# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 03/28/24 19:15:43 Wed, 27 Sep 2017 07:37:38 GMT Sebastian Huber [a70edfc] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Add wmb() to descriptor updates Wed, 27 Sep 2017 07:33:41 GMT Sebastian Huber [7f7a339] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Support up to three interrupt requests Wed, 27 Sep 2017 07:42:10 GMT Sebastian Huber [e2e4bf4] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Avoid AXI bus issues due to a MAC reset Wed, 27 Sep 2017 07:54:56 GMT Sebastian Huber [ba0b059] * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/ffec/if_ffecreg.h (modified) ffec: Add FECFLAG_AVB variant flag This flag is analogous to the ... Wed, 27 Sep 2017 07:23:06 GMT Sebastian Huber [1378632] * freebsd/sys/dev/ffec/if_ffecreg.h (modified) ffec: Increase descriptor ring alignment For optimal performance a ... Wed, 27 Sep 2017 07:38:28 GMT Sebastian Huber [9c34735] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Use explicit cache synchronization Wed, 27 Sep 2017 07:55:41 GMT Sebastian Huber [91a7527] * freebsd/sys/dev/ffec/if_ffec.c (modified) ffec: Support more rgmii variants Tue, 22 Aug 2017 15:44:27 GMT Sebastian Huber [95b102f] * freebsd/sys/dev/ffec/if_ffec.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) ffec: Port to RTEMS Fri, 04 Aug 2017 12:52:32 GMT Sebastian Huber [807b5bb] * freebsd/sys/dev/ffec/if_ffec.c (added) * freebsd/sys/dev/ffec/if_ffecreg.h (added) ffec: Import from FreeBSD Fri, 22 Sep 2017 12:40:51 GMT Sebastian Huber [b469163] * rtemsbsd/rtems/rtems-kernel-nexus.c (modified) Generalize bsp_fdt_map_intr() Update #3090. Fri, 22 Sep 2017 07:41:20 GMT Christian Mauderer [c6f4aa6] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/if_atsam.h (added) * rtemsbsd/sys/dev/atsam/if_atsam.c (modified) * rtemsbsd/sys/dev/atsam/if_atsam_media.c (added) if_atsam: Allow fixed MII settings. Fri, 22 Sep 2017 07:41:19 GMT Christian Mauderer [0190cfd] * rtemsbsd/sys/dev/atsam/if_atsam.c (modified) if_atsam: Move statistics to sysctl. Fri, 22 Sep 2017 07:41:18 GMT Christian Mauderer [80a7fe6] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/atsam/if_atsam.c (modified) if-atsam: Port to rtems-libbsd. Fri, 22 Sep 2017 07:41:17 GMT Christian Mauderer [b16eca9] * rtemsbsd/sys/dev/atsam/if_atsam.c (added) rtemsbsd/if-atsam: Copy from RTEMS. Copied from RTEMS commit ... Fri, 15 Sep 2017 10:46:57 GMT Sebastian Huber [894c965] * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * rtemsbsd/rtems/rtems-kernel-get-file.c (modified) Support reference counting for file descriptors Close #3132. Fri, 25 Aug 2017 12:23:18 GMT Sebastian Huber [666a568] * freebsd/sys/sys/systm.h (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * testsuite/evdev01/init.c (modified) * testsuite/ftpd02/test_main.c (modified) * testsuite/media01/test_main.c (modified) * testsuite/pf01/test_main.c (modified) * testsuite/pf02/test_main.c (modified) * testsuite/program01/test_main.c (modified) * testsuite/selectpollkqueue01/test_main.c (modified) * testsuite/telnetd01/test_main.c (modified) * testsuite/termios/test_termios_driver.c (modified) * testsuite/termios01/test_main.c (modified) * testsuite/usbserial01/init.c (modified) Include missing and Fix warnings. Update ... Thu, 10 Aug 2017 13:03:44 GMT Sebastian Huber [34ff390] * rtemsbsd/include/machine/bus.h (modified) BUS_SPACE(9): 64-bit support Update #3082. Wed, 23 Aug 2017 08:54:04 GMT Sebastian Huber [885ac75] * freebsd/crypto/openssl/crypto/arm_arch.h (modified) * freebsd/crypto/openssl/crypto/armcap.c (modified) openssl: Workaround for ARM-specific files Update #3110. Tue, 22 Aug 2017 15:51:40 GMT Sebastian Huber [301ee6e] * freebsd/lib/libc/stdlib/strtoimax.c (deleted) * freebsd/lib/libc/stdlib/strtoumax.c (deleted) * libbsd.py (modified) * libbsd_waf.py (modified) Remove strtoimax() and strtoumax() This is now provided by Newlib. Tue, 01 Aug 2017 12:32:08 GMT Sichen Zhao <1473996754@…> [1f7037d] * builder.py (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * waf_generator.py (modified) Port openssl to RTEMS. Tue, 01 Aug 2017 12:31:19 GMT Sichen Zhao <1473996754@…> [6bed520] * freebsd/crypto/openssl/crypto/LPdir_unix.c (added) * freebsd/crypto/openssl/crypto/aes/aes.h (added) * freebsd/crypto/openssl/crypto/aes/aes_cbc.c (added) * freebsd/crypto/openssl/crypto/aes/aes_cfb.c (added) * freebsd/crypto/openssl/crypto/aes/aes_core.c (added) * freebsd/crypto/openssl/crypto/aes/aes_ctr.c (added) * freebsd/crypto/openssl/crypto/aes/aes_ecb.c (added) * freebsd/crypto/openssl/crypto/aes/aes_ige.c (added) * freebsd/crypto/openssl/crypto/aes/aes_locl.h (added) * freebsd/crypto/openssl/crypto/aes/aes_misc.c (added) * freebsd/crypto/openssl/crypto/aes/aes_ofb.c (added) * freebsd/crypto/openssl/crypto/aes/aes_wrap.c (added) * freebsd/crypto/openssl/crypto/arm_arch.h (added) * freebsd/crypto/openssl/crypto/armcap.c (added) * freebsd/crypto/openssl/crypto/asn1/a_bitstr.c (added) * freebsd/crypto/openssl/crypto/asn1/a_bool.c (added) * freebsd/crypto/openssl/crypto/asn1/a_bytes.c (added) * freebsd/crypto/openssl/crypto/asn1/a_d2i_fp.c (added) * freebsd/crypto/openssl/crypto/asn1/a_digest.c (added) * freebsd/crypto/openssl/crypto/asn1/a_dup.c (added) * freebsd/crypto/openssl/crypto/asn1/a_enum.c (added) * freebsd/crypto/openssl/crypto/asn1/a_gentm.c (added) * freebsd/crypto/openssl/crypto/asn1/a_i2d_fp.c (added) * freebsd/crypto/openssl/crypto/asn1/a_int.c (added) * freebsd/crypto/openssl/crypto/asn1/a_mbstr.c (added) * freebsd/crypto/openssl/crypto/asn1/a_object.c (added) * freebsd/crypto/openssl/crypto/asn1/a_octet.c (added) * freebsd/crypto/openssl/crypto/asn1/a_print.c (added) * freebsd/crypto/openssl/crypto/asn1/a_set.c (added) * freebsd/crypto/openssl/crypto/asn1/a_sign.c (added) * freebsd/crypto/openssl/crypto/asn1/a_strex.c (added) * freebsd/crypto/openssl/crypto/asn1/a_strnid.c (added) * freebsd/crypto/openssl/crypto/asn1/a_time.c (added) * freebsd/crypto/openssl/crypto/asn1/a_type.c (added) * freebsd/crypto/openssl/crypto/asn1/a_utctm.c (added) * freebsd/crypto/openssl/crypto/asn1/a_utf8.c (added) * freebsd/crypto/openssl/crypto/asn1/a_verify.c (added) * freebsd/crypto/openssl/crypto/asn1/ameth_lib.c (added) * freebsd/crypto/openssl/crypto/asn1/asn1.h (added) * freebsd/crypto/openssl/crypto/asn1/asn1_err.c (added) * freebsd/crypto/openssl/crypto/asn1/asn1_gen.c (added) * freebsd/crypto/openssl/crypto/asn1/asn1_lib.c (added) * freebsd/crypto/openssl/crypto/asn1/asn1_locl.h (added) * freebsd/crypto/openssl/crypto/asn1/asn1_mac.h (added) * freebsd/crypto/openssl/crypto/asn1/asn1_par.c (added) * freebsd/crypto/openssl/crypto/asn1/asn1t.h (added) * freebsd/crypto/openssl/crypto/asn1/asn_mime.c (added) * freebsd/crypto/openssl/crypto/asn1/asn_moid.c (added) * freebsd/crypto/openssl/crypto/asn1/asn_pack.c (added) * freebsd/crypto/openssl/crypto/asn1/bio_asn1.c (added) * freebsd/crypto/openssl/crypto/asn1/bio_ndef.c (added) * freebsd/crypto/openssl/crypto/asn1/charmap.h (added) * freebsd/crypto/openssl/crypto/asn1/d2i_pr.c (added) * freebsd/crypto/openssl/crypto/asn1/d2i_pu.c (added) * freebsd/crypto/openssl/crypto/asn1/evp_asn1.c (added) * freebsd/crypto/openssl/crypto/asn1/f_enum.c (added) * freebsd/crypto/openssl/crypto/asn1/f_int.c (added) * freebsd/crypto/openssl/crypto/asn1/f_string.c (added) * freebsd/crypto/openssl/crypto/asn1/i2d_pr.c (added) * freebsd/crypto/openssl/crypto/asn1/i2d_pu.c (added) * freebsd/crypto/openssl/crypto/asn1/n_pkey.c (added) * freebsd/crypto/openssl/crypto/asn1/nsseq.c (added) * freebsd/crypto/openssl/crypto/asn1/p5_pbe.c (added) * freebsd/crypto/openssl/crypto/asn1/p5_pbev2.c (added) * freebsd/crypto/openssl/crypto/asn1/p8_pkey.c (added) * freebsd/crypto/openssl/crypto/asn1/t_bitst.c (added) * freebsd/crypto/openssl/crypto/asn1/t_crl.c (added) * freebsd/crypto/openssl/crypto/asn1/t_pkey.c (added) * freebsd/crypto/openssl/crypto/asn1/t_req.c (added) * freebsd/crypto/openssl/crypto/asn1/t_spki.c (added) * freebsd/crypto/openssl/crypto/asn1/t_x509.c (added) * freebsd/crypto/openssl/crypto/asn1/t_x509a.c (added) * freebsd/crypto/openssl/crypto/asn1/tasn_dec.c (added) * freebsd/crypto/openssl/crypto/asn1/tasn_enc.c (added) * freebsd/crypto/openssl/crypto/asn1/tasn_fre.c (added) * freebsd/crypto/openssl/crypto/asn1/tasn_new.c (added) * freebsd/crypto/openssl/crypto/asn1/tasn_prn.c (added) * freebsd/crypto/openssl/crypto/asn1/tasn_typ.c (added) * freebsd/crypto/openssl/crypto/asn1/tasn_utl.c (added) * freebsd/crypto/openssl/crypto/asn1/x_algor.c (added) * freebsd/crypto/openssl/crypto/asn1/x_attrib.c (added) * freebsd/crypto/openssl/crypto/asn1/x_bignum.c (added) * freebsd/crypto/openssl/crypto/asn1/x_crl.c (added) * freebsd/crypto/openssl/crypto/asn1/x_exten.c (added) * freebsd/crypto/openssl/crypto/asn1/x_info.c (added) * freebsd/crypto/openssl/crypto/asn1/x_long.c (added) * freebsd/crypto/openssl/crypto/asn1/x_name.c (added) * freebsd/crypto/openssl/crypto/asn1/x_nx509.c (added) * freebsd/crypto/openssl/crypto/asn1/x_pkey.c (added) * freebsd/crypto/openssl/crypto/asn1/x_pubkey.c (added) * freebsd/crypto/openssl/crypto/asn1/x_req.c (added) * freebsd/crypto/openssl/crypto/asn1/x_sig.c (added) * freebsd/crypto/openssl/crypto/asn1/x_spki.c (added) * freebsd/crypto/openssl/crypto/asn1/x_val.c (added) * freebsd/crypto/openssl/crypto/asn1/x_x509.c (added) * freebsd/crypto/openssl/crypto/asn1/x_x509a.c (added) * freebsd/crypto/openssl/crypto/bf/bf_cbc.c (added) * freebsd/crypto/openssl/crypto/bf/bf_cfb64.c (added) * freebsd/crypto/openssl/crypto/bf/bf_ecb.c (added) * freebsd/crypto/openssl/crypto/bf/bf_enc.c (added) * freebsd/crypto/openssl/crypto/bf/bf_locl.h (added) * freebsd/crypto/openssl/crypto/bf/bf_ofb64.c (added) * freebsd/crypto/openssl/crypto/bf/bf_opts.c (added) * freebsd/crypto/openssl/crypto/bf/bf_pi.h (added) * freebsd/crypto/openssl/crypto/bf/bf_skey.c (added) * freebsd/crypto/openssl/crypto/bf/bfspeed.c (added) * freebsd/crypto/openssl/crypto/bf/bftest.c (added) * freebsd/crypto/openssl/crypto/bf/blowfish.h (added) * freebsd/crypto/openssl/crypto/bio/b_dump.c (added) * freebsd/crypto/openssl/crypto/bio/b_print.c (added) * freebsd/crypto/openssl/crypto/bio/b_sock.c (added) * freebsd/crypto/openssl/crypto/bio/bf_buff.c (added) * freebsd/crypto/openssl/crypto/bio/bf_lbuf.c (added) * freebsd/crypto/openssl/crypto/bio/bf_nbio.c (added) * freebsd/crypto/openssl/crypto/bio/bf_null.c (added) * freebsd/crypto/openssl/crypto/bio/bio.h (added) * freebsd/crypto/openssl/crypto/bio/bio_cb.c (added) * freebsd/crypto/openssl/crypto/bio/bio_err.c (added) * freebsd/crypto/openssl/crypto/bio/bio_lcl.h (added) * freebsd/crypto/openssl/crypto/bio/bio_lib.c (added) * freebsd/crypto/openssl/crypto/bio/bss_acpt.c (added) * freebsd/crypto/openssl/crypto/bio/bss_bio.c (added) * freebsd/crypto/openssl/crypto/bio/bss_conn.c (added) * freebsd/crypto/openssl/crypto/bio/bss_dgram.c (added) * freebsd/crypto/openssl/crypto/bio/bss_fd.c (added) * freebsd/crypto/openssl/crypto/bio/bss_file.c (added) * freebsd/crypto/openssl/crypto/bio/bss_log.c (added) * freebsd/crypto/openssl/crypto/bio/bss_mem.c (added) * freebsd/crypto/openssl/crypto/bio/bss_null.c (added) * freebsd/crypto/openssl/crypto/bio/bss_sock.c (added) * freebsd/crypto/openssl/crypto/bn/bn.h (added) * freebsd/crypto/openssl/crypto/bn/bn_add.c (added) * freebsd/crypto/openssl/crypto/bn/bn_asm.c (added) * freebsd/crypto/openssl/crypto/bn/bn_blind.c (added) * freebsd/crypto/openssl/crypto/bn/bn_const.c (added) * freebsd/crypto/openssl/crypto/bn/bn_ctx.c (added) * freebsd/crypto/openssl/crypto/bn/bn_depr.c (added) * freebsd/crypto/openssl/crypto/bn/bn_div.c (added) * freebsd/crypto/openssl/crypto/bn/bn_err.c (added) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (added) * freebsd/crypto/openssl/crypto/bn/bn_exp2.c (added) * freebsd/crypto/openssl/crypto/bn/bn_gcd.c (added) * freebsd/crypto/openssl/crypto/bn/bn_gf2m.c (added) * freebsd/crypto/openssl/crypto/bn/bn_kron.c (added) * freebsd/crypto/openssl/crypto/bn/bn_lcl.h (added) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (added) * freebsd/crypto/openssl/crypto/bn/bn_mod.c (added) * freebsd/crypto/openssl/crypto/bn/bn_mont.c (added) * freebsd/crypto/openssl/crypto/bn/bn_mpi.c (added) * freebsd/crypto/openssl/crypto/bn/bn_mul.c (added) * freebsd/crypto/openssl/crypto/bn/bn_nist.c (added) * freebsd/crypto/openssl/crypto/bn/bn_prime.c (added) * freebsd/crypto/openssl/crypto/bn/bn_prime.h (added) * freebsd/crypto/openssl/crypto/bn/bn_print.c (added) * freebsd/crypto/openssl/crypto/bn/bn_rand.c (added) * freebsd/crypto/openssl/crypto/bn/bn_recp.c (added) * freebsd/crypto/openssl/crypto/bn/bn_shift.c (added) * freebsd/crypto/openssl/crypto/bn/bn_sqr.c (added) * freebsd/crypto/openssl/crypto/bn/bn_sqrt.c (added) * freebsd/crypto/openssl/crypto/bn/bn_word.c (added) * freebsd/crypto/openssl/crypto/bn/bn_x931p.c (added) * freebsd/crypto/openssl/crypto/bn/bnspeed.c (added) * freebsd/crypto/openssl/crypto/bn/bntest.c (added) * freebsd/crypto/openssl/crypto/bn/divtest.c (added) * freebsd/crypto/openssl/crypto/bn/expspeed.c (added) * freebsd/crypto/openssl/crypto/bn/exptest.c (added) * freebsd/crypto/openssl/crypto/bn/rsaz_exp.c (added) * freebsd/crypto/openssl/crypto/bn/rsaz_exp.h (added) * freebsd/crypto/openssl/crypto/buffer/buf_err.c (added) * freebsd/crypto/openssl/crypto/buffer/buf_str.c (added) * freebsd/crypto/openssl/crypto/buffer/buffer.c (added) * freebsd/crypto/openssl/crypto/buffer/buffer.h (added) * freebsd/crypto/openssl/crypto/camellia/camellia.c (added) * freebsd/crypto/openssl/crypto/camellia/camellia.h (added) * freebsd/crypto/openssl/crypto/camellia/cmll_cbc.c (added) * freebsd/crypto/openssl/crypto/camellia/cmll_cfb.c (added) * freebsd/crypto/openssl/crypto/camellia/cmll_ctr.c (added) * freebsd/crypto/openssl/crypto/camellia/cmll_ecb.c (added) * freebsd/crypto/openssl/crypto/camellia/cmll_locl.h (added) * freebsd/crypto/openssl/crypto/camellia/cmll_misc.c (added) * freebsd/crypto/openssl/crypto/camellia/cmll_ofb.c (added) * freebsd/crypto/openssl/crypto/camellia/cmll_utl.c (added) * freebsd/crypto/openssl/crypto/cast/c_cfb64.c (added) * freebsd/crypto/openssl/crypto/cast/c_ecb.c (added) * freebsd/crypto/openssl/crypto/cast/c_enc.c (added) * freebsd/crypto/openssl/crypto/cast/c_ofb64.c (added) * freebsd/crypto/openssl/crypto/cast/c_skey.c (added) * freebsd/crypto/openssl/crypto/cast/cast.h (added) * freebsd/crypto/openssl/crypto/cast/cast_lcl.h (added) * freebsd/crypto/openssl/crypto/cast/cast_s.h (added) * freebsd/crypto/openssl/crypto/cast/cast_spd.c (added) * freebsd/crypto/openssl/crypto/cast/castopts.c (added) * freebsd/crypto/openssl/crypto/cast/casttest.c (added) * freebsd/crypto/openssl/crypto/cmac/cm_ameth.c (added) * freebsd/crypto/openssl/crypto/cmac/cm_pmeth.c (added) * freebsd/crypto/openssl/crypto/cmac/cmac.c (added) * freebsd/crypto/openssl/crypto/cmac/cmac.h (added) * freebsd/crypto/openssl/crypto/cms/cms.h (added) * freebsd/crypto/openssl/crypto/cms/cms_asn1.c (added) * freebsd/crypto/openssl/crypto/cms/cms_att.c (added) * freebsd/crypto/openssl/crypto/cms/cms_cd.c (added) * freebsd/crypto/openssl/crypto/cms/cms_dd.c (added) * freebsd/crypto/openssl/crypto/cms/cms_enc.c (added) * freebsd/crypto/openssl/crypto/cms/cms_env.c (added) * freebsd/crypto/openssl/crypto/cms/cms_err.c (added) * freebsd/crypto/openssl/crypto/cms/cms_ess.c (added) * freebsd/crypto/openssl/crypto/cms/cms_io.c (added) * freebsd/crypto/openssl/crypto/cms/cms_kari.c (added) * freebsd/crypto/openssl/crypto/cms/cms_lcl.h (added) * freebsd/crypto/openssl/crypto/cms/cms_lib.c (added) * freebsd/crypto/openssl/crypto/cms/cms_pwri.c (added) * freebsd/crypto/openssl/crypto/cms/cms_sd.c (added) * freebsd/crypto/openssl/crypto/cms/cms_smime.c (added) * freebsd/crypto/openssl/crypto/comp/c_rle.c (added) * freebsd/crypto/openssl/crypto/comp/c_zlib.c (added) * freebsd/crypto/openssl/crypto/comp/comp.h (added) * freebsd/crypto/openssl/crypto/comp/comp_err.c (added) * freebsd/crypto/openssl/crypto/comp/comp_lib.c (added) * freebsd/crypto/openssl/crypto/conf/conf.h (added) * freebsd/crypto/openssl/crypto/conf/conf_api.c (added) * freebsd/crypto/openssl/crypto/conf/conf_api.h (added) * freebsd/crypto/openssl/crypto/conf/conf_def.c (added) * freebsd/crypto/openssl/crypto/conf/conf_def.h (added) * freebsd/crypto/openssl/crypto/conf/conf_err.c (added) * freebsd/crypto/openssl/crypto/conf/conf_lib.c (added) * freebsd/crypto/openssl/crypto/conf/conf_mall.c (added) * freebsd/crypto/openssl/crypto/conf/conf_mod.c (added) * freebsd/crypto/openssl/crypto/conf/conf_sap.c (added) * freebsd/crypto/openssl/crypto/constant_time_locl.h (added) * freebsd/crypto/openssl/crypto/constant_time_test.c (added) * freebsd/crypto/openssl/crypto/cpt_err.c (added) * freebsd/crypto/openssl/crypto/cryptlib.c (added) * freebsd/crypto/openssl/crypto/cryptlib.h (added) * freebsd/crypto/openssl/crypto/crypto.h (added) * freebsd/crypto/openssl/crypto/cversion.c (added) * freebsd/crypto/openssl/crypto/des/cbc3_enc.c (added) * freebsd/crypto/openssl/crypto/des/cbc_cksm.c (added) * freebsd/crypto/openssl/crypto/des/cbc_enc.c (added) * freebsd/crypto/openssl/crypto/des/cfb64ede.c (added) * freebsd/crypto/openssl/crypto/des/cfb64enc.c (added) * freebsd/crypto/openssl/crypto/des/cfb_enc.c (added) * freebsd/crypto/openssl/crypto/des/des.c (added) * freebsd/crypto/openssl/crypto/des/des.h (added) * freebsd/crypto/openssl/crypto/des/des_enc.c (added) * freebsd/crypto/openssl/crypto/des/des_locl.h (added) * freebsd/crypto/openssl/crypto/des/des_old.h (added) * freebsd/crypto/openssl/crypto/des/des_old2.c (added) * freebsd/crypto/openssl/crypto/des/des_ver.h (added) * freebsd/crypto/openssl/crypto/des/ecb3_enc.c (added) * freebsd/crypto/openssl/crypto/des/ecb_enc.c (added) * freebsd/crypto/openssl/crypto/des/ede_cbcm_enc.c (added) * freebsd/crypto/openssl/crypto/des/enc_read.c (added) * freebsd/crypto/openssl/crypto/des/enc_writ.c (added) * freebsd/crypto/openssl/crypto/des/fcrypt.c (added) * freebsd/crypto/openssl/crypto/des/fcrypt_b.c (added) * freebsd/crypto/openssl/crypto/des/ncbc_enc.c (added) * freebsd/crypto/openssl/crypto/des/ofb64ede.c (added) * freebsd/crypto/openssl/crypto/des/ofb64enc.c (added) * freebsd/crypto/openssl/crypto/des/ofb_enc.c (added) * freebsd/crypto/openssl/crypto/des/pcbc_enc.c (added) * freebsd/crypto/openssl/crypto/des/qud_cksm.c (added) * freebsd/crypto/openssl/crypto/des/rand_key.c (added) * freebsd/crypto/openssl/crypto/des/read2pwd.c (added) * freebsd/crypto/openssl/crypto/des/read_pwd.c (added) * freebsd/crypto/openssl/crypto/des/rpc_des.h (added) * freebsd/crypto/openssl/crypto/des/rpc_enc.c (added) * freebsd/crypto/openssl/crypto/des/rpw.c (added) * freebsd/crypto/openssl/crypto/des/set_key.c (added) * freebsd/crypto/openssl/crypto/des/speed.c (added) * freebsd/crypto/openssl/crypto/des/spr.h (added) * freebsd/crypto/openssl/crypto/des/str2key.c (added) * freebsd/crypto/openssl/crypto/des/xcbc_enc.c (added) * freebsd/crypto/openssl/crypto/dh/dh.h (added) * freebsd/crypto/openssl/crypto/dh/dh_ameth.c (added) * freebsd/crypto/openssl/crypto/dh/dh_asn1.c (added) * freebsd/crypto/openssl/crypto/dh/dh_check.c (added) * freebsd/crypto/openssl/crypto/dh/dh_depr.c (added) * freebsd/crypto/openssl/crypto/dh/dh_err.c (added) * freebsd/crypto/openssl/crypto/dh/dh_gen.c (added) * freebsd/crypto/openssl/crypto/dh/dh_kdf.c (added) * freebsd/crypto/openssl/crypto/dh/dh_key.c (added) * freebsd/crypto/openssl/crypto/dh/dh_lib.c (added) * freebsd/crypto/openssl/crypto/dh/dh_pmeth.c (added) * freebsd/crypto/openssl/crypto/dh/dh_prn.c (added) * freebsd/crypto/openssl/crypto/dh/dh_rfc5114.c (added) * freebsd/crypto/openssl/crypto/dh/dhtest.c (added) * freebsd/crypto/openssl/crypto/dh/p1024.c (added) * freebsd/crypto/openssl/crypto/dh/p192.c (added) * freebsd/crypto/openssl/crypto/dh/p512.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa.h (added) * freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_asn1.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_depr.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_err.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_gen.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_key.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_lib.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_locl.h (added) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_pmeth.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_prn.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_sign.c (added) * freebsd/crypto/openssl/crypto/dsa/dsa_vrf.c (added) * freebsd/crypto/openssl/crypto/dsa/dsagen.c (added) * freebsd/crypto/openssl/crypto/dsa/dsatest.c (added) * freebsd/crypto/openssl/crypto/dso/dso.h (added) * freebsd/crypto/openssl/crypto/dso/dso_beos.c (added) * freebsd/crypto/openssl/crypto/dso/dso_dl.c (added) * freebsd/crypto/openssl/crypto/dso/dso_dlfcn.c (added) * freebsd/crypto/openssl/crypto/dso/dso_err.c (added) * freebsd/crypto/openssl/crypto/dso/dso_lib.c (added) * freebsd/crypto/openssl/crypto/dso/dso_null.c (added) * freebsd/crypto/openssl/crypto/dso/dso_openssl.c (added) * freebsd/crypto/openssl/crypto/ebcdic.c (added) * freebsd/crypto/openssl/crypto/ebcdic.h (added) * freebsd/crypto/openssl/crypto/ec/ec.h (added) * freebsd/crypto/openssl/crypto/ec/ec2_mult.c (added) * freebsd/crypto/openssl/crypto/ec/ec2_oct.c (added) * freebsd/crypto/openssl/crypto/ec/ec2_smpl.c (added) * freebsd/crypto/openssl/crypto/ec/ec_ameth.c (added) * freebsd/crypto/openssl/crypto/ec/ec_asn1.c (added) * freebsd/crypto/openssl/crypto/ec/ec_check.c (added) * freebsd/crypto/openssl/crypto/ec/ec_curve.c (added) * freebsd/crypto/openssl/crypto/ec/ec_cvt.c (added) * freebsd/crypto/openssl/crypto/ec/ec_err.c (added) * freebsd/crypto/openssl/crypto/ec/ec_key.c (added) * freebsd/crypto/openssl/crypto/ec/ec_lcl.h (added) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (added) * freebsd/crypto/openssl/crypto/ec/ec_mult.c (added) * freebsd/crypto/openssl/crypto/ec/ec_oct.c (added) * freebsd/crypto/openssl/crypto/ec/ec_pmeth.c (added) * freebsd/crypto/openssl/crypto/ec/ec_print.c (added) * freebsd/crypto/openssl/crypto/ec/eck_prn.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_mont.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_nist.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_nistputil.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256_table.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_oct.c (added) * freebsd/crypto/openssl/crypto/ec/ecp_smpl.c (added) * freebsd/crypto/openssl/crypto/ec/ectest.c (added) * freebsd/crypto/openssl/crypto/ecdh/ecdh.h (added) * freebsd/crypto/openssl/crypto/ecdh/ecdhtest.c (added) * freebsd/crypto/openssl/crypto/ecdh/ech_err.c (added) * freebsd/crypto/openssl/crypto/ecdh/ech_kdf.c (added) * freebsd/crypto/openssl/crypto/ecdh/ech_key.c (added) * freebsd/crypto/openssl/crypto/ecdh/ech_lib.c (added) * freebsd/crypto/openssl/crypto/ecdh/ech_locl.h (added) * freebsd/crypto/openssl/crypto/ecdh/ech_ossl.c (added) * freebsd/crypto/openssl/crypto/ecdsa/ecdsa.h (added) * freebsd/crypto/openssl/crypto/ecdsa/ecdsatest.c (added) * freebsd/crypto/openssl/crypto/ecdsa/ecs_asn1.c (added) * freebsd/crypto/openssl/crypto/ecdsa/ecs_err.c (added) * freebsd/crypto/openssl/crypto/ecdsa/ecs_lib.c (added) * freebsd/crypto/openssl/crypto/ecdsa/ecs_locl.h (added) * freebsd/crypto/openssl/crypto/ecdsa/ecs_ossl.c (added) * freebsd/crypto/openssl/crypto/ecdsa/ecs_sign.c (added) * freebsd/crypto/openssl/crypto/ecdsa/ecs_vrf.c (added) * freebsd/crypto/openssl/crypto/engine/eng_all.c (added) * freebsd/crypto/openssl/crypto/engine/eng_cnf.c (added) * freebsd/crypto/openssl/crypto/engine/eng_cryptodev.c (added) * freebsd/crypto/openssl/crypto/engine/eng_ctrl.c (added) * freebsd/crypto/openssl/crypto/engine/eng_dyn.c (added) * freebsd/crypto/openssl/crypto/engine/eng_err.c (added) * freebsd/crypto/openssl/crypto/engine/eng_fat.c (added) * freebsd/crypto/openssl/crypto/engine/eng_init.c (added) * freebsd/crypto/openssl/crypto/engine/eng_int.h (added) * freebsd/crypto/openssl/crypto/engine/eng_lib.c (added) * freebsd/crypto/openssl/crypto/engine/eng_list.c (added) * freebsd/crypto/openssl/crypto/engine/eng_openssl.c (added) * freebsd/crypto/openssl/crypto/engine/eng_pkey.c (added) * freebsd/crypto/openssl/crypto/engine/eng_rdrand.c (added) * freebsd/crypto/openssl/crypto/engine/eng_table.c (added) * freebsd/crypto/openssl/crypto/engine/engine.h (added) * freebsd/crypto/openssl/crypto/engine/enginetest.c (added) * freebsd/crypto/openssl/crypto/engine/tb_asnmth.c (added) * freebsd/crypto/openssl/crypto/engine/tb_cipher.c (added) * freebsd/crypto/openssl/crypto/engine/tb_dh.c (added) * freebsd/crypto/openssl/crypto/engine/tb_digest.c (added) * freebsd/crypto/openssl/crypto/engine/tb_dsa.c (added) * freebsd/crypto/openssl/crypto/engine/tb_ecdh.c (added) * freebsd/crypto/openssl/crypto/engine/tb_ecdsa.c (added) * freebsd/crypto/openssl/crypto/engine/tb_pkmeth.c (added) * freebsd/crypto/openssl/crypto/engine/tb_rand.c (added) * freebsd/crypto/openssl/crypto/engine/tb_rsa.c (added) * freebsd/crypto/openssl/crypto/engine/tb_store.c (added) * freebsd/crypto/openssl/crypto/err/err.c (added) * freebsd/crypto/openssl/crypto/err/err.h (added) * freebsd/crypto/openssl/crypto/err/err_all.c (added) * freebsd/crypto/openssl/crypto/err/err_prn.c (added) * freebsd/crypto/openssl/crypto/evp/bio_b64.c (added) * freebsd/crypto/openssl/crypto/evp/bio_enc.c (added) * freebsd/crypto/openssl/crypto/evp/bio_md.c (added) * freebsd/crypto/openssl/crypto/evp/bio_ok.c (added) * freebsd/crypto/openssl/crypto/evp/c_all.c (added) * freebsd/crypto/openssl/crypto/evp/c_allc.c (added) * freebsd/crypto/openssl/crypto/evp/c_alld.c (added) * freebsd/crypto/openssl/crypto/evp/digest.c (added) * freebsd/crypto/openssl/crypto/evp/e_aes.c (added) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c (added) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c (added) * freebsd/crypto/openssl/crypto/evp/e_bf.c (added) * freebsd/crypto/openssl/crypto/evp/e_camellia.c (added) * freebsd/crypto/openssl/crypto/evp/e_cast.c (added) * freebsd/crypto/openssl/crypto/evp/e_des.c (added) * freebsd/crypto/openssl/crypto/evp/e_des3.c (added) * freebsd/crypto/openssl/crypto/evp/e_idea.c (added) * freebsd/crypto/openssl/crypto/evp/e_null.c (added) * freebsd/crypto/openssl/crypto/evp/e_old.c (added) * freebsd/crypto/openssl/crypto/evp/e_rc2.c (added) * freebsd/crypto/openssl/crypto/evp/e_rc4.c (added) * freebsd/crypto/openssl/crypto/evp/e_rc4_hmac_md5.c (added) * freebsd/crypto/openssl/crypto/evp/e_rc5.c (added) * freebsd/crypto/openssl/crypto/evp/e_seed.c (added) * freebsd/crypto/openssl/crypto/evp/e_xcbc_d.c (added) * freebsd/crypto/openssl/crypto/evp/encode.c (added) * freebsd/crypto/openssl/crypto/evp/evp.h (added) * freebsd/crypto/openssl/crypto/evp/evp_acnf.c (added) * freebsd/crypto/openssl/crypto/evp/evp_cnf.c (added) * freebsd/crypto/openssl/crypto/evp/evp_enc.c (added) * freebsd/crypto/openssl/crypto/evp/evp_err.c (added) * freebsd/crypto/openssl/crypto/evp/evp_extra_test.c (added) * freebsd/crypto/openssl/crypto/evp/evp_key.c (added) * freebsd/crypto/openssl/crypto/evp/evp_lib.c (added) * freebsd/crypto/openssl/crypto/evp/evp_locl.h (added) * freebsd/crypto/openssl/crypto/evp/evp_pbe.c (added) * freebsd/crypto/openssl/crypto/evp/evp_pkey.c (added) * freebsd/crypto/openssl/crypto/evp/evp_test.c (added) * freebsd/crypto/openssl/crypto/evp/m_dss.c (added) * freebsd/crypto/openssl/crypto/evp/m_dss1.c (added) * freebsd/crypto/openssl/crypto/evp/m_ecdsa.c (added) * freebsd/crypto/openssl/crypto/evp/m_md2.c (added) * freebsd/crypto/openssl/crypto/evp/m_md4.c (added) * freebsd/crypto/openssl/crypto/evp/m_md5.c (added) * freebsd/crypto/openssl/crypto/evp/m_mdc2.c (added) * freebsd/crypto/openssl/crypto/evp/m_null.c (added) * freebsd/crypto/openssl/crypto/evp/m_ripemd.c (added) * freebsd/crypto/openssl/crypto/evp/m_sha.c (added) * freebsd/crypto/openssl/crypto/evp/m_sha1.c (added) * freebsd/crypto/openssl/crypto/evp/m_sigver.c (added) * freebsd/crypto/openssl/crypto/evp/m_wp.c (added) * freebsd/crypto/openssl/crypto/evp/names.c (added) * freebsd/crypto/openssl/crypto/evp/openbsd_hw.c (added) * freebsd/crypto/openssl/crypto/evp/p5_crpt.c (added) * freebsd/crypto/openssl/crypto/evp/p5_crpt2.c (added) * freebsd/crypto/openssl/crypto/evp/p_dec.c (added) * freebsd/crypto/openssl/crypto/evp/p_enc.c (added) * freebsd/crypto/openssl/crypto/evp/p_lib.c (added) * freebsd/crypto/openssl/crypto/evp/p_open.c (added) * freebsd/crypto/openssl/crypto/evp/p_seal.c (added) * freebsd/crypto/openssl/crypto/evp/p_sign.c (added) * freebsd/crypto/openssl/crypto/evp/p_verify.c (added) * freebsd/crypto/openssl/crypto/evp/pmeth_fn.c (added) * freebsd/crypto/openssl/crypto/evp/pmeth_gn.c (added) * freebsd/crypto/openssl/crypto/evp/pmeth_lib.c (added) * freebsd/crypto/openssl/crypto/ex_data.c (added) * freebsd/crypto/openssl/crypto/fips_err.h (added) * freebsd/crypto/openssl/crypto/fips_ers.c (added) * freebsd/crypto/openssl/crypto/hmac/hm_ameth.c (added) * freebsd/crypto/openssl/crypto/hmac/hm_pmeth.c (added) * freebsd/crypto/openssl/crypto/hmac/hmac.c (added) * freebsd/crypto/openssl/crypto/hmac/hmac.h (added) * freebsd/crypto/openssl/crypto/hmac/hmactest.c (added) * freebsd/crypto/openssl/crypto/idea/i_cbc.c (added) * freebsd/crypto/openssl/crypto/idea/i_cfb64.c (added) * freebsd/crypto/openssl/crypto/idea/i_ecb.c (added) * freebsd/crypto/openssl/crypto/idea/i_ofb64.c (added) * freebsd/crypto/openssl/crypto/idea/i_skey.c (added) * freebsd/crypto/openssl/crypto/idea/idea.h (added) * freebsd/crypto/openssl/crypto/idea/idea_lcl.h (added) * freebsd/crypto/openssl/crypto/idea/idea_spd.c (added) * freebsd/crypto/openssl/crypto/idea/ideatest.c (added) * freebsd/crypto/openssl/crypto/krb5/krb5_asn.c (added) * freebsd/crypto/openssl/crypto/krb5/krb5_asn.h (added) * freebsd/crypto/openssl/crypto/lhash/lhash.c (added) * freebsd/crypto/openssl/crypto/lhash/lhash.h (added) * freebsd/crypto/openssl/crypto/md32_common.h (added) * freebsd/crypto/openssl/crypto/md4/md4.c (added) * freebsd/crypto/openssl/crypto/md4/md4.h (added) * freebsd/crypto/openssl/crypto/md4/md4_dgst.c (added) * freebsd/crypto/openssl/crypto/md4/md4_locl.h (added) * freebsd/crypto/openssl/crypto/md4/md4_one.c (added) * freebsd/crypto/openssl/crypto/md4/md4test.c (added) * freebsd/crypto/openssl/crypto/md5/md5.c (added) * freebsd/crypto/openssl/crypto/md5/md5.h (added) * freebsd/crypto/openssl/crypto/md5/md5_dgst.c (added) * freebsd/crypto/openssl/crypto/md5/md5_locl.h (added) * freebsd/crypto/openssl/crypto/md5/md5_one.c (added) * freebsd/crypto/openssl/crypto/md5/md5test.c (added) * freebsd/crypto/openssl/crypto/mdc2/mdc2.h (added) * freebsd/crypto/openssl/crypto/mdc2/mdc2_one.c (added) * freebsd/crypto/openssl/crypto/mdc2/mdc2dgst.c (added) * freebsd/crypto/openssl/crypto/mdc2/mdc2test.c (added) * freebsd/crypto/openssl/crypto/mem.c (added) * freebsd/crypto/openssl/crypto/mem_clr.c (added) * freebsd/crypto/openssl/crypto/mem_dbg.c (added) * freebsd/crypto/openssl/crypto/modes/cbc128.c (added) * freebsd/crypto/openssl/crypto/modes/ccm128.c (added) * freebsd/crypto/openssl/crypto/modes/cfb128.c (added) * freebsd/crypto/openssl/crypto/modes/ctr128.c (added) * freebsd/crypto/openssl/crypto/modes/cts128.c (added) * freebsd/crypto/openssl/crypto/modes/gcm128.c (added) * freebsd/crypto/openssl/crypto/modes/modes.h (added) * freebsd/crypto/openssl/crypto/modes/modes_lcl.h (added) * freebsd/crypto/openssl/crypto/modes/ofb128.c (added) * freebsd/crypto/openssl/crypto/modes/wrap128.c (added) * freebsd/crypto/openssl/crypto/modes/xts128.c (added) * freebsd/crypto/openssl/crypto/o_dir.c (added) * freebsd/crypto/openssl/crypto/o_dir.h (added) * freebsd/crypto/openssl/crypto/o_dir_test.c (added) * freebsd/crypto/openssl/crypto/o_fips.c (added) * freebsd/crypto/openssl/crypto/o_init.c (added) * freebsd/crypto/openssl/crypto/o_str.c (added) * freebsd/crypto/openssl/crypto/o_str.h (added) * freebsd/crypto/openssl/crypto/o_time.c (added) * freebsd/crypto/openssl/crypto/o_time.h (added) * freebsd/crypto/openssl/crypto/objects/o_names.c (added) * freebsd/crypto/openssl/crypto/objects/obj_dat.c (added) * freebsd/crypto/openssl/crypto/objects/obj_dat.h (added) * freebsd/crypto/openssl/crypto/objects/obj_err.c (added) * freebsd/crypto/openssl/crypto/objects/obj_lib.c (added) * freebsd/crypto/openssl/crypto/objects/obj_mac.h (added) * freebsd/crypto/openssl/crypto/objects/obj_xref.c (added) * freebsd/crypto/openssl/crypto/objects/obj_xref.h (added) * freebsd/crypto/openssl/crypto/objects/objects.h (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp.h (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_asn.c (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_cl.c (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_err.c (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_ext.c (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_ht.c (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_lib.c (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_prn.c (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_srv.c (added) * freebsd/crypto/openssl/crypto/ocsp/ocsp_vfy.c (added) * freebsd/crypto/openssl/crypto/opensslconf.h (added) * freebsd/crypto/openssl/crypto/opensslv.h (added) * freebsd/crypto/openssl/crypto/ossl_typ.h (added) * freebsd/crypto/openssl/crypto/pem/pem.h (added) * freebsd/crypto/openssl/crypto/pem/pem2.h (added) * freebsd/crypto/openssl/crypto/pem/pem_all.c (added) * freebsd/crypto/openssl/crypto/pem/pem_err.c (added) * freebsd/crypto/openssl/crypto/pem/pem_info.c (added) * freebsd/crypto/openssl/crypto/pem/pem_lib.c (added) * freebsd/crypto/openssl/crypto/pem/pem_oth.c (added) * freebsd/crypto/openssl/crypto/pem/pem_pk8.c (added) * freebsd/crypto/openssl/crypto/pem/pem_pkey.c (added) * freebsd/crypto/openssl/crypto/pem/pem_seal.c (added) * freebsd/crypto/openssl/crypto/pem/pem_sign.c (added) * freebsd/crypto/openssl/crypto/pem/pem_x509.c (added) * freebsd/crypto/openssl/crypto/pem/pem_xaux.c (added) * freebsd/crypto/openssl/crypto/pem/pvkfmt.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_add.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_asn.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_attr.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_crpt.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_crt.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_decr.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_init.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_key.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_kiss.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_mutl.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_npas.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_p8d.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_p8e.c (added) * freebsd/crypto/openssl/crypto/pkcs12/p12_utl.c (added) * freebsd/crypto/openssl/crypto/pkcs12/pk12err.c (added) * freebsd/crypto/openssl/crypto/pkcs12/pkcs12.h (added) * freebsd/crypto/openssl/crypto/pkcs7/bio_pk7.c (added) * freebsd/crypto/openssl/crypto/pkcs7/pk7_asn1.c (added) * freebsd/crypto/openssl/crypto/pkcs7/pk7_attr.c (added) * freebsd/crypto/openssl/crypto/pkcs7/pk7_dgst.c (added) * freebsd/crypto/openssl/crypto/pkcs7/pk7_doit.c (added) * freebsd/crypto/openssl/crypto/pkcs7/pk7_lib.c (added) * freebsd/crypto/openssl/crypto/pkcs7/pk7_mime.c (added) * freebsd/crypto/openssl/crypto/pkcs7/pk7_smime.c (added) * freebsd/crypto/openssl/crypto/pkcs7/pkcs7.h (added) * freebsd/crypto/openssl/crypto/pkcs7/pkcs7err.c (added) * freebsd/crypto/openssl/crypto/ppc_arch.h (added) * freebsd/crypto/openssl/crypto/ppccap.c (added) * freebsd/crypto/openssl/crypto/pqueue/pq_test.c (added) * freebsd/crypto/openssl/crypto/pqueue/pqueue.c (added) * freebsd/crypto/openssl/crypto/pqueue/pqueue.h (added) * freebsd/crypto/openssl/crypto/rand/md_rand.c (added) * freebsd/crypto/openssl/crypto/rand/rand.h (added) * freebsd/crypto/openssl/crypto/rand/rand_egd.c (added) * freebsd/crypto/openssl/crypto/rand/rand_err.c (added) * freebsd/crypto/openssl/crypto/rand/rand_lcl.h (added) * freebsd/crypto/openssl/crypto/rand/rand_lib.c (added) * freebsd/crypto/openssl/crypto/rand/rand_unix.c (added) * freebsd/crypto/openssl/crypto/rand/randfile.c (added) * freebsd/crypto/openssl/crypto/rand/randtest.c (added) * freebsd/crypto/openssl/crypto/rc2/rc2.h (added) * freebsd/crypto/openssl/crypto/rc2/rc2_cbc.c (added) * freebsd/crypto/openssl/crypto/rc2/rc2_ecb.c (added) * freebsd/crypto/openssl/crypto/rc2/rc2_locl.h (added) * freebsd/crypto/openssl/crypto/rc2/rc2_skey.c (added) * freebsd/crypto/openssl/crypto/rc2/rc2cfb64.c (added) * freebsd/crypto/openssl/crypto/rc2/rc2ofb64.c (added) * freebsd/crypto/openssl/crypto/rc2/rc2speed.c (added) * freebsd/crypto/openssl/crypto/rc2/rc2test.c (added) * freebsd/crypto/openssl/crypto/rc2/tab.c (added) * freebsd/crypto/openssl/crypto/rc4/rc4.h (added) * freebsd/crypto/openssl/crypto/rc4/rc4_enc.c (added) * freebsd/crypto/openssl/crypto/rc4/rc4_locl.h (added) * freebsd/crypto/openssl/crypto/rc4/rc4_skey.c (added) * freebsd/crypto/openssl/crypto/rc4/rc4_utl.c (added) * freebsd/crypto/openssl/crypto/rc4/rc4speed.c (added) * freebsd/crypto/openssl/crypto/rc4/rc4test.c (added) * freebsd/crypto/openssl/crypto/ripemd/ripemd.h (added) * freebsd/crypto/openssl/crypto/ripemd/rmd160.c (added) * freebsd/crypto/openssl/crypto/ripemd/rmd_dgst.c (added) * freebsd/crypto/openssl/crypto/ripemd/rmd_locl.h (added) * freebsd/crypto/openssl/crypto/ripemd/rmd_one.c (added) * freebsd/crypto/openssl/crypto/ripemd/rmdconst.h (added) * freebsd/crypto/openssl/crypto/ripemd/rmdtest.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa.h (added) * freebsd/crypto/openssl/crypto/rsa/rsa_ameth.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_asn1.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_chk.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_crpt.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_depr.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_eay.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_err.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_lib.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_locl.h (added) * freebsd/crypto/openssl/crypto/rsa/rsa_none.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_null.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_oaep.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_pk1.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_pmeth.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_prn.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_pss.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_saos.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_sign.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_ssl.