# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 04/20/24 02:01:08 Wed, 22 Aug 2018 12:59:50 GMT Sebastian Huber [3489e3b] * Makefile.todo (modified) * freebsd-org (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/wpa/src/ap/ap_config.h (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.c (modified) * freebsd/contrib/wpa/src/ap/ap_drv_ops.h (modified) * freebsd/contrib/wpa/src/ap/hostapd.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11_auth.h (modified) * freebsd/contrib/wpa/src/ap/ieee802_11_shared.c (modified) * freebsd/contrib/wpa/src/ap/pmksa_cache_auth.h (modified) * freebsd/contrib/wpa/src/ap/sta_info.h (modified) * freebsd/contrib/wpa/src/ap/vlan.h (added) * freebsd/contrib/wpa/src/ap/wpa_auth.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_ft.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_i.h (modified) * freebsd/contrib/wpa/src/common/ctrl_iface_common.c (added) * freebsd/contrib/wpa/src/common/ctrl_iface_common.h (added) * freebsd/contrib/wpa/src/common/defs.h (modified) * freebsd/contrib/wpa/src/common/eapol_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.c (modified) * freebsd/contrib/wpa/src/common/ieee802_11_common.h (modified) * freebsd/contrib/wpa/src/common/ieee802_11_defs.h (modified) * freebsd/contrib/wpa/src/common/qca-vendor.h (modified) * freebsd/contrib/wpa/src/common/sae.h (modified) * freebsd/contrib/wpa/src/common/version.h (modified) * freebsd/contrib/wpa/src/common/wpa_common.c (modified) * freebsd/contrib/wpa/src/common/wpa_common.h (modified) * freebsd/contrib/wpa/src/common/wpa_ctrl.h (modified) * freebsd/contrib/wpa/src/crypto/aes-omac1.c (modified) * freebsd/contrib/wpa/src/crypto/crypto.h (modified) * freebsd/contrib/wpa/src/crypto/crypto_openssl.c (modified) * freebsd/contrib/wpa/src/crypto/ms_funcs.c (modified) * freebsd/contrib/wpa/src/crypto/sha256-internal.c (modified) * freebsd/contrib/wpa/src/crypto/sha256-prf.c (modified) * freebsd/contrib/wpa/src/crypto/sha256.h (modified) * freebsd/contrib/wpa/src/crypto/tls.h (modified) * freebsd/contrib/wpa/src/crypto/tls_internal.c (modified) * freebsd/contrib/wpa/src/drivers/driver.h (modified) * freebsd/contrib/wpa/src/drivers/driver_bsd.c (modified) * freebsd/contrib/wpa/src/drivers/driver_common.c (modified) * freebsd/contrib/wpa/src/drivers/driver_ndis.c (modified) * freebsd/contrib/wpa/src/drivers/driver_nl80211.h (modified) * freebsd/contrib/wpa/src/drivers/driver_wired.c (modified) * freebsd/contrib/wpa/src/drivers/drivers.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_config.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_gtc.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_i.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_leap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_md5.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_methods.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_methods.h (modified) * freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_otp.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_peap.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_psk.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c (modified) * freebsd/contrib/wpa/src/eap_peer/eap_ttls.c (modified) * freebsd/contrib/wpa/src/eap_server/eap_methods.h (modified) * freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c (modified) * freebsd/contrib/wpa/src/p2p/p2p.h (modified) * freebsd/contrib/wpa/src/radius/radius.h (modified) * freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c (modified) * freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h (modified) * freebsd/contrib/wpa/src/rsn_supp/preauth.c (modified) * freebsd/contrib/wpa/src/rsn_supp/preauth.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_i.h (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c (modified) * freebsd/contrib/wpa/src/tls/tlsv1_client.h (modified) * freebsd/contrib/wpa/src/tls/tlsv1_cred.h (modified) * freebsd/contrib/wpa/src/utils/common.c (modified) * freebsd/contrib/wpa/src/utils/common.h (modified) * freebsd/contrib/wpa/src/utils/eloop.c (modified) * freebsd/contrib/wpa/src/utils/eloop.h (modified) * freebsd/contrib/wpa/src/utils/module_tests.h (added) * freebsd/contrib/wpa/src/utils/os.h (modified) * freebsd/contrib/wpa/src/utils/os_unix.c (modified) * freebsd/contrib/wpa/src/utils/platform.h (modified) * freebsd/contrib/wpa/src/utils/trace.h (modified) * freebsd/contrib/wpa/src/utils/wpa_debug.c (modified) * freebsd/contrib/wpa/src/utils/wpabuf.c (modified) * freebsd/contrib/wpa/src/utils/wpabuf.h (modified) * freebsd/contrib/wpa/src/wps/wps.c (modified) * freebsd/contrib/wpa/src/wps/wps.h (modified) * freebsd/contrib/wpa/src/wps/wps_attr_build.c (modified) * freebsd/contrib/wpa/src/wps/wps_attr_parse.c (modified) * freebsd/contrib/wpa/src/wps/wps_attr_process.c (modified) * freebsd/contrib/wpa/src/wps/wps_common.c (modified) * freebsd/contrib/wpa/src/wps/wps_defs.h (modified) * freebsd/contrib/wpa/src/wps/wps_enrollee.c (modified) * freebsd/contrib/wpa/src/wps/wps_i.h (modified) * freebsd/contrib/wpa/src/wps/wps_registrar.c (modified) * freebsd/contrib/wpa/src/wps/wps_upnp.c (modified) * freebsd/contrib/wpa/src/wps/wps_upnp.h (modified) * freebsd/contrib/wpa/src/wps/wps_upnp_i.h (modified) * freebsd/contrib/wpa/src/wps/wps_upnp_ssdp.c (modified) * freebsd/contrib/wpa/src/wps/wps_upnp_web.c (modified) * freebsd/contrib/wpa/wpa_supplicant/ap.h (modified) * freebsd/contrib/wpa/wpa_supplicant/autoscan.h (modified) * freebsd/contrib/wpa/wpa_supplicant/bgscan.h (modified) * freebsd/contrib/wpa/wpa_supplicant/binder/binder.h (added) * freebsd/contrib/wpa/wpa_supplicant/bss.c (modified) * freebsd/contrib/wpa/wpa_supplicant/bss.h (modified) * freebsd/contrib/wpa/wpa_supplicant/config.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config.h (modified) * freebsd/contrib/wpa/wpa_supplicant/config_file.c (modified) * freebsd/contrib/wpa/wpa_supplicant/config_ssid.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface_unix.c (modified) * freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_new.h (modified) * freebsd/contrib/wpa/wpa_supplicant/driver_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/events.c (modified) * freebsd/contrib/wpa/wpa_supplicant/gas_query.c (modified) * freebsd/contrib/wpa/wpa_supplicant/gas_query.h (modified) * freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ibss_rsn.h (modified) * freebsd/contrib/wpa/wpa_supplicant/interworking.c (modified) * freebsd/contrib/wpa/wpa_supplicant/interworking.h (modified) * freebsd/contrib/wpa/wpa_supplicant/main.c (modified) * freebsd/contrib/wpa/wpa_supplicant/mesh.h (modified) * freebsd/contrib/wpa/wpa_supplicant/mesh_mpm.h (modified) * freebsd/contrib/wpa/wpa_supplicant/mesh_rsn.h (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.c (modified) * freebsd/contrib/wpa/wpa_supplicant/notify.h (modified) * freebsd/contrib/wpa/wpa_supplicant/offchannel.c (modified) * freebsd/contrib/wpa/wpa_supplicant/p2p_supplicant.h (modified) * freebsd/contrib/wpa/wpa_supplicant/scan.c (modified) * freebsd/contrib/wpa/wpa_supplicant/scan.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wmm_ac.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.h (modified) * freebsd/crypto/openssl/crypto/asn1/a_bool.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_object.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_strex.c (modified) * freebsd/crypto/openssl/crypto/asn1/ameth_lib.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1.h (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_err.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_enc.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_log.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_mem.c (modified) * freebsd/crypto/openssl/crypto/bn/bn.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_div.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_gf2m.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lcl.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mod.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mont.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_sqr.c (modified) * freebsd/crypto/openssl/crypto/bn_int.h (added) * freebsd/crypto/openssl/crypto/conf/conf_api.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_pmeth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa.h (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_err.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_gen.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_ameth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256.c (modified) * freebsd/crypto/openssl/crypto/ecdsa/ecdsatest.c (modified) * freebsd/crypto/openssl/crypto/ecdsa/ecs_ossl.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_lib.c (modified) * freebsd/crypto/openssl/crypto/engine/tb_asnmth.c (modified) * freebsd/crypto/openssl/crypto/o_time.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/pem/pem.h (modified) * freebsd/crypto/openssl/crypto/pem/pem_lib.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pk8.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pkey.c (modified) * freebsd/crypto/openssl/crypto/pem/pvkfmt.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_asn.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_eay.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_oaep.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pk1.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_sign.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ssl.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_cmp.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vfy.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_purp.c (modified) * freebsd/crypto/openssl/ssl/d1_both.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/s3_srvr.c (modified) * freebsd/crypto/openssl/ssl/ssl.h (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/crypto/openssl/ssl/t1_trce.c (modified) * freebsd/include/nl_types.h (added) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/gen/sethostname.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/include/un-namespace.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libcapsicum/capsicum_helpers.h (added) * freebsd/lib/libcasper/libcasper/libcasper.h (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/lib/libutil/libutil.h (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/privsep.c (modified) * freebsd/sbin/dhclient/privsep.h (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.h (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/pfctl_altq.c (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/pfctl/pfctl_parser.h (modified) * freebsd/sbin/pfctl/pfctl_qstats.c (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-namespace.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-parse-data.h (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/mmc/mmc.h (modified) * freebsd/sys/contrib/ck/include/ck_pr.h (modified) * freebsd/sys/contrib/ck/include/ck_queue.h (modified) * freebsd/sys/contrib/ck/include/gcc/ppc/ck_pr.h (modified) * freebsd/sys/contrib/ck/include/gcc/x86/ck_pr.h (modified) * freebsd/sys/contrib/ck/include/gcc/x86_64/ck_pr.h (modified) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna32.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/crypto_verify/sodium/verify.c (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/crypto_onetimeauth_poly1305.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/crypto_verify_16.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/crypto_verify_32.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/crypto_verify_64.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/export.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/private/common.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/private/implementations.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/randombytes.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/runtime.h (added) * freebsd/sys/contrib/libsodium/src/libsodium/include/sodium/utils.h (added) * freebsd/sys/crypto/chacha20/chacha.c (modified) * freebsd/sys/crypto/chacha20/chacha.h (modified) * freebsd/sys/crypto/libsodium/utils.c (added) * freebsd/sys/crypto/sha2/sha224.h (added) * freebsd/sys/crypto/sha2/sha256c.c (modified) * freebsd/sys/crypto/sha2/sha512c.c (modified) * freebsd/sys/crypto/skein/skein.c (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/evdev/cdev.c (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev.h (modified) * freebsd/sys/dev/evdev/evdev_utils.c (modified) * freebsd/sys/dev/evdev/input-event-codes.h (modified) * freebsd/sys/dev/evdev/input.h (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/kbd/kbd.c (modified) * freebsd/sys/dev/kbd/kbdreg.h (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcbrvar.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofw_subr.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_reg.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au.h (modified) * freebsd/sys/dev/rtwn/rtl8812a/usb/r12au_init.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au.h (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8821a/usb/r21au_init.c (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_gtaskqueue.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/net/altq/altq.h (modified) * freebsd/sys/net/altq/altq_cbq.c (modified) * freebsd/sys/net/altq/altq_cbq.h (modified) * freebsd/sys/net/altq/altq_codel.c (modified) * freebsd/sys/net/altq/altq_codel.h (modified) * freebsd/sys/net/altq/altq_fairq.c (modified) * freebsd/sys/net/altq/altq_fairq.h (modified) * freebsd/sys/net/altq/altq_hfsc.c (modified) * freebsd/sys/net/altq/altq_hfsc.h (modified) * freebsd/sys/net/altq/altq_priq.c (modified) * freebsd/sys/net/altq/altq_priq.h (modified) * freebsd/sys/net/altq/altq_subr.c (modified) * freebsd/sys/net/altq/altq_var.h (modified) * freebsd/sys/net/altq/if_altq.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bpf_jitter.h (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gif.h (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/route_var.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_fib.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_gif.h (deleted) * freebsd/sys/netinet/in_kdtrace.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/pim_var.h (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_asconf.h (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_dtrace_define.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_peeloff.c (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_hpts.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_log_buf.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udplite.h (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_fib.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/pim6_var.h (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/scope6_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/pf/if_pflog.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_altq.h (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/_cryptodev.h (added) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/cryptosoft.h (modified) * freebsd/sys/opencrypto/xform_auth.h (modified) * freebsd/sys/opencrypto/xform_md5.c (modified) * freebsd/sys/opencrypto/xform_poly1305.c (added) * freebsd/sys/opencrypto/xform_poly1305.h (added) * freebsd/sys/opencrypto/xform_rmd160.c (modified) * freebsd/sys/opencrypto/xform_sha1.c (modified) * freebsd/sys/opencrypto/xform_sha2.c (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/cpu.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mouse.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/nv.h (modified) * freebsd/sys/sys/pciio.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/sglist.h (added) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/cryptodev_if.h (modified) * rtemsbsd/include/rtems/bsd/local/sdhci_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/include/sys/boot.h (added) * rtemsbsd/include/sys/epoch.h (modified) * rtemsbsd/include/sys/kpilite.h (added) * rtemsbsd/include/vm/vm_pager.h (added) * rtemsbsd/local/cryptodev_if.c (modified) * rtemsbsd/local/ifdi_if.c (modified) * rtemsbsd/local/sdhci_if.c (modified) * rtemsbsd/rtems/rtems-kernel-epoch.c (modified) * rtemsbsd/sys/arm/at91/at91_mci.c (moved) * rtemsbsd/sys/arm/at91/at91_mcireg.h (moved) * rtemsbsd/sys/arm/at91/at91_pdcreg.h (moved) * rtemsbsd/sys/arm/at91/at91reg.h (moved) * rtemsbsd/sys/arm/at91/at91var.h (moved) * testsuite/epoch01/test_main.c (modified) Update to FreeBSD head 2018-09-17 Git mirror commit ... Wed, 12 Sep 2018 07:16:44 GMT Sebastian Huber [3becda1] * freebsd/sys/contrib/ck/include/ck_md.h (modified) ck: Define CK_MD_PPC32_LWSYNC if available This is option has a ... Mon, 10 Sep 2018 13:06:07 GMT Sebastian Huber [baf1ca7] * freebsd/sys/contrib/ck/include/gcc/ck_pr.h (modified) ck: Use atomic built-ins Update #3472. Tue, 21 Aug 2018 11:47:02 GMT Sebastian Huber [bcdce02] * freebsd-org (modified) * freebsd/contrib/libpcap/bpf_image.c (modified) * freebsd/contrib/libpcap/diag-control.h (added) * freebsd/contrib/libpcap/etherent.c (modified) * freebsd/contrib/libpcap/extract.h (modified) * freebsd/contrib/libpcap/fad-getad.c (modified) * freebsd/contrib/libpcap/fad-helpers.c (deleted) * freebsd/contrib/libpcap/fmtutils.c (added) * freebsd/contrib/libpcap/fmtutils.h (added) * freebsd/contrib/libpcap/ftmacros.h (added) * freebsd/contrib/libpcap/gencode.c (modified) * freebsd/contrib/libpcap/gencode.h (modified) * freebsd/contrib/libpcap/grammar.c (modified) * freebsd/contrib/libpcap/grammar.y (modified) * freebsd/contrib/libpcap/ieee80211.h (modified) * freebsd/contrib/libpcap/inet.c (deleted) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/optimize.c (modified) * freebsd/contrib/libpcap/optimize.h (added) * freebsd/contrib/libpcap/pcap-bpf.c (modified) * freebsd/contrib/libpcap/pcap-common.c (modified) * freebsd/contrib/libpcap/pcap-common.h (modified) * freebsd/contrib/libpcap/pcap-int.h (modified) * freebsd/contrib/libpcap/pcap-types.h (added) * freebsd/contrib/libpcap/pcap.c (modified) * freebsd/contrib/libpcap/pcap/can_socketcan.h (modified) * freebsd/contrib/libpcap/pcap/compiler-tests.h (added) * freebsd/contrib/libpcap/pcap/export-defs.h (deleted) * freebsd/contrib/libpcap/pcap/funcattrs.h (added) * freebsd/contrib/libpcap/pcap/namedb.h (modified) * freebsd/contrib/libpcap/pcap/nflog.h (modified) * freebsd/contrib/libpcap/pcap/pcap-inttypes.h (added) * freebsd/contrib/libpcap/pcap/pcap.h (modified) * freebsd/contrib/libpcap/pcap/sll.h (modified) * freebsd/contrib/libpcap/pcap/usb.h (modified) * freebsd/contrib/libpcap/portability.h (modified) * freebsd/contrib/libpcap/savefile.c (modified) * freebsd/contrib/libpcap/scanner.c (modified) * freebsd/contrib/libpcap/scanner.h (modified) * freebsd/contrib/libpcap/scanner.l (modified) * freebsd/contrib/libpcap/sf-pcap.c (modified) * freebsd/contrib/libpcap/sf-pcapng.c (moved) * freebsd/contrib/libpcap/sf-pcapng.h (moved) * freebsd/contrib/libpcap/varattrs.h (added) * freebsd/contrib/libxo/libxo/libxo.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/lib/libc/db/mpool/mpool-compat.c (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifconfig.h (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmedia-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-namespace.h (modified) * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-namespace.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl-data.h (modified) * freebsd/sys/arm/at91/at91_mci.c (modified) * freebsd/sys/arm/at91/at91_mcireg.h (modified) * freebsd/sys/arm/at91/at91_pdcreg.h (modified) * freebsd/sys/arm/ti/am335x/am335x_prcm.c (modified) * freebsd/sys/arm/ti/ti_hwmods.c (modified) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/contrib/ck/include/ck_backoff.h (added) * freebsd/sys/contrib/ck/include/ck_cc.h (added) * freebsd/sys/contrib/ck/include/ck_epoch.h (added) * freebsd/sys/contrib/ck/include/ck_limits.h (added) * freebsd/sys/contrib/ck/include/ck_md.h (added) * freebsd/sys/contrib/ck/include/ck_pr.h (added) * freebsd/sys/contrib/ck/include/ck_queue.h (added) * freebsd/sys/contrib/ck/include/ck_stack.h (added) * freebsd/sys/contrib/ck/include/ck_stdbool.h (added) * freebsd/sys/contrib/ck/include/ck_stddef.h (added) * freebsd/sys/contrib/ck/include/ck_stdint.h (added) * freebsd/sys/contrib/ck/include/ck_string.h (added) * freebsd/sys/contrib/ck/include/gcc/aarch64/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/arm/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/arm/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ck_cc.h (added) * freebsd/sys/contrib/ck/include/gcc/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ppc/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ppc/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ppc64/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/ppc64/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/sparcv9/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/sparcv9/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/x86/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/x86/ck_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/x86_64/ck_f_pr.h (added) * freebsd/sys/contrib/ck/include/gcc/x86_64/ck_pr.h (added) * freebsd/sys/contrib/ck/src/ck_epoch.c (added) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.c (modified) * freebsd/sys/dev/e1000/e1000_82571.c (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_i210.c (modified) * freebsd/sys/dev/e1000/e1000_i210.