# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 03/28/24 23:51:38 Thu, 26 Jul 2018 12:49:35 GMT Sebastian Huber [1372502] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Make sure CALLOUT_DFRMIGRATION is not used This flag supports the ... Thu, 26 Jul 2018 12:35:56 GMT Sebastian Huber [e37f03e] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Make sure CALLOUT_PROCESSED is not used This flag is only used in ... Thu, 26 Jul 2018 12:12:46 GMT Sebastian Huber [6d9d7b1] * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/sys/callout.h (modified) Critical bug fix for callouts FreeBSD has two callout executors, ... Thu, 26 Jul 2018 11:52:43 GMT Sebastian Huber [3df89c0] * testsuite/selectpollkqueue01/test_main.c (modified) selectpollkqueue01: Invalidate file descriptor This is not a ... Thu, 26 Jul 2018 10:03:45 GMT Sebastian Huber [6fb003f] * freebsd/sys/vm/uma.h (modified) * freebsd/sys/vm/uma_core.c (modified) * testsuite/syscalls01/test_main.c (modified) * testsuite/thread01/test_main.c (modified) Fix sporadic test failures via uma_timeout() Mon, 02 Jul 2018 06:21:37 GMT Sebastian Huber [94b5368] * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/sys/socketvar.h (modified) * rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h (modified) Avoid malloc() in getsockaddr() The getsockaddr() function is used ... Wed, 04 Jul 2018 05:19:01 GMT Nicolas Tsiogkas [e6f6b5e] * freebsd/sys/net/bpf.c (modified) BPF(9): Pass flags to bpfopen() Mon, 02 Jul 2018 07:16:14 GMT Sebastian Huber [a1e4757] * testsuite/syscalls01/test_main.c (modified) syscalls01: Fix sporadic test failures Mon, 18 Jun 2018 11:22:49 GMT Christian Mauderer [a07eb67] * rtems_waf (modified) rtems_waf: Fix show-commands option. Mon, 18 Jun 2018 11:06:47 GMT Christian Mauderer [aad7461] * .gitmodules (modified) rtems_waf: Move to the public repositories. For an update from an ... Wed, 30 May 2018 11:34:36 GMT Christian Mauderer [f8cf074] * rtemsbsd/include/bsp/nexus-devices.h (modified) beagle: Disable WiFi if libbsd is build without it. Update #3351. Thu, 17 May 2018 18:35:19 GMT Christian Mauderer [e1d62e8] * waf_libbsd.py (modified) waf: Fix python3 compatibility. Wed, 02 May 2018 07:01:32 GMT Sebastian Huber [b2eb48c] * dhcpcd/dhcpcd.c (modified) * dhcpcd/namespace.h (modified) * dhcpcd/script.c (modified) * dhcpcd/script.h (modified) * libbsd.py (modified) * rtemsbsd/include/rtems/dhcpcd.h (modified) * testsuite/dhcpcd01/test_main.c (modified) dhcpcd: Add hooks Wed, 02 May 2018 06:58:48 GMT Sebastian Huber [8bd38d6] * dhcpcd/dhcpcd.c (modified) * dhcpcd/namespace.h (modified) * rtemsbsd/include/machine/rtems-bsd-commands.h (modified) * rtemsbsd/include/rtems/dhcpcd.h (added) * rtemsbsd/rtems/rtems-bsd-init-dhcp.c (modified) * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) * rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) dhcpcd: Add rtems_dhcpcd_start() Use it throughout to start the ... Thu, 03 May 2018 06:18:24 GMT Sebastian Huber [bd09f9f] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Do not create directories used by dhcpcd The dhcpcd will ... Thu, 03 May 2018 06:17:59 GMT Sebastian Huber [9c570da] * rtemsbsd/rtems/rtems-bsd-rc-conf-net.c (modified) rc_conf: Include missing header files Wed, 02 May 2018 09:25:18 GMT Christian Mauderer [dd35ec5] * builder.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Allow to add libs per test. Update #3419. Wed, 02 May 2018 09:56:39 GMT Christian Mauderer [a779a3b] * freebsd/sbin/pfctl/parse.c (modified) * freebsd/sbin/pfctl/parse.y (modified) pfctl: Undef INET6 to avoid warning. Wed, 25 Apr 2018 14:28:00 GMT Christian Mauderer [338f300] * builder.py (modified) * buildset/default.ini (modified) * buildset/everything.ini (added) * buildset/minimal.ini (added) * buildset/sample.ini (deleted) * dhcpcd/config.h (modified) * dhcpcd/dhcp6.c (modified) * dhcpcd/ipv6.c (modified) * dhcpcd/ipv6.h (modified) * dhcpcd/ipv6nd.c (modified) * dhcpcd/platform.h (modified) * freebsd/lib/libc/rpc/rpcb_clnt.c (modified) * freebsd/sbin/ifconfig/ifconfig.c (modified) * freebsd/sbin/ping6/ping6.c (modified) * libbsd.py (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-user-space.