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_test.c (added) * freebsd/crypto/openssl/crypto/rsa/rsa_x931.c (added) * freebsd/crypto/openssl/crypto/s390xcap.c (added) * freebsd/crypto/openssl/crypto/seed/seed.c (added) * freebsd/crypto/openssl/crypto/seed/seed.h (added) * freebsd/crypto/openssl/crypto/seed/seed_cbc.c (added) * freebsd/crypto/openssl/crypto/seed/seed_cfb.c (added) * freebsd/crypto/openssl/crypto/seed/seed_ecb.c (added) * freebsd/crypto/openssl/crypto/seed/seed_locl.h (added) * freebsd/crypto/openssl/crypto/seed/seed_ofb.c (added) * freebsd/crypto/openssl/crypto/sha/sha.c (added) * freebsd/crypto/openssl/crypto/sha/sha.h (added) * freebsd/crypto/openssl/crypto/sha/sha1.c (added) * freebsd/crypto/openssl/crypto/sha/sha1_one.c (added) * freebsd/crypto/openssl/crypto/sha/sha1dgst.c (added) * freebsd/crypto/openssl/crypto/sha/sha1test.c (added) * freebsd/crypto/openssl/crypto/sha/sha256.c (added) * freebsd/crypto/openssl/crypto/sha/sha256t.c (added) * freebsd/crypto/openssl/crypto/sha/sha512.c (added) * freebsd/crypto/openssl/crypto/sha/sha512t.c (added) * freebsd/crypto/openssl/crypto/sha/sha_dgst.c (added) * freebsd/crypto/openssl/crypto/sha/sha_locl.h (added) * freebsd/crypto/openssl/crypto/sha/sha_one.c (added) * freebsd/crypto/openssl/crypto/sha/shatest.c (added) * freebsd/crypto/openssl/crypto/sparc_arch.h (added) * freebsd/crypto/openssl/crypto/sparcv9cap.c (added) * freebsd/crypto/openssl/crypto/srp/srp.h (added) * freebsd/crypto/openssl/crypto/srp/srp_grps.h (added) * freebsd/crypto/openssl/crypto/srp/srp_lcl.h (added) * freebsd/crypto/openssl/crypto/srp/srp_lib.c (added) * freebsd/crypto/openssl/crypto/srp/srp_vfy.c (added) * freebsd/crypto/openssl/crypto/srp/srptest.c (added) * freebsd/crypto/openssl/crypto/stack/safestack.h (added) * freebsd/crypto/openssl/crypto/stack/stack.c (added) * freebsd/crypto/openssl/crypto/stack/stack.h (added) * freebsd/crypto/openssl/crypto/symhacks.h (added) * freebsd/crypto/openssl/crypto/threads/mttest.c (added) * freebsd/crypto/openssl/crypto/threads/th-lock.c (added) * freebsd/crypto/openssl/crypto/ts/ts.h (added) * freebsd/crypto/openssl/crypto/ts/ts_asn1.c (added) * freebsd/crypto/openssl/crypto/ts/ts_conf.c (added) * freebsd/crypto/openssl/crypto/ts/ts_err.c (added) * freebsd/crypto/openssl/crypto/ts/ts_lib.c (added) * freebsd/crypto/openssl/crypto/ts/ts_req_print.c (added) * freebsd/crypto/openssl/crypto/ts/ts_req_utils.c (added) * freebsd/crypto/openssl/crypto/ts/ts_rsp_print.c (added) * freebsd/crypto/openssl/crypto/ts/ts_rsp_sign.c (added) * freebsd/crypto/openssl/crypto/ts/ts_rsp_utils.c (added) * freebsd/crypto/openssl/crypto/ts/ts_rsp_verify.c (added) * freebsd/crypto/openssl/crypto/ts/ts_verify_ctx.c (added) * freebsd/crypto/openssl/crypto/txt_db/txt_db.c (added) * freebsd/crypto/openssl/crypto/txt_db/txt_db.h (added) * freebsd/crypto/openssl/crypto/ui/ui.h (added) * freebsd/crypto/openssl/crypto/ui/ui_compat.c (added) * freebsd/crypto/openssl/crypto/ui/ui_compat.h (added) * freebsd/crypto/openssl/crypto/ui/ui_err.c (added) * freebsd/crypto/openssl/crypto/ui/ui_lib.c (added) * freebsd/crypto/openssl/crypto/ui/ui_locl.h (added) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (added) * freebsd/crypto/openssl/crypto/ui/ui_util.c (added) * freebsd/crypto/openssl/crypto/uid.c (added) * freebsd/crypto/openssl/crypto/vms_rms.h (added) * freebsd/crypto/openssl/crypto/whrlpool/whrlpool.h (added) * freebsd/crypto/openssl/crypto/whrlpool/wp_block.c (added) * freebsd/crypto/openssl/crypto/whrlpool/wp_dgst.c (added) * freebsd/crypto/openssl/crypto/whrlpool/wp_locl.h (added) * freebsd/crypto/openssl/crypto/whrlpool/wp_test.c (added) * freebsd/crypto/openssl/crypto/x509/by_dir.c (added) * freebsd/crypto/openssl/crypto/x509/by_file.c (added) * freebsd/crypto/openssl/crypto/x509/verify_extra_test.c (added) * freebsd/crypto/openssl/crypto/x509/vpm_int.h (added) * freebsd/crypto/openssl/crypto/x509/x509.h (added) * freebsd/crypto/openssl/crypto/x509/x509_att.c (added) * freebsd/crypto/openssl/crypto/x509/x509_cmp.c (added) * freebsd/crypto/openssl/crypto/x509/x509_d2.c (added) * freebsd/crypto/openssl/crypto/x509/x509_def.c (added) * freebsd/crypto/openssl/crypto/x509/x509_err.c (added) * freebsd/crypto/openssl/crypto/x509/x509_ext.c (added) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (added) * freebsd/crypto/openssl/crypto/x509/x509_obj.c (added) * freebsd/crypto/openssl/crypto/x509/x509_r2x.c (added) * freebsd/crypto/openssl/crypto/x509/x509_req.c (added) * freebsd/crypto/openssl/crypto/x509/x509_set.c (added) * freebsd/crypto/openssl/crypto/x509/x509_trs.c (added) * freebsd/crypto/openssl/crypto/x509/x509_txt.c (added) * freebsd/crypto/openssl/crypto/x509/x509_v3.c (added) * freebsd/crypto/openssl/crypto/x509/x509_vfy.c (added) * freebsd/crypto/openssl/crypto/x509/x509_vfy.h (added) * freebsd/crypto/openssl/crypto/x509/x509_vpm.c (added) * freebsd/crypto/openssl/crypto/x509/x509cset.c (added) * freebsd/crypto/openssl/crypto/x509/x509name.c (added) * freebsd/crypto/openssl/crypto/x509/x509rset.c (added) * freebsd/crypto/openssl/crypto/x509/x509spki.c (added) * freebsd/crypto/openssl/crypto/x509/x509type.c (added) * freebsd/crypto/openssl/crypto/x509/x_all.c (added) * freebsd/crypto/openssl/crypto/x509v3/ext_dat.h (added) * freebsd/crypto/openssl/crypto/x509v3/pcy_cache.c (added) * freebsd/crypto/openssl/crypto/x509v3/pcy_data.c (added) * freebsd/crypto/openssl/crypto/x509v3/pcy_int.h (added) * freebsd/crypto/openssl/crypto/x509v3/pcy_lib.c (added) * freebsd/crypto/openssl/crypto/x509v3/pcy_map.c (added) * freebsd/crypto/openssl/crypto/x509v3/pcy_node.c (added) * freebsd/crypto/openssl/crypto/x509v3/pcy_tree.c (added) * freebsd/crypto/openssl/crypto/x509v3/tabtest.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_addr.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_akey.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_akeya.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_alt.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_asid.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_bcons.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_bitst.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_conf.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_cpols.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_crld.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_enum.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_extku.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_genn.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_ia5.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_info.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_int.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_lib.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_ncons.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_ocsp.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_pci.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_pcia.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_pcons.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_pku.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_pmaps.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_prn.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_purp.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_scts.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_skey.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_sxnet.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3_utl.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3err.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3nametest.c (added) * freebsd/crypto/openssl/crypto/x509v3/v3prin.c (added) * freebsd/crypto/openssl/crypto/x509v3/x509v3.h (added) * freebsd/crypto/openssl/e_os.h (added) * freebsd/crypto/openssl/e_os2.h (added) * freebsd/crypto/openssl/engines/ccgost/e_gost_err.c (added) * freebsd/crypto/openssl/engines/ccgost/e_gost_err.h (added) * freebsd/crypto/openssl/engines/ccgost/gost2001.c (added) * freebsd/crypto/openssl/engines/ccgost/gost2001_keyx.c (added) * freebsd/crypto/openssl/engines/ccgost/gost2001_keyx.h (added) * freebsd/crypto/openssl/engines/ccgost/gost89.c (added) * freebsd/crypto/openssl/engines/ccgost/gost89.h (added) * freebsd/crypto/openssl/engines/ccgost/gost94_keyx.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_ameth.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_asn1.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_crypt.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_ctl.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_eng.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_keywrap.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_keywrap.h (added) * freebsd/crypto/openssl/engines/ccgost/gost_lcl.h (added) * freebsd/crypto/openssl/engines/ccgost/gost_md.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_params.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_params.h (added) * freebsd/crypto/openssl/engines/ccgost/gost_pmeth.c (added) * freebsd/crypto/openssl/engines/ccgost/gost_sign.c (added) * freebsd/crypto/openssl/engines/ccgost/gosthash.c (added) * freebsd/crypto/openssl/engines/ccgost/gosthash.h (added) * freebsd/crypto/openssl/engines/ccgost/gostsum.c (added) * freebsd/crypto/openssl/engines/e_4758cca.c (added) * freebsd/crypto/openssl/engines/e_4758cca_err.c (added) * freebsd/crypto/openssl/engines/e_4758cca_err.h (added) * freebsd/crypto/openssl/engines/e_aep.c (added) * freebsd/crypto/openssl/engines/e_aep_err.c (added) * freebsd/crypto/openssl/engines/e_aep_err.h (added) * freebsd/crypto/openssl/engines/e_atalla.c (added) * freebsd/crypto/openssl/engines/e_atalla_err.c (added) * freebsd/crypto/openssl/engines/e_atalla_err.h (added) * freebsd/crypto/openssl/engines/e_capi.c (added) * freebsd/crypto/openssl/engines/e_capi_err.c (added) * freebsd/crypto/openssl/engines/e_capi_err.h (added) * freebsd/crypto/openssl/engines/e_chil.c (added) * freebsd/crypto/openssl/engines/e_chil_err.c (added) * freebsd/crypto/openssl/engines/e_chil_err.h (added) * freebsd/crypto/openssl/engines/e_cswift.c (added) * freebsd/crypto/openssl/engines/e_cswift_err.c (added) * freebsd/crypto/openssl/engines/e_cswift_err.h (added) * freebsd/crypto/openssl/engines/e_gmp.c (added) * freebsd/crypto/openssl/engines/e_gmp_err.c (added) * freebsd/crypto/openssl/engines/e_gmp_err.h (added) * freebsd/crypto/openssl/engines/e_nuron.c (added) * freebsd/crypto/openssl/engines/e_nuron_err.c (added) * freebsd/crypto/openssl/engines/e_nuron_err.h (added) * freebsd/crypto/openssl/engines/e_padlock.c (added) * freebsd/crypto/openssl/engines/e_sureware.c (added) * freebsd/crypto/openssl/engines/e_sureware_err.c (added) * freebsd/crypto/openssl/engines/e_sureware_err.h (added) * freebsd/crypto/openssl/engines/e_ubsec.c (added) * freebsd/crypto/openssl/engines/e_ubsec_err.c (added) * freebsd/crypto/openssl/engines/e_ubsec_err.h (added) * freebsd/crypto/openssl/engines/vendor_defns/aep.h (added) * freebsd/crypto/openssl/engines/vendor_defns/atalla.h (added) * freebsd/crypto/openssl/engines/vendor_defns/cswift.h (added) * freebsd/crypto/openssl/engines/vendor_defns/hw_4758_cca.h (added) * freebsd/crypto/openssl/engines/vendor_defns/hw_ubsec.h (added) * freebsd/crypto/openssl/engines/vendor_defns/hwcryptohook.h (added) * freebsd/crypto/openssl/engines/vendor_defns/sureware.h (added) * freebsd/crypto/openssl/ssl/bad_dtls_test.c (added) * freebsd/crypto/openssl/ssl/bio_ssl.c (added) * freebsd/crypto/openssl/ssl/clienthellotest.c (added) * freebsd/crypto/openssl/ssl/d1_both.c (added) * freebsd/crypto/openssl/ssl/d1_clnt.c (added) * freebsd/crypto/openssl/ssl/d1_lib.c (added) * freebsd/crypto/openssl/ssl/d1_meth.c (added) * freebsd/crypto/openssl/ssl/d1_pkt.c (added) * freebsd/crypto/openssl/ssl/d1_srtp.c (added) * freebsd/crypto/openssl/ssl/d1_srvr.c (added) * freebsd/crypto/openssl/ssl/dtls1.h (added) * freebsd/crypto/openssl/ssl/kssl.c (added) * freebsd/crypto/openssl/ssl/kssl.h (added) * freebsd/crypto/openssl/ssl/kssl_lcl.h (added) * freebsd/crypto/openssl/ssl/s23_clnt.c (added) * freebsd/crypto/openssl/ssl/s23_lib.c (added) * freebsd/crypto/openssl/ssl/s23_meth.c (added) * freebsd/crypto/openssl/ssl/s23_pkt.c (added) * freebsd/crypto/openssl/ssl/s23_srvr.c (added) * freebsd/crypto/openssl/ssl/s2_clnt.c (added) * freebsd/crypto/openssl/ssl/s2_enc.c (added) * freebsd/crypto/openssl/ssl/s2_lib.c (added) * freebsd/crypto/openssl/ssl/s2_meth.c (added) * freebsd/crypto/openssl/ssl/s2_pkt.c (added) * freebsd/crypto/openssl/ssl/s2_srvr.c (added) * freebsd/crypto/openssl/ssl/s3_both.c (added) * freebsd/crypto/openssl/ssl/s3_cbc.c (added) * freebsd/crypto/openssl/ssl/s3_clnt.c (added) * freebsd/crypto/openssl/ssl/s3_enc.c (added) * freebsd/crypto/openssl/ssl/s3_lib.c (added) * freebsd/crypto/openssl/ssl/s3_meth.c (added) * freebsd/crypto/openssl/ssl/s3_pkt.c (added) * freebsd/crypto/openssl/ssl/s3_srvr.c (added) * freebsd/crypto/openssl/ssl/srtp.h (added) * freebsd/crypto/openssl/ssl/ssl.h (added) * freebsd/crypto/openssl/ssl/ssl2.h (added) * freebsd/crypto/openssl/ssl/ssl23.h (added) * freebsd/crypto/openssl/ssl/ssl3.h (added) * freebsd/crypto/openssl/ssl/ssl_algs.c (added) * freebsd/crypto/openssl/ssl/ssl_asn1.c (added) * freebsd/crypto/openssl/ssl/ssl_cert.c (added) * freebsd/crypto/openssl/ssl/ssl_ciph.c (added) * freebsd/crypto/openssl/ssl/ssl_conf.c (added) * freebsd/crypto/openssl/ssl/ssl_err.c (added) * freebsd/crypto/openssl/ssl/ssl_err2.c (added) * freebsd/crypto/openssl/ssl/ssl_lib.c (added) * freebsd/crypto/openssl/ssl/ssl_locl.h (added) * freebsd/crypto/openssl/ssl/ssl_rsa.c (added) * freebsd/crypto/openssl/ssl/ssl_sess.c (added) * freebsd/crypto/openssl/ssl/ssl_stat.c (added) * freebsd/crypto/openssl/ssl/ssl_txt.c (added) * freebsd/crypto/openssl/ssl/ssl_utst.c (added) * freebsd/crypto/openssl/ssl/ssltest.c (added) * freebsd/crypto/openssl/ssl/sslv2conftest.c (added) * freebsd/crypto/openssl/ssl/t1_clnt.c (added) * freebsd/crypto/openssl/ssl/t1_enc.c (added) * freebsd/crypto/openssl/ssl/t1_ext.c (added) * freebsd/crypto/openssl/ssl/t1_lib.c (added) * freebsd/crypto/openssl/ssl/t1_meth.c (added) * freebsd/crypto/openssl/ssl/t1_reneg.c (added) * freebsd/crypto/openssl/ssl/t1_srvr.c (added) * freebsd/crypto/openssl/ssl/t1_trce.c (added) * freebsd/crypto/openssl/ssl/tls1.h (added) * freebsd/crypto/openssl/ssl/tls_srp.c (added) Import openssl from FreeBSD. Fri, 11 Aug 2017 05:27:13 GMT Christian Mauderer [8d2dbd3] * builder.py (modified) * libbsd_waf.py (modified) * waf_generator.py (modified) waf: Move glob operator ** to builder.py This allows a finer ... Fri, 11 Aug 2017 05:27:12 GMT Christian Mauderer [307b324] * builder.py (modified) * libbsd_waf.py (modified) * waf_generator.py (modified) waf_generator: Copy headers if necessary. There are some cases, ... Tue, 01 Aug 2017 07:21:32 GMT Sichen Zhao <1473996754@…> [097ccba] * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) Enable the WEP encrypted WiFi. Now rtems can connnect WiFi via WEP ... Tue, 01 Aug 2017 07:21:31 GMT Sichen Zhao <1473996754@…> [47169ea] * Makefile.todo (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/local/rtwn-rtl8188eufw.c (added) Port rtl8188eu driver to RTEMS. Now USB dongle rtl8188eu can work ... Fri, 28 Jul 2017 06:44:52 GMT Sebastian Huber [6e328c3] * freebsd/sys/kern/kern_event.c (modified) KQUEUE(2): Add missing file handler Fri, 28 Jul 2017 06:42:42 GMT Sebastian Huber [17ab62c] * freebsd/sys/kern/sys_pipe.c (modified) PIPE(2): Add missing file handler Fri, 28 Jul 2017 06:36:33 GMT Sebastian Huber [0913210] * freebsd/sys/kern/sys_socket.c (modified) SOCKET(2): Add missing file handler Tue, 18 Jul 2017 06:31:03 GMT Sebastian Huber [b43517b] * freebsd/sys/dev/usb/controller/ohci.h (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (modified) ohci: Fix for BSP_USB_OTG_TRANSCEIVER_I2C_ADDR Mon, 17 Jul 2017 13:32:52 GMT Christian Mauderer [658f9b8] * freebsd/sys/dev/rtwn/rtl8192c/r92c_llt.