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_mac.c (modified) * freebsd/sys/dev/e1000/e1000_mac.h (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/em_txrx.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/igb_txrx.c (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/evdev/uinput.h (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/fdt/fdt_common.h (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * freebsd/sys/dev/ofw/openfirm.h (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/usb_rdesc.h (modified) * freebsd/sys/dev/usb/net/if_aue.c (modified) * freebsd/sys/dev/usb/net/if_axe.c (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/net/if_cue.c (modified) * freebsd/sys/dev/usb/net/if_kue.c (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/net/if_rue.c (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_udav.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.h (modified) * freebsd/sys/dev/usb/serial/uchcom.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.h (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_gtaskqueue.c (added) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_inq.c (modified) * freebsd/sys/kern/tty_outq.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/net/altq/altq_subr.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/dlt.h (modified) * freebsd/sys/net/fddi.h (deleted) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_arc.h (deleted) * freebsd/sys/net/if_arcsubr.c (deleted) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_bridgevar.h (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (deleted) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/netdump/netdump.h (added) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_hpts.h (added) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_offload.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/toecore.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/ck.h (added) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/cons.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/gtaskqueue.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * libbsd.py (modified) * linux/drivers/net/ethernet/freescale/fman/mac.c (modified) * rtemsbsd/include/machine/atomic.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/sys/disk_zone.h (added) * rtemsbsd/include/sys/epoch.h (added) * rtemsbsd/rtems/rtems-kernel-epoch.c (added) * rtemsbsd/rtems/rtems-kernel-jail.c (modified) * rtemsbsd/sys/arm/lpc/if_lpe.c (modified) * testsuite/epoch01/epoch01.py (added) * testsuite/epoch01/epoch01.scn (added) * testsuite/epoch01/test_main.c (added) Update to FreeBSD head 2018-06-01 Git mirror commit ... Tue, 21 Aug 2018 07:39:55 GMT Sebastian Huber [2df56db] * freebsd-org (modified) * freebsd/crypto/openssl/crypto/asn1/a_gentm.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_mbstr.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_object.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_strex.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_time.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_utctm.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1.h (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_err.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_lib.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_par.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn_mime.c (modified) * freebsd/crypto/openssl/crypto/asn1/t_x509a.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_dec.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_prn.c (modified) * freebsd/crypto/openssl/crypto/bf/bftest.c (modified) * freebsd/crypto/openssl/crypto/bio/b_dump.c (modified) * freebsd/crypto/openssl/crypto/bio/b_print.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_cb.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_bio.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_conn.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_file.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mont.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_print.c (modified) * freebsd/crypto/openssl/crypto/bn/bntest.c (modified) * freebsd/crypto/openssl/crypto/bn/expspeed.c (modified) * freebsd/crypto/openssl/crypto/bn/exptest.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_def.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_mod.c (modified) * freebsd/crypto/openssl/crypto/des/ecb_enc.c (modified) * freebsd/crypto/openssl/crypto/des/fcrypt.c (modified) * freebsd/crypto/openssl/crypto/des/read_pwd.c (modified) * freebsd/crypto/openssl/crypto/des/set_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dhtest.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsatest.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_lib.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_mult.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistz256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_smpl.c (modified) * freebsd/crypto/openssl/crypto/ec/ectest.c (modified) * freebsd/crypto/openssl/crypto/ecdh/ecdhtest.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_cryptodev.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_table.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/err/err_prn.c (modified) * freebsd/crypto/openssl/crypto/evp/bio_b64.c (modified) * freebsd/crypto/openssl/crypto/evp/digest.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_camellia.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_enc.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_locl.h (modified) * freebsd/crypto/openssl/crypto/evp/evp_pbe.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_test.c (modified) * freebsd/crypto/openssl/crypto/evp/openbsd_hw.c (modified) * freebsd/crypto/openssl/crypto/evp/p5_crpt2.c (modified) * freebsd/crypto/openssl/crypto/hmac/hmac.c (modified) * freebsd/crypto/openssl/crypto/md4/md4.c (modified) * freebsd/crypto/openssl/crypto/mem_dbg.c (modified) * freebsd/crypto/openssl/crypto/o_init.c (modified) * freebsd/crypto/openssl/crypto/o_time.c (modified) * freebsd/crypto/openssl/crypto/objects/o_names.c (modified) * freebsd/crypto/openssl/crypto/objects/obj_dat.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/pem/pem_info.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_lib.c (modified) * freebsd/crypto/openssl/crypto/pkcs7/pk7_doit.c (modified) * freebsd/crypto/openssl/crypto/rand/md_rand.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_egd.c (modified) * freebsd/crypto/openssl/crypto/rand/rand_unix.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_crpt.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pss.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_test.c (modified) * freebsd/crypto/openssl/crypto/srp/srp_grps.h (modified) * freebsd/crypto/openssl/crypto/threads/mttest.c (modified) * freebsd/crypto/openssl/crypto/ts/ts_rsp_sign.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_openssl.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_txt.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_v3.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_vpm.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_alt.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_conf.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_info.c (modified) * freebsd/crypto/openssl/engines/ccgost/gost_eng.c (modified) * freebsd/crypto/openssl/engines/e_atalla.c (modified) * freebsd/crypto/openssl/ssl/bad_dtls_test.c (modified) * freebsd/crypto/openssl/ssl/d1_lib.c (modified) * freebsd/crypto/openssl/ssl/d1_pkt.c (modified) * freebsd/crypto/openssl/ssl/kssl.c (modified) * freebsd/crypto/openssl/ssl/s23_srvr.c (modified) * freebsd/crypto/openssl/ssl/s2_clnt.c (modified) * freebsd/crypto/openssl/ssl/s2_enc.c (modified) * freebsd/crypto/openssl/ssl/s2_lib.c (modified) * freebsd/crypto/openssl/ssl/s2_srvr.c (modified) * freebsd/crypto/openssl/ssl/s3_clnt.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/s3_pkt.c (modified) * freebsd/crypto/openssl/ssl/s3_srvr.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/ssltest.c (modified) * freebsd/crypto/openssl/ssl/t1_enc.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/crypto/openssl/ssl/t1_trce.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/rpc/svc_dg.c (modified) * freebsd/lib/libcasper/libcasper/libcasper.h (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/dhclient/errwarn.c (modified) * freebsd/sbin/dhclient/hash.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/privsep.c (modified) * freebsd/sbin/dhclient/privsep.h (modified) * freebsd/sbin/dhclient/tables.c (modified) * freebsd/sbin/dhclient/tree.h (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/contrib/libb2/blake2-impl.h (added) * freebsd/sys/contrib/libb2/blake2.h (added) * freebsd/sys/contrib/libb2/blake2b-ref.c (added) * freebsd/sys/contrib/libb2/blake2s-ref.c (added) * freebsd/sys/crypto/blake2/blake2-sw.c (added) * freebsd/sys/crypto/chacha20/chacha-sw.c (added) * freebsd/sys/crypto/chacha20/chacha.c (added) * freebsd/sys/crypto/chacha20/chacha.h (added) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_mbx.c (modified) * freebsd/sys/dev/e1000/e1000_phy.c (modified) * freebsd/sys/dev/e1000/e1000_vf.c (modified) * freebsd/sys/dev/e1000/em_txrx.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/gpio/gpiobusvar.h (modified) * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofw_subr.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/rtwn/if_rtwn_ridx.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/usb/controller/musb_otg.c (modified) * freebsd/sys/dev/usb/controller/musb_otg.h (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/wsp.c (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/serial/uftdi.c (modified) * freebsd/sys/dev/usb/serial/uslcom.c (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_upgt.c (modified) * freebsd/sys/dev/usb/wlan/if_ural.c (modified) * freebsd/sys/dev/usb/wlan/if_urtw.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_ipsec.c (modified) * freebsd/sys/net/if_iso88025subr.c (deleted) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/iso88025.h (deleted) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/cc/cc.h (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/cc/cc_newreno.h (added) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/tcp_fastopen.h (added) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_log_buf.h (added) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/keysock.h (modified) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_private.h (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf.h (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/xform_auth.h (modified) * freebsd/sys/opencrypto/xform_enc.h (modified) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/aio.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/disk.h (added) * freebsd/sys/sys/domainset.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/ktr_class.h (modified) * freebsd/sys/sys/linker_set.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/priv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/seq.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-data.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-namespace.h (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/pci_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/include/sys/kerneldump.h (added) * rtemsbsd/local/pci_if.c (modified) Update to FreeBSD head 2018-04-01 Git mirror commit ... Mon, 20 Aug 2018 13:53:03 GMT Sebastian Huber [18fa92c] * freebsd-org (modified) * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/addrtoname.h (modified) * freebsd/contrib/tcpdump/addrtostr.c (modified) * freebsd/contrib/tcpdump/af.c (modified) * freebsd/contrib/tcpdump/af.h (modified) * freebsd/contrib/tcpdump/checksum.c (modified) * freebsd/contrib/tcpdump/extract.h (modified) * freebsd/contrib/tcpdump/funcattrs.h (added) * freebsd/contrib/tcpdump/gmpls.c (modified) * freebsd/contrib/tcpdump/gmpls.h (modified) * freebsd/contrib/tcpdump/ip6.h (modified) * freebsd/contrib/tcpdump/ipproto.c (modified) * freebsd/contrib/tcpdump/ipproto.h (modified) * freebsd/contrib/tcpdump/l2vpn.c (modified) * freebsd/contrib/tcpdump/l2vpn.h (modified) * freebsd/contrib/tcpdump/netdissect-stdinc.h (modified) * freebsd/contrib/tcpdump/netdissect.h (modified) * freebsd/contrib/tcpdump/nlpid.c (modified) * freebsd/contrib/tcpdump/nlpid.h (modified) * freebsd/contrib/tcpdump/oui.c (modified) * freebsd/contrib/tcpdump/oui.h (modified) * freebsd/contrib/tcpdump/print-802_11.c (modified) * freebsd/contrib/tcpdump/print-802_15_4.c (modified) * freebsd/contrib/tcpdump/print-aodv.c (modified) * freebsd/contrib/tcpdump/print-arp.c (modified) * freebsd/contrib/tcpdump/print-atm.c (modified) * freebsd/contrib/tcpdump/print-beep.c (modified) * freebsd/contrib/tcpdump/print-bfd.c (modified) * freebsd/contrib/tcpdump/print-bgp.c (modified) * freebsd/contrib/tcpdump/print-bootp.c (modified) * freebsd/contrib/tcpdump/print-cfm.c (modified) * freebsd/contrib/tcpdump/print-chdlc.c (modified) * freebsd/contrib/tcpdump/print-cnfp.c (modified) * freebsd/contrib/tcpdump/print-decnet.c (modified) * freebsd/contrib/tcpdump/print-dhcp6.c (modified) * freebsd/contrib/tcpdump/print-domain.c (modified) * freebsd/contrib/tcpdump/print-eap.c (modified) * freebsd/contrib/tcpdump/print-eigrp.c (modified) * freebsd/contrib/tcpdump/print-esp.c (modified) * freebsd/contrib/tcpdump/print-ether.c (modified) * freebsd/contrib/tcpdump/print-fr.c (modified) * freebsd/contrib/tcpdump/print-frag6.c (modified) * freebsd/contrib/tcpdump/print-gre.c (modified) * freebsd/contrib/tcpdump/print-hncp.c (modified) * freebsd/contrib/tcpdump/print-icmp.c (modified) * freebsd/contrib/tcpdump/print-icmp6.c (modified) * freebsd/contrib/tcpdump/print-ip.c (modified) * freebsd/contrib/tcpdump/print-ip6.c (modified) * freebsd/contrib/tcpdump/print-ip6opts.c (modified) * freebsd/contrib/tcpdump/print-isakmp.c (modified) * freebsd/contrib/tcpdump/print-isoclns.c (modified) * freebsd/contrib/tcpdump/print-juniper.c (modified) * freebsd/contrib/tcpdump/print-l2tp.c (modified) * freebsd/contrib/tcpdump/print-ldp.c (modified) * freebsd/contrib/tcpdump/print-llc.c (modified) * freebsd/contrib/tcpdump/print-lldp.c (modified) * freebsd/contrib/tcpdump/print-lmp.c (modified) * freebsd/contrib/tcpdump/print-lspping.c (modified) * freebsd/contrib/tcpdump/print-m3ua.c (modified) * freebsd/contrib/tcpdump/print-mobility.c (modified) * freebsd/contrib/tcpdump/print-mpcp.c (modified) * freebsd/contrib/tcpdump/print-mpls.c (modified) * freebsd/contrib/tcpdump/print-mptcp.c (modified) * freebsd/contrib/tcpdump/print-nfs.c (modified) * freebsd/contrib/tcpdump/print-null.c (modified) * freebsd/contrib/tcpdump/print-olsr.c (modified) * freebsd/contrib/tcpdump/print-ospf6.c (modified) * freebsd/contrib/tcpdump/print-pgm.c (modified) * freebsd/contrib/tcpdump/print-pim.c (modified) * freebsd/contrib/tcpdump/print-pktap.c (modified) * freebsd/contrib/tcpdump/print-ppp.c (modified) * freebsd/contrib/tcpdump/print-radius.c (modified) * freebsd/contrib/tcpdump/print-resp.c (modified) * freebsd/contrib/tcpdump/print-ripng.c (modified) * freebsd/contrib/tcpdump/print-rpki-rtr.c (modified) * freebsd/contrib/tcpdump/print-rsvp.c (modified) * freebsd/contrib/tcpdump/print-rt6.c (modified) * freebsd/contrib/tcpdump/print-rx.c (modified) * freebsd/contrib/tcpdump/print-sip.c (modified) * freebsd/contrib/tcpdump/print-sl.c (modified) * freebsd/contrib/tcpdump/print-slow.c (modified) * freebsd/contrib/tcpdump/print-stp.c (modified) * freebsd/contrib/tcpdump/print-syslog.c (modified) * freebsd/contrib/tcpdump/print-telnet.c (modified) * freebsd/contrib/tcpdump/print-tftp.c (modified) * freebsd/contrib/tcpdump/print-vqp.c (modified) * freebsd/contrib/tcpdump/print-vtp.c (modified) * freebsd/contrib/tcpdump/print-wb.c (modified) * freebsd/contrib/tcpdump/print-zephyr.c (modified) * freebsd/contrib/tcpdump/print.c (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-addrtoname-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-namespace.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-tcpdump-data.h (modified) * freebsd/contrib/tcpdump/signature.c (modified) * freebsd/contrib/tcpdump/signature.h (modified) * freebsd/contrib/tcpdump/smbutil.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/tcpdump/util-print.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_i2d_fp.c (modified) * freebsd/crypto/openssl/crypto/bio/b_print.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_fat.c (modified) * freebsd/crypto/openssl/crypto/lhash/lhash.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_gen.c (modified) * freebsd/crypto/openssl/crypto/symhacks.h (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_lib.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_scts.c (modified) * freebsd/crypto/openssl/ssl/bad_dtls_test.c (modified) * freebsd/crypto/openssl/ssl/s23_clnt.c (modified) * freebsd/crypto/openssl/ssl/s3_pkt.c (modified) * freebsd/crypto/openssl/ssl/srtp.h (modified) * freebsd/crypto/openssl/ssl/ssl.h (modified) * freebsd/crypto/openssl/ssl/ssltest.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/err.h (modified) * freebsd/include/ifaddrs.h (modified) * freebsd/include/netdb.h (modified) * freebsd/include/res_update.h (modified) * freebsd/include/resolv.h (modified) * freebsd/lib/libc/include/isc/eventlib.h (modified) * freebsd/lib/libc/include/isc/list.h (modified) * freebsd/lib/libc/include/isc/platform.h (modified) * freebsd/lib/libc/include/reentrant.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_cidr_ntop.c (modified) * freebsd/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd/lib/libc/inet/inet_net_ntop.c (modified) * freebsd/lib/libc/inet/inet_net_pton.c (modified) * freebsd/lib/libc/inet/inet_neta.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) * freebsd/lib/libc/inet/nsap_addr.c (modified) * freebsd/lib/libc/isc/ev_streams.c (modified) * freebsd/lib/libc/isc/ev_timers.c (modified) * freebsd/lib/libc/isc/eventlib_p.h (modified) * freebsd/lib/libc/nameser/ns_name.c (modified) * freebsd/lib/libc/nameser/ns_netint.c (modified) * freebsd/lib/libc/nameser/ns_parse.c (modified) * freebsd/lib/libc/nameser/ns_print.c (modified) * freebsd/lib/libc/nameser/ns_samedomain.c (modified) * freebsd/lib/libc/nameser/ns_ttl.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/getifaddrs.c (modified) * freebsd/lib/libc/net/if_indextoname.c (modified) * freebsd/lib/libc/net/if_nameindex.c (modified) * freebsd/lib/libc/net/if_nametoindex.c (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_debug.h (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_mkupdate.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_update.c (modified) * freebsd/lib/libcasper/libcasper/libcasper.h (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/inet.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/packet.c (modified) * freebsd/sbin/dhclient/parse.c (modified) * freebsd/sbin/dhclient/privsep.c (modified) * freebsd/sbin/dhclient/tree.c (modified) * freebsd/sbin/ifconfig/sfp.c (modified) * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/pfctl_optimize.c (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/mmc/mmc.h (modified) * freebsd/sys/cam/mmc/mmc_all.h (modified) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/cadence/if_cgem.c (modified) * freebsd/sys/dev/e1000/e1000_82543.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.h (modified) * freebsd/sys/dev/e1000/e1000_regs.h (modified) * freebsd/sys/dev/e1000/em_txrx.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/e1000/igb_txrx.c (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/net/if_cdce.c (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/wlan/if_rum.c (modified) * freebsd/sys/dev/usb/wlan/if_run.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_hash.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/altq/altq_hfsc.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/sff8472.h (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_reass.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_crc32.c (modified) * freebsd/sys/netinet/sctp_crc32.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netpfil/pf/if_pflog.c (modified) * freebsd/sys/netpfil/pf/in4_cksum.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf.h (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_osfp.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/opencrypto/xform_userland.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/_domainset.h (added) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/capsicum.