# # ChangeLog for / in rtems-libbsd # # Generated by Trac 1.2.1.dev0 # 06/17/24 03:09:16 Wed, 20 May 2015 07:48:33 GMT Sebastian Huber [76395ec] * rtemsbsd/rtems/rtems-bsd-chunk.c (modified) rtems-bsd-chunk: Include missing header file Wed, 20 May 2015 07:45:38 GMT Chris Johns [feaf877] * wscript (added) wscript: Generate. Wed, 20 May 2015 07:45:16 GMT Chris Johns [5ba6949] * .gitignore (modified) * .gitmodules (modified) * builder.py (modified) * freebsd-to-rtems.py (modified) * rtems_waf (added) * waf_generator.py (added) Add support to build using waf. Mon, 18 May 2015 01:00:33 GMT Chris Johns [66ec94a] * Makefile (modified) Makefile: Regenerate Sat, 16 May 2015 06:52:52 GMT Chris Johns [6dc8649] * makefile.py (modified) freebsd-to-rtems: Fix the Makefile test generator. This removes the ... Wed, 08 Apr 2015 09:35:27 GMT Sebastian Huber [4dab3a0] * freebsd/sys/vm/uma_core.c (modified) ZONE(9): Disable uma_prealloc() Mon, 16 Mar 2015 20:39:14 GMT Sebastian Huber [278bc93] * Makefile (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ehci.h (modified) * libbsd.py (modified) * rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c (modified) * rtemsbsd/sys/dev/usb/controller/ohci_lpc.c (added) * rtemsbsd/sys/dev/usb/controller/ohci_lpc24xx.c (deleted) * rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c (deleted) * rtemsbsd/sys/dev/usb/controller/usb_otg_transceiver.c (added) * rtemsbsd/sys/dev/usb/controller/usb_otg_transceiver_dump.c (added) * rtemsbsd/sys/dev/usb/usb_otg_transceiver.h (added) usb: Import USB support from libusb Fri, 15 May 2015 13:28:09 GMT Sebastian Huber [a0828f9] * Makefile (modified) Makefile: Regenerate Fri, 15 May 2015 13:39:34 GMT Sebastian Huber [0799761] * libbsd.py (modified) Disable IEEE 802.11 module Fri, 01 May 2015 06:02:22 GMT Chris Johns [314be23] * .gitignore (modified) * builder.py (added) * freebsd-to-rtems.py (modified) * libbsd.py (added) * makefile.py (added) freebsd-to-rtems: Refactor the conversion support to allow multiples ... Thu, 23 Apr 2015 12:56:08 GMT Sebastian Huber [67f8497] * freebsd/sys/kern/subr_sleepqueue.c (modified) SLEEPQUEUE(9): Update due to API changes Thu, 23 Apr 2015 12:55:42 GMT Sebastian Huber [c0b0b3e] * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-bsd-muteximpl.c (modified) rtems-bsd-mutex: Update due to API changes Wed, 08 Apr 2015 05:52:14 GMT Sebastian Huber [c6e85ef] * freebsd/sys/sys/kernel.h (modified) * rtemsbsd/rtems/rtems-bsd-init.c (modified) Use signed integer type for ticks Wed, 08 Apr 2015 05:22:01 GMT Sebastian Huber [8b722db] * freebsd/sys/kern/subr_sleepqueue.c (modified) SLEEPQUEUE(9): Include missing header file Tue, 07 Apr 2015 13:31:27 GMT Sebastian Huber [4f75a78] * Makefile (modified) * freebsd-to-rtems.py (modified) * rtemsbsd/mghttpd/mongoose.c (added) * rtemsbsd/mghttpd/mongoose.h (added) mghttpd: Import from RTEMS Tue, 07 Apr 2015 12:00:07 GMT Sebastian Huber [0c395c0] * .gitignore (modified) * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/include/rpc/rpcb_prot.h (added) * freebsd/lib/libc/net/nslexer.c (added) * freebsd/lib/libc/net/nsparser.c (added) * freebsd/lib/libc/net/nsparser.h (added) * freebsd/lib/libipsec/policy_parse.c (added) * freebsd/lib/libipsec/policy_token.c (added) * freebsd/lib/libipsec/y.tab.h (added) * freebsd/sbin/route/keywords.h (added) Add generated files This avoids dependencies on a particular ... Tue, 07 Apr 2015 11:54:23 GMT Sebastian Huber [da5e3a2] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Avoid mbuf use after free Tue, 07 Apr 2015 11:53:16 GMT Sebastian Huber [ebc797f] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Increase DMA descriptor count This prevents some packet ... Tue, 07 Apr 2015 11:00:20 GMT Sebastian Huber [fb7a532] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Typo Wed, 01 Apr 2015 07:44:31 GMT Sebastian Huber [f6894a8] * rtemsbsd/include/sys/_stdint.h (deleted) The is now available in Newlib Thu, 26 Mar 2015 14:39:18 GMT Sebastian Huber [aee6864] * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-cache.h (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) if_dwc: Add Altera Cyclone V support Mon, 30 Mar 2015 12:30:04 GMT Sebastian Huber [6b176ce] * freebsd/sys/dev/dwc/if_dwc.c (modified) * freebsd/sys/dev/dwc/if_dwc.h (modified) if_dwc: Checksum offload Mon, 30 Mar 2015 09:40:24 GMT Sebastian Huber [a681853] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Avoid tx defrag if possible Drop packets in case of ... Mon, 30 Mar 2015 09:51:36 GMT Sebastian Huber [822aa5de] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Simplify tx desc setup Mon, 30 Mar 2015 07:51:18 GMT Sebastian Huber [dd1feda] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Fix transmit starvation Fri, 27 Mar 2015 08:48:27 GMT Sebastian Huber [1535c87] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Avoid NULL pointer access Thu, 26 Mar 2015 14:11:41 GMT Sebastian Huber [4a5a309] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Fix warning Fri, 27 Mar 2015 13:16:40 GMT Sebastian Huber [6a4b5a4] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Use explicit cache operations Fri, 27 Mar 2015 10:14:44 GMT Sebastian Huber [d5ad68a] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Move interrupt handler install Fri, 27 Mar 2015 10:14:22 GMT Sebastian Huber [8f12e89b] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Reduce DMA descriptor count Thu, 26 Mar 2015 14:21:07 GMT Sebastian Huber [c94bb49] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Add nexus device support Thu, 26 Mar 2015 14:19:53 GMT Sebastian Huber [d3a6abb] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Use rtems_bsd_get_mac_address() Thu, 26 Mar 2015 14:13:18 GMT Sebastian Huber [acab727] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Workaround for missing FDT support Thu, 26 Mar 2015 14:09:57 GMT Sebastian Huber [13afbe7] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Silence warning Thu, 26 Mar 2015 14:08:36 GMT Sebastian Huber [36a92df] * freebsd/sys/dev/dwc/if_dwc.c (modified) if_dwc: Workaround for if_inc_counter() Thu, 26 Mar 2015 13:25:44 GMT Sebastian Huber [0c10bd5] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/dev/dwc/if_dwc.c (added) * freebsd/sys/dev/dwc/if_dwc.h (added) if_dwc: Import from FreeBSD Fri, 27 Mar 2015 13:25:16 GMT Sebastian Huber [2121b4f] * freebsd/sys/dev/mii/micphy.c (modified) micphy: Hack to set some skew values This works for the Altera ... Fri, 27 Mar 2015 10:13:25 GMT Sebastian Huber [710d2a1] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/dev/mii/micphy.c (added) * freebsd/sys/dev/mii/ukphy.c (added) * freebsd/sys/dev/mii/ukphy_subr.c (added) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) mii: Add phy devices Mon, 30 Mar 2015 07:52:17 GMT Sebastian Huber [4ccf797] * rtemsbsd/rtems/rtems-bsd-init.c (modified) Fix maxid and maxcpus sysctls This prevents an infinte loop in ... Fri, 27 Mar 