# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/19/24 01:26:28 Wed, 08 Nov 2017 13:11:09 GMT Christian Mauderer [bdc4f21] * freebsd/contrib/wpa/src/rsn_supp/tdls.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) wpa: Port to new files to RTEMS. Wed, 08 Nov 2017 13:10:40 GMT Christian Mauderer [b0f0b2f] * freebsd/contrib/wpa/src/ap/pmksa_cache_auth.h (added) * freebsd/contrib/wpa/src/ap/wmm.h (added) * freebsd/contrib/wpa/src/ap/wpa_auth.c (added) * freebsd/contrib/wpa/src/ap/wpa_auth.h (added) * freebsd/contrib/wpa/src/ap/wpa_auth_ft.c (added) * freebsd/contrib/wpa/src/ap/wpa_auth_i.h (added) * freebsd/contrib/wpa/src/ap/wpa_auth_ie.h (added) * freebsd/contrib/wpa/src/eapol_auth/eapol_auth_sm.h (added) * freebsd/contrib/wpa/src/radius/radius.h (added) * freebsd/contrib/wpa/src/rsn_supp/tdls.c (added) * freebsd/contrib/wpa/src/utils/bitfield.h (added) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c (added) wpa: Import all files for KRACK patch. Wed, 08 Nov 2017 10:25:59 GMT Christian Mauderer [a506ba9] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Add timing to read_ivar. Wed, 08 Nov 2017 09:44:48 GMT Christian Mauderer [e7f3260] * freebsd/sys/sys/bus.h (modified) freebsd/bus: Check return value of bus_accessor. Tue, 07 Nov 2017 15:17:55 GMT Christian Mauderer [ec29b2a] * freebsd/sys/arm/at91/at91_mci.c (modified) * freebsd/sys/arm/at91/at91_mcireg.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_at91.h (added) at91_mci: Port to RTEMS and adapt for atsam. Tue, 23 Aug 2016 11:16:53 GMT Sebastian Huber [ea5880a] * freebsd/sys/arm/at91/at91_mci.c (added) * freebsd/sys/arm/at91/at91_mcireg.h (added) * freebsd/sys/arm/at91/at91_pdcreg.h (added) * freebsd/sys/arm/at91/at91reg.h (added) * freebsd/sys/arm/at91/at91var.h (added) at91_mci: Import from FreeBSD Tue, 07 Nov 2017 14:15:38 GMT Christian Mauderer [5892207] * freebsd/sys/dev/usb/controller/saf1761_otg.c (modified) * freebsd/sys/dev/usb/controller/saf1761_otg_fdt.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) saf1761_otg: Port to RTEMS. Tue, 11 Apr 2017 08:36:12 GMT Christian Mauderer [cf8e1d4] * freebsd/sys/dev/usb/controller/saf1761_otg.c (added) * freebsd/sys/dev/usb/controller/saf1761_otg.h (added) * freebsd/sys/dev/usb/controller/saf1761_otg_fdt.c (added) * freebsd/sys/dev/usb/controller/saf1761_otg_reg.h (added) usb/saf1761: Import from FreeBSD. Import the files for the SAF1761 ... Tue, 07 Nov 2017 10:54:39 GMT Christian Mauderer [ddd16bc] * dhcpcd/dhcp.c (modified) dhcpcd: Don't ignore interface on transient errors. In case of WPA ... Wed, 08 Nov 2017 11:43:39 GMT Christian Mauderer [e5abb31] * libbsd.txt (modified) libbsd.txt: Describe current state of WLAN. Fri, 03 Nov 2017 10:08:48 GMT Christian Mauderer [bed8742] * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) wpa_supplicant: Fix getopt. Thu, 02 Nov 2017 14:07:23 GMT Christian Mauderer [79ad952] * freebsd/contrib/wpa/src/eap_peer/eap_methods.c (modified) * freebsd/contrib/wpa/src/utils/includes.h (modified) wpa_supplicant: Include rtems-bsd-program.h. Thu, 02 Nov 2017 13:34:35 GMT Christian Mauderer [4613db0] * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-wpa-supplicant.h (added) * rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c (added) wpa_supplicant: Add lock. Thu, 02 Nov 2017 13:08:10 GMT Christian Mauderer [ee0c369] * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) * rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c (modified) wpa_supplicant: Move forking command into own file. The malloc ... Thu, 12 Oct 2017 12:16:09 GMT Sichen Zhao <1473996754@…> [ce2262e] * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c (added) * testsuite/media01/test_main.c (modified) Add wpa_supplicant_fork command. Add fork command for wpa ... Thu, 12 Oct 2017 12:16:08 GMT Sichen Zhao <1473996754@…> [0aa7e63] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) Add wpa_supplicant command in test suite. Add wpa supplicant ... Thu, 12 Oct 2017 12:16:07 GMT Sichen Zhao <1473996754@…> [8f2267b] * builder.py (modified) * freebsd/contrib/wpa/src/utils/os_unix.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config.h (modified) * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/machine/rtems-wpa_supplicant-mutex.h (added) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c (added) * rtemsbsd/rtems/rtems-wpa_supplicant_mutex.c (added) Port wpa supplicant to RTEMS. Add wpa_supplicant lib support and ... Tue, 01 Aug 2017 12:43:41 GMT Sichen Zhao <1473996754@…> [9c9d11b] * freebsd/contrib/wpa/src/ap/ap_config.h (added) * freebsd/contrib/wpa/src/ap/ap_drv_ops.c (added) * freebsd/contrib/wpa/src/ap/ap_drv_ops.h (added) * freebsd/contrib/wpa/src/ap/hostapd.h (added) * freebsd/contrib/wpa/src/ap/hs20.c (added) * freebsd/contrib/wpa/src/ap/hs20.h (added) * freebsd/contrib/wpa/src/ap/ieee802_11.h (added) * freebsd/contrib/wpa/src/ap/ieee802_11_auth.h (added) * freebsd/contrib/wpa/src/ap/ieee802_11_shared.c (added) * freebsd/contrib/wpa/src/ap/p2p_hostapd.h (added) * freebsd/contrib/wpa/src/ap/sta_info.h (added) * freebsd/contrib/wpa/src/common/defs.h (added) * freebsd/contrib/wpa/src/common/eapol_common.h (added) * freebsd/contrib/wpa/src/common/gas.c (added) * freebsd/contrib/wpa/src/common/gas.h (added) * freebsd/contrib/wpa/src/common/hw_features_common.c (added) * freebsd/contrib/wpa/src/common/hw_features_common.h (added) * freebsd/contrib/wpa/src/common/ieee802_11_common.c (added) * freebsd/contrib/wpa/src/common/ieee802_11_common.h (added) * freebsd/contrib/wpa/src/common/ieee802_11_defs.h (added) * freebsd/contrib/wpa/src/common/qca-vendor.h (added) * freebsd/contrib/wpa/src/common/sae.h (added) * freebsd/contrib/wpa/src/common/version.h (added) * freebsd/contrib/wpa/src/common/wpa_common.c (added) * freebsd/contrib/wpa/src/common/wpa_common.h (added) * freebsd/contrib/wpa/src/common/wpa_ctrl.h (added) * freebsd/contrib/wpa/src/crypto/aes-ctr.c (added) * freebsd/contrib/wpa/src/crypto/aes-eax.c (added) * freebsd/contrib/wpa/src/crypto/aes-encblock.c (added) * freebsd/contrib/wpa/src/crypto/aes-omac1.c (added) * freebsd/contrib/wpa/src/crypto/aes-unwrap.c (added) * freebsd/contrib/wpa/src/crypto/aes.h (added) * freebsd/contrib/wpa/src/crypto/aes_wrap.h (added) * freebsd/contrib/wpa/src/crypto/crypto.h (added) * freebsd/contrib/wpa/src/crypto/crypto_openssl.c (added) * freebsd/contrib/wpa/src/crypto/dh_group5.h (added) * freebsd/contrib/wpa/src/crypto/md5.h (added) * freebsd/contrib/wpa/src/crypto/ms_funcs.c (added) * freebsd/contrib/wpa/src/crypto/ms_funcs.h (added) * freebsd/contrib/wpa/src/crypto/random.c (added) * freebsd/contrib/wpa/src/crypto/random.h (added) * freebsd/contrib/wpa/src/crypto/rc4.c (added) * freebsd/contrib/wpa/src/crypto/sha1-pbkdf2.c (added) * freebsd/contrib/wpa/src/crypto/sha1-prf.c (added) * freebsd/contrib/wpa/src/crypto/sha1.c (added) * freebsd/contrib/wpa/src/crypto/sha1.h (added) * freebsd/contrib/wpa/src/crypto/sha256-internal.c (added) * freebsd/contrib/wpa/src/crypto/sha256-prf.c (added) * freebsd/contrib/wpa/src/crypto/sha256.h (added) * freebsd/contrib/wpa/src/crypto/sha256_i.h (added) * freebsd/contrib/wpa/src/crypto/sha384.h (added) * freebsd/contrib/wpa/src/crypto/tls.h (added) * freebsd/contrib/wpa/src/crypto/tls_internal.c (added) * freebsd/contrib/wpa/src/drivers/driver.h (added) * freebsd/contrib/wpa/src/drivers/driver_bsd.c (added) * freebsd/contrib/wpa/src/drivers/driver_common.c (added) * freebsd/contrib/wpa/src/drivers/driver_ndis.c (added) * freebsd/contrib/wpa/src/drivers/driver_ndis.h (added) * freebsd/contrib/wpa/src/drivers/driver_nl80211.h (added) * freebsd/contrib/wpa/src/drivers/driver_wired.c (added) * freebsd/contrib/wpa/src/drivers/drivers.c (added) * freebsd/contrib/wpa/src/drivers/linux_defines.h (added) * freebsd/contrib/wpa/src/eap_common/chap.c (added) * freebsd/contrib/wpa/src/eap_common/chap.h (added) * freebsd/contrib/wpa/src/eap_common/eap_common.c (added) * freebsd/contrib/wpa/src/eap_common/eap_common.h (added) * freebsd/contrib/wpa/src/eap_common/eap_defs.h (added) * freebsd/contrib/wpa/src/eap_common/eap_peap_common.c (added) * freebsd/contrib/wpa/src/eap_common/eap_peap_common.h (added) * freebsd/contrib/wpa/src/eap_common/eap_psk_common.c (added) * freebsd/contrib/wpa/src/eap_common/eap_psk_common.h (added) * freebsd/contrib/wpa/src/eap_common/eap_tlv_common.h (added) * freebsd/contrib/wpa/src/eap_common/eap_ttls.h (added) * freebsd/contrib/wpa/src/eap_common/eap_wsc_common.h (added) * freebsd/contrib/wpa/src/eap_peer/eap.c (added) * freebsd/contrib/wpa/src/eap_peer/eap.h (added) * freebsd/contrib/wpa/src/eap_peer/eap_config.h (added) * freebsd/contrib/wpa/src/eap_peer/eap_gtc.