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/domainset.h (added) * freebsd/sys/sys/gtaskqueue.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mouse.h (modified) * freebsd/sys/sys/nv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/rman.h (modified) * freebsd/sys/sys/sf_buf.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/tslog.h (added) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/watchdog.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/sys/x86/include/machine/bus.h (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/_limits.h (modified) * rtemsbsd/include/machine/atomic.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) * rtemsbsd/include/rtems/bsd/local/device_if.h (modified) * rtemsbsd/include/rtems/bsd/local/ifdi_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/include/vm/vm_phys.h (added) * rtemsbsd/rtems/rtems-kernel-malloc.c (modified) * rtemsbsd/sys/arm/lpc/if_lpe.c (moved) * rtemsbsd/sys/arm/lpc/if_lpereg.h (moved) * rtemsbsd/sys/arm/lpc/lpc_pwr.c (moved) * rtemsbsd/sys/arm/lpc/lpcreg.h (moved) * rtemsbsd/sys/arm/lpc/lpcvar.h (moved) Update to FreeBSD head 2018-02-01 Git mirror commit ... Thu, 09 Aug 2018 12:02:09 GMT Sebastian Huber [bb80d9d] * freebsd-org (modified) * freebsd/bin/hostname/hostname.c (modified) * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_bitstr.c (modified) * freebsd/crypto/openssl/crypto/asn1/asn1_int.h (added) * freebsd/crypto/openssl/crypto/asn1/tasn_fre.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_new.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_name.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_pkey.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_exp.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_lib.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mont.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_mul.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_x931p.c (modified) * freebsd/crypto/openssl/crypto/cryptlib.c (modified) * freebsd/crypto/openssl/crypto/dh/dh.h (modified) * freebsd/crypto/openssl/crypto/dh/dh_kdf.c (modified) * freebsd/crypto/openssl/crypto/dh/dh_pmeth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_gen.c (modified) * freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_mont.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c (modified) * freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c (modified) * freebsd/crypto/openssl/crypto/ecdh/ech_lib.c (modified) * freebsd/crypto/openssl/crypto/ecdsa/ecs_lib.c (modified) * freebsd/crypto/openssl/crypto/ecdsa/ecs_ossl.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c (modified) * freebsd/crypto/openssl/crypto/evp/evp.h (modified) * freebsd/crypto/openssl/crypto/evp/evp_key.c (modified) * freebsd/crypto/openssl/crypto/evp/pmeth_lib.c (modified) * freebsd/crypto/openssl/crypto/ex_data.c (modified) * freebsd/crypto/openssl/crypto/lhash/lhash.c (modified) * freebsd/crypto/openssl/crypto/ocsp/ocsp_vfy.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/pem/pem_lib.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pk8.c (modified) * freebsd/crypto/openssl/crypto/pem/pem_pkey.c (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_kiss.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_ameth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_oaep.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pk1.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_lib.c (modified) * freebsd/crypto/openssl/crypto/whrlpool/wp_dgst.c (modified) * freebsd/crypto/openssl/crypto/x509/by_dir.c (modified) * freebsd/crypto/openssl/crypto/x509/by_file.c (modified) * freebsd/crypto/openssl/crypto/x509v3/pcy_tree.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_addr.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_genn.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_ncons.c (modified) * freebsd/crypto/openssl/ssl/s23_clnt.c (modified) * freebsd/crypto/openssl/ssl/s3_pkt.c (modified) * freebsd/crypto/openssl/ssl/s3_srvr.c (modified) * freebsd/crypto/openssl/ssl/ssl_ciph.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/ssltest.c (modified) * freebsd/crypto/openssl/ssl/tls1.h (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/arpa/nameser_compat.h (modified) * freebsd/include/db.h (modified) * freebsd/include/err.h (modified) * freebsd/include/mpool.h (modified) * freebsd/include/netconfig.h (modified) * freebsd/include/netdb.h (modified) * freebsd/include/nlist.h (modified) * freebsd/include/nsswitch.h (modified) * freebsd/include/resolv.h (modified) * freebsd/include/rpc/auth.h (modified) * freebsd/include/rpc/auth_des.h (modified) * freebsd/include/rpc/auth_kerb.h (modified) * freebsd/include/rpc/auth_unix.h (modified) * freebsd/include/rpc/clnt.h (modified) * freebsd/include/rpc/clnt_soc.h (modified) * freebsd/include/rpc/des.h (modified) * freebsd/include/rpc/des_crypt.h (modified) * freebsd/include/rpc/nettype.h (modified) * freebsd/include/rpc/pmap_clnt.h (modified) * freebsd/include/rpc/pmap_prot.h (modified) * freebsd/include/rpc/pmap_rmt.h (modified) * freebsd/include/rpc/raw.h (modified) * freebsd/include/rpc/rpc.h (modified) * freebsd/include/rpc/rpc_com.h (modified) * freebsd/include/rpc/rpc_msg.h (modified) * freebsd/include/rpc/rpcb_clnt.h (modified) * freebsd/include/rpc/rpcent.h (modified) * freebsd/include/rpc/rpcsec_gss.h (modified) * freebsd/include/rpc/svc.h (modified) * freebsd/include/rpc/svc_auth.h (modified) * freebsd/include/rpc/svc_dg.h (modified) * freebsd/include/rpc/svc_soc.h (modified) * freebsd/include/rpc/xdr.h (modified) * freebsd/include/rpcsvc/nis_tags.h (modified) * freebsd/include/rpcsvc/yp_prot.h (modified) * freebsd/include/rpcsvc/ypclnt.h (modified) * freebsd/include/sysexits.h (modified) * freebsd/lib/libbsdstat/bsdstat.c (modified) * freebsd/lib/libbsdstat/bsdstat.h (modified) * freebsd/lib/libc/db/btree/bt_close.c (modified) * freebsd/lib/libc/db/btree/bt_conv.c (modified) * freebsd/lib/libc/db/btree/bt_debug.c (modified) * freebsd/lib/libc/db/btree/bt_delete.c (modified) * freebsd/lib/libc/db/btree/bt_get.c (modified) * freebsd/lib/libc/db/btree/bt_open.c (modified) * freebsd/lib/libc/db/btree/bt_overflow.c (modified) * freebsd/lib/libc/db/btree/bt_page.c (modified) * freebsd/lib/libc/db/btree/bt_put.c (modified) * freebsd/lib/libc/db/btree/bt_search.c (modified) * freebsd/lib/libc/db/btree/bt_seq.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/btree/bt_utils.c (modified) * freebsd/lib/libc/db/btree/btree.h (modified) * freebsd/lib/libc/db/btree/extern.h (modified) * freebsd/lib/libc/db/db/db.c (modified) * freebsd/lib/libc/db/mpool/mpool-compat.c (modified) * freebsd/lib/libc/db/mpool/mpool.c (modified) * freebsd/lib/libc/db/recno/extern.h (modified) * freebsd/lib/libc/db/recno/rec_close.c (modified) * freebsd/lib/libc/db/recno/rec_delete.c (modified) * freebsd/lib/libc/db/recno/rec_get.c (modified) * freebsd/lib/libc/db/recno/rec_open.c (modified) * freebsd/lib/libc/db/recno/rec_put.c (modified) * freebsd/lib/libc/db/recno/rec_search.c (modified) * freebsd/lib/libc/db/recno/rec_seq.c (modified) * freebsd/lib/libc/db/recno/rec_utils.c (modified) * freebsd/lib/libc/db/recno/recno.h (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/gen/feature_present.c (modified) * freebsd/lib/libc/gen/getdomainname.c (modified) * freebsd/lib/libc/gen/gethostname.c (modified) * freebsd/lib/libc/gen/sethostname.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/include/nss_tls.h (modified) * freebsd/lib/libc/include/reentrant.h (modified) * freebsd/lib/libc/include/spinlock.h (modified) * freebsd/lib/libc/include/un-namespace.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_lnaof.c (modified) * freebsd/lib/libc/inet/inet_makeaddr.c (modified) * freebsd/lib/libc/inet/inet_netof.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/net/ether_addr.c (modified) * freebsd/lib/libc/net/gai_strerror.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/gethostbyht.c (modified) * freebsd/lib/libc/net/gethostbynis.c (modified) * freebsd/lib/libc/net/gethostnamadr.c (modified) * freebsd/lib/libc/net/getifmaddrs.c (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/net/getnetbydns.c (modified) * freebsd/lib/libc/net/getnetbyht.c (modified) * freebsd/lib/libc/net/getnetbynis.c (modified) * freebsd/lib/libc/net/getnetnamadr.c (modified) * freebsd/lib/libc/net/getproto.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getprotoname.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/ip6opt.c (modified) * freebsd/lib/libc/net/linkaddr.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/net/netdb_private.h (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/net/nslexer.c (modified) * freebsd/lib/libc/net/nslexer.l (modified) * freebsd/lib/libc/net/nsparser.c (modified) * freebsd/lib/libc/net/nsparser.y (modified) * freebsd/lib/libc/net/nss_backends.h (modified) * freebsd/lib/libc/net/rcmd.c (modified) * freebsd/lib/libc/net/recv.c (modified) * freebsd/lib/libc/net/rthdr.c (modified) * freebsd/lib/libc/net/send.c (modified) * freebsd/lib/libc/net/vars.c (modified) * freebsd/lib/libc/posix1e/mac.c (modified) * freebsd/lib/libc/resolv/h_errno.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_state.c (modified) * freebsd/lib/libc/rpc/auth_des.c (modified) * freebsd/lib/libc/rpc/auth_none.c (modified) * freebsd/lib/libc/rpc/auth_unix.c (modified) * freebsd/lib/libc/rpc/authdes_prot.c (modified) * freebsd/lib/libc/rpc/authunix_prot.c (modified) * freebsd/lib/libc/rpc/bindresvport.c (modified) * freebsd/lib/libc/rpc/clnt_bcast.c (modified) * freebsd/lib/libc/rpc/clnt_dg.c (modified) * freebsd/lib/libc/rpc/clnt_generic.c (modified) * freebsd/lib/libc/rpc/clnt_perror.c (modified) * freebsd/lib/libc/rpc/clnt_raw.c (modified) * freebsd/lib/libc/rpc/clnt_simple.c (modified) * freebsd/lib/libc/rpc/clnt_vc.c (modified) * freebsd/lib/libc/rpc/crypt_client.c (modified) * freebsd/lib/libc/rpc/des_crypt.c (modified) * freebsd/lib/libc/rpc/des_soft.c (modified) * freebsd/lib/libc/rpc/getnetconfig.c (modified) * freebsd/lib/libc/rpc/getnetpath.c (modified) * freebsd/lib/libc/rpc/getpublickey.c (modified) * freebsd/lib/libc/rpc/getrpcent.c (modified) * freebsd/lib/libc/rpc/getrpcport.c (modified) * freebsd/lib/libc/rpc/key_call.c (modified) * freebsd/lib/libc/rpc/key_prot_xdr.c (modified) * freebsd/lib/libc/rpc/mt_misc.h (modified) * freebsd/lib/libc/rpc/netname.c (modified) * freebsd/lib/libc/rpc/netnamer.c (modified) * freebsd/lib/libc/rpc/pmap_clnt.c (modified) * freebsd/lib/libc/rpc/pmap_getmaps.c (modified) * freebsd/lib/libc/rpc/pmap_getport.c (modified) * freebsd/lib/libc/rpc/pmap_prot.c (modified) * freebsd/lib/libc/rpc/pmap_prot2.c (modified) * freebsd/lib/libc/rpc/pmap_rmt.c (modified) * freebsd/lib/libc/rpc/rpc_callmsg.c (modified) * freebsd/lib/libc/rpc/rpc_com.h (modified) * freebsd/lib/libc/rpc/rpc_commondata.c (modified) * freebsd/lib/libc/rpc/rpc_dtablesize.c (modified) * freebsd/lib/libc/rpc/rpc_generic.c (modified) * freebsd/lib/libc/rpc/rpc_prot.c (modified) * freebsd/lib/libc/rpc/rpc_soc.c (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/lib/libc/rpc/rpcb_prot.c (modified) * freebsd/lib/libc/rpc/rpcb_st_xdr.c (modified) * freebsd/lib/libc/rpc/rpcdname.c (modified) * freebsd/lib/libc/rpc/rpcsec_gss_stub.c (modified) * freebsd/lib/libc/rpc/rtime.c (modified) * freebsd/lib/libc/rpc/svc.c (modified) * freebsd/lib/libc/rpc/svc_auth.c (modified) * freebsd/lib/libc/rpc/svc_auth_des.c (modified) * freebsd/lib/libc/rpc/svc_auth_unix.c (modified) * freebsd/lib/libc/rpc/svc_dg.c (modified) * freebsd/lib/libc/rpc/svc_generic.c (modified) * freebsd/lib/libc/rpc/svc_raw.c (modified) * freebsd/lib/libc/rpc/svc_run.c (modified) * freebsd/lib/libc/rpc/svc_simple.c (modified) * freebsd/lib/libc/rpc/svc_vc.c (modified) * freebsd/lib/libc/stdio/fgetln.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libc/string/strsep.c (modified) * freebsd/lib/libc/xdr/xdr.c (modified) * freebsd/lib/libc/xdr/xdr_array.c (modified) * freebsd/lib/libc/xdr/xdr_float.c (modified) * freebsd/lib/libc/xdr/xdr_mem.c (modified) * freebsd/lib/libc/xdr/xdr_rec.c (modified) * freebsd/lib/libc/xdr/xdr_reference.c (modified) * freebsd/lib/libc/xdr/xdr_sizeof.c (modified) * freebsd/lib/libc/xdr/xdr_stdio.c (modified) * freebsd/lib/libcasper/libcasper/libcasper.h (added) * freebsd/lib/libcasper/services/cap_dns/cap_dns.h (added) * freebsd/lib/libcasper/services/cap_syslog/cap_syslog.h (added) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/lib/libmemstat/memstat.c (modified) * freebsd/lib/libmemstat/memstat.h (modified) * freebsd/lib/libmemstat/memstat_all.c (modified) * freebsd/lib/libmemstat/memstat_internal.h (modified) * freebsd/lib/libmemstat/memstat_malloc.c (modified) * freebsd/lib/libmemstat/memstat_uma.c (modified) * freebsd/lib/libutil/expand_number.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/lib/libutil/libutil.h (modified) * freebsd/lib/libutil/trimdomain.c (modified) * freebsd/sbin/dhclient/alloc.c (modified) * freebsd/sbin/dhclient/bpf.c (modified) * freebsd/sbin/dhclient/clparse.c (modified) * freebsd/sbin/dhclient/conflex.c (modified) * freebsd/sbin/dhclient/convert.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/dhcp.h (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/dhclient/dhctoken.h (modified) * freebsd/sbin/dhclient/dispatch.c (modified) * freebsd/sbin/dhclient/errwarn.c (modified) * freebsd/sbin/dhclient/hash.c (modified) * freebsd/sbin/dhclient/inet.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/packet.c (modified) * freebsd/sbin/dhclient/parse.c (modified) * freebsd/sbin/dhclient/tables.c (modified) * freebsd/sbin/dhclient/tree.c (modified) * freebsd/sbin/dhclient/tree.h (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifbridge.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifconfig.h (modified) * freebsd/sbin/ifconfig/ifgif.c (modified) * freebsd/sbin/ifconfig/ifgre.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/ifmac.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/ifconfig/ifvlan.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/pfctl/pf_print_state.c (modified) * freebsd/sbin/pfctl/pfctl.c (modified) * freebsd/sbin/pfctl/pfctl.h (modified) * freebsd/sbin/pfctl/pfctl_parser.c (modified) * freebsd/sbin/pfctl/pfctl_parser.h (modified) * freebsd/sbin/pfctl/pfctl_radix.c (modified) * freebsd/sbin/pfctl/pfctl_table.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/at91/at91_mci.c (modified) * freebsd/sys/arm/at91/at91_mcireg.h (modified) * freebsd/sys/arm/at91/at91_pdcreg.h (modified) * freebsd/sys/arm/at91/at91reg.h (modified) * freebsd/sys/arm/at91/at91var.h (modified) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/arm/include/machine/in_cksum.h (modified) * freebsd/sys/arm/lpc/if_lpe.c (modified) * freebsd/sys/arm/lpc/if_lpereg.h (modified) * freebsd/sys/arm/lpc/lpc_pwr.c (modified) * freebsd/sys/arm/lpc/lpcreg.h (modified) * freebsd/sys/arm/lpc/lpcvar.h (modified) * freebsd/sys/arm/ti/am335x/am335x_prcm.c (modified) * freebsd/sys/arm/ti/am335x/am335x_scm.h (modified) * freebsd/sys/arm/ti/am335x/am335x_usbss.c (modified) * freebsd/sys/arm/ti/ti_cpuid.h (modified) * freebsd/sys/arm/ti/ti_prcm.c (modified) * freebsd/sys/arm/ti/ti_prcm.h (modified) * freebsd/sys/arm/ti/ti_scm.c (modified) * freebsd/sys/arm/ti/ti_scm.h (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/arm/ti/tivar.h (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (modified) * freebsd/sys/arm/xilinx/zy7_slcr.h (modified) * freebsd/sys/avr/include/machine/in_cksum.h (modified) * freebsd/sys/bfin/include/machine/in_cksum.h (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/bsm/audit_kevents.h (modified) * freebsd/sys/cam/ata/ata_all.h (modified) * freebsd/sys/cam/cam.c (modified) * freebsd/sys/cam/cam.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_debug.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_sim.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/cam_xpt_sim.h (modified) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/crypto/sha1.c (modified) * freebsd/sys/crypto/sha1.h (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bce/if_bcefw.h (modified) * freebsd/sys/dev/bce/if_bcereg.h (modified) * freebsd/sys/dev/bfe/if_bfe.c (modified) * freebsd/sys/dev/bfe/if_bfereg.h (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/bge/if_bgereg.h (modified) * freebsd/sys/dev/cadence/if_cgem.c (modified) * freebsd/sys/dev/cadence/if_cgem_hw.h (modified) * freebsd/sys/dev/dc/dcphy.c (modified) * freebsd/sys/dev/dc/if_dc.c (modified) * freebsd/sys/dev/dc/if_dcreg.h (modified) * freebsd/sys/dev/dc/pnphy.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.c (modified) * freebsd/sys/dev/e1000/e1000_80003es2lan.h (modified) * freebsd/sys/dev/e1000/e1000_82540.c (modified) * freebsd/sys/dev/e1000/e1000_82541.c (modified) * freebsd/sys/dev/e1000/e1000_82541.h (modified) * freebsd/sys/dev/e1000/e1000_82542.c (modified) * freebsd/sys/dev/e1000/e1000_82543.c (modified) * freebsd/sys/dev/e1000/e1000_82543.h (modified) * freebsd/sys/dev/e1000/e1000_82571.c (modified) * freebsd/sys/dev/e1000/e1000_82571.h (modified) * freebsd/sys/dev/e1000/e1000_82575.c (modified) * freebsd/sys/dev/e1000/e1000_82575.h (modified) * freebsd/sys/dev/e1000/e1000_api.c (modified) * freebsd/sys/dev/e1000/e1000_api.h (modified) * freebsd/sys/dev/e1000/e1000_defines.h (modified) * freebsd/sys/dev/e1000/e1000_hw.h (modified) * freebsd/sys/dev/e1000/e1000_i210.c (modified) * freebsd/sys/dev/e1000/e1000_i210.h (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.h (modified) * freebsd/sys/dev/e1000/e1000_mac.c (modified) * freebsd/sys/dev/e1000/e1000_mac.h (modified) * freebsd/sys/dev/e1000/e1000_manage.c (modified) * freebsd/sys/dev/e1000/e1000_manage.h (modified) * freebsd/sys/dev/e1000/e1000_mbx.c (modified) * freebsd/sys/dev/e1000/e1000_mbx.h (modified) * freebsd/sys/dev/e1000/e1000_nvm.c (modified) * freebsd/sys/dev/e1000/e1000_nvm.h (modified) * freebsd/sys/dev/e1000/e1000_osdep.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/e1000/e1000_phy.c (modified) * freebsd/sys/dev/e1000/e1000_phy.h (modified) * freebsd/sys/dev/e1000/e1000_regs.h (modified) * freebsd/sys/dev/e1000/e1000_vf.c (modified) * freebsd/sys/dev/e1000/e1000_vf.h (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev.h (modified) * freebsd/sys/dev/evdev/evdev_utils.c (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/fdt/fdt_common.h (modified) * freebsd/sys/dev/fdt/simplebus.c (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/ffec/if_ffecreg.h (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/fxp/if_fxpreg.h (modified) * freebsd/sys/dev/fxp/if_fxpvar.h (modified) * freebsd/sys/dev/fxp/rcvbundl.h (modified) * freebsd/sys/dev/gpio/gpiobus.c (modified) * freebsd/sys/dev/gpio/gpiobusvar.h (modified) * freebsd/sys/dev/gpio/ofw_gpiobus.c (modified) * freebsd/sys/dev/kbd/kbd.c (modified) * freebsd/sys/dev/kbd/kbdreg.h (modified) * freebsd/sys/dev/kbd/kbdtables.h (modified) * freebsd/sys/dev/led/led.c (modified) * freebsd/sys/dev/mii/brgphy.c (modified) * freebsd/sys/dev/mii/brgphyreg.h (modified) * freebsd/sys/dev/mii/e1000phy.c (modified) * freebsd/sys/dev/mii/e1000phyreg.h (modified) * freebsd/sys/dev/mii/icsphy.c (modified) * freebsd/sys/dev/mii/icsphyreg.h (modified) * freebsd/sys/dev/mii/mii.c (modified) * freebsd/sys/dev/mii/mii.h (modified) * freebsd/sys/dev/mii/mii_bitbang.c (modified) * freebsd/sys/dev/mii/mii_bitbang.h (modified) * freebsd/sys/dev/mii/mii_physubr.c (modified) * freebsd/sys/dev/mii/miivar.h (modified) * freebsd/sys/dev/mii/rgephy.c (modified) * freebsd/sys/dev/mii/rgephyreg.h (modified) * freebsd/sys/dev/mii/ukphy.c (modified) * freebsd/sys/dev/mii/ukphy_subr.c (modified) * freebsd/sys/dev/mmc/bridge.