# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 05/04/24 12:40:03 Tue, 22 Sep 2020 15:43:50 GMT Sebastian Huber [cb1faf6] * freebsd/sys/or1k/include/machine/in_cksum.h (added) * libbsd.py (modified) Add or1k support Tue, 22 Sep 2020 15:49:20 GMT Sebastian Huber [1c2cc5b] * freebsd/sys/contrib/ck/include/ck_pr.h (modified) ck: Use default implementation < ARMv6 Wed, 08 Jul 2020 09:17:38 GMT Sebastian Huber [f1f0362] * waf_libbsd.py (modified) build: Ensure mandatory compiler/linker flags Tue, 15 Sep 2020 01:20:44 GMT Chris Johns [089780d] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) * wscript (modified) waf: Implement module dependency checking in the build system - Do ... Wed, 02 Sep 2020 23:54:27 GMT Chris Johns [025af7c] * builder.py (modified) * buildset/default.ini (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) * wscript (modified) build: Separate the kernel and user land include paths - Provide ... Tue, 01 Sep 2020 06:55:06 GMT Chris Johns [c8c03f7] * builder.py (modified) * freebsd-to-rtems.py (modified) waf: Add a config report Tue, 01 Sep 2020 04:01:14 GMT Chris Johns [93effa4] * builder.py (modified) * waf_libbsd.py (modified) * wscript (modified) waf: Reformat to PEP8 using yapf Sun, 13 Sep 2020 08:07:50 GMT Sebastian Huber [5eed6ac] * rtemsbsd/rtems/rtems-bsd-cxx.cc (modified) rtems-bsd-cxx: Undefine _GNU_SOURCE At least the powerpc C++ ... Mon, 07 Sep 2020 15:44:17 GMT Sebastian Huber [2abb02eb] * libbsd.py (modified) * testsuite/mcast01/test_main.c (added) mcast01: Add test program Mon, 07 Sep 2020 08:03:31 GMT Sebastian Huber [272d5f5] * Makefile.todo (modified) * freebsd/usr.sbin/ifmcstat/ifmcstat.c (modified) * freebsd/usr.sbin/ifmcstat/printb.c (modified) * freebsd/usr.sbin/ifmcstat/rtems-bsd-ifmcstat-data.h (added) * freebsd/usr.sbin/ifmcstat/rtems-bsd-ifmcstat-ifmcstat-data.h (added) * freebsd/usr.sbin/ifmcstat/rtems-bsd-ifmcstat-namespace.h (added) * freebsd/usr.sbin/ifmcstat/rtems-bsd-ifmcstat-printb-data.h (added) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-ifmcstat.c (added) * testsuite/media01/test_main.c (modified) ifmcstat: Port to RTEMS Mon, 07 Sep 2020 07:39:22 GMT Sebastian Huber [11bdcef] * freebsd/usr.sbin/ifmcstat/ifmcstat.c (added) * freebsd/usr.sbin/ifmcstat/printb.c (added) ifmcstat: Import from FreeBSD Wed, 08 Jul 2020 11:13:54 GMT Sebastian Huber [03d7f76] * rtemsbsd/nfsclient/nfs.c (modified) nfsclient: Next attempt to fix 64-bit targets In serporidok use the ... Thu, 06 Aug 2020 11:21:00 GMT Sebastian Huber [d964a67] * testsuite/media01/test_main.c (modified) * testsuite/netshell01/test_main.c (modified) * testsuite/pf02/test_main.c (modified) * testsuite/ppp01/test_main.c (modified) * testsuite/telnetd01/test_main.c (modified) * testsuite/zerocopy01/test_main.c (modified) telnet: Use rtems_shell_dup_current_env() Update #3859. Wed, 05 Aug 2020 12:49:11 GMT Sebastian Huber [bd7e6ee] * rtemsbsd/rtems/rtems-kernel-bus-dma.c (modified) Conditionally include Remove superfluous ... Wed, 05 Aug 2020 11:21:46 GMT Sebastian Huber [c4233ce] * ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h (modified) racoon: Change type due to Newlib API changes Wed, 29 Jul 2020 08:18:17 GMT Christian Mauderer [9abf1d3] * testsuite/epoch01/test_main.c (modified) * testsuite/evdev01/init.c (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/include/rtems/bsd/test/default-termios-init.h (modified) * testsuite/smp01/test_main.c (modified) * testsuite/swi01/init.c (modified) * testsuite/timeout01/init.c (modified) * testsuite/usb01/init.c (modified) * testsuite/usbkbd01/init.c (modified) * testsuite/usbmouse01/init.c (modified) * testsuite/usbserial01/init.c (modified) testsuite: Use new name of test-info.h. In RTEMS the test.h has ... Wed, 27 May 2020 11:49:08 GMT Christian Mauderer [97dc907] * freebsd/sys/dev/ffec/if_ffec.c (modified) if_ffec: Align send buffers to cache if necessary. Wed, 27 May 2020 07:55:43 GMT Christian Mauderer [7e453ad] * rtemsbsd/include/rtems/bsd/local/opt_usb.h (modified) imx: Don't use USB_NEED_BUSDMA_COHERENT_ALLOC That option makes ... Wed, 27 May 2020 08:08:01 GMT Christian Mauderer [5e37800] * rtemsbsd/rtems/rtems-kernel-bus-dma.c (modified) busdma: Don't sync nocache memory on ARM The busdma shouldn't try ... Wed, 27 May 2020 07:55:06 GMT Christian Mauderer [bbdac23] * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c (modified) rtwn_usb: Make sure buffers are cache aligned Thu, 02 Apr 2020 14:42:43 GMT Christian Mauderer [cdd6003] * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_busdma.h (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (modified) * rtemsbsd/rtems/rtems-kernel-bus-dma-mbuf.c (modified) * rtemsbsd/rtems/rtems-kernel-bus-dma.c (modified) busdma: Option to round to cache lines on sync Some targets support ... Wed, 20 May 2020 08:50:06 GMT Christian Mauderer [1398d93] * freebsd/sys/arm/freescale/imx/imx_gpio.c (deleted) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/sys/arm/freescale/imx/imx_rtems_gpio.c (added) imx: Use RTEMS GPIO driver instead of FreeBSD one Update 3869 Tue, 12 May 2020 06:45:29 GMT Christian Mauderer [4c762de] * freebsd/sys/dev/gpio/gpioregulator.c (deleted) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) gpioregulator: Remove. There is a bug in the #ifdef regarding FDT ... Wed, 29 Jul 2020 08:56:06 GMT Christian Mauderer [d044b29] * wscript (modified) wscript: Update RTEMS version to 6. Wed, 08 Jul 2020 08:21:20 GMT Sebastian Huber [26866d2] * rtemsbsd/rtems/rtems-bsd-init-dhcp.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Fix linker errors with minimal build set Mon, 15 Jun 2020 05:18:23 GMT Sebastian Huber [36a19bfd] * waf_libbsd.py (modified) build: Do not convert cflags to defines This makes it possible to ... Thu, 18 Jun 2020 12:22:10 GMT Sebastian Huber [7d194e5] * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.h (modified) * mDNSResponder/mDNSPosix/mDNSUNP.c (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/mDNSDebug.c (modified) * testsuite/foobarserver/test_main.c (modified) mDNSResponder: Port to RTEMS Update #4010. Thu, 18 Jun 2020 11:13:40 GMT Sebastian Huber [2cd9511] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/dnssec.