# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/19/24 06:26:25 Mon, 17 Jul 2017 13:32:52 GMT Christian Mauderer [658f9b8] * freebsd/sys/dev/rtwn/rtl8192c/r92c_llt.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_chan.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_fw.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_init.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_led.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_priv.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_reg.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rf.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rom.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rom_defs.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rom_image.h (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_rx.c (added) * freebsd/sys/dev/rtwn/rtl8192e/r92e_var.h (added) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu.h (added) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_attach.c (added) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_init.c (added) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_reg.h (added) * libbsd.py (modified) * libbsd_waf.py (modified) dev/rtwn: Import new files from FreeBSD. Thu, 13 Jul 2017 02:24:05 GMT Sichen Zhao <1473996754@…> [9121570] * freebsd/sys/arm/ti/am335x/am335x_prcm.c (modified) * freebsd/sys/arm/ti/ti_cpuid.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/intr.h (added) * rtemsbsd/include/rtems/bsd/local/fdt_pinctrl_if.h (added) Port am335x usb driver to RTEMS. Add FDT and umass support for ... Thu, 13 Jul 2017 02:24:04 GMT Sichen Zhao <1473996754@…> [bd3c01a] * freebsd/sys/arm/ti/am335x/am335x_musb.c (added) * freebsd/sys/arm/ti/am335x/am335x_prcm.c (added) * freebsd/sys/arm/ti/am335x/am335x_scm.h (added) * freebsd/sys/arm/ti/am335x/am335x_usbss.c (added) * freebsd/sys/arm/ti/ti_cpuid.h (added) * freebsd/sys/arm/ti/ti_prcm.c (added) * freebsd/sys/arm/ti/ti_prcm.h (added) * freebsd/sys/arm/ti/ti_scm.c (added) * freebsd/sys/arm/ti/ti_scm.h (added) * freebsd/sys/arm/ti/tivar.h (added) * freebsd/sys/dev/fdt/fdt_pinctrl.h (added) * freebsd/sys/dev/usb/controller/musb_otg.c (added) * freebsd/sys/dev/usb/controller/musb_otg.h (added) * freebsd/sys/sys/timeet.h (added) * freebsd/sys/sys/watchdog.h (added) Import am335x usb driver file from FreeBSD. Tue, 11 Jul 2017 08:42:32 GMT Sebastian Huber [83574df] * rtemsbsd/rtems/rtems-kernel-termioskqueuepoll.c (modified) termios: Interrupt server API changes Tue, 09 May 2017 12:09:49 GMT Sebastian Huber [378b5c2] * rtemsbsd/rtems/rtems-kernel-panic.c (modified) Use LOG_EMERG for panic() Wed, 10 May 2017 12:39:19 GMT Sebastian Huber [9128d20] * freebsd/sys/sys/libkern.h (modified) libkern.h: Add ffsll() Mon, 10 Jul 2017 06:24:56 GMT Sebastian Huber [127296c] * freebsd/sys/sys/libkern.h (modified) libkern.h: Avoid conflict with Mon, 26 Jun 2017 07:36:56 GMT Sebastian Huber [e3e88e1] * CONTRIBUTING.md (added) * libbsd.txt (modified) Add CONTRIBUTING.md Thu, 22 Jun 2017 04:56:52 GMT Sebastian Huber [9db59c7] * freebsd/lib/libc/inet/nsap_addr.c (modified) Remove unused inet_* weak references This change requires a Newlib ... Fri, 16 Jun 2017 05:31:51 GMT Sebastian Huber [b83012a] * freebsd/include/arpa/inet.h (deleted) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_net_ntop.c (modified) * freebsd/lib/libc/inet/inet_net_pton.c (modified) * freebsd/lib/libc/inet/inet_neta.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) Remove unused inet_* weak references This change requires a Newlib ... Thu, 08 Jun 2017 11:15:12 GMT Sebastian Huber [3c967ca] * builder.py (modified) * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/evdev/evdev_mt.c (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_subr.c (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_beacon.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_calib.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_cam.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_efuse.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_fw.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_task.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_tx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_reg.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_led.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_led.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_led.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_caps.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_led.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_init.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_led.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_dfs.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_init.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_reg.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c (modified) * freebsd/sys/dev/tsec/if_tsec_fdt.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/input/atp.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/uhid.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/input/wsp.c (modified) * freebsd/sys/dev/usb/net/if_aue.c (modified) * freebsd/sys/dev/usb/net/if_axe.c (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/net/if_cdce.c (modified) * freebsd/sys/dev/usb/net/if_cue.c (modified) * freebsd/sys/dev/usb/net/if_ipheth.c (modified) * freebsd/sys/dev/usb/net/if_kue.c (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/net/if_rue.c (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_udav.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/serial/uark.c (modified) * freebsd/sys/dev/usb/serial/ubsa.c (modified) * freebsd/sys/dev/usb/serial/ubser.c (modified) * freebsd/sys/dev/usb/serial/uchcom.c (modified) * freebsd/sys/dev/usb/serial/ucycom.c (modified) * freebsd/sys/dev/usb/serial/ufoma.c (modified) * freebsd/sys/dev/usb/serial/uftdi.c (modified) * freebsd/sys/dev/usb/serial/ugensa.c (modified) * freebsd/sys/dev/usb/serial/uipaq.c (modified) * freebsd/sys/dev/usb/serial/ulpt.c (modified) * freebsd/sys/dev/usb/serial/umcs.c (modified) * freebsd/sys/dev/usb/serial/umct.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/serial/umoscom.c (modified) * freebsd/sys/dev/usb/serial/uplcom.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.c (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/serial/uvisor.c (modified) * freebsd/sys/dev/usb/serial/uvscom.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_khelp.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_osd.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/kern_uuid.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_firmware.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_rman.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/tty_inq.c (modified) * freebsd/sys/kern/tty_outq.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/altq/if_altq.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/ifq.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_fib.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_fib.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec_mod.c (modified) * freebsd/sys/netipsec/ipsec_pcb.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/subr_ipsec.c (modified) * freebsd/sys/netipsec/udpencap.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw2.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_bpf.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_pfil.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_algo.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (modified) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn_control.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl_control.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/ip_fw_nptv6.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/sys/_lock.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/fail.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/hhook.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/lock_profile.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/seq.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_dbg.c (modified) * rtemsbsd/include/machine/_kernel_lock.h (modified) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (modified) * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/include/rtems/bsd/sys/lock.h (deleted) * rtemsbsd/rtems/rtems-bsd-generic.c (modified) * rtemsbsd/rtems/rtems-kernel-cam.c (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-jail.c (modified) * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-page.c (modified) * rtemsbsd/rtems/rtems-kernel-pci_cfgreg.c (modified) * rtemsbsd/rtems/rtems-kernel-program.