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcbrvar.h (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/mmc/mmcvar.h (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.h (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/ofw/ofw_pci.h (modified) * freebsd/sys/dev/ofw/ofwvar.h (modified) * freebsd/sys/dev/ofw/openfirm.c (modified) * freebsd/sys/dev/ofw/openfirm.h (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcib_private.h (modified) * freebsd/sys/dev/pci/pcireg.h (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/smc/if_smcreg.h (modified) * freebsd/sys/dev/smc/if_smcvar.h (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/tsec/if_tsec.h (modified) * freebsd/sys/dev/tsec/if_tsec_fdt.c (modified) * freebsd/sys/dev/tsec/if_tsecreg.h (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg.h (modified) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) * freebsd/sys/dev/usb/controller/dwc_otgreg.h (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ehci.h (modified) * freebsd/sys/dev/usb/controller/ehcireg.h (modified) * freebsd/sys/dev/usb/controller/musb_otg.c (modified) * freebsd/sys/dev/usb/controller/musb_otg.h (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/ohci.h (modified) * freebsd/sys/dev/usb/controller/ohcireg.h (modified) * freebsd/sys/dev/usb/controller/uhcireg.h (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/controller/xhcireg.h (modified) * freebsd/sys/dev/usb/input/atp.c (modified) * freebsd/sys/dev/usb/input/uep.c (modified) * freebsd/sys/dev/usb/input/uhid.c (modified) * freebsd/sys/dev/usb/input/ukbd.c (modified) * freebsd/sys/dev/usb/input/ums.c (modified) * freebsd/sys/dev/usb/input/usb_rdesc.h (modified) * freebsd/sys/dev/usb/input/wsp.c (modified) * freebsd/sys/dev/usb/net/if_aue.c (modified) * freebsd/sys/dev/usb/net/if_auereg.h (modified) * freebsd/sys/dev/usb/net/if_axe.c (modified) * freebsd/sys/dev/usb/net/if_axereg.h (modified) * freebsd/sys/dev/usb/net/if_axge.c (modified) * freebsd/sys/dev/usb/net/if_axgereg.h (modified) * freebsd/sys/dev/usb/net/if_cdce.c (modified) * freebsd/sys/dev/usb/net/if_cdcereg.h (modified) * freebsd/sys/dev/usb/net/if_cue.c (modified) * freebsd/sys/dev/usb/net/if_cuereg.h (modified) * freebsd/sys/dev/usb/net/if_ipheth.c (modified) * freebsd/sys/dev/usb/net/if_iphethvar.h (modified) * freebsd/sys/dev/usb/net/if_kue.c (modified) * freebsd/sys/dev/usb/net/if_kuefw.h (modified) * freebsd/sys/dev/usb/net/if_kuereg.h (modified) * freebsd/sys/dev/usb/net/if_mos.c (modified) * freebsd/sys/dev/usb/net/if_mosreg.h (modified) * freebsd/sys/dev/usb/net/if_rue.c (modified) * freebsd/sys/dev/usb/net/if_ruereg.h (modified) * freebsd/sys/dev/usb/net/if_smsc.c (modified) * freebsd/sys/dev/usb/net/if_smscreg.h (modified) * freebsd/sys/dev/usb/net/if_udav.c (modified) * freebsd/sys/dev/usb/net/if_udavreg.h (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/net/ruephy.c (modified) * freebsd/sys/dev/usb/net/ruephyreg.h (modified) * freebsd/sys/dev/usb/net/usb_ethernet.c (modified) * freebsd/sys/dev/usb/net/usb_ethernet.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.h (modified) * freebsd/sys/dev/usb/serial/u3g.c (modified) * freebsd/sys/dev/usb/serial/ubsa.c (modified) * freebsd/sys/dev/usb/serial/ubser.c (modified) * freebsd/sys/dev/usb/serial/uchcom.c (modified) * freebsd/sys/dev/usb/serial/ucycom.c (modified) * freebsd/sys/dev/usb/serial/ufoma.c (modified) * freebsd/sys/dev/usb/serial/uftdi.c (modified) * freebsd/sys/dev/usb/serial/ugensa.c (modified) * freebsd/sys/dev/usb/serial/uipaq.c (modified) * freebsd/sys/dev/usb/serial/ulpt.c (modified) * freebsd/sys/dev/usb/serial/umcs.c (modified) * freebsd/sys/dev/usb/serial/umcs.h (modified) * freebsd/sys/dev/usb/serial/umct.c (modified) * freebsd/sys/dev/usb/serial/umodem.c (modified) * freebsd/sys/dev/usb/serial/uplcom.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.c (modified) * freebsd/sys/dev/usb/serial/usb_serial.h (modified) * freebsd/sys/dev/usb/serial/uvisor.c (modified) * freebsd/sys/dev/usb/serial/uvscom.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/ufm_ioctl.h (modified) * freebsd/sys/dev/usb/usb.h (modified) * freebsd/sys/dev/usb/usb_bus.h (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_busdma.h (modified) * freebsd/sys/dev/usb/usb_cdc.h (modified) * freebsd/sys/dev/usb/usb_controller.h (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_core.h (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_debug.h (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_dev.h (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_device.h (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_dynamic.h (modified) * freebsd/sys/dev/usb/usb_endian.h (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_freebsd.h (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_generic.h (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_hub.h (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_mbuf.h (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_msctest.h (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_pf.h (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_process.h (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_request.h (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_transfer.h (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/dev/usb/usb_util.h (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/dev/usb/usbdi_util.h (modified) * freebsd/sys/dev/usb/usbhid.h (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/dev/usb/wlan/if_zydfw.h (modified) * freebsd/sys/fs/devfs/devfs_int.h (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/h8300/include/machine/in_cksum.h (modified) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/i386/include/machine/_bus.h (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/in_cksum.h (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/isa/isavar.h (modified) * freebsd/sys/isa/pnpvar.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_condvar.c (modified) * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_hhook.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_khelp.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_module.c (modified) * freebsd/sys/kern/kern_mtxpool.c (modified) * freebsd/sys/kern/kern_osd.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/kern_uuid.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_bufring.c (modified) * freebsd/sys/kern/subr_bus.c (modified) * freebsd/sys/kern/subr_counter.c (modified) * freebsd/sys/kern/subr_eventhandler.c (modified) * freebsd/sys/kern/subr_firmware.c (modified) * freebsd/sys/kern/subr_hash.c (modified) * freebsd/sys/kern/subr_hints.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_module.c (modified) * freebsd/sys/kern/subr_pcpu.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/sys_pipe.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/tty_inq.c (modified) * freebsd/sys/kern/tty_outq.c (modified) * freebsd/sys/kern/tty_ttydisc.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_domain.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_mbuf2.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/random.c (modified) * freebsd/sys/lm32/include/machine/in_cksum.h (modified) * freebsd/sys/m32c/include/machine/in_cksum.h (modified) * freebsd/sys/m32r/include/machine/in_cksum.h (modified) * freebsd/sys/m68k/include/machine/in_cksum.h (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/mips/include/machine/in_cksum.h (modified) * freebsd/sys/mips/mips/in_cksum.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf.h (modified) * freebsd/sys/net/bpf_buffer.c (modified) * freebsd/sys/net/bpf_buffer.h (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bpf_jitter.h (modified) * freebsd/sys/net/bpf_zerocopy.h (modified) * freebsd/sys/net/bpfdesc.h (modified) * freebsd/sys/net/bridgestp.c (modified) * freebsd/sys/net/bridgestp.h (modified) * freebsd/sys/net/fddi.h (modified) * freebsd/sys/net/firewire.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/ieee8023ad_lacp.h (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_arc.h (modified) * freebsd/sys/net/if_arcsubr.c (modified) * freebsd/sys/net/if_arp.h (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_bridgevar.h (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_clone.h (modified) * freebsd/sys/net/if_dead.c (modified) * freebsd/sys/net/if_disc.c (modified) * freebsd/sys/net/if_dl.h (modified) * freebsd/sys/net/if_edsc.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_enc.h (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_fddisubr.c (modified) * freebsd/sys/net/if_fwsubr.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/net/if_gif.h (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_iso88025subr.c (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_llatbl.h (modified) * freebsd/sys/net/if_llc.h (modified) * freebsd/sys/net/if_loop.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_pflog.h (modified) * freebsd/sys/net/if_pfsync.h (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tap.h (modified) * freebsd/sys/net/if_tapvar.h (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_types.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan_var.h (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/ifq.h (modified) * freebsd/sys/net/iso88025.h (modified) * freebsd/sys/net/netisr.c (modified) * freebsd/sys/net/netisr.h (modified) * freebsd/sys/net/netisr_internal.h (modified) * freebsd/sys/net/pfil.c (modified) * freebsd/sys/net/pfil.h (modified) * freebsd/sys/net/pfkeyv2.h (modified) * freebsd/sys/net/pfvar.h (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/radix_mpath.h (modified) * freebsd/sys/net/raw_cb.c (modified) * freebsd/sys/net/raw_cb.h (modified) * freebsd/sys/net/raw_usrreq.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rss_config.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/sff8472.h (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net/slcompress.h (modified) * freebsd/sys/net/vnet.h (modified) * freebsd/sys/net80211/_ieee80211.h (modified) * freebsd/sys/net80211/ieee80211.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_acl.c (modified) * freebsd/sys/net80211/ieee80211_action.c (modified) * freebsd/sys/net80211/ieee80211_action.h (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.h (modified) * freebsd/sys/net80211/ieee80211_ageq.c (modified) * freebsd/sys/net80211/ieee80211_ageq.h (modified) * freebsd/sys/net80211/ieee80211_alq.h (modified) * freebsd/sys/net80211/ieee80211_crypto.c (modified) * freebsd/sys/net80211/ieee80211_crypto.h (modified) * freebsd/sys/net80211/ieee80211_crypto_ccmp.c (modified) * freebsd/sys/net80211/ieee80211_crypto_none.c (modified) * freebsd/sys/net80211/ieee80211_crypto_tkip.c (modified) * freebsd/sys/net80211/ieee80211_crypto_wep.c (modified) * freebsd/sys/net80211/ieee80211_ddb.c (modified) * freebsd/sys/net80211/ieee80211_dfs.c (modified) * freebsd/sys/net80211/ieee80211_dfs.h (modified) * freebsd/sys/net80211/ieee80211_freebsd.c (modified) * freebsd/sys/net80211/ieee80211_freebsd.h (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_hostap.h (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_hwmp.c (modified) * freebsd/sys/net80211/ieee80211_input.c (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_ioctl.h (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_mesh.h (modified) * freebsd/sys/net80211/ieee80211_monitor.c (modified) * freebsd/sys/net80211/ieee80211_monitor.h (modified) * freebsd/sys/net80211/ieee80211_node.c (modified) * freebsd/sys/net80211/ieee80211_node.h (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_phy.c (modified) * freebsd/sys/net80211/ieee80211_phy.h (modified) * freebsd/sys/net80211/ieee80211_power.c (modified) * freebsd/sys/net80211/ieee80211_power.h (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_radiotap.c (modified) * freebsd/sys/net80211/ieee80211_radiotap.h (modified) * freebsd/sys/net80211/ieee80211_ratectl.c (modified) * freebsd/sys/net80211/ieee80211_ratectl.h (modified) * freebsd/sys/net80211/ieee80211_ratectl_none.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.c (modified) * freebsd/sys/net80211/ieee80211_regdomain.h (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.h (modified) * freebsd/sys/net80211/ieee80211_scan.c (modified) * freebsd/sys/net80211/ieee80211_scan.h (modified) * freebsd/sys/net80211/ieee80211_scan_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_sta.h (modified) * freebsd/sys/net80211/ieee80211_superg.c (modified) * freebsd/sys/net80211/ieee80211_superg.h (modified) * freebsd/sys/net80211/ieee80211_tdma.c (modified) * freebsd/sys/net80211/ieee80211_tdma.h (modified) * freebsd/sys/net80211/ieee80211_var.h (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/net80211/ieee80211_wds.h (modified) * freebsd/sys/net80211/ieee80211_xauth.c (modified) * freebsd/sys/netinet/accf_data.c (modified) * freebsd/sys/netinet/accf_dns.c (modified) * freebsd/sys/netinet/accf_http.c (modified) * freebsd/sys/netinet/cc/cc.c (modified) * freebsd/sys/netinet/cc/cc_module.h (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/icmp6.h (modified) * freebsd/sys/netinet/icmp_var.h (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/if_ether.h (modified) * freebsd/sys/netinet/igmp.c (modified) * freebsd/sys/netinet/igmp.h (modified) * freebsd/sys/netinet/igmp_var.h (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_gif.c (modified) * freebsd/sys/netinet/in_kdtrace.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/in_proto.c (modified) * freebsd/sys/netinet/in_systm.h (modified) * freebsd/sys/netinet/in_var.h (modified) * freebsd/sys/netinet/ip.h (modified) * freebsd/sys/netinet/ip6.h (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_carp.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_divert.h (modified) * freebsd/sys/netinet/ip_dummynet.h (modified) * freebsd/sys/netinet/ip_ecn.c (modified) * freebsd/sys/netinet/ip_ecn.h (modified) * freebsd/sys/netinet/ip_encap.c (modified) * freebsd/sys/netinet/ip_encap.h (modified) * freebsd/sys/netinet/ip_fastfwd.c (modified) * freebsd/sys/netinet/ip_fw.h (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_icmp.h (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_mroute.h (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ip_options.h (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/ip_var.h (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias.h (modified) * freebsd/sys/netinet/libalias/alias_cuseeme.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_dummy.c (modified) * freebsd/sys/netinet/libalias/alias_ftp.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/libalias/alias_mod.h (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/libalias/alias_skinny.c (modified) * freebsd/sys/netinet/libalias/alias_smedia.c (modified) * freebsd/sys/netinet/libalias/alias_util.c (modified) * freebsd/sys/netinet/pim.h (modified) * freebsd/sys/netinet/pim_var.h (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_asconf.h (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_bsd_addr.h (modified) * freebsd/sys/netinet/sctp_cc_functions.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_crc32.c (modified) * freebsd/sys/netinet/sctp_crc32.h (modified) * freebsd/sys/netinet/sctp_dtrace_declare.h (modified) * freebsd/sys/netinet/sctp_dtrace_define.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_indata.h (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_input.h (modified) * freebsd/sys/netinet/sctp_lock_bsd.h (modified) * freebsd/sys/netinet/sctp_os.h (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_peeloff.c (modified) * freebsd/sys/netinet/sctp_peeloff.h (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_sysctl.h (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_timer.h (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_debug.c (modified) * freebsd/sys/netinet/tcp_debug.h (modified) * freebsd/sys/netinet/tcp_fsm.h (modified) * freebsd/sys/netinet/tcp_hostcache.c (modified) * freebsd/sys/netinet/tcp_hostcache.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_lro.h (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet/tcp_offload.h (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_sack.c (modified) * freebsd/sys/netinet/tcp_seq.h (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_timer.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/tcpip.h (modified) * freebsd/sys/netinet/toecore.h (modified) * freebsd/sys/netinet/udp.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet/udp_var.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_cksum.c (modified) * freebsd/sys/netinet6/in6_gif.c (modified) * freebsd/sys/netinet6/in6_ifattach.c (modified) * freebsd/sys/netinet6/in6_ifattach.h (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_pcb.h (modified) * freebsd/sys/netinet6/in6_proto.c (modified) * freebsd/sys/netinet6/in6_rmx.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/in6_var.h (modified) * freebsd/sys/netinet6/ip6_ecn.h (modified) * freebsd/sys/netinet6/ip6_fastfwd.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_mroute.h (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/ip6_var.h (modified) * freebsd/sys/netinet6/ip6protosw.h (modified) * freebsd/sys/netinet6/mld6.c (modified) * freebsd/sys/netinet6/mld6.h (modified) * freebsd/sys/netinet6/mld6_var.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6.h (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netinet6/pim6.h (modified) * freebsd/sys/netinet6/pim6_var.h (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/raw_ip6.h (modified) * freebsd/sys/netinet6/route6.c (modified) * freebsd/sys/netinet6/scope6.c (modified) * freebsd/sys/netinet6/scope6_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/send.h (modified) * freebsd/sys/netinet6/tcp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netinet6/udp6_var.h (modified) * freebsd/sys/netipsec/ah.h (modified) * freebsd/sys/netipsec/esp.h (modified) * freebsd/sys/netipsec/ipcomp.h (modified) * freebsd/sys/netipsec/ipcomp_var.h (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec6.h (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key.h (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/key_debug.h (modified) * freebsd/sys/netipsec/key_var.h (modified) * freebsd/sys/netipsec/keydb.h (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/keysock.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netipsec/xform_tcp.c (modified) * freebsd/sys/netpfil/pf/if_pfsync.c (modified) * freebsd/sys/netpfil/pf/in4_cksum.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/netpfil/pf/pf.h (modified) * freebsd/sys/netpfil/pf/pf_altq.h (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/netpfil/pf/pf_mtag.h (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_ruleset.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/nios2/include/machine/in_cksum.h (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/powerpc/include/machine/cpufunc.h (modified) * freebsd/sys/powerpc/include/machine/in_cksum.h (modified) * freebsd/sys/powerpc/include/machine/intr_machdep.h (modified) * freebsd/sys/powerpc/include/machine/psl.h (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/powerpc/powerpc/in_cksum.c (modified) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/security/audit/audit.h (modified) * freebsd/sys/sh/include/machine/in_cksum.h (modified) * freebsd/sys/sparc/include/machine/in_cksum.h (modified) * freebsd/sys/sparc64/include/machine/asi.h (modified) * freebsd/sys/sparc64/include/machine/cpufunc.h (modified) * freebsd/sys/sparc64/include/machine/in_cksum.h (modified) * freebsd/sys/sparc64/include/machine/pstate.h (modified) * freebsd/sys/sparc64/sparc64/in_cksum.c (modified) * freebsd/sys/sys/_bus_dma.h (modified) * freebsd/sys/sys/_callout.h (modified) * freebsd/sys/sys/_lock.h (modified) * freebsd/sys/sys/_lockmgr.h (modified) * freebsd/sys/sys/_mutex.h (modified) * freebsd/sys/sys/_null.h (modified) * freebsd/sys/sys/_pctrie.h (modified) * freebsd/sys/sys/_rmlock.h (modified) * freebsd/sys/sys/_rwlock.h (modified) * freebsd/sys/sys/_semaphore.h (modified) * freebsd/sys/sys/_sx.h (modified) * freebsd/sys/sys/_task.h (modified) * freebsd/sys/sys/_unrhdr.h (modified) * freebsd/sys/sys/acl.h (modified) * freebsd/sys/sys/aio.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/blist.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/buf_ring.h (modified) * freebsd/sys/sys/bufobj.h (modified) * freebsd/sys/sys/bus.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/callout.h (modified) * freebsd/sys/sys/capability.h (modified) * freebsd/sys/sys/caprights.h (modified) * freebsd/sys/sys/condvar.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/cons.h (modified) * freebsd/sys/sys/counter.h (modified) * freebsd/sys/sys/cpu.h (modified) * freebsd/sys/sys/ctype.h (modified) * freebsd/sys/sys/domain.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/fail.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/filedesc.h (modified) * freebsd/sys/sys/firmware.h (modified) * freebsd/sys/sys/gpio.h (modified) * freebsd/sys/sys/hash.h (modified) * freebsd/sys/sys/hhook.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/kenv.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/khelp.h (modified) * freebsd/sys/sys/kobj.h (modified) * freebsd/sys/sys/kthread.h (modified) * freebsd/sys/sys/ktr.h (modified) * freebsd/sys/sys/ktr_class.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/limits.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/linker_set.h (modified) * freebsd/sys/sys/lock_profile.h (modified) * freebsd/sys/sys/lockmgr.h (modified) * freebsd/sys/sys/lockstat.h (modified) * freebsd/sys/sys/loginclass.h (modified) * freebsd/sys/sys/mac.h (modified) * freebsd/sys/sys/malloc.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/module_khelp.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/mqueue.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/nlist_aout.h (modified) * freebsd/sys/sys/osd.h (modified) * freebsd/sys/sys/pciio.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/priv.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/protosw.h (modified) * freebsd/sys/sys/racct.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/reboot.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/resourcevar.h (modified) * freebsd/sys/sys/rmlock.h (modified) * freebsd/sys/sys/rtprio.h (modified) * freebsd/sys/sys/runq.