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSDebug.h (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/DNS64.c (modified) * mDNSResponder/mDNSMacOSX/DNS64.h (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnsextd.c (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/unittests/uds_daemon_ut.c (modified) mDNSResponder: Update to v878.270.2 The sources can be obtained ... Thu, 18 Jun 2020 11:13:05 GMT Sebastian Huber [d58e81b] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) mDNSResponder: Update to v878.260.1 The sources can be obtained ... Thu, 18 Jun 2020 11:12:03 GMT Sebastian Huber [d49a862] * mDNSResponder/Clients/dnssdutil.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSMacOSX/BATS/mDNSResponder.plist (added) * mDNSResponder/mDNSMacOSX/dnssdutil-entitlements.plist (added) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) mDNSResponder: Update to v878.250.4 The sources can be obtained ... Thu, 18 Jun 2020 11:10:44 GMT Sebastian Huber [8aace47] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSCore/uDNS.h (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) mDNSResponder: Update to v878.240.1 The sources can be obtained ... Thu, 18 Jun 2020 11:09:27 GMT Sebastian Huber [a8a0ba9] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnsextd.c (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) * mDNSResponder/unittests/CNameRecordTests.c (modified) mDNSResponder: Update to v878.230.2 The sources can be obtained ... Thu, 18 Jun 2020 11:07:18 GMT Sebastian Huber [c6d65fa] * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnssdutil.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSDebug.h (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/D2D.c (modified) * mDNSResponder/mDNSMacOSX/DNS64.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.h (modified) * mDNSResponder/mDNSMacOSX/LoggingProfiles/AppleInternal/com.apple.mDNSResponder.plist (added) * mDNSResponder/mDNSMacOSX/LoggingProfiles/com.apple.mDNSResponder.plist (added) * mDNSResponder/mDNSMacOSX/Metrics.h (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/Private/com.apple.mDNSResponder.plist (deleted) * mDNSResponder/mDNSMacOSX/Scripts/bonjour-mcast-diagnose (added) * mDNSResponder/mDNSMacOSX/Scripts/bonjour-start-mdns-tcpdump (added) * mDNSResponder/mDNSMacOSX/Scripts/com.apple.mDNSResponder.mdns-tcpdump.plist (added) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/helper-stubs.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSMacOSX/uDNSPathEvalulation.c (modified) * mDNSResponder/mDNSPosix/ProxyResponder.c (modified) * mDNSResponder/mDNSPosix/Responder.c (modified) * mDNSResponder/mDNSPosix/mDNSUNP.c (modified) * mDNSResponder/mDNSPosix/mDNSUNP.h (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dns_sd_private.h (modified) * mDNSResponder/mDNSShared/dnssd_clientlib.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/mDNSDebug.c (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/unittests/mDNSCoreReceiveTest.c (modified) * mDNSResponder/unittests/mdns_ut.c (modified) * mDNSResponder/unittests/unittest_common.h (modified) mDNSResponder: Update to v878.200.35 The sources can be obtained ... Thu, 18 Jun 2020 11:05:54 GMT Sebastian Huber [0a1f82a] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) mDNSResponder: Update to v878.70.2 The sources can be obtained via: ... Thu, 18 Jun 2020 10:55:21 GMT Sebastian Huber [79fabda] * mDNSResponder/Clients/dnssdutil.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/LegacyNATTraversal.c (modified) * mDNSResponder/mDNSShared/CommonServices.h (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnsextd.conf (modified) mDNSResponder: Update to v878.50.17 The sources can be obtained ... Thu, 18 Jun 2020 10:51:20 GMT Sebastian Huber [a4a6523] * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.1 (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.h (modified) * mDNSResponder/mDNSPosix/mDNSUNP.c (modified) * mDNSResponder/mDNSResponder.sln (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/mDNSDebug.c (modified) * mDNSResponder/mDNSWindows/BonjourQuickLooks.sln (modified) * mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/BonjourQuickLooksInstaller.wixproj (modified) mDNSResponder: Back to mDNSResponder-878.30.4 Update #4010. Tue, 23 Jun 2020 12:10:06 GMT Sebastian Huber [6ac7738] * testsuite/epoch01/test_main.c (modified) epoch01: Fix sporadic test failures Fri, 17 Apr 2020 13:02:20 GMT Christian Mauderer [d38dbbe] * freebsd/sys/arm/freescale/imx/imx6_usbphy.c (modified) imx6_usbphy: Fix regulator (vbus-supply) Update #3869. Fri, 17 Apr 2020 07:08:18 GMT Christian Mauderer [3184227] * freebsd/sys/dev/extres/regulator/regulator.c (modified) * freebsd/sys/dev/gpio/gpioregulator.c (modified) regulator: Disable FDT parts for non-FDT targets Fri, 17 Apr 2020 08:24:08 GMT Jan Sommer [a69293c] * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/kern/subr_gtaskqueue.c (modified) * rtemsbsd/i386/include/machine/clock.h (added) * rtemsbsd/include/rtems/bsd/local/opt_acpi.h (added) i386: Port to RTEMS - Update imported files to compile rtems-libbsd ... Fri, 17 Apr 2020 08:24:07 GMT Jan Sommer [dc86c55] * freebsd/sys/i386/i386/legacy.c (deleted) * freebsd/sys/i386/include/machine/legacyvar.h (deleted) * freebsd/sys/i386/include/machine/specialreg.h (deleted) * rtemsbsd/include/x86/legacyvar.h (added) * rtemsbsd/include/x86/x86_var.h (added) i386: Delete old machine dependent files - The files in the i386 ... Fri, 17 Apr 2020 08:24:06 GMT Jan Sommer [efe9b55] * freebsd/sys/net/iflib.c (modified) iflib.c: Deactivate use of ifc_cpus - cpusets and SMP are currently ... Fri, 17 Apr 2020 08:24:05 GMT Jan Sommer [fb5499a] * freebsd/sys/sys/callout.h (modified) Callout: Redefine callout_reset_on for rtems - callout_reset_on ... Fri, 17 Apr 2020 08:24:04 GMT Jan Sommer [079bdd3] * libbsd.py (modified) i386: Add missing files to build system - Update FreeBSD files in ... Fri, 17 Apr 2020 