# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/25/24 12:06:06 Thu, 09 Aug 2018 06:00:16 GMT Sebastian Huber [4c22b5c] * rtemsbsd/include/machine/_kernel_if.h (added) * rtemsbsd/include/machine/_kernel_socket.h (added) Add FreeBSD kernel space header files Move the kernel space content ... Thu, 23 Aug 2018 06:38:20 GMT Sebastian Huber [ee738dd] * freebsd/contrib/wpa/src/rsn_supp/tdls.c (deleted) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c (deleted) * libbsd.py (modified) WPA_SUPPLICANT(8): Remove unused files Remove unused files which ... Tue, 21 Aug 2018 08:42:25 GMT Sebastian Huber [63084c1] * buildset/default.ini (modified) * freebsd/sys/netinet6/ip_fw_nat64.h (deleted) * freebsd/sys/netinet6/ip_fw_nptv6.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm_codel.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm_pie.h (deleted) * freebsd/sys/netpfil/ipfw/dn_heap.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_fq_codel.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_fq_codel_helper.h (deleted) * freebsd/sys/netpfil/ipfw/ip_dn_private.h (deleted) * freebsd/sys/netpfil/ipfw/ip_fw2.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_bpf.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_pfil.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table.h (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table_algo.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn_control.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl_control.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/ip_fw_nptv6.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.h (deleted) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) IPFW(4): Remove FreeBSD import This firewall was not ported to ... Mon, 20 Aug 2018 13:19:56 GMT Sebastian Huber [f62c62d] * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) Update rtems-bsd-kernel-namespace.h Update #3472. Fri, 24 Aug 2018 07:06:14 GMT Sebastian Huber [0963419] * freebsd/sys/kern/uipc_syscalls.c (modified) Fix alignment of getsockaddr_sockaddr Fri, 24 Aug 2018 06:55:00 GMT Sebastian Huber [12a885c] * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * rtemsbsd/powerpc/include/linux/time.h (modified) Update due to API changes Changes correspond to ... Mon, 20 Aug 2018 13:19:37 GMT Sebastian Huber [8e35aaa] * testsuite/termios/test_termios_utilities.c (modified) tests/termios: Fix warnings Thu, 09 Aug 2018 05:20:08 GMT Sebastian Huber [1d99262] * freebsd/sys/sys/libkern.h (modified) libkern.h: Avoid call overhead for bcmp() Mon, 06 Aug 2018 05:37:22 GMT Christian Mauderer [9bc7b96] * libbsd.txt (modified) libbsd.txt: Update version info and manpage links. The information ... Fri, 27 Jul 2018 12:39:47 GMT Christian Mauderer [afac48a] * libbsd.txt (modified) libbsd.txt: Add ipsec. Thu, 02 Aug 2018 08:22:11 GMT Christian Mauderer [baffbf3] * libbsd.py (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) * testsuite/ipsec01/README (added) * testsuite/ipsec01/setup_FreeBSD_as_communication_partner.sh (added) * testsuite/ipsec01/test_main.c (added) testsuite/ipsec01: Add. Thu, 02 Aug 2018 08:23:15 GMT Christian Mauderer [028bf82] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc.conf: Fix cloned interface setup. The cloned interfaces have to ... Thu, 02 Aug 2018 06:44:14 GMT Christian Mauderer [c7eec93] * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) Add RTEMS_BSD_CONFIG_IPSEC. Mon, 30 Jul 2018 15:02:59 GMT Christian Mauderer [1b467ad] * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/include/rtems/ipsec.h (added) * rtemsbsd/rtems/rtems-bsd-racoon.c (added) * rtemsbsd/rtems/rtems-bsd-rc-conf-ipsec.c (added) Add ipsec to rc.conf. Wed, 13 Jun 2018 09:11:03 GMT Christian Mauderer [5e13963] * buildset/everything.ini (modified) buildset/everything: Add some usefull comments. Thu, 03 May 2018 12:15:11 GMT Christian Mauderer [b376ae1] * freebsd/lib/libipsec/ipsec_dump_policy.c (deleted) * freebsd/lib/libipsec/ipsec_strerror.c (deleted) * freebsd/lib/libipsec/ipsec_strerror.h (deleted) * freebsd/lib/libipsec/libpfkey.h (deleted) * freebsd/lib/libipsec/pfkey.c (deleted) * freebsd/lib/libipsec/pfkey_dump.c (deleted) * freebsd/lib/libipsec/policy_parse.c (deleted) * freebsd/lib/libipsec/policy_parse.y (deleted) * freebsd/lib/libipsec/policy_token.c (deleted) * freebsd/lib/libipsec/policy_token.l (deleted) * freebsd/lib/libipsec/y.tab.h (deleted) * ipsec-tools/src/config.h (added) * ipsec-tools/src/libipsec/config.h (added) * ipsec-tools/src/libipsec/ipsec_dump_policy.c (modified) * ipsec-tools/src/libipsec/ipsec_get_policylen.c (modified) * ipsec-tools/src/libipsec/ipsec_strerror.c (modified) * ipsec-tools/src/libipsec/key_debug.c (modified) * ipsec-tools/src/libipsec/libpfkey.h (modified) * ipsec-tools/src/libipsec/pfkey.c (modified) * ipsec-tools/src/libipsec/pfkey_dump.c (modified) * ipsec-tools/src/libipsec/policy_parse.c (modified) * ipsec-tools/src/libipsec/policy_parse.h (modified) * ipsec-tools/src/libipsec/policy_parse.y (modified) * ipsec-tools/src/libipsec/policy_token.c (modified) * ipsec-tools/src/libipsec/policy_token.l (modified) * ipsec-tools/src/libipsec/test-policy.c (modified) * ipsec-tools/src/racoon/admin.c (modified) * ipsec-tools/src/racoon/algorithm.c (modified) * ipsec-tools/src/racoon/algorithm.h (modified) * ipsec-tools/src/racoon/backupsa.c (modified) * ipsec-tools/src/racoon/cfparse.c (modified) * ipsec-tools/src/racoon/cfparse.h (modified) * ipsec-tools/src/racoon/cfparse_wrapper.c (added) * ipsec-tools/src/racoon/cftoken.c (modified) * ipsec-tools/src/racoon/cftoken_proto.h (modified) * ipsec-tools/src/racoon/cftoken_wrapper.c (added) * ipsec-tools/src/racoon/config.h (added) * ipsec-tools/src/racoon/crypto_openssl.c (modified) * ipsec-tools/src/racoon/dnssec.c (modified) * ipsec-tools/src/racoon/eaytest.c (modified) * ipsec-tools/src/racoon/evt.c (modified) * ipsec-tools/src/racoon/genlist.c (modified) * ipsec-tools/src/racoon/getcertsbyname.c (modified) * ipsec-tools/src/racoon/grabmyaddr.c (modified) * ipsec-tools/src/racoon/gssapi.c (modified) * ipsec-tools/src/racoon/handler.c (modified) * ipsec-tools/src/racoon/ipsec_doi.c (modified) * ipsec-tools/src/racoon/isakmp.c (modified) * ipsec-tools/src/racoon/isakmp_agg.c (modified) * ipsec-tools/src/racoon/isakmp_base.c (modified) * ipsec-tools/src/racoon/isakmp_cfg.c (modified) * ipsec-tools/src/racoon/isakmp_frag.c (modified) * ipsec-tools/src/racoon/isakmp_ident.c (modified) * ipsec-tools/src/racoon/isakmp_inf.c (modified) * ipsec-tools/src/racoon/isakmp_newg.c (modified) * ipsec-tools/src/racoon/isakmp_quick.c (modified) * ipsec-tools/src/racoon/isakmp_unity.c (modified) * ipsec-tools/src/racoon/isakmp_xauth.c (modified) * ipsec-tools/src/racoon/kmpstat.c (modified) * ipsec-tools/src/racoon/localconf.c (modified) * ipsec-tools/src/racoon/logger.c (modified) * ipsec-tools/src/racoon/main.c (modified) * ipsec-tools/src/racoon/misc.c (modified) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-alg-fst.c (modified) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-api-fst.c (modified) * ipsec-tools/src/racoon/missing/crypto/sha2/config.h (added) * ipsec-tools/src/racoon/missing/crypto/sha2/sha2.c (modified) * ipsec-tools/src/racoon/nattraversal.c (modified) * ipsec-tools/src/racoon/oakley.c (modified) * ipsec-tools/src/racoon/package_version.h (added) * ipsec-tools/src/racoon/pfkey.c (modified) * ipsec-tools/src/racoon/plainrsa-gen.c (modified) * ipsec-tools/src/racoon/plog.c (modified) * ipsec-tools/src/racoon/policy.c (modified) * ipsec-tools/src/racoon/privsep.c (modified) * ipsec-tools/src/racoon/proposal.c (modified) * ipsec-tools/src/racoon/prsa_par.c (modified) * ipsec-tools/src/racoon/prsa_par.h (modified) * ipsec-tools/src/racoon/prsa_par.y (modified) * ipsec-tools/src/racoon/prsa_par_wrapper.c (added) * ipsec-tools/src/racoon/prsa_tok.c (modified) * ipsec-tools/src/racoon/prsa_tok.l (modified) * ipsec-tools/src/racoon/prsa_tok_wrapper.c (added) * ipsec-tools/src/racoon/racoonctl.c (modified) * ipsec-tools/src/racoon/remoteconf.c (modified) * ipsec-tools/src/racoon/rsalist.c (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-admin-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-algorithm-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-backupsa-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-cfparse_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-cftoken_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-crypto_openssl-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-dnssec-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-evt-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-genlist-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-getcertsbyname-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-grabmyaddr-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-gssapi-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-handler-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-ipsec_doi-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_agg-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_base-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_frag-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_ident-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_inf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_newg-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_quick-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-localconf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-logger-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-main-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-misc-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-namespace.