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/sdt.h (modified) * freebsd/sys/sys/selinfo.h (modified) * freebsd/sys/sys/serial.h (modified) * freebsd/sys/sys/sf_buf.h (modified) * freebsd/sys/sys/sigio.h (modified) * freebsd/sys/sys/signalvar.h (modified) * freebsd/sys/sys/sleepqueue.h (modified) * freebsd/sys/sys/slicer.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/stddef.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/sx.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/syslog.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/timeet.h (modified) * freebsd/sys/sys/tree.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/ttydevsw.h (modified) * freebsd/sys/sys/ttydisc.h (modified) * freebsd/sys/sys/ttyhook.h (modified) * freebsd/sys/sys/ttyqueue.h (modified) * freebsd/sys/sys/ucred.h (modified) * freebsd/sys/sys/un.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/uuid.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/sys/watchdog.h (modified) * freebsd/sys/v850/include/machine/in_cksum.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_dbg.c (modified) * freebsd/sys/vm/uma_dbg.h (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/sys/x86/include/machine/bus.h (modified) * freebsd/sys/x86/include/machine/pci_cfgreg.h (modified) * freebsd/sys/x86/pci/pci_bus.c (modified) * freebsd/usr.bin/netstat/bpf.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/mbuf.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/pfkey.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * freebsd/usr.bin/netstat/unix.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * freebsd/usr.sbin/tcpdump/tcpdump/config.h (modified) * freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.c (modified) * freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.h (modified) * libbsd.py (modified) * rtemsbsd/include/casper/cap_dns.h (added) * rtemsbsd/include/casper/cap_syslog.h (added) * rtemsbsd/include/libcasper.h (added) * rtemsbsd/include/machine/_kernel_lock.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) Update to FreeBSD head 2017-12-01 Git mirror commit ... Thu, 09 Aug 2018 11:04:41 GMT Sebastian Huber [e4a8065] * freebsd-org (modified) * freebsd/contrib/libxo/libxo/libxo.c (modified) * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libutil/libutil.h (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sys/arm/ti/am335x/am335x_prcm.c (modified) * freebsd/sys/arm/ti/ti_cpuid.h (modified) * freebsd/sys/arm/ti/ti_scm.c (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/mmc/mmc.h (modified) * freebsd/sys/cam/mmc/mmc_sdio.h (deleted) * freebsd/sys/cam/nvme/nvme_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/mmc/bridge.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_subr.c (modified) * freebsd/sys/dev/mmc/mmc_subr.h (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/mmc/mmcvar.h (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/ofw/ofw_bus_subr.c (modified) * freebsd/sys/dev/ofw/ofw_fdt.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/rtwn/if_rtwn_ridx.h (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_fw.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_priv.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_var.h (modified) * freebsd/sys/dev/rtwn/rtl8192e/r92e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/smc/if_smc.c (modified) * freebsd/sys/dev/usb/net/if_ure.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.h (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usbhid.h (modified) * freebsd/sys/dev/usb/wlan/if_uath.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/i386/include/machine/cpufunc.h (modified) * freebsd/sys/i386/include/machine/intr_machdep.h (modified) * freebsd/sys/i386/include/machine/md_var.h (modified) * freebsd/sys/kern/kern_sysctl.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/libkern/crc32.c (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/mips/include/machine/cpuregs.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net80211/ieee80211_ioctl.c (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_asconf.h (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_timer.c (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec6.h (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/udpencap.c (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netpfil/pf/pf_lb.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * freebsd/sys/opencrypto/cryptodev.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/xform_aes_icm.c (modified) * freebsd/sys/opencrypto/xform_aes_xts.c (modified) * freebsd/sys/opencrypto/xform_blf.c (modified) * freebsd/sys/opencrypto/xform_cast5.c (modified) * freebsd/sys/opencrypto/xform_cml.c (modified) * freebsd/sys/opencrypto/xform_deflate.c (modified) * freebsd/sys/opencrypto/xform_des1.c (modified) * freebsd/sys/opencrypto/xform_des3.c (modified) * freebsd/sys/opencrypto/xform_gmac.c (modified) * freebsd/sys/opencrypto/xform_md5.c (modified) * freebsd/sys/opencrypto/xform_null.c (modified) * freebsd/sys/opencrypto/xform_rijndael.c (modified) * freebsd/sys/opencrypto/xform_rmd160.c (modified) * freebsd/sys/opencrypto/xform_sha1.c (modified) * freebsd/sys/opencrypto/xform_sha2.c (modified) * freebsd/sys/opencrypto/xform_skipjack.c (modified) * freebsd/sys/powerpc/include/machine/spr.h (modified) * freebsd/sys/sys/_task.h (modified) * freebsd/sys/sys/blist.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/gpio.h (modified) * freebsd/sys/sys/gtaskqueue.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/mutex.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/tcpdump/tcpdump/config.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) Update to FreeBSD head 2017-10-01 Git mirror commit ... Tue, 07 Aug 2018 12:56:50 GMT Sebastian Huber [c37f9fb] * freebsd-org (modified) * freebsd/contrib/libxo/libxo/libxo.c (modified) * freebsd/contrib/libxo/libxo/xo.h (modified) * freebsd/contrib/libxo/libxo/xo_buf.h (modified) * freebsd/contrib/libxo/libxo/xo_encoder.c (modified) * freebsd/contrib/libxo/libxo/xo_encoder.h (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/net/nsdispatch.c (modified) * freebsd/lib/libc/rpc/getnetconfig.c (modified) * freebsd/lib/libc/rpc/rpc_generic.c (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/lib/libc/rpc/rpcb_prot.c (modified) * freebsd/lib/libc/rpc/rpcb_st_xdr.c (modified) * freebsd/lib/libc/stdio/fgetln.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libc/xdr/xdr.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/arm/ti/ti_sdhci.c (modified) * freebsd/sys/cam/cam.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/mmc/mmc.h (added) * freebsd/sys/cam/mmc/mmc_all.h (added) * freebsd/sys/cam/mmc/mmc_bus.h (added) * freebsd/sys/cam/mmc/mmc_sdio.h (added) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/evdev/cdev.c (modified) * freebsd/sys/dev/evdev/evdev.c (modified) * freebsd/sys/dev/evdev/evdev_mt.c (modified) * freebsd/sys/dev/evdev/evdev_private.h (modified) * freebsd/sys/dev/evdev/evdev_utils.c (modified) * freebsd/sys/dev/evdev/input-event-codes.h (modified) * freebsd/sys/dev/evdev/input.h (modified) * freebsd/sys/dev/evdev/uinput.c (modified) * freebsd/sys/dev/evdev/uinput.h (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/mii/mii_fdt.c (added) * freebsd/sys/dev/mii/mii_fdt.h (added) * freebsd/sys/dev/mii/miivar.h (modified) * freebsd/sys/dev/mmc/bridge.h (modified) * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmc_ioctl.h (modified) * freebsd/sys/dev/mmc/mmc_private.h (modified) * freebsd/sys/dev/mmc/mmc_subr.c (modified) * freebsd/sys/dev/mmc/mmcbrvar.h (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) * freebsd/sys/dev/mmc/mmcsd.c (modified) * freebsd/sys/dev/nvme/nvme.h (modified) * freebsd/sys/dev/rtwn/if_rtwn_rx.c (modified) * freebsd/sys/dev/rtwn/if_rtwnreg.h (modified) * freebsd/sys/dev/rtwn/if_rtwnvar.h (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_attach.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.c (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_rx.h (modified) * freebsd/sys/dev/rtwn/pci/rtwn_pci_var.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_priv.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rom_defs.h (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_rx.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/usb/r88eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_rom_image.h (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_tx.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_tx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_attach.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_ep.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_rx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_tx.c (modified) * freebsd/sys/dev/rtwn/usb/rtwn_usb_var.h (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/tsec/if_tsec.c (modified) * freebsd/sys/dev/usb/controller/saf1761_otg.c (modified) * freebsd/sys/dev/usb/wlan/if_rsu.c (modified) * freebsd/sys/dev/usb/wlan/if_zyd.c (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_uuid.c (modified) * freebsd/sys/kern/subr_blist.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/subr_uio.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/uipc_accf.c (modified) * freebsd/sys/kern/uipc_mbuf.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/if_enc.c (modified) * freebsd/sys/net/if_enc.h (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_stf.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net80211/ieee80211_amrr.c (modified) * freebsd/sys/net80211/ieee80211_output.c (modified) * freebsd/sys/net80211/ieee80211_rssadapt.c (modified) * freebsd/sys/netinet/cc/cc_newreno.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_output.h (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_timewait.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netpfil/pf/pf.c (modified) * freebsd/sys/sys/_pctrie.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/blist.h (modified) * freebsd/sys/sys/buf.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/jail.h (modified) * freebsd/sys/sys/module.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/socketvar.h (modified) * freebsd/sys/sys/sockopt.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/unpcb.h (modified) * freebsd/sys/sys/uuid.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/usr.bin/netstat/flowtable.c (deleted) * freebsd/usr.bin/netstat/inet.c (modified) * freebsd/usr.bin/netstat/main.c (modified) * freebsd/usr.bin/netstat/netstat.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-data.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-namespace.h (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbr_if.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbus_if.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_mmccam.h (added) * rtemsbsd/local/mmcbr_if.c (modified) * rtemsbsd/local/mmcbus_if.c (modified) * rtemsbsd/rtems/rtems-kernel-bus-dma.c (modified) Update to FreeBSD head 2017-08-01 Git mirror commit ... Tue, 07 Aug 2018 10:12:37 GMT Sebastian Huber [de261e0] * freebsd-org (modified) * freebsd/contrib/libxo/libxo/libxo.c (modified) * freebsd/contrib/libxo/libxo/xo.h (modified) * freebsd/contrib/libxo/libxo/xo_buf.h (modified) * freebsd/contrib/libxo/libxo/xo_encoder.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/crypto/openssl/crypto/armcap.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_bitstr.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_digest.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_gentm.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_strnid.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_time.c (modified) * freebsd/crypto/openssl/crypto/asn1/a_utctm.c (modified) * freebsd/crypto/openssl/crypto/asn1/f_enum.c (modified) * freebsd/crypto/openssl/crypto/asn1/f_int.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_dec.c (modified) * freebsd/crypto/openssl/crypto/asn1/tasn_new.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_long.c (modified) * freebsd/crypto/openssl/crypto/asn1/x_name.c (modified) * freebsd/crypto/openssl/crypto/bio/b_print.c (modified) * freebsd/crypto/openssl/crypto/bio/bio_cb.c (modified) * freebsd/crypto/openssl/crypto/bio/bss_file.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.c (modified) * freebsd/crypto/openssl/crypto/bn/bn_prime.h (modified) * freebsd/crypto/openssl/crypto/bn/bn_print.c (modified) * freebsd/crypto/openssl/crypto/comp/c_rle.c (modified) * freebsd/crypto/openssl/crypto/conf/conf.h (modified) * freebsd/crypto/openssl/crypto/conf/conf_def.c (modified) * freebsd/crypto/openssl/crypto/conf/conf_err.c (modified) * freebsd/crypto/openssl/crypto/des/set_key.c (modified) * freebsd/crypto/openssl/crypto/dh/dh.h (modified) * freebsd/crypto/openssl/crypto/ec/ec_ameth.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_asn1.c (modified) * freebsd/crypto/openssl/crypto/ec/ec_mult.c (modified) * freebsd/crypto/openssl/crypto/ec/eck_prn.c (modified) * freebsd/crypto/openssl/crypto/engine/eng_cryptodev.c (modified) * freebsd/crypto/openssl/crypto/err/err.c (modified) * freebsd/crypto/openssl/crypto/err/err.h (modified) * freebsd/crypto/openssl/crypto/evp/e_aes.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c (modified) * freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c (modified) * freebsd/crypto/openssl/crypto/evp/e_des3.c (modified) * freebsd/crypto/openssl/crypto/evp/evp_enc.c (modified) * freebsd/crypto/openssl/crypto/evp/pmeth_lib.c (modified) * freebsd/crypto/openssl/crypto/ex_data.c (modified) * freebsd/crypto/openssl/crypto/hmac/hm_pmeth.c (modified) * freebsd/crypto/openssl/crypto/mem.c (modified) * freebsd/crypto/openssl/crypto/o_dir.c (modified) * freebsd/crypto/openssl/crypto/o_time.c (modified) * freebsd/crypto/openssl/crypto/opensslv.h (modified) * freebsd/crypto/openssl/crypto/pkcs12/p12_mutl.c (modified) * freebsd/crypto/openssl/crypto/ppccap.c (modified) * freebsd/crypto/openssl/crypto/rand/md_rand.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pmeth.c (modified) * freebsd/crypto/openssl/crypto/rsa/rsa_pss.c (modified) * freebsd/crypto/openssl/crypto/srp/srp_vfy.c (modified) * freebsd/crypto/openssl/crypto/txt_db/txt_db.c (modified) * freebsd/crypto/openssl/crypto/ui/ui_lib.c (modified) * freebsd/crypto/openssl/crypto/x509/x509_lu.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_alt.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_cpols.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_info.c (modified) * freebsd/crypto/openssl/crypto/x509v3/v3_purp.c (modified) * freebsd/crypto/openssl/ssl/d1_both.c (modified) * freebsd/crypto/openssl/ssl/d1_clnt.c (modified) * freebsd/crypto/openssl/ssl/d1_pkt.c (modified) * freebsd/crypto/openssl/ssl/d1_srvr.c (modified) * freebsd/crypto/openssl/ssl/s23_clnt.c (modified) * freebsd/crypto/openssl/ssl/s23_srvr.c (modified) * freebsd/crypto/openssl/ssl/s3_clnt.c (modified) * freebsd/crypto/openssl/ssl/s3_enc.c (modified) * freebsd/crypto/openssl/ssl/s3_lib.c (modified) * freebsd/crypto/openssl/ssl/s3_pkt.c (modified) * freebsd/crypto/openssl/ssl/s3_srvr.c (modified) * freebsd/crypto/openssl/ssl/ssl_cert.c (modified) * freebsd/crypto/openssl/ssl/ssl_ciph.c (modified) * freebsd/crypto/openssl/ssl/ssl_lib.c (modified) * freebsd/crypto/openssl/ssl/ssl_locl.h (modified) * freebsd/crypto/openssl/ssl/ssl_rsa.c (modified) * freebsd/crypto/openssl/ssl/ssl_sess.c (modified) * freebsd/crypto/openssl/ssl/ssltest.c (modified) * freebsd/crypto/openssl/ssl/t1_ext.c (modified) * freebsd/crypto/openssl/ssl/t1_lib.c (modified) * freebsd/lib/lib80211/lib80211_regdomain.c (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libc/include/spinlock.h (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/rpc/svc.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/sbin/dhclient/dhclient.c (modified) * freebsd/sbin/dhclient/options.c (modified) * freebsd/sbin/dhclient/parse.c (modified) * freebsd/sbin/ifconfig/af_inet6.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/af_nd6.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/iflagg.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/cam/ata/ata_all.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/crypto/des/des_enc.c (modified) * freebsd/sys/crypto/des/des_setkey.c (modified) * freebsd/sys/dev/e1000/e1000_ich8lan.c (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_em.h (modified) * freebsd/sys/dev/fdt/fdt_common.c (modified) * freebsd/sys/dev/ffec/if_ffec.c (modified) * freebsd/sys/dev/fxp/if_fxp.c (modified) * freebsd/sys/dev/mii/micphy.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pcib_private.h (modified) * freebsd/sys/dev/rtwn/if_rtwn.c (modified) * freebsd/sys/dev/rtwn/rtl8188e/r88e_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192c/r92c_chan.c (modified) * freebsd/sys/dev/rtwn/rtl8192e/usb/r92eu_attach.c (modified) * freebsd/sys/dev/rtwn/rtl8812a/r12a_chan.c (modified) * freebsd/sys/dev/sdhci/sdhci.c (modified) * freebsd/sys/dev/sdhci/sdhci.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/fs/devfs/devfs_vnops.c (modified) * freebsd/sys/i386/i386/in_cksum.c (modified) * freebsd/sys/kern/kern_intr.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_kobj.c (modified) * freebsd/sys/kern/subr_prf.c (modified) * freebsd/sys/kern/sys_socket.c (modified) * freebsd/sys/kern/tty.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/libkern/crc32.c (modified) * freebsd/sys/net/altq/altq_rio.c (modified) * freebsd/sys/net/altq/altq_rmclass.h (modified) * freebsd/sys/net/bpf_filter.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/bpf_jitter.h (modified) * freebsd/sys/net/ethernet.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_ethersubr.c (modified) * freebsd/sys/net/if_gre.c (modified) * freebsd/sys/net/if_gre.h (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_lagg.h (modified) * freebsd/sys/net/if_llatbl.c (modified) * freebsd/sys/net/if_media.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_var.h (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/iflib.h (modified) * freebsd/sys/net/netisr.h (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net/slcompress.c (modified) * freebsd/sys/net80211/ieee80211_adhoc.c (modified) * freebsd/sys/net80211/ieee80211_hostap.c (modified) * freebsd/sys/net80211/ieee80211_ht.c (modified) * freebsd/sys/net80211/ieee80211_ht.h (modified) * freebsd/sys/net80211/ieee80211_input.h (modified) * freebsd/sys/net80211/ieee80211_mesh.c (modified) * freebsd/sys/net80211/ieee80211_proto.c (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/net80211/ieee80211_radiotap.h (modified) * freebsd/sys/net80211/ieee80211_sta.c (modified) * freebsd/sys/net80211/ieee80211_wds.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_kdtrace.h (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/in_pcb.h (modified) * freebsd/sys/netinet/ip_divert.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/raw_ip.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctp_var.h (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_lro.c (modified) * freebsd/sys/netinet/tcp_output.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet/tcp_syncache.c (modified) * freebsd/sys/netinet/tcp_syncache.h (modified) * freebsd/sys/netinet/tcp_usrreq.c (modified) * freebsd/sys/netinet/tcp_var.h (modified) * freebsd/sys/netinet/udp_usrreq.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/ip6_output.c (modified) * freebsd/sys/netinet6/raw_ip6.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netinet6/sctp6_var.h (modified) * freebsd/sys/netinet6/udp6_usrreq.c (modified) * freebsd/sys/netipsec/ipsec.h (modified) * freebsd/sys/netipsec/ipsec_input.c (modified) * freebsd/sys/netipsec/ipsec_mbuf.c (modified) * freebsd/sys/netipsec/ipsec_output.c (modified) * freebsd/sys/netipsec/ipsec_pcb.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/key_debug.h (modified) * freebsd/sys/netipsec/xform_ah.c (modified) * freebsd/sys/netipsec/xform_esp.c (modified) * freebsd/sys/netipsec/xform_ipcomp.c (modified) * freebsd/sys/netpfil/pf/pf_if.c (modified) * freebsd/sys/netpfil/pf/pf_ioctl.c (modified) * freebsd/sys/netpfil/pf/pf_norm.c (modified) * freebsd/sys/netpfil/pf/pf_table.c (modified) * freebsd/sys/opencrypto/criov.c (modified) * freebsd/sys/opencrypto/cryptodev.h (modified) * freebsd/sys/opencrypto/cryptosoft.c (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/interrupt.h (modified) * freebsd/sys/sys/kobj.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mount.h (modified) * freebsd/sys/sys/pcpu.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/random.h (modified) * freebsd/sys/sys/smp.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/sys/vmmeter.h (modified) * freebsd/sys/sys/vnode.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/usr.bin/netstat/inet6.c (modified) * freebsd/usr.bin/netstat/ipsec.