08:24:03 GMT Jan Sommer [dbf72c2] * libbsd.py (modified) * waf_libbsd.py (modified) waf: Add path-mappings feature - path-mappings allow to fix ... Fri, 17 Apr 2020 08:24:02 GMT Jan Sommer [ce5b52d] * freebsd/sys/net/iflib.c (added) * freebsd/sys/net/iflib_private.h (added) * freebsd/sys/net/mp_ring.c (added) * freebsd/sys/net/mp_ring.h (added) * freebsd/sys/x86/include/machine/intr_machdep.h (added) * freebsd/sys/x86/include/machine/legacyvar.h (added) * freebsd/sys/x86/include/machine/specialreg.h (added) * freebsd/sys/x86/include/machine/x86_var.h (added) * freebsd/sys/x86/x86/legacy.c (added) i386: Add missing files from FreeBSD - Files needed to make ... Thu, 16 Apr 2020 07:52:12 GMT Christian Mauderer [592003f] * freebsd/sys/arm/freescale/imx/imx6_ccm.c (modified) * freebsd/sys/arm/freescale/imx/imx6_usbphy.c (modified) * freebsd/sys/dev/usb/controller/ehci_imx.c (modified) imx: Fix build for all other BSPs. Thu, 05 Mar 2020 13:33:30 GMT Christian Mauderer [b3da96c] * freebsd/sys/arm/freescale/imx/imx6_usbphy.c (modified) imx6_usbphy: Add regulator (vbus-supply). Update #3869. Mon, 11 Feb 2019 08:35:37 GMT Christian Mauderer [2eab546] * freebsd/sys/dev/usb/controller/ehci_imx.c (modified) ehci_imx: Set/clear ENHOSTDISCONNECT in USB PHY. This is not a nice ... Thu, 02 Apr 2020 15:47:43 GMT Christian Mauderer [c5455b0] * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) ehci_imx: Add to build. Wed, 14 Nov 2018 09:40:50 GMT Christian Mauderer [4a2d99b] * freebsd/sys/arm/freescale/imx/imx6_usbphy.c (modified) * freebsd/sys/dev/usb/controller/ehci_imx.c (modified) ehci_imx: Port to RTEMS Update #3869. Wed, 14 Nov 2018 09:40:27 GMT Sebastian Huber [29eda67] * freebsd/sys/arm/freescale/imx/imx6_usbphy.c (added) * freebsd/sys/dev/usb/controller/ehci_imx.c (added) ehci_imx: Import from FreeBSD Update #3869. Thu, 02 Apr 2020 11:44:46 GMT Christian Mauderer [113662d] * rtemsbsd/include/machine/rtems-bsd-cache.h (modified) Add support for i.mx cache. Update #3869. Thu, 13 Feb 2020 09:56:26 GMT Christian Mauderer [24806ee] * Makefile.todo (modified) * buildset/default.ini (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/rtems/bsd/local/regdev_if.h (added) * rtemsbsd/include/rtems/bsd/local/regnode_if.h (added) * rtemsbsd/local/regdev_if.c (added) * rtemsbsd/local/regnode_if.c (added) regulator: Add to build. Update #3869. Thu, 02 Apr 2020 16:04:17 GMT Christian Mauderer [404ad60] * freebsd/sys/dev/extres/regulator/regulator.c (added) * freebsd/sys/dev/extres/regulator/regulator.h (added) * freebsd/sys/dev/extres/regulator/regulator_bus.c (added) * freebsd/sys/dev/extres/regulator/regulator_fixed.c (added) * freebsd/sys/dev/extres/regulator/regulator_fixed.h (added) * freebsd/sys/dev/gpio/gpioregulator.c (added) regulator: Import from FreeBSD. Update #3869. Mon, 11 Feb 2019 12:25:04 GMT Sebastian Huber [10aa08e] * freebsd/sys/arm/freescale/imx/imx_gpio.c (modified) imx gpio port Update #3869. Thu, 02 Apr 2020 15:43:10 GMT Christian Mauderer [3a1d48c] * buildset/default.ini (modified) * libbsd.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) imx6_ccm: Add and build module. Update #3869. Mon, 11 Feb 2019 06:54:57 GMT Sebastian Huber [f88f7a0] * freebsd/sys/arm/freescale/imx/imx6_ccm.c (modified) imx6_ccm: Port to RTEMS Update #3869. Fri, 08 Feb 2019 11:02:05 GMT Sebastian Huber [beabd3b] * freebsd/sys/arm/freescale/imx/imx6_anatopreg.h (added) * freebsd/sys/arm/freescale/imx/imx6_anatopvar.h (added) * freebsd/sys/arm/freescale/imx/imx6_ccm.c (added) * freebsd/sys/arm/freescale/imx/imx6_ccmreg.h (added) * freebsd/sys/arm/freescale/imx/imx6_machdep.h (added) * freebsd/sys/arm/freescale/imx/imx_machdep.h (added) imx6_ccm: Import from FreeBSD Update #3869. Tue, 14 Apr 2020 13:55:33 GMT Sebastian Huber [64c45b5] * freebsd/sys/dev/usb/usb_busdma.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_usb.h (modified) usb_busdma: Add USB_NEED_BUSDMA_COHERENT_ALLOC Some BSPs have a ... Fri, 03 Apr 2020 07:35:23 GMT Moyano, Gabriel [8e33f3b] * testsuite/arphole/test_main.c (modified) * testsuite/cdev01/test_main.c (modified) * testsuite/commands01/test_main.c (modified) * testsuite/condvar01/test_main.c (modified) * testsuite/crypto01/test_main.c (modified) * testsuite/debugger01/test_main.c (modified) * testsuite/dhcpcd01/test_main.c (modified) * testsuite/dhcpcd02/test_main.c (modified) * testsuite/epoch01/test_main.c (modified) * testsuite/evdev01/init.c (modified) * testsuite/foobarclient/test_main.c (modified) * testsuite/foobarserver/test_main.c (modified) * testsuite/ftpd01/test_main.c (modified) * testsuite/ftpd02/test_main.c (modified) * testsuite/init01/test_main.c (modified) * testsuite/ipsec01/test_main.c (modified) * testsuite/lagg01/test_main.c (modified) * testsuite/log01/test_main.c (modified) * testsuite/loopback01/test_main.c (modified) * testsuite/media01/test_main.c (modified) * testsuite/mutex01/test_main.c (modified) * testsuite/netshell01/test_main.c (modified) * testsuite/nfs01/test_main.c (modified) * testsuite/openssl01/test_main.c (modified) * testsuite/openssl02/test_main.c (modified) * testsuite/pf01/test_main.c (modified) * testsuite/pf02/test_main.c (modified) * testsuite/ping01/test_main.c (modified) * testsuite/ppp01/test_main.c (modified) * testsuite/program01/test_main.c (modified) * testsuite/rcconf01/test_main.c (modified) * testsuite/rcconf02/test_main.c (modified) * testsuite/rwlock01/test_main.c (modified) * testsuite/selectpollkqueue01/test_main.c (modified) * testsuite/sleep01/test_main.c (modified) * testsuite/smp01/test_main.c (modified) * testsuite/swi01/init.c (modified) * testsuite/syscalls01/test_main.c (modified) * testsuite/telnetd01/test_main.c (modified) * testsuite/termios/test_main.c (modified) * testsuite/termios01/test_main.c (modified) * testsuite/termios02/test_main.c (modified) * testsuite/termios03/test_main.c (modified) * testsuite/termios04/test_main.c (modified) * testsuite/termios05/test_main.c (modified) * testsuite/termios06/test_main.c (modified) * testsuite/thread01/test_main.c (modified) * testsuite/timeout01/init.c (modified) * testsuite/unix01/test_main.c (modified) * testsuite/usb01/init.c (modified) * testsuite/usbkbd01/init.c (modified) * testsuite/usbmouse01/init.c (modified) * testsuite/usbserial01/init.c (modified) * testsuite/vlan01/test_main.c (modified) * testsuite/zerocopy01/test_main.c (modified) testsuite: A description for each test added Mon, 06 Apr 2020 06:56:55 GMT Chris Johns [816a2f9] * rtems_waf (modified) rtems_waf: Update to origin/master. Closes #3888. Tue, 31 Mar 2020 07:56:40 GMT Sebastian Huber [018fa32] * testsuite/evdev01/init.c (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/include/rtems/bsd/test/default-termios-init.h (modified) * testsuite/swi01/init.c (modified) * testsuite/timeout01/init.c (modified) * testsuite/usb01/init.c (modified) * testsuite/usbkbd01/init.c (modified) * testsuite/usbmouse01/init.c (modified) * testsuite/usbserial01/init.c (modified) testsuite: CONFIGURE_MAXIMUM_FILE_DESCRIPTORS Wed, 01 Apr 2020 09:39:28 GMT Christian Mauderer [cec7e3f] * freebsd/sys/dev/mmc/mmcsd.c (modified) mmcsd: Don't handle multiple hardware partitions. The ... Tue, 31 Mar 2020 08:57:55 GMT Moyano, Gabriel [27ff7e7] * testsuite/arphole/test_main.c (modified) * testsuite/debugger01/test_main.c (modified) * testsuite/evdev01/init.c (modified) * testsuite/foobarclient/test_main.c (modified) * testsuite/foobarserver/test_main.c (modified) * testsuite/ftpd01/test_main.c (modified) * testsuite/ipsec01/test_main.c (modified) * testsuite/media01/test_main.c (modified) * testsuite/netshell01/test_main.c (modified) * testsuite/nfs01/test_main.c (modified) * testsuite/pf02/test_main.c (modified) * testsuite/ppp01/test_main.c (modified) * testsuite/telnetd01/test_main.c (modified) * testsuite/termios/test_main.c (modified) * testsuite/usb01/init.c (modified) * testsuite/usbkbd01/init.c (modified) * testsuite/usbmouse01/init.c (modified) * testsuite/usbserial01/init.c (modified) * testsuite/zerocopy01/test_main.c (modified) testsuite: User input define added Tue, 31 Mar 2020 08:57:54 GMT Moyano, Gabriel [b4937b0] * testsuite/evdev01/init.c (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/include/rtems/bsd/test/default-termios-init.h (modified) * testsuite/swi01/init.c (modified) * testsuite/termios/test_main.c (modified) * testsuite/timeout01/init.c (modified) * testsuite/usb01/init.c (modified) * testsuite/usbkbd01/init.c (modified) * testsuite/usbmouse01/init.c (modified) * testsuite/usbserial01/init.c (modified) * waf_libbsd.py (modified) testsuite: Using RTEMS tester functions at beginning and at the end ... Wed, 25 Mar 2020 07:37:10 GMT Sebastian Huber [835250d] * freebsd/sys/kern/kern_synch.c (modified) Fix INVARIANTS support Sat, 28 Mar 2020 21:59:10 GMT Vijay Kumar Banerjee [236295c] * wscript (modified) wscript: Python2 support for unicode strings in contexts Closes #3909 Wed, 11 Mar 2020 10:05:59 GMT Sebastian Huber [039afd9] * rtemsbsd/nfsclient/rpcio.c (modified) nfsclient: Use a system event for RPC Aviod conflicts with ... Thu, 05 Mar 2020 10:18:05 GMT Chris Johns [3cc039c] * builder.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Change the test configure check for libdebugger to it's lib - ... Fri, 28 Feb 2020 03:04:13 GMT Chris Johns [2b9172c] * rtems_waf (modified) rtems_waf: Update to master (096372fc4504) Closes #3888 Thu, 27 Feb 2020 07:36:15 GMT Sebastian Huber [e562e3b] * waf (modified) waf: Update to waf-2.0.19 Update #3569. Mon, 10 Feb 2020 14:34:55 GMT Sebastian Huber [46b3858] * freebsd-org (modified) * freebsd/contrib/expat/lib/ascii.h (modified) * freebsd/contrib/expat/lib/asciitab.h (modified) * freebsd/contrib/expat/lib/expat.h (modified) * freebsd/contrib/expat/lib/expat_external.h (modified) * freebsd/contrib/expat/lib/iasciitab.h (modified) * freebsd/contrib/expat/lib/internal.h (modified) * freebsd/contrib/expat/lib/latin1tab.h (modified) * freebsd/contrib/expat/lib/nametab.h (modified) * freebsd/contrib/expat/lib/utf8tab.h (modified) * freebsd/contrib/expat/lib/xmlparse.c (modified) * freebsd/contrib/expat/lib/xmlrole.c (modified) * freebsd/contrib/expat/lib/xmlrole.h (modified) * freebsd/contrib/expat/lib/xmltok.c (modified) * freebsd/contrib/expat/lib/xmltok.h (modified) * freebsd/contrib/expat/lib/xmltok_impl.c (modified) * freebsd/contrib/expat/lib/xmltok_impl.h (modified) * freebsd/contrib/expat/lib/xmltok_ns.c (modified) * freebsd/contrib/libpcap/diag-control.h (modified) * freebsd/contrib/libpcap/fmtutils.c (modified) * freebsd/contrib/libpcap/fmtutils.h (modified) * freebsd/contrib/libpcap/ftmacros.h (modified) * freebsd/contrib/libpcap/gencode.c (modified) * freebsd/contrib/libpcap/gencode.h (modified) * freebsd/contrib/libpcap/grammar.c (modified) * freebsd/contrib/libpcap/grammar.h (modified) * freebsd/contrib/libpcap/grammar.y (modified) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/optimize.c (modified) * freebsd/contrib/libpcap/pcap-bpf.c (modified) * freebsd/contrib/libpcap/pcap-common.c (modified) * freebsd/contrib/libpcap/pcap-common.h (modified) * freebsd/contrib/libpcap/pcap-int.h (modified) * freebsd/contrib/libpcap/pcap.c (modified) * freebsd/contrib/libpcap/pcap/compiler-tests.h (modified) * freebsd/contrib/libpcap/pcap/funcattrs.h (modified) * freebsd/contrib/libpcap/pcap/nflog.h (modified) * freebsd/contrib/libpcap/pcap/pcap-inttypes.h (modified) * freebsd/contrib/libpcap/pcap/pcap.h (modified) * freebsd/contrib/libpcap/pcap/sll.h (modified) * freebsd/contrib/libpcap/pcap/socket.h (added) * freebsd/contrib/libpcap/portability.h (modified) * freebsd/contrib/libpcap/savefile.c (modified) * freebsd/contrib/libpcap/scanner.c (modified) * freebsd/contrib/libpcap/scanner.h (modified) * freebsd/contrib/libpcap/scanner.l (modified) * freebsd/contrib/libpcap/sf-pcap.c (modified) * freebsd/contrib/libpcap/sf-pcap.h (modified) * freebsd/contrib/libpcap/sf-pcapng.c (modified) * freebsd/contrib/libpcap/sf-pcapng.h (modified) * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/netdissect.h (modified) * freebsd/contrib/tcpdump/print-802_11.c (modified) * freebsd/contrib/tcpdump/print-aoe.c (modified) * freebsd/contrib/tcpdump/print-babel.c (modified) * freebsd/contrib/tcpdump/print-bfd.c (modified) * freebsd/contrib/tcpdump/print-bgp.c (modified) * freebsd/contrib/tcpdump/print-bootp.c (modified) * freebsd/contrib/tcpdump/print-dccp.c (modified) * freebsd/contrib/tcpdump/print-decnet.c (modified) * freebsd/contrib/tcpdump/print-domain.c (modified) * freebsd/contrib/tcpdump/print-dvmrp.c (modified) * freebsd/contrib/tcpdump/print-eigrp.c (modified) * freebsd/contrib/tcpdump/print-esp.c (modified) * freebsd/contrib/tcpdump/print-fr.c (modified) * freebsd/contrib/tcpdump/print-hncp.c (modified) * freebsd/contrib/tcpdump/print-icmp.c (modified) * freebsd/contrib/tcpdump/print-icmp6.c (modified) * freebsd/contrib/tcpdump/print-ipnet.c (modified) * freebsd/contrib/tcpdump/print-isakmp.c (modified) * freebsd/contrib/tcpdump/print-juniper.c (modified) * freebsd/contrib/tcpdump/print-l2tp.c (modified) * freebsd/contrib/tcpdump/print-ldp.c (modified) * freebsd/contrib/tcpdump/print-lmp.c (modified) * freebsd/contrib/tcpdump/print-nfs.c (modified) * freebsd/contrib/tcpdump/print-openflow.c (modified) * freebsd/contrib/tcpdump/print-ospf.c (modified) * freebsd/contrib/tcpdump/print-ospf6.c (modified) * freebsd/contrib/tcpdump/print-pflog.c (modified) * freebsd/contrib/tcpdump/print-ppi.c (modified) * freebsd/contrib/tcpdump/print-rsvp.c (modified) * freebsd/contrib/tcpdump/print-rx.c (modified) * freebsd/contrib/tcpdump/print-sflow.c (modified) * freebsd/contrib/tcpdump/print-sl.c (modified) * freebsd/contrib/tcpdump/print-sll.c (modified) * freebsd/contrib/tcpdump/print-smb.c (modified) * freebsd/contrib/tcpdump/print-tcp.c (modified) * freebsd/contrib/tcpdump/print-udp.c (modified) * freebsd/contrib/tcpdump/print-vrrp.c (modified) * freebsd/contrib/tcpdump/print-vtp.c (modified) * freebsd/contrib/tcpdump/print-wb.c (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-namespace.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-dvmrp-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pim-data.h (modified) * freebsd/contrib/tcpdump/signature.c (modified) * freebsd/contrib/tcpdump/smbutil.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/tcpdump/util-print.c (modified) * freebsd/lib/libc/net/nslexer.c (modified) * freebsd/lib/libc/net/nsparser.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/sfp.c (modified) * freebsd/sbin/nvmecontrol/comnd.c (modified) * freebsd/sbin/nvmecontrol/identify.c (modified) * freebsd/sbin/nvmecontrol/identify_ext.c (modified) * freebsd/sbin/nvmecontrol/logpage.c (modified) * freebsd/sbin/nvmecontrol/modules/wdc/wdc.c (modified) * freebsd/sbin/nvmecontrol/nc_util.c (modified) * freebsd/sbin/nvmecontrol/ns.c (modified) * freebsd/sbin/nvmecontrol/nvmecontrol_ext.h (modified) * freebsd/sbin/nvmecontrol/power.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sys/arm/freescale/imx/imx_gpio.c (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/gpio/gpiobus.c (modified) * freebsd/sys/dev/gpio/gpiobusvar.h (modified) * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) * freebsd/sys/dev/kbd/kbd.c (modified) * freebsd/sys/dev/kbd/kbdreg.h (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/nvme/nvme.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/nvme/nvme_ctrlr.c (modified) * freebsd/sys/dev/nvme/nvme_ctrlr_cmd.c (modified) * freebsd/sys/dev/nvme/nvme_pci.c (modified) * freebsd/sys/dev/nvme/nvme_private.h (modified) * freebsd/sys/dev/nvme/nvme_qpair.c (modified) * freebsd/sys/dev/nvme/nvme_sysctl.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/usb_bus.h (modified) * freebsd/sys/dev/usb/usb_device.h (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_firmware.c (modified) * freebsd/sys/kern/subr_gtaskqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/dlt.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_tap.c (deleted) * freebsd/sys/net/if_tap.h (modified) * freebsd/sys/net/if_tapvar.h (deleted) * freebsd/sys/net/if_tun.c (deleted) * freebsd/sys/net/if_tuntap.c (added) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/sff8472.h (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_carp.h (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_dtrace_define.h (deleted) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/signalvar.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/pcpu_aux.h (added) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD stable/12 2020-02-10 Git mirror commit ... Mon, 10 Feb 2020 19:20:54 GMT Sebastian Huber [18cc38e] * testsuite/epoch01/test_main.c (modified) epoch01: Update due to API changes Update #3815. Mon, 10 Feb 2020 18:38:15 GMT Sebastian Huber [ca90847] * testsuite/syscalls01/test_main.c (modified) syscalls01: Fix sporadic test failures Mon, 10 Feb 2020 17:13:07 GMT Sebastian Huber [9d90575] * freebsd/sys/sys/eventhandler.h (modified) EVENTHANDLER(9): Avoid multiple definition errors Mon, 03 Feb 2020 12:32:31 GMT Christian Mauderer [bbdb76e] * dhcpcd/dhcpcd.c (modified) dhcpcd: Pass config structure. Thu, 19 Dec 2019 09:50:12 GMT Sebastian Huber [a8f29d6] * freebsd/lib/libc/net/sockatmark.c (added) * libbsd.py (modified) * testsuite/syscalls01/test_main.c (modified) SOCKATMARK(3): Import from FreeBSD Close #3798. Fri, 20 Sep 2019 05:57:01 GMT Sebastian Huber [afaeccc] * freebsd/sbin/nvmecontrol/comnd.c (modified) * freebsd/sbin/nvmecontrol/comnd.h (modified) * freebsd/sbin/nvmecontrol/devlist.c (modified) * freebsd/sbin/nvmecontrol/firmware.c (modified) * freebsd/sbin/nvmecontrol/format.c (modified) * freebsd/sbin/nvmecontrol/identify.c (modified) * freebsd/sbin/nvmecontrol/identify_ext.c (modified) * freebsd/sbin/nvmecontrol/logpage.c (modified) * freebsd/sbin/nvmecontrol/modules/intel/intel.c (modified) * freebsd/sbin/nvmecontrol/modules/wdc/wdc.c (modified) * freebsd/sbin/nvmecontrol/nc_util.c (modified) * freebsd/sbin/nvmecontrol/ns.c (modified) * freebsd/sbin/nvmecontrol/nsid.c (modified) * freebsd/sbin/nvmecontrol/nvmecontrol.c (modified) * freebsd/sbin/nvmecontrol/nvmecontrol.h (modified) * freebsd/sbin/nvmecontrol/passthru.c (modified) * freebsd/sbin/nvmecontrol/perftest.c (modified) * freebsd/sbin/nvmecontrol/power.c (modified) * freebsd/sbin/nvmecontrol/reset.c (modified) * freebsd/sbin/nvmecontrol/resv.c (modified) * freebsd/sbin/nvmecontrol/sanitize.c (modified) * freebsd/sbin/nvmecontrol/wdc.