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_inet6.h (modified) * testsuite/commands01/test_main.c (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/media01/test_main.c (modified) buildset: Add minimal and everything config. This adds two new ... Thu, 26 Apr 2018 14:10:09 GMT Christian Mauderer [4eb2502] * freebsd/contrib/tcpdump/print-sunrpc.c (deleted) tcpdump: Remove unused file. Wed, 25 Apr 2018 12:51:07 GMT Christian Mauderer [93f1904] * waf_libbsd.py (modified) waf: Generate a rtems/bsd/modules.h The generated file defines a ... Wed, 02 May 2018 12:59:48 GMT Christian Mauderer [1588cf1] * waf_libbsd.py (modified) waf: Fix source code generators. There have been some bugs with the ... Wed, 25 Apr 2018 10:50:26 GMT Christian Mauderer [821976e] * waf_libbsd.py (modified) waf: Fix usage of build-include from config. Wed, 02 May 2018 08:35:35 GMT Sebastian Huber [634b3bf] * rtemsbsd/debugger/rtems-debugger-remote-tcp.c (deleted) * rtemsbsd/include/rtems/rtems-debugger-remote-tcp.h (deleted) rtems-debugger: Remove files They are now in the main RTEMS ... Mon, 30 Apr 2018 09:07:05 GMT Sebastian Huber [443a058] * freebsd/include/arpa/ftp.h (deleted) * libbsd.py (modified) * rtemsbsd/ftpd/ftpd-init.c (deleted) * rtemsbsd/ftpd/ftpd.c (deleted) * rtemsbsd/ftpfs/ftpfs.c (deleted) * rtemsbsd/include/rtems/ftpd.h (deleted) * rtemsbsd/include/rtems/ftpfs.h (deleted) * rtemsbsd/include/rtems/telnetd.h (deleted) * rtemsbsd/telnetd/check_passwd.c (deleted) * rtemsbsd/telnetd/des.c (deleted) * rtemsbsd/telnetd/passwd.h (deleted) * rtemsbsd/telnetd/pty.c (deleted) * rtemsbsd/telnetd/telnetd-init.c (deleted) * rtemsbsd/telnetd/telnetd.c (deleted) * waf_libbsd.py (modified) Use network services from RTEMS Close #3419. Mon, 30 Apr 2018 11:35:25 GMT Sebastian Huber [b1404f2] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) Add DHCP clientid to test default network init Fri, 27 Apr 2018 08:14:44 GMT Sebastian Huber [ef5d536] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Simplify XDMA usage Fri, 27 Apr 2018 06:39:22 GMT Sebastian Huber [d45899b] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Get rid of bounce buffer Thu, 26 Apr 2018 13:23:08 GMT Sebastian Huber [3fac9e9] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Use real interrupt Execute at91_mci_intr() in interrupt ... Thu, 26 Apr 2018 13:19:42 GMT Sebastian Huber [c7e162a] * freebsd/sys/dev/mmc/mmc.c (modified) * freebsd/sys/dev/mmc/mmcreg.h (modified) mmc: Optimize mmc_wait_for_req() Use a self-contained RTEMS binary ... Thu, 26 Apr 2018 09:14:39 GMT Sebastian Huber [4b14263] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Fix use of BOARD_MCK Thu, 26 Apr 2018 09:14:10 GMT Sebastian Huber [f092186] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Fix use of pre-processor defines Fri, 06 Apr 2018 08:35:42 GMT Christian Mauderer [854427b] * CONTRIBUTING.md (modified) * README.waf (modified) * builder.py (modified) * buildset/default.ini (added) * buildset/sample.ini (added) * libbsd.py (modified) * rtems_waf (modified) * waf_libbsd.py (modified) * wscript (modified) waf: Add configurations with different modules. Update #3351 Fri, 06 Apr 2018 07:37:35 GMT Christian Mauderer [fedd993] * builder.py (modified) * freebsd-to-rtems.py (modified) freebsd-to-rtems.py: Use all modules. Update #3351 Fri, 06 Apr 2018 07:42:29 GMT Christian Mauderer [494b156] * libbsd.py (modified) waf: Remove module without