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * freebsd/usr.bin/vmstat/vmstat.c (modified) * freebsd/usr.sbin/arp/arp.c (modified) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbus_if.h (modified) Update to FreeBSD head 2017-06-01 Git mirror commit ... Fri, 21 Sep 2018 08:25:18 GMT Sebastian Huber [a25e6a9] * libbsd.txt (modified) libbsd.txt: Use rtems_bsd_ifconfig_lo0() Fri, 21 Sep 2018 08:27:28 GMT Sebastian Huber [9ff995c] * libbsd.txt (modified) libbsd.txt: Remove linker set paragraph These linker sections are ... Fri, 21 Sep 2018 08:23:08 GMT Sebastian Huber [2707771] * libbsd.txt (modified) libbsd.txt: Avoid explicit versions Update #3472. Fri, 21 Sep 2018 08:21:24 GMT Sebastian Huber [ab4fe11] * CONTRIBUTING.md (modified) CONTRIBUTING.md: Avoid explicit commit numbers Update #3472. Wed, 19 Sep 2018 06:57:22 GMT Sebastian Huber [2723609] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/Metrics.h (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) mDNSResponder: Update to v878.30.4 The sources can be obtained via: ... Wed, 19 Sep 2018 06:56:44 GMT Sebastian Huber [1e55d820] * mDNSResponder/Clients/dnssdutil.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) mDNSResponder: Update to v878.20.3 The sources can be obtained via: ... Wed, 19 Sep 2018 06:56:09 GMT Sebastian Huber [4c086a2] * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnssdutil.c (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/TXT.rtf (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnsproxy.h (modified) * mDNSResponder/mDNSCore/dnssec.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/nsec.c (modified) * mDNSResponder/mDNSCore/nsec3.c (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSCore/uDNS.h (modified) * mDNSResponder/mDNSMacOSX/BLE.c (modified) * mDNSResponder/mDNSMacOSX/BLE.h (modified) * mDNSResponder/mDNSMacOSX/BonjourEvents.c (modified) * mDNSResponder/mDNSMacOSX/BonjourTop/BonjourTop.xcodeproj/project.pbxproj (added) * mDNSResponder/mDNSMacOSX/BonjourTop/BonjourTop.xcodeproj/project.xcworkspace/contents.xcworkspacedata (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.1 (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/CaptureFile.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/CaptureFile.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/CollectBy.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/CollectBy.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/DNSFrame.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/DNSFrame.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/Frame.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/Frame.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/LLRBTree.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/LLRBTree.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjIPAddr.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjIPAddr.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjMACAddr.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjMACAddr.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjStringtoStringMap.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjStringtoStringMap.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjsocket.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjsocket.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjstring.cpp (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjstring.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/bjtypes.h (added) * mDNSResponder/mDNSMacOSX/BonjourTop/source/main.cpp (added) * mDNSResponder/mDNSMacOSX/D2D.c (added) * mDNSResponder/mDNSMacOSX/D2D.h (added) * mDNSResponder/mDNSMacOSX/DNS64.c (added) * mDNSResponder/mDNSMacOSX/DNS64.h (added) * mDNSResponder/mDNSMacOSX/DNS64State.h (added) * mDNSResponder/mDNSMacOSX/DNSProxySupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.c (modified) * mDNSResponder/mDNSMacOSX/DomainBrowser/Shared/CNDomainBrowserPathUtils.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/Shared/CNDomainBrowserPathUtils.m (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/Shared/_CNDomainBrowser.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/Shared/_CNDomainBrowser.m (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/CNDomainBrowserViewController.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/CNDomainBrowserViewController.m (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/DomainBrowser.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/DomainBrowser.strings (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/iOS/Info.plist (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/macOS/CNDomainBrowserView.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/macOS/CNDomainBrowserView.m (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/macOS/DomainBrowser.h (added) * mDNSResponder/mDNSMacOSX/DomainBrowser/macOS/Info.plist (added) * mDNSResponder/mDNSMacOSX/LegacyNATTraversal.c (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/add_idle.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/add_pressed.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_disabled.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_idle.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Artwork/remove_pressed.tiff (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Base.lproj/DNSServiceDiscoveryPref.nib/designable.nib (added) * mDNSResponder/mDNSMacOSX/PreferencePane/Base.lproj/DNSServiceDiscoveryPref.nib/keyedobjects.nib (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/BonjourPrefTool-Info.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/BonjourPrefTool.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/BonjourPrefTool.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/BonjourPrefToolProtocol.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/entitlements.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/BonjourPrefTool/main.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.c (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.h (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.h (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/classes.nib (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/info.nib (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/DNSServiceDiscoveryPref.nib/keyedobjects.nib (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/Info-PreferencePane.plist (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.c (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.h (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/BonjourPrefRemoteViewService-Info.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/BonjourPrefRemoteViewService.h (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/BonjourPrefRemoteViewService.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/InfoPlist.strings (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/entitlements.plist (added) * mDNSResponder/mDNSMacOSX/PreferencePane/RemoteViewService/main.m (added) * mDNSResponder/mDNSMacOSX/PreferencePane/ddnswriteconfig.m (deleted) * mDNSResponder/mDNSMacOSX/PreferencePane/installtool (deleted) * mDNSResponder/mDNSMacOSX/Private/dnsctl_server.c (modified) * mDNSResponder/mDNSMacOSX/Private/xpc_services.c (modified) * mDNSResponder/mDNSMacOSX/SettingsBundle/Assets.xcassets/Contents.json (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Assets.xcassets/UIPreferencesBlueCheck.imageset/Contents.json (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Assets.xcassets/UIPreferencesBlueCheck.imageset/UIPreferencesBlueCheck.png (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Assets.xcassets/UIPreferencesBlueCheck.imageset/UIPreferencesBlueCheck@2x.png (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourConstants.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourSCStore.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourSCStore.m (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourSettingsController.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/BonjourSettingsController.m (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/CNBrowseDomainsController.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/CNBrowseDomainsController.m (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/HostnameController.h (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/HostnameController.m (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Info.plist (added) * mDNSResponder/mDNSMacOSX/SettingsBundle/Localizable.strings (added) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponderHelper.plist (modified) * mDNSResponder/mDNSMacOSX/coreBLE.h (modified) * mDNSResponder/mDNSMacOSX/coreBLE.m (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSNetMonitor/mDNSNetMonitor.8 (added) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-xcodeproj-explanation.txt (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSMacOSX/uDNSPathEvalulation.c (modified) * mDNSResponder/mDNSPosix/ExampleClientApp.c (modified) * mDNSResponder/mDNSPosix/NetMonitor.c (modified) * mDNSResponder/mDNSPosix/PosixDaemon.c (modified) * mDNSResponder/mDNSPosix/ProxyResponder.c (modified) * mDNSResponder/mDNSPosix/Responder.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.h (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dns_sd_internal.h (added) * mDNSResponder/mDNSShared/dns_sd_private.h (moved) * mDNSResponder/mDNSShared/dnsextd.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/mDNSShared/uds_daemon.h (modified) * mDNSResponder/mDNSVxWorks/mDNSVxWorks.c (modified) * mDNSResponder/mDNSVxWorks/mDNSVxWorksIPv4Only.c (modified) * mDNSResponder/mDNSWindows/BonjourQuickLooks.sln (added) * mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/BonjourQuickLooksInstaller.wixproj (added) * mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/Product.wxs (added) * mDNSResponder/mDNSWindows/WinVersRes.h (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) * mDNSResponder/unittests/CNameRecordTests.c (added) * mDNSResponder/unittests/CNameRecordTests.h (added) * mDNSResponder/unittests/LocalOnlyTimeoutTests.c (added) * mDNSResponder/unittests/LocalOnlyTimeoutTests.h (added) * mDNSResponder/unittests/ResourceRecordTest.c (modified) * mDNSResponder/unittests/daemon_ut.c (added) * mDNSResponder/unittests/mDNSCoreReceiveTest.c (added) * mDNSResponder/unittests/mDNSCoreReceiveTest.h (added) * mDNSResponder/unittests/main.c (modified) * mDNSResponder/unittests/mdns_macosx_ut.c (added) * mDNSResponder/unittests/mdns_ut.c (added) * mDNSResponder/unittests/uds_daemon_ut.c (added) * mDNSResponder/unittests/unittest.h (modified) * mDNSResponder/unittests/unittest_common.c (added) * mDNSResponder/unittests/unittest_common.h (added) mDNSResponder: Update to v878.1.1 The sources can be obtained via: ... Wed, 19 Sep 2018 06:55:35 GMT Sebastian Huber [a814950] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnsproxy.h (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnsextd.c (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) mDNSResponder: Update to v765.50.9 The sources can be obtained via: ... Wed, 19 Sep 2018 06:54:52 GMT Sebastian Huber [7d33d36] * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSPosix/Responder.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSUNP.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) mDNSResponder: Update to v765.30.11 The sources can be obtained ... Wed, 19 Sep 2018 06:54:13 GMT Sebastian Huber [fc605b3] * mDNSResponder/.gitignore (added) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) mDNSResponder: Update to v765.20.4 The sources can be obtained via: ... Wed, 19 Sep 2018 06:53:26 GMT Sebastian Huber [f01edf1] * libbsd.py (modified) * mDNSResponder/Clients/ClientCommon.c (modified) * mDNSResponder/Clients/Java/nmakefile (modified) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/52D711AF-4055-4867-A494-7E31552BB9E1.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/Screen Shot 2015-09-16 at 3.36.23 PM.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/Screen Shot 2015-09-16 at 3.46.14 PM.png (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/TXT.rtf (added) * mDNSResponder/Documents/Attach mDNSResponder to Xcode.rtfd/unknown.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/A944EB40-AEFD-4CA1-BF10-E8F52835CA8C.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/Screen Shot 2015-09-16 at 4.22.37 PM.png (added) * mDNSResponder/Documents/Start mDNSResponder in Xcode.rtfd/TXT.rtf (added) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnssec.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/nsec3.c (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSCore/uDNS.h (modified) * mDNSResponder/mDNSMacOSX/BLE.c (added) * mDNSResponder/mDNSMacOSX/BLE.h (added) * mDNSResponder/mDNSMacOSX/DNSProxySupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryDefines.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryReply.defs (deleted) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryRequest.defs (deleted) * mDNSResponder/mDNSMacOSX/Metrics.h (modified) * mDNSResponder/mDNSMacOSX/Metrics.m (modified) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.c (modified) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.h (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/ConfigurationAuthority.c (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.c (modified) * mDNSResponder/mDNSMacOSX/Private/com.apple.mDNSResponder.plist (added) * mDNSResponder/mDNSMacOSX/Private/dns_sd_private.h (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.h (modified) * mDNSResponder/mDNSMacOSX/Private/dns_xpc.h (modified) * mDNSResponder/mDNSMacOSX/Private/dnsctl_server.c (added) * mDNSResponder/mDNSMacOSX/Private/xpc_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/xpc_services.h (modified) * mDNSResponder/mDNSMacOSX/SymptomReporter.c (modified) * mDNSResponder/mDNSMacOSX/com.apple.dnsextd.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponder.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponderHelper.plist (modified) * mDNSResponder/mDNSMacOSX/com.apple.networking.mDNSResponder (deleted) * mDNSResponder/mDNSMacOSX/coreBLE.h (added) * mDNSResponder/mDNSMacOSX/coreBLE.m (added) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/dnsctl-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/helper-error.h (deleted) * mDNSResponder/mDNSMacOSX/helper-main.c (modified) * mDNSResponder/mDNSMacOSX/helper-server.h (modified) * mDNSResponder/mDNSMacOSX/helper-stubs.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/helper.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg-types.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg.defs (deleted) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/xcshareddata/xcschemes/Build All.xcscheme (added) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/xcshareddata/xcschemes/mDNSResponder.xcscheme (added) * mDNSResponder/mDNSMacOSX/mDNSResponderLogging.mobileconfig (deleted) * mDNSResponder/mDNSMacOSX/uDNSPathEvalulation.c (modified) * mDNSResponder/mDNSPosix/._ReadMe.txt (deleted) * mDNSResponder/mDNSPosix/Makefile (modified) * mDNSResponder/mDNSPosix/ReadMe.txt (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mdnsd.sh (modified) * mDNSResponder/mDNSPosix/nss_mdns.c (modified) * mDNSResponder/mDNSShared/PlatformCommon.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.h (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/mDNSShared/uds_daemon.h (modified) * mDNSResponder/mDNSWindows/ControlPanel/ConfigPropertySheet.cpp (modified) * mDNSResponder/mDNSWindows/ControlPanel/ControlPanelExe.cpp (modified) * mDNSResponder/mDNSWindows/ControlPanel/FourthPage.cpp (modified) * mDNSResponder/mDNSWindows/DLLStub/DLLStub.cpp (modified) * mDNSResponder/mDNSWindows/DLLX/DNSSD.cpp (modified) * mDNSResponder/mDNSWindows/DNSServiceBrowser/Windows/Sources/ChooserDialog.cpp (modified) * mDNSResponder/mDNSWindows/DNSServiceBrowser/WindowsCE/Sources/BrowserDialog.cpp (modified) * mDNSResponder/mDNSWindows/Java/makefile (modified) * mDNSResponder/mDNSWindows/Java/makefile64 (modified) * mDNSResponder/mDNSWindows/NSPTool/NSPTool.c (modified) * mDNSResponder/mDNSWindows/SystemService/Service.c (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) * mDNSResponder/mDNSWindows/mdnsNSP/mdnsNSP.c (modified) * mDNSResponder/unittests/DNSMessageTest.c (added) * mDNSResponder/unittests/DNSMessageTest.h (added) * mDNSResponder/unittests/DomainNameTest.c (added) * mDNSResponder/unittests/DomainNameTest.h (added) * mDNSResponder/unittests/InterfaceTest.c (added) * mDNSResponder/unittests/InterfaceTest.h (added) * mDNSResponder/unittests/ResourceRecordTest.c (added) * mDNSResponder/unittests/ResourceRecordTest.h (added) * mDNSResponder/unittests/main.c (added) * mDNSResponder/unittests/unittest.c (added) * mDNSResponder/unittests/unittest.h (added) * rtemsbsd/mdns/mDNSResolveService.c (added) mDNSResponder: Update to v765.1.2 The sources can be obtained via: ... Wed, 19 Sep 2018 06:52:21 GMT Sebastian Huber [f761b29] * mDNSResponder/.DS_Store (modified) * mDNSResponder/Clients/ClientCommon.c (modified) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/CryptoAlg.c (modified) * mDNSResponder/mDNSCore/CryptoAlg.h (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/DNSCommon.h (modified) * mDNSResponder/mDNSCore/DNSDigest.c (modified) * mDNSResponder/mDNSCore/anonymous.c (modified) * mDNSResponder/mDNSCore/anonymous.h (modified) * mDNSResponder/mDNSCore/dnsproxy.c (modified) * mDNSResponder/mDNSCore/dnsproxy.h (modified) * mDNSResponder/mDNSCore/dnssec.c (modified) * mDNSResponder/mDNSCore/dnssec.h (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSDebug.h (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/nsec.c (modified) * mDNSResponder/mDNSCore/nsec.h (modified) * mDNSResponder/mDNSCore/nsec3.c (modified) * mDNSResponder/mDNSCore/nsec3.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOS9/Mac OS Test Responder.c (deleted) * mDNSResponder/mDNSMacOS9/Mac OS Test Searcher.c (deleted) * mDNSResponder/mDNSMacOS9/README.txt (deleted) * mDNSResponder/mDNSMacOS9/Responder.c (deleted) * mDNSResponder/mDNSMacOS9/Searcher.c (deleted) * mDNSResponder/mDNSMacOS9/ShowInitIcon.c (deleted) * mDNSResponder/mDNSMacOS9/ShowInitIcon.h (deleted) * mDNSResponder/mDNSMacOS9/SubTypeTester.c (deleted) * mDNSResponder/mDNSMacOS9/mDNS.mcp (deleted) * mDNSResponder/mDNSMacOS9/mDNSLibrary.c (deleted) * mDNSResponder/mDNSMacOS9/mDNSLibraryLoader.c (deleted) * mDNSResponder/mDNSMacOS9/mDNSLibraryResources.r (deleted) * mDNSResponder/mDNSMacOS9/mDNSMacOS9.c (deleted) * mDNSResponder/mDNSMacOS9/mDNSMacOS9.h (deleted) * mDNSResponder/mDNSMacOS9/mDNSPrefix.h (deleted) * mDNSResponder/mDNSMacOSX/BonjourEvents.c (modified) * mDNSResponder/mDNSMacOSX/CUPolicy.c (deleted) * mDNSResponder/mDNSMacOSX/CryptoSupport.c (modified) * mDNSResponder/mDNSMacOSX/CryptoSupport.h (modified) * mDNSResponder/mDNSMacOSX/DNSProxySupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.c (modified) * mDNSResponder/mDNSMacOSX/DNSSECSupport.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.c (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscovery.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryDefines.h (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryReply.defs (modified) * mDNSResponder/mDNSMacOSX/DNSServiceDiscoveryRequest.defs (modified) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo-Tiger.helper.plist (deleted) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo-Tiger.plist (deleted) * mDNSResponder/mDNSMacOSX/LegacyNATTraversal.c (modified) * mDNSResponder/mDNSMacOSX/Metrics.h (moved) * mDNSResponder/mDNSMacOSX/Metrics.m (added) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.c (modified) * mDNSResponder/mDNSMacOSX/P2PPacketFilter.h (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/DNSServiceDiscoveryPref.m (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/English.lproj/InfoPlist.strings (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/PrivilegedOperations.c (modified) * mDNSResponder/mDNSMacOSX/PreferencePane/ddnswriteconfig.m (modified) * mDNSResponder/mDNSMacOSX/Private/dns_sd_private.h (added) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.h (modified) * mDNSResponder/mDNSMacOSX/Private/dns_xpc.h (modified) * mDNSResponder/mDNSMacOSX/Private/xpc_services.c (modified) * mDNSResponder/mDNSMacOSX/SymptomReporter.c (added) * mDNSResponder/mDNSMacOSX/VPNService.c (deleted) * mDNSResponder/mDNSMacOSX/base.xcconfig (deleted) * mDNSResponder/mDNSMacOSX/com.apple.dnsextd.plist (moved) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponder.plist (moved) * mDNSResponder/mDNSMacOSX/com.apple.mDNSResponderHelper.plist (moved) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/helper-error.h (modified) * mDNSResponder/mDNSMacOSX/helper-main.c (modified) * mDNSResponder/mDNSMacOSX/helper-server.h (modified) * mDNSResponder/mDNSMacOSX/helper-stubs.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/helper.