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) * rtemsbsd/sys/dev/input/touchscreen/tsc_lpc32xx.c (modified) * rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c (modified) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (modified) * testsuite/condvar01/test_main.c (modified) * testsuite/mutex01/test_main.c (modified) * testsuite/rwlock01/test_main.c (modified) * testsuite/sleep01/test_main.c (modified) * testsuite/smp01/test_main.c (modified) * testsuite/timeout01/timeout_test.c (modified) Use provided by Newlib Tue, 23 May 2017 11:18:31 GMT Sebastian Huber [0237319] * builder.py (modified) * freebsd/bin/hostname/hostname.c (modified) * freebsd/contrib/libpcap/gencode.c (modified) * freebsd/contrib/libpcap/inet.c (modified) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/pcap-bpf.c (modified) * freebsd/contrib/libpcap/pcap-int.h (modified) * freebsd/contrib/libxo/libxo/xo_encoder.c (modified) * freebsd/contrib/tcpdump/tcpdump-stdinc.h (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/resolv.h (modified) * freebsd/lib/lib80211/lib80211_ioctl.c (modified) * freebsd/lib/lib80211/lib80211_regdomain.c (modified) * freebsd/lib/libc/db/btree/bt_close.c (modified) * freebsd/lib/libc/db/btree/bt_conv.c (modified) * freebsd/lib/libc/db/btree/bt_debug.c (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_overflow.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/btree/bt_utils.c (modified) * freebsd/lib/libc/db/mpool/mpool.c (modified) * freebsd/lib/libc/db/recno/rec_utils.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/gen/sethostname.c (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) * freebsd/lib/libc/inet/nsap_addr.c (modified) * freebsd/lib/libc/isc/eventlib_p.h (modified) * freebsd/lib/libc/net/base64.c (modified) * freebsd/lib/libc/net/ether_addr.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/gethostnamadr.c (modified) * freebsd/lib/libc/net/getifaddrs.c (modified) * freebsd/lib/libc/net/getifmaddrs.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getnetnamadr.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/ip6opt.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/rthdr.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_mkupdate.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_update.c (modified) * freebsd/lib/libc/rpc/auth_time.c (modified) * freebsd/lib/libc/rpc/auth_unix.c (modified) * freebsd/lib/libc/rpc/clnt_simple.c (modified) * freebsd/lib/libc/rpc/getrpcent.c (modified) * freebsd/lib/libc/rpc/netname.c (modified) * freebsd/lib/libc/rpc/netnamer.c (modified) * freebsd/lib/libc/rpc/rpc_generic.c (modified) * freebsd/lib/libc/rpc/rpc_prot.c (modified) * freebsd/lib/libc/rpc/svc_auth_des.c (modified) * freebsd/lib/libc/rpc/svc_vc.c (modified) * freebsd/lib/libc/xdr/xdr_float.c (modified) * freebsd/lib/libipsec/ipsec_dump_policy.c (modified) * freebsd/lib/libipsec/ipsec_get_policylen.c (modified) * freebsd/lib/libipsec/ipsec_strerror.c (modified) * freebsd/lib/libipsec/pfkey.c (modified) * freebsd/lib/libipsec/pfkey_dump.c (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/lib/libmemstat/memstat_malloc.c (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/trimdomain.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifcarp.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifgif.c (modified) * freebsd/sbin/ifconfig/ifgre.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmac.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/ifconfig/ifvlan.c (modified) * freebsd/sbin/ifconfig/sfp.c (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/arm/in_cksum.c (modified) * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/lpc/lpc_pwr.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/avr/avr/in_cksum.c (modified) * freebsd/sys/bfin/bfin/in_cksum.c (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/cam/cam.c (modified) * freebsd/sys/cam/cam_sim.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/crypto/des/des_ecb.c (modified) * freebsd/sys/crypto/des/des_setkey.c (modified) * freebsd/sys/crypto/rc4/rc4.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api-fst.c (modified) * freebsd/sys/crypto/siphash/siphash.c (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/cadence/if_cgem.c (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/evdev/cdev.c (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev_mt.c (modified) * freebsd/sys/dev/evdev/evdev_utils.c (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/fdt/simplebus.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/kbd/kbd.c (modified) * freebsd/sys/dev/led/led.c (modified) * freebsd/sys/dev/mii/brgphy.c (modified) * freebsd/sys/dev/mii/e1000phy.c (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mii/micphy.c (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/mii/mii_bitbang.c (modified) * freebsd/sys/dev/mii/mii_physubr.c (modified) * freebsd/sys/dev/mii/rgephy.c (modified) * freebsd/sys/dev/mii/ukphy.c (modified) * freebsd/sys/dev/mii/ukphy_subr.c (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_subr.c (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofw_subr.c (modified) * freebsd/sys/dev/ofw/ofwbus.c (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_beacon.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_calib.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_cam.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_efuse.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_fw.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_task.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_tx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_reg.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_led.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_led.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_led.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_caps.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_led.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rf.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_init.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_calib.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_led.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rom.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_dfs.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_init.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_reg.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/tsec/if_tsec_fdt.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/input/atp.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/uhid.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/input/wsp.c (modified) * freebsd/sys/dev/usb/net/if_aue.c (modified) * freebsd/sys/dev/usb/net/if_axe.c (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/net/if_cdce.c (modified) * freebsd/sys/dev/usb/net/if_cue.c (modified) * freebsd/sys/dev/usb/net/if_ipheth.c (modified) * freebsd/sys/dev/usb/net/if_kue.c (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/net/if_rue.c (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_udav.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/net/ruephy.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/serial/uark.c (modified) * freebsd/sys/dev/usb/serial/ubsa.c (modified) * freebsd/sys/dev/usb/serial/ubser.c (modified) * freebsd/sys/dev/usb/serial/uchcom.c (modified) * freebsd/sys/dev/usb/serial/ucycom.c (modified) * freebsd/sys/dev/usb/serial/ufoma.c (modified) * freebsd/sys/dev/usb/serial/uftdi.c (modified) * freebsd/sys/dev/usb/serial/ugensa.c (modified) * freebsd/sys/dev/usb/serial/uipaq.c (modified) * freebsd/sys/dev/usb/serial/ulpt.c (modified) * freebsd/sys/dev/usb/serial/umcs.c (modified) * freebsd/sys/dev/usb/serial/umct.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/serial/umoscom.c (modified) * freebsd/sys/dev/usb/serial/uplcom.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.c (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/serial/uvisor.c (modified) * freebsd/sys/dev/usb/serial/uvscom.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_upgt.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/h8300/h8300/in_cksum.c (modified) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/i386/i386/legacy.c (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_hhook.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_khelp.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_osd.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/kern_uuid.c (modified) * freebsd/sys/kern/subr_bufring.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_firmware.c (modified) * freebsd/sys/kern/subr_hash.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_rman.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_inq.c (modified) * freebsd/sys/kern/tty_outq.c (modified) * freebsd/sys/kern/tty_ttydisc.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_mbufhash.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/bcd.c (modified) * freebsd/sys/libkern/inet_ntoa.c (modified) * freebsd/sys/lm32/lm32/in_cksum.c (modified) * freebsd/sys/m32c/m32c/in_cksum.c (modified) * freebsd/sys/m32r/m32r/in_cksum.c (modified) * freebsd/sys/m68k/m68k/in_cksum.c (modified) * freebsd/sys/mips/mips/in_cksum.c (modified) * freebsd/sys/net/altq/altq.h (modified) * freebsd/sys/net/altq/altq_cbq.c (modified) * freebsd/sys/net/altq/altq_cdnr.c (modified) * freebsd/sys/net/altq/altq_codel.c (modified) * freebsd/sys/net/altq/altq_fairq.c (modified) * freebsd/sys/net/altq/altq_hfsc.c (modified) * freebsd/sys/net/altq/altq_priq.c (modified) * freebsd/sys/net/altq/altq_red.c (modified) * freebsd/sys/net/altq/altq_rio.c (modified) * freebsd/sys/net/altq/altq_rmclass.c (modified) * freebsd/sys/net/altq/altq_subr.c (modified) * freebsd/sys/net/altq/altq_var.