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_chan.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_fw.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_init.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_led.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_priv.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_reg.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rf.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rom.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rom_defs.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rom_image.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rx.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_var.h (added) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu.h (added) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_attach.c (added) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_init.c (added) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_reg.h (added) * libbsd.py (modified) * libbsd_waf.py (modified) dev/rtwn: Import new files from FreeBSD. Thu, 13 Jul 2017 02:24:05 GMT Sichen Zhao <1473996754@…> [9121570] * freebsd/sys/arm/ti/am335x/am335x_prcm.c (modified) * freebsd/sys/arm/ti/ti_cpuid.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/intr.h (added) * rtemsbsd/include/rtems/bsd/local/fdt_pinctrl_if.h (added) Port am335x usb driver to RTEMS. Add FDT and umass support for ... Thu, 13 Jul 2017 02:24:04 GMT Sichen Zhao <1473996754@…> [bd3c01a] * freebsd/sys/arm/ti/am335x/am335x_musb.c (added) * freebsd/sys/arm/ti/am335x/am335x_prcm.c (added) * freebsd/sys/arm/ti/am335x/am335x_scm.h (added) * freebsd/sys/arm/ti/am335x/am335x_usbss.c (added) * freebsd/sys/arm/ti/ti_cpuid.h (added) * freebsd/sys/arm/ti/ti_prcm.c (added) * freebsd/sys/arm/ti/ti_prcm.h (added) * freebsd/sys/arm/ti/ti_scm.c (added) * freebsd/sys/arm/ti/ti_scm.h (added) * freebsd/sys/arm/ti/tivar.h (added) * freebsd/sys/dev/fdt/fdt_pinctrl.h (added) * freebsd/sys/dev/usb/controller/musb_otg.c (added) * freebsd/sys/dev/usb/controller/musb_otg.h (added) * freebsd/sys/sys/timeet.h (added) * freebsd/sys/sys/watchdog.h (added) Import am335x usb driver file from FreeBSD. Tue, 11 Jul 2017 08:42:32 GMT Sebastian Huber [83574df] * rtemsbsd/rtems/rtems-kernel-termioskqueuepoll.c (modified) termios: Interrupt server API changes Tue, 09 May 2017 12:09:49 GMT Sebastian Huber [378b5c2] * rtemsbsd/rtems/rtems-kernel-panic.c (modified) Use LOG_EMERG for panic() Wed, 10 May 2017 12:39:19 GMT Sebastian Huber [9128d20] * freebsd/sys/sys/libkern.h (modified) libkern.h: Add ffsll() Mon, 10 Jul 2017 06:24:56 GMT Sebastian Huber [127296c] * freebsd/sys/sys/libkern.h (modified) libkern.h: Avoid conflict with Mon, 26 Jun 2017 07:36:56 GMT Sebastian Huber [e3e88e1] * CONTRIBUTING.md (added) * libbsd.txt (modified) Add CONTRIBUTING.md Thu, 22 Jun 2017 04:56:52 GMT Sebastian Huber [9db59c7] * freebsd/lib/libc/inet/nsap_addr.c (modified) Remove unused inet_* weak references This change requires a Newlib ... Fri, 16 Jun 2017 05:31:51 GMT Sebastian Huber [b83012a] * freebsd/include/arpa/inet.h (deleted) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_net_ntop.c (modified) * freebsd/lib/libc/inet/inet_net_pton.c (modified) * freebsd/lib/libc/inet/inet_neta.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) Remove unused inet_* weak references This change requires a Newlib ... Thu, 08 Jun 2017 11:15:12 GMT Sebastian Huber [3c967ca] * builder.py (modified) * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/evdev/evdev_mt.c (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_subr.c (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_beacon.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_calib.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_cam.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_efuse.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_fw.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_task.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_tx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_reg.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_led.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_led.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_led.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_caps.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_led.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_init.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_led.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_dfs.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_init.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_reg.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c (modified) * freebsd/sys/dev/tsec/if_tsec_fdt.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/input/atp.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/uhid.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/input/wsp.c (modified) * freebsd/sys/dev/usb/net/if_aue.c (modified) * freebsd/sys/dev/usb/net/if_axe.c (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/net/if_cdce.c (modified) * freebsd/sys/dev/usb/net/if_cue.c (modified) * freebsd/sys/dev/usb/net/if_ipheth.c (modified) * freebsd/sys/dev/usb/net/if_kue.c (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/net/if_rue.c (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_udav.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/serial/uark.c (modified) * freebsd/sys/dev/usb/serial/ubsa.c (modified) * freebsd/sys/dev/usb/serial/ubser.c (modified) * freebsd/sys/dev/usb/serial/uchcom.c (modified) * freebsd/sys/dev/usb/serial/ucycom.c (modified) * freebsd/sys/dev/usb/serial/ufoma.c (modified) * freebsd/sys/dev/usb/serial/uftdi.c (modified) * freebsd/sys/dev/usb/serial/ugensa.c (modified) * freebsd/sys/dev/usb/serial/uipaq.c (modified) * freebsd/sys/dev/usb/serial/ulpt.c (modified) * freebsd/sys/dev/usb/serial/umcs.c (modified) * freebsd/sys/dev/usb/serial/umct.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/serial/umoscom.c (modified) * freebsd/sys/dev/usb/serial/uplcom.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.c (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/serial/uvisor.c (modified) * freebsd/sys/dev/usb/serial/uvscom.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_khelp.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_osd.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/kern_uuid.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_firmware.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_rman.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/tty_inq.c (modified) * freebsd/sys/kern/tty_outq.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/altq/if_altq.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/ifq.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_fib.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_fib.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec_mod.c (modified) * freebsd/sys/netipsec/ipsec_pcb.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/subr_ipsec.c (modified) * freebsd/sys/netipsec/udpencap.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw2.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_bpf.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_pfil.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_algo.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (modified) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn_control.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl_control.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/ip_fw_nptv6.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/sys/_lock.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/fail.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/hhook.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/lock_profile.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/seq.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_dbg.c (modified) * rtemsbsd/include/machine/_kernel_lock.h (modified) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (modified) * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/include/rtems/bsd/sys/lock.h (deleted) * rtemsbsd/rtems/rtems-bsd-generic.c (modified) * rtemsbsd/rtems/rtems-kernel-cam.c (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-jail.c (modified) * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-page.c (modified) * rtemsbsd/rtems/rtems-kernel-pci_cfgreg.c (modified) * rtemsbsd/rtems/rtems-kernel-program.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) * rtemsbsd/sys/dev/input/touchscreen/tsc_lpc32xx.c (modified) * rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c (modified) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (modified) * testsuite/condvar01/test_main.c (modified) * testsuite/mutex01/test_main.c (modified) * testsuite/rwlock01/test_main.c (modified) * testsuite/sleep01/test_main.c (modified) * testsuite/smp01/test_main.c (modified) * testsuite/timeout01/timeout_test.c (modified) Use provided by Newlib Tue, 23 May 2017 11:18:31 GMT Sebastian Huber [0237319] * builder.py (modified) * freebsd/bin/hostname/hostname.c (modified) * freebsd/contrib/libpcap/gencode.c (modified) * freebsd/contrib/libpcap/inet.c (modified) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/pcap-bpf.c (modified) * freebsd/contrib/libpcap/pcap-int.h (modified) * freebsd/contrib/libxo/libxo/xo_encoder.c (modified) * freebsd/contrib/tcpdump/tcpdump-stdinc.h (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/resolv.h (modified) * freebsd/lib/lib80211/lib80211_ioctl.c (modified) * freebsd/lib/lib80211/lib80211_regdomain.c (modified) * freebsd/lib/libc/db/btree/bt_close.c (modified) * freebsd/lib/libc/db/btree/bt_conv.c (modified) * freebsd/lib/libc/db/btree/bt_debug.c (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_overflow.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/btree/bt_utils.c (modified) * freebsd/lib/libc/db/mpool/mpool.c (modified) * freebsd/lib/libc/db/recno/rec_utils.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/gen/sethostname.c (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) * freebsd/lib/libc/inet/nsap_addr.c (modified) * freebsd/lib/libc/isc/eventlib_p.h (modified) * freebsd/lib/libc/net/base64.c (modified) * freebsd/lib/libc/net/ether_addr.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/gethostnamadr.c (modified) * freebsd/lib/libc/net/getifaddrs.c (modified) * freebsd/lib/libc/net/getifmaddrs.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getnetnamadr.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/ip6opt.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/rthdr.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_mkupdate.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_update.c (modified) * freebsd/lib/libc/rpc/auth_time.c (modified) * freebsd/lib/libc/rpc/auth_unix.c (modified) * freebsd/lib/libc/rpc/clnt_simple.c (modified) * freebsd/lib/libc/rpc/getrpcent.c (modified) * freebsd/lib/libc/rpc/netname.c (modified) * freebsd/lib/libc/rpc/netnamer.c (modified) * freebsd/lib/libc/rpc/rpc_generic.c (modified) * freebsd/lib/libc/rpc/rpc_prot.c (modified) * freebsd/lib/libc/rpc/svc_auth_des.c (modified) * freebsd/lib/libc/rpc/svc_vc.c (modified) * freebsd/lib/libc/xdr/xdr_float.c (modified) * freebsd/lib/libipsec/ipsec_dump_policy.c (modified) * freebsd/lib/libipsec/ipsec_get_policylen.c (modified) * freebsd/lib/libipsec/ipsec_strerror.c (modified) * freebsd/lib/libipsec/pfkey.c (modified) * freebsd/lib/libipsec/pfkey_dump.c (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/lib/libmemstat/memstat_malloc.c (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/trimdomain.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifcarp.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifgif.c (modified) * freebsd/sbin/ifconfig/ifgre.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmac.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/ifconfig/ifvlan.c (modified) * freebsd/sbin/ifconfig/sfp.c (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/arm/in_cksum.c (modified) * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/lpc/lpc_pwr.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/avr/avr/in_cksum.c (modified) * freebsd/sys/bfin/bfin/in_cksum.c (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/cam/cam.c (modified) * freebsd/sys/cam/cam_sim.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/crypto/des/des_ecb.c (modified) * freebsd/sys/crypto/des/des_setkey.c (modified) * freebsd/sys/crypto/rc4/rc4.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.c (modified) * freebsd/sys/crypto/siphash/siphash.c (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/cadence/if_cgem.c (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/evdev/cdev.c (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev_mt.c (modified) * freebsd/sys/dev/evdev/evdev_utils.c (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/fdt/simplebus.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/kbd/kbd.c (modified) * freebsd/sys/dev/led/led.c (modified) * freebsd/sys/dev/mii/brgphy.c (modified) * freebsd/sys/dev/mii/e1000phy.c (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mii/micphy.c (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/mii/mii_bitbang.c (modified) * freebsd/sys/dev/mii/mii_physubr.c (modified) * freebsd/sys/dev/mii/rgephy.c (modified) * freebsd/sys/dev/mii/ukphy.c (modified) * freebsd/sys/dev/mii/ukphy_subr.c (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_subr.c (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofw_subr.c (modified) * freebsd/sys/dev/ofw/ofwbus.c (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_beacon.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_calib.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_cam.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_efuse.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_fw.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_task.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_tx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_reg.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_led.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_led.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_led.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_caps.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_led.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_init.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_led.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_dfs.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_init.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_reg.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/tsec/if_tsec_fdt.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/input/atp.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/uhid.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/input/wsp.c (modified) * freebsd/sys/dev/usb/net/if_aue.c (modified) * freebsd/sys/dev/usb/net/if_axe.c (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/net/if_cdce.c (modified) * freebsd/sys/dev/usb/net/if_cue.c (modified) * freebsd/sys/dev/usb/net/if_ipheth.c (modified) * freebsd/sys/dev/usb/net/if_kue.c (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/net/if_rue.c (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_udav.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/net/ruephy.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/serial/uark.c (modified) * freebsd/sys/dev/usb/serial/ubsa.c (modified) * freebsd/sys/dev/usb/serial/ubser.c (modified) * freebsd/sys/dev/usb/serial/uchcom.c (modified) * freebsd/sys/dev/usb/serial/ucycom.c (modified) * freebsd/sys/dev/usb/serial/ufoma.c (modified) * freebsd/sys/dev/usb/serial/uftdi.c (modified) * freebsd/sys/dev/usb/serial/ugensa.c (modified) * freebsd/sys/dev/usb/serial/uipaq.c (modified) * freebsd/sys/dev/usb/serial/ulpt.c (modified) * freebsd/sys/dev/usb/serial/umcs.c (modified) * freebsd/sys/dev/usb/serial/umct.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/serial/umoscom.c (modified) * freebsd/sys/dev/usb/serial/uplcom.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.c (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/serial/uvisor.c (modified) * freebsd/sys/dev/usb/serial/uvscom.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_upgt.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/h8300/h8300/in_cksum.c (modified) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/i386/i386/legacy.c (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_hhook.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_khelp.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_osd.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/kern_uuid.c (modified) * freebsd/sys/kern/subr_bufring.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_firmware.c (modified) * freebsd/sys/kern/subr_hash.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_rman.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_inq.c (modified) * freebsd/sys/kern/tty_outq.c (modified) * freebsd/sys/kern/tty_ttydisc.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_mbufhash.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/bcd.c (modified) * freebsd/sys/libkern/inet_ntoa.c (modified) * freebsd/sys/lm32/lm32/in_cksum.c (modified) * freebsd/sys/m32c/m32c/in_cksum.c (modified) * freebsd/sys/m32r/m32r/in_cksum.c (modified) * freebsd/sys/m68k/m68k/in_cksum.c (modified) * freebsd/sys/mips/mips/in_cksum.c (modified) * freebsd/sys/net/altq/altq.h (modified) * freebsd/sys/net/altq/altq_cbq.c (modified) * freebsd/sys/net/altq/altq_cdnr.c (modified) * freebsd/sys/net/altq/altq_codel.c (modified) * freebsd/sys/net/altq/altq_fairq.c (modified) * freebsd/sys/net/altq/altq_hfsc.c (modified) * freebsd/sys/net/altq/altq_priq.c (modified) * freebsd/sys/net/altq/altq_red.c (modified) * freebsd/sys/net/altq/altq_rio.c (modified) * freebsd/sys/net/altq/altq_rmclass.c (modified) * freebsd/sys/net/altq/altq_subr.c (modified) * freebsd/sys/net/altq/altq_var.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if.h (deleted) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_atmsubr.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_mib.c (modified) * freebsd/sys/net/if_spppfr.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211_acl.c (modified) * freebsd/sys/net80211/ieee80211_action.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_ageq.c (modified) * freebsd/sys/net80211/ieee80211_alq.c (modified) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_crypto.c (modified) * freebsd/sys/net80211/ieee80211_crypto_ccmp.c (modified) * freebsd/sys/net80211/ieee80211_crypto_none.c (modified) * freebsd/sys/net80211/ieee80211_crypto_tkip.c (modified) * freebsd/sys/net80211/ieee80211_crypto_wep.c (modified) * freebsd/sys/net80211/ieee80211_ddb.c (modified) * freebsd/sys/net80211/ieee80211_dfs.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_monitor.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_phy.c (modified) * freebsd/sys/net80211/ieee80211_power.c (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_radiotap.c (modified) * freebsd/sys/net80211/ieee80211_ratectl.c (modified) * freebsd/sys/net80211/ieee80211_ratectl_none.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/net80211/ieee80211_scan.c (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_scan_sw.c (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_vht.c (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/net80211/ieee80211_xauth.c (modified) * freebsd/sys/netinet/accf_data.c (modified) * freebsd/sys/netinet/accf_dns.c (modified) * freebsd/sys/netinet/accf_http.c (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/if_atm.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in.h (deleted) * freebsd/sys/netinet/in_fib.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_rmx.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_ecn.c (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias_cuseeme.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_dummy.c (modified) * freebsd/sys/netinet/libalias/alias_ftp.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_pptp.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/libalias/alias_skinny.c (modified) * freebsd/sys/netinet/libalias/alias_smedia.c (modified) * freebsd/sys/netinet/libalias/alias_util.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/tcp.h (deleted) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6.h (deleted) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_fib.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_mod.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/ipsec_pcb.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/subr_ipsec.c (modified) * freebsd/sys/netipsec/udpencap.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw2.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_bpf.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_pfil.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_algo.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (modified) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn_control.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl_control.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/ip_fw_nptv6.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (modified) * freebsd/sys/netpfil/pf/if_pflog.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/in4_cksum.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/netpfil/pf/pf_ruleset.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/nios2/nios2/in_cksum.c (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodeflate.c (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/deflate.c (modified) * freebsd/sys/opencrypto/rmd160.c (modified) * freebsd/sys/opencrypto/skipjack.c (modified) * freebsd/sys/opencrypto/xform.c (modified) * freebsd/sys/opencrypto/xform_auth.h (modified) * freebsd/sys/opencrypto/xform_comp.h (modified) * freebsd/sys/opencrypto/xform_enc.h (modified) * freebsd/sys/powerpc/powerpc/in_cksum.c (modified) * freebsd/sys/sh/sh/in_cksum.c (modified) * freebsd/sys/sparc/sparc/in_cksum.c (modified) * freebsd/sys/sparc64/sparc64/in_cksum.c (modified) * freebsd/sys/sys/_bitset.h (deleted) * freebsd/sys/sys/_cpuset.h (deleted) * freebsd/sys/sys/_sockaddr_storage.h (deleted) * freebsd/sys/sys/acl.h (modified) * freebsd/sys/sys/bitset.h (deleted) * freebsd/sys/sys/bitstring.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/fail.h (modified) * freebsd/sys/sys/ktr.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/socket.h (deleted) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/v850/v850/in_cksum.c (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_dbg.c (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/tools/tools/net80211/wlanstats/main.c (modified) * freebsd/tools/tools/net80211/wlanstats/wlanstats.c (modified) * freebsd/usr.bin/netstat/bpf.c (modified) * freebsd/usr.bin/netstat/flowtable.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mbuf.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/nl_symbols.c (modified) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/_align.h (deleted) * rtemsbsd/include/machine/bitstring.h (deleted) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/machine/rtems-bsd-param.h (deleted) * rtemsbsd/include/machine/rtems-bsd-thread.h (modified) * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) * rtemsbsd/include/machine/rtems-bsd-version.h (added) * rtemsbsd/include/rtems/bsd/sys/cpuset.h (deleted) * rtemsbsd/include/rtems/bsd/sys/errno.h (deleted) * rtemsbsd/include/rtems/bsd/sys/param.h (deleted) * rtemsbsd/include/sys/_cpuset.h (deleted) * rtemsbsd/local/bus_if.c (modified) * rtemsbsd/local/cryptodev_if.c (modified) * rtemsbsd/local/device_if.c (modified) * rtemsbsd/local/gpio_if.c (modified) * rtemsbsd/local/if_dwc_if.c (modified) * rtemsbsd/local/ifdi_if.c (modified) * rtemsbsd/local/miibus_if.c (modified) * rtemsbsd/local/mmcbr_if.c (modified) * rtemsbsd/local/mmcbus_if.c (modified) * rtemsbsd/local/pcib_if.c (modified) * rtemsbsd/local/usb_if.c (modified) * rtemsbsd/rtems/ipsec_get_policylen.c (modified) * rtemsbsd/rtems/rtems-bsd-cxx.cc (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * rtemsbsd/rtems/rtems-kernel-autoconf.c (modified) * rtemsbsd/rtems/rtems-kernel-bus-root.c (modified) * rtemsbsd/rtems/rtems-kernel-cam.c (modified) * rtemsbsd/rtems/rtems-kernel-chunk.c (modified) * rtemsbsd/rtems/rtems-kernel-configintrhook.c (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-jail.c (modified) * rtemsbsd/rtems/rtems-kernel-malloc.c (modified) * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-nexus.c (modified) * rtemsbsd/rtems/rtems-kernel-page.c (modified) * rtemsbsd/rtems/rtems-kernel-panic.c (modified) * rtemsbsd/rtems/rtems-kernel-pci_bus.c (modified) * rtemsbsd/rtems/rtems-kernel-pci_cfgreg.