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-nattraversal-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-oakley-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-pfkey-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-plog-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-policy-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-privsep-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-proposal-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-prsa_par_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-prsa_tok_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-remoteconf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-rsalist-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-safefile-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sainfo-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-schedule-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sha2-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sockmisc-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-str2val-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-strnames-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-vendorid-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-vmbuf-data.h (added) * ipsec-tools/src/racoon/safefile.c (modified) * ipsec-tools/src/racoon/sainfo.c (modified) * ipsec-tools/src/racoon/schedule.c (modified) * ipsec-tools/src/racoon/security.c (modified) * ipsec-tools/src/racoon/session.c (modified) * ipsec-tools/src/racoon/sockmisc.c (modified) * ipsec-tools/src/racoon/sockmisc.h (modified) * ipsec-tools/src/racoon/str2val.c (modified) * ipsec-tools/src/racoon/strnames.c (modified) * ipsec-tools/src/racoon/throttle.c (modified) * ipsec-tools/src/racoon/vendorid.c (modified) * ipsec-tools/src/racoon/vmbuf.c (modified) * ipsec-tools/src/setkey/config.h (added) * ipsec-tools/src/setkey/package_version.h (added) * ipsec-tools/src/setkey/parse.c (modified) * ipsec-tools/src/setkey/parse.h (modified) * ipsec-tools/src/setkey/parse.y (modified) * ipsec-tools/src/setkey/parse_wrapper.c (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-namespace.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-parse_wrapper-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-setkey-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-token_wrapper-data.h (added) * ipsec-tools/src/setkey/setkey.c (modified) * ipsec-tools/src/setkey/token.c (modified) * ipsec-tools/src/setkey/token_wrapper.c (added) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/machine/rtems-bsd-racoon.h (moved) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-racoon.c (added) * rtemsbsd/rtems/rtems-bsd-shell-setkey.c (added) * rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c (modified) * rtemsbsd/rtems/rtems-racoon-mutex.c (added) * testsuite/media01/test_main.c (modified) ipsec-tools: Port libipsec, setkey and racoon. Note that this ... Wed, 06 Jun 2018 09:11:52 GMT Christian Mauderer [8645c9d7] * ipsec-tools/src/libipsec/libpfkey.h (modified) * ipsec-tools/src/libipsec/pfkey.c (modified) * ipsec-tools/src/racoon/gssapi.c (modified) * ipsec-tools/src/racoon/handler.h (modified) * ipsec-tools/src/racoon/isakmp.c (modified) * ipsec-tools/src/racoon/isakmp_cfg.c (modified) * ipsec-tools/src/racoon/isakmp_frag.c (modified) * ipsec-tools/src/racoon/isakmp_inf.c (modified) * ipsec-tools/src/racoon/isakmp_quick.c (modified) * ipsec-tools/src/racoon/localconf.c (modified) * ipsec-tools/src/racoon/nattraversal.c (modified) * ipsec-tools/src/racoon/pfkey.c (modified) ipsec-tools: Apply patches from FreeBSD ports. Source: ... Wed, 30 May 2018 12:27:35 GMT Christian Mauderer [ff36f5e] * ipsec-tools/ChangeLog (added) * ipsec-tools/ChangeLog.old (added) * ipsec-tools/Makefile.am (added) * ipsec-tools/Makefile.in (added) * ipsec-tools/NEWS (added) * ipsec-tools/README (added) * ipsec-tools/aclocal.m4 (added) * ipsec-tools/acracoon.m4 (added) * ipsec-tools/bootstrap (added) * ipsec-tools/compile (added) * ipsec-tools/config.guess (added) * ipsec-tools/config.h.in (added) * ipsec-tools/config.sub (added) * ipsec-tools/configure (added) * ipsec-tools/configure.ac (added) * ipsec-tools/depcomp (added) * ipsec-tools/install-sh (added) * ipsec-tools/ltmain.sh (added) * ipsec-tools/missing (added) * ipsec-tools/package_version.h.in (added) * ipsec-tools/rpm/Makefile.am (added) * ipsec-tools/rpm/Makefile.in (added) * ipsec-tools/rpm/ipsec-tools.spec.in (added) * ipsec-tools/rpm/suse/Makefile.am (added) * ipsec-tools/rpm/suse/Makefile.in (added) * ipsec-tools/rpm/suse/ipsec-tools.spec (added) * ipsec-tools/rpm/suse/ipsec-tools.spec.in (added) * ipsec-tools/rpm/suse/racoon.init (added) * ipsec-tools/rpm/suse/sysconfig.racoon (added) * ipsec-tools/src/Makefile.am (added) * ipsec-tools/src/Makefile.in (added) * ipsec-tools/src/include-glibc/Makefile.am (added) * ipsec-tools/src/include-glibc/Makefile.in (added) * ipsec-tools/src/include-glibc/glibc-bugs.h (added) * ipsec-tools/src/include-glibc/net/pfkeyv2.h (added) * ipsec-tools/src/include-glibc/netinet/ipsec.h (added) * ipsec-tools/src/include-glibc/sys/queue.h (added) * ipsec-tools/src/libipsec/Makefile.am (added) * ipsec-tools/src/libipsec/Makefile.in (added) * ipsec-tools/src/libipsec/ipsec_dump_policy.c (added) * ipsec-tools/src/libipsec/ipsec_get_policylen.c (added) * ipsec-tools/src/libipsec/ipsec_set_policy.3 (added) * ipsec-tools/src/libipsec/ipsec_strerror.3 (added) * ipsec-tools/src/libipsec/ipsec_strerror.c (added) * ipsec-tools/src/libipsec/ipsec_strerror.h (added) * ipsec-tools/src/libipsec/key_debug.c (added) * ipsec-tools/src/libipsec/libpfkey.h (added) * ipsec-tools/src/libipsec/pfkey.c (added) * ipsec-tools/src/libipsec/pfkey_dump.c (added) * ipsec-tools/src/libipsec/policy_parse.c (added) * ipsec-tools/src/libipsec/policy_parse.h (added) * ipsec-tools/src/libipsec/policy_parse.y (added) * ipsec-tools/src/libipsec/policy_token.c (added) * ipsec-tools/src/libipsec/policy_token.l (added) * ipsec-tools/src/libipsec/test-policy.c (added) * ipsec-tools/src/racoon/Makefile.am (added) * ipsec-tools/src/racoon/Makefile.in (added) * ipsec-tools/src/racoon/TODO (added) * ipsec-tools/src/racoon/admin.c (added) * ipsec-tools/src/racoon/admin.h (added) * ipsec-tools/src/racoon/admin_var.h (added) * ipsec-tools/src/racoon/algorithm.c (added) * ipsec-tools/src/racoon/algorithm.h (added) * ipsec-tools/src/racoon/backupsa.c (added) * ipsec-tools/src/racoon/backupsa.h (added) * ipsec-tools/src/racoon/cfparse.c (added) * ipsec-tools/src/racoon/cfparse.h (added) * ipsec-tools/src/racoon/cfparse.y (added) * ipsec-tools/src/racoon/cfparse_proto.h (added) * ipsec-tools/src/racoon/cftoken.c (added) * ipsec-tools/src/racoon/cftoken.l (added) * ipsec-tools/src/racoon/cftoken_proto.h (added) * ipsec-tools/src/racoon/contrib/sp.pl (added) * ipsec-tools/src/racoon/crypto_openssl.c (added) * ipsec-tools/src/racoon/crypto_openssl.h (added) * ipsec-tools/src/racoon/debug.h (added) * ipsec-tools/src/racoon/debugrm.h (added) * ipsec-tools/src/racoon/dhgroup.h (added) * ipsec-tools/src/racoon/dnssec.c (added) * ipsec-tools/src/racoon/dnssec.h (added) * ipsec-tools/src/racoon/doc/FAQ (added) * ipsec-tools/src/racoon/doc/README.certificate (added) * ipsec-tools/src/racoon/doc/README.gssapi (added) * ipsec-tools/src/racoon/doc/README.plainrsa (added) * ipsec-tools/src/racoon/doc/README.privsep (added) * ipsec-tools/src/racoon/dump.h (added) * ipsec-tools/src/racoon/eaytest.c (added) * ipsec-tools/src/racoon/evt.c (added) * ipsec-tools/src/racoon/evt.h (added) * ipsec-tools/src/racoon/gcmalloc.h (added) * ipsec-tools/src/racoon/genlist.c (added) * ipsec-tools/src/racoon/genlist.h (added) * ipsec-tools/src/racoon/getcertsbyname.c (added) * ipsec-tools/src/racoon/gnuc.h (added) * ipsec-tools/src/racoon/grabmyaddr.c (added) * ipsec-tools/src/racoon/grabmyaddr.h (added) * ipsec-tools/src/racoon/gssapi.c (added) * ipsec-tools/src/racoon/gssapi.h (added) * ipsec-tools/src/racoon/handler.c (added) * ipsec-tools/src/racoon/handler.h (added) * ipsec-tools/src/racoon/ipsec_doi.c (added) * ipsec-tools/src/racoon/ipsec_doi.h (added) * ipsec-tools/src/racoon/isakmp.c (added) * ipsec-tools/src/racoon/isakmp.h (added) * ipsec-tools/src/racoon/isakmp_agg.c (added) * ipsec-tools/src/racoon/isakmp_agg.h (added) * ipsec-tools/src/racoon/isakmp_base.c (added) * ipsec-tools/src/racoon/isakmp_base.h (added) * ipsec-tools/src/racoon/isakmp_cfg.c (added) * ipsec-tools/src/racoon/isakmp_cfg.h (added) * ipsec-tools/src/racoon/isakmp_frag.c (added) * ipsec-tools/src/racoon/isakmp_frag.h (added) * ipsec-tools/src/racoon/isakmp_ident.c (added) * ipsec-tools/src/racoon/isakmp_ident.h (added) * ipsec-tools/src/racoon/isakmp_inf.c (added) * ipsec-tools/src/racoon/isakmp_inf.h (added) * ipsec-tools/src/racoon/isakmp_newg.c (added) * ipsec-tools/src/racoon/isakmp_newg.h (added) * ipsec-tools/src/racoon/isakmp_quick.c (added) * ipsec-tools/src/racoon/isakmp_quick.h (added) * ipsec-tools/src/racoon/isakmp_unity.c (added) * ipsec-tools/src/racoon/isakmp_unity.h (added) * ipsec-tools/src/racoon/isakmp_var.h (added) * ipsec-tools/src/racoon/isakmp_xauth.c (added) * ipsec-tools/src/racoon/isakmp_xauth.h (added) * ipsec-tools/src/racoon/kmpstat.c (added) * ipsec-tools/src/racoon/localconf.c (added) * ipsec-tools/src/racoon/localconf.h (added) * ipsec-tools/src/racoon/logger.c (added) * ipsec-tools/src/racoon/logger.h (added) * ipsec-tools/src/racoon/main.c (added) * ipsec-tools/src/racoon/misc.c (added) * ipsec-tools/src/racoon/misc.h (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/boxes-fst.dat (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-alg-fst.c (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-alg-fst.h (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-api-fst.c (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-api-fst.h (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael.h (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael_local.h (added) * ipsec-tools/src/racoon/missing/crypto/sha2/sha2.c (added) * ipsec-tools/src/racoon/missing/crypto/sha2/sha2.h (added) * ipsec-tools/src/racoon/nattraversal.c (added) * ipsec-tools/src/racoon/nattraversal.h (added) * ipsec-tools/src/racoon/netdb_dnssec.h (added) * ipsec-tools/src/racoon/oakley.c (added) * ipsec-tools/src/racoon/oakley.h (added) * ipsec-tools/src/racoon/pfkey.c (added) * ipsec-tools/src/racoon/pfkey.h (added) * ipsec-tools/src/racoon/plainrsa-gen.8 (added) * ipsec-tools/src/racoon/plainrsa-gen.c (added) * ipsec-tools/src/racoon/plog.c (added) * ipsec-tools/src/racoon/plog.h (added) * ipsec-tools/src/racoon/policy.c (added) * ipsec-tools/src/racoon/policy.h (added) * ipsec-tools/src/racoon/privsep.c (added) * ipsec-tools/src/racoon/privsep.h (added) * ipsec-tools/src/racoon/proposal.c (added) * ipsec-tools/src/racoon/proposal.h (added) * ipsec-tools/src/racoon/prsa_par.c (added) * ipsec-tools/src/racoon/prsa_par.h (added) * ipsec-tools/src/racoon/prsa_par.y (added) * ipsec-tools/src/racoon/prsa_tok.c (added) * ipsec-tools/src/racoon/prsa_tok.l (added) * ipsec-tools/src/racoon/racoon.8 (added) * ipsec-tools/src/racoon/racoon.conf.5 (added) * ipsec-tools/src/racoon/racoonctl.8 (added) * ipsec-tools/src/racoon/racoonctl.c (added) * ipsec-tools/src/racoon/racoonctl.h (added) * ipsec-tools/src/racoon/remoteconf.c (added) * ipsec-tools/src/racoon/remoteconf.h (added) * ipsec-tools/src/racoon/rsalist.c (added) * ipsec-tools/src/racoon/rsalist.h (added) * ipsec-tools/src/racoon/safefile.c (added) * ipsec-tools/src/racoon/safefile.h (added) * ipsec-tools/src/racoon/sainfo.c (added) * ipsec-tools/src/racoon/sainfo.h (added) * ipsec-tools/src/racoon/samples/psk.txt.in (added) * ipsec-tools/src/racoon/samples/psk.txt.sample (added) * ipsec-tools/src/racoon/samples/racoon.conf.in (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample-gssapi (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample-inherit (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample-natt (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample-plainrsa (added) * ipsec-tools/src/racoon/samples/roadwarrior/README (added) * ipsec-tools/src/racoon/samples/roadwarrior/client/phase1-down.sh (added) * ipsec-tools/src/racoon/samples/roadwarrior/client/phase1-up.sh (added) * ipsec-tools/src/racoon/samples/roadwarrior/client/racoon.conf (added) * ipsec-tools/src/racoon/samples/roadwarrior/server/racoon.conf (added) * ipsec-tools/src/racoon/samples/roadwarrior/server/racoon.conf-radius (added) * ipsec-tools/src/racoon/schedule.c (added) * ipsec-tools/src/racoon/schedule.h (added) * ipsec-tools/src/racoon/security.c (added) * ipsec-tools/src/racoon/session.c (added) * ipsec-tools/src/racoon/session.h (added) * ipsec-tools/src/racoon/sockmisc.c (added) * ipsec-tools/src/racoon/sockmisc.h (added) * ipsec-tools/src/racoon/stats.pl (added) * ipsec-tools/src/racoon/str2val.c (added) * ipsec-tools/src/racoon/str2val.h (added) * ipsec-tools/src/racoon/strnames.c (added) * ipsec-tools/src/racoon/strnames.h (added) * ipsec-tools/src/racoon/throttle.c (added) * ipsec-tools/src/racoon/throttle.h (added) * ipsec-tools/src/racoon/var.h (added) * ipsec-tools/src/racoon/vendorid.c (added) * ipsec-tools/src/racoon/vendorid.h (added) * ipsec-tools/src/racoon/vmbuf.c (added) * ipsec-tools/src/racoon/vmbuf.h (added) * ipsec-tools/src/setkey/Makefile.am (added) * ipsec-tools/src/setkey/Makefile.in (added) * ipsec-tools/src/setkey/extern.h (added) * ipsec-tools/src/setkey/parse.c (added) * ipsec-tools/src/setkey/parse.h (added) * ipsec-tools/src/setkey/parse.y (added) * ipsec-tools/src/setkey/sample-policy01.cf (added) * ipsec-tools/src/setkey/sample-policy02.cf (added) * ipsec-tools/src/setkey/sample.cf (added) * ipsec-tools/src/setkey/scriptdump.pl (added) * ipsec-tools/src/setkey/setkey.8 (added) * ipsec-tools/src/setkey/setkey.c (added) * ipsec-tools/src/setkey/test-pfkey.c (added) * ipsec-tools/src/setkey/token.c (added) * ipsec-tools/src/setkey/token.l (added) * ipsec-tools/src/setkey/vchar.h (added) * ipsec-tools/test-driver (added) * ipsec-tools/ylwrap (added) Import ipsec-tools 0.8.2. Import unchanged ipsec-tools sources in ... Fri, 27 Apr 2018 12:57:20 GMT Christian Mauderer [6215813] * buildset/default.ini (modified) * buildset/everything.ini (modified) * freebsd/sys/net/if_ipsec.c (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_ipsec.h (modified) if_ipsec: Port and add to everything-buildset. This ports the ... Thu, 03 May 2018 11:31:25 GMT Christian Mauderer [09bbedc] * freebsd/sys/net/if_ipsec.c (added) * freebsd/sys/net/if_ipsec.h (added) if_ipsec: Import from FreeBSD. Mon, 07 May 2018 08:19:28 GMT Christian Mauderer [01855a5] * builder.py (modified) * waf_libbsd.py (modified) waf: Allow to only generate lex and yacc. In some applications, ... Wed, 13 Jun 2018 13:04:47 GMT Christian Mauderer [879eaa7] * userspace-header-gen.py (modified) userspace-header-gen: Special case for Yacc / Lex. Some variables ... Tue, 26 Jun 2018 11:54:08 GMT Christian Mauderer [9ea8664] * freebsd/sys/sys/random.h (modified) random: Implement read_random via getentropy. Tue, 12 Jun 2018 13:44:44 GMT Christian Mauderer [9efc650] * freebsd/sys/crypto/sha2/sha2.h (deleted) crypto/sha2: Remove left over file. This file seems to be imported ... Thu, 26 Jul 2018 12:49:35 GMT Sebastian Huber [1372502] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Make sure CALLOUT_DFRMIGRATION is not used This flag supports the ... Thu, 26 Jul 2018 12:35:56 GMT Sebastian Huber [e37f03e] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Make sure CALLOUT_PROCESSED is not used This flag is only used in ... Thu, 26 Jul 2018 12:12:46 GMT Sebastian Huber [6d9d7b1] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Critical bug fix for callouts FreeBSD has two callout executors, ... Thu, 26 Jul 2018 11:52:43 GMT Sebastian Huber [3df89c0] * testsuite/selectpollkqueue01/test_main.c (modified) selectpollkqueue01: Invalidate file descriptor This is not a ... Thu, 26 Jul 2018 10:03:45 GMT Sebastian Huber [6fb003f] * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * testsuite/syscalls01/test_main.c (modified) * testsuite/thread01/test_main.c (modified) Fix sporadic test failures via uma_timeout() Mon, 02 Jul 2018 06:21:37 GMT Sebastian Huber [94b5368] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/socketvar.