2015 14:05:44 GMT Sebastian Huber [8e37837] * rtemsbsd/ftpd/ftpd.c (modified) ftpd: Fairplay Tue, 31 Mar 2015 07:41:04 GMT Sebastian Huber [f8367a1] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) tests: Support DEFAULT_EARLY_INITIALIZATION Mon, 30 Mar 2015 21:01:09 GMT Sebastian Huber [49b9c5e] * Makefile (modified) * freebsd-to-rtems.py (modified) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/lagg01/test_main.c (added) LAGG(4): Enable and test Mon, 30 Mar 2015 19:28:26 GMT Sebastian Huber [012c263] * Makefile (modified) * freebsd-to-rtems.py (modified) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) * testsuite/vlan01/test_main.c (added) VLAN(4): Enable and test Mon, 30 Mar 2015 20:33:24 GMT Sebastian Huber [675acb2] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) tests: Fix define usage Thu, 26 Mar 2015 09:24:30 GMT Sebastian Huber [d0ecc91] * Makefile (modified) * freebsd-to-rtems.py (modified) * testsuite/include/rtems/bsd/test/default-init.h (modified) * testsuite/media01/test_main.c (added) media01: New test Thu, 26 Mar 2015 12:48:37 GMT Sebastian Huber [8179d4c] * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (modified) dw_mmc: Implement host acquire/release This should avoid the "mmc: ... Thu, 26 Mar 2015 11:09:24 GMT Sebastian Huber [9ea1778] * freebsd/sys/dev/mmc/mmc.c (modified) mmc: Remove RTEMS special cases Mon, 16 Mar 2015 21:10:36 GMT Sebastian Huber [fc9e83b] * Makefile (modified) * Makefile.todo (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/dev/mmc/bridge.h (added) * freebsd/sys/dev/mmc/mmc.c (added) * freebsd/sys/dev/mmc/mmcbrvar.h (added) * freebsd/sys/dev/mmc/mmcreg.h (added) * freebsd/sys/dev/mmc/mmcsd.c (added) * freebsd/sys/dev/mmc/mmcvar.h (added) * freebsd/sys/dev/sdhci/sdhci.c (added) * freebsd/sys/dev/sdhci/sdhci.h (added) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/rtems/bsd/local/mmcbr_if.h (added) * rtemsbsd/include/rtems/bsd/local/mmcbus_if.h (added) * rtemsbsd/local/mmcbr_if.c (added) * rtemsbsd/local/mmcbus_if.c (added) * rtemsbsd/rtems/rtems-bsd-cam.c (modified) * rtemsbsd/rtems/rtems-bsd-configintrhook.c (added) * rtemsbsd/sys/dev/dw_mmc/dw_mmc.c (added) * rtemsbsd/sys/dev/dw_mmc/dw_mmcreg.h (added) * testsuite/include/rtems/bsd/test/default-network-init.h (modified) mmc: Import MMC/SDCard support from libusb Tue, 17 Mar 2015 07:55:47 GMT Sebastian Huber [024e064] * rtemsbsd/include/bsp/nexus-devices.h (modified) nexus-devices: Fix for QorIQ T variants Tue, 24 Mar 2015 08:42:28 GMT Sebastian Huber [9bfcb86] * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-bsd-muteximpl.c (modified) rtems-bsd-mutex: Support priority changes Mon, 16 Mar 2015 15:54:56 GMT Sebastian Huber [5bcdc25] * Makefile (modified) * freebsd-to-rtems.py (modified) * testsuite/smp01/test_main.c (added) smp01: New test Sun, 15 Mar 2015 20:49:14 GMT Sebastian Huber [50553bc] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/kern_condvar.c (added) * freebsd/sys/sys/condvar.h (modified) * freebsd/sys/sys/systm.h (modified) * rtemsbsd/rtems/rtems-bsd-condvar.c (deleted) CONDVAR(9): Use FreeBSD implementation Tue, 24 Mar 2015 09:02:45 GMT Sebastian Huber [8475e7a] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/subr_sleepqueue.c (modified) * freebsd/sys/sys/proc.h (modified) * libbsd.txt (modified) * rtemsbsd/include/machine/rtems-bsd-thread.