sources. There are no imported sources ... Tue, 27 Mar 2018 07:31:49 GMT Christian Mauderer [a6a6d54] * builder.py (modified) * waf_libbsd.py (modified) waf: Fix freebsd-to-rtems.py. Update #3351 Mon, 26 Mar 2018 04:14:53 GMT Chris Johns [d797c5d] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * waf_libbsd.py (modified) waf: Refactor libbsd.py to support per module generation. This ... Mon, 26 Mar 2018 04:14:52 GMT Chris Johns [f7a09b5] * builder.py (modified) * freebsd-to-rtems.py (modified) * libbsd.py (modified) * libbsd.txt (modified) * libbsd_waf.py (deleted) * waf_generator.py (deleted) * waf_libbsd.py (added) * wscript (modified) waf: Support building from libbsd.py directly from waf. Remove the ... Tue, 27 Mar 2018 12:42:31 GMT Sebastian Huber [8189ea8] * freebsd/sys/opencrypto/cryptodev.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/crypto/cryptodev.h (added) * testsuite/crypto01/test_main.c (added) CRYPTO(4): Port to RTEMS Tue, 27 Mar 2018 11:25:16 GMT Sebastian Huber [6600368] * freebsd/sys/opencrypto/cryptodev.c (added) CRYPTO(4): Import from FreeBSD Tue, 27 Mar 2018 12:41:50 GMT Sebastian Huber [b8f7836] * freebsd/sys/fs/devfs/devfs_int.h (modified) DEVFS(5): Fix warning Tue, 27 Mar 2018 12:40:19 GMT Sebastian Huber [8993827] * rtemsbsd/sys/fs/devfs/devfs_devs.c (modified) DEVFS(5): Properly initialize fp->f_cdevpriv Fri, 23 Mar 2018 06:58:18 GMT Christian Mauderer [7ec935e] * libbsd.txt (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-kernel-vprintf.c (modified) vprintf: Add handler that mutes all output. This adds a vprintf ... Fri, 23 Mar 2018 08:14:34 GMT Sebastian Huber [d300a34] * rtemsbsd/rtems/rtems-bsd-ifconfig.c (modified) Silence rtems_bsd_ifconfig() Wed, 21 Mar 2018 08:23:17 GMT Christian Mauderer [b3d1e6a] * config.inc (modified) * libbsd.txt (modified) * libbsd_waf.py (modified) * waf_generator.py (modified) config.inc: Remove unused values. Thu, 15 Mar 2018 08:09:31 GMT Christian Mauderer [b2a210c] * rtemsbsd/sys/dev/atsam/if_atsam.c (modified) if_atsam: Add checksum offload. Tue, 13 Mar 2018 14:02:55 GMT Christian Mauderer [67c35b9] * libbsd.py (modified) * libbsd_waf.py (modified) openssl: Provide deprecated functions. Some applications (like the ... Mon, 12 Mar 2018 13:38:46 GMT Sebastian Huber [eae664e] * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-kernel-muteximpl.c (modified) * testsuite/mutex01/test_main.c (modified) mutex: Use panic() after ISR lock release Using panic() with ... Tue, 06 Feb 2018 08:29:49 GMT Sebastian Huber [2275776] * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) dwc_otg: Default to USB host mode In case no "dr_mode" property is ... Tue, 06 Feb 2018 08:28:02 GMT Sebastian Huber [b79c025] * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (modified) dwc_otg: Add compatibility string, constify Support device tree of ... Mon, 05 Feb 2018 15:45:59 GMT Sebastian Huber [bcaa8a2] * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) dw_mmc: Properly init/reset DMA Mon, 05 Feb 2018 15:45:20 GMT Sebastian Huber [138bf25] * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) dw_mmc: Add MMCBR_IVAR_TIMING Mon, 05 Feb 2018 12:57:11 GMT Sebastian Huber [c30fa94] * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/mii/micphy.c (modified) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.c (added) * freebsd/sys/dev/usb/controller/dwc_otg_fdt.h (added) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-nexus-bus.h (modified) * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) * rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c (deleted) Add device tree support for Altera/Intel Cyclone V Close #3290. Mon, 05 Feb 2018 11:05:52 GMT Sebastian Huber [9906c4a] * testsuite/swi01/init.c (modified) * testsuite/timeout01/init.c (modified) tests: Fix configuration