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) Avoid malloc() in getsockaddr() The getsockaddr() function is used ... Wed, 04 Jul 2018 05:19:01 GMT Nicolas Tsiogkas [e6f6b5e] * freebsd/sys/net/bpf.c (modified) BPF(9): Pass flags to bpfopen() Mon, 02 Jul 2018 07:16:14 GMT Sebastian Huber [a1e4757] * testsuite/syscalls01/test_main.c (modified) syscalls01: Fix sporadic test failures Mon, 18 Jun 2018 11:22:49 GMT Christian Mauderer [a07eb67] * rtems_waf (modified) rtems_waf: Fix show-commands option. Mon, 18 Jun 2018 11:06:47 GMT Christian Mauderer [aad7461] * .gitmodules (modified) rtems_waf: Move to the public repositories. For an update from an ... Wed, 30 May 2018 11:34:36 GMT Christian Mauderer [f8cf074] * rtemsbsd/include/bsp/nexus-devices.h (modified) beagle: Disable WiFi if libbsd is build without it. Update #3351. Thu, 17 May 2018 18:35:19 GMT Christian Mauderer [e1d62e8] * waf_libbsd.py (modified) waf: Fix python3 compatibility. Wed, 02 May 2018 07:01:32 GMT Sebastian Huber [b2eb48c] * dhcpcd/dhcpcd.c (modified) * dhcpcd/namespace.h (modified) * dhcpcd/script.c (modified) * dhcpcd/script.h (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/dhcpcd.h (modified) * testsuite/dhcpcd01/test_main.c (modified) dhcpcd: Add hooks Wed, 02 May 2018 06:58:48 GMT Sebastian Huber [8bd38d6] * dhcpcd/dhcpcd.c (modified) * dhcpcd/namespace.h (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/dhcpcd.h (added) * rtemsbsd/rtems/rtems-bsd-init-dhcp.c (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) dhcpcd: Add rtems_dhcpcd_start() Use it throughout to start the ... Thu, 03 May 2018 06:18:24 GMT Sebastian Huber [bd09f9f] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Do not create directories used by dhcpcd The dhcpcd will ... Thu, 03 May 2018 06:17:59 GMT Sebastian Huber [9c570da] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Include missing header files Wed, 02 May 2018 09:25:18 GMT Christian Mauderer [dd35ec5] * builder.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Allow to add libs per test. Update #3419. Wed, 02 May 2018 09:56:39 GMT Christian Mauderer [a779a3b] * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.y (modified) pfctl: Undef INET6 to avoid warning. Wed, 25 Apr 2018 14:28:00 GMT Christian Mauderer [338f300] * builder.py (modified) * buildset/default.ini (modified) * buildset/everything.ini (added) * buildset/minimal.ini (added) * buildset/sample.ini (deleted) * dhcpcd/config.h (modified) * dhcpcd/dhcp6.c (modified) * dhcpcd/ipv6.c (modified) * dhcpcd/ipv6.h (modified) * dhcpcd/ipv6nd.c (modified) * dhcpcd/platform.h (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_inet6.h (modified) * testsuite/commands01/test_main.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) buildset: Add minimal and everything config. This adds two new ... Thu, 26 Apr 2018 14:10:09 GMT Christian Mauderer [4eb2502] * freebsd/contrib/tcpdump/print-sunrpc.c (deleted) tcpdump: Remove unused file. Wed, 25 Apr 2018 12:51:07 GMT Christian Mauderer [93f1904] * waf_libbsd.py (modified) waf: Generate a rtems/bsd/modules.h The generated file defines a ... Wed, 02 May 2018 12:59:48 GMT Christian Mauderer [1588cf1] * waf_libbsd.py (modified) waf: Fix source code generators. There have been some bugs with the ... Wed, 25 Apr 2018 10:50:26 GMT Christian Mauderer [821976e] * waf_libbsd.py (modified) waf: Fix usage of build-include from config. Wed, 02 May 2018 08:35:35 GMT Sebastian Huber [634b3bf] * rtemsbsd/debugger/rtems-debugger-remote-tcp.c (deleted) * rtemsbsd/include/rtems/rtems-debugger-remote-tcp.h (deleted) rtems-debugger: Remove files They are now in the main RTEMS ... Mon, 30 Apr 2018 09:07:05 GMT Sebastian Huber [443a058] * freebsd/include/arpa/ftp.h (deleted) * libbsd.py (modified) * rtemsbsd/ftpd/ftpd-init.c (deleted) * rtemsbsd/ftpd/ftpd.c (deleted) * rtemsbsd/ftpfs/ftpfs.c (deleted) * rtemsbsd/include/rtems/ftpd.h (deleted) * rtemsbsd/include/rtems/ftpfs.h (deleted) * rtemsbsd/include/rtems/telnetd.h (deleted) * rtemsbsd/telnetd/check_passwd.c (deleted) * rtemsbsd/telnetd/des.c (deleted) * rtemsbsd/telnetd/passwd.h (deleted) * rtemsbsd/telnetd/pty.c (deleted) * rtemsbsd/telnetd/telnetd-init.c (deleted) * rtemsbsd/telnetd/telnetd.c (deleted) * waf_libbsd.py (modified) Use network services from RTEMS Close #3419. Mon, 30 Apr 2018 11:35:25 GMT Sebastian Huber [b1404f2] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Add