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_sleepqueue_profiling.h (added) * rtemsbsd/include/sys/sleepqueue.h (deleted) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) SLEEPQUEUE(9): Port to RTEMS Tue, 24 Mar 2015 09:02:31 GMT Sebastian Huber [9975839] * freebsd/sys/kern/subr_sleepqueue.c (added) * freebsd/sys/sys/sleepqueue.h (added) SLEEPQUEUE(9): Import from FreeBSD Tue, 24 Mar 2015 09:09:43 GMT Sebastian Huber [53b03a1] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_synch.c (modified) * freebsd/sys/sys/proc.h (modified) * rtemsbsd/include/rtems/bsd/local/opt_sched.h (added) * rtemsbsd/include/sys/kdb.h (added) * rtemsbsd/rtems/rtems-bsd-kern_synch.c (deleted) SLEEP(9): Port to RTEMS Tue, 24 Mar 2015 09:08:40 GMT Sebastian Huber [f661c79] * freebsd/sys/kern/kern_synch.c (added) SLEEP(9): Import from FreeBSD Sun, 15 Mar 2015 09:01:25 GMT Sebastian Huber [20b7d3d] * freebsd-to-rtems.py (modified) * freebsd/sys/sys/_timeval.h (deleted) * freebsd/sys/sys/select.h (modified) * rtemsbsd/include/rtems/bsd/sys/time.h (modified) * rtemsbsd/include/rtems/bsd/sys/timespec.h (modified) * rtemsbsd/rtems/rtems-bsd-timesupport.c (modified) Update due to Newlib etc. changes Sun, 15 Mar 2015 19:47:58 GMT Sebastian Huber [67e7ea5] * freebsd-to-rtems.py (modified) Special case for Mon, 09 Mar 2015 13:20:20 GMT Sebastian Huber [e5724f7] * rtemsbsd/include/machine/atomic.h (modified) atomic.h: Fix for GCC version 5 and later Fri, 06 Mar 2015 13:57:29 GMT Sebastian Huber [3cafb9a] * testsuite/include/rtems/bsd/test/default-network-init.h (modified) tests: Add PROFREPORT shell command Fri, 06 Mar 2015 12:58:45 GMT Sebastian Huber [e5db084] * freebsd/sys/sys/systm.h (modified) * freebsd/sys/vm/uma_core.c (modified) ZONE(9): Enable per-processor cache for SMP This prevents a ... Tue, 17 Feb 2015 19:49:10 GMT Sebastian Huber [8ed1b18] * rtemsbsd/include/machine/rtems-bsd-mutex.h (modified) * rtemsbsd/include/machine/rtems-bsd-muteximpl.h (modified) * rtemsbsd/rtems/rtems-bsd-muteximpl.c (modified) rtems_bsd_mutex: SMP support via ISR locks Fri, 13 Feb 2015 15:30:47 GMT Sebastian Huber [e5a0175] * rtemsbsd/include/machine/atomic.h (modified) atomic.h: Use or for SMP Fri, 13 Feb 2015 15:45:12 GMT Sebastian Huber [9a50734] * rtemsbsd/include/machine/atomic.h (modified) atomic.h: Format changes Fri, 13 Feb 2015 11:49:57 GMT Sebastian Huber [e684326] * rtemsbsd/include/machine/atomic.h (modified) * rtemsbsd/include/machine/bus_dma.h (modified) * rtemsbsd/include/machine/resource.h (modified) * rtemsbsd/include/machine/rtems-bsd-cache.h (modified) * rtemsbsd/include/machine/rtems-bsd-symbols.h (modified) * rtemsbsd/include/machine/rtems-bsd-sysinit.h (modified) Change license to BSD Fri, 13 Feb 2015 11:47:21 GMT Sebastian Huber [dd9e4ef] * rtemsbsd/include/machine/clock.h (modified) * rtemsbsd/include/machine/stdarg.h (modified) Mark header files as empty Fri, 13 Feb 2015 11:00:17 GMT Sebastian Huber [19adb93] * rtemsbsd/rtems/rtems-bsd-cxx.cc (modified) rtems-bsd-cxx.cc: Fix include order Fri, 13 Feb 2015 10:59:27 GMT Sebastian Huber [f59a2da] * Makefile (modified) * freebsd-to-rtems.py (modified) Use C11 and C++11 This is necessary to use and . Fri, 13 Feb 2015 10:51:35 GMT Sebastian Huber [be2e60c] * rtemsbsd/include/machine/rtems-bsd-taskqueue.h (deleted) * rtemsbsd/include/machine/signal.h (deleted) * rtemsbsd/include/machine/ucontext.h (deleted) Delete unused files Thu, 12 Feb 2015 12:34:09 GMT Sebastian Huber [5c0aa97] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * rtemsbsd/include/rtems/bsd/zerocopy.h (added) * rtemsbsd/rtems/rtems-bsd-mbuf.c (added) * testsuite/zerocopy01/test_main.c (added) Add zerocopy sendto Thu, 12 Feb 2015 12:26:26 GMT Sebastian Huber [f181630] * rtemsbsd/rtems/rtems-bsd-muteximpl.c (modified) rtems_bsd_mutex: Add missing ISR enable Mon, 02 Feb 2015 13:27:13 GMT Sebastian Huber [7eeb079] * freebsd-org (modified) * freebsd/include/rpc/auth.h (modified) * freebsd/include/rpc/auth_des.h (modified) * freebsd/include/rpc/auth_unix.h (modified) * freebsd/include/rpc/clnt.h (modified) * freebsd/include/rpc/clnt_soc.h (modified) * freebsd/include/rpc/pmap_clnt.h (modified) * freebsd/include/rpc/pmap_prot.h (modified) * freebsd/include/rpc/rpc.h (modified) * freebsd/include/rpc/rpc_msg.h (modified) * freebsd/include/rpc/rpcb_clnt.h (modified) * freebsd/include/rpc/rpcb_prot.x (modified) * freebsd/include/rpc/rpcent.h (modified) * freebsd/include/rpc/svc.h (modified) * freebsd/include/rpc/svc_auth.h (modified) * freebsd/include/rpc/svc_soc.h (modified) * freebsd/include/rpc/xdr.h (modified) * freebsd/lib/libc/net/getaddrinfo.c (modified) * freebsd/lib/libipsec/ipsec_dump_policy.c (modified) * freebsd/sbin/ifconfig/af_inet.c (modified) * freebsd/sbin/ifconfig/ifgroup.c (modified) * freebsd/sbin/route/keywords (modified) * freebsd/sbin/route/route.c (modified) * freebsd/sys/cam/ata/ata_all.h (modified) * freebsd/sys/cam/cam.h (modified) * freebsd/sys/cam/cam_ccb.h (modified) * freebsd/sys/cam/cam_debug.h (modified) * freebsd/sys/cam/cam_periph.h (modified) * freebsd/sys/cam/cam_xpt.h (modified) * freebsd/sys/cam/cam_xpt_sim.h (modified) * freebsd/sys/cam/scsi/scsi_all.c (modified) * freebsd/sys/cam/scsi/scsi_all.h (modified) * freebsd/sys/cam/scsi/scsi_da.h (modified) * freebsd/sys/contrib/pf/net/pf_lb.c (modified) * freebsd/sys/dev/bce/if_bce.c (modified) * freebsd/sys/dev/bce/if_bcefw.h (modified) * freebsd/sys/dev/bce/if_bcereg.h (modified) * freebsd/sys/dev/bge/if_bge.c (modified) * freebsd/sys/dev/bge/if_bgereg.h (modified) * freebsd/sys/dev/e1000/e1000_defines.h (modified) * freebsd/sys/dev/e1000/if_em.c (modified) * freebsd/sys/dev/e1000/if_igb.c (modified) * freebsd/sys/dev/e1000/if_lem.c (modified) * freebsd/sys/dev/fxp/if_fxpreg.h (modified) * freebsd/sys/dev/mii/brgphy.c (modified) * freebsd/sys/dev/pci/pci.c (modified) * freebsd/sys/dev/pci/pci_pci.c (modified) * freebsd/sys/dev/pci/pci_private.h (modified) * freebsd/sys/dev/pci/pci_user.c (modified) * freebsd/sys/dev/pci/pcib_private.h (modified) * freebsd/sys/dev/pci/pcireg.h (modified) * freebsd/sys/dev/pci/pcivar.h (modified) * freebsd/sys/dev/re/if_re.c (modified) * freebsd/sys/dev/usb/controller/ehci.c (modified) * freebsd/sys/dev/usb/controller/ohci.c (modified) * freebsd/sys/dev/usb/controller/usb_controller.c (modified) * freebsd/sys/dev/usb/controller/xhcireg.h (modified) * freebsd/sys/dev/usb/quirk/usb_quirk.c (modified) * freebsd/sys/dev/usb/storage/umass.c (modified) * freebsd/sys/dev/usb/usb.h (modified) * freebsd/sys/dev/usb/usb_bus.h (modified) * freebsd/sys/dev/usb/usb_busdma.c (modified) * freebsd/sys/dev/usb/usb_controller.h (modified) * freebsd/sys/dev/usb/usb_core.h (modified) * freebsd/sys/dev/usb/usb_dev.c (modified) * freebsd/sys/dev/usb/usb_device.c (modified) * freebsd/sys/dev/usb/usb_device.h (modified) * freebsd/sys/dev/usb/usb_freebsd.h (modified) * freebsd/sys/dev/usb/usb_generic.c (modified) * freebsd/sys/dev/usb/usb_hub.c (modified) * freebsd/sys/dev/usb/usb_hub.h (modified) * freebsd/sys/dev/usb/usb_ioctl.h (modified) * freebsd/sys/dev/usb/usb_msctest.c (modified) * freebsd/sys/dev/usb/usb_process.c (modified) * freebsd/sys/dev/usb/usb_process.h (modified) * freebsd/sys/dev/usb/usb_request.c (modified) * freebsd/sys/dev/usb/usb_transfer.c (modified) * freebsd/sys/dev/usb/usbdi.h (modified) * freebsd/sys/i386/include/machine/specialreg.h (modified) * freebsd/sys/kern/init_main.c (modified) * freebsd/sys/kern/kern_event.c (modified) * freebsd/sys/kern/kern_linker.c (modified) * freebsd/sys/kern/kern_mbuf.c (modified) * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/kern/kern_time.c (modified) * freebsd/sys/kern/kern_timeout.c (modified) * freebsd/sys/kern/subr_lock.c (modified) * freebsd/sys/kern/subr_rman.c (modified) * freebsd/sys/kern/subr_sbuf.c (modified) * freebsd/sys/kern/subr_taskqueue.c (modified) * freebsd/sys/kern/sys_generic.c (modified) * freebsd/sys/kern/uipc_sockbuf.c (modified) * freebsd/sys/kern/uipc_socket.c (modified) * freebsd/sys/kern/uipc_syscalls.c (modified) * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/mips/include/machine/cpufunc.h (modified) * freebsd/sys/net/ieee8023ad_lacp.c (modified) * freebsd/sys/net/if.c (modified) * freebsd/sys/net/if_lagg.c (modified) * freebsd/sys/net/if_media.h (modified) * freebsd/sys/net/if_spppsubr.c (modified) * freebsd/sys/net/if_tap.c (modified) * freebsd/sys/net/if_tun.c (modified) * freebsd/sys/net/if_vlan.c (modified) * freebsd/sys/net/radix.c (modified) * freebsd/sys/net/radix.h (modified) * freebsd/sys/net/radix_mpath.c (modified) * freebsd/sys/net/route.c (modified) * freebsd/sys/net/route.h (modified) * freebsd/sys/net/rtsock.c (modified) * freebsd/sys/net80211/ieee80211.h (modified) * freebsd/sys/net80211/ieee80211_proto.h (modified) * freebsd/sys/netinet/if_ether.c (modified) * freebsd/sys/netinet/in.c (modified) * freebsd/sys/netinet/in_mcast.c (modified) * freebsd/sys/netinet/in_pcb.c (modified) * freebsd/sys/netinet/ip_icmp.c (modified) * freebsd/sys/netinet/ip_input.c (modified) * freebsd/sys/netinet/ip_mroute.c (modified) * freebsd/sys/netinet/ip_output.c (modified) * freebsd/sys/netinet/sctp.h (modified) * freebsd/sys/netinet/sctp_asconf.c (modified) * freebsd/sys/netinet/sctp_auth.c (modified) * freebsd/sys/netinet/sctp_auth.h (modified) * freebsd/sys/netinet/sctp_bsd_addr.c (modified) * freebsd/sys/netinet/sctp_constants.h (modified) * freebsd/sys/netinet/sctp_dtrace_define.h (modified) * freebsd/sys/netinet/sctp_indata.c (modified) * freebsd/sys/netinet/sctp_input.c (modified) * freebsd/sys/netinet/sctp_os_bsd.h (modified) * freebsd/sys/netinet/sctp_output.c (modified) * freebsd/sys/netinet/sctp_pcb.c (modified) * freebsd/sys/netinet/sctp_pcb.h (modified) * freebsd/sys/netinet/sctp_structs.h (modified) * freebsd/sys/netinet/sctp_sysctl.c (modified) * freebsd/sys/netinet/sctp_sysctl.h (modified) * freebsd/sys/netinet/sctp_timer.c (modified) * freebsd/sys/netinet/sctp_uio.h (modified) * freebsd/sys/netinet/sctp_usrreq.c (modified) * freebsd/sys/netinet/sctputil.c (modified) * freebsd/sys/netinet/sctputil.h (modified) * freebsd/sys/netinet/tcp_input.c (modified) * freebsd/sys/netinet/tcp_reass.c (modified) * freebsd/sys/netinet/tcp_subr.c (modified) * freebsd/sys/netinet6/frag6.c (modified) * freebsd/sys/netinet6/icmp6.c (modified) * freebsd/sys/netinet6/in6.c (modified) * freebsd/sys/netinet6/in6_mcast.c (modified) * freebsd/sys/netinet6/in6_pcb.c (modified) * freebsd/sys/netinet6/ip6_forward.c (modified) * freebsd/sys/netinet6/ip6_input.c (modified) * freebsd/sys/netinet6/ip6_mroute.c (modified) * freebsd/sys/netinet6/ip6_mroute.h (modified) * freebsd/sys/netinet6/nd6.c (modified) * freebsd/sys/netinet6/nd6_nbr.c (modified) * freebsd/sys/netinet6/sctp6_usrreq.c (modified) * freebsd/sys/netpfil/ipfw/ip_dummynet.