# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 05/01/24 10:00:24 Thu, 11 Aug 2016 07:41:49 GMT Chris Johns [26a8cee] * freebsd/sys/dev/mii/e1000phy.c (modified) e1000phy: Provide local support for Marvell's 88E1512 PHY. This PHY ... Wed, 10 Aug 2016 06:04:16 GMT Sebastian Huber [62c4755] * libbsd.txt (modified) doc: Add FreeBSD import version section Thu, 04 Aug 2016 11:20:04 GMT Christian Mauderer [bc9e939] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-pf.c (added) * testsuite/rcconf02/test_main.c (modified) pf: Add configuration via rc.conf. Mon, 08 Aug 2016 14:11:21 GMT Christian Mauderer [6cfb5c2] * libbsd.txt (modified) pf: Improve documentation regarding stack. Mon, 08 Aug 2016 13:53:39 GMT Christian Mauderer [61e2e1b] * rtemsbsd/rtems/rtems-bsd-rc-conf.c (modified) rc.conf: Use more stack for the rc worker. Most of the tests run ... Thu, 04 Aug 2016 06:30:44 GMT Christian Mauderer [a8d016c] * testsuite/pf01/test_main.c (modified) testsuite/pf01: Remove pflog-module from test. This module is not ... Thu, 04 Aug 2016 06:02:24 GMT Christian Mauderer [32a3dd1] * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * testsuite/pf01/test_main.c (modified) * testsuite/pf02/test_main.c (modified) pf: Add RTEMS_BSD_CONFIG_FIREWALL_xxx options. Fri, 05 Aug 2016 10:00:47 GMT Christian Mauderer [0717607] * rtemsbsd/sys/dev/ffec/if_ffec_mcf548x.c (modified) if_ffec_mcf548x: Init when interface is set to UP. Call the driver ... Thu, 04 Aug 2016 12:13:20 GMT Christian Mauderer [9907ae4] * freebsd/usr.bin/netstat/inet.c (modified) netstat: Don't init vars if they are not defined. The variables are ... Thu, 04 Aug 2016 12:12:17 GMT Christian Mauderer [2fb3a36] * create-kernel-namespace.sh (modified) * freebsd/lib/libc/net/vars.c (modified) * freebsd/sys/netinet6/in6.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) freebsd: Add constant ipv6 addresses from vars.c. This is necessary ... Wed, 03 Aug 2016 11:27:11 GMT Christian Mauderer [7aaa9a1] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/pf02/test_main.c (added) testsuite/pf02: Add interactive pf test. Tue, 12 Jul 2016 11:41:39 GMT Christian Mauderer [f1941b2] * libbsd.txt (modified) libbsd.txt: Add section describing PF. Wed, 06 Jul 2016 14:06:54 GMT Christian Mauderer [f71cbd0] * libbsd.txt (modified) libbsd.txt: Add guide for user space tools. Fri, 22 Jul 2016 12:50:09 GMT Christian Mauderer [df222eb] * testsuite/pf01/test_main.c (modified) testsuite/pf01: Test pfctl and pf. Fri, 22 Jul 2016 12:49:49 GMT Christian Mauderer [7f86f6a] * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/netcmds-config.h (modified) * rtemsbsd/rtems/rtems-bsd-shell-netcmds.c (modified) pfctl: Add rtems_bsd_command_pfctl. Tue, 05 Jul 2016 14:08:38 GMT Christian Mauderer [c79290a] * libbsd.py (modified) * libbsd_waf.py (modified) pfctl: build files. Fri, 22 Jul 2016 12:36:19 GMT Christian Mauderer [09ce54e] * freebsd/contrib/pf/pfctl/parse.c (added) pfctl: Add yacc generated file. Tue, 05 Jul 2016 14:31:43 GMT Christian Mauderer [d79524e] * freebsd/contrib/pf/pfctl/parse-data.h (added) * freebsd/contrib/pf/pfctl/parse.y (modified) * freebsd/contrib/pf/pfctl/pf_print_state.c (modified) * freebsd/contrib/pf/pfctl/pfctl-data.h (added) * freebsd/contrib/pf/pfctl/pfctl.c (modified) * freebsd/contrib/pf/pfctl/pfctl_altq-data.h (added) * freebsd/contrib/pf/pfctl/pfctl_altq.c (modified) * freebsd/contrib/pf/pfctl/pfctl_optimize-data.h (added) * freebsd/contrib/pf/pfctl/pfctl_optimize.c (modified) * freebsd/contrib/pf/pfctl/pfctl_osfp-data.h (added) * freebsd/contrib/pf/pfctl/pfctl_osfp.c (modified) * freebsd/contrib/pf/pfctl/pfctl_parser-data.h (added) * freebsd/contrib/pf/pfctl/pfctl_parser.c (modified) * freebsd/contrib/pf/pfctl/pfctl_qstats-data.h (added) * freebsd/contrib/pf/pfctl/pfctl_qstats.c (modified) * freebsd/contrib/pf/pfctl/pfctl_radix-data.h (added) * freebsd/contrib/pf/pfctl/pfctl_radix.c (modified) * freebsd/contrib/pf/pfctl/pfctl_table.c (modified) pfctl: Adapt for RTEMS. Fri, 29 Jul 2016 14:04:42 GMT Christian Mauderer [686583c] * freebsd/contrib/pf/pfctl/parse.y (modified) * freebsd/contrib/pf/pfctl/pfctl.c (modified) * freebsd/contrib/pf/pfctl/pfctl_altq.c (modified) * freebsd/contrib/pf/pfctl/pfctl_optimize.c (modified) * freebsd/contrib/pf/pfctl/pfctl_osfp.c (modified) * freebsd/contrib/pf/pfctl/pfctl_parser.c (modified) pfctl: Use static where possible. Wed, 06 Jul 2016 07:50:51 GMT Christian Mauderer [c70221c] * freebsd/contrib/pf/pfctl/pfctl.c (modified) * freebsd/contrib/pf/pfctl/pfctl_altq.c (modified) * freebsd/contrib/pf/pfctl/pfctl_optimize.c (modified) * freebsd/contrib/pf/pfctl/pfctl_osfp.c (modified) * freebsd/contrib/pf/pfctl/pfctl_parser.c (modified) * freebsd/contrib/pf/pfctl/pfctl_qstats.c (modified) * freebsd/contrib/pf/pfctl/pfctl_radix.c (modified) pfctl: Add const and move static variables. Note: This should be ... Tue, 05 Jul 2016 14:31:43 GMT Christian Mauderer [b6252fb] * freebsd/contrib/pf/pfctl/pfctl.c (modified) pfctl: Match prototype. Note: This should be upstreamed into BSD. Tue, 05 Jul 2016 14:07:37 GMT Christian Mauderer [6e9a8ea] * freebsd/contrib/pf/pfctl/parse.y (added) * freebsd/contrib/pf/pfctl/pf_print_state.c (added) * freebsd/contrib/pf/pfctl/pfctl.c (added) * freebsd/contrib/pf/pfctl/pfctl.h (added) * freebsd/contrib/pf/pfctl/pfctl_altq.c (added) * freebsd/contrib/pf/pfctl/pfctl_optimize.c (added) * freebsd/contrib/pf/pfctl/pfctl_osfp.c (added) * freebsd/contrib/pf/pfctl/pfctl_parser.c (added) * freebsd/contrib/pf/pfctl/pfctl_parser.h (added) * freebsd/contrib/pf/pfctl/pfctl_qstats.c (added) * freebsd/contrib/pf/pfctl/pfctl_radix.c (added) * freebsd/contrib/pf/pfctl/pfctl_table.c (added) pfctl: Import sources from FreeBSD. Fri, 15 Jul 2016 05:32:56 GMT Christian Mauderer [21abaef] * freebsd/bin/hostname/hostname.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/lib/libc/gen/err.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/main.c (modified) freebsd: Don't use new wrappers for old ports. Some of the commands ... Thu, 14 Jul 2016 09:01:43 GMT Christian Mauderer [d31a365] * rtemsbsd/include/machine/rtems-bsd-program.h (modified) * rtemsbsd/rtems/rtems-kernel-program.c (modified) * testsuite/program01/test_main.c (modified) rtemsbsd: Add wrapper for open, fopen, malloc, ... Add the ... Fri, 15 Jul 2016 09:39:48 GMT Christian Mauderer [3d91340] * rtemsbsd/include/machine/rtems-bsd-program.h (modified) * rtemsbsd/rtems/rtems-kernel-program.c (modified) * testsuite/program01/test_main.c (modified) rtemsbsd: Add call to program with a data restore This adds the ... Thu, 14 Jul 2016 13:34:13 GMT Christian Mauderer [fa43d6a] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/program01/test_main.c (added) * testsuite/syscalls01/test_main.c (modified) testsuite/syscalls01: Split out program01 part. This allows to use ... Mon, 27 Jun 2016 12:29:53 GMT Christian Mauderer [a9bd422] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) * testsuite/pf01/test_main.c (added) testsuite/pf01: Add test that links PF. Tue, 28 Jun 2016 13:13:09 GMT Christian Mauderer [8dacfe4] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/cdev01/test_cdev.c (added) * testsuite/cdev01/test_cdev01.h (added) * testsuite/cdev01/test_main.c (added) testsuite/cdev01: Add test for cdev functions. Tue, 28 Jun 2016 15:27:08 GMT Christian Mauderer [9a01ebf] * freebsd/sys/kern/kern_conf.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/sys/conf.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/rtems/rtems-kernel-conf.c (deleted) kern_conf.c: Adapt for RTEMS. Wed, 29 Jun 2016 08:22:03 GMT Christian Mauderer [6c0cfc2] * freebsd/sys/kern/kern_conf.c (added) kern_conf.c: Import from FreeBSD. Thu, 30 Jun 2016 05:55:27 GMT Christian Mauderer [b5db332] * freebsd/sys/sys/conf.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/sys/fs/devfs/devfs_devs.c (added) rtemsbsd/devfs: Add. Tue, 28 Jun 2016 06:32:30 GMT Sebastian Huber [bf7faad] * rtemsbsd/include/machine/rtems-bsd-mutex.h (modified) * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-kernel-muteximpl.c (modified) rtems-bsd-mutex: Update due to API changes Thu, 28 Jul 2016 02:19:01 GMT Chris Johns [b6c170f] * freebsd/sys/kern/subr_sleepqueue.c (modified) kern/sleepqueue: Update due to API changes Thu, 28 Jul 2016 02:17:08 GMT Chris Johns [a0ea5f8] * freebsd/sys/kern/subr_sleepqueue.c (modified) Revert "kern/sleepqueue: Update due to API changes" This reverts ... Thu, 28 Jul 2016 02:16:09 GMT Chris Johns [1bf6529] * freebsd/sys/kern/subr_sleepqueue.c (modified) kern/sleepqueue: Update due to API changes Wed, 27 Jul 2016 06:51:53 GMT Sebastian Huber [e5aa554] * rtemsbsd/rtems/rtems-kernel-muteximpl.c (modified) rtems-bsd-mutex: Update due to API changes Mon, 18 Jul 2016 22:12:17 GMT Chris Johns [9510012] * rtemsbsd/include/machine/rtems-bsd-config.h (modified) config: Fix telnetd configuration warning. Sat, 09 Jul 2016 04:43:03 GMT Chris Johns [ac0e5bf] * rtems_waf (modified) Update to bring in the --show-commands fix. Wed, 06 Jul 2016 07:08:07 GMT Chris Johns [b8c7bf9] * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Set syslog priority to 'debug' for all tests. Thu, 30 Jun 2016 03:32:29 GMT Chris Johns [761ae78] * rtemsbsd/include/librtemsNfs.h (modified) * rtemsbsd/nfsclient/nfs.c (modified) * rtemsbsd/nfsclient/rpcio.c (modified) Make the license message viewable with a verbose option. The ... Fri, 01 Jul 2016 06:43:56 GMT Chris Johns [34f6271] * rtemsbsd/include/machine/rtems-bsd-config.h (modified) Provide empty RTEMS_BSD_CFGDECL_.