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg-types.h (modified) * mDNSResponder/mDNSMacOSX/helpermsg.defs (modified) * mDNSResponder/mDNSMacOSX/ipsec_strerror.h (modified) * mDNSResponder/mDNSMacOSX/libpfkey.h (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.pbproj/project.pbxproj (deleted) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSMacOSX/mDNSResponderHelper.8 (modified) * mDNSResponder/mDNSMacOSX/pfkey.c (modified) * mDNSResponder/mDNSMacOSX/uDNSPathEvalulation.c (added) * mDNSResponder/mDNSPosix/._ReadMe.txt (added) * mDNSResponder/mDNSPosix/Identify.c (modified) * mDNSResponder/mDNSPosix/Makefile (modified) * mDNSResponder/mDNSPosix/ReadMe.txt (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSUNP.c (modified) * mDNSResponder/mDNSPosix/mdnsd.sh (modified) * mDNSResponder/mDNSPosix/nss_mdns.c (modified) * mDNSResponder/mDNSShared/CommonServices.h (modified) * mDNSResponder/mDNSShared/DebugServices.c (modified) * mDNSResponder/mDNSShared/GenLinkedList.c (modified) * mDNSResponder/mDNSShared/PlatformCommon.c (modified) * mDNSResponder/mDNSShared/dns-sd.1 (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnsextd.8 (modified) * mDNSResponder/mDNSShared/dnsextd.c (modified) * mDNSResponder/mDNSShared/dnsextd_lexer.l (modified) * mDNSResponder/mDNSShared/dnsextd_parser.y (modified) * mDNSResponder/mDNSShared/dnssd_clientlib.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.h (modified) * mDNSResponder/mDNSShared/mDNSDebug.c (modified) * mDNSResponder/mDNSShared/mDNSResponder.8 (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) * mDNSResponder/mDNSShared/uds_daemon.h (modified) * mDNSResponder/mDNSWindows/mDNSWin32.c (modified) mDNSResponder: Update to v625.41.2 The sources can be obtained via: ... Thu, 20 Sep 2018 09:12:30 GMT Sebastian Huber [49ebc73] * mDNSResponder/Clients/.DS_Store (deleted) * mDNSResponder/Clients/._.DS_Store (deleted) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/CUPolicy.c (modified) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.helper.plist (modified) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.plist (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.h (moved) * mDNSResponder/mDNSMacOSX/VPNService.c (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder-entitlements.plist (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.sb (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/uds_daemon.c (modified) mDNSResponder: Update to v576.30.4 The sources can be obtained via: ... Wed, 19 Sep 2018 06:49:34 GMT Sebastian Huber [e36ca10] * mDNSResponder/.DS_Store (added) * mDNSResponder/._.DS_Store (added) * mDNSResponder/Clients/.DS_Store (added) * mDNSResponder/Clients/._.DS_Store (added) * mDNSResponder/Clients/Makefile (modified) * mDNSResponder/Clients/dns-sd.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSCore/DNSCommon.c (modified) * mDNSResponder/mDNSCore/mDNS.c (modified) * mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h (modified) * mDNSResponder/mDNSCore/uDNS.c (modified) * mDNSResponder/mDNSMacOSX/base.xcconfig (modified) * mDNSResponder/mDNSMacOSX/daemon.c (modified) * mDNSResponder/mDNSMacOSX/helper.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.h (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSPosix/Makefile (modified) * mDNSResponder/mDNSPosix/NetMonitor.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) * mDNSResponder/mDNSPosix/mDNSPosix.h (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientshim.c (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) mDNSResponder: Update to v567 The sources can be obtained via: ... Wed, 19 Sep 2018 06:43:53 GMT Sebastian Huber [111789e] * mDNSResponder/Clients/dnsctl.c (modified) * mDNSResponder/Makefile (modified) * mDNSResponder/mDNSMacOSX/BonjourEvents.c (modified) * mDNSResponder/mDNSMacOSX/LaunchDaemonInfo.plist (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services.c (modified) * mDNSResponder/mDNSMacOSX/Private/dns_services_mdns.h (moved) * mDNSResponder/mDNSMacOSX/base.xcconfig (added) * mDNSResponder/mDNSMacOSX/mDNSMacOSX.c (modified) * mDNSResponder/mDNSMacOSX/mDNSResponder.xcodeproj/project.pbxproj (modified) * mDNSResponder/mDNSShared/dns_sd.h (modified) * mDNSResponder/mDNSShared/dnssd_clientstub.c (modified) * mDNSResponder/mDNSShared/dnssd_ipc.h (modified) mDNSResponder: Update to v561.1.1 The sources can be obtained via: ... Thu, 20 Sep 2018 08:32:22 GMT Sebastian Huber [152d81f] * rtemsbsd/mdns/mdns.c (modified) mDNSResponder: Increase stack size The current stack size was ... Thu, 20 Sep 2018 08:23:48 GMT Sebastian Huber [3f09126] * rtemsbsd/mdns/mdns.c (modified) mDNSResponder: Use FPU enabled task Thu, 20 Sep 2018 08:22:53 GMT Sebastian Huber [ed40c80] * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) mDNSResponder: Fix gAllocatedEventFDs allocation Mon, 17 Sep 2018 07:47:20 GMT Sebastian Huber [4d8f9e6] * mDNSResponder/mDNSPosix/mDNSPosix.c (modified) mDNSResponder: Honour file descriptor maximum Dynamically allocate ... Mon, 17 Sep 2018 08:04:28 GMT Sebastian Huber [48cbe6c] * rtemsbsd/include/poll.h (deleted) Remove This header file is provided by RTEMS. Fri, 04 Aug 2017 12:32:19 GMT Sebastian Huber [a85d900] * freebsd/sys/kern/kern_timeout.c (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) Optimize callout handline via static timer wheel The number of ... Fri, 14 Sep 2018 11:46:50 GMT Sebastian Huber [cf447b9] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/_callout.h (modified) Remove struct callout::c_cpu This is an optimization of the callout ... Wed, 12 Sep 2018 06:04:59 GMT Sebastian Huber [08fbf18] * rtemsbsd/rtems/rtems-kernel-irqs.c (modified) Initialize interrupt server earlier This allows to initialize other ... Thu, 06 Sep 2018 08:50:03 GMT Sebastian Huber [6e5b088] * libbsd.py (modified) * rtemsbsd/rtems/rtems-kernel-mtxpool.c (added) Move dynamic mutex pool to separate file This avoids false ... Thu, 06 Sep 2018 08:51:44 GMT Sebastian Huber [3b8f03b] * rtemsbsd/include/machine/bus.h (modified) Fix BUS_SPACE_MAXADDR for 64-bit targets Thu, 30 Aug 2018 08:44:25 GMT Sebastian Huber [3990b45] * rtemsbsd/include/machine/cpu.h (modified) Use rtems_counter_read() for get_cyclecount() Tue, 11 Sep 2018 09:24:25 GMT Sebastian Huber [0f9d58f] * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) dw_mmc: Avoid conflicting device ivars Do not overwrite the device ... Mon, 10 Sep 2018 13:07:57 GMT Sebastian Huber [f56067e] * rtemsbsd/rtems/rtems-kernel-vprintf.c (modified) vprintf: Avoid printf() to avoid FPU usage Fri, 31 Aug 2018 05:00:11 GMT Sebastian Huber [f7d6bd2] * userspace-header-gen.py (modified) userspace-header-gen.py: Revert interpreter change Tue, 28 Aug 2018 12:15:47 GMT Sebastian Huber [b6c64e1] * Makefile.todo (modified) * freebsd/bin/stty/rtems-bsd-stty-key-data.h (modified) * freebsd/bin/stty/rtems-bsd-stty-namespace.h (modified) * freebsd/bin/stty/rtems-bsd-stty-print-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-addrtoname-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-namespace.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-802_11-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-dccp-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-egp-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-isakmp-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-nfs-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-radius-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-rx-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-sl-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-snmp-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-print-telnet-data.h (modified) * freebsd/contrib/tcpdump/rtems-bsd-tcpdump-tcpdump-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_inet-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_inet6-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-af_link-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifbridge-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifconfig-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgif-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgre-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifgroup-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifieee80211-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-iflagg-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmac-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifmedia-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifpfsync-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-ifvlan-data.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-namespace.h (modified) * freebsd/sbin/ifconfig/rtems-bsd-ifconfig-sfp-data.h (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.y (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-namespace.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-parse-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_altq-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_optimize-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_osfp-data.h (modified) * freebsd/sbin/pfctl/rtems-bsd-pfctl-pfctl_table-data.h (modified) * freebsd/sbin/ping/rtems-bsd-ping-ping-data.h (modified) * freebsd/sbin/ping6/rtems-bsd-ping6-ping6-data.h (modified) * freebsd/sbin/route/rtems-bsd-route-route-data.h (modified) * freebsd/sbin/sysctl/rtems-bsd-sysctl-sysctl-data.h (modified) * freebsd/tools/tools/net80211/wlanstats/rtems-bsd-wlanstats-namespace.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-data.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-inet-data.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-inet6-data.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-main-data.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-namespace.h (modified) * freebsd/usr.bin/netstat/rtems-bsd-netstat-route-data.h (modified) * freebsd/usr.sbin/arp/rtems-bsd-arp-arp-data.h (modified) Regenerate program header files Tue, 28 Aug 2018 12:14:27 GMT Sebastian Huber [b2e1123] * userspace-header-gen.py (modified) userspace-header-gen.py: Sort file content Sort the file content to ... Tue, 28 Aug 2018 10:51:49 GMT Sebastian Huber [43a39b7] * testsuite/syscalls01/test_main.c (modified) syscalls01: Fix for IPSEC enabled Tue, 28 Aug 2018 10:00:46 GMT Sebastian Huber [fa3e012] * Makefile.todo (modified) * freebsd/lib/libc/net/nslexer.c (modified) * freebsd/lib/libc/net/nsparser.c (modified) * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.h (modified) Update yacc and lex generated files Use the FreeBSD 11.1 yacc and ... Tue, 28 Aug 2018 07:41:00 GMT Sebastian Huber [100e66f] * freebsd/lib/libkvm/kvm.h (modified) kvaddr_t is now provided by Update #3472. Thu, 09 Aug 2018 10:59:55 GMT Sebastian Huber [dd60daa] * builder.py (modified) Allow *.c as kernel space header files This is a workaround for the ... Thu, 09 Aug 2018 06:00:16 GMT Sebastian Huber [4c22b5c] * rtemsbsd/include/machine/_kernel_if.h (added) * rtemsbsd/include/machine/_kernel_socket.h (added) Add FreeBSD kernel space header files Move the kernel space content ... Thu, 23 Aug 2018 06:38:20 GMT Sebastian Huber [ee738dd] * freebsd/contrib/wpa/src/rsn_supp/tdls.c (deleted) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c (deleted) * libbsd.py (modified) WPA_SUPPLICANT(8): Remove unused files Remove unused files which ... Tue, 21 Aug 2018 08:42:25 GMT Sebastian Huber [63084c1] * buildset/default.ini (modified) * freebsd/sys/netinet6/ip_fw_nat64.h (deleted) * freebsd/sys/netinet6/ip_fw_nptv6.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm_codel.h (deleted) * freebsd/sys/netpfil/ipfw/dn_aqm_pie.h (deleted) * freebsd/sys/netpfil/ipfw/dn_heap.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_fq_codel.h (deleted) * freebsd/sys/netpfil/ipfw/dn_sched_fq_codel_helper.h (deleted) * freebsd/sys/netpfil/ipfw/ip_dn_private.h (deleted) * freebsd/sys/netpfil/ipfw/ip_fw2.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_bpf.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_dynamic.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_eaction.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_iface.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_pfil.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table.h (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table_algo.c (deleted) * freebsd/sys/netpfil/ipfw/ip_fw_table_value.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/ip_fw_nat64.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64_translate.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64lsn_control.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.c (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl.h (deleted) * freebsd/sys/netpfil/ipfw/nat64/nat64stl_control.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/ip_fw_nptv6.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.c (deleted) * freebsd/sys/netpfil/ipfw/nptv6/nptv6.h (deleted) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) IPFW(4): Remove FreeBSD import This firewall was not ported to ... Mon, 20 Aug 2018 13:19:56 GMT Sebastian Huber [f62c62d] * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) Update rtems-bsd-kernel-namespace.h Update #3472. Fri, 24 Aug 2018 07:06:14 GMT Sebastian Huber [0963419] * freebsd/sys/kern/uipc_syscalls.c (modified) Fix alignment of getsockaddr_sockaddr Fri, 24 Aug 2018 06:55:00 GMT Sebastian Huber [12a885c] * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/opencrypto/crypto.c (modified) * rtemsbsd/powerpc/include/linux/time.h (modified) Update due to API changes Changes correspond to ... Mon, 20 Aug 2018 13:19:37 GMT Sebastian Huber [8e35aaa] * testsuite/termios/test_termios_utilities.c (modified) tests/termios: Fix warnings Thu, 09 Aug 2018 05:20:08 GMT Sebastian Huber [1d99262] * freebsd/sys/sys/libkern.h (modified) libkern.h: Avoid call overhead for bcmp() Mon, 06 Aug 2018 05:37:22 GMT Christian Mauderer [9bc7b96] * libbsd.txt (modified) libbsd.txt: Update version info and manpage links. The information ... Fri, 27 Jul 2018 12:39:47 GMT Christian Mauderer [afac48a] * libbsd.txt (modified) libbsd.txt: Add ipsec. Thu, 02 Aug 2018 08:22:11 GMT Christian Mauderer [baffbf3] * libbsd.py (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) * testsuite/ipsec01/README (added) * testsuite/ipsec01/setup_FreeBSD_as_communication_partner.sh (added) * testsuite/ipsec01/test_main.c (added) testsuite/ipsec01: Add. Thu, 02 Aug 2018 08:23:15 GMT Christian Mauderer [028bf82] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc.conf: Fix cloned interface setup. The cloned interfaces have to ... Thu, 02 Aug 2018 06:44:14 GMT Christian Mauderer [c7eec93] * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) Add RTEMS_BSD_CONFIG_IPSEC. Mon, 30 Jul 2018 15:02:59 GMT Christian Mauderer [1b467ad] * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/include/rtems/ipsec.h (added) * rtemsbsd/rtems/rtems-bsd-racoon.c (added) * rtemsbsd/rtems/rtems-bsd-rc-conf-ipsec.c (added) Add ipsec to rc.conf. Wed, 13 Jun 2018 09:11:03 GMT Christian Mauderer [5e13963] * buildset/everything.ini (modified) buildset/everything: Add some usefull comments. Thu, 03 May 2018 12:15:11 GMT Christian Mauderer [b376ae1] * freebsd/lib/libipsec/ipsec_dump_policy.c (deleted) * freebsd/lib/libipsec/ipsec_strerror.c (deleted) * freebsd/lib/libipsec/ipsec_strerror.h (deleted) * freebsd/lib/libipsec/libpfkey.h (deleted) * freebsd/lib/libipsec/pfkey.c (deleted) * freebsd/lib/libipsec/pfkey_dump.c (deleted) * freebsd/lib/libipsec/policy_parse.c (deleted) * freebsd/lib/libipsec/policy_parse.y (deleted) * freebsd/lib/libipsec/policy_token.c (deleted) * freebsd/lib/libipsec/policy_token.l (deleted) * freebsd/lib/libipsec/y.tab.h (deleted) * ipsec-tools/src/config.h (added) * ipsec-tools/src/libipsec/config.h (added) * ipsec-tools/src/libipsec/ipsec_dump_policy.c (modified) * ipsec-tools/src/libipsec/ipsec_get_policylen.c (modified) * ipsec-tools/src/libipsec/ipsec_strerror.c (modified) * ipsec-tools/src/libipsec/key_debug.c (modified) * ipsec-tools/src/libipsec/libpfkey.h (modified) * ipsec-tools/src/libipsec/pfkey.c (modified) * ipsec-tools/src/libipsec/pfkey_dump.c (modified) * ipsec-tools/src/libipsec/policy_parse.c (modified) * ipsec-tools/src/libipsec/policy_parse.h (modified) * ipsec-tools/src/libipsec/policy_parse.y (modified) * ipsec-tools/src/libipsec/policy_token.c (modified) * ipsec-tools/src/libipsec/policy_token.l (modified) * ipsec-tools/src/libipsec/test-policy.c (modified) * ipsec-tools/src/racoon/admin.c (modified) * ipsec-tools/src/racoon/algorithm.c (modified) * ipsec-tools/src/racoon/algorithm.h (modified) * ipsec-tools/src/racoon/backupsa.c (modified) * ipsec-tools/src/racoon/cfparse.c (modified) * ipsec-tools/src/racoon/cfparse.h (modified) * ipsec-tools/src/racoon/cfparse_wrapper.c (added) * ipsec-tools/src/racoon/cftoken.c (modified) * ipsec-tools/src/racoon/cftoken_proto.h (modified) * ipsec-tools/src/racoon/cftoken_wrapper.c (added) * ipsec-tools/src/racoon/config.h (added) * ipsec-tools/src/racoon/crypto_openssl.c (modified) * ipsec-tools/src/racoon/dnssec.c (modified) * ipsec-tools/src/racoon/eaytest.c (modified) * ipsec-tools/src/racoon/evt.c (modified) * ipsec-tools/src/racoon/genlist.c (modified) * ipsec-tools/src/racoon/getcertsbyname.c (modified) * ipsec-tools/src/racoon/grabmyaddr.c (modified) * ipsec-tools/src/racoon/gssapi.c (modified) * ipsec-tools/src/racoon/handler.c (modified) * ipsec-tools/src/racoon/ipsec_doi.c (modified) * ipsec-tools/src/racoon/isakmp.c (modified) * ipsec-tools/src/racoon/isakmp_agg.c (modified) * ipsec-tools/src/racoon/isakmp_base.c (modified) * ipsec-tools/src/racoon/isakmp_cfg.c (modified) * ipsec-tools/src/racoon/isakmp_frag.c (modified) * ipsec-tools/src/racoon/isakmp_ident.c (modified) * ipsec-tools/src/racoon/isakmp_inf.c (modified) * ipsec-tools/src/racoon/isakmp_newg.c (modified) * ipsec-tools/src/racoon/isakmp_quick.c (modified) * ipsec-tools/src/racoon/isakmp_unity.c (modified) * ipsec-tools/src/racoon/isakmp_xauth.c (modified) * ipsec-tools/src/racoon/kmpstat.c (modified) * ipsec-tools/src/racoon/localconf.c (modified) * ipsec-tools/src/racoon/logger.c (modified) * ipsec-tools/src/racoon/main.c (modified) * ipsec-tools/src/racoon/misc.c (modified) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-alg-fst.c (modified) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-api-fst.c (modified) * ipsec-tools/src/racoon/missing/crypto/sha2/config.h (added) * ipsec-tools/src/racoon/missing/crypto/sha2/sha2.c (modified) * ipsec-tools/src/racoon/nattraversal.c (modified) * ipsec-tools/src/racoon/oakley.c (modified) * ipsec-tools/src/racoon/package_version.h (added) * ipsec-tools/src/racoon/pfkey.c (modified) * ipsec-tools/src/racoon/plainrsa-gen.c (modified) * ipsec-tools/src/racoon/plog.c (modified) * ipsec-tools/src/racoon/policy.c (modified) * ipsec-tools/src/racoon/privsep.c (modified) * ipsec-tools/src/racoon/proposal.c (modified) * ipsec-tools/src/racoon/prsa_par.c (modified) * ipsec-tools/src/racoon/prsa_par.h (modified) * ipsec-tools/src/racoon/prsa_par.y (modified) * ipsec-tools/src/racoon/prsa_par_wrapper.c (added) * ipsec-tools/src/racoon/prsa_tok.c (modified) * ipsec-tools/src/racoon/prsa_tok.l (modified) * ipsec-tools/src/racoon/prsa_tok_wrapper.c (added) * ipsec-tools/src/racoon/racoonctl.c (modified) * ipsec-tools/src/racoon/remoteconf.c (modified) * ipsec-tools/src/racoon/rsalist.c (modified) * ipsec-tools/src/racoon/rtems-bsd-racoon-admin-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-algorithm-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-backupsa-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-cfparse_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-cftoken_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-crypto_openssl-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-dnssec-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-evt-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-genlist-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-getcertsbyname-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-grabmyaddr-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-gssapi-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-handler-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-ipsec_doi-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_agg-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_base-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_frag-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_ident-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_inf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_newg-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-isakmp_quick-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-localconf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-logger-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-main-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-misc-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-namespace.