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-nvmecontrol.c (added) NVMECONTROL(8): Port to RTEMS Update #3821. Tue, 24 Sep 2019 07:40:00 GMT Sebastian Huber [380ef17] * libbsd.py (modified) NVMECONTROL(8): Add to build Update #3821. Fri, 20 Sep 2019 05:55:33 GMT Sebastian Huber [94a7b59] * freebsd/sbin/nvmecontrol/comnd.c (added) * freebsd/sbin/nvmecontrol/comnd.h (added) * freebsd/sbin/nvmecontrol/devlist.c (added) * freebsd/sbin/nvmecontrol/firmware.c (added) * freebsd/sbin/nvmecontrol/format.c (added) * freebsd/sbin/nvmecontrol/identify.c (added) * freebsd/sbin/nvmecontrol/identify_ext.c (added) * freebsd/sbin/nvmecontrol/logpage.c (added) * freebsd/sbin/nvmecontrol/modules/intel/intel.c (added) * freebsd/sbin/nvmecontrol/modules/wdc/wdc.c (added) * freebsd/sbin/nvmecontrol/nc_util.c (added) * freebsd/sbin/nvmecontrol/ns.c (added) * freebsd/sbin/nvmecontrol/nsid.c (added) * freebsd/sbin/nvmecontrol/nvmecontrol.c (added) * freebsd/sbin/nvmecontrol/nvmecontrol.h (added) * freebsd/sbin/nvmecontrol/nvmecontrol_ext.h (added) * freebsd/sbin/nvmecontrol/passthru.c (added) * freebsd/sbin/nvmecontrol/perftest.c (added) * freebsd/sbin/nvmecontrol/power.c (added) * freebsd/sbin/nvmecontrol/reset.c (added) * freebsd/sbin/nvmecontrol/resv.c (added) * freebsd/sbin/nvmecontrol/sanitize.c (added) * freebsd/sbin/nvmecontrol/wdc.c (added) NVMECONTROL(8): Import from FreeBSD Update #3821. Wed, 11 Sep 2019 09:10:21 GMT Sebastian Huber [e7291f7] * libbsd.py (modified) * rtemsbsd/sys/dev/nvd/nvd.c (added) NVD(4): Add RTEMS-specific NVMe disk driver Update #3821. Fri, 20 Sep 2019 12:00:43 GMT Sebastian Huber [6735da1] * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/nvme/nvme_ns.c (modified) NVME(4): Add NVME_GET_NAMESPACE IO control Update #3821. Fri, 20 Sep 2019 11:53:06 GMT Sebastian Huber [eb4dcdf] * libbsd.py (modified) NVME(4): Install header files Update #3821. Fri, 20 Sep 2019 07:59:50 GMT Sebastian Huber [16c04c3] * freebsd/sys/dev/nvme/nvme_ctrlr.c (modified) NVME(4): Enable per-CPU IO queues Update #3821. Wed, 18 Sep 2019 11:39:58 GMT Sebastian Huber [13f34a7] * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/nvme/nvme_ns_cmd.c (modified) * freebsd/sys/dev/nvme/nvme_private.h (modified) * freebsd/sys/dev/nvme/nvme_qpair.c (modified) NVME(4): Add support for SGL Update #3821. Thu, 19 Sep 2019 05:29:24 GMT Sebastian Huber [90a95b57] * freebsd/sys/dev/nvme/nvme.h (modified) NVME(4): Add SGL descriptor Update #3821. Wed, 11 Sep 2019 12:55:26 GMT Sebastian Huber [d97f171] * freebsd/sys/dev/nvme/nvme_private.h (modified) * freebsd/sys/dev/nvme/nvme_qpair.c (modified) NVME(4): Optimize data transfer Update #3821. Thu, 18 Jul 2019 08:19:11 GMT Sebastian Huber [aaeae61] * freebsd/sys/dev/nvme/nvme_private.h (modified) NVME(4): Big endian support Update #3821. Mon, 03 Sep 2018 12:21:14 GMT Sebastian Huber [da6b9a1] * buildset/default.ini (modified) * freebsd/sys/dev/nvme/nvme.c (modified) * freebsd/sys/dev/nvme/nvme_ctrlr.c (modified) * freebsd/sys/dev/nvme/nvme_ns.c (modified) * freebsd/sys/dev/nvme/nvme_ns_cmd.c (modified) * freebsd/sys/dev/nvme/nvme_private.h (modified) * freebsd/sys/dev/nvme/nvme_qpair.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_nvme.h (added) NVME(4): Port to RTEMS Update #3821. Tue, 09 Jul 2019 07:00:11 GMT Sebastian Huber [fed6e9b] * libbsd.py (modified) NVME(4): Add build module Update #3821. Mon, 03 Sep 2018 12:03:26 GMT Sebastian Huber [5ac41dc] * freebsd/sys/dev/nvme/nvme.c (added) * freebsd/sys/dev/nvme/nvme_ctrlr.c (added) * freebsd/sys/dev/nvme/nvme_ctrlr_cmd.c (added) * freebsd/sys/dev/nvme/nvme_ns.c (added) * freebsd/sys/dev/nvme/nvme_ns_cmd.c (added) * freebsd/sys/dev/nvme/nvme_pci.c (added) * freebsd/sys/dev/nvme/nvme_private.h (added) * freebsd/sys/dev/nvme/nvme_qpair.c (added) * freebsd/sys/dev/nvme/nvme_sysctl.c (added) * freebsd/sys/dev/nvme/nvme_util.c (added) NVME(4): Import from FreeBSD Update #3821. Wed, 25 Sep 2019 08:58:00 GMT Sebastian Huber [b5f802ef] * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/sys/pcpu.h (modified) * rtemsbsd/include/machine/counter.h (modified) Add support for EARLY_COUNTER Tue, 24 Sep 2019 12:20:34 GMT Sebastian Huber [c1e05b9] * testsuite/log01/test_main.c (modified) * testsuite/media01/test_main.c (modified) * testsuite/termios/test_termios_utilities.h (modified) * testsuite/termios06/test_main.c (modified) * testsuite/usbkbd01/init.c (modified) * testsuite/usbmouse01/init.c (modified) Fix warnings Tue, 24 Sep 2019 12:20:08 GMT Sebastian Huber [f105680] * freebsd/sys/sys/syslog.h (deleted) * libbsd.py (modified) * rtemsbsd/include/syslog.h (deleted) Remove obsolete header files Tue, 24 Sep 2019 12:10:43 GMT Sebastian Huber [7664fdc] * testsuite/syscalls01/test_main.c (modified) Compatibility for next Newlib update Tue, 24 Sep 2019 12:02:40 GMT Sebastian Huber [4a6660c] * freebsd/sys/sys/signalvar.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/rtems/rtems-kernel-signal.c (deleted) Fix pgsigio() warnings Wed, 25 Sep 2019 07:24:09 GMT Sebastian Huber [8618727] * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) Add compatiblity for older Newlib variants Mon, 23 Sep 2019 10:49:10 GMT Sebastian Huber [37323bb] * freebsd-org (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/wpa/src/ap/ap_config.h (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.c (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.h (modified) * freebsd/contrib/wpa/src/ap/hostapd.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11.h (modified) * freebsd/contrib/wpa/src/ap/sta_info.