dependencies Wed, 29 Nov 2017 14:26:17 GMT Sebastian Huber [0f9258f] * rtemsbsd/powerpc/include/linux/percpu.h (modified) linux/percpu.h: Fix for uni-processor config Mon, 15 Jan 2018 13:41:58 GMT Sebastian Huber [a0633c5] * freebsd/sys/kern/subr_sleepqueue.c (modified) SLEEPQUEUE(9): Update due to API changes Update #3264. Mon, 08 Jan 2018 12:55:36 GMT Sebastian Huber [8b3da13] * rtemsbsd/rtems/rtems-kernel-termioskqueuepoll.c (modified) termios: Update due to API changes Update #2843. Thu, 11 Jan 2018 13:30:49 GMT Sebastian Huber [327f4e1] * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_macless.c (modified) sdk_dpaa: What to do with tail queue drop? The issue is this: ... Wed, 17 Jan 2018 12:28:45 GMT Sebastian Huber [d62a3df] * libbsd.py (modified) * libbsd_waf.py (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_base.c (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_base.h (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_common.h (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_macless.c (modified) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_trace.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/fm_ext.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/lnxwrp_fsl_fman.h (added) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/powerpc/include/linux/fsl_bman.h (added) * rtemsbsd/powerpc/include/linux/fsl_qman.h (added) * rtemsbsd/powerpc/include/linux/highmem.h (added) * rtemsbsd/powerpc/include/linux/net_tstamp.h (added) * rtemsbsd/sys/powerpc/drivers/net/ethernet/freescale/sdk_dpaa/if_ml.c (added) sdk_dpaa: Port to RTEMS Update #3277. Fri, 27 Oct 2017 09:50:01 GMT Sebastian Huber [f5ed3aa] * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_base.c (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_base.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_common.h (added) * linux/drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_macless.c (added) sdk_dpaa: Import from QorIQ SDK Linux ... Wed, 10 Jan 2018 14:08:19 GMT Sebastian Huber [0f6ff4a] * linux/drivers/soc/fsl/qbman/qman_ccsr.c (modified) * linux/drivers/soc/fsl/qbman/qman_portal.c (modified) * rtemsbsd/include/rtems/bsd/local/opt_dpaa.h (modified) dpaa: QMan portal only initialization Update #3277. Fri, 12 Jan 2018 12:22:10 GMT Sebastian Huber [a7d252c] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/soc/fsl/qbman/bman.c (modified) * linux/include/soc/fsl/bman.h (modified) dpaa: Add and use bman_new_pool_for_bpid() Update #3277. Wed, 10 Jan 2018 12:19:01 GMT Sebastian Huber [95fe5b1] * linux/drivers/soc/fsl/qbman/bman_ccsr.c (modified) dpaa: Use device tree throughout in BMan init Update #3277. Wed, 17 Jan 2018 12:49:44 GMT Sebastian Huber [1342fad0] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_dpaa.h (modified) dpaa: Add and use SDK_DPAA_COMPAT_STATIC Update #3277. Tue, 09 Jan 2018 10:45:31 GMT Sebastian Huber [34b7ccc] * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.c (modified) * linux/drivers/net/ethernet/freescale/dpaa/dpaa_eth.h (modified) dpaa: Support FQ_TYPE_RX_PCD Update #3277. Fri, 12 Jan 2018 12:23:24 GMT Sebastian Huber [bdf99316] * linux/drivers/soc/fsl/qbman/bman.c (modified) dpaa: Disable unused bman_pool members Update #3277. Tue, 23 Jan 2018 09:48:19 GMT Sebastian Huber [2fba1e4] * rtemsbsd/include/rtems/bsd/local/opt_dpaa.h (modified) dpaa: Remove unused configuration defines Update #3277. Wed, 10 Jan 2018 13:11:57 GMT Sebastian Huber [cfc149b] * rtemsbsd/sys/powerpc/compat.c (modified) linux/of_irq.h: Generalize of_irq_to_resource() Determine interrupt ... Wed, 17 Jan 2018 13:30:44 GMT Sebastian Huber [e4923c8] * linux/drivers/net/ethernet/freescale/fman/fman.c (modified) * linux/drivers/soc/fsl/qbman/qman_ccsr.c (modified) * rtemsbsd/powerpc/include/linux/device.