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if.h (deleted) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_atmsubr.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_mib.c (modified) * freebsd/sys/net/if_spppfr.c (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211_acl.c (modified) * freebsd/sys/net80211/ieee80211_action.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_ageq.c (modified) * freebsd/sys/net80211/ieee80211_alq.c (modified) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_crypto.c (modified) * freebsd/sys/net80211/ieee80211_crypto_ccmp.c (modified) * freebsd/sys/net80211/ieee80211_crypto_none.c (modified) * freebsd/sys/net80211/ieee80211_crypto_tkip.c (modified) * freebsd/sys/net80211/ieee80211_crypto_wep.c (modified) * freebsd/sys/net80211/ieee80211_ddb.c (modified) * freebsd/sys/net80211/ieee80211_dfs.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_monitor.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_phy.c (modified) * freebsd/sys/net80211/ieee80211_power.c (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_radiotap.c (modified) * freebsd/sys/net80211/ieee80211_ratectl.c (modified) * freebsd/sys/net80211/ieee80211_ratectl_none.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/net80211/ieee80211_scan.c (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_scan_sw.c (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_vht.c (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/net80211/ieee80211_xauth.c (modified) * freebsd/sys/netinet/accf_data.c (modified) * freebsd/sys/netinet/accf_dns.c (modified) * freebsd/sys/netinet/accf_http.c (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/if_atm.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in.h (deleted) * freebsd/sys/netinet/in_fib.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_rmx.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_ecn.c (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias_cuseeme.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_dummy.c (modified) * freebsd/sys/netinet/libalias/alias_ftp.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_pptp.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/libalias/alias_skinny.c (modified) * freebsd/sys/netinet/libalias/alias_smedia.c (modified) * freebsd/sys/netinet/libalias/alias_util.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/tcp.h (deleted) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6.h (deleted) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_fib.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_mod.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/ipsec_pcb.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/subr_ipsec.c (modified) * freebsd/sys/netipsec/udpencap.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw2.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_bpf.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_pfil.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_algo.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (modified) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn_control.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl_control.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/ip_fw_nptv6.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (modified) * freebsd/sys/netpfil/pf/if_pflog.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/in4_cksum.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/netpfil/pf/pf_ruleset.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/nios2/nios2/in_cksum.c (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodeflate.c (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/deflate.c (modified) * freebsd/sys/opencrypto/rmd160.c (modified) * freebsd/sys/opencrypto/skipjack.c (modified) * freebsd/sys/opencrypto/xform.c (modified) * freebsd/sys/opencrypto/xform_auth.h (modified) * freebsd/sys/opencrypto/xform_comp.h (modified) * freebsd/sys/opencrypto/xform_enc.h (modified) * freebsd/sys/powerpc/powerpc/in_cksum.c (modified) * freebsd/sys/sh/sh/in_cksum.c (modified) * freebsd/sys/sparc/sparc/in_cksum.c (modified) * freebsd/sys/sparc64/sparc64/in_cksum.c (modified) * freebsd/sys/sys/_bitset.h (deleted) * freebsd/sys/sys/_cpuset.h (deleted) * freebsd/sys/sys/_sockaddr_storage.h (deleted) * freebsd/sys/sys/acl.h (modified) * freebsd/sys/sys/bitset.h (deleted) * freebsd/sys/sys/bitstring.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/fail.h (modified) * freebsd/sys/sys/ktr.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/socket.h (deleted) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/v850/v850/in_cksum.c (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_dbg.c (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/tools/tools/net80211/wlanstats/main.c (modified) * freebsd/tools/tools/net80211/wlanstats/wlanstats.c (modified) * freebsd/usr.bin/netstat/bpf.c (modified) * freebsd/usr.bin/netstat/flowtable.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mbuf.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/nl_symbols.c (modified) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/_align.h (deleted) * rtemsbsd/include/machine/bitstring.h (deleted) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/machine/rtems-bsd-param.h (deleted) * rtemsbsd/include/machine/rtems-bsd-thread.h (modified) * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) * rtemsbsd/include/machine/rtems-bsd-version.h (added) * rtemsbsd/include/rtems/bsd/sys/cpuset.h (deleted) * rtemsbsd/include/rtems/bsd/sys/errno.h (deleted) * rtemsbsd/include/rtems/bsd/sys/param.h (deleted) * rtemsbsd/include/sys/_cpuset.h (deleted) * rtemsbsd/local/bus_if.c (modified) * rtemsbsd/local/cryptodev_if.c (modified) * rtemsbsd/local/device_if.c (modified) * rtemsbsd/local/gpio_if.c (modified) * rtemsbsd/local/if_dwc_if.c (modified) * rtemsbsd/local/ifdi_if.c (modified) * rtemsbsd/local/miibus_if.c (modified) * rtemsbsd/local/mmcbr_if.c (modified) * rtemsbsd/local/mmcbus_if.c (modified) * rtemsbsd/local/pcib_if.c (modified) * rtemsbsd/local/usb_if.c (modified) * rtemsbsd/rtems/ipsec_get_policylen.c (modified) * rtemsbsd/rtems/rtems-bsd-cxx.cc (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * rtemsbsd/rtems/rtems-kernel-autoconf.c (modified) * rtemsbsd/rtems/rtems-kernel-bus-root.c (modified) * rtemsbsd/rtems/rtems-kernel-cam.c (modified) * rtemsbsd/rtems/rtems-kernel-chunk.c (modified) * rtemsbsd/rtems/rtems-kernel-configintrhook.c (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-jail.c (modified) * rtemsbsd/rtems/rtems-kernel-malloc.c (modified) * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-nexus.c (modified) * rtemsbsd/rtems/rtems-kernel-page.c (modified) * rtemsbsd/rtems/rtems-kernel-panic.c (modified) * rtemsbsd/rtems/rtems-kernel-pci_bus.c (modified) * rtemsbsd/rtems/rtems-kernel-pci_cfgreg.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) * rtemsbsd/rtems/rtems-kernel-thread.c (modified) * rtemsbsd/rtems/rtems-legacy-mii.c (modified) * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) * rtemsbsd/sys/dev/ffec/if_ffec_mcf548x.c (modified) * rtemsbsd/sys/dev/input/touchscreen/tsc_lpc32xx.c (modified) * rtemsbsd/sys/dev/smc/if_smc_nexus.c (modified) * rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c (modified) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (modified) * rtemsbsd/sys/dev/usb/controller/usb_otg_transceiver_dump.c (modified) * rtemsbsd/sys/net/if_ppp.c (modified) * rtemsbsd/sys/net/ppp_tty.c (modified) * testsuite/commands01/test_main.c (modified) * testsuite/condvar01/test_main.c (modified) * testsuite/loopback01/test_main.c (modified) * testsuite/mutex01/test_main.c (modified) * testsuite/netshell01/test_main.c (modified) * testsuite/rcconf01/test_main.c (modified) * testsuite/rcconf02/test_main.c (modified) * testsuite/rwlock01/test_main.c (modified) * testsuite/selectpollkqueue01/test_main.c (modified) * testsuite/sleep01/test_main.c (modified) * testsuite/smp01/test_main.c (modified) * testsuite/termios/test_main.c (modified) * testsuite/termios/test_termios_utilities.c (modified) * testsuite/termios06/test_main.c (modified) * testsuite/thread01/test_main.c (modified) * testsuite/timeout01/timeout_test.c (modified) * testsuite/unix01/test_main.c (modified) Update due to Newlib 2017-06-07 changes The following files are now ... Wed, 17 May 2017 12:40:37 GMT Kevin Kirspel [29c0cff] * libbsd.py (modified) * libbsd_waf.py (modified) Update scripts to include support for input devices - USB Keyboard, ... Wed, 17 May 2017 12:40:36 GMT Kevin Kirspel [427ee3e] * freebsd/sys/sys/proc.h (modified) Redirect FREEBSD's kern_yield to RTEMS sched_yield Wed, 17 May 2017 12:40:35 GMT Kevin Kirspel [15a4321] * testsuite/evdev01/init.c (added) * testsuite/usbkbd01/init.c (added) * testsuite/usbmouse01/init.c (added) Add tests for USB keyboard and mouse as well as EVDEV Wed, 17 May 2017 12:40:34 GMT Kevin Kirspel [9d4afe9] * rtemsbsd/rtems/rtems-kernel-init.c (modified) Add keyboard driver set variable Wed, 17 May 2017 12:40:33 GMT Kevin Kirspel [e28a8d0] * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/input/touchscreen/tsc_lpc32xx.c (added) Add LPC32XX touch screen driver Wed, 17 May 2017 12:40:32 GMT Kevin Kirspel [fb2aa6e] * freebsd/sys/sys/bitstring.h (modified) * rtemsbsd/include/machine/bitstring.h (added) Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h Wed, 17 May 2017 12:40:31 GMT Kevin Kirspel [18cf428] * freebsd/sys/dev/evdev/evdev.