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_ft.c (modified) * freebsd/contrib/wpa/src/common/dpp.h (modified) * freebsd/contrib/wpa/src/common/hw_features_common.c (modified) * freebsd/contrib/wpa/src/common/hw_features_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.c (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_defs.h (modified) * freebsd/contrib/wpa/src/common/qca-vendor.h (modified) * freebsd/contrib/wpa/src/common/sae.h (modified) * freebsd/contrib/wpa/src/common/version.h (modified) * freebsd/contrib/wpa/src/common/wpa_common.c (modified) * freebsd/contrib/wpa/src/common/wpa_ctrl.h (modified) * freebsd/contrib/wpa/src/crypto/crypto.h (modified) * freebsd/contrib/wpa/src/crypto/crypto_openssl.c (modified) * freebsd/contrib/wpa/src/crypto/sha1-prf.c (modified) * freebsd/contrib/wpa/src/crypto/sha1.c (modified) * freebsd/contrib/wpa/src/crypto/sha256-prf.c (modified) * freebsd/contrib/wpa/src/crypto/sha256.h (modified) * freebsd/contrib/wpa/src/crypto/tls.h (modified) * freebsd/contrib/wpa/src/drivers/driver.h (modified) * freebsd/contrib/wpa/src/drivers/driver_bsd.c (modified) * freebsd/contrib/wpa/src/drivers/driver_common.c (modified) * freebsd/contrib/wpa/src/drivers/driver_ndis.c (modified) * freebsd/contrib/wpa/src/drivers/driver_nl80211.h (modified) * freebsd/contrib/wpa/src/eap_common/eap_defs.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_config.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_leap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_methods.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_peap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h (modified) * freebsd/contrib/wpa/src/eap_server/eap_methods.h (modified) * freebsd/contrib/wpa/src/eapol_auth/eapol_auth_sm.h (modified) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c (modified) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_i.h (modified) * freebsd/contrib/wpa/src/utils/common.c (modified) * freebsd/contrib/wpa/src/utils/common.h (modified) * freebsd/contrib/wpa/src/utils/wpa_debug.c (modified) * freebsd/contrib/wpa/src/wps/wps.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ap.h (modified) * freebsd/contrib/wpa/wpa_supplicant/bss.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config.h (modified) * freebsd/contrib/wpa/wpa_supplicant/config_file.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config_ssid.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c (modified) * freebsd/contrib/wpa/wpa_supplicant/dpp_supplicant.h (modified) * freebsd/contrib/wpa/wpa_supplicant/driver_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/eap_register.c (modified) * freebsd/contrib/wpa/wpa_supplicant/events.c (modified) * freebsd/contrib/wpa/wpa_supplicant/interworking.c (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.c (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.h (modified) * freebsd/contrib/wpa/wpa_supplicant/op_classes.c (modified) * freebsd/contrib/wpa/wpa_supplicant/rrm.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c (modified) * freebsd/crypto/openssl/apps/apps.c (modified) * freebsd/crypto/openssl/apps/apps.h (modified) * freebsd/crypto/openssl/apps/ca.c (modified) * freebsd/crypto/openssl/apps/dgst.c (modified) * freebsd/crypto/openssl/apps/enc.c (modified) * freebsd/crypto/openssl/apps/ocsp.c (modified) * freebsd/crypto/openssl/apps/openssl.c (modified) * freebsd/crypto/openssl/apps/pkcs12.c (modified) * freebsd/crypto/openssl/apps/req.c (modified) * freebsd/crypto/openssl/apps/s_apps.h (modified) * freebsd/crypto/openssl/apps/s_cb.c (modified) * freebsd/crypto/openssl/apps/s_client.c (modified) * freebsd/crypto/openssl/apps/speed.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_time.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_type.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_bignum.c (modified) * freebsd/crypto/openssl/crypto/bio/b_addr.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_dgram.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_file.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_mem.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_div.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lcl.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_rand.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_sqrt.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_att.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_env.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_err.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_lcl.h (modified) * freebsd/crypto/openssl/crypto/cms/cms_sd.c (modified) * freebsd/crypto/openssl/crypto/cms/cms_smime.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_sap.c (modified) * freebsd/crypto/openssl/crypto/ctype.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_check.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_gen.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_lib.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_err.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_asn1.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_curve.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_lcl.h (modified) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (modified) * freebsd/crypto/openssl/crypto/ec/ecdh_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ecdsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistputil.c (modified) * freebsd/crypto/openssl/crypto/ec/ecx_meth.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_devcrypto.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_openssl.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/evp/bio_ok.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aria.c (modified) * freebsd/crypto/openssl/crypto/evp/e_chacha20_poly1305.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_err.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_lib.c (modified) * freebsd/crypto/openssl/crypto/evp/m_sha3.c (modified) * freebsd/crypto/openssl/crypto/include/internal/ctype.h (modified) * freebsd/crypto/openssl/crypto/include/internal/rand_int.h (modified) * freebsd/crypto/openssl/crypto/include/internal/sm2err.h (modified) * freebsd/crypto/openssl/crypto/init.c (modified) * freebsd/crypto/openssl/crypto/lhash/lhash.c (modified) * freebsd/crypto/openssl/crypto/o_str.c (modified) * freebsd/crypto/openssl/crypto/pem/pvkfmt.