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-nattraversal-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-oakley-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-pfkey-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-plog-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-policy-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-privsep-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-proposal-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-prsa_par_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-prsa_tok_wrapper-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-remoteconf-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-rsalist-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-safefile-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sainfo-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-schedule-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sha2-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-sockmisc-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-str2val-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-strnames-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-vendorid-data.h (added) * ipsec-tools/src/racoon/rtems-bsd-racoon-vmbuf-data.h (added) * ipsec-tools/src/racoon/safefile.c (modified) * ipsec-tools/src/racoon/sainfo.c (modified) * ipsec-tools/src/racoon/schedule.c (modified) * ipsec-tools/src/racoon/security.c (modified) * ipsec-tools/src/racoon/session.c (modified) * ipsec-tools/src/racoon/sockmisc.c (modified) * ipsec-tools/src/racoon/sockmisc.h (modified) * ipsec-tools/src/racoon/str2val.c (modified) * ipsec-tools/src/racoon/strnames.c (modified) * ipsec-tools/src/racoon/throttle.c (modified) * ipsec-tools/src/racoon/vendorid.c (modified) * ipsec-tools/src/racoon/vmbuf.c (modified) * ipsec-tools/src/setkey/config.h (added) * ipsec-tools/src/setkey/package_version.h (added) * ipsec-tools/src/setkey/parse.c (modified) * ipsec-tools/src/setkey/parse.h (modified) * ipsec-tools/src/setkey/parse.y (modified) * ipsec-tools/src/setkey/parse_wrapper.c (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-namespace.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-parse_wrapper-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-setkey-data.h (added) * ipsec-tools/src/setkey/rtems-bsd-setkey-token_wrapper-data.h (added) * ipsec-tools/src/setkey/setkey.c (modified) * ipsec-tools/src/setkey/token.c (modified) * ipsec-tools/src/setkey/token_wrapper.c (added) * libbsd.py (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/machine/rtems-bsd-racoon.h (moved) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-racoon.c (added) * rtemsbsd/rtems/rtems-bsd-shell-setkey.c (added) * rtemsbsd/rtems/rtems-kernel-wpa-supplicant.c (modified) * rtemsbsd/rtems/rtems-racoon-mutex.c (added) * testsuite/media01/test_main.c (modified) ipsec-tools: Port libipsec, setkey and racoon. Note that this ... Wed, 06 Jun 2018 09:11:52 GMT Christian Mauderer [8645c9d7] * ipsec-tools/src/libipsec/libpfkey.h (modified) * ipsec-tools/src/libipsec/pfkey.c (modified) * ipsec-tools/src/racoon/gssapi.c (modified) * ipsec-tools/src/racoon/handler.h (modified) * ipsec-tools/src/racoon/isakmp.c (modified) * ipsec-tools/src/racoon/isakmp_cfg.c (modified) * ipsec-tools/src/racoon/isakmp_frag.c (modified) * ipsec-tools/src/racoon/isakmp_inf.c (modified) * ipsec-tools/src/racoon/isakmp_quick.c (modified) * ipsec-tools/src/racoon/localconf.c (modified) * ipsec-tools/src/racoon/nattraversal.c (modified) * ipsec-tools/src/racoon/pfkey.c (modified) ipsec-tools: Apply patches from FreeBSD ports. Source: ... Wed, 30 May 2018 12:27:35 GMT Christian Mauderer [ff36f5e] * ipsec-tools/ChangeLog (added) * ipsec-tools/ChangeLog.old (added) * ipsec-tools/Makefile.am (added) * ipsec-tools/Makefile.in (added) * ipsec-tools/NEWS (added) * ipsec-tools/README (added) * ipsec-tools/aclocal.m4 (added) * ipsec-tools/acracoon.m4 (added) * ipsec-tools/bootstrap (added) * ipsec-tools/compile (added) * ipsec-tools/config.guess (added) * ipsec-tools/config.h.in (added) * ipsec-tools/config.sub (added) * ipsec-tools/configure (added) * ipsec-tools/configure.ac (added) * ipsec-tools/depcomp (added) * ipsec-tools/install-sh (added) * ipsec-tools/ltmain.sh (added) * ipsec-tools/missing (added) * ipsec-tools/package_version.h.in (added) * ipsec-tools/rpm/Makefile.am (added) * ipsec-tools/rpm/Makefile.in (added) * ipsec-tools/rpm/ipsec-tools.spec.in (added) * ipsec-tools/rpm/suse/Makefile.am (added) * ipsec-tools/rpm/suse/Makefile.in (added) * ipsec-tools/rpm/suse/ipsec-tools.spec (added) * ipsec-tools/rpm/suse/ipsec-tools.spec.in (added) * ipsec-tools/rpm/suse/racoon.init (added) * ipsec-tools/rpm/suse/sysconfig.racoon (added) * ipsec-tools/src/Makefile.am (added) * ipsec-tools/src/Makefile.in (added) * ipsec-tools/src/include-glibc/Makefile.am (added) * ipsec-tools/src/include-glibc/Makefile.in (added) * ipsec-tools/src/include-glibc/glibc-bugs.h (added) * ipsec-tools/src/include-glibc/net/pfkeyv2.h (added) * ipsec-tools/src/include-glibc/netinet/ipsec.h (added) * ipsec-tools/src/include-glibc/sys/queue.h (added) * ipsec-tools/src/libipsec/Makefile.am (added) * ipsec-tools/src/libipsec/Makefile.in (added) * ipsec-tools/src/libipsec/ipsec_dump_policy.c (added) * ipsec-tools/src/libipsec/ipsec_get_policylen.c (added) * ipsec-tools/src/libipsec/ipsec_set_policy.3 (added) * ipsec-tools/src/libipsec/ipsec_strerror.3 (added) * ipsec-tools/src/libipsec/ipsec_strerror.c (added) * ipsec-tools/src/libipsec/ipsec_strerror.h (added) * ipsec-tools/src/libipsec/key_debug.c (added) * ipsec-tools/src/libipsec/libpfkey.h (added) * ipsec-tools/src/libipsec/pfkey.c (added) * ipsec-tools/src/libipsec/pfkey_dump.c (added) * ipsec-tools/src/libipsec/policy_parse.c (added) * ipsec-tools/src/libipsec/policy_parse.h (added) * ipsec-tools/src/libipsec/policy_parse.y (added) * ipsec-tools/src/libipsec/policy_token.c (added) * ipsec-tools/src/libipsec/policy_token.l (added) * ipsec-tools/src/libipsec/test-policy.c (added) * ipsec-tools/src/racoon/Makefile.am (added) * ipsec-tools/src/racoon/Makefile.in (added) * ipsec-tools/src/racoon/TODO (added) * ipsec-tools/src/racoon/admin.c (added) * ipsec-tools/src/racoon/admin.h (added) * ipsec-tools/src/racoon/admin_var.h (added) * ipsec-tools/src/racoon/algorithm.c (added) * ipsec-tools/src/racoon/algorithm.h (added) * ipsec-tools/src/racoon/backupsa.c (added) * ipsec-tools/src/racoon/backupsa.h (added) * ipsec-tools/src/racoon/cfparse.c (added) * ipsec-tools/src/racoon/cfparse.h (added) * ipsec-tools/src/racoon/cfparse.y (added) * ipsec-tools/src/racoon/cfparse_proto.h (added) * ipsec-tools/src/racoon/cftoken.c (added) * ipsec-tools/src/racoon/cftoken.l (added) * ipsec-tools/src/racoon/cftoken_proto.h (added) * ipsec-tools/src/racoon/contrib/sp.pl (added) * ipsec-tools/src/racoon/crypto_openssl.c (added) * ipsec-tools/src/racoon/crypto_openssl.h (added) * ipsec-tools/src/racoon/debug.h (added) * ipsec-tools/src/racoon/debugrm.h (added) * ipsec-tools/src/racoon/dhgroup.h (added) * ipsec-tools/src/racoon/dnssec.c (added) * ipsec-tools/src/racoon/dnssec.h (added) * ipsec-tools/src/racoon/doc/FAQ (added) * ipsec-tools/src/racoon/doc/README.certificate (added) * ipsec-tools/src/racoon/doc/README.gssapi (added) * ipsec-tools/src/racoon/doc/README.plainrsa (added) * ipsec-tools/src/racoon/doc/README.privsep (added) * ipsec-tools/src/racoon/dump.h (added) * ipsec-tools/src/racoon/eaytest.c (added) * ipsec-tools/src/racoon/evt.c (added) * ipsec-tools/src/racoon/evt.h (added) * ipsec-tools/src/racoon/gcmalloc.h (added) * ipsec-tools/src/racoon/genlist.c (added) * ipsec-tools/src/racoon/genlist.h (added) * ipsec-tools/src/racoon/getcertsbyname.c (added) * ipsec-tools/src/racoon/gnuc.h (added) * ipsec-tools/src/racoon/grabmyaddr.c (added) * ipsec-tools/src/racoon/grabmyaddr.h (added) * ipsec-tools/src/racoon/gssapi.c (added) * ipsec-tools/src/racoon/gssapi.h (added) * ipsec-tools/src/racoon/handler.c (added) * ipsec-tools/src/racoon/handler.h (added) * ipsec-tools/src/racoon/ipsec_doi.c (added) * ipsec-tools/src/racoon/ipsec_doi.h (added) * ipsec-tools/src/racoon/isakmp.c (added) * ipsec-tools/src/racoon/isakmp.h (added) * ipsec-tools/src/racoon/isakmp_agg.c (added) * ipsec-tools/src/racoon/isakmp_agg.h (added) * ipsec-tools/src/racoon/isakmp_base.c (added) * ipsec-tools/src/racoon/isakmp_base.h (added) * ipsec-tools/src/racoon/isakmp_cfg.c (added) * ipsec-tools/src/racoon/isakmp_cfg.h (added) * ipsec-tools/src/racoon/isakmp_frag.c (added) * ipsec-tools/src/racoon/isakmp_frag.h (added) * ipsec-tools/src/racoon/isakmp_ident.c (added) * ipsec-tools/src/racoon/isakmp_ident.h (added) * ipsec-tools/src/racoon/isakmp_inf.c (added) * ipsec-tools/src/racoon/isakmp_inf.h (added) * ipsec-tools/src/racoon/isakmp_newg.c (added) * ipsec-tools/src/racoon/isakmp_newg.h (added) * ipsec-tools/src/racoon/isakmp_quick.c (added) * ipsec-tools/src/racoon/isakmp_quick.h (added) * ipsec-tools/src/racoon/isakmp_unity.c (added) * ipsec-tools/src/racoon/isakmp_unity.h (added) * ipsec-tools/src/racoon/isakmp_var.h (added) * ipsec-tools/src/racoon/isakmp_xauth.c (added) * ipsec-tools/src/racoon/isakmp_xauth.h (added) * ipsec-tools/src/racoon/kmpstat.c (added) * ipsec-tools/src/racoon/localconf.c (added) * ipsec-tools/src/racoon/localconf.h (added) * ipsec-tools/src/racoon/logger.c (added) * ipsec-tools/src/racoon/logger.h (added) * ipsec-tools/src/racoon/main.c (added) * ipsec-tools/src/racoon/misc.c (added) * ipsec-tools/src/racoon/misc.h (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/boxes-fst.dat (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-alg-fst.c (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-alg-fst.h (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-api-fst.c (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael-api-fst.h (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael.h (added) * ipsec-tools/src/racoon/missing/crypto/rijndael/rijndael_local.h (added) * ipsec-tools/src/racoon/missing/crypto/sha2/sha2.c (added) * ipsec-tools/src/racoon/missing/crypto/sha2/sha2.h (added) * ipsec-tools/src/racoon/nattraversal.c (added) * ipsec-tools/src/racoon/nattraversal.h (added) * ipsec-tools/src/racoon/netdb_dnssec.h (added) * ipsec-tools/src/racoon/oakley.c (added) * ipsec-tools/src/racoon/oakley.h (added) * ipsec-tools/src/racoon/pfkey.c (added) * ipsec-tools/src/racoon/pfkey.h (added) * ipsec-tools/src/racoon/plainrsa-gen.8 (added) * ipsec-tools/src/racoon/plainrsa-gen.c (added) * ipsec-tools/src/racoon/plog.c (added) * ipsec-tools/src/racoon/plog.h (added) * ipsec-tools/src/racoon/policy.c (added) * ipsec-tools/src/racoon/policy.h (added) * ipsec-tools/src/racoon/privsep.c (added) * ipsec-tools/src/racoon/privsep.h (added) * ipsec-tools/src/racoon/proposal.c (added) * ipsec-tools/src/racoon/proposal.h (added) * ipsec-tools/src/racoon/prsa_par.c (added) * ipsec-tools/src/racoon/prsa_par.h (added) * ipsec-tools/src/racoon/prsa_par.y (added) * ipsec-tools/src/racoon/prsa_tok.c (added) * ipsec-tools/src/racoon/prsa_tok.l (added) * ipsec-tools/src/racoon/racoon.8 (added) * ipsec-tools/src/racoon/racoon.conf.5 (added) * ipsec-tools/src/racoon/racoonctl.8 (added) * ipsec-tools/src/racoon/racoonctl.c (added) * ipsec-tools/src/racoon/racoonctl.h (added) * ipsec-tools/src/racoon/remoteconf.c (added) * ipsec-tools/src/racoon/remoteconf.h (added) * ipsec-tools/src/racoon/rsalist.c (added) * ipsec-tools/src/racoon/rsalist.h (added) * ipsec-tools/src/racoon/safefile.c (added) * ipsec-tools/src/racoon/safefile.h (added) * ipsec-tools/src/racoon/sainfo.c (added) * ipsec-tools/src/racoon/sainfo.h (added) * ipsec-tools/src/racoon/samples/psk.txt.in (added) * ipsec-tools/src/racoon/samples/psk.txt.sample (added) * ipsec-tools/src/racoon/samples/racoon.conf.in (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample-gssapi (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample-inherit (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample-natt (added) * ipsec-tools/src/racoon/samples/racoon.conf.sample-plainrsa (added) * ipsec-tools/src/racoon/samples/roadwarrior/README (added) * ipsec-tools/src/racoon/samples/roadwarrior/client/phase1-down.sh (added) * ipsec-tools/src/racoon/samples/roadwarrior/client/phase1-up.sh (added) * ipsec-tools/src/racoon/samples/roadwarrior/client/racoon.conf (added) * ipsec-tools/src/racoon/samples/roadwarrior/server/racoon.conf (added) * ipsec-tools/src/racoon/samples/roadwarrior/server/racoon.conf-radius (added) * ipsec-tools/src/racoon/schedule.c (added) * ipsec-tools/src/racoon/schedule.h (added) * ipsec-tools/src/racoon/security.c (added) * ipsec-tools/src/racoon/session.c (added) * ipsec-tools/src/racoon/session.h (added) * ipsec-tools/src/racoon/sockmisc.c (added) * ipsec-tools/src/racoon/sockmisc.h (added) * ipsec-tools/src/racoon/stats.pl (added) * ipsec-tools/src/racoon/str2val.c (added) * ipsec-tools/src/racoon/str2val.h (added) * ipsec-tools/src/racoon/strnames.c (added) * ipsec-tools/src/racoon/strnames.h (added) * ipsec-tools/src/racoon/throttle.c (added) * ipsec-tools/src/racoon/throttle.h (added) * ipsec-tools/src/racoon/var.h (added) * ipsec-tools/src/racoon/vendorid.c (added) * ipsec-tools/src/racoon/vendorid.h (added) * ipsec-tools/src/racoon/vmbuf.c (added) * ipsec-tools/src/racoon/vmbuf.h (added) * ipsec-tools/src/setkey/Makefile.am (added) * ipsec-tools/src/setkey/Makefile.in (added) * ipsec-tools/src/setkey/extern.h (added) * ipsec-tools/src/setkey/parse.c (added) * ipsec-tools/src/setkey/parse.h (added) * ipsec-tools/src/setkey/parse.y (added) * ipsec-tools/src/setkey/sample-policy01.cf (added) * ipsec-tools/src/setkey/sample-policy02.cf (added) * ipsec-tools/src/setkey/sample.cf (added) * ipsec-tools/src/setkey/scriptdump.pl (added) * ipsec-tools/src/setkey/setkey.8 (added) * ipsec-tools/src/setkey/setkey.c (added) * ipsec-tools/src/setkey/test-pfkey.c (added) * ipsec-tools/src/setkey/token.c (added) * ipsec-tools/src/setkey/token.l (added) * ipsec-tools/src/setkey/vchar.h (added) * ipsec-tools/test-driver (added) * ipsec-tools/ylwrap (added) Import ipsec-tools 0.8.2. Import unchanged ipsec-tools sources in ... Fri, 27 Apr 2018 12:57:20 GMT Christian Mauderer [6215813] * buildset/default.ini (modified) * buildset/everything.ini (modified) * freebsd/sys/net/if_ipsec.c (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/bsd/local/opt_ipsec.h (modified) if_ipsec: Port and add to everything-buildset. This ports the ... Thu, 03 May 2018 11:31:25 GMT Christian Mauderer [09bbedc] * freebsd/sys/net/if_ipsec.c (added) * freebsd/sys/net/if_ipsec.h (added) if_ipsec: Import from FreeBSD. Mon, 07 May 2018 08:19:28 GMT Christian Mauderer [01855a5] * builder.py (modified) * waf_libbsd.py (modified) waf: Allow to only generate lex and yacc. In some applications, ... Wed, 13 Jun 2018 13:04:47 GMT Christian Mauderer [879eaa7] * userspace-header-gen.py (modified) userspace-header-gen: Special case for Yacc / Lex. Some variables ... Tue, 26 Jun 2018 11:54:08 GMT Christian Mauderer [9ea8664] * freebsd/sys/sys/random.h (modified) random: Implement read_random via getentropy. Tue, 12 Jun 2018 13:44:44 GMT Christian Mauderer [9efc650] * freebsd/sys/crypto/sha2/sha2.h (deleted) crypto/sha2: Remove left over file. This file seems to be imported ... Thu, 26 Jul 2018 12:49:35 GMT Sebastian Huber [1372502] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Make sure CALLOUT_DFRMIGRATION is not used This flag supports the ... Thu, 26 Jul 2018 12:35:56 GMT Sebastian Huber [e37f03e] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Make sure CALLOUT_PROCESSED is not used This flag is only used in ... Thu, 26 Jul 2018 12:12:46 GMT Sebastian Huber [6d9d7b1] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Critical bug fix for callouts FreeBSD has two callout executors, ... Thu, 26 Jul 2018 11:52:43 GMT Sebastian Huber [3df89c0] * testsuite/selectpollkqueue01/test_main.c (modified) selectpollkqueue01: Invalidate file descriptor This is not a ... Thu, 26 Jul 2018 10:03:45 GMT Sebastian Huber [6fb003f] * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * testsuite/syscalls01/test_main.c (modified) * testsuite/thread01/test_main.c (modified) Fix sporadic test failures via uma_timeout() Mon, 02 Jul 2018 06:21:37 GMT Sebastian Huber [94b5368] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/socketvar.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) Avoid malloc() in getsockaddr() The getsockaddr() function is used ... Wed, 04 Jul 2018 05:19:01 GMT Nicolas Tsiogkas [e6f6b5e] * freebsd/sys/net/bpf.c (modified) BPF(9): Pass flags to bpfopen() Mon, 02 Jul 2018 07:16:14 GMT Sebastian Huber [a1e4757] * testsuite/syscalls01/test_main.c (modified) syscalls01: Fix sporadic test failures Mon, 18 Jun 2018 11:22:49 GMT Christian Mauderer [a07eb67] * rtems_waf (modified) rtems_waf: Fix show-commands option. Mon, 18 Jun 2018 11:06:47 GMT Christian Mauderer [aad7461] * .gitmodules (modified) rtems_waf: Move to the public repositories. For an update from an ... Wed, 30 May 2018 11:34:36 GMT Christian Mauderer [f8cf074] * rtemsbsd/include/bsp/nexus-devices.h (modified) beagle: Disable WiFi if libbsd is build without it. Update #3351. Thu, 17 May 2018 18:35:19 GMT Christian Mauderer [e1d62e8] * waf_libbsd.py (modified) waf: Fix python3 compatibility. Wed, 02 May 2018 07:01:32 GMT Sebastian Huber [b2eb48c] * dhcpcd/dhcpcd.c (modified) * dhcpcd/namespace.h (modified) * dhcpcd/script.c (modified) * dhcpcd/script.h (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/dhcpcd.h (modified) * testsuite/dhcpcd01/test_main.c (modified) dhcpcd: Add hooks Wed, 02 May 2018 06:58:48 GMT Sebastian Huber [8bd38d6] * dhcpcd/dhcpcd.c (modified) * dhcpcd/namespace.h (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/dhcpcd.h (added) * rtemsbsd/rtems/rtems-bsd-init-dhcp.c (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) dhcpcd: Add rtems_dhcpcd_start() Use it throughout to start the ... Thu, 03 May 2018 06:18:24 GMT Sebastian Huber [bd09f9f] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Do not create directories used by dhcpcd The dhcpcd will ... Thu, 03 May 2018 06:17:59 GMT Sebastian Huber [9c570da] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Include missing header files Wed, 02 May 2018 09:25:18 GMT Christian Mauderer [dd35ec5] * builder.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Allow to add libs per test. Update #3419. Wed, 02 May 2018 09:56:39 GMT Christian Mauderer [a779a3b] * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.y (modified) pfctl: Undef INET6 to avoid warning. Wed, 25 Apr 2018 14:28:00 GMT Christian Mauderer [338f300] * builder.py (modified) * buildset/default.ini (modified) * buildset/everything.ini (added) * buildset/minimal.ini (added) * buildset/sample.ini (deleted) * dhcpcd/config.h (modified) * dhcpcd/dhcp6.c (modified) * dhcpcd/ipv6.c (modified) * dhcpcd/ipv6.h (modified) * dhcpcd/ipv6nd.c (modified) * dhcpcd/platform.h (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_inet6.h (modified) * testsuite/commands01/test_main.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) buildset: Add minimal and everything config. This adds two new ... Thu, 26 Apr 2018 14:10:09 GMT Christian Mauderer [4eb2502] * freebsd/contrib/tcpdump/print-sunrpc.c (deleted) tcpdump: Remove unused file. Wed, 25 Apr 2018 12:51:07 GMT Christian Mauderer [93f1904] * waf_libbsd.py (modified) waf: Generate a rtems/bsd/modules.h The generated file defines a ... Wed, 02 May 2018 12:59:48 GMT Christian Mauderer [1588cf1] * waf_libbsd.py (modified) waf: Fix source code generators. There have been some bugs with the ... Wed, 25 Apr 2018 10:50:26 GMT Christian Mauderer [821976e] * waf_libbsd.py (modified) waf: Fix usage of build-include from config. Wed, 02 May 2018 08:35:35 GMT Sebastian Huber [634b3bf] * rtemsbsd/debugger/rtems-debugger-remote-tcp.c (deleted) * rtemsbsd/include/rtems/rtems-debugger-remote-tcp.h (deleted) rtems-debugger: Remove files They are now in the main RTEMS ... Mon, 30 Apr 2018 09:07:05 GMT Sebastian Huber [443a058] * freebsd/include/arpa/ftp.h (deleted) * libbsd.py (modified) * rtemsbsd/ftpd/ftpd-init.c (deleted) * rtemsbsd/ftpd/ftpd.c (deleted) * rtemsbsd/ftpfs/ftpfs.c (deleted) * rtemsbsd/include/rtems/ftpd.h (deleted) * rtemsbsd/include/rtems/ftpfs.h (deleted) * rtemsbsd/include/rtems/telnetd.h (deleted) * rtemsbsd/telnetd/check_passwd.c (deleted) * rtemsbsd/telnetd/des.c (deleted) * rtemsbsd/telnetd/passwd.h (deleted) * rtemsbsd/telnetd/pty.c (deleted) * rtemsbsd/telnetd/telnetd-init.c (deleted) * rtemsbsd/telnetd/telnetd.c (deleted) * waf_libbsd.py (modified) Use network services from RTEMS Close #3419. Mon, 30 Apr 2018 11:35:25 GMT Sebastian Huber [b1404f2] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Add DHCP clientid to test default network init Fri, 27 Apr 2018 08:14:44 GMT Sebastian Huber [ef5d536] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Simplify XDMA usage Fri, 27 Apr 2018 06:39:22 GMT Sebastian Huber [d45899b] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Get rid of bounce buffer Thu, 26 Apr 2018 13:23:08 GMT Sebastian Huber [3fac9e9] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Use real interrupt Execute at91_mci_intr() in interrupt ... Thu, 26 Apr 2018 13:19:42 GMT Sebastian Huber [c7e162a] * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) mmc: Optimize mmc_wait_for_req() Use a self-contained RTEMS binary ... Thu, 26 Apr 2018 09:14:39 GMT Sebastian Huber [4b14263] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Fix use of BOARD_MCK