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) * rtemsbsd/rtems/rtems-kernel-thread.c (modified) * rtemsbsd/rtems/rtems-legacy-mii.c (modified) * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) * rtemsbsd/sys/dev/ffec/if_ffec_mcf548x.c (modified) * rtemsbsd/sys/dev/input/touchscreen/tsc_lpc32xx.c (modified) * rtemsbsd/sys/dev/smc/if_smc_nexus.c (modified) * rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c (modified) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (modified) * rtemsbsd/sys/dev/usb/controller/usb_otg_transceiver_dump.c (modified) * rtemsbsd/sys/net/if_ppp.c (modified) * rtemsbsd/sys/net/ppp_tty.c (modified) * testsuite/commands01/test_main.c (modified) * testsuite/condvar01/test_main.c (modified) * testsuite/loopback01/test_main.c (modified) * testsuite/mutex01/test_main.c (modified) * testsuite/netshell01/test_main.c (modified) * testsuite/rcconf01/test_main.c (modified) * testsuite/rcconf02/test_main.c (modified) * testsuite/rwlock01/test_main.c (modified) * testsuite/selectpollkqueue01/test_main.c (modified) * testsuite/sleep01/test_main.c (modified) * testsuite/smp01/test_main.c (modified) * testsuite/termios/test_main.c (modified) * testsuite/termios/test_termios_utilities.c (modified) * testsuite/termios06/test_main.c (modified) * testsuite/thread01/test_main.c (modified) * testsuite/timeout01/timeout_test.c (modified) * testsuite/unix01/test_main.c (modified) Update due to Newlib 2017-06-07 changes The following files are now ... Wed, 17 May 2017 12:40:37 GMT Kevin Kirspel [29c0cff] * libbsd.py (modified) * libbsd_waf.py (modified) Update scripts to include support for input devices - USB Keyboard, ... Wed, 17 May 2017 12:40:36 GMT Kevin Kirspel [427ee3e] * freebsd/sys/sys/proc.h (modified) Redirect FREEBSD's kern_yield to RTEMS sched_yield Wed, 17 May 2017 12:40:35 GMT Kevin Kirspel [15a4321] * testsuite/evdev01/init.c (added) * testsuite/usbkbd01/init.c (added) * testsuite/usbmouse01/init.c (added) Add tests for USB keyboard and mouse as well as EVDEV Wed, 17 May 2017 12:40:34 GMT Kevin Kirspel [9d4afe9] * rtemsbsd/rtems/rtems-kernel-init.c (modified) Add keyboard driver set variable Wed, 17 May 2017 12:40:33 GMT Kevin Kirspel [e28a8d0] * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/input/touchscreen/tsc_lpc32xx.c (added) Add LPC32XX touch screen driver Wed, 17 May 2017 12:40:32 GMT Kevin Kirspel [fb2aa6e] * freebsd/sys/sys/bitstring.h (modified) * rtemsbsd/include/machine/bitstring.h (added) Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h Wed, 17 May 2017 12:40:31 GMT Kevin Kirspel [18cf428] * freebsd/sys/dev/evdev/evdev.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_evdev.h (added) Modify FREEBSD EVDEV driver for use in RTEMS Wed, 17 May 2017 12:40:30 GMT Kevin Kirspel [b51279b] * freebsd/sys/dev/usb/input/ukbd.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_kbd.h (added) * rtemsbsd/include/rtems/bsd/local/opt_ukbd.h (added) Modify FREEBSD USB keyboard drivers for use in RTEMS Wed, 17 May 2017 12:40:29 GMT Kevin Kirspel [a7415b7] * freebsd/sys/dev/usb/usb_dev.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_usb.h (modified) Add USB UGEN support for RTEMS Wed, 17 May 2017 12:40:28 GMT Kevin Kirspel [3e7de30] * freebsd/sys/dev/usb/input/atp.c (added) * freebsd/sys/dev/usb/input/uep.c (added) * freebsd/sys/dev/usb/input/uhid.c (added) * freebsd/sys/dev/usb/input/ukbd.c (added) * freebsd/sys/dev/usb/input/ums.c (added) * freebsd/sys/dev/usb/input/usb_rdesc.h (added) * freebsd/sys/dev/usb/input/wsp.c (added) * freebsd/sys/sys/mouse.h (added) Add FREEBSD USB input device files Wed, 17 May 2017 12:40:27 GMT Kevin Kirspel [41d2784] * freebsd/sys/dev/kbd/kbd.c (added) * freebsd/sys/dev/kbd/kbdreg.h (added) * freebsd/sys/dev/kbd/kbdtables.h (added) * freebsd/sys/sys/kbio.h (added) Add FREEBSD keyboard driver files Wed, 17 May 2017 12:40:26 GMT Kevin Kirspel [67de3b5] * freebsd/sys/dev/evdev/cdev.c (added) * freebsd/sys/dev/evdev/evdev.c (added) * freebsd/sys/dev/evdev/evdev.h (added) * freebsd/sys/dev/evdev/evdev_mt.c (added) * freebsd/sys/dev/evdev/evdev_private.h (added) * freebsd/sys/dev/evdev/evdev_utils.c (added) * freebsd/sys/dev/evdev/input-event-codes.h (added) * freebsd/sys/dev/evdev/input.h (added) * freebsd/sys/dev/evdev/uinput.c (added) * freebsd/sys/dev/evdev/uinput.h (added) Adding EVDEV FREEBSD files Fri, 12 May 2017 12:16:27 GMT Kevin Kirspel [817cbf7] * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/sys/file.h (modified) * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) devfs: Fix some issues Fix issue with cdev private data usage with ... Fri, 12 May 2017 12:16:26 GMT Kevin Kirspel [6afe73d] * libbsd.py (modified) * libbsd_waf.py (modified) Updating scripts for USB Serial Drivers Fri, 12 May 2017 12:16:25 GMT Kevin Kirspel [534017c] * testsuite/usbserial01/init.c (added) Adding USB Serial test Fri, 12 May 2017 12:16:24 GMT Kevin Kirspel [5040ee5] * freebsd/sys/dev/usb/serial/usb_serial.c (modified) Update USB Serial Driver for use with RTEMS Fri, 12 May 2017 12:16:23 GMT Kevin Kirspel [746d74b] * freebsd/sys/dev/usb/uftdiio.h (added) Add USB headers to support USB Serial drivers Fri, 12 May 2017 12:16:22 GMT Kevin Kirspel [286c391] * freebsd/sys/dev/usb/serial/u3g.c (added) * freebsd/sys/dev/usb/serial/uark.c (added) * freebsd/sys/dev/usb/serial/ubsa.c (added) * freebsd/sys/dev/usb/serial/ubser.c (added) * freebsd/sys/dev/usb/serial/uchcom.c (added) * freebsd/sys/dev/usb/serial/ucycom.c (added) * freebsd/sys/dev/usb/serial/ufoma.c (added) * freebsd/sys/dev/usb/serial/uftdi.c (added) * freebsd/sys/dev/usb/serial/uftdi_reg.h (added) * freebsd/sys/dev/usb/serial/ugensa.c (added) * freebsd/sys/dev/usb/serial/uipaq.c (added) * freebsd/sys/dev/usb/serial/ulpt.c (added) * freebsd/sys/dev/usb/serial/umcs.c (added) * freebsd/sys/dev/usb/serial/umcs.h (added) * freebsd/sys/dev/usb/serial/umct.c (added) * freebsd/sys/dev/usb/serial/umodem.c (added) * freebsd/sys/dev/usb/serial/umoscom.c (added) * freebsd/sys/dev/usb/serial/uplcom.c (added) * freebsd/sys/dev/usb/serial/usb_serial.c (added) * freebsd/sys/dev/usb/serial/usb_serial.h (added) * freebsd/sys/dev/usb/serial/uslcom.c (added) * freebsd/sys/dev/usb/serial/uvisor.c (added) * freebsd/sys/dev/usb/serial/uvscom.c (added) Adding FREEBSD USB Serial Drivers Thu, 04 May 2017 12:28:01 GMT Kevin Kirspel [9d52d91] * libbsd.py (modified) * libbsd_waf.py (modified) Updating scripts for FREEBSD TTY support Thu, 04 May 2017 12:28:00 GMT Kevin Kirspel [333bfb6] * testsuite/include/rtems/bsd/test/default-termios-init.h (added) * testsuite/termios/test_main.c (added) * testsuite/termios/test_termios_driver.c (added) * testsuite/termios/test_termios_driver.h (added) * testsuite/termios/test_termios_utilities.c (added) * testsuite/termios/test_termios_utilities.h (added) * testsuite/termios01/test_main.c (added) * testsuite/termios02/test_main.c (added) * testsuite/termios03/test_main.c (added) * testsuite/termios04/test_main.c (added) * testsuite/termios05/test_main.c (added) * testsuite/termios06/test_main.c (added) Adding test cases for FREEBSD termios support through tty Thu, 04 May 2017 12:27:59 GMT Kevin Kirspel [880a17c] * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_gdb.h (added) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-stty.c (added) * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) Adding RTEMS support for FREEBSD TTY Thu, 04 May 2017 12:27:58 GMT Kevin Kirspel [4a8f953] * freebsd/sys/fs/devfs/devfs_int.h (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_ttydisc.c (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/proc.h (modified) Updating FREEBSD for tty support Thu, 04 May 2017 12:27:57 GMT Kevin Kirspel [567cce1] * freebsd/bin/stty/cchar.c (modified) * freebsd/bin/stty/gfmt.c (modified) * freebsd/bin/stty/key.c (modified) * freebsd/bin/stty/modes.c (modified) * freebsd/bin/stty/print.c (modified) * freebsd/bin/stty/rtems-bsd-stty-cchar-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-gfmt-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-key-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-modes-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-namespace.h (added) * freebsd/bin/stty/rtems-bsd-stty-print-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-stty-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-util-data.h (added) * freebsd/bin/stty/stty.c (modified) * freebsd/bin/stty/util.c (modified) Updating STTY command for use in RTEMS shell Thu, 04 May 2017 12:27:56 GMT Kevin Kirspel [f6c52e0] * freebsd/sys/fs/devfs/devfs_vnops.c (added) * freebsd/sys/kern/tty.c (added) * freebsd/sys/kern/tty_inq.c (added) * freebsd/sys/kern/tty_outq.c (added) * freebsd/sys/kern/tty_ttydisc.c (added) * freebsd/sys/sys/cons.h (added) * freebsd/sys/sys/serial.h (added) Adding tty support files from FREEBSD tree Thu, 04 May 2017 12:27:55 GMT Kevin Kirspel [67cd18e] * freebsd/bin/stty/cchar.c (added) * freebsd/bin/stty/extern.h (added) * freebsd/bin/stty/gfmt.c (added) * freebsd/bin/stty/key.c (added) * freebsd/bin/stty/modes.c (added) * freebsd/bin/stty/print.c (added) * freebsd/bin/stty/stty.c (added) * freebsd/bin/stty/stty.h (added) * freebsd/bin/stty/util.c (added) Adding stty command files from FREEBSD tree Thu, 27 Apr 2017 04:58:09 GMT Chris Johns [53914f2] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Move the defaultroute_delay to the defaultroute processing. ... Thu, 27 Apr 2017 03:57:28 GMT Chris Johns [4437573] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * testsuite/rcconf01/test_main.c (modified) * testsuite/rcconf02/test_main.c (modified) rc_conf: Add support for ifconfig__alias[0-9]+. The ... Wed, 26 Apr 2017 07:39:38 GMT Chris Johns [43c65f5] * rtemsbsd/rtems/rtems-bsd-rc-conf.c (modified) rc_conf: Do not use a local variable for the rc_conf context. If a ... Wed, 26 Apr 2017 07:38:50 GMT Chris Johns [145a821] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Minor clean up in the net services. Thu, 02 Mar 2017 15:45:31 GMT Sebastian Huber [334019d] * rtemsbsd/include/bsp/nexus-devices.h (modified) nexus-devices: Use FDT for qoriq BSPs Tue, 04 Apr 2017 07:36:57 GMT Sebastian Huber [de8a76d] * Makefile.todo (modified) * freebsd-org (modified) * freebsd/bin/hostname/hostname.c (modified) * freebsd/include/arpa/nameser_compat.h (modified) * freebsd/include/err.h (modified) * freebsd/lib/libc/db/btree/bt_close.c (modified) * freebsd/lib/libc/db/btree/bt_conv.c (modified) * freebsd/lib/libc/db/btree/bt_debug.c (modified) * freebsd/lib/libc/db/btree/bt_delete.c (modified) * freebsd/lib/libc/db/btree/bt_get.c (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_overflow.c (modified) * freebsd/lib/libc/db/btree/bt_page.c (modified) * freebsd/lib/libc/db/btree/bt_put.c (modified) * freebsd/lib/libc/db/btree/bt_search.c (modified) * freebsd/lib/libc/db/btree/bt_seq.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/btree/bt_utils.c (modified) * freebsd/lib/libc/db/btree/btree.h (modified) * freebsd/lib/libc/db/btree/extern.h (modified) * freebsd/lib/libc/db/db/db.c (modified) * freebsd/lib/libc/db/mpool/mpool.c (modified) * freebsd/lib/libc/db/recno/extern.h (modified) * freebsd/lib/libc/db/recno/rec_close.c (modified) * freebsd/lib/libc/db/recno/rec_delete.c (modified) * freebsd/lib/libc/db/recno/rec_get.c (modified) * freebsd/lib/libc/db/recno/rec_open.c (modified) * freebsd/lib/libc/db/recno/rec_put.c (modified) * freebsd/lib/libc/db/recno/rec_search.c (modified) * freebsd/lib/libc/db/recno/rec_seq.c (modified) * freebsd/lib/libc/db/recno/rec_utils.c (modified) * freebsd/lib/libc/db/recno/recno.h (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/gen/sethostname.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/include/un-namespace.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbyht.c (modified) * freebsd/lib/libc/net/getproto.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getprotoname.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/linkaddr.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/recv.c (modified) * freebsd/lib/libc/net/send.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/rpc/getnetconfig.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libipsec/pfkey.c (modified) * freebsd/lib/libipsec/pfkey_dump.c (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/bsm/audit_kevents.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/crypto/intake.h (moved) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_defines.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/em_txrx.c (added) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/e1000/if_igb.c (deleted) * freebsd/sys/dev/e1000/if_igb.h (deleted) * freebsd/sys/dev/e1000/if_lem.c (deleted) * freebsd/sys/dev/e1000/if_lem.h (deleted) * freebsd/sys/dev/e1000/igb_txrx.c (added) * freebsd/sys/dev/fdt/fdt_common.h (modified) * freebsd/sys/dev/fdt/simplebus.c (modified) * freebsd/sys/dev/mmc/bridge.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_ioctl.h (moved) * freebsd/sys/dev/mmc/mmc_private.h (added) * freebsd/sys/dev/mmc/mmc_subr.c (added) * freebsd/sys/dev/mmc/mmc_subr.h (added) * freebsd/sys/dev/mmc/mmcbrvar.h (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/mmc/mmcvar.h (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pcib_private.h (modified) * freebsd/sys/dev/pci/pcireg.h (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.h (modified) * freebsd/sys/dev/rtwn/if_rtwn_tx.c (modified) * freebsd/sys/dev/rtwn/if_rtwnvar.h (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_reg.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx_desc.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx_desc.