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw2.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_log.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_nat.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_private.h (modified) * freebsd/sys/netpfil/ipfw/ip_fw_sockopt.c (modified) * freebsd/sys/netpfil/ipfw/ip_fw_table.c (modified) * freebsd/sys/opencrypto/deflate.c (modified) * freebsd/sys/pci/if_rlreg.h (modified) * freebsd/sys/rpc/types.h (modified) * freebsd/sys/sys/_rmlock.h (modified) * freebsd/sys/sys/_rwlock.h (modified) * freebsd/sys/sys/ata.h (modified) * freebsd/sys/sys/bus_dma.h (modified) * freebsd/sys/sys/conf.h (modified) * freebsd/sys/sys/eventhandler.h (modified) * freebsd/sys/sys/eventvar.h (modified) * freebsd/sys/sys/kernel.h (modified) * freebsd/sys/sys/linker.h (modified) * freebsd/sys/sys/lockmgr.h (modified) * freebsd/sys/sys/mbuf.h (modified) * freebsd/sys/sys/mman.h (modified) * freebsd/sys/sys/pciio.h (modified) * freebsd/sys/sys/proc.h (modified) * freebsd/sys/sys/refcount.h (modified) * freebsd/sys/sys/rmlock.h (modified) * freebsd/sys/sys/rwlock.h (modified) * freebsd/sys/sys/sdt.h (modified) * freebsd/sys/sys/sockbuf.h (modified) * freebsd/sys/sys/sysctl.h (modified) * freebsd/sys/sys/sysproto.h (modified) * freebsd/sys/sys/systm.h (modified) * freebsd/sys/sys/taskqueue.h (modified) * freebsd/sys/sys/tty.h (modified) * freebsd/sys/sys/user.h (modified) * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/vm.h (modified) * freebsd/sys/vm/vm_extern.h (modified) * freebsd/usr.bin/netstat/main.c (modified) * rtemsbsd/include/rtems/bsd/local/miidevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs.h (modified) * rtemsbsd/include/rtems/bsd/local/usbdevs_data.h (modified) * rtemsbsd/include/rtems/bsd/sys/param.h (modified) * rtemsbsd/rtems/rtems-bsd-mutex.c (modified) * rtemsbsd/rtems/rtems-bsd-thread.c (modified) Update to FreeBSD 9.3 Fri, 30 Jan 2015 09:02:39 GMT Sebastian Huber [948b1a5] * freebsd-to-rtems.py (modified) freebsd-to-rtems.py: Fix revert includes Fri, 30 Jan 2015 08:49:39 GMT Sebastian Huber [cf20101] * freebsd-to-rtems.py (modified) freebsd-to-rtems.py: Change default directories Fri, 23 Jan 2015 09:54:41 GMT Sebastian Huber [bdf9bce3] * freebsd/sys/dev/tsec/if_tsec.c (modified) if_tsec: Workaround if no PHY is present Fri, 23 Jan 2015 09:24:25 GMT Sebastian Huber [c0877d7] * freebsd/sys/dev/tsec/if_tsec.c (modified) if_tsec: Disable device sysctls Mon, 18 Nov 2013 11:46:27 GMT Sebastian Huber [8fe59fe] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/dev/tsec/if_tsec.h (modified) * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/sys/dev/tsec/if_tsec_nexus.c (added) if_tsec: Add Nexus support Fri, 13 Feb 2015 09:31:27 GMT Sebastian Huber [5383ed4] * Makefile (modified) * freebsd-to-rtems.py (modified) * libbsd.txt (modified) * rtemsbsd/include/rtems/bsd/bsd.h (modified) * rtemsbsd/rtems/rtems-bsd-get-allocator-domain-size.c (added) * rtemsbsd/rtems/rtems-bsd-page.c (modified) Add and use rtems_bsd_get_allocator_domain_size() Thu, 29 Jan 2015 07:43:16 GMT Sebastian Huber [aa4f504] * freebsd/sys/kern/kern_mib.c (modified) * freebsd/sys/vm/uma_core.c (modified) ZONE(9): Enable UMA sysctls Thu, 29 Jan 2015 07:42:36 GMT Sebastian Huber [a27a1ba] * freebsd/sys/kern/kern_sysctl.c (modified) SBUF(9): Enable sbuf_new_for_sysctl() Thu, 29 Jan 2015 07:40:56 GMT Sebastian Huber [74c5b0f] * freebsd/usr.bin/netstat/mbuf.c (modified) NETSTAT(1): Disable malloc stats Thu, 29 Jan 2015 07:38:28 GMT Sebastian Huber [cbffc0b0] * freebsd/lib/libmemstat/memstat_all.c (modified) LIBMEMSTAT(3): Disable malloc sysctls Thu, 29 Jan 2015 07:24:58 GMT Sebastian Huber [513e234] * rtemsbsd/rtems/rtems-bsd-init.c (modified) Add SMP sysctls Tue, 27 Jan 2015 07:27:30 GMT Sebastian Huber [b68b88c] * freebsd/sys/vm/uma_core.c (modified) * freebsd/sys/vm/uma_int.h (modified) ZONE(9): Use page allocator Tue, 27 Jan 2015 07:26:53 GMT Sebastian Huber [3c302b6] * Makefile (modified) * freebsd-to-rtems.py (modified) * rtemsbsd/include/machine/rtems-bsd-page.h (added) * rtemsbsd/rtems/rtems-bsd-page.c (added) Add a simple page allocator Tue, 27 Jan 2015 06:58:44 GMT Sebastian Huber [8e009cd] * freebsd/sys/sys/systm.h (modified) Map bcopy() and bzero() via macros Fri, 23 Jan 2015 07:32:07 GMT Sebastian Huber [b112710] * freebsd/sys/kern/uipc_usrreq.c (modified) * freebsd/sys/net/bpf.c (modified) * freebsd/sys/sys/unpcb.h (modified) Update due to IMFS generic API changes Tue, 20 Jan 2015 10:04:39 GMT Sebastian Huber [5071600] * rtemsbsd/include/bsp/nexus-devices.h (modified) * rtemsbsd/include/machine/rtems-bsd-cache.h (modified) * testsuite/include/rtems/bsd/test/network-config.h.in (modified) Add Xilinx Zynq BSP support Tue, 25 Nov 2014 13:37:22 GMT Sebastian Huber [dae9f66] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/arm/xilinx/zy7_slcr.c (added) * freebsd/sys/arm/xilinx/zy7_slcr.h (added) zy7_slcr: Import from FreeBSD Tue, 25 Nov 2014 12:14:46 GMT Sebastian Huber [946611a] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/dev/mii/e1000phy.c (added) * freebsd/sys/dev/mii/e1000phyreg.h (added) e1000phy: Import from FreeBSD Tue, 25 Nov 2014 11:54:56 GMT Sebastian Huber [6a73f64] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Use rtems_bsd_get_mac_address() Tue, 25 Nov 2014 14:20:45 GMT Sebastian Huber [dec6b67] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Enable hardware checksum assist Tue, 25 Nov 2014 11:54:35 GMT Sebastian Huber [911f517] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Use explicit cache operations Tue, 25 Nov 2014 11:53:42 GMT Sebastian Huber [cd179c4] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Add volatile to rx/tx desc rings Tue, 25 Nov 2014 11:53:04 GMT Sebastian Huber [8c3823e] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Silence warning Tue, 20 Jan 2015 10:04:00 GMT Sebastian Huber [d65c5e5] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Add nexus device support Thu, 20 Nov 2014 14:23:05 GMT Sebastian Huber [4ff97c8] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Disable device sysctls Thu, 20 Nov 2014 06:59:45 GMT Sebastian Huber [14ecf75d] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Workaround for missing FDT support Thu, 20 Nov 2014 06:58:17 GMT Sebastian Huber [a09f00e] * freebsd/sys/dev/cadence/if_cgem.c (modified) if_cgem: Workaround for if_inc_counter() Thu, 20 Nov 2014 06:57:05 GMT Sebastian Huber [b8e0c66] * Makefile (modified) * freebsd-to-rtems.py (modified) * freebsd/sys/dev/cadence/if_cgem.c (added) * freebsd/sys/dev/cadence/if_cgem_hw.h (added) if_cgem: Import from FreeBSD