DHCP clientid to test default network init Fri, 27 Apr 2018 08:14:44 GMT Sebastian Huber [ef5d536] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Simplify XDMA usage Fri, 27 Apr 2018 06:39:22 GMT Sebastian Huber [d45899b] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Get rid of bounce buffer Thu, 26 Apr 2018 13:23:08 GMT Sebastian Huber [3fac9e9] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Use real interrupt Execute at91_mci_intr() in interrupt ... Thu, 26 Apr 2018 13:19:42 GMT Sebastian Huber [c7e162a] * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) mmc: Optimize mmc_wait_for_req() Use a self-contained RTEMS binary ... Thu, 26 Apr 2018 09:14:39 GMT Sebastian Huber [4b14263] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Fix use of BOARD_MCK Thu, 26 Apr 2018 09:14:10 GMT Sebastian Huber [f092186] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Fix use of pre-processor defines Fri, 06 Apr 2018 08:35:42 GMT Christian Mauderer [854427b] * CONTRIBUTING.md (modified) * README.waf (modified) * builder.py (modified) * buildset/default.ini (added) * buildset/sample.ini (added) * libbsd.py (modified) * rtems_waf (modified) * waf_libbsd.py (modified) * wscript (modified) waf: Add configurations with different modules. Update #3351 Fri, 06 Apr 2018 07:37:35 GMT Christian Mauderer [fedd993] * builder.py (modified) * freebsd-to-rtems.py (modified) freebsd-to-rtems.py: Use all modules. Update #3351 Fri, 06 Apr 2018 07:42:29 GMT Christian Mauderer [494b156] * libbsd.py (modified) waf: Remove module without sources. There are no imported sources ... Tue, 27 Mar 2018 07:31:49 GMT Christian Mauderer [a6a6d54] * builder.py (modified) * waf_libbsd.py (modified) waf: Fix freebsd-to-rtems.py. Update #3351 Mon, 26 Mar 2018 04:14:53 GMT Chris Johns [d797c5d] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Refactor libbsd.py to support per module generation. This ... Mon, 26 Mar 2018 04:14:52 GMT Chris Johns [f7a09b5] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (deleted) * waf_generator.py (deleted) * waf_libbsd.py (added) * wscript (modified) waf: Support building from libbsd.py directly from waf. Remove the ... Tue, 27 Mar 2018 12:42:31 GMT Sebastian Huber [8189ea8] * freebsd/sys/opencrypto/cryptodev.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/crypto/cryptodev.h (added) * testsuite/crypto01/test_main.c (added) CRYPTO(4): Port to RTEMS Tue, 27 Mar 2018 11:25:16 GMT Sebastian Huber [6600368] * freebsd/sys/opencrypto/cryptodev.c (added) CRYPTO(4): Import from FreeBSD Tue, 27 Mar 2018 12:41:50 GMT Sebastian Huber [b8f7836] * freebsd/sys/fs/devfs/devfs_int.h (modified) DEVFS(5): Fix warning Tue, 27 Mar 2018 12:40:19 GMT Sebastian Huber [8993827] * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) DEVFS(5): Properly initialize fp->f_cdevpriv Fri, 23 Mar 2018 06:58:18 GMT Christian Mauderer [7ec935e] * libbsd.txt (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-kernel-vprintf.c (modified) vprintf: Add handler that mutes all output. This adds a vprintf ... Fri, 23 Mar 2018 08:14:34 GMT Sebastian Huber [d300a34] * rtemsbsd/rtems/rtems-bsd-ifconfig.c (modified) Silence rtems_bsd_ifconfig() Wed, 21 Mar 2018 08:23:17 GMT Christian Mauderer [b3d1e6a] * config.inc (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * waf_generator.py (modified) config.inc: Remove unused values. Thu, 15 Mar 2018 08:09:31 GMT Christian Mauderer [b2a210c] * rtemsbsd/sys/dev/atsam/if_atsam.c (modified) if_atsam: Add checksum offload. Tue, 13 Mar 2018 14:02:55 GMT Christian Mauderer [67c35b9] * libbsd.py (modified) * libbsd_waf.py (modified) openssl: Provide deprecated functions. Some applications (like the ... Mon, 12 Mar 2018 13:38:46 GMT Sebastian Huber [eae664e] * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-kernel-muteximpl.c (modified) * testsuite/mutex01/test_main.c (modified) mutex: Use panic() after ISR lock release Using panic() with ... Tue, 06 Feb 2018 08:29:49 GMT Sebastian Huber [2275776] * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) dwc_otg: Default to USB host mode In case no "dr_mode" property is ... Tue, 06 Feb 2018 08:28:02 GMT Sebastian Huber [b79c025] * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) dwc_otg: Add compatibility string, constify Support device tree of ... Mon, 05 Feb 2018 15:45:59 GMT Sebastian Huber [bcaa8a2] * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) dw_mmc: Properly init/reset DMA Mon, 05 Feb 2018 15:45:20 GMT Sebastian Huber [138bf25] * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) dw_mmc: Add MMCBR_IVAR_TIMING Mon, 05 Feb 2018 12:57:11 GMT Sebastian Huber [c30fa94] * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/mii/micphy.