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of_address.h: of_address_to_resource() Translate address in ... Wed, 10 Jan 2018 12:18:05 GMT Sebastian Huber [0f1d2f6] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/powerpc/include/linux/of_address.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of_address.h: Add of_translate_address() Update #3277. Wed, 17 Jan 2018 13:14:30 GMT Sebastian Huber [81fc57d] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of.h: Add of_find_node_by_path() Update #3277. Wed, 17 Jan 2018 13:14:10 GMT Sebastian Huber [44fca38] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of.h: Add of_read_number() Update #3277. Wed, 17 Jan 2018 13:13:53 GMT Sebastian Huber [26ce2ac] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of.h: Add of_n_size_cells() Update #3277. Wed, 17 Jan 2018 13:13:34 GMT Sebastian Huber [0d421d8] * rtemsbsd/powerpc/include/linux/of.h (modified) * rtemsbsd/sys/powerpc/compat.c (modified) linux/of.h: Add of_n_addr_cells() Update #3277. Wed, 17 Jan 2018 12:26:11 GMT Sebastian Huber [066b536] * rtemsbsd/powerpc/include/linux/sort.h (added) linux/sort.h: New file Update #3277. Tue, 16 Jan 2018 12:07:36 GMT Sebastian Huber [583216a] * rtemsbsd/powerpc/include/linux/smp.h (modified) linux/smp.h: Avoid function call overhead Update #3277. Thu, 02 Nov 2017 13:29:57 GMT Sebastian Huber [fe05886] * rtemsbsd/powerpc/include/linux/compiler.h (modified) linux/compiler.h: Define __cold Update #3277. Tue, 23 Jan 2018 10:52:50 GMT Sebastian Huber [2253814] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-ifconfig.c (added) Add rtems_bsd_ifconfig() Wed, 17 Jan 2018 10:48:36 GMT Sebastian Huber [13c4093] * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) ehci_mpc83xx.c: Fix for qoriq hypervisor guest Tue, 16 Jan 2018 12:06:39 GMT Sebastian Huber [ea121a0] * freebsd/sys/vm/uma_core.c (modified) ZONE(9): Avoid function call overhead Mon, 08 Jan 2018 12:54:29 GMT Sebastian Huber [4e17f14] * freebsd/sys/sys/bus.h (modified) DEVICE(9): Fix __BUS_ACCESSOR() Fri, 22 Dec 2017 12:18:25 GMT Sebastian Huber [4e3a5d3] * freebsd/crypto/openssl/crypto/bf/bf_cbc.c (deleted) * libbsd.py (modified) * libbsd_waf.py (modified) openssl: Remove superfluous file Wed, 29 Nov 2017 14:26:54 GMT Sebastian Huber [b1649d6] * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-init-dhcp.c (added) Add rtems_bsd_initialize_dhcp() Fri, 17 Nov 2017 13:23:55 GMT Christian Mauderer [9569b39] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Fix for 32k buffer. Fri, 17 Nov 2017 09:49:59 GMT Sebastian Huber [c360b1a] * freebsd/sys/sys/_rwlock.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-rwlock.h (deleted) * rtemsbsd/include/machine/rtems-bsd-rwlockimpl.h (deleted) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlockimpl.c (deleted) * testsuite/rwlock01/test_main.c (modified) Revert "RWLOCK(9): Add reader/writer lock implementation" This was ... Fri, 17 Nov 2017 09:49:31 GMT Sebastian Huber [b5822c2] * freebsd/sys/sys/_sx.h (modified) * freebsd/sys/sys/sx.h (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) Revert "SX(9): Implement with reader/writer lock" This was ... Wed, 15 Nov 2017 10:49:09 GMT Sebastian Huber [cc7a8d8] * freebsd/sys/sys/_sx.h (modified) * freebsd/sys/sys/sx.h (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) SX(9): Implement with reader/writer lock Tue, 14 Nov 2017 11:57:01 GMT Sebastian Huber [97a98f6] * freebsd/sys/sys/_rwlock.h (modified) * libbsd.py (modified) * libbsd_waf.py (modified) * rtemsbsd/include/machine/rtems-bsd-rwlock.h (added) * rtemsbsd/include/machine/rtems-bsd-rwlockimpl.h (added) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlockimpl.c (added) * testsuite/rwlock01/test_main.c (modified) RWLOCK(9): Add reader/writer lock implementation Thu, 16 Nov 2017 07:17:03 