 AM Sebastian Huber ffec: Fix comment Update #3090. 5-freebsd-12
(edit) @a8a9cf1   Oct 25, 2017, 8:17:23 AM Sebastian Huber ffec: Add checksum offload Update #3090. 5-freebsd-12
(edit) @0323c28   Oct 25, 2017, 6:01:27 AM Sebastian Huber ffec: Add interrupt coalescing support Code is an adapted from the … 5-freebsd-12
(edit) @fd5ee57   Oct 25, 2017, 11:25:15 AM Sebastian Huber ffec: Increase buffer descriptor count to 512 Update #3090. 5-freebsd-12
(edit) @0cb4075   Oct 24, 2017, 10:17:00 AM Sebastian Huber ffec: Defragment transmit mbuf only if necessary Use structure … 5-freebsd-12
(edit) @798d308   Oct 24, 2017, 12:11:56 PM Sebastian Huber ffec: Fix NULL pointer access Update #3090. 5-freebsd-12
(edit) @b8fdbe2   Oct 4, 2017, 12:15:59 PM Sebastian Huber ffec: Use RACC[SHIFT16] This avoids the move of entire receive frames … 5-freebsd-12
(edit) @2fcf5aa   Oct 24, 2017, 10:19:28 AM Sebastian Huber rtems-bsd-mutex: Update due to API changes Update #3117. 5-freebsd-12
(edit) @445d59e   Oct 24, 2017, 6:15:06 AM Sebastian Huber Remove ability to synchronize with Linux 5-freebsd-12
(edit) @1dd58e4   Oct 24, 2017, 6:14:26 AM Sebastian Huber Remove Linux submodule 5-freebsd-12
(edit) @fb84af0   Oct 24, 2017, 5:42:36 AM Sebastian Huber Fix install arch-specific header files 5-freebsd-12
(edit) @a677fe9   Oct 23, 2017, 7:11:15 AM Sebastian Huber dpaa: Use only one FMan MAC SGT zone 5-freebsd-12
(edit) @b1fd51c   Oct 20, 2017, 12:55:13 PM Sebastian Huber dpaa: Reduce receive buffer seed Seed the receive buffers of each … 5-freebsd-12
(edit) @33356a8   Aug 23, 2017, 8:08:16 AM Sebastian Huber dpaa: Improve QMan portal initialization Be less dependent on the … 5-freebsd-12
(edit) @24866e6   Aug 23, 2017, 7:59:31 AM Sebastian Huber dpaa: Reduce PFDR space from 32MiB to 16MiB 5-freebsd-12
(edit) @de5791b   Jul 13, 2017, 6:31:46 AM Sebastian Huber dpaa: Add "libbsd,dedicated-portal" to QMan portals By default, the … 5-freebsd-12
(edit) @e818128   Jun 23, 2017, 9:39:26 AM Sebastian Huber dpaa: Add "libbsd,dequeue" to QMan portals The dequeue support for … 5-freebsd-12
(edit) @3cfc31c   Jul 11, 2017, 12:53:42 PM Sebastian Huber dpaa: Set portal interrupt affinity 5-freebsd-12
(edit) @ef1655c   Jul 10, 2017, 7:19:10 AM Sebastian Huber Update to Linux 4.12 Linux baseline … 5-freebsd-12
(edit) @e3dc39e   Jun 27, 2017, 10:51:07 AM Sebastian Huber dpaa: Add <soc/fsl/dpaa.h> 5-freebsd-12
(edit) @9789434   Jun 27, 2017, 7:31:34 AM Sebastian Huber linux: Move upper_32_bits() and lower_32_bits() 5-freebsd-12
(edit) @65d6fa2   Jun 27, 2017, 7:31:11 AM Sebastian Huber linux: Make Linux types available in user-space 5-freebsd-12
(edit) @0de65a8   Jun 27, 2017, 7:30:44 AM Sebastian Huber linux: Include missing <sys/errno.h> 5-freebsd-12
(edit) @9cc419f   Jun 27, 2017, 6:36:05 AM Sebastian Huber Install Linux header files 5-freebsd-12
(edit) @33d82be1   Jun 27, 2017, 6:34:53 AM Sebastian Huber waf: Install arch-specific header files 5-freebsd-12
(edit) @e846288   Jun 21, 2017, 12:35:19 PM Sebastian Huber Add rtems_bsd_set_if_input() 5-freebsd-12
(edit) @07c8680   May 24, 2017, 11:16:11 AM Sebastian Huber dpaa: Get c45 ids 5-freebsd-12
(edit) @03d1426   May 24, 2017, 11:15:14 AM Sebastian Huber dpaa: No error if MII attach failed 5-freebsd-12
(edit) @9da83e7   May 24, 2017, 6:32:09 AM Sebastian Huber dpaa: Support c45 phys 5-freebsd-12
(edit) @66e83e0e   May 19, 2017, 7:47:45 AM Sebastian Huber soc/qbman: Simplify bman_release() Get the affine portal only once … 5-freebsd-12
(edit) @1908686   May 19, 2017, 7:41:16 AM Sebastian Huber soc/qman: Do not enable stashing without PAMU Do not enable stashing … 5-freebsd-12
(edit) @e2d48f5   May 19, 2017, 7:31:15 AM Sebastian Huber dpaa: Implement GENMASK() similar to Linux 5-freebsd-12