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_evdev.h (added) Modify FREEBSD EVDEV driver for use in RTEMS Wed, 17 May 2017 12:40:30 GMT Kevin Kirspel [b51279b] * freebsd/sys/dev/usb/input/ukbd.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_kbd.h (added) * rtemsbsd/include/rtems/bsd/local/opt_ukbd.h (added) Modify FREEBSD USB keyboard drivers for use in RTEMS Wed, 17 May 2017 12:40:29 GMT Kevin Kirspel [a7415b7] * freebsd/sys/dev/usb/usb_dev.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_usb.h (modified) Add USB UGEN support for RTEMS Wed, 17 May 2017 12:40:28 GMT Kevin Kirspel [3e7de30] * freebsd/sys/dev/usb/input/atp.c (added) * freebsd/sys/dev/usb/input/uep.c (added) * freebsd/sys/dev/usb/input/uhid.c (added) * freebsd/sys/dev/usb/input/ukbd.c (added) * freebsd/sys/dev/usb/input/ums.c (added) * freebsd/sys/dev/usb/input/usb_rdesc.h (added) * freebsd/sys/dev/usb/input/wsp.c (added) * freebsd/sys/sys/mouse.h (added) Add FREEBSD USB input device files Wed, 17 May 2017 12:40:27 GMT Kevin Kirspel [41d2784] * freebsd/sys/dev/kbd/kbd.c (added) * freebsd/sys/dev/kbd/kbdreg.h (added) * freebsd/sys/dev/kbd/kbdtables.h (added) * freebsd/sys/sys/kbio.h (added) Add FREEBSD keyboard driver files Wed, 17 May 2017 12:40:26 GMT Kevin Kirspel [67de3b5] * freebsd/sys/dev/evdev/cdev.c (added) * freebsd/sys/dev/evdev/evdev.c (added) * freebsd/sys/dev/evdev/evdev.h (added) * freebsd/sys/dev/evdev/evdev_mt.c (added) * freebsd/sys/dev/evdev/evdev_private.h (added) * freebsd/sys/dev/evdev/evdev_utils.c (added) * freebsd/sys/dev/evdev/input-event-codes.h (added) * freebsd/sys/dev/evdev/input.h (added) * freebsd/sys/dev/evdev/uinput.c (added) * freebsd/sys/dev/evdev/uinput.h (added) Adding EVDEV FREEBSD files Fri, 12 May 2017 12:16:27 GMT Kevin Kirspel [817cbf7] * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/sys/file.h (modified) * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) devfs: Fix some issues Fix issue with cdev private data usage with ... Fri, 12 May 2017 12:16:26 GMT Kevin Kirspel [6afe73d] * libbsd.py (modified) * libbsd_waf.py (modified) Updating scripts for USB Serial Drivers Fri, 12 May 2017 12:16:25 GMT Kevin Kirspel [534017c] * testsuite/usbserial01/init.c (added) Adding USB Serial test Fri, 12 May 2017 12:16:24 GMT Kevin Kirspel [5040ee5] * freebsd/sys/dev/usb/serial/usb_serial.c (modified) Update USB Serial Driver for use with RTEMS Fri, 12 May 2017 12:16:23 GMT Kevin Kirspel [746d74b] * freebsd/sys/dev/usb/uftdiio.h (added) Add USB headers to support USB Serial drivers Fri, 12 May 2017 12:16:22 GMT Kevin Kirspel [286c391] * freebsd/sys/dev/usb/serial/u3g.c (added) * freebsd/sys/dev/usb/serial/uark.c (added) * freebsd/sys/dev/usb/serial/ubsa.c (added) * freebsd/sys/dev/usb/serial/ubser.c (added) * freebsd/sys/dev/usb/serial/uchcom.c (added) * freebsd/sys/dev/usb/serial/ucycom.c (added) * freebsd/sys/dev/usb/serial/ufoma.c (added) * freebsd/sys/dev/usb/serial/uftdi.c (added) * freebsd/sys/dev/usb/serial/uftdi_reg.h (added) * freebsd/sys/dev/usb/serial/ugensa.c (added) * freebsd/sys/dev/usb/serial/uipaq.c (added) * freebsd/sys/dev/usb/serial/ulpt.c (added) * freebsd/sys/dev/usb/serial/umcs.c (added) * freebsd/sys/dev/usb/serial/umcs.h (added) * freebsd/sys/dev/usb/serial/umct.c (added) * freebsd/sys/dev/usb/serial/umodem.c (added) * freebsd/sys/dev/usb/serial/umoscom.c (added) * freebsd/sys/dev/usb/serial/uplcom.c (added) * freebsd/sys/dev/usb/serial/usb_serial.c (added) * freebsd/sys/dev/usb/serial/usb_serial.h (added) * freebsd/sys/dev/usb/serial/uslcom.c (added) * freebsd/sys/dev/usb/serial/uvisor.c (added) * freebsd/sys/dev/usb/serial/uvscom.c (added) Adding FREEBSD USB Serial Drivers Thu, 04 May 2017 12:28:01 GMT Kevin Kirspel [9d52d91] * libbsd.py (modified) * libbsd_waf.py (modified) Updating scripts for FREEBSD TTY support Thu, 04 May 2017 12:28:00 GMT Kevin Kirspel [333bfb6] * testsuite/include/rtems/bsd/test/default-termios-init.h (added) * testsuite/termios/test_main.c (added) * testsuite/termios/test_termios_driver.c (added) * testsuite/termios/test_termios_driver.h (added) * testsuite/termios/test_termios_utilities.c (added) * testsuite/termios/test_termios_utilities.h (added) * testsuite/termios01/test_main.c (added) * testsuite/termios02/test_main.c (added) * testsuite/termios03/test_main.c (added) * testsuite/termios04/test_main.c (added) * testsuite/termios05/test_main.c (added) * testsuite/termios06/test_main.c (added) Adding test cases for FREEBSD termios support through tty Thu, 04 May 2017 12:27:59 GMT Kevin Kirspel [880a17c] * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_gdb.h (added) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-stty.c (added) * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) Adding RTEMS support for FREEBSD TTY Thu, 04 May 2017 12:27:58 GMT Kevin Kirspel [4a8f953] * freebsd/sys/fs/devfs/devfs_int.h (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_ttydisc.c (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/proc.h (modified) Updating FREEBSD for tty support Thu, 04 May 2017 12:27:57 GMT Kevin Kirspel [567cce1] * freebsd/bin/stty/cchar.c (modified) * freebsd/bin/stty/gfmt.c (modified) * freebsd/bin/stty/key.c (modified) * freebsd/bin/stty/modes.c (modified) * freebsd/bin/stty/print.c (modified) * freebsd/bin/stty/rtems-bsd-stty-cchar-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-gfmt-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-key-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-modes-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-namespace.h (added) * freebsd/bin/stty/rtems-bsd-stty-print-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-stty-data.h (added) * freebsd/bin/stty/rtems-bsd-stty-util-data.h (added) * freebsd/bin/stty/stty.c (modified) * freebsd/bin/stty/util.c (modified) Updating STTY command for use in RTEMS shell Thu, 04 May 2017 12:27:56 GMT Kevin Kirspel [f6c52e0] * freebsd/sys/fs/devfs/devfs_vnops.c (added) * freebsd/sys/kern/tty.c (added) * freebsd/sys/kern/tty_inq.c (added) * freebsd/sys/kern/tty_outq.c (added) * freebsd/sys/kern/tty_ttydisc.c (added) * freebsd/sys/sys/cons.h (added) * freebsd/sys/sys/serial.h (added) Adding tty support files from FREEBSD tree Thu, 04 May 2017 12:27:55 GMT Kevin Kirspel [67cd18e] * freebsd/bin/stty/cchar.c (added) * freebsd/bin/stty/extern.h (added) * freebsd/bin/stty/gfmt.c (added) * freebsd/bin/stty/key.c (added) * freebsd/bin/stty/modes.c (added) * freebsd/bin/stty/print.c (added) * freebsd/bin/stty/stty.c (added) * freebsd/bin/stty/stty.h (added) * freebsd/bin/stty/util.c (added) Adding stty command files from FREEBSD tree Thu, 27 Apr 2017 04:58:09 GMT Chris Johns [53914f2] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Move the defaultroute_delay to the defaultroute processing. ... Thu, 27 Apr 2017 03:57:28 GMT Chris Johns [4437573] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * testsuite/rcconf01/test_main.c (modified) * testsuite/rcconf02/test_main.c (modified) rc_conf: Add support for ifconfig__alias[0-9]+. The ... Wed, 26 Apr 2017 07:39:38 GMT Chris Johns [43c65f5] * rtemsbsd/rtems/rtems-bsd-rc-conf.c (modified) rc_conf: Do not use a local variable for the rc_conf context. If a ... Wed, 26 Apr 2017 07:38:50 GMT Chris Johns [145a821] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Minor clean up in the net services. Thu, 02 Mar 2017 15:45:31 GMT Sebastian Huber [334019d] * rtemsbsd/include/bsp/nexus-devices.h (modified) nexus-devices: Use FDT for qoriq BSPs Tue, 04 Apr 2017 07:36:57 GMT Sebastian Huber [de8a76d] * Makefile.todo (modified) * freebsd-org (modified) * freebsd/bin/hostname/hostname.c (modified) * freebsd/include/arpa/nameser_compat.h (modified) * freebsd/include/err.h (modified) * freebsd/lib/libc/db/btree/bt_close.c (modified) * freebsd/lib/libc/db/btree/bt_conv.c (modified) * freebsd/lib/libc/db/btree/bt_debug.c (modified) * freebsd/lib/libc/db/btree/bt_delete.c (modified) * freebsd/lib/libc/db/btree/bt_get.c (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_overflow.c (modified) * freebsd/lib/libc/db/btree/bt_page.c (modified) * freebsd/lib/libc/db/btree/bt_put.c (modified) * freebsd/lib/libc/db/btree/bt_search.c (modified) * freebsd/lib/libc/db/btree/bt_seq.