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_i.h (added) * freebsd/contrib/wpa/src/eap_peer/eap_leap.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_md5.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_methods.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_methods.h (added) * freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_otp.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_peap.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_proxy.h (added) * freebsd/contrib/wpa/src/eap_peer/eap_psk.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_tls.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c (added) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h (added) * freebsd/contrib/wpa/src/eap_peer/eap_ttls.c (added) * freebsd/contrib/wpa/src/eap_peer/mschapv2.c (added) * freebsd/contrib/wpa/src/eap_peer/mschapv2.h (added) * freebsd/contrib/wpa/src/eap_peer/tncc.h (added) * freebsd/contrib/wpa/src/eap_server/eap_methods.h (added) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c (added) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h (added) * freebsd/contrib/wpa/src/fst/fst.h (added) * freebsd/contrib/wpa/src/fst/fst_ctrl_aux.h (added) * freebsd/contrib/wpa/src/fst/fst_ctrl_iface.h (added) * freebsd/contrib/wpa/src/l2_packet/l2_packet.h (added) * freebsd/contrib/wpa/src/l2_packet/l2_packet_freebsd.c (added) * freebsd/contrib/wpa/src/p2p/p2p.h (added) * freebsd/contrib/wpa/src/rsn_supp/peerkey.c (added) * freebsd/contrib/wpa/src/rsn_supp/peerkey.h (added) * freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c (added) * freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h (added) * freebsd/contrib/wpa/src/rsn_supp/preauth.c (added) * freebsd/contrib/wpa/src/rsn_supp/preauth.h (added) * freebsd/contrib/wpa/src/rsn_supp/wpa.c (added) * freebsd/contrib/wpa/src/rsn_supp/wpa.h (added) * freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c (added) * freebsd/contrib/wpa/src/rsn_supp/wpa_i.h (added) * freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c (added) * freebsd/contrib/wpa/src/rsn_supp/wpa_ie.h (added) * freebsd/contrib/wpa/src/tls/tlsv1_client.h (added) * freebsd/contrib/wpa/src/tls/tlsv1_cred.h (added) * freebsd/contrib/wpa/src/tls/tlsv1_server.h (added) * freebsd/contrib/wpa/src/utils/base64.c (added) * freebsd/contrib/wpa/src/utils/base64.h (added) * freebsd/contrib/wpa/src/utils/build_config.h (added) * freebsd/contrib/wpa/src/utils/common.c (added) * freebsd/contrib/wpa/src/utils/common.h (added) * freebsd/contrib/wpa/src/utils/eloop.c (added) * freebsd/contrib/wpa/src/utils/eloop.h (added) * freebsd/contrib/wpa/src/utils/ext_password.h (added) * freebsd/contrib/wpa/src/utils/includes.h (added) * freebsd/contrib/wpa/src/utils/ip_addr.h (added) * freebsd/contrib/wpa/src/utils/list.h (added) * freebsd/contrib/wpa/src/utils/os.h (added) * freebsd/contrib/wpa/src/utils/os_unix.c (added) * freebsd/contrib/wpa/src/utils/pcsc_funcs.h (added) * freebsd/contrib/wpa/src/utils/platform.h (added) * freebsd/contrib/wpa/src/utils/state_machine.h (added) * freebsd/contrib/wpa/src/utils/trace.h (added) * freebsd/contrib/wpa/src/utils/uuid.c (added) * freebsd/contrib/wpa/src/utils/uuid.h (added) * freebsd/contrib/wpa/src/utils/wpa_debug.c (added) * freebsd/contrib/wpa/src/utils/wpa_debug.h (added) * freebsd/contrib/wpa/src/utils/wpabuf.c (added) * freebsd/contrib/wpa/src/utils/wpabuf.h (added) * freebsd/contrib/wpa/src/wps/http.h (added) * freebsd/contrib/wpa/src/wps/http_client.c (added) * freebsd/contrib/wpa/src/wps/http_client.h (added) * freebsd/contrib/wpa/src/wps/http_server.c (added) * freebsd/contrib/wpa/src/wps/http_server.h (added) * freebsd/contrib/wpa/src/wps/httpread.c (added) * freebsd/contrib/wpa/src/wps/httpread.h (added) * freebsd/contrib/wpa/src/wps/upnp_xml.c (added) * freebsd/contrib/wpa/src/wps/upnp_xml.h (added) * freebsd/contrib/wpa/src/wps/wps.c (added) * freebsd/contrib/wpa/src/wps/wps.h (added) * freebsd/contrib/wpa/src/wps/wps_attr_build.c (added) * freebsd/contrib/wpa/src/wps/wps_attr_parse.c (added) * freebsd/contrib/wpa/src/wps/wps_attr_parse.h (added) * freebsd/contrib/wpa/src/wps/wps_attr_process.c (added) * freebsd/contrib/wpa/src/wps/wps_common.c (added) * freebsd/contrib/wpa/src/wps/wps_defs.h (added) * freebsd/contrib/wpa/src/wps/wps_dev_attr.c (added) * freebsd/contrib/wpa/src/wps/wps_dev_attr.h (added) * freebsd/contrib/wpa/src/wps/wps_enrollee.c (added) * freebsd/contrib/wpa/src/wps/wps_er.h (added) * freebsd/contrib/wpa/src/wps/wps_i.h (added) * freebsd/contrib/wpa/src/wps/wps_registrar.c (added) * freebsd/contrib/wpa/src/wps/wps_upnp.c (added) * freebsd/contrib/wpa/src/wps/wps_upnp.h (added) * freebsd/contrib/wpa/src/wps/wps_upnp_ap.c (added) * freebsd/contrib/wpa/src/wps/wps_upnp_event.c (added) * freebsd/contrib/wpa/src/wps/wps_upnp_i.h (added) * freebsd/contrib/wpa/src/wps/wps_upnp_ssdp.c (added) * freebsd/contrib/wpa/src/wps/wps_upnp_web.c (added) * freebsd/contrib/wpa/wpa_supplicant/ap.h (added) * freebsd/contrib/wpa/wpa_supplicant/autoscan.h (added) * freebsd/contrib/wpa/wpa_supplicant/bgscan.h (added) * freebsd/contrib/wpa/wpa_supplicant/blacklist.c (added) * freebsd/contrib/wpa/wpa_supplicant/blacklist.h (added) * freebsd/contrib/wpa/wpa_supplicant/bss.c (added) * freebsd/contrib/wpa/wpa_supplicant/bss.h (added) * freebsd/contrib/wpa/wpa_supplicant/config.c (added) * freebsd/contrib/wpa/wpa_supplicant/config.h (added) * freebsd/contrib/wpa/wpa_supplicant/config_file.c (added) * freebsd/contrib/wpa/wpa_supplicant/config_ssid.h (added) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c (added) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.h (added) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface_unix.c (added) * freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_common.h (added) * freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_new.h (added) * freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_old.h (added) * freebsd/contrib/wpa/wpa_supplicant/driver_i.h (added) * freebsd/contrib/wpa/wpa_supplicant/eap_register.c (added) * freebsd/contrib/wpa/wpa_supplicant/events.c (added) * freebsd/contrib/wpa/wpa_supplicant/gas_query.c (added) * freebsd/contrib/wpa/wpa_supplicant/gas_query.h (added) * freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.c (added) * freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.h (added) * freebsd/contrib/wpa/wpa_supplicant/ibss_rsn.h (added) * freebsd/contrib/wpa/wpa_supplicant/interworking.c (added) * freebsd/contrib/wpa/wpa_supplicant/interworking.h (added) * freebsd/contrib/wpa/wpa_supplicant/main.c (added) * freebsd/contrib/wpa/wpa_supplicant/mesh.h (added) * freebsd/contrib/wpa/wpa_supplicant/mesh_mpm.h (added) * freebsd/contrib/wpa/wpa_supplicant/mesh_rsn.h (added) * freebsd/contrib/wpa/wpa_supplicant/notify.c (added) * freebsd/contrib/wpa/wpa_supplicant/notify.h (added) * freebsd/contrib/wpa/wpa_supplicant/offchannel.c (added) * freebsd/contrib/wpa/wpa_supplicant/offchannel.h (added) * freebsd/contrib/wpa/wpa_supplicant/p2p_supplicant.h (added) * freebsd/contrib/wpa/wpa_supplicant/scan.c (added) * freebsd/contrib/wpa/wpa_supplicant/scan.h (added) * freebsd/contrib/wpa/wpa_supplicant/sme.h (added) * freebsd/contrib/wpa/wpa_supplicant/wifi_display.h (added) * freebsd/contrib/wpa/wpa_supplicant/wmm_ac.c (added) * freebsd/contrib/wpa/wpa_supplicant/wmm_ac.h (added) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.h (added) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant.c (added) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h (added) * freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c (added) * freebsd/contrib/wpa/wpa_supplicant/wpas_glue.h (added) * freebsd/contrib/wpa/wpa_supplicant/wpas_kay.h (added) * freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.c (added) * freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.h (added) * freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.c (added) * freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.h (added) * freebsd/usr.sbin/wpa/wpa_supplicant/ntddndis.h (added) Import wpa from FreeBSD Fri, 10 Nov 2017 12:32:14 GMT Sebastian Huber [847de24] * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) Fix build for non-FDT platforms Wed, 08 Nov 2017 13:43:32 GMT Sichen Zhao <1473996754@…> [7c68f4e] * Makefile.todo (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/fdt.h (added) * rtemsbsd/include/rtems/bsd/local/gpiobus_if.h (added) * rtemsbsd/include/rtems/bsd/local/sdhci_if.h (added) * rtemsbsd/local/gpiobus_if.c (added) * rtemsbsd/local/sdhci_if.c (added) Port BBB sd driver files to RTEMS. So BBB can mount and read eMMC ... Wed, 08 Nov 2017 13:43:31 GMT Sichen Zhao <1473996754@…> [7e52ab9] * freebsd/sys/arm/ti/ti_hwmods.c (added) * freebsd/sys/arm/ti/ti_hwmods.h (added) * freebsd/sys/arm/ti/ti_sdhci.c (added) * freebsd/sys/dev/gpio/gpiobus.c (added) * freebsd/sys/dev/gpio/gpiobusvar.h (added) * freebsd/sys/dev/gpio/ofw_gpiobus.c (added) * freebsd/sys/dev/sdhci/sdhci.c (added) * freebsd/sys/dev/sdhci/sdhci.h (added) * freebsd/sys/dev/sdhci/sdhci_fdt_gpio.c (added) * freebsd/sys/dev/sdhci/sdhci_fdt_gpio.h (added) Import BBB sd driver files from FreeBSD. Fri, 10 Nov 2017 10:53:07 GMT Sebastian Huber [896f068] * testsuite/syscalls01/test_main.c (modified) tests/syscalls01: Fix shutdown() test The socket must be connected ... Fri, 10 Nov 2017 10:48:51 GMT Sebastian Huber [23cd284] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-ifconfig-lo0.c (added) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Add rtems_bsd_ifconfig_lo0() Fri, 10 Nov 2017 10:17:13 GMT Sebastian Huber [eeeda4b] * testsuite/syscalls01/test_main.c (modified) tests/syscall01: Update error values FreeBSD changed the error values. Fri, 10 Nov 2017 10:15:35 GMT Sebastian Huber [057656b] * freebsd/sys/kern/uipc_socket.c (modified) Disable HHOOK(9) support for sockets Support was only partly ... Fri, 10 Nov 2017 10:01:39 GMT Sebastian Huber [72d5fa1] * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) Fix reference counting for file descriptors Update #3132. Thu, 09 Nov 2017 13:28:55 GMT Sebastian Huber [b15a719] * wscript (modified) Change RTEMS version to 5 Update #3220. Thu, 09 Nov 2017 13:28:37 GMT Sebastian Huber [c64806c] * testsuite/mutex01/test_main.c (modified) tests/mutex01: Fix mtx_recursed() usage Thu, 09 Nov 2017 13:28:17 GMT Sebastian Huber [6fbcf2e] * testsuite/program01/test_main.c (modified) tests/program01: Fix test name Thu, 26 Oct 2017 13:02:24 GMT Sebastian Huber [45149ec] * linux/drivers/net/ethernet/freescale/fman/fman.c (modified) * linux/drivers/soc/fsl/qbman/bman_ccsr.c (modified) * linux/drivers/soc/fsl/qbman/dpaa_sys.h (modified) * linux/drivers/soc/fsl/qbman/qman_ccsr.c (modified) * linux/drivers/soc/fsl/qbman/qman_portal.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_dpaa.h (modified) Fix general PowerPC build Thu, 26 Oct 2017 06:43:53 GMT Sebastian Huber [936b597] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Fix comment Update #3090. Wed, 25 Oct 2017 08:17:23 GMT Sebastian Huber [a8a9cf1] * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/ffec/if_ffecreg.h (modified) ffec: Add checksum offload Update #3090. Wed, 25 Oct 2017 06:01:27 GMT Sebastian Huber [0323c28] * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/ffec/if_ffecreg.h (modified) ffec: Add interrupt coalescing support Code is an adapted from the ... Wed, 25 Oct 2017 11:25:15 GMT Sebastian Huber [fd5ee57] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Increase buffer descriptor count to 512 Update #3090. Tue, 24 Oct 2017 10:17:00 GMT Sebastian Huber [0cb4075] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Defragment transmit mbuf only if necessary Use structure ... Tue, 24 Oct 2017 12:11:56 GMT Sebastian Huber [798d308] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Fix NULL pointer access Update #3090. Wed, 04 Oct 2017 12:15:59 GMT Sebastian Huber [b8fdbe2] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Use RACC[SHIFT16] This avoids the move of entire receive ... Tue, 24 Oct 2017 10:19:28 GMT Sebastian Huber [2fcf5aa] * rtemsbsd/rtems/rtems-kernel-muteximpl.c (modified) rtems-bsd-mutex: Update due to API changes Update #3117. Tue, 24 Oct 2017 06:15:06 GMT Sebastian Huber [445d59e] * builder.py (modified) * freebsd-to-rtems.py (modified) Remove ability to synchronize with Linux Tue, 24 Oct 2017 06:14:26 GMT Sebastian Huber [1dd58e4] * .gitmodules (modified) * linux-org (deleted) Remove Linux submodule Tue, 24 Oct 2017 05:42:36 GMT Sebastian Huber [fb84af0] * waf_generator.py (modified) Fix install arch-specific header files Mon, 23 Oct 2017 07:11:15 GMT Sebastian Huber [a677fe9] * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.c (modified) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.h (modified) dpaa: Use only one FMan MAC SGT zone Fri, 20 Oct 2017 12:55:13 GMT Sebastian Huber [b1fd51c] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) dpaa: Reduce receive buffer seed Seed the receive buffers of each ... Wed, 23 Aug 2017 08:08:16 GMT Sebastian Huber [33356a8] * linux/drivers/soc/fsl/qbman/qman_portal.c (modified) dpaa: Improve QMan portal initialization Be less dependent on the ... Wed, 23 Aug 2017 07:59:31 GMT Sebastian Huber [24866e6] * linux/drivers/soc/fsl/qbman/qman_ccsr.c (modified) dpaa: Reduce PFDR space from 32MiB to 16MiB Thu, 13 Jul 2017 06:31:46 GMT Sebastian Huber [de5791b] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/fman/mac.c (modified) * linux/drivers/net/ethernet/freescale/fman/mac.h (modified) * linux/drivers/soc/fsl/qbman/qman.c (modified) * linux/drivers/soc/fsl/qbman/qman_portal.c (modified) * linux/drivers/soc/fsl/qbman/qman_priv.h (modified) * linux/include/soc/fsl/qman.h (modified) * rtemsbsd/powerpc/include/soc/fsl/dpaa.h (modified) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.c (modified) dpaa: Add "libbsd,dedicated-portal" to QMan portals By default, the ... Fri, 23 Jun 2017 09:39:26 GMT Sebastian Huber [e818128] * linux/drivers/soc/fsl/qbman/qman_portal.c (modified) dpaa: Add "libbsd,dequeue" to QMan portals The dequeue support for ... Tue, 11 Jul 2017 12:53:42 GMT Sebastian Huber [3cfc31c] * linux/drivers/soc/fsl/qbman/bman.c (modified) * linux/drivers/soc/fsl/qbman/qman.c (modified) dpaa: Set portal interrupt affinity Mon, 10 Jul 2017 07:19:10 GMT Sebastian Huber [ef1655c] * linux-org (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/fman/mac.c (modified) Update to Linux 4.12 Linux baseline ... Tue, 27 Jun 2017 10:51:07 GMT Sebastian Huber [e3dc39e] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * rtemsbsd/powerpc/include/soc/fsl/dpaa.h (added) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.c (modified) dpaa: Add Tue, 27 Jun 2017 07:31:34 GMT Sebastian Huber [9789434] * rtemsbsd/powerpc/include/asm/byteorder.h (modified) * rtemsbsd/powerpc/include/linux/kernel.h (modified) linux: Move upper_32_bits() and lower_32_bits() Tue, 27 Jun 2017 07:31:11 GMT Sebastian Huber [65d6fa2] * rtemsbsd/powerpc/include/asm/types.h (modified) linux: Make Linux types available in user-space Tue, 27 Jun 2017 07:30:44 GMT Sebastian Huber [0de65a8] * rtemsbsd/powerpc/include/linux/bitops.h (modified) linux: Include missing Tue, 27 Jun 2017 06:36:05 GMT Sebastian Huber [9cc419f] * builder.py (modified) * libbsd_waf.py (modified) Install Linux header files Tue, 27 Jun 2017 06:34:53 GMT Sebastian Huber [33d82be1] * builder.py (modified) * libbsd_waf.py (modified) * waf_generator.py (modified) waf: Install arch-specific header files Wed, 21 Jun 2017 12:35:19 GMT Sebastian Huber [e846288] * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_var.