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (added) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.h (added) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) * rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c (deleted) Add device tree support for Altera/Intel Cyclone V Close #3290. Mon, 05 Feb 2018 11:05:52 GMT Sebastian Huber [9906c4a] * testsuite/swi01/init.c (modified) * testsuite/timeout01/init.c (modified) tests: Fix configuration dependencies Wed, 29 Nov 2017 14:26:17 GMT Sebastian Huber [0f9258f] * rtemsbsd/powerpc/include/linux/percpu.h (modified) linux/percpu.h: Fix for uni-processor config Mon, 15 Jan 2018 13:41:58 GMT Sebastian Huber [a0633c5] * freebsd/sys/kern/subr_sleepqueue.c (modified) SLEEPQUEUE(9): Update due to API changes Update #3264. Mon, 08 Jan 2018 12:55:36 GMT Sebastian Huber [8b3da13] * rtemsbsd/rtems/rtems-kernel-termioskqueuepoll.c (modified) termios: Update due to API changes Update #2843. Thu, 11 Jan 2018 13:30:49 GMT Sebastian Huber [327f4e1] * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_macless.c (modified) sdk_dpaa: What to do with tail queue drop? The issue is this: ... Wed, 17 Jan 2018 12:28:45 GMT Sebastian Huber [d62a3df] * libbsd.py (modified) * libbsd_waf.py (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_base.c (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_base.h (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_common.h (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_macless.c (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_trace.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/fm_ext.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/lnxwrp_fsl_fman.h (added) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/powerpc/include/linux/fsl_bman.h (added) * rtemsbsd/powerpc/include/linux/fsl_qman.h (added) * rtemsbsd/powerpc/include/linux/highmem.h (added) * rtemsbsd/powerpc/include/linux/net_tstamp.h (added) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/sdk_dpaa/if_ml.c (added) sdk_dpaa: Port to RTEMS Update #3277. Fri, 27 Oct 2017 09:50:01 GMT Sebastian Huber [f5ed3aa] * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_base.c (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_base.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_common.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_macless.c (added) sdk_dpaa: Import from QorIQ SDK Linux ... Wed, 10 Jan 2018 14:08:19 GMT Sebastian Huber [0f6ff4a] * linux/drivers/soc/fsl/qbman/qman_ccsr.c (modified) * linux/drivers/soc/fsl/qbman/qman_portal.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_dpaa.h (modified) dpaa: QMan portal only initialization Update #3277. Fri, 12 Jan 2018 12:22:10 GMT Sebastian Huber [a7d252c] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/soc/fsl/qbman/bman.c (modified) * linux/include/soc/fsl/bman.h (modified) dpaa: Add and use bman_new_pool_for_bpid() Update #3277. Wed, 10 Jan 2018 12:19:01 GMT Sebastian Huber [95fe5b1] * linux/drivers/soc/fsl/qbman/bman_ccsr.c (modified) dpaa: Use device tree throughout in BMan init Update #3277. Wed, 17 Jan 2018 12:49:44 GMT Sebastian Huber [1342fad0] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_dpaa.h (modified) dpaa: Add and use SDK_DPAA_COMPAT_STATIC Update #3277. Tue, 09 Jan 2018 10:45:31 GMT Sebastian Huber [34b7ccc] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (modified) dpaa: Support FQ_TYPE_RX_PCD Update #3277. Fri, 12 Jan 2018 12:23:24 GMT Sebastian Huber [bdf99316] * linux/drivers/soc/fsl/qbman/bman.c (modified) dpaa: Disable unused bman_pool members Update #3277. Tue, 23 Jan 2018 09:48:19 GMT Sebastian Huber [2fba1e4] * rtemsbsd/include/rtems/bsd/local/opt_dpaa.h (modified) dpaa: Remove unused configuration defines Update #3277. Wed, 10 Jan 2018 13:11:57 GMT Sebastian Huber [cfc149b] * rtemsbsd/sys/powerpc/compat.c (modified) linux/of_irq.h: Generalize of_irq_to_resource() Determine interrupt ... Wed, 17 Jan 2018 13:30:44 GMT Sebastian Huber [e4923c8] * linux/drivers/net/ethernet/freescale/fman/fman.c (modified) * linux/drivers/soc/fsl/qbman/qman_ccsr.c (modified) * rtemsbsd/powerpc/include/linux/device.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of_address.h: of_address_to_resource() Translate address in ... Wed, 10 Jan 2018 12:18:05 GMT Sebastian Huber [0f1d2f6] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/powerpc/include/linux/of_address.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of_address.h: Add of_translate_address() Update #3277. Wed, 17 Jan 2018 13:14:30 GMT Sebastian Huber [81fc57d] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of.h: Add of_find_node_by_path() Update #3277. Wed, 17 Jan 2018 13:14:10 GMT Sebastian Huber [44fca38] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of.h: Add of_read_number() Update #3277. Wed, 17 Jan 2018 13:13:53 GMT Sebastian Huber [26ce2ac] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of.h: Add of_n_size_cells() Update #3277. Wed, 17 Jan 2018 13:13:34 GMT Sebastian Huber [0d421d8] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of.h: Add of_n_addr_cells() Update #3277. Wed, 17 Jan 2018 12:26:11 GMT Sebastian Huber [066b536] * rtemsbsd/powerpc/include/linux/sort.h (added) linux/sort.h: New file Update #3277. Tue, 16 Jan 2018 12:07:36 GMT Sebastian Huber [583216a] * rtemsbsd/powerpc/include/linux/smp.h (modified) linux/smp.h: Avoid function call overhead Update #3277.