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/btree/bt_utils.c (modified) * freebsd/lib/libc/db/btree/btree.h (modified) * freebsd/lib/libc/db/btree/extern.h (modified) * freebsd/lib/libc/db/db/db.c (modified) * freebsd/lib/libc/db/mpool/mpool.c (modified) * freebsd/lib/libc/db/recno/extern.h (modified) * freebsd/lib/libc/db/recno/rec_close.c (modified) * freebsd/lib/libc/db/recno/rec_delete.c (modified) * freebsd/lib/libc/db/recno/rec_get.c (modified) * freebsd/lib/libc/db/recno/rec_open.c (modified) * freebsd/lib/libc/db/recno/rec_put.c (modified) * freebsd/lib/libc/db/recno/rec_search.c (modified) * freebsd/lib/libc/db/recno/rec_seq.c (modified) * freebsd/lib/libc/db/recno/rec_utils.c (modified) * freebsd/lib/libc/db/recno/recno.h (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/gen/sethostname.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/include/un-namespace.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbyht.c (modified) * freebsd/lib/libc/net/getproto.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getprotoname.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/linkaddr.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/recv.c (modified) * freebsd/lib/libc/net/send.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/rpc/getnetconfig.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libipsec/pfkey.c (modified) * freebsd/lib/libipsec/pfkey_dump.c (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/bsm/audit_kevents.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/crypto/intake.h (moved) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_defines.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/em_txrx.c (added) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/e1000/if_igb.c (deleted) * freebsd/sys/dev/e1000/if_igb.h (deleted) * freebsd/sys/dev/e1000/if_lem.c (deleted) * freebsd/sys/dev/e1000/if_lem.h (deleted) * freebsd/sys/dev/e1000/igb_txrx.c (added) * freebsd/sys/dev/fdt/fdt_common.h (modified) * freebsd/sys/dev/fdt/simplebus.c (modified) * freebsd/sys/dev/mmc/bridge.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_ioctl.h (moved) * freebsd/sys/dev/mmc/mmc_private.h (added) * freebsd/sys/dev/mmc/mmc_subr.c (added) * freebsd/sys/dev/mmc/mmc_subr.h (added) * freebsd/sys/dev/mmc/mmcbrvar.h (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/mmc/mmcvar.h (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pcib_private.h (modified) * freebsd/sys/dev/pci/pcireg.h (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.h (modified) * freebsd/sys/dev/rtwn/if_rtwn_tx.c (modified) * freebsd/sys/dev/rtwn/if_rtwnvar.h (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_init.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_reg.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx_desc.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx_desc.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_beacon.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx_desc.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/r21a_init.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/tsec/if_tsec.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.h (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_pf.h (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/bcd.c (modified) * freebsd/sys/libkern/inet_ntoa.c (modified) * freebsd/sys/libkern/random.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf.h (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/dlt.h (added) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if.h (modified) * freebsd/sys/net/if_arc.h (modified) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_bridgevar.h (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_dl.h (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llc.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_types.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (added) * freebsd/sys/net/ifq.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfkeyv2.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_cb.h (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/route_var.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net/slcompress.h (modified) * freebsd/sys/net80211/_ieee80211.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_node.h (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_superg.h (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_var.h (modified) * freebsd/sys/net80211/ieee80211_vht.c (added) * freebsd/sys/net80211/ieee80211_vht.h (added) * freebsd/sys/netinet/cc/cc.h (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/if_ether.h (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp.h (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in.h (modified) * freebsd/sys/netinet/in_fib.c (modified) * freebsd/sys/netinet/in_fib.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_systm.h (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_carp.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_icmp.h (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_ipsec.c (deleted) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_mroute.h (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_options.h (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/tcp.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_debug.h (modified) * freebsd/sys/netinet/tcp_fsm.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/tcpip.h (modified) * freebsd/sys/netinet/udp.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6.h (modified) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_fib.c (modified) * freebsd/sys/netinet6/in6_fib.h (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_ipsec.c (deleted) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/ip6protosw.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/tcp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_var.h (modified) * freebsd/sys/netipsec/ah_var.h (modified) * freebsd/sys/netipsec/esp.h (modified) * freebsd/sys/netipsec/esp_var.h (modified) * freebsd/sys/netipsec/ipcomp_var.h (modified) * freebsd/sys/netipsec/ipip_var.h (deleted) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec6.h (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_mod.c (added) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/ipsec_pcb.c (added) * freebsd/sys/netipsec/ipsec_support.h (added) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key.h (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/key_debug.h (modified) * freebsd/sys/netipsec/key_var.h (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/keysock.h (modified) * freebsd/sys/netipsec/subr_ipsec.c (added) * freebsd/sys/netipsec/udpencap.c (added) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_ipip.c (deleted) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/ipfw/dn_aqm_pie.h (modified) * freebsd/sys/netpfil/ipfw/dn_heap.h (modified) * freebsd/sys/netpfil/ipfw/ip_fw2.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_private.h (modified) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (modified) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (modified) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/powerpc/include/machine/cpufunc.h (modified) * freebsd/sys/powerpc/include/machine/intr_machdep.h (added) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/security/audit/audit.h (modified) * freebsd/sys/sparc64/sparc64/in_cksum.c (modified) * freebsd/sys/sys/_callout.h (modified) * freebsd/sys/sys/_sockaddr_storage.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/bitstring.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/capability.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/ctype.h (modified) * freebsd/sys/sys/domain.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/gtaskqueue.h (added) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/limits.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/lockmgr.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/nlist_aout.h (modified) * freebsd/sys/sys/nv.h (added) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/pipe.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/protosw.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/sdt.h (modified) * freebsd/sys/sys/selinfo.h (modified) * freebsd/sys/sys/sigio.h (modified) * freebsd/sys/sys/signalvar.h (modified) * freebsd/sys/sys/sleepqueue.h (modified) * freebsd/sys/sys/slicer.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socket.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/sockstate.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/syslog.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/ttyqueue.h (modified) * freebsd/sys/sys/ucred.h (modified) * freebsd/sys/sys/un.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/tools/tools/net80211/wlanstats/main.c (modified) * freebsd/usr.bin/netstat/flowtable.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/_inttypes.h (added) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/bus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/ifdi_if.h (added) * rtemsbsd/include/rtems/bsd/local/mmcbr_if.