* defines if not used. Fri, 01 Jul 2016 06:36:13 GMT Chris Johns [4dec435] * testsuite/rcconf02/test_main.c (modified) Add a wait for key press to test rccof02. Fri, 01 Jul 2016 05:49:52 GMT Chris Johns [65c65bb] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/include/rtems/telnetd.h (modified) * rtemsbsd/telnetd/telnetd-init.c (added) * rtemsbsd/telnetd/telnetd-service.c (added) * rtemsbsd/telnetd/telnetd.c (modified) * testsuite/rcconf02/test_main.c (modified) Add telnetd as service to rc.conf. Thu, 30 Jun 2016 03:35:37 GMT Chris Johns [fc26479] * rtemsbsd/include/rtems/ftpd.h (modified) Add ftpd initailize comment. Thu, 30 Jun 2016 01:42:49 GMT Chris Johns [f01b1f72] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-allocator-domain-size.c (added) * rtemsbsd/rtems/rtems-bsd-get-allocator-domain-size.c (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. The domain allocator ... Wed, 29 Jun 2016 23:25:13 GMT Chris Johns [dc5b267] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) Fix wording and spelling. Wed, 29 Jun 2016 23:19:52 GMT Chris Johns [573b1982] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf.c (modified) * testsuite/rcconf02/test_main.c (modified) Add DHCP support to rc.conf. Wed, 29 Jun 2016 23:19:06 GMT Chris Johns [912b685] * rtemsbsd/include/machine/rtems-bsd-kernel-space.h (modified) Make the LibBSD PID match getpid(). Wed, 29 Jun 2016 23:18:21 GMT Chris Johns [c980a04] * rtemsbsd/include/machine/rtems-bsd-config.h (modified) Fix fomatting and C++ guard. Wed, 29 Jun 2016 23:17:21 GMT Chris Johns [45960a3] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/rtems-routes.h (added) * rtemsbsd/rtems/rtems-routes.c (added) Add rtems_get_route to fetch a specific route from the routing tables. Wed, 29 Jun 2016 23:14:55 GMT Chris Johns [4a2b844] * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/syslog.c (modified) Default syslog priority to INFO. Add rtems_setlogpriority to ... Tue, 28 Jun 2016 03:32:01 GMT Chris Johns [90873cc] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/ftpd/ftpd-init.c (added) * rtemsbsd/ftpd/ftpd-service.c (added) * rtemsbsd/ftpd/ftpd.c (modified) * rtemsbsd/include/machine/rtems-bsd-config.h (added) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (modified) * rtemsbsd/include/rtems/ftpd.h (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/rcconf02/test_main.c (modified) Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. Tue, 28 Jun 2016 03:31:11 GMT Chris Johns [c2ec5f1] * rtemsbsd/rtems/rtems-bsd-rc-conf.c (modified) Print the service when starting. Tue, 28 Jun 2016 03:30:44 GMT Chris Johns [f588325] * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) Change the Nexus bus to defines and have the BSP declare them. Mon, 27 Jun 2016 11:31:03 GMT Chris Johns [ace5fb6] * freebsd/sys/dev/cadence/if_cgem.c (modified) Enable the Cadence cgem device syctls. Mon, 27 Jun 2016 11:27:01 GMT Chris Johns [591bd2d] * freebsd/sys/dev/cadence/if_cgem.c (modified) Revert "Enable the Cadence cgem device syctls." This reverts commit ... Mon, 27 Jun 2016 11:25:38 GMT Chris Johns [9362e76] * freebsd/sys/dev/cadence/if_cgem.c (modified) Enable the Cadence cgem device syctls. Mon, 27 Jun 2016 11:24:03 GMT Chris Johns [9835790] * freebsd/sys/kern/subr_bus.c (modified) Enable device sysctl. Mon, 27 Jun 2016 06:45:18 GMT Chris Johns [39a650e] * libbsd.txt (modified) Add VDE and QEMU doco. Mon, 27 Jun 2016 03:35:08 GMT Chris Johns [459d67d] * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (added) Move the Nexus bus driver decls available to users. Mon, 27 Jun 2016 03:25:48 GMT Chris Johns [7439724] * libbsd.py (modified) * libbsd_waf.py (modified) * testsuite/rcconf02/test_main.c (added) Add a services base test. Mon, 27 Jun 2016 03:24:43 GMT Chris Johns [55c564a] * rtemsbsd/include/machine/rtems-bsd-rc-conf-directives.h (deleted) * rtemsbsd/include/machine/rtems-bsd-rc-conf-services.h (added) * rtemsbsd/include/machine/rtems-bsd-rc-conf.h (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf.c (modified) * testsuite/rcconf01/test_main.c (modified) Refactor rc.conf processing to be services based. Mon, 27 Jun 2016 03:15:11 GMT Chris Johns [c6713d1] * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) Add DEFAULT_NETWORK_PAGE_MBUFS_SIZE to allow per BSP allocation ... Mon, 27 Jun 2016 03:12:39 GMT Chris Johns [9edacb6] * libbsd.txt (modified) Fix spelling. Mon, 27 Jun 2016 03:12:06 GMT Chris Johns [b23da31] * rtemsbsd/rtems/rtems-kernel-nexus.c (modified) Change LibBSD to use shared interrupts. Mon, 27 Jun 2016 03:09:04 GMT Chris Johns [130fa35] * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-get-allocator-domain-size.c (modified) Make the domain allocation size global to allow it to set in tests. ... Mon, 27 Jun 2016 03:07:54 GMT Chris Johns [a0e49f9] * rtemsbsd/rtems/rtems-kernel-jail.c (modified) Add functions used the bridge and tap interfaces. Thu, 23 Jun 2016 12:18:17 GMT Sebastian Huber [c991d65] * testsuite/log01/test_main.c (modified) Update due to RTEMS printer API changes Thu, 23 Jun 2016 12:06:21 GMT Sebastian Huber [32fd702] * freebsd/sys/kern/kern_intr.c (modified) * rtemsbsd/include/machine/stdarg.h (modified) * rtemsbsd/rtems/rtems-kernel-panic.c (modified) * rtemsbsd/rtems/rtems-kernel-program.c (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Update due to RTEMS printer API changes Mon, 20 Jun 2016 00:07:08 GMT Chris Johns [628512a] * rtems_waf (modified) Update rtems_waf to pick up the long command line fix. Thu, 16 Jun 2016 07:08:37 GMT Chris Johns [616be5c] * rtems_waf (modified) Pick up white space fix. Thu, 16 Jun 2016 03:32:28 GMT Chris Johns [32ceb14] * libbsd_waf.py (modified) * rtems_waf (modified) * waf_generator.py (modified) * wscript (modified) Add support for long command lines and fix some shell rules on Windows. Wed, 15 Jun 2016 05:49:24 GMT Sebastian Huber [5851034] * freebsd/lib/libc/include/reentrant.h (modified) reentrant.h: There is no main thread in RTEMS Mon, 13 Jun 2016 09:59:04 GMT Sebastian Huber [d6ad59d] * libbsd.txt (modified) libbsd.txt: Clarify xilinx_zynq_a9_qemu usage Fri, 10 Jun 2016 12:11:40 GMT Sebastian Huber [58c4e1c5] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/nfsclient/nfs.c (modified) * rtemsbsd/nfsclient/rpcio.c (modified) * testsuite/nfs01/test_main.c (added) nfsclient: Port to LibBSD Thu, 09 Jun 2016 09:31:27 GMT Sebastian Huber [4464594] * rtemsbsd/include/librtemsNfs.h (added) * rtemsbsd/nfsclient/LICENSE (added) * rtemsbsd/nfsclient/README (added) * rtemsbsd/nfsclient/mount_prot.h (added) * rtemsbsd/nfsclient/mount_prot.x (added) * rtemsbsd/nfsclient/mount_prot_xdr.c (added) * rtemsbsd/nfsclient/nfs.c (added) * rtemsbsd/nfsclient/nfs_prot.h (added) * rtemsbsd/nfsclient/nfs_prot.x (added) * rtemsbsd/nfsclient/nfs_prot_xdr.c (added) * rtemsbsd/nfsclient/nfsclient-private.h (added) * rtemsbsd/nfsclient/rpcio.c (added) * rtemsbsd/nfsclient/rpcio.h (added) nfsclient: Import from RTEMS RTEMS Git commit ... Thu, 09 Jun 2016 09:48:16 GMT Sebastian Huber [a037da6] * freebsd/lib/libc/xdr/rpc_com.h (added) * freebsd/lib/libc/xdr/xdr.c (modified) * freebsd/lib/libc/xdr/xdr_float.c (modified) * freebsd/lib/libc/xdr/xdr_rec.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) XDR(3): Port to RTEMS Thu, 09 Jun 2016 09:46:09 GMT Sebastian Huber [f41a394] * freebsd/lib/libc/xdr/xdr.c (added) * freebsd/lib/libc/xdr/xdr_array.c (added) * freebsd/lib/libc/xdr/xdr_float.c (added) * freebsd/lib/libc/xdr/xdr_mem.c (added) * freebsd/lib/libc/xdr/xdr_rec.c (added) * freebsd/lib/libc/xdr/xdr_reference.c (added) * freebsd/lib/libc/xdr/xdr_sizeof.c (added) * freebsd/lib/libc/xdr/xdr_stdio.c (added) XDR(3): Import from FreeBSD Thu, 09 Jun 2016 08:48:05 GMT Sebastian Huber [9880635] * freebsd/include/rpc/clnt_stat.h (modified) * freebsd/include/rpc/rpc_msg.h (modified) * freebsd/include/rpc/svc.h (modified) * freebsd/include/rpcsvc/nis_db.h (modified) * freebsd/include/rpcsvc/yp_prot.h (modified) * freebsd/lib/libc/include/namespace.h (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) RPC(3): Port to RTEMS Thu, 09 Jun 2016 08:23:57 GMT Sebastian Huber [60b1d40] * freebsd/include/gssapi.h (added) * freebsd/include/gssapi/gssapi.h (added) * freebsd/include/rpc/auth_kerb.h (added) * freebsd/include/rpc/des.h (added) * freebsd/include/rpc/des_crypt.h (added) * freebsd/include/rpc/key_prot.h (added) * freebsd/include/rpc/nettype.h (added) * freebsd/include/rpc/pmap_rmt.h (added) * freebsd/include/rpc/raw.h (added) * freebsd/include/rpc/rpc_com.h (added) * freebsd/include/rpc/rpcsec_gss.h (added) * freebsd/include/rpc/svc_dg.h (added) * freebsd/include/rpcsvc/bootparam_prot.x (added) * freebsd/include/rpcsvc/crypt.h (added) * freebsd/include/rpcsvc/crypt.x (added) * freebsd/include/rpcsvc/key_prot.x (added) * freebsd/include/rpcsvc/klm_prot.x (added) * freebsd/include/rpcsvc/mount.x (added) * freebsd/include/rpcsvc/nfs_prot.x (added) * freebsd/include/rpcsvc/nis.h (added) * freebsd/include/rpcsvc/nis.x (added) * freebsd/include/rpcsvc/nis_cache.x (added) * freebsd/include/rpcsvc/nis_callback.x (added) * freebsd/include/rpcsvc/nis_object.x (added) * freebsd/include/rpcsvc/nlm_prot.x (added) * freebsd/include/rpcsvc/pmap_prot.x (added) * freebsd/include/rpcsvc/rex.x (added) * freebsd/include/rpcsvc/rnusers.x (added) * freebsd/include/rpcsvc/rquota.x (added) * freebsd/include/rpcsvc/rstat.x (added) * freebsd/include/rpcsvc/rwall.x (added) * freebsd/include/rpcsvc/sm_inter.x (added) * freebsd/include/rpcsvc/spray.x (added) * freebsd/include/rpcsvc/yp.x (added) * freebsd/include/rpcsvc/yppasswd.x (added) * freebsd/include/rpcsvc/ypupdate_prot.x (added) * freebsd/include/rpcsvc/ypxfrd.x (added) * freebsd/lib/libc/rpc/auth_des.c (added) * freebsd/lib/libc/rpc/auth_none.c (added) * freebsd/lib/libc/rpc/auth_time.c (added) * freebsd/lib/libc/rpc/auth_unix.c (added) * freebsd/lib/libc/rpc/authdes_prot.c (added) * freebsd/lib/libc/rpc/authunix_prot.c (added) * freebsd/lib/libc/rpc/bindresvport.c (added) * freebsd/lib/libc/rpc/clnt_bcast.c (added) * freebsd/lib/libc/rpc/clnt_dg.c (added) * freebsd/lib/libc/rpc/clnt_generic.c (added) * freebsd/lib/libc/rpc/clnt_perror.c (added) * freebsd/lib/libc/rpc/clnt_raw.c (added) * freebsd/lib/libc/rpc/clnt_simple.c (added) * freebsd/lib/libc/rpc/clnt_vc.c (added) * freebsd/lib/libc/rpc/crypt_client.c (added) * freebsd/lib/libc/rpc/des_crypt.c (added) * freebsd/lib/libc/rpc/des_soft.c (added) * freebsd/lib/libc/rpc/getnetconfig.c (added) * freebsd/lib/libc/rpc/getnetpath.c (added) * freebsd/lib/libc/rpc/getpublickey.c (added) * freebsd/lib/libc/rpc/getrpcent.c (added) * freebsd/lib/libc/rpc/getrpcport.c (added) * freebsd/lib/libc/rpc/key_call.c (added) * freebsd/lib/libc/rpc/key_prot_xdr.c (added) * freebsd/lib/libc/rpc/mt_misc.c (added) * freebsd/lib/libc/rpc/mt_misc.h (added) * freebsd/lib/libc/rpc/netname.c (added) * freebsd/lib/libc/rpc/netnamer.c (added) * freebsd/lib/libc/rpc/pmap_clnt.c (added) * freebsd/lib/libc/rpc/pmap_getmaps.c (added) * freebsd/lib/libc/rpc/pmap_getport.c (added) * freebsd/lib/libc/rpc/pmap_prot.c (added) * freebsd/lib/libc/rpc/pmap_prot2.c (added) * freebsd/lib/libc/rpc/pmap_rmt.c (added) * freebsd/lib/libc/rpc/rpc_callmsg.c (added) * freebsd/lib/libc/rpc/rpc_com.h (added) * freebsd/lib/libc/rpc/rpc_commondata.c (added) * freebsd/lib/libc/rpc/rpc_dtablesize.c (added) * freebsd/lib/libc/rpc/rpc_generic.c (added) * freebsd/lib/libc/rpc/rpc_prot.c (added) * freebsd/lib/libc/rpc/rpc_soc.c (added) * freebsd/lib/libc/rpc/rpcb_clnt.c (added) * freebsd/lib/libc/rpc/rpcb_prot.c (added) * freebsd/lib/libc/rpc/rpcb_st_xdr.c (added) * freebsd/lib/libc/rpc/rpcdname.c (added) * freebsd/lib/libc/rpc/rpcsec_gss_stub.c (added) * freebsd/lib/libc/rpc/rtime.c (added) * freebsd/lib/libc/rpc/svc.c (added) * freebsd/lib/libc/rpc/svc_auth.c (added) * freebsd/lib/libc/rpc/svc_auth_des.c (added) * freebsd/lib/libc/rpc/svc_auth_unix.c (added) * freebsd/lib/libc/rpc/svc_dg.c (added) * freebsd/lib/libc/rpc/svc_generic.c (added) * freebsd/lib/libc/rpc/svc_raw.c (added) * freebsd/lib/libc/rpc/svc_run.c (added) * freebsd/lib/libc/rpc/svc_simple.c (added) * freebsd/lib/libc/rpc/svc_vc.c (added) RPC(3): Import from FreeBSD Thu, 09 Jun 2016 09:19:09 GMT Sebastian Huber [68d406b] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/ftpfs/ftpfs.c (added) * rtemsbsd/include/rtems/ftpfs.h (added) * testsuite/ftpd02/test_main.c (added) ftpfs: Import from RTEMS RTEMS Git commit ... Fri, 10 Jun 2016 11:05:16 GMT Sebastian Huber [71f66e7] * testsuite/selectpollkqueue01/test_main.c (modified) selectpollkqueue01: Add EVFILT_USER test case Thu, 09 Jun 2016 12:38:31 GMT Sebastian Huber [17232fe] * freebsd/sys/netinet/ipfw/dn_heap.c (deleted) * freebsd/sys/netinet/ipfw/dn_heap.h (deleted) * freebsd/sys/netinet/ipfw/dn_sched.h (deleted) * freebsd/sys/netinet/ipfw/dn_sched_fifo.c (deleted) * freebsd/sys/netinet/ipfw/dn_sched_prio.c (deleted) * freebsd/sys/netinet/ipfw/dn_sched_qfq.c (deleted) * freebsd/sys/netinet/ipfw/dn_sched_rr.c (deleted) * freebsd/sys/netinet/ipfw/dn_sched_wf2q.c (deleted) * freebsd/sys/netinet/ipfw/ip_dn_glue.c (deleted) * freebsd/sys/netinet/ipfw/ip_dn_io.c (deleted) * freebsd/sys/netinet/ipfw/ip_dn_private.h (deleted) * freebsd/sys/netinet/ipfw/ip_dummynet.c (deleted) * freebsd/sys/netinet/ipfw/ip_fw2.c (deleted) * freebsd/sys/netinet/ipfw/ip_fw_log.c (deleted) * freebsd/sys/netinet/ipfw/ip_fw_nat.c (deleted) * freebsd/sys/netinet/ipfw/ip_fw_pfil.c (deleted) * freebsd/sys/netinet/ipfw/ip_fw_private.h (deleted) * freebsd/sys/netinet/ipfw/ip_fw_sockopt.c (deleted) * freebsd/sys/netinet/ipfw/ip_fw_table.c (deleted) Remove unused files Files moved in FreeBSD to "sys/netpfil/ipfw". Thu, 09 Jun 2016 11:55:48 GMT Sebastian Huber [1bb23f0] * libbsd.txt (modified) libbsd.txt: Fix format Tue, 31 May 2016 07:16:54 GMT Chris Johns [ab5cd63] * testsuite/arphole/test_main.c (modified) * testsuite/loopback01/test_main.c (modified) tests: Fix compile errors after tools upgrade. Mon, 30 May 2016 23:49:31 GMT Chris Johns [f9798ad] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.txt (modified) Add a stats report command. The report shows the level of changes ... Mon, 30 May 2016 14:05:15 GMT Sebastian Huber [70d52b8] * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-kernel-muteximpl.c (modified) rtems-bsd-mutex: Update due to API changes Mon, 18 Apr 2016 12:46:03 GMT Sebastian Huber [b367591] * freebsd/sys/sys/stdint.h (modified) Adjust for latest Newlib Wed, 27 Apr 2016 08:28:49 GMT Sebastian Huber [04762cf] * freebsd/include/arpa/nameser_compat.h (modified) * freebsd/sys/crypto/sha2/sha2.c (modified) * freebsd/sys/netatalk/endian.h (modified) * freebsd/sys/netinet/in.h (modified) * rtemsbsd/include/machine/rtems-bsd-endian.h (deleted) Directly use provided by Newlib Wed, 27 Apr 2016 08:26:50 GMT Sebastian Huber [b6f6deb] * builder.py (modified) * freebsd/include/arpa/inet.h (modified) * freebsd/include/err.h (modified) * freebsd/include/netdb.h (modified) * freebsd/lib/libc/include/libc_private.h (modified) * freebsd/lib/libkvm/kvm.h (modified) * freebsd/lib/libutil/libutil.h (modified) * freebsd/sys/netinet/in.h (modified) * freebsd/sys/sys/sbuf.h (modified) * freebsd/sys/sys/socket.h (modified) * freebsd/sys/sys/stdint.h (modified) * freebsd/sys/sys/syslog.h (modified) * freebsd/sys/sys/un.h (modified) * rtemsbsd/include/rtems/bsd/sys/_types.h (deleted) * rtemsbsd/include/rtems/bsd/sys/resource.h (modified) Directly use provided by Newlib Wed, 27 Apr 2016 08:25:22 GMT Sebastian Huber [3d1e767] * builder.py (modified) * freebsd/contrib/libpcap/bpf_image.c (modified) * freebsd/contrib/libpcap/etherent.c (modified) * freebsd/contrib/libpcap/fad-getad.c (modified) * freebsd/contrib/libpcap/gencode.c (modified) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/optimize.c (modified) * freebsd/contrib/libpcap/pcap-bpf.c (modified) * freebsd/contrib/libpcap/pcap-common.c (modified) * freebsd/contrib/libpcap/pcap.c (modified) * freebsd/contrib/libpcap/pcap/pcap.h (modified) * freebsd/contrib/libpcap/savefile.c (modified) * freebsd/contrib/libpcap/sf-pcap-ng.c (modified) * freebsd/contrib/libpcap/sf-pcap.c (modified) * freebsd/contrib/tcpdump/nameser.h (modified) * freebsd/contrib/tcpdump/netdissect.h (modified) * freebsd/contrib/tcpdump/print-pflog.c (modified) * freebsd/contrib/tcpdump/tcpdump-stdinc.h (modified) * freebsd/include/arpa/nameser.h (modified) * freebsd/include/db.h (modified) * freebsd/include/nsswitch.h (modified) * freebsd/include/res_update.h (modified) * freebsd/include/resolv.h (modified) * freebsd/lib/libc/db/btree/bt_delete.c (modified) * freebsd/lib/libc/db/btree/bt_get.c (modified) * freebsd/lib/libc/db/btree/bt_page.c (modified) * freebsd/lib/libc/db/btree/bt_put.c (modified) * freebsd/lib/libc/db/btree/bt_search.c (modified) * freebsd/lib/libc/db/btree/bt_seq.c (modified) * freebsd/lib/libc/db/btree/bt_split.c (modified) * freebsd/lib/libc/db/db/db.c (modified) * freebsd/lib/libc/db/recno/rec_close.c (modified) * freebsd/lib/libc/db/recno/rec_delete.c (modified) * freebsd/lib/libc/db/recno/rec_get.c (modified) * freebsd/lib/libc/db/recno/rec_open.c (modified) * freebsd/lib/libc/db/recno/rec_put.c (modified) * freebsd/lib/libc/db/recno/rec_search.c (modified) * freebsd/lib/libc/db/recno/rec_seq.c (modified) * freebsd/lib/libc/gen/feature_present.c (modified) * freebsd/lib/libc/include/isc/eventlib.h (modified) * freebsd/lib/libc/include/resolv_mt.h (modified) * freebsd/lib/libc/include/spinlock.h (modified) * freebsd/lib/libc/inet/inet_addr.c (modified) * freebsd/lib/libc/inet/inet_cidr_ntop.c (modified) * freebsd/lib/libc/inet/inet_cidr_pton.c (modified) * freebsd/lib/libc/inet/inet_net_ntop.c (modified) * freebsd/lib/libc/inet/inet_net_pton.c (modified) * freebsd/lib/libc/inet/inet_neta.c (modified) * freebsd/lib/libc/inet/inet_network.c (modified) * freebsd/lib/libc/inet/inet_ntoa.c (modified) * freebsd/lib/libc/inet/inet_ntop.c (modified) * freebsd/lib/libc/inet/inet_pton.c (modified) * freebsd/lib/libc/inet/nsap_addr.c (modified) * freebsd/lib/libc/isc/ev_streams.c (modified) * freebsd/lib/libc/isc/eventlib_p.h (modified) * freebsd/lib/libc/nameser/ns_name.c (modified) * freebsd/lib/libc/nameser/ns_parse.c (modified) * freebsd/lib/libc/nameser/ns_print.c (modified) * freebsd/lib/libc/nameser/ns_samedomain.c (modified) * freebsd/lib/libc/net/base64.c (modified) * freebsd/lib/libc/net/ether_addr.c (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libc/net/gethostbydns.c (modified) * freebsd/lib/libc/net/getifaddrs.c (modified) * freebsd/lib/libc/net/getnameinfo.c (modified) * freebsd/lib/libc/net/getnetbyht.c (modified) * freebsd/lib/libc/net/getprotoent.c (modified) * freebsd/lib/libc/net/getservent.c (modified) * freebsd/lib/libc/net/if_indextoname.c (modified) * freebsd/lib/libc/net/if_nameindex.c (modified) * freebsd/lib/libc/net/if_nametoindex.c (modified) * freebsd/lib/libc/net/ip6opt.c (modified) * freebsd/lib/libc/net/linkaddr.c (modified) * freebsd/lib/libc/net/map_v4v6.c (modified) * freebsd/lib/libc/net/recv.c (modified) * freebsd/lib/libc/net/rthdr.c (modified) * freebsd/lib/libc/net/send.c (modified) * freebsd/lib/libc/net/vars.c (modified) * freebsd/lib/libc/posix1e/mac.c (modified) * freebsd/lib/libc/resolv/h_errno.c (modified) * freebsd/lib/libc/resolv/herror.c (modified) * freebsd/lib/libc/resolv/res_comp.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_debug.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_mkquery.c (modified) * freebsd/lib/libc/resolv/res_mkupdate.c (modified) * freebsd/lib/libc/resolv/res_query.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_state.c (modified) * freebsd/lib/libc/stdio/local.h (modified) * freebsd/lib/libipsec/ipsec_dump_policy.c (modified) * freebsd/lib/libipsec/ipsec_get_policylen.c (modified) * freebsd/lib/libipsec/ipsec_strerror.c (modified) * freebsd/lib/libipsec/pfkey.c (modified) * freebsd/lib/libipsec/pfkey_dump.c (modified) * freebsd/lib/libmemstat/memstat_all.c (modified) * freebsd/lib/libutil/expand_number.c (modified) * freebsd/lib/libutil/humanize_number.c (modified) * freebsd/sbin/dhclient/privsep.h (modified) * freebsd/sbin/ifconfig/af_atalk.c (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/af_link.c (modified) * freebsd/sbin/ifconfig/ifclone.