GMT Sebastian Huber [344b8e6] * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) LOCKING(9): Remove dead code (DDB) Thu, 16 Nov 2017 07:15:37 GMT Sebastian Huber [3f23fcd] * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) LOCKING(9): Remove dead code (KDTRACE_HOOKS) Tue, 14 Nov 2017 12:06:39 GMT Sebastian Huber [9c1490a] * rtemsbsd/include/machine/_kernel_lock.h (modified) * rtemsbsd/rtems/rtems-kernel-mutex.c (modified) * rtemsbsd/rtems/rtems-kernel-rwlock.c (modified) * rtemsbsd/rtems/rtems-kernel-sx.c (modified) LOCKING(9): Update to current FreeBSD version Wed, 15 Nov 2017 12:24:29 GMT Sebastian Huber [b03a1c0] * freebsd/sys/kern/uipc_syscalls.c (modified) Fix file descriptor reference counting in accept() Update #3132. Fri, 10 Nov 2017 13:19:29 GMT Sebastian Huber [06f06d4] * freebsd/sys/sys/mutex.h (modified) Fix warning Fri, 10 Nov 2017 13:04:48 GMT Sebastian Huber [4525674] * freebsd/contrib/tcpdump/addrtoname.c (modified) * freebsd/contrib/tcpdump/addrtostr.c (modified) * freebsd/contrib/tcpdump/af.c (modified) * freebsd/contrib/tcpdump/ascii_strcasecmp.c (modified) * freebsd/contrib/tcpdump/bpf_dump.c (modified) * freebsd/contrib/tcpdump/checksum.c (modified) * freebsd/contrib/tcpdump/cpack.c (modified) * freebsd/contrib/tcpdump/gmpls.c (modified) * freebsd/contrib/tcpdump/gmt2local.c (modified) * freebsd/contrib/tcpdump/in_cksum.c (modified) * freebsd/contrib/tcpdump/ipproto.c (modified) * freebsd/contrib/tcpdump/l2vpn.c (modified) * freebsd/contrib/tcpdump/machdep.c (modified) * freebsd/contrib/tcpdump/netdissect.c (modified) * freebsd/contrib/tcpdump/nlpid.c (modified) * freebsd/contrib/tcpdump/oui.c (modified) * freebsd/contrib/tcpdump/parsenfsfh.c (modified) * freebsd/contrib/tcpdump/print-802_11.c (modified) * freebsd/contrib/tcpdump/print-802_15_4.c (modified) * freebsd/contrib/tcpdump/print-ah.c (modified) * freebsd/contrib/tcpdump/print-ahcp.c (modified) * freebsd/contrib/tcpdump/print-aodv.c (modified) * freebsd/contrib/tcpdump/print-aoe.c (modified) * freebsd/contrib/tcpdump/print-ap1394.c (modified) * freebsd/contrib/tcpdump/print-arcnet.c (modified) * freebsd/contrib/tcpdump/print-arp.c (modified) * freebsd/contrib/tcpdump/print-ascii.c (modified) * freebsd/contrib/tcpdump/print-atalk.c (modified) * freebsd/contrib/tcpdump/print-atm.c (modified) * freebsd/contrib/tcpdump/print-babel.c (modified) * freebsd/contrib/tcpdump/print-beep.c (modified) * freebsd/contrib/tcpdump/print-bfd.c (modified) * freebsd/contrib/tcpdump/print-bgp.c (modified) * freebsd/contrib/tcpdump/print-bootp.c (modified) * freebsd/contrib/tcpdump/print-bt.c (modified) * freebsd/contrib/tcpdump/print-calm-fast.c (modified) * freebsd/contrib/tcpdump/print-carp.c (modified) * freebsd/contrib/tcpdump/print-cdp.c (modified) * freebsd/contrib/tcpdump/print-cfm.c (modified) * freebsd/contrib/tcpdump/print-chdlc.c (modified) * freebsd/contrib/tcpdump/print-cip.c (modified) * freebsd/contrib/tcpdump/print-cnfp.c (modified) * freebsd/contrib/tcpdump/print-dccp.c (modified) * freebsd/contrib/tcpdump/print-decnet.c (modified) * freebsd/contrib/tcpdump/print-dhcp6.c (modified) * freebsd/contrib/tcpdump/print-domain.c (modified) * freebsd/contrib/tcpdump/print-dtp.c (modified) * freebsd/contrib/tcpdump/print-dvmrp.c (modified) * freebsd/contrib/tcpdump/print-eap.c (modified) * freebsd/contrib/tcpdump/print-egp.c (modified) * freebsd/contrib/tcpdump/print-eigrp.c (modified) * freebsd/contrib/tcpdump/print-enc.c (modified) * freebsd/contrib/tcpdump/print-esp.c (modified) * freebsd/contrib/tcpdump/print-ether.c (modified) * freebsd/contrib/tcpdump/print-fddi.c (modified) * freebsd/contrib/tcpdump/print-forces.c (modified) * freebsd/contrib/tcpdump/print-fr.c (modified) * freebsd/contrib/tcpdump/print-frag6.c (modified) * freebsd/contrib/tcpdump/print-ftp.c (modified) * freebsd/contrib/tcpdump/print-geneve.c (modified) * freebsd/contrib/tcpdump/print-geonet.c (modified) * freebsd/contrib/tcpdump/print-gre.c (modified) * freebsd/contrib/tcpdump/print-hncp.c (modified) * freebsd/contrib/tcpdump/print-hsrp.c (modified) * freebsd/contrib/tcpdump/print-http.c (modified) * freebsd/contrib/tcpdump/print-icmp.c (modified) * freebsd/contrib/tcpdump/print-icmp6.c (modified) * freebsd/contrib/tcpdump/print-igmp.c (modified) * freebsd/contrib/tcpdump/print-igrp.c (modified) * freebsd/contrib/tcpdump/print-ip.c (modified) * freebsd/contrib/tcpdump/print-ip6.c (modified) * freebsd/contrib/tcpdump/print-ip6opts.c (modified) * freebsd/contrib/tcpdump/print-ipcomp.c (modified) * freebsd/contrib/tcpdump/print-ipfc.c (modified) * freebsd/contrib/tcpdump/print-ipnet.c (modified) * freebsd/contrib/tcpdump/print-ipx.c (modified) * freebsd/contrib/tcpdump/print-isakmp.c (modified) * freebsd/contrib/tcpdump/print-isoclns.c (modified) * freebsd/contrib/tcpdump/print-juniper.c (modified) * freebsd/contrib/tcpdump/print-krb.c (modified) * freebsd/contrib/tcpdump/print-l2tp.c (modified) * freebsd/contrib/tcpdump/print-lane.c (modified) * freebsd/contrib/tcpdump/print-ldp.c (modified) * freebsd/contrib/tcpdump/print-lisp.c (modified) * freebsd/contrib/tcpdump/print-llc.c (modified) * freebsd/contrib/tcpdump/print-lldp.c (modified) * freebsd/contrib/tcpdump/print-lmp.c (modified) * freebsd/contrib/tcpdump/print-loopback.c (modified) * freebsd/contrib/tcpdump/print-lspping.c (modified) * freebsd/contrib/tcpdump/print-lwapp.c (modified) * freebsd/contrib/tcpdump/print-lwres.c (modified) * freebsd/contrib/tcpdump/print-m3ua.c (modified) * freebsd/contrib/tcpdump/print-medsa.c (modified) * freebsd/contrib/tcpdump/print-mobile.c (modified) * freebsd/contrib/tcpdump/print-mobility.c (modified) * freebsd/contrib/tcpdump/print-mpcp.c (modified) * freebsd/contrib/tcpdump/print-mpls.c (modified) * freebsd/contrib/tcpdump/print-mptcp.c (modified) * freebsd/contrib/tcpdump/print-msdp.c (modified) * freebsd/contrib/tcpdump/print-msnlb.c (modified) * freebsd/contrib/tcpdump/print-nfs.c (modified) * freebsd/contrib/tcpdump/print-nsh.c (modified) * freebsd/contrib/tcpdump/print-ntp.c (modified) * freebsd/contrib/tcpdump/print-null.c (modified) * freebsd/contrib/tcpdump/print-olsr.c (modified) * freebsd/contrib/tcpdump/print-openflow-1.0.c (modified) * freebsd/contrib/tcpdump/print-openflow.c (modified) * freebsd/contrib/tcpdump/print-ospf.c (modified) * freebsd/contrib/tcpdump/print-ospf6.c (modified) * freebsd/contrib/tcpdump/print-otv.c (modified) * freebsd/contrib/tcpdump/print-pflog.c (modified) * freebsd/contrib/tcpdump/print-pfsync.c (modified) * freebsd/contrib/tcpdump/print-pgm.c (modified) * freebsd/contrib/tcpdump/print-pim.c (modified) * freebsd/contrib/tcpdump/print-pktap.c (modified) * freebsd/contrib/tcpdump/print-ppi.c (modified) * freebsd/contrib/tcpdump/print-ppp.c (modified) * freebsd/contrib/tcpdump/print-pppoe.c (modified) * freebsd/contrib/tcpdump/print-pptp.c (modified) * freebsd/contrib/tcpdump/print-radius.c (modified) * freebsd/contrib/tcpdump/print-raw.c (modified) * freebsd/contrib/tcpdump/print-resp.c (modified) * freebsd/contrib/tcpdump/print-rip.c (modified) * freebsd/contrib/tcpdump/print-ripng.c (modified) * freebsd/contrib/tcpdump/print-rpki-rtr.c (modified) * freebsd/contrib/tcpdump/print-rrcp.c (modified) * freebsd/contrib/tcpdump/print-rsvp.c (modified) * freebsd/contrib/tcpdump/print-rt6.c (modified) * freebsd/contrib/tcpdump/print-rtsp.c (modified) * freebsd/contrib/tcpdump/print-rx.c (modified) * freebsd/contrib/tcpdump/print-sctp.c (modified) * freebsd/contrib/tcpdump/print-sflow.c (modified) * freebsd/contrib/tcpdump/print-sip.c (modified) * freebsd/contrib/tcpdump/print-sl.c (modified) * freebsd/contrib/tcpdump/print-sll.c (modified) * freebsd/contrib/tcpdump/print-slow.c (modified) * freebsd/contrib/tcpdump/print-smb.c (modified) * freebsd/contrib/tcpdump/print-smtp.c (modified) * freebsd/contrib/tcpdump/print-snmp.c (modified) * freebsd/contrib/tcpdump/print-stp.c (modified) * freebsd/contrib/tcpdump/print-sunatm.c (modified) * freebsd/contrib/tcpdump/print-symantec.c (modified) * freebsd/contrib/tcpdump/print-syslog.c (modified) * freebsd/contrib/tcpdump/print-tcp.c (modified) * freebsd/contrib/tcpdump/print-telnet.c (modified) * freebsd/contrib/tcpdump/print-tftp.c (modified) * freebsd/contrib/tcpdump/print-timed.c (modified) * freebsd/contrib/tcpdump/print-tipc.c (modified) * freebsd/contrib/tcpdump/print-token.c (modified) * freebsd/contrib/tcpdump/print-udld.c (modified) * freebsd/contrib/tcpdump/print-udp.c (modified) * freebsd/contrib/tcpdump/print-usb.c (modified) * freebsd/contrib/tcpdump/print-vjc.c (modified) * freebsd/contrib/tcpdump/print-vqp.c (modified) * freebsd/contrib/tcpdump/print-vrrp.c (modified) * freebsd/contrib/tcpdump/print-vtp.c (modified) * freebsd/contrib/tcpdump/print-vxlan-gpe.c (modified) * freebsd/contrib/tcpdump/print-vxlan.c (modified) * freebsd/contrib/tcpdump/print-wb.c (modified) * freebsd/contrib/tcpdump/print-zephyr.c (modified) * freebsd/contrib/tcpdump/print-zeromq.c (modified) * freebsd/contrib/tcpdump/print.c (modified) * freebsd/contrib/tcpdump/setsignal.c (modified) * freebsd/contrib/tcpdump/signature.c (modified) * freebsd/contrib/tcpdump/smbutil.c (modified) * freebsd/contrib/tcpdump/tcpdump.c (modified) * freebsd/contrib/tcpdump/util-print.c (modified) tcpdump: Fix import/export Thu, 09 Nov 2017 13:35:13 GMT Christian Mauderer [9521c08] * freebsd/contrib/wpa/src/utils/os_unix.c (modified) wpa_supplicant: Use arc4random instead of getentropy. Tue, 17 Oct 2017 17:22:36 GMT gordon [bc4bb2e] * freebsd/contrib/wpa/src/ap/wpa_auth.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth.h (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_ft.c (modified) * freebsd/contrib/wpa/src/ap/wpa_auth_i.h (modified) * freebsd/contrib/wpa/src/common/wpa_common.h (modified) * freebsd/contrib/wpa/src/rsn_supp/tdls.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c (modified) * freebsd/contrib/wpa/src/rsn_supp/wpa_i.h (modified) * freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c (modified) * freebsd/contrib/wpa/wpa_supplicant/events.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h (modified) Update wpa_supplicant/hostapd for 2017-01 vulnerability release. ... Wed, 08 Nov 2017 13:11:09 GMT Christian Mauderer [bdc4f21] * freebsd/contrib/wpa/src/rsn_supp/tdls.c (modified) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c (modified) * libbsd.py (modified) * libbsd_waf.py (modified) wpa: Port to new files to RTEMS. Wed, 08 Nov 2017 13:10:40 GMT Christian Mauderer [b0f0b2f] * freebsd/contrib/wpa/src/ap/pmksa_cache_auth.h (added) * freebsd/contrib/wpa/src/ap/wmm.h (added) * freebsd/contrib/wpa/src/ap/wpa_auth.c (added) * freebsd/contrib/wpa/src/ap/wpa_auth.h (added) * freebsd/contrib/wpa/src/ap/wpa_auth_ft.c (added) * freebsd/contrib/wpa/src/ap/wpa_auth_i.h (added) * freebsd/contrib/wpa/src/ap/wpa_auth_ie.h (added) * freebsd/contrib/wpa/src/eapol_auth/eapol_auth_sm.h (added) * freebsd/contrib/wpa/src/radius/radius.h (added) * freebsd/contrib/wpa/src/rsn_supp/tdls.c (added) * freebsd/contrib/wpa/src/utils/bitfield.h (added) * freebsd/contrib/wpa/wpa_supplicant/wnm_sta.c (added) wpa: Import all files for KRACK patch. Wed, 08 Nov 2017 10:25:59 GMT Christian Mauderer [a506ba9] * freebsd/sys/arm/at91/at91_mci.c (modified) at91_mci: Add timing to read_ivar. Wed, 08 Nov 2017 09:44:48 GMT Christian Mauderer [e7f3260] * freebsd/sys/sys/bus.h (modified) freebsd/bus: Check return value of bus_accessor.