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_ratelimit.h (added) * rtemsbsd/include/rtems/bsd/local/pci_if.h (modified) * rtemsbsd/include/rtems/bsd/local/pcib_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/local/ifdi_if.c (added) * rtemsbsd/local/mmcbr_if.c (modified) * rtemsbsd/local/pcib_if.c (modified) Update to FreeBSD head 2017-04-04 Git mirror commit ... Tue, 17 Jan 2017 11:50:11 GMT Sebastian Huber [3360232] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Enable bridging by default Mon, 03 Apr 2017 12:10:37 GMT Sebastian Huber [0395c5d] * rtemsbsd/sys/net/ppp_tty.c (modified) ppp: Update due to API changes Tue, 14 Mar 2017 06:15:34 GMT Sebastian Huber [0732183] * freebsd/sys/kern/uipc_syscalls.c (modified) Fix SOCK_CLOEXEC with socket() and socketpair() Remove SOCK_CLOEXEC ... Wed, 08 Mar 2017 08:05:05 GMT Sebastian Huber [5f3722a] * freebsd/sys/dev/tsec/if_tsec.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) if_tsec: Enable FDT support Thu, 02 Mar 2017 15:29:11 GMT Sebastian Huber [c1205ee] * Makefile.todo (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofwvar.h (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/contrib/libfdt/libfdt.h (added) * rtemsbsd/include/contrib/libfdt/libfdt_env.h (added) * rtemsbsd/include/machine/ofw_machdep.h (modified) * rtemsbsd/include/rtems/bsd/local/ofw_bus_if.h (added) * rtemsbsd/include/rtems/bsd/local/ofw_if.h (added) * rtemsbsd/include/rtems/bsd/local/opt_platform.h (modified) * rtemsbsd/local/ofw_bus_if.c (added) * rtemsbsd/local/ofw_if.c (added) * rtemsbsd/rtems/ofw_machdep.c (added) * rtemsbsd/rtems/rtems-kernel-nexus.c (modified) FDT(4): Port to RTEMS Thu, 02 Mar 2017 15:28:14 GMT Sebastian Huber [f0dd0c5] * freebsd/sys/dev/fdt/fdt_common.c (added) * freebsd/sys/dev/fdt/fdt_common.h (added) * freebsd/sys/dev/fdt/simplebus.c (added) * freebsd/sys/dev/fdt/simplebus.h (added) * freebsd/sys/dev/ofw/ofw_bus.h (added) * freebsd/sys/dev/ofw/ofw_bus_subr.c (added) * freebsd/sys/dev/ofw/ofw_bus_subr.h (added) * freebsd/sys/dev/ofw/ofw_fdt.c (added) * freebsd/sys/dev/ofw/ofw_pci.h (added) * freebsd/sys/dev/ofw/ofw_subr.c (added) * freebsd/sys/dev/ofw/ofw_subr.h (added) * freebsd/sys/dev/ofw/ofwbus.c (added) * freebsd/sys/dev/ofw/ofwvar.h (added) * freebsd/sys/dev/ofw/openfirm.c (added) * freebsd/sys/dev/tsec/if_tsec_fdt.c (added) * freebsd/sys/sys/slicer.h (added) FDT(4): Import from FreeBSD Mon, 06 Mar 2017 06:41:44 GMT Sebastian Huber [517e229] * testsuite/media01/test_main.c (modified) media01: Add cpuinfo command Mon, 06 Mar 2017 11:07:32 GMT Sebastian Huber [18a623e] * freebsd/sys/sys/systm.h (modified) Provide strtoq() and strtouq() Mon, 06 Mar 2017 11:07:13 GMT Sebastian Huber [08f4881] * freebsd/usr.bin/netstat/main.c (modified) NETSTAT(1): Disable unused functions Mon, 06 Mar 2017 11:06:38 GMT Sebastian Huber [6bc5190] * freebsd/sys/net/pfil.c (modified) Disable unused pfil_try_rlock() Mon, 06 Mar 2017 11:06:19 GMT Sebastian Huber [5268338] * freebsd/sys/kern/subr_prf.c (modified) Provide sbuf_hexdump() Mon, 06 Mar 2017 11:05:54 GMT Sebastian Huber [57ba8ad] * freebsd/sys/kern/subr_hints.c (modified) Avoid kern_unsetenv() Wed, 01 Mar 2017 09:49:05 GMT Sebastian Huber [ae9e46d] * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) Fix dw_mmc dependencies Tue, 21 Feb 2017 14:26:31 GMT Sebastian Huber [045ff6e] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/rtems/rtems-kernel-termioskqueuepoll.c (added) * testsuite/netshell01/test_main.c (modified) Add poll() and select() support for Termios Tue, 21 Feb 2017 11:57:34 GMT Sebastian Huber [631fb98] * testsuite/netshell01/test_main.c (modified) netshell01: Add license, fix format Wed, 22 Feb 2017 10:49:33 GMT Sebastian Huber [5e093a5] * freebsd/sys/kern/subr_sleepqueue.c (modified) SLEEPQUEUE(9): Fix absolute timeouts The FreeBSD kernel timeouts ... Tue, 21 Feb 2017 07:34:58 GMT Sebastian Huber [2a5d001] * builder.py (modified) * libbsd_waf.py (modified) C11/C++11 are the default for the RTEMS 4.12 GCC Tue, 21 Feb 2017 07:34:09 GMT Sebastian Huber [284ff16] * testsuite/media01/test_main.c (modified) * testsuite/smp01/test_main.c (modified) Update due to configuration API changes Tue, 14 Feb 2017 10:55:18 GMT Sebastian Huber [a739190] * freebsd/sbin/sysctl/sysctl.c (modified) SYSCTL(8): Fix command line option processing Mon, 30 Jan 2017 16:58:16 GMT Kevin Kirspel [9f2205a] * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/lpc/lpc_pwr.c (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/usb/controller/ohci.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (added) * rtemsbsd/sys/dev/usb/usb_otg_transceiver.h (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) Port LPC32XX Ethernet and USB OHCI to RTEMS Mon, 30 Jan 2017 16:58:15 GMT Kevin Kirspel [803a495] * freebsd/sys/arm/lpc/if_lpe.c (added) * freebsd/sys/arm/lpc/if_lpereg.h (added) * freebsd/sys/arm/lpc/lpc_pwr.c (added) * freebsd/sys/arm/lpc/lpcreg.h (added) * freebsd/sys/arm/lpc/lpcvar.h (added) Adding LPC32XX ethernet driver support Mon, 30 Jan 2017 16:58:24 GMT Kevin Kirspel [5382f639] * rtemsbsd/include/machine/rtems-bsd-cache.h (modified) Add support for LPC32XX cache Mon, 30 Jan 2017 16:58:18 GMT Kevin Kirspel [ea395a7] * freebsd/sys/sys/linker_set.h (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) Add ordered Nexus devices Add support for ordering the ... Mon, 13 Feb 2017 07:38:45 GMT Sebastian Huber [2c4840f] * README.waf (modified) README.waf: Change BSP, add QEMU command line Tue, 31 Jan 2017 08:50:45 GMT Sebastian Huber [1fd5083] * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/sys/proc.h (modified) SLEEPQUEUE(9): Add wmesg to thread wait info Tue, 31 Jan 2017 08:49:49 GMT Sebastian Huber [ee94f8a] * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/sys/_lock.h (modified) * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) rtems-bsd-mutex: Use thread queue name Tue, 17 Jan 2017 10:01:44 GMT Christian Mauderer [c6b85e8] * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_inet-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_inet6-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifbridge-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifclone-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgif-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgre-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgroup-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifieee80211-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-iflagg-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmac-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmedia-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifpfsync-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifvlan-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-sfp-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_altq-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_optimize-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_table-data.h (modified) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-namespace.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-data.h (modified) userspace tools: Regenerate headers. Tue, 17 Jan 2017 11:00:55 GMT Christian Mauderer [46d0378] * userspace-header-gen.py (modified) userspace-header-gen: Don't generate first array size. Wed, 14 Dec 2016 13:10:18 GMT Christian Mauderer [120caa6] * testsuite/commands01/test_main.c (modified) testsuite/commands01: Add wlanstats call. Fri, 09 Dec 2016 10:51:50 GMT Christian Mauderer [ecda181] * builder.py (modified) * freebsd/tools/tools/net80211/wlanstats/main.c (modified) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-data.h (added) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-main-data.h (added) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-namespace.h (added) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-wlanstats-data.h (added) * freebsd/tools/tools/net80211/wlanstats/wlanstats.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-wlanstats.c (added) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) freebsd/wlanstats: Port to FreeBSD. Fri, 09 Dec 2016 08:15:24 GMT Christian Mauderer [d415406] * freebsd/lib/libbsdstat/bsdstat.c (added) * freebsd/lib/libbsdstat/bsdstat.h (added) * freebsd/tools/tools/net80211/wlanstats/main.c (added) * freebsd/tools/tools/net80211/wlanstats/wlanstats.c (added) * freebsd/tools/tools/net80211/wlanstats/wlanstats.h (added) freebsd/wlanstats: Import from FreeBSD. Wed, 30 Nov 2016 15:41:12 GMT Christian Mauderer [d686d7b] * Makefile.todo (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_usb.h (modified) * rtemsbsd/local/runfw.c (added) wlan/run: Add firmware. Fri, 18 Nov 2016 10:13:11 GMT Christian Mauderer [edf32f2] * Makefile.todo (modified) * freebsd/sys/dev/rtwn/if_rtwn_task.