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/zerocopy.h (modified) * rtemsbsd/rtems/rtems-bsd-set-if-input.c (added) Add rtems_bsd_set_if_input() Wed, 24 May 2017 11:16:11 GMT Sebastian Huber [07c8680] * rtemsbsd/sys/powerpc/fdt_phy.c (modified) dpaa: Get c45 ids Wed, 24 May 2017 11:15:14 GMT Sebastian Huber [03d1426] * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.c (modified) dpaa: No error if MII attach failed Wed, 24 May 2017 06:32:09 GMT Sebastian Huber [9da83e7] * rtemsbsd/powerpc/include/linux/phy.h (modified) * rtemsbsd/sys/powerpc/fdt_phy.c (modified) dpaa: Support c45 phys Fri, 19 May 2017 07:47:45 GMT Sebastian Huber [66e83e0e] * linux/drivers/soc/fsl/qbman/bman.c (modified) soc/qbman: Simplify bman_release() Get the affine portal only once ... Fri, 19 May 2017 07:41:16 GMT Sebastian Huber [1908686] * linux/drivers/soc/fsl/qbman/qman.c (modified) soc/qman: Do not enable stashing without PAMU Do not enable ... Fri, 19 May 2017 07:31:15 GMT Sebastian Huber [e2d48f5] * rtemsbsd/powerpc/include/linux/bitops.h (modified) dpaa: Implement GENMASK() similar to Linux Thu, 18 May 2017 12:19:09 GMT Sebastian Huber [7f1f428] * linux/drivers/soc/fsl/qbman/qman.c (modified) qman_api.c: Prevent false clearing of IRQ status Adding ... Thu, 18 May 2017 09:53:08 GMT Sebastian Huber [69a5677] * linux/drivers/soc/fsl/qbman/qman.c (modified) * linux/include/soc/fsl/qman.h (modified) dpaa: Disable QMAN_VOLATILE_FLAG_WAIT_INT Thu, 18 May 2017 09:50:43 GMT Sebastian Huber [96da40c] * linux/drivers/soc/fsl/qbman/qman.c (modified) dpaa: Avoid QMan work queue Thu, 18 May 2017 06:13:07 GMT Sebastian Huber [ed254d58] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.c (modified) dpaa: Use receive checksum offload Thu, 18 May 2017 05:44:00 GMT Sebastian Huber [3471177] * linux/drivers/soc/fsl/qbman/qman.c (modified) dpaa: Enable preemption in qm_mr_process_task() Thu, 18 May 2017 05:28:22 GMT Sebastian Huber [b3a6ad0] * linux/drivers/soc/fsl/qbman/qman.c (modified) dpaa: Disable unused CGR code Thu, 18 May 2017 05:27:33 GMT Sebastian Huber [cf40770] * linux-org (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (modified) * linux/drivers/net/ethernet/freescale/fman/fman.c (modified) * linux/drivers/net/ethernet/freescale/fman/fman.h (modified) * linux/drivers/net/ethernet/freescale/fman/fman_dtsec.c (modified) * linux/drivers/net/ethernet/freescale/fman/fman_memac.c (modified) * linux/drivers/net/ethernet/freescale/fman/fman_memac.h (modified) * linux/drivers/net/ethernet/freescale/fman/fman_port.c (modified) * linux/drivers/soc/fsl/qbman/qman.c (modified) * linux/drivers/soc/fsl/qbman/qman_ccsr.c (modified) * linux/drivers/soc/fsl/qbman/qman_priv.h (modified) * linux/include/soc/fsl/qman.h (modified) Linux update to 4.12-rc1+ Linux baseline ... Wed, 17 May 2017 07:25:39 GMT Sebastian Huber [721b1c1] * linux/drivers/soc/fsl/qbman/bman_ccsr.c (modified) * linux/drivers/soc/fsl/qbman/qman_ccsr.c (modified) * linux/drivers/soc/fsl/qbman/qman_portal.c (modified) qbman: Fix platform_get_irq() error checks Fri, 05 May 2017 06:47:39 GMT Sebastian Huber [cd089b9] * libbsd.py (modified) * libbsd_waf.py (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_common.c (deleted) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_common.h (deleted) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_sg.c (deleted) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_trace.h (modified) * linux/drivers/net/ethernet/freescale/fman/fman.c (modified) * linux/drivers/net/ethernet/freescale/fman/fman.h (modified) * linux/drivers/net/ethernet/freescale/fman/fman_dtsec.c (modified) * linux/drivers/net/ethernet/freescale/fman/fman_mac.h (modified) * linux/drivers/net/ethernet/freescale/fman/fman_memac.c (modified) * linux/drivers/net/ethernet/freescale/fman/fman_muram.h (modified) * linux/drivers/net/ethernet/freescale/fman/fman_port.c (modified) * linux/drivers/net/ethernet/freescale/fman/fman_port.h (modified) * linux/drivers/net/ethernet/freescale/fman/fman_sp.c (modified) * linux/drivers/net/ethernet/freescale/fman/fman_tgec.c (modified) * linux/drivers/net/ethernet/freescale/fman/mac.c (modified) * linux/drivers/net/ethernet/freescale/fman/mac.h (modified) * linux/drivers/soc/fsl/qbman/bman.c (modified) * linux/drivers/soc/fsl/qbman/bman_api.c (deleted) * linux/drivers/soc/fsl/qbman/bman_ccsr.c (added) * linux/drivers/soc/fsl/qbman/bman_portal.c (deleted) * linux/drivers/soc/fsl/qbman/bman_priv.h (modified) * linux/drivers/soc/fsl/qbman/bman_test.c (deleted) * linux/drivers/soc/fsl/qbman/bman_test.h (modified) * linux/drivers/soc/fsl/qbman/bman_test_api.c (modified) * linux/drivers/soc/fsl/qbman/bman_test_thresh.c (deleted) * linux/drivers/soc/fsl/qbman/bman_utils.c (deleted) * linux/drivers/soc/fsl/qbman/dpaa_resource.c (deleted) * linux/drivers/soc/fsl/qbman/dpaa_sys.h (modified) * linux/drivers/soc/fsl/qbman/qman.c (modified) * linux/drivers/soc/fsl/qbman/qman.h (deleted) * linux/drivers/soc/fsl/qbman/qman_api.c (deleted) * linux/drivers/soc/fsl/qbman/qman_ccsr.c (added) * linux/drivers/soc/fsl/qbman/qman_driver.c (deleted) * linux/drivers/soc/fsl/qbman/qman_portal.c (modified) * linux/drivers/soc/fsl/qbman/qman_priv.h (modified) * linux/drivers/soc/fsl/qbman/qman_test.c (deleted) * linux/drivers/soc/fsl/qbman/qman_test.h (modified) * linux/drivers/soc/fsl/qbman/qman_test_api.c (modified) * linux/drivers/soc/fsl/qbman/qman_test_stash.c (modified) * linux/drivers/soc/fsl/qbman/qman_utils.c (deleted) * linux/include/soc/fsl/bman.h (modified) * linux/include/soc/fsl/qman.h (modified) * rtemsbsd/powerpc/include/asm/cache.h (modified) * rtemsbsd/powerpc/include/linux/bitops.h (modified) * rtemsbsd/powerpc/include/linux/compiler.h (modified) * rtemsbsd/powerpc/include/linux/cpu.h (added) * rtemsbsd/powerpc/include/linux/cpumask.h (added) * rtemsbsd/powerpc/include/linux/crc32.h (moved) * rtemsbsd/powerpc/include/linux/device.h (modified) * rtemsbsd/powerpc/include/linux/fsl/guts.h (added) * rtemsbsd/powerpc/include/linux/genalloc.h (added) * rtemsbsd/powerpc/include/linux/ioport.h (modified) * rtemsbsd/powerpc/include/linux/libfdt_env.h (added) * rtemsbsd/powerpc/include/linux/list.h (modified) * rtemsbsd/powerpc/include/linux/mii.h (added) * rtemsbsd/powerpc/include/linux/netdevice.h (modified) * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/powerpc/include/linux/of_mdio.h (modified) * rtemsbsd/powerpc/include/linux/of_net.h (modified) * rtemsbsd/powerpc/include/linux/percpu.h (modified) * rtemsbsd/powerpc/include/linux/phy.h (modified) * rtemsbsd/powerpc/include/linux/platform_device.h (modified) * rtemsbsd/powerpc/include/linux/prefetch.h (added) * rtemsbsd/powerpc/include/linux/sched/signal.h (added) * rtemsbsd/powerpc/include/linux/slab.h (modified) * rtemsbsd/powerpc/include/linux/types.h (modified) * rtemsbsd/powerpc/include/linux/wait.h (modified) * rtemsbsd/powerpc/include/linux/workqueue.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.c (modified) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.h (modified) * rtemsbsd/sys/powerpc/fdt_phy.c (modified) * rtemsbsd/sys/powerpc/fman_muram.c (modified) Linux update to 4.11-rc5 Linux baseline ... Wed, 27 Apr 2016 09:58:19 GMT Sebastian Huber [28ee86a] * builder.py (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (added) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (added) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_common.c (added) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_common.h (added) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_sg.c (added) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_sysfs.c (added) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth_trace.h (added) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_ethtool.c (added) * linux/drivers/net/ethernet/freescale/fman/crc_mac_addr_ext.h (added) * linux/drivers/net/ethernet/freescale/fman/fman.c (added) * linux/drivers/net/ethernet/freescale/fman/fman.h (added) * linux/drivers/net/ethernet/freescale/fman/fman_dtsec.c (added) * linux/drivers/net/ethernet/freescale/fman/fman_dtsec.h (added) * linux/drivers/net/ethernet/freescale/fman/fman_mac.h (added) * linux/drivers/net/ethernet/freescale/fman/fman_memac.c (added) * linux/drivers/net/ethernet/freescale/fman/fman_memac.h (added) * linux/drivers/net/ethernet/freescale/fman/fman_muram.c (added) * linux/drivers/net/ethernet/freescale/fman/fman_muram.h (added) * linux/drivers/net/ethernet/freescale/fman/fman_port.c (added) * linux/drivers/net/ethernet/freescale/fman/fman_port.h (added) * linux/drivers/net/ethernet/freescale/fman/fman_sp.c (added) * linux/drivers/net/ethernet/freescale/fman/fman_sp.h (added) * linux/drivers/net/ethernet/freescale/fman/fman_tgec.c (added) * linux/drivers/net/ethernet/freescale/fman/fman_tgec.h (added) * linux/drivers/net/ethernet/freescale/fman/mac.c (added) * linux/drivers/net/ethernet/freescale/fman/mac.h (added) * linux/drivers/soc/fsl/qbman/bman-debugfs.c (added) * linux/drivers/soc/fsl/qbman/bman.c (added) * linux/drivers/soc/fsl/qbman/bman.h (added) * linux/drivers/soc/fsl/qbman/bman_api.c (added) * linux/drivers/soc/fsl/qbman/bman_portal.c (added) * linux/drivers/soc/fsl/qbman/bman_priv.h (added) * linux/drivers/soc/fsl/qbman/bman_test.c (added) * linux/drivers/soc/fsl/qbman/bman_test.h (added) * linux/drivers/soc/fsl/qbman/bman_test_api.c (added) * linux/drivers/soc/fsl/qbman/bman_test_thresh.c (added) * linux/drivers/soc/fsl/qbman/bman_utils.c (added) * linux/drivers/soc/fsl/qbman/dpaa_resource.c (added) * linux/drivers/soc/fsl/qbman/dpaa_sys.h (added) * linux/drivers/soc/fsl/qbman/qman-debugfs.c (added) * linux/drivers/soc/fsl/qbman/qman.c (added) * linux/drivers/soc/fsl/qbman/qman.h (added) * linux/drivers/soc/fsl/qbman/qman_api.c (added) * linux/drivers/soc/fsl/qbman/qman_driver.c (added) * linux/drivers/soc/fsl/qbman/qman_portal.c (added) * linux/drivers/soc/fsl/qbman/qman_priv.h (added) * linux/drivers/soc/fsl/qbman/qman_test.c (added) * linux/drivers/soc/fsl/qbman/qman_test.h (added) * linux/drivers/soc/fsl/qbman/qman_test_api.c (added) * linux/drivers/soc/fsl/qbman/qman_test_stash.c (added) * linux/drivers/soc/fsl/qbman/qman_utils.c (added) * linux/include/soc/fsl/bman.h (added) * linux/include/soc/fsl/qman.h (added) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_dpaa.h (added) * rtemsbsd/powerpc/include/asm/atomic.h (added) * rtemsbsd/powerpc/include/asm/byteorder.h (added) * rtemsbsd/powerpc/include/asm/cache.h (added) * rtemsbsd/powerpc/include/asm/cacheflush.h (added) * rtemsbsd/powerpc/include/asm/fsl_pamu_stash.h (added) * rtemsbsd/powerpc/include/asm/mpc85xx.h (added) * rtemsbsd/powerpc/include/asm/pgtable.h (added) * rtemsbsd/powerpc/include/asm/types.h (added) * rtemsbsd/powerpc/include/fdt_phy.h (added) * rtemsbsd/powerpc/include/linux/bitops.h (added) * rtemsbsd/powerpc/include/linux/bitrev.h (added) * rtemsbsd/powerpc/include/linux/clk.h (added) * rtemsbsd/powerpc/include/linux/compiler.h (added) * rtemsbsd/powerpc/include/linux/completion.h (added) * rtemsbsd/powerpc/include/linux/ctype.h (added) * rtemsbsd/powerpc/include/linux/debugfs.h (added) * rtemsbsd/powerpc/include/linux/delay.h (added) * rtemsbsd/powerpc/include/linux/device.h (added) * rtemsbsd/powerpc/include/linux/dma-mapping.h (added) * rtemsbsd/powerpc/include/linux/err.h (added) * rtemsbsd/powerpc/include/linux/errno.h (added) * rtemsbsd/powerpc/include/linux/etherdevice.h (added) * rtemsbsd/powerpc/include/linux/gfp.h (added) * rtemsbsd/powerpc/include/linux/if_ether.h (added) * rtemsbsd/powerpc/include/linux/init.h (added) * rtemsbsd/powerpc/include/linux/interrupt.h (added) * rtemsbsd/powerpc/include/linux/io.h (added) * rtemsbsd/powerpc/include/linux/iommu.h (added) * rtemsbsd/powerpc/include/linux/ioport.h (added) * rtemsbsd/powerpc/include/linux/jiffies.h (added) * rtemsbsd/powerpc/include/linux/kdev_t.h (added) * rtemsbsd/powerpc/include/linux/kernel.h (added) * rtemsbsd/powerpc/include/linux/kobject.h (added) * rtemsbsd/powerpc/include/linux/kref.h (added) * rtemsbsd/powerpc/include/linux/kthread.h (added) * rtemsbsd/powerpc/include/linux/list.h (added) * rtemsbsd/powerpc/include/linux/log2.h (added) * rtemsbsd/powerpc/include/linux/module.h (added) * rtemsbsd/powerpc/include/linux/moduleparam.h (added) * rtemsbsd/powerpc/include/linux/netdevice.h (added) * rtemsbsd/powerpc/include/linux/of.h (added) * rtemsbsd/powerpc/include/linux/of_address.h (added) * rtemsbsd/powerpc/include/linux/of_irq.h (added) * rtemsbsd/powerpc/include/linux/of_mdio.h (added) * rtemsbsd/powerpc/include/linux/of_net.h (added) * rtemsbsd/powerpc/include/linux/of_platform.h (added) * rtemsbsd/powerpc/include/linux/of_reserved_mem.h (added) * rtemsbsd/powerpc/include/linux/page.h (added) * rtemsbsd/powerpc/include/linux/percpu.h (added) * rtemsbsd/powerpc/include/linux/phy.h (added) * rtemsbsd/powerpc/include/linux/phy_fixed.h (added) * rtemsbsd/powerpc/include/linux/platform_device.h (added) * rtemsbsd/powerpc/include/linux/rbtree.h (added) * rtemsbsd/powerpc/include/linux/rwlock.h (added) * rtemsbsd/powerpc/include/linux/sched.h (added) * rtemsbsd/powerpc/include/linux/slab.h (added) * rtemsbsd/powerpc/include/linux/smp.h (added) * rtemsbsd/powerpc/include/linux/spinlock.h (added) * rtemsbsd/powerpc/include/linux/sysfs.h (added) * rtemsbsd/powerpc/include/linux/threads.h (added) * rtemsbsd/powerpc/include/linux/time.h (added) * rtemsbsd/powerpc/include/linux/timer.h (added) * rtemsbsd/powerpc/include/linux/types.h (added) * rtemsbsd/powerpc/include/linux/uaccess.h (added) * rtemsbsd/powerpc/include/linux/vmalloc.h (added) * rtemsbsd/powerpc/include/linux/wait.h (added) * rtemsbsd/powerpc/include/linux/workqueue.h (added) * rtemsbsd/sys/powerpc/compat.c (added) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.c (added) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/dpaa/if_fmanmac.h (added) * rtemsbsd/sys/powerpc/fdt_phy.c (added) * rtemsbsd/sys/powerpc/fman_muram.c (added) * rtemsbsd/sys/powerpc/linux_compat.c (added) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) Import DPAA driver snapshot Imported from Freescale Linux ... Fri, 20 Oct 2017 10:51:20 GMT Sebastian Huber [b2b2e1a] * freebsd/sys/powerpc/include/machine/spr.h (modified) powerpc: Fix warnings Tue, 16 May 2017 09:27:12 GMT Sebastian Huber [43fdf50] * freebsd/sys/libkern/crc32.c (added) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) Import CRC32 support from FreeBSD Wed, 17 May 2017 08:23:56 GMT Sebastian Huber [64163f3] * rtemsbsd/rtems/rtems-kernel-thread.c (modified) Initialize BSD user extension earlier Wed, 10 May 2017 09:31:29 GMT Sebastian Huber [f7f3c4b] * freebsd/sys/kern/subr_blist.c (added) * freebsd/sys/sys/blist.h (added) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) blist: Import from FreeBSD Thu, 06 Apr 2017 13:09:42 GMT Sebastian Huber [238e275] * builder.py (modified) scripts: Support CPU-dependent RTEMS source files Mon, 03 Apr 2017 13:18:09 GMT Sebastian Huber [23d6e50] * builder.py (modified) * freebsd-to-rtems.py (modified) scripts: Support Linux import Mon, 03 Apr 2017 13:12:18 GMT Sebastian Huber [fa4ec51] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * waf_generator.py (modified) scripts: Generalize names Mon, 03 Apr 2017 13:16:56 GMT Sebastian Huber [d61f731] * .gitmodules (modified) * linux-org (added) Add Linux submodule Thu, 18 May 2017 07:35:46 GMT Sebastian Huber [62c8ca0] * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/sys/rmlock.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/vm/uma_core.c (modified) * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) Fix INVARIANTS support Fri, 20 Oct 2017 10:52:37 GMT Sebastian Huber [5be4f06] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Add CPUINFO command to default network init Wed, 23 Nov 2016 13:06:26 GMT Sebastian Huber [1e554b81] * testsuite/media01/test_main.c (modified) media01: Scale with processor count Mon, 21 Nov 2016 13:57:57 GMT Sebastian Huber [91fb6e3] * rtemsbsd/rtems/rtems-kernel-page.c (modified) rtems-kernel-page: Reclaim pages earlier Thu, 10 Nov 2016 13:58:22 GMT Sebastian Huber [7533adc] * rtemsbsd/rtems/rtems-kernel-page.c (modified) rtems-kernel-page: Add used pages counter Mon, 14 Nov 2016 09:17:10 GMT Sebastian Huber [5ede682] * freebsd/sys/vm/uma_core.c (modified) ZONE(9): Use recursive lock for the UMA drain Mon, 21 Nov 2016 13:56:59 GMT Sebastian Huber [be708ff] * freebsd/sys/vm/uma_core.c (modified) ZONE(9): Reduce BUCKET_MAX to 128 Reduces the worst-case ... Tue, 26 Apr 2016 13:02:00 GMT Sebastian Huber [b988014] * freebsd/sys/vm/uma_core.c (modified) ZONE(9): Fix uma_zone_set_max() Account for items provided for ... Tue, 14 Feb 2017 10:48:46 GMT Sebastian Huber [a8e84c6] * freebsd/sys/kern/subr_bus.c (modified) DEVICE(9): Avoid NULL pointer access Fri, 20 Oct 2017 11:59:14 GMT Sebastian Huber [fd34b52] * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/swi01/init.c (modified) * testsuite/timeout01/init.c (modified) tests: Remove obsolete config defines Fri, 20 Oct 2017 12:50:14 GMT Sebastian Huber [7ec4d87] * dhcpcd/compat/pselect.c (modified) dhcpcd: Honour file descriptor maximum Tue, 17 Oct 2017 11:56:20 GMT Sebastian Huber [9a583a9] * freebsd/sys/kern/subr_sleepqueue.c (modified) SLEEPQUEUE(9): Update due to API changes Update #3117. Update #3182. Mon, 16 Oct 2017 07:49:09 GMT Sebastian Huber [79ec6b9] * builder.py (modified) * libbsd_waf.py (modified) Install libpcap header files Thu, 12 Oct 2017 07:38:16 GMT Sebastian Huber [c79946a] * freebsd/sys/net/bpf.c (modified) BPF(9): Remove RTEMS-specifics Tue, 10 Oct 2017 10:55:06 GMT Sebastian Huber [1043048] * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/addrtoname.h (modified) * freebsd/contrib/tcpdump/addrtostr.c (added) * freebsd/contrib/tcpdump/addrtostr.h (moved) * freebsd/contrib/tcpdump/af.c (modified) * freebsd/contrib/tcpdump/af.h (modified) * freebsd/contrib/tcpdump/ah.h (modified) * freebsd/contrib/tcpdump/aodv.h (deleted) * freebsd/contrib/tcpdump/appletalk.h (modified) * freebsd/contrib/tcpdump/arcnet.h (deleted) * freebsd/contrib/tcpdump/ascii_strcasecmp.c (added) * freebsd/contrib/tcpdump/ascii_strcasecmp.h (moved) * freebsd/contrib/tcpdump/atm.h (modified) * freebsd/contrib/tcpdump/bootp.h (deleted) * freebsd/contrib/tcpdump/bpf_dump.c (modified) * freebsd/contrib/tcpdump/chdlc.h (modified) * freebsd/contrib/tcpdump/checksum.c (modified) * freebsd/contrib/tcpdump/cpack.c (modified) * freebsd/contrib/tcpdump/cpack.h (modified) * freebsd/contrib/tcpdump/dccp.h (deleted) * freebsd/contrib/tcpdump/decnet.h (deleted) * freebsd/contrib/tcpdump/enc.h (deleted) * freebsd/contrib/tcpdump/esp.h (deleted) * freebsd/contrib/tcpdump/ether.h (modified) * freebsd/contrib/tcpdump/ethertype.h (modified) * freebsd/contrib/tcpdump/extract.h (modified) * freebsd/contrib/tcpdump/fddi.h (deleted) * freebsd/contrib/tcpdump/forces.h (deleted) * freebsd/contrib/tcpdump/gmpls.c (modified) * freebsd/contrib/tcpdump/gmpls.h (modified) * freebsd/contrib/tcpdump/gmt2local.c (modified) * freebsd/contrib/tcpdump/gmt2local.h (modified) * freebsd/contrib/tcpdump/icmp6.h (deleted) * freebsd/contrib/tcpdump/ieee802_11.h (deleted) * freebsd/contrib/tcpdump/ieee802_11_radio.h (deleted) * freebsd/contrib/tcpdump/igrp.h (deleted) * freebsd/contrib/tcpdump/in_cksum.c (modified) * freebsd/contrib/tcpdump/interface.h (modified) * freebsd/contrib/tcpdump/ip.h (modified) * freebsd/contrib/tcpdump/ip6.h (modified) * freebsd/contrib/tcpdump/ipnet.h (deleted) * freebsd/contrib/tcpdump/ipproto.c (modified) * freebsd/contrib/tcpdump/ipproto.h (modified) * freebsd/contrib/tcpdump/ipsec_doi.h (deleted) * freebsd/contrib/tcpdump/ipx.h (deleted) * freebsd/contrib/tcpdump/isakmp.h (deleted) * freebsd/contrib/tcpdump/l2tp.h (deleted) * freebsd/contrib/tcpdump/l2vpn.c (modified) * freebsd/contrib/tcpdump/l2vpn.h (modified) * freebsd/contrib/tcpdump/lane.h (deleted) * freebsd/contrib/tcpdump/llc.h (modified) * freebsd/contrib/tcpdump/machdep.c (modified) * freebsd/contrib/tcpdump/machdep.h (modified) * freebsd/contrib/tcpdump/mib.h (modified) * freebsd/contrib/tcpdump/mpls.h (modified) * freebsd/contrib/tcpdump/nameser.h (modified) * freebsd/contrib/tcpdump/netbios.h (deleted) * freebsd/contrib/tcpdump/netdissect-stdinc.h (moved) * freebsd/contrib/tcpdump/netdissect.c (added) * freebsd/contrib/tcpdump/netdissect.h (modified) * freebsd/contrib/tcpdump/nfs.h (modified) * freebsd/contrib/tcpdump/nfsfh.h (modified) * freebsd/contrib/tcpdump/nlpid.c (modified) * freebsd/contrib/tcpdump/nlpid.h (modified) * freebsd/contrib/tcpdump/ntp.h (deleted) * freebsd/contrib/tcpdump/oakley.h (deleted) * freebsd/contrib/tcpdump/openflow.h (added) * freebsd/contrib/tcpdump/ospf.h (modified) * freebsd/contrib/tcpdump/ospf6.h (deleted) * freebsd/contrib/tcpdump/oui.c (modified) * freebsd/contrib/tcpdump/oui.h (modified) * freebsd/contrib/tcpdump/parsenfsfh.c (modified) * freebsd/contrib/tcpdump/pcap-missing.h (modified) * freebsd/contrib/tcpdump/pmap_prot.h (deleted) * freebsd/contrib/tcpdump/ppi.h (deleted) * freebsd/contrib/tcpdump/ppp.h (modified) * freebsd/contrib/tcpdump/print-802_11.c (modified) * freebsd/contrib/tcpdump/print-802_15_4.c (modified) * freebsd/contrib/tcpdump/print-ah.c (modified) * freebsd/contrib/tcpdump/print-ahcp.c (added) * freebsd/contrib/tcpdump/print-aodv.c (modified) * freebsd/contrib/tcpdump/print-aoe.c (added) * freebsd/contrib/tcpdump/print-ap1394.c (modified) * freebsd/contrib/tcpdump/print-arcnet.c (modified) * freebsd/contrib/tcpdump/print-arp.c (modified) * freebsd/contrib/tcpdump/print-ascii.c (modified) * freebsd/contrib/tcpdump/print-atalk.c (modified) * freebsd/contrib/tcpdump/print-atm.c (modified) * freebsd/contrib/tcpdump/print-babel.c (modified) * freebsd/contrib/tcpdump/print-beep.c (modified) * freebsd/contrib/tcpdump/print-bfd.c (modified) * freebsd/contrib/tcpdump/print-bgp.c (modified) * freebsd/contrib/tcpdump/print-bootp.c (modified) * freebsd/contrib/tcpdump/print-bt.c (modified) * freebsd/contrib/tcpdump/print-calm-fast.c (added) * freebsd/contrib/tcpdump/print-carp.c (modified) * freebsd/contrib/tcpdump/print-cdp.c (modified) * freebsd/contrib/tcpdump/print-cfm.c (modified) * freebsd/contrib/tcpdump/print-chdlc.c (modified) * freebsd/contrib/tcpdump/print-cip.c (modified) * freebsd/contrib/tcpdump/print-cnfp.c (modified) * freebsd/contrib/tcpdump/print-dccp.c (modified) * freebsd/contrib/tcpdump/print-decnet.c (modified) * freebsd/contrib/tcpdump/print-dhcp6.c (modified) * freebsd/contrib/tcpdump/print-domain.c (modified) * freebsd/contrib/tcpdump/print-dtp.c (modified) * freebsd/contrib/tcpdump/print-dvmrp.c (modified) * freebsd/contrib/tcpdump/print-eap.c (modified) * freebsd/contrib/tcpdump/print-egp.c (modified) * freebsd/contrib/tcpdump/print-eigrp.c (modified) * freebsd/contrib/tcpdump/print-enc.c (modified) * freebsd/contrib/tcpdump/print-esp.c (modified) * freebsd/contrib/tcpdump/print-ether.c (modified) * freebsd/contrib/tcpdump/print-fddi.c (modified) * freebsd/contrib/tcpdump/print-forces.c (modified) * freebsd/contrib/tcpdump/print-fr.c (modified) * freebsd/contrib/tcpdump/print-frag6.c (modified) * freebsd/contrib/tcpdump/print-ftp.c (moved) * freebsd/contrib/tcpdump/print-geneve.c (added) * freebsd/contrib/tcpdump/print-geonet.c (added) * freebsd/contrib/tcpdump/print-gre.c (modified) * freebsd/contrib/tcpdump/print-hncp.c (added) * freebsd/contrib/tcpdump/print-hsrp.c (modified) * freebsd/contrib/tcpdump/print-http.c (added) * freebsd/contrib/tcpdump/print-icmp.c (modified) * freebsd/contrib/tcpdump/print-icmp6.c (modified) * freebsd/contrib/tcpdump/print-igmp.c (modified) * freebsd/contrib/tcpdump/print-igrp.c (modified) * freebsd/contrib/tcpdump/print-ip.c (modified) * freebsd/contrib/tcpdump/print-ip6.c (modified) * freebsd/contrib/tcpdump/print-ip6opts.c (modified) * freebsd/contrib/tcpdump/print-ipcomp.c (modified) * freebsd/contrib/tcpdump/print-ipfc.c (modified) * freebsd/contrib/tcpdump/print-ipnet.c (modified) * freebsd/contrib/tcpdump/print-ipx.c (modified) * freebsd/contrib/tcpdump/print-isakmp.c (modified) * freebsd/contrib/tcpdump/print-isoclns.c (modified) * freebsd/contrib/tcpdump/print-juniper.c (modified) * freebsd/contrib/tcpdump/print-krb.c (modified) * freebsd/contrib/tcpdump/print-l2tp.c (modified) * freebsd/contrib/tcpdump/print-lane.c (modified) * freebsd/contrib/tcpdump/print-ldp.c (modified) * freebsd/contrib/tcpdump/print-lisp.c (added) * freebsd/contrib/tcpdump/print-llc.c (modified) * freebsd/contrib/tcpdump/print-lldp.c (modified) * freebsd/contrib/tcpdump/print-lmp.c (modified) * freebsd/contrib/tcpdump/print-loopback.c (added) * freebsd/contrib/tcpdump/print-lspping.c (modified) * freebsd/contrib/tcpdump/print-lwapp.c (modified) * freebsd/contrib/tcpdump/print-lwres.c (modified) * freebsd/contrib/tcpdump/print-m3ua.c (added) * freebsd/contrib/tcpdump/print-medsa.c (added) * freebsd/contrib/tcpdump/print-mobile.c (modified) * freebsd/contrib/tcpdump/print-mobility.c (modified) * freebsd/contrib/tcpdump/print-mpcp.c (modified) * freebsd/contrib/tcpdump/print-mpls.c (modified) * freebsd/contrib/tcpdump/print-mptcp.c (added) * freebsd/contrib/tcpdump/print-msdp.c (modified) * freebsd/contrib/tcpdump/print-msnlb.c (modified) * freebsd/contrib/tcpdump/print-netbios.c (deleted) * freebsd/contrib/tcpdump/print-nfs.c (modified) * freebsd/contrib/tcpdump/print-nsh.c (added) * freebsd/contrib/tcpdump/print-ntp.c (modified) * freebsd/contrib/tcpdump/print-null.c (modified) * freebsd/contrib/tcpdump/print-olsr.c (modified) * freebsd/contrib/tcpdump/print-openflow-1.0.c (added) * freebsd/contrib/tcpdump/print-openflow.c (added) * freebsd/contrib/tcpdump/print-ospf.c (modified) * freebsd/contrib/tcpdump/print-ospf6.c (modified) * freebsd/contrib/tcpdump/print-otv.c (modified) * freebsd/contrib/tcpdump/print-pflog.c (modified) * freebsd/contrib/tcpdump/print-pfsync.c (modified) * freebsd/contrib/tcpdump/print-pgm.c (modified) * freebsd/contrib/tcpdump/print-pim.c (modified) * freebsd/contrib/tcpdump/print-pktap.c (added) * freebsd/contrib/tcpdump/print-ppi.c (modified) * freebsd/contrib/tcpdump/print-ppp.c (modified) * freebsd/contrib/tcpdump/print-pppoe.c (modified) * freebsd/contrib/tcpdump/print-pptp.c (modified) * freebsd/contrib/tcpdump/print-radius.c (modified) * freebsd/contrib/tcpdump/print-raw.c (modified) * freebsd/contrib/tcpdump/print-resp.c (added) * freebsd/contrib/tcpdump/print-rip.c (modified) * freebsd/contrib/tcpdump/print-ripng.c (modified) * freebsd/contrib/tcpdump/print-rpki-rtr.c (modified) * freebsd/contrib/tcpdump/print-rrcp.c (modified) * freebsd/contrib/tcpdump/print-rsvp.c (modified) * freebsd/contrib/tcpdump/print-rt6.c (modified) * freebsd/contrib/tcpdump/print-rtsp.c (added) * freebsd/contrib/tcpdump/print-rx.c (modified) * freebsd/contrib/tcpdump/print-sctp.c (modified) * freebsd/contrib/tcpdump/print-sflow.c (modified) * freebsd/contrib/tcpdump/print-sip.c (modified) * freebsd/contrib/tcpdump/print-sl.c (modified) * freebsd/contrib/tcpdump/print-sll.c (modified) * freebsd/contrib/tcpdump/print-slow.c (modified) * freebsd/contrib/tcpdump/print-smb.c (modified) * freebsd/contrib/tcpdump/print-smtp.c (added) * freebsd/contrib/tcpdump/print-snmp.c (modified) * freebsd/contrib/tcpdump/print-stp.c (modified) * freebsd/contrib/tcpdump/print-sunatm.c (modified) * freebsd/contrib/tcpdump/print-sunrpc.c (modified) * freebsd/contrib/tcpdump/print-symantec.c (modified) * freebsd/contrib/tcpdump/print-syslog.c (modified) * freebsd/contrib/tcpdump/print-tcp.c (modified) * freebsd/contrib/tcpdump/print-telnet.c (modified) * freebsd/contrib/tcpdump/print-tftp.c (modified) * freebsd/contrib/tcpdump/print-timed.c (modified) * freebsd/contrib/tcpdump/print-tipc.c (modified) * freebsd/contrib/tcpdump/print-token.c (modified) * freebsd/contrib/tcpdump/print-udld.c (modified) * freebsd/contrib/tcpdump/print-udp.c (modified) * freebsd/contrib/tcpdump/print-usb.c (modified) * freebsd/contrib/tcpdump/print-vjc.c (modified) * freebsd/contrib/tcpdump/print-vqp.c (modified) * freebsd/contrib/tcpdump/print-vrrp.c (modified) * freebsd/contrib/tcpdump/print-vtp.c (modified) * freebsd/contrib/tcpdump/print-vxlan-gpe.c (added) * freebsd/contrib/tcpdump/print-vxlan.c (modified) * freebsd/contrib/tcpdump/print-wb.c (modified) * freebsd/contrib/tcpdump/print-zephyr.c (modified) * freebsd/contrib/tcpdump/print-zeromq.c (modified) * freebsd/contrib/tcpdump/print.c (added) * freebsd/contrib/tcpdump/print.h (added) * freebsd/contrib/tcpdump/route6d.h (deleted) * freebsd/contrib/tcpdump/rpc_auth.h (modified) * freebsd/contrib/tcpdump/rpc_msg.h (modified) * freebsd/contrib/tcpdump/rpl.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-addrtoname-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-addrtostr-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-af-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-ascii_strcasecmp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-bpf_dump-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-checksum-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-cpack-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-gmpls-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-gmt2local-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-in_cksum-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-ipproto-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-l2vpn-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-machdep-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-namespace.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-netdissect-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-nlpid-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-oui-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-parsenfsfh-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-802_11-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-802_15_4-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ah-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ahcp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-aodv-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-aoe-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ap1394-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-arcnet-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-arp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ascii-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-atalk-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-atm-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-babel-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-beep-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-bfd-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-bgp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-bootp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-bt-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-calm-fast-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-carp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-cdp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-cfm-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-chdlc-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-cip-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-cnfp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-dccp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-decnet-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-dhcp6-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-domain-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-dtp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-dvmrp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-eap-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-egp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-eigrp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-enc-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-esp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ether-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-fddi-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-forces-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-fr-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-frag6-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ftp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-geneve-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-geonet-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-gre-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-hncp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-hsrp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-http-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-icmp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-icmp6-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-igmp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-igrp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ip-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ip6-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ip6opts-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ipcomp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ipfc-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ipnet-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ipx-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-isakmp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-isoclns-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-juniper-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-krb-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-l2tp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-lane-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ldp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-lisp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-llc-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-lldp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-lmp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-loopback-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-lspping-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-lwapp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-lwres-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-m3ua-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-medsa-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