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_doit.c (modified) * freebsd/crypto/openssl/crypto/rand/drbg_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_err.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_lcl.h (modified) * freebsd/crypto/openssl/crypto/rand/rand_lib.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_unix.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_err.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_lib.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/sm2/sm2_sign.c (modified) * freebsd/crypto/openssl/crypto/store/loader_file.c (modified) * freebsd/crypto/openssl/crypto/store/store_lib.c (modified) * freebsd/crypto/openssl/crypto/threads_none.c (modified) * freebsd/crypto/openssl/crypto/threads_pthread.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_lib.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (modified) * freebsd/crypto/openssl/crypto/uid.c (modified) * freebsd/crypto/openssl/crypto/whrlpool/wp_block.c (modified) * freebsd/crypto/openssl/crypto/x509/by_dir.c (modified) * freebsd/crypto/openssl/crypto/x509/t_req.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_att.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_cmp.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_err.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vfy.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_alt.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_purp.c (modified) * freebsd/crypto/openssl/e_os.h (modified) * freebsd/crypto/openssl/include/internal/constant_time_locl.h (modified) * freebsd/crypto/openssl/include/internal/cryptlib.h (modified) * freebsd/crypto/openssl/include/internal/dsoerr.h (modified) * freebsd/crypto/openssl/include/internal/refcount.h (modified) * freebsd/crypto/openssl/include/internal/thread_once.h (modified) * freebsd/crypto/openssl/include/internal/tsan_assist.h (modified) * freebsd/crypto/openssl/include/openssl/asn1err.h (modified) * freebsd/crypto/openssl/include/openssl/asyncerr.h (modified) * freebsd/crypto/openssl/include/openssl/bio.h (modified) * freebsd/crypto/openssl/include/openssl/bioerr.h (modified) * freebsd/crypto/openssl/include/openssl/bnerr.h (modified) * freebsd/crypto/openssl/include/openssl/buffererr.h (modified) * freebsd/crypto/openssl/include/openssl/cms.h (modified) * freebsd/crypto/openssl/include/openssl/cmserr.h (modified) * freebsd/crypto/openssl/include/openssl/comperr.h (modified) * freebsd/crypto/openssl/include/openssl/conferr.h (modified) * freebsd/crypto/openssl/include/openssl/cryptoerr.h (modified) * freebsd/crypto/openssl/include/openssl/cterr.h (modified) * freebsd/crypto/openssl/include/openssl/dherr.h (modified) * freebsd/crypto/openssl/include/openssl/dsaerr.h (modified) * freebsd/crypto/openssl/include/openssl/ec.h (modified) * freebsd/crypto/openssl/include/openssl/ecerr.h (modified) * freebsd/crypto/openssl/include/openssl/engineerr.h (modified) * freebsd/crypto/openssl/include/openssl/evp.h (modified) * freebsd/crypto/openssl/include/openssl/evperr.h (modified) * freebsd/crypto/openssl/include/openssl/kdferr.h (modified) * freebsd/crypto/openssl/include/openssl/objectserr.h (modified) * freebsd/crypto/openssl/include/openssl/ocsperr.h (modified) * freebsd/crypto/openssl/include/openssl/opensslv.h (modified) * freebsd/crypto/openssl/include/openssl/pemerr.h (modified) * freebsd/crypto/openssl/include/openssl/pkcs12err.h (modified) * freebsd/crypto/openssl/include/openssl/pkcs7err.h (modified) * freebsd/crypto/openssl/include/openssl/randerr.h (modified) * freebsd/crypto/openssl/include/openssl/rsaerr.h (modified) * freebsd/crypto/openssl/include/openssl/ssl.h (modified) * freebsd/crypto/openssl/include/openssl/sslerr.h (modified) * freebsd/crypto/openssl/include/openssl/store.h (modified) * freebsd/crypto/openssl/include/openssl/storeerr.h (modified) * freebsd/crypto/openssl/include/openssl/tls1.h (modified) * freebsd/crypto/openssl/include/openssl/tserr.h (modified) * freebsd/crypto/openssl/include/openssl/uierr.h (modified) * freebsd/crypto/openssl/include/openssl/x509err.h (modified) * freebsd/crypto/openssl/include/openssl/x509v3.h (modified) * freebsd/crypto/openssl/include/openssl/x509v3err.h (modified) * freebsd/crypto/openssl/ssl/d1_msg.c (modified) * freebsd/crypto/openssl/ssl/record/rec_layer_s3.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert.c (modified) * freebsd/crypto/openssl/ssl/ssl_ciph.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions_clnt.c (modified) * freebsd/crypto/openssl/ssl/statem/extensions_srvr.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_clnt.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_lib.c (modified) * freebsd/crypto/openssl/ssl/statem/statem_srvr.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/crypto/openssl/ssl/tls13_enc.c (modified) * freebsd/include/rpcsvc/yp_prot.h (modified) * freebsd/lib/libc/nameser/ns_name.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/rpc/getrpcent.c (modified) * freebsd/lib/libcapsicum/capsicum_helpers.h (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping/rtems-bsd-ping-data.h (modified) * freebsd/sbin/ping/rtems-bsd-ping-namespace.h (modified) * freebsd/sbin/ping/rtems-bsd-ping-utils-data.h (added) * freebsd/sbin/ping/utils.c (added) * freebsd/sbin/ping/utils.h (added) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/ping6/rtems-bsd-ping6-data.h (modified) * freebsd/sbin/ping6/rtems-bsd-ping6-namespace.h (modified) * freebsd/sbin/ping6/rtems-bsd-ping6-ping6-data.h (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/usb/usb.h (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_hpts.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_log_buf.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/vnode.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD stable/12 2019-09-23 Git mirror commit ... Mon, 23 Sep 2019 12:27:32 GMT Sebastian Huber [d06c638] * freebsd/sys/kern/sys_generic.c (modified) * testsuite/selectpollkqueue01/test_main.c (modified) * testsuite/syscalls01/test_main.c (modified) Add pselect()
