# # ChangeLog for wscript in rtems-docs # # Generated by Trac 1.2.1.dev0 # 04/20/24 01:35:57 Wed, 27 Feb 2019 22:16:57 GMT Chris Johns [1599d99] * posix-compliance/posix_rst.py (modified) * wscript (modified) waf: Fix python3 issues. - Found after updating to FreeBSD-12.0 ... Tue, 12 Feb 2019 23:57:10 GMT Chris Johns [7b36a6b] * common/coverpage/coverpage.html (modified) * wscript (modified) waf: Use the release date in the coverpage Tue, 12 Feb 2019 23:50:50 GMT Chris Johns [d721375] * common/version.py (modified) * wscript (modified) waf: Fix version.py to support older versions of git. Tue, 12 Feb 2019 23:18:43 GMT Chris Johns [5d8b0dd] * bsp-howto/wscript (modified) * c-user/wscript (modified) * cpu-supplement/wscript (modified) * develenv/wscript (modified) * eclipse/wscript (modified) * eng/wscript (modified) * filesystem/wscript (modified) * images/wscript (modified) * networking/wscript (modified) * porting/wscript (modified) * posix-compliance/wscript (modified) * posix-users/wscript (modified) * rtemsconfig/wscript (modified) * shell/wscript (modified) * user/wscript (modified) * wscript (modified) waf: Remove as many sys path hacks as we can. There are still ... Fri, 08 Feb 2019 08