-mobile-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-mobility-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-mpcp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-mpls-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-mptcp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-msdp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-msnlb-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-nfs-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-nsh-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ntp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-null-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-olsr-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-openflow-1.0-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-openflow-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ospf-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ospf6-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-otv-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pflog-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pfsync-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pgm-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pim-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pktap-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ppi-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ppp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pppoe-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-pptp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-radius-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-raw-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-resp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-rip-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-ripng-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-rpki-rtr-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-rrcp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-rsvp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-rt6-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-rtsp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-rx-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-sctp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-sflow-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-sip-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-sl-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-sll-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-slow-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-smb-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-smtp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-snmp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-stp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-sunatm-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-symantec-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-syslog-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-tcp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-telnet-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-tftp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-timed-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-tipc-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-token-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-udld-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-udp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-usb-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-vjc-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-vqp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-vrrp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-vtp-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-vxlan-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-vxlan-gpe-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-wb-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-zephyr-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-zeromq-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-setsignal-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-signature-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-smbutil-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-tcpdump-data.h (added) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-util-print-data.h (added) * freebsd/contrib/tcpdump/rx.h (deleted) * freebsd/contrib/tcpdump/sctpConstants.h (deleted) * freebsd/contrib/tcpdump/sctpHeader.h (deleted) * freebsd/contrib/tcpdump/setsignal.c (modified) * freebsd/contrib/tcpdump/setsignal.h (modified) * freebsd/contrib/tcpdump/signature.c (modified) * freebsd/contrib/tcpdump/signature.h (modified) * freebsd/contrib/tcpdump/slcompress.h (modified) * freebsd/contrib/tcpdump/slip.h (deleted) * freebsd/contrib/tcpdump/sll.h (deleted) * freebsd/contrib/tcpdump/smb.h (modified) * freebsd/contrib/tcpdump/smbutil.c (modified) * freebsd/contrib/tcpdump/strtoaddr.h (added) * freebsd/contrib/tcpdump/tcp.h (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/tcpdump/telnet.h (deleted) * freebsd/contrib/tcpdump/tftp.h (deleted) * freebsd/contrib/tcpdump/timed.h (deleted) * freebsd/contrib/tcpdump/timeval-operations.h (added) * freebsd/contrib/tcpdump/token.h (deleted) * freebsd/contrib/tcpdump/udp.h (modified) * freebsd/contrib/tcpdump/util-print.c (added) * freebsd/contrib/tcpdump/util.c (deleted) * freebsd/usr.sbin/tcpdump/tcpdump/config.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) tcpdump: Update to FreeBSD head 2017-04-04 Update tcpdump from Git ... Tue, 10 Oct 2017 12:35:40 GMT Sebastian Huber [cd7d52d] * CONTRIBUTING.md (modified) Update CONTRIBUTING.md Tue, 10 Oct 2017 10:51:26 GMT Sebastian Huber [acf428e] * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) user-space: Define O_DIRECTORY Tue, 10 Oct 2017 12:03:11 GMT Sebastian Huber [a53da0d] * userspace-header-gen.py (modified) userspace-header-gen.py: Python 3 compatibility Mon, 09 Oct 2017 07:59:36 GMT Sebastian Huber [97c5f8e8] * Makefile.todo (modified) * freebsd/contrib/libpcap/arcnet.h (modified) * freebsd/contrib/libpcap/atmuni31.h (modified) * freebsd/contrib/libpcap/bpf_image.c (modified) * freebsd/contrib/libpcap/etherent.c (modified) * freebsd/contrib/libpcap/ethertype.h (modified) * freebsd/contrib/libpcap/extract.h (added) * freebsd/contrib/libpcap/fad-getad.c (modified) * freebsd/contrib/libpcap/fad-helpers.c (added) * freebsd/contrib/libpcap/gencode.c (modified) * freebsd/contrib/libpcap/gencode.h (modified) * freebsd/contrib/libpcap/grammar.c (modified) * freebsd/contrib/libpcap/grammar.h (moved) * freebsd/contrib/libpcap/grammar.y (modified) * freebsd/contrib/libpcap/ieee80211.h (modified) * freebsd/contrib/libpcap/inet.c (modified) * freebsd/contrib/libpcap/llc.h (modified) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/nametoaddr.h (added) * freebsd/contrib/libpcap/nlpid.h (modified) * freebsd/contrib/libpcap/optimize.c (modified) * freebsd/contrib/libpcap/pcap-bpf.c (modified) * freebsd/contrib/libpcap/pcap-common.c (modified) * freebsd/contrib/libpcap/pcap-common.h (modified) * freebsd/contrib/libpcap/pcap-int.h (modified) * freebsd/contrib/libpcap/pcap-namedb.h (modified) * freebsd/contrib/libpcap/pcap.c (modified) * freebsd/contrib/libpcap/pcap.h (modified) * freebsd/contrib/libpcap/pcap/can_socketcan.h (added) * freebsd/contrib/libpcap/pcap/export-defs.h (added) * freebsd/contrib/libpcap/pcap/namedb.h (modified) * freebsd/contrib/libpcap/pcap/nflog.h (added) * freebsd/contrib/libpcap/pcap/pcap.h (modified) * freebsd/contrib/libpcap/pcap/sll.h (modified) * freebsd/contrib/libpcap/pcap/usb.h (modified) * freebsd/contrib/libpcap/pcap_version.h (added) * freebsd/contrib/libpcap/portability.h (added) * freebsd/contrib/libpcap/ppp.h (modified) * freebsd/contrib/libpcap/savefile.c (modified) * freebsd/contrib/libpcap/scanner.c (modified) * freebsd/contrib/libpcap/scanner.h (added) * freebsd/contrib/libpcap/scanner.l (modified) * freebsd/contrib/libpcap/sf-pcap-ng.c (modified) * freebsd/contrib/libpcap/sf-pcap-ng.h (modified) * freebsd/contrib/libpcap/sf-pcap.c (modified) * freebsd/contrib/libpcap/sf-pcap.h (modified) * freebsd/contrib/libpcap/sunatmpos.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) Update libpcap to FreeBSD head 2017-04-04 Update libpcap from Git ... Mon, 09 Oct 2017 11:47:45 GMT Sebastian Huber [67cbb9d] * libbsd_waf.py (modified) Regenerate libbsd_waf.py