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_rtwn.h (moved) * rtemsbsd/local/rtwn-rtl8192cfwT.c (added) rtwn: Port to RTEMS Tue, 22 Nov 2016 09:41:47 GMT Christian Mauderer [0cbb715] * freebsd/sys/dev/rtwn/if_rtwn.c (added) * freebsd/sys/dev/rtwn/if_rtwn_beacon.c (added) * freebsd/sys/dev/rtwn/if_rtwn_beacon.h (added) * freebsd/sys/dev/rtwn/if_rtwn_calib.c (added) * freebsd/sys/dev/rtwn/if_rtwn_calib.h (added) * freebsd/sys/dev/rtwn/if_rtwn_cam.c (added) * freebsd/sys/dev/rtwn/if_rtwn_cam.h (added) * freebsd/sys/dev/rtwn/if_rtwn_debug.h (added) * freebsd/sys/dev/rtwn/if_rtwn_efuse.c (added) * freebsd/sys/dev/rtwn/if_rtwn_efuse.h (added) * freebsd/sys/dev/rtwn/if_rtwn_fw.c (added) * freebsd/sys/dev/rtwn/if_rtwn_fw.h (added) * freebsd/sys/dev/rtwn/if_rtwn_nop.h (added) * freebsd/sys/dev/rtwn/if_rtwn_ridx.h (added) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (added) * freebsd/sys/dev/rtwn/if_rtwn_rx.h (added) * freebsd/sys/dev/rtwn/if_rtwn_task.c (added) * freebsd/sys/dev/rtwn/if_rtwn_task.h (added) * freebsd/sys/dev/rtwn/if_rtwn_tx.c (added) * freebsd/sys/dev/rtwn/if_rtwn_tx.h (added) * freebsd/sys/dev/rtwn/if_rtwnreg.h (added) * freebsd/sys/dev/rtwn/if_rtwnvar.h (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.h (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_reg.c (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_reg.h (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.h (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_tx.c (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_tx.h (added) * freebsd/sys/dev/rtwn/pci/rtwn_pci_var.h (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e.h (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_beacon.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_calib.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_fw_cmd.h (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_init.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_led.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_priv.h (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_reg.h (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rf.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom_defs.h (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom_image.h (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_tx.c (added) * freebsd/sys/dev/rtwn/rtl8188e/r88e_tx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu.h (added) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (added) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_init.c (added) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_reg.h (added) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_rx.c (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce.h (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_attach.c (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_calib.c (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_fw.c (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_init.c (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_led.c (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_priv.h (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_reg.h (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_rx.c (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_rx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_tx.c (added) * freebsd/sys/dev/rtwn/rtl8192c/pci/r92ce_tx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_attach.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_beacon.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_calib.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw_cmd.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_init.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_priv.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_reg.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rf.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom_defs.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom_image.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8192c/r92c_var.h (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu.h (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_attach.c (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_init.c (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_led.c (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_priv.h (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_reg.h (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_rx.c (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_tx.c (added) * freebsd/sys/dev/rtwn/rtl8192c/usb/r92cu_tx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_beacon.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_calib.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_caps.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_fw.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_fw_cmd.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_init.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_led.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_priv.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_reg.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rf.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rom.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rom_defs.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rom_image.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8812a/r12a_var.h (added) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au.h (added) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_attach.c (added) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_init.c (added) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_reg.h (added) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_rx.c (added) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_tx.c (added) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_tx_desc.h (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a.h (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_beacon.c (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_calib.c (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_chan.c (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_fw.c (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_init.c (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_led.c (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_priv.h (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_reg.h (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rom.c (added) * freebsd/sys/dev/rtwn/rtl8821a/r21a_rx.c (added) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au.h (added) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (added) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_dfs.c (added) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_init.c (added) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_reg.h (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.h (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_reg.c (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_reg.h (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.h (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.h (added) * freebsd/sys/dev/rtwn/usb/rtwn_usb_var.h (added) * libbsd.txt (modified) rtwn: Import from FreeBSD. Mon, 12 Dec 2016 09:51:42 GMT Christian Mauderer [9bc41d0] * Makefile.todo (modified) * freebsd/lib/lib80211/lib80211_regdomain.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-regdomain.h (added) * rtemsbsd/rtems/rtems-bsd-regdomain.c (added) lib80211/regdomain: Port to RTEMS. Fri, 18 Nov 2016 13:59:56 GMT Christian Mauderer [bce3e5e] * freebsd/lib/lib80211/lib80211_regdomain.c (modified) lib80211/regdomain: Import from FreeBSD. Fri, 18 Nov 2016 10:11:27 GMT Christian Mauderer [20fa599] * Makefile.todo (modified) * firmware-gen.py (added) firmware-gen.py: Add script to generate firmware c files. Thu, 17 Nov 2016 08:15:27 GMT Christian Mauderer [e9a8b5a] * rtemsbsd/rtems/rtems-kernel-init.c (modified) wlan ratectl and sta: Call init. Wed, 16 Nov 2016 15:29:17 GMT Christian Mauderer [5c3223f] * builder.py (modified) * freebsd/lib/lib80211/lib80211_regdomain.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifieee80211-data.h (added) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-namespace.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsdxml.h (added) ifconfig/wlan, expat, lib80211: Port to RTEMS. Wed, 16 Nov 2016 14:02:20 GMT Christian Mauderer [2389539] * freebsd/contrib/expat/lib/ascii.h (added) * freebsd/contrib/expat/lib/asciitab.h (added) * freebsd/contrib/expat/lib/expat.h (added) * freebsd/contrib/expat/lib/expat_external.h (added) * freebsd/contrib/expat/lib/iasciitab.h (added) * freebsd/contrib/expat/lib/internal.h (added) * freebsd/contrib/expat/lib/latin1tab.h (added) * freebsd/contrib/expat/lib/nametab.h (added) * freebsd/contrib/expat/lib/utf8tab.h (added) * freebsd/contrib/expat/lib/xmlparse.c (added) * freebsd/contrib/expat/lib/xmlrole.c (added) * freebsd/contrib/expat/lib/xmlrole.h (added) * freebsd/contrib/expat/lib/xmltok.c (added) * freebsd/contrib/expat/lib/xmltok.h (added) * freebsd/contrib/expat/lib/xmltok_impl.c (added) * freebsd/contrib/expat/lib/xmltok_impl.h (added) * freebsd/contrib/expat/lib/xmltok_ns.c (added) * freebsd/lib/lib80211/lib80211_ioctl.c (added) * freebsd/lib/lib80211/lib80211_ioctl.h (added) * freebsd/lib/lib80211/lib80211_regdomain.c (added) * freebsd/lib/lib80211/lib80211_regdomain.h (moved) * freebsd/sbin/ifconfig/ifieee80211.c (modified) ifconfig/wlan, expat, lib80211: Import from FreeBSD. Mon, 12 Dec 2016 11:23:40 GMT Christian Mauderer [59338de] * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_urtwn.h (added) Port USB and USB WLAN. Mon, 14 Nov 2016 12:30:48 GMT Christian