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/ifconfig/ifpfsync.c (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/arm/include/machine/cpufunc.h (modified) * freebsd/sys/bsm/audit.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/contrib/pf/net/pfvar.h (modified) * freebsd/sys/crypto/blowfish/bf_ecb.c (modified) * freebsd/sys/crypto/blowfish/bf_enc.c (modified) * freebsd/sys/crypto/blowfish/bf_skey.c (modified) * freebsd/sys/crypto/camellia/camellia-api.c (modified) * freebsd/sys/crypto/camellia/camellia.c (modified) * freebsd/sys/crypto/des/des_enc.c (modified) * freebsd/sys/crypto/rc4/rc4.c (modified) * freebsd/sys/crypto/rijndael/rijndael-alg-fst.c (modified) * freebsd/sys/crypto/rijndael/rijndael-api.c (modified) * freebsd/sys/crypto/sha1.c (modified) * freebsd/sys/crypto/sha2/sha2.c (modified) * freebsd/sys/dev/e1000/e1000_osdep.h (modified) * freebsd/sys/dev/ofw/openfirm.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg.c (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_core.c (modified) * freebsd/sys/dev/usb/usb_debug.c (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_dynamic.c (modified) * freebsd/sys/dev/usb/usb_error.c (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_handle_request.c (modified) * freebsd/sys/dev/usb/usb_hid.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_lookup.c (modified) * freebsd/sys/dev/usb/usb_mbuf.c (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_parse.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usb_util.c (modified) * freebsd/sys/kern/subr_unit.c (modified) * freebsd/sys/libkern/arc4random.c (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/bpf_jitter.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_clone.c (modified) * freebsd/sys/net/if_epair.c (modified) * freebsd/sys/net/if_faith.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/libalias/alias.c (modified) * freebsd/sys/netinet/libalias/alias_cuseeme.c (modified) * freebsd/sys/netinet/libalias/alias_dummy.c (modified) * freebsd/sys/netinet/libalias/alias_ftp.c (modified) * freebsd/sys/netinet/libalias/alias_irc.c (modified) * freebsd/sys/netinet/libalias/alias_local.h (modified) * freebsd/sys/netinet/libalias/alias_mod.c (modified) * freebsd/sys/netinet/libalias/alias_nbt.c (modified) * freebsd/sys/netinet/libalias/alias_pptp.c (modified) * freebsd/sys/netinet/libalias/alias_proxy.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/libalias/alias_smedia.c (modified) * freebsd/sys/netinet/libalias/alias_util.c (modified) * freebsd/sys/netinet/pim.h (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/tcp.h (modified) * freebsd/sys/netinet/tcp_offload.c (modified) * freebsd/sys/netinet6/ip6_id.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netipsec/key.c (modified) * freebsd/sys/netipsec/key_debug.c (modified) * freebsd/sys/netipsec/keysock.c (modified) * freebsd/sys/netipsec/xform.h (modified) * freebsd/sys/opencrypto/cast.c (modified) * freebsd/sys/opencrypto/deflate.c (modified) * freebsd/sys/powerpc/include/machine/cpufunc.h (modified) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/security/mac/mac_framework.h (modified) * freebsd/sys/sys/aio.h (modified) * freebsd/sys/sys/capability.h (modified) * freebsd/sys/sys/file.h (modified) * freebsd/sys/sys/hash.h (modified) * freebsd/sys/sys/libkern.h (modified) * freebsd/sys/sys/racct.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_dbg.c (modified) * freebsd/usr.bin/netstat/bpf.c (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/sctp.c (modified) * rtemsbsd/include/machine/rtems-bsd-bus-dma.h (modified) * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/include/machine/rtems-bsd-thread.h (modified) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/include/rtems/bsd/sys/types.h (deleted) * rtemsbsd/rtems/ipsec_get_policylen.c (modified) * rtemsbsd/rtems/rtems-bsd-cxx.cc (modified) * rtemsbsd/rtems/rtems-bsd-generic.c (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * rtemsbsd/rtems/rtems-bsd-shell.c (modified) * rtemsbsd/rtems/rtems-kernel-assert.c (modified) * rtemsbsd/rtems/rtems-kernel-autoconf.c (modified) * rtemsbsd/rtems/rtems-kernel-configintrhook.c (modified) * rtemsbsd/rtems/rtems-kernel-delay.c (modified) * rtemsbsd/rtems/rtems-kernel-init.c (modified) * rtemsbsd/rtems/rtems-kernel-irqs.c (modified) * rtemsbsd/rtems/rtems-kernel-jail.c (modified) * rtemsbsd/rtems/rtems-kernel-malloc.c (modified) * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-nexus.c (modified) * rtemsbsd/rtems/rtems-kernel-page.c (modified) * rtemsbsd/rtems/rtems-kernel-panic.c (modified) * rtemsbsd/rtems/rtems-kernel-program.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-signal.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) * rtemsbsd/rtems/rtems-kernel-sysctl.c (modified) * rtemsbsd/rtems/rtems-kernel-sysctlbyname.c (modified) * rtemsbsd/rtems/rtems-kernel-sysctlnametomib.c (modified) * rtemsbsd/rtems/rtems-kernel-thread.c (modified) * rtemsbsd/rtems/rtems-kernel-vprintf.c (modified) * rtemsbsd/sys/dev/ffec/if_ffec_mcf548x.c (modified) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * testsuite/condvar01/test_main.c (modified) * testsuite/log01/test_main.c (modified) * testsuite/mutex01/test_main.c (modified) * testsuite/rwlock01/test_main.c (modified) * testsuite/smp01/test_main.c (modified) * testsuite/thread01/test_main.c (modified) * testsuite/timeout01/timeout_test.c (modified) Directly use provided by Newlib Thu, 07 Apr 2016 07:48:12 GMT Sebastian Huber [2017a6d] * builder.py (modified) * dhcpcd/config.h (modified) * freebsd/contrib/libpcap/nametoaddr.c (modified) * freebsd/contrib/libpcap/pcap/pcap.h (modified) * freebsd/contrib/tcpdump/tcpdump-stdinc.h (modified) * freebsd/lib/libc/include/isc/eventlib.h (modified) * freebsd/lib/libc/net/name6.c (modified) * freebsd/lib/libc/resolv/res_data.c (modified) * freebsd/lib/libc/resolv/res_findzonecut.c (modified) * freebsd/lib/libc/resolv/res_init.c (modified) * freebsd/lib/libc/resolv/res_send.c (modified) * freebsd/lib/libc/resolv/res_update.c (modified) * freebsd/sbin/dhclient/dhcpd.h (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ifconfig/ifieee80211.c (modified) * freebsd/sbin/ifconfig/ifmedia.c (modified) * freebsd/sbin/ping/ping.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * freebsd/sbin/sysctl/sysctl.c (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/contrib/altq/altq/altq_cbq.c (modified) * freebsd/sys/contrib/altq/altq/altq_red.c (modified) * freebsd/sys/contrib/altq/altq/altq_rmclass.c (modified) * freebsd/sys/contrib/pf/net/if_pfsync.c (modified) * freebsd/sys/contrib/pf/net/pf.c (modified) * freebsd/sys/contrib/pf/net/pf_if.c (modified) * freebsd/sys/contrib/pf/net/pf_ioctl.c (modified) * freebsd/sys/contrib/pf/net/pf_lb.c (modified) * freebsd/sys/contrib/pf/net/pf_norm.c (modified) * freebsd/sys/contrib/pf/net/pf_subr.c (modified) * freebsd/sys/crypto/blowfish/bf_skey.c (modified) * freebsd/sys/crypto/sha1.c (modified) * freebsd/sys/crypto/sha2/sha2.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/libkern/arc4random.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/net/if.h (modified) * freebsd/sys/net/if_bridge.c (modified) * freebsd/sys/net/if_faith.c (modified) * freebsd/sys/net/if_gif.c (modified) * freebsd/sys/netinet/ip_carp.c (modified) * freebsd/sys/netinet/ip_gre.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_id.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_options.c (modified) * freebsd/sys/netinet/ipfw/ip_dn_glue.c (modified) * freebsd/sys/netinet/ipfw/ip_dn_io.c (modified) * freebsd/sys/netinet/ipfw/ip_dummynet.c (modified) * freebsd/sys/netinet/libalias/alias_db.c (modified) * freebsd/sys/netinet/libalias/alias_sctp.h (modified) * freebsd/sys/netinet/sctp_header.h (modified) * freebsd/sys/netinet6/dest6.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/in6_src.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/nd6_rtr.c (modified) * freebsd/sys/netipsec/ipsec.c (modified) * freebsd/sys/netpfil/ipfw/ip_dn_glue.c (modified) * freebsd/sys/netpfil/ipfw/ip_dn_io.c (modified) * freebsd/sys/netpfil/ipfw/ip_dummynet.c (modified) * freebsd/sys/opencrypto/xform.c (modified) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/usr.bin/netstat/if.c (modified) * freebsd/usr.bin/netstat/mroute.c (modified) * freebsd/usr.bin/netstat/mroute6.c (modified) * freebsd/usr.bin/netstat/route.c (modified) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/include/rtems/bsd/sys/time.h (deleted) Directly use provided by Newlib Mon, 30 May 2016 14:00:25 GMT Sebastian Huber [f575822] * rtemsbsd/include/machine/rtems-bsd-rc-conf.h (modified) rtems-bsd-rc-conf.h: Add missing include Mon, 30 May 2016 14:00:07 GMT Sebastian Huber [f70f9f5] * testsuite/rcconf01/test_main.c (modified) testsuite/rcconf01: Add missing include Wed, 25 May 2016 11:11:59 GMT Sebastian Huber [43a14eb] * freebsd/sys/kern/sys_generic.c (modified) * rtemsbsd/rtems/rtems-kernel-thread.c (modified) Update due to API changes Wed, 25 May 2016 11:10:22 GMT Sebastian Huber [92e9493] * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) testsuite: Update due to API changes Wed, 25 May 2016 11:09:58 GMT Sebastian Huber [9546d90] * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-kernel-muteximpl.c (modified) rtems-bsd-mutex: Update due to API changes Wed, 18 May 2016 09:03:39 GMT Chris Johns [d8e6b4c] * rtemsbsd/rtems/rtems-bsd-rc-conf.c (modified) rc.conf: Add the net directives by default. Wed, 18 May 2016 09:03:20 GMT Chris Johns [84665b5] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc.conf: Fix the wild card regex for ifconfig_ Wed, 18 May 2016 05:21:09 GMT Chris Johns [f9fa038] * rtemsbsd/rtems/rtems-bsd-rc-conf.c (modified) Fix memory leak in rc.conf processing.