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx_desc.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/tsec/if_tsec.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.h (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_pf.h (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/bcd.c (modified) * freebsd/sys/libkern/inet_ntoa.c (modified) * freebsd/sys/libkern/random.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf.h (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/dlt.h (added) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if.h (modified) * freebsd/sys/net/if_arc.h (modified) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_bridgevar.h (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_dl.h (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llc.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_types.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (added) * freebsd/sys/net/ifq.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfkeyv2.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_cb.h (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/route_var.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net/slcompress.h (modified) * freebsd/sys/net80211/_ieee80211.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_node.h (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_superg.h (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_var.h (modified) * freebsd/sys/net80211/ieee80211_vht.c (added) * freebsd/sys/net80211/ieee80211_vht.h (added) * freebsd/sys/netinet/cc/cc.h (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/if_ether.h (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp.h (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in.h (modified) * freebsd/sys/netinet/in_fib.c (modified) * freebsd/sys/netinet/in_fib.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_systm.h (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_carp.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_icmp.h (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_ipsec.c (deleted) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_mroute.h (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_options.h (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/tcp.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_debug.h (modified) * freebsd/sys/netinet/tcp_fsm.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/tcpip.h (modified) * freebsd/sys/netinet/udp.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6.h (modified) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_fib.c (modified) * freebsd/sys/netinet6/in6_fib.h (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_ipsec.c (deleted) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/ip6protosw.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/tcp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_var.h (modified) * freebsd/sys/netipsec/ah_var.h (modified) * freebsd/sys/netipsec/esp.h (modified) * freebsd/sys/netipsec/esp_var.h (modified) * freebsd/sys/netipsec/ipcomp_var.h (modified) * freebsd/sys/netipsec/ipip_var.h (deleted) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec6.h (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_mod.c (added) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/ipsec_pcb.c (added) * freebsd/sys/netipsec/ipsec_support.h (added) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key.h (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/key_debug.h (modified) * freebsd/sys/netipsec/key_var.h (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/keysock.h (modified) * freebsd/sys/netipsec/subr_ipsec.c (added) * freebsd/sys/netipsec/udpencap.c (added) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_ipip.c (deleted) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/ipfw/dn_aqm_pie.h (modified) * freebsd/sys/netpfil/ipfw/dn_heap.h (modified) * freebsd/sys/netpfil/ipfw/ip_fw2.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_private.h (modified) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/powerpc/include/machine/cpufunc.h (modified) * freebsd/sys/powerpc/include/machine/intr_machdep.h (added) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/security/audit/audit.h (modified) * freebsd/sys/sparc64/sparc64/in_cksum.c (modified) * freebsd/sys/sys/_callout.h (modified) * freebsd/sys/sys/_sockaddr_storage.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/bitstring.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/capability.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/ctype.h (modified) * freebsd/sys/sys/domain.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/gtaskqueue.h (added) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/limits.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/lockmgr.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/nlist_aout.h (modified) * freebsd/sys/sys/nv.h (added) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/pipe.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/protosw.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/sdt.h (modified) * freebsd/sys/sys/selinfo.h (modified) * freebsd/sys/sys/sigio.h (modified) * freebsd/sys/sys/signalvar.h (modified) * freebsd/sys/sys/sleepqueue.h (modified) * freebsd/sys/sys/slicer.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socket.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/sockstate.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/syslog.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/ttyqueue.h (modified) * freebsd/sys/sys/ucred.h (modified) * freebsd/sys/sys/un.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/tools/tools/net80211/wlanstats/main.c (modified) * freebsd/usr.bin/netstat/flowtable.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/_inttypes.h (added) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/bus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/ifdi_if.h (added) * rtemsbsd/include/rtems/bsd/local/mmcbr_if.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_ratelimit.h (added) * rtemsbsd/include/rtems/bsd/local/pci_if.h (modified) * rtemsbsd/include/rtems/bsd/local/pcib_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/local/ifdi_if.c (added) * rtemsbsd/local/mmcbr_if.c (modified) * rtemsbsd/local/pcib_if.c (modified) Update to FreeBSD head 2017-04-04 Git mirror commit ... Tue, 17 Jan 2017 11:50:11 GMT Sebastian Huber [3360232] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Enable bridging by default Mon, 03 Apr 2017 12:10:37 GMT Sebastian Huber [0395c5d] * rtemsbsd/sys/net/ppp_tty.c (modified) ppp: Update due to API changes Tue, 14 Mar 2017 06:15:34 GMT Sebastian Huber [0732183] * freebsd/sys/kern/uipc_syscalls.c (modified) Fix SOCK_CLOEXEC with socket() and socketpair() Remove SOCK_CLOEXEC ... Wed, 08 Mar 2017 08:05:05 GMT Sebastian Huber [5f3722a] * freebsd/sys/dev/tsec/if_tsec.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) if_tsec: Enable FDT support Thu, 02 Mar 2017 15:29:11 GMT Sebastian Huber [c1205ee] * Makefile.todo (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofwvar.h (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/contrib/libfdt/libfdt.h (added) * rtemsbsd/include/contrib/libfdt/libfdt_env.h (added) * rtemsbsd/include/machine/ofw_machdep.h (modified) * rtemsbsd/include/rtems/bsd/local/ofw_bus_if.h (added) * rtemsbsd/include/rtems/bsd/local/ofw_if.h (added) * rtemsbsd/include/rtems/bsd/local/opt_platform.h (modified) * rtemsbsd/local/ofw_bus_if.c (added) * rtemsbsd/local/ofw_if.c (added) * rtemsbsd/rtems/ofw_machdep.c (added) * rtemsbsd/rtems/rtems-kernel-nexus.c (modified) FDT(4): Port to RTEMS Thu, 02 Mar 2017 15:28:14 GMT Sebastian Huber [f0dd0c5] * freebsd/sys/dev/fdt/fdt_common.c (added) * freebsd/sys/dev/fdt/fdt_common.h (added) * freebsd/sys/dev/fdt/simplebus.c (added) * freebsd/sys/dev/fdt/simplebus.h (added) * freebsd/sys/dev/ofw/ofw_bus.h (added) * freebsd/sys/dev/ofw/ofw_bus_subr.c (added) * freebsd/sys/dev/ofw/ofw_bus_subr.h (added) * freebsd/sys/dev/ofw/ofw_fdt.c (added) * freebsd/sys/dev/ofw/ofw_pci.h (added) * freebsd/sys/dev/ofw/ofw_subr.c (added) * freebsd/sys/dev/ofw/ofw_subr.h (added) * freebsd/sys/dev/ofw/ofwbus.c (added) * freebsd/sys/dev/ofw/ofwvar.h (added) * freebsd/sys/dev/ofw/openfirm.c (added) * freebsd/sys/dev/tsec/if_tsec_fdt.c (added) * freebsd/sys/sys/slicer.h (added) FDT(4): Import from FreeBSD Mon, 06 Mar 2017 06:41:44 GMT Sebastian Huber [517e229] * testsuite/media01/test_main.c (modified) media01: Add cpuinfo command Mon, 06 Mar 2017 11:07:32 GMT Sebastian Huber [18a623e] * freebsd/sys/sys/systm.h (modified) Provide strtoq() and strtouq() Mon, 06 Mar 2017 11:07:13 GMT Sebastian Huber [08f4881] * freebsd/usr.bin/netstat/main.c (modified) NETSTAT(1): Disable unused functions Mon, 06 Mar 2017 11:06:38 GMT Sebastian Huber [6bc5190] * freebsd/sys/net/pfil.c (modified) Disable unused pfil_try_rlock() Mon, 06 Mar 2017 11:06:19 GMT Sebastian Huber [5268338] * freebsd/sys/kern/subr_prf.c (modified) Provide sbuf_hexdump() Mon, 06 Mar 2017 11:05:54 GMT Sebastian Huber [57ba8ad] * freebsd/sys/kern/subr_hints.c (modified) Avoid kern_unsetenv() Wed, 01 Mar 2017 09:49:05 GMT Sebastian Huber [ae9e46d] * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) Fix dw_mmc dependencies Tue, 21 Feb 2017 14:26:31 GMT Sebastian Huber [045ff6e] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/rtems/rtems-kernel-termioskqueuepoll.c (added) * testsuite/netshell01/test_main.c (modified) Add poll() and select() support for Termios Tue, 21 Feb 2017 11:57:34 GMT Sebastian Huber [631fb98] * testsuite/netshell01/test_main.c (modified) netshell01: Add license, fix format Wed, 22 Feb 2017 10:49:33 GMT Sebastian Huber [5e093a5] * freebsd/sys/kern/subr_sleepqueue.c (modified) SLEEPQUEUE(9): Fix absolute timeouts The FreeBSD kernel timeouts ... Tue, 21 Feb 2017 07:34:58 GMT Sebastian Huber [2a5d001] * builder.py (modified) * libbsd_waf.py (modified) C11/C++11 are the default for the RTEMS 4.12 GCC Tue, 21 Feb 2017 07:34:09 GMT Sebastian Huber [284ff16] * testsuite/media01/test_main.c (modified) * testsuite/smp01/test_main.c (modified) Update due to configuration API changes Tue, 14 Feb 2017 10:55:18 GMT Sebastian Huber [a739190] * freebsd/sbin/sysctl/sysctl.c (modified) SYSCTL(8): Fix command line option processing Mon, 30 Jan 2017 16:58:16 GMT Kevin Kirspel [9f2205a] * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/lpc/lpc_pwr.c (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/usb/controller/ohci.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (added) * rtemsbsd/sys/dev/usb/usb_otg_transceiver.h (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) Port LPC32XX Ethernet and USB OHCI to RTEMS Mon, 30 Jan 2017 16:58:15 GMT Kevin Kirspel [803a495] * freebsd/sys/arm/lpc/if_lpe.c (added) * freebsd/sys/arm/lpc/if_lpereg.h (added) * freebsd/sys/arm/lpc/lpc_pwr.c (added) * freebsd/sys/arm/lpc/lpcreg.h (added) * freebsd/sys/arm/lpc/lpcvar.h (added) Adding LPC32XX ethernet driver support Mon, 30 Jan 2017 16:58:24 GMT Kevin Kirspel [5382f639] * rtemsbsd/include/machine/rtems-bsd-cache.h (modified) Add support for LPC32XX cache Mon, 30 Jan 2017 16:58:18 GMT Kevin Kirspel [ea395a7] * freebsd/sys/sys/linker_set.h (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) Add ordered Nexus devices Add support for ordering the ... Mon, 13 Feb 2017 07:38:45 GMT Sebastian Huber [2c4840f] * README.waf (modified) README.waf: Change BSP, add QEMU command line Tue, 31 Jan 2017 08:50:45 GMT Sebastian Huber [1fd5083] * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/sys/proc.h (modified) SLEEPQUEUE(9): Add wmesg to thread wait info Tue, 31 Jan 2017 08:49:49 GMT Sebastian Huber [ee94f8a] * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/sys/_lock.h (modified) * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) rtems-bsd-mutex: Use thread queue name Tue, 17 Jan 2017 10:01:44 GMT Christian Mauderer [c6b85e8] * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_inet-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_inet6-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifbridge-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifclone-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgif-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgre-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgroup-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifieee80211-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-iflagg-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmac-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmedia-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifpfsync-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifvlan-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-sfp-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_altq-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_optimize-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_table-data.h (modified) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-namespace.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-data.h (modified) userspace tools: Regenerate headers. Tue, 17 Jan 2017 11:00:55 GMT Christian Mauderer [46d0378] * userspace-header-gen.py (modified) userspace-header-gen: Don't generate first array size.