Mauderer [d145449] * freebsd/sys/dev/usb/net/if_aue.c (added) * freebsd/sys/dev/usb/net/if_auereg.h (added) * freebsd/sys/dev/usb/net/if_axe.c (added) * freebsd/sys/dev/usb/net/if_axereg.h (added) * freebsd/sys/dev/usb/net/if_axge.c (added) * freebsd/sys/dev/usb/net/if_axgereg.h (added) * freebsd/sys/dev/usb/net/if_cdce.c (added) * freebsd/sys/dev/usb/net/if_cdcereg.h (added) * freebsd/sys/dev/usb/net/if_cue.c (added) * freebsd/sys/dev/usb/net/if_cuereg.h (added) * freebsd/sys/dev/usb/net/if_ipheth.c (added) * freebsd/sys/dev/usb/net/if_iphethvar.h (added) * freebsd/sys/dev/usb/net/if_kue.c (added) * freebsd/sys/dev/usb/net/if_kuefw.h (added) * freebsd/sys/dev/usb/net/if_kuereg.h (added) * freebsd/sys/dev/usb/net/if_mos.c (added) * freebsd/sys/dev/usb/net/if_mosreg.h (added) * freebsd/sys/dev/usb/net/if_rue.c (added) * freebsd/sys/dev/usb/net/if_ruereg.h (added) * freebsd/sys/dev/usb/net/if_smsc.c (added) * freebsd/sys/dev/usb/net/if_smscreg.h (added) * freebsd/sys/dev/usb/net/if_udav.c (added) * freebsd/sys/dev/usb/net/if_udavreg.h (added) * freebsd/sys/dev/usb/net/if_ure.c (added) * freebsd/sys/dev/usb/net/if_urereg.h (added) * freebsd/sys/dev/usb/net/ruephy.c (added) * freebsd/sys/dev/usb/net/ruephyreg.h (added) * freebsd/sys/dev/usb/net/usb_ethernet.c (added) * freebsd/sys/dev/usb/net/usb_ethernet.h (added) * freebsd/sys/dev/usb/wlan/if_rsu.c (added) * freebsd/sys/dev/usb/wlan/if_rsureg.h (added) * freebsd/sys/dev/usb/wlan/if_rum.c (added) * freebsd/sys/dev/usb/wlan/if_rumfw.h (added) * freebsd/sys/dev/usb/wlan/if_rumreg.h (added) * freebsd/sys/dev/usb/wlan/if_rumvar.h (added) * freebsd/sys/dev/usb/wlan/if_run.c (added) * freebsd/sys/dev/usb/wlan/if_runreg.h (added) * freebsd/sys/dev/usb/wlan/if_runvar.h (added) * freebsd/sys/dev/usb/wlan/if_uath.c (added) * freebsd/sys/dev/usb/wlan/if_uathreg.h (added) * freebsd/sys/dev/usb/wlan/if_uathvar.h (added) * freebsd/sys/dev/usb/wlan/if_upgt.c (added) * freebsd/sys/dev/usb/wlan/if_upgtvar.h (added) * freebsd/sys/dev/usb/wlan/if_ural.c (added) * freebsd/sys/dev/usb/wlan/if_uralreg.h (added) * freebsd/sys/dev/usb/wlan/if_uralvar.h (added) * freebsd/sys/dev/usb/wlan/if_urtw.c (added) * freebsd/sys/dev/usb/wlan/if_urtwreg.h (added) * freebsd/sys/dev/usb/wlan/if_urtwvar.h (added) * freebsd/sys/dev/usb/wlan/if_zyd.c (added) * freebsd/sys/dev/usb/wlan/if_zydfw.h (added) * freebsd/sys/dev/usb/wlan/if_zydreg.h (added) Import USB and USB WLAN from FreeBSD. Mon, 12 Dec 2016 12:09:09 GMT Christian Mauderer [66eb143] * freebsd/sys/kern/subr_firmware.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) firmware: Port to RTEMS. Wed, 16 Nov 2016 12:20:05 GMT Christian Mauderer [2e8dd24] * freebsd/sys/kern/subr_firmware.c (added) * freebsd/sys/sys/firmware.h (added) firmware: Import from FreeBSD. Mon, 12 Dec 2016 11:31:33 GMT Christian Mauderer [efc782b] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_platform.h (added) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) Port IEEE 802.11. Mon, 14 Nov 2016 12:46:13 GMT Christian Mauderer [a241ea8] * freebsd/sys/net80211/_ieee80211.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_acl.c (modified) * freebsd/sys/net80211/ieee80211_action.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_ageq.c (modified) * freebsd/sys/net80211/ieee80211_alq.c (added) * freebsd/sys/net80211/ieee80211_alq.h (added) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_crypto.c (modified) * freebsd/sys/net80211/ieee80211_crypto.h (modified) * freebsd/sys/net80211/ieee80211_crypto_ccmp.c (modified) * freebsd/sys/net80211/ieee80211_crypto_none.c (modified) * freebsd/sys/net80211/ieee80211_crypto_tkip.c (modified) * freebsd/sys/net80211/ieee80211_crypto_wep.c (modified) * freebsd/sys/net80211/ieee80211_ddb.c (modified) * freebsd/sys/net80211/ieee80211_dfs.c (modified) * freebsd/sys/net80211/ieee80211_dfs.h (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_hostap.h (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.h (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_mesh.h (modified) * freebsd/sys/net80211/ieee80211_monitor.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_node.h (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_phy.c (modified) * freebsd/sys/net80211/ieee80211_phy.h (modified) * freebsd/sys/net80211/ieee80211_power.c (modified) * freebsd/sys/net80211/ieee80211_power.h (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_radiotap.c (modified) * freebsd/sys/net80211/ieee80211_radiotap.h (modified) * freebsd/sys/net80211/ieee80211_ratectl.c (modified) * freebsd/sys/net80211/ieee80211_ratectl.h (modified) * freebsd/sys/net80211/ieee80211_ratectl_none.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.h (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/net80211/ieee80211_scan.c (modified) * freebsd/sys/net80211/ieee80211_scan.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_scan_sw.c (added) * freebsd/sys/net80211/ieee80211_scan_sw.h (added) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.h (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_superg.h (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_tdma.h (modified) * freebsd/sys/net80211/ieee80211_var.h (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/net80211/ieee80211_xauth.c (modified) Import IEEE 802.11 from FreeBSD. Thu, 12 Jan 2017 13:56:23 GMT Sebastian Huber [172f2ac] * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/sys/proc.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell.c (deleted) * rtemsbsd/rtems/rtems-kernel-thread.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) * testsuite/rcconf02/test_main.c (modified) * testsuite/thread01/test_main.c (modified) Use thread name support Update #2858. Wed, 11 Jan 2017 13:15:31 GMT Sebastian Huber [fb288fa] * freebsd/sbin/route/route.c (modified) * freebsd/sbin/route/rtems-bsd-route-route-data.h (modified) ROUTE(8): Disable routing socket timeout support FIXME: This ... Wed, 11 Jan 2017 13:01:17 GMT Sebastian Huber [f11bfc2] * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) rtems-bsd-mutex: Add SMP lock debug support Wed, 11 Jan 2017 10:52:41 GMT Sebastian Huber [e5ef01e] * rtemsbsd/rtems/rtems-kernel-muteximpl.c (modified) rtems-bsd-mutex: Update due to API changes Tue, 10 Jan 2017 13:41:23 GMT Sebastian Huber [9e8ce9ae] * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-namespace.h (modified) * testsuite/pf01/test_main.c (modified) pf: Some fixes after the update Tue, 10 Jan 2017 13:40:29 GMT Sebastian Huber [774f19f] * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) devfs: Fix typo Tue, 10 Jan 2017 13:00:53 GMT Sebastian Huber [851722b] * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) Declare feature_present() Tue, 10 Jan 2017 13:00:20 GMT Sebastian Huber [3dff21a] * freebsd/sys/contrib/pf/net/if_pflog.c (deleted) * freebsd/sys/contrib/pf/net/if_pflog.h (deleted) * freebsd/sys/contrib/pf/net/if_pflow.h (deleted) * freebsd/sys/contrib/pf/net/if_pfsync.c (deleted) * freebsd/sys/contrib/pf/net/if_pfsync.h (deleted) * freebsd/sys/contrib/pf/net/pf.c (deleted) * freebsd/sys/contrib/pf/net/pf_if.c (deleted) * freebsd/sys/contrib/pf/net/pf_ioctl.c (deleted) * freebsd/sys/contrib/pf/net/pf_lb.c (deleted) * freebsd/sys/contrib/pf/net/pf_mtag.h (deleted) * freebsd/sys/contrib/pf/net/pf_norm.c (deleted) * freebsd/sys/contrib/pf/net/pf_osfp.c (deleted) * freebsd/sys/contrib/pf/net/pf_ruleset.c (deleted) * freebsd/sys/contrib/pf/net/pf_subr.c (deleted) * freebsd/sys/contrib/pf/net/pf_table.c (deleted) * freebsd/sys/contrib/pf/net/pfvar.h (deleted) * freebsd/sys/contrib/pf/netinet/in4_cksum.c (deleted) Remove obsolete PF files Tue, 10 Jan 2017 07:04:58 GMT Sebastian Huber [64c663c] * freebsd/usr.sbin/arp/arp.c (modified) * freebsd/usr.sbin/arp/rtems-bsd-arp-arp-data.h (added) * freebsd/usr.sbin/arp/rtems-bsd-arp-data.h (added) * freebsd/usr.sbin/arp/rtems-bsd-arp-namespace.h (added) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-arp.c (added) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) * testsuite/netshell01/shellconfig.c (modified) ARP(8): Port to RTEMS Tue, 10 Jan 2017 06:58:50 GMT Sebastian Huber [246b61e] * freebsd/usr.sbin/arp/arp.c (added) ARP(8): Import from FreeBSD Mon, 09 Jan 2017 13:47:04 GMT Sebastian Huber [0577772] * freebsd-org (modified) * freebsd/contrib/libpcap/grammar.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/nslexer.c (modified) * freebsd/lib/libc/net/nsparser.c (modified) * freebsd/lib/libipsec/policy_parse.c (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/route/keywords.h (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/cam/scsi/scsi_da.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_bsd_addr.h (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_crc32.c (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (added) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/counter.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/seq.h (modified) * freebsd/sys/sys/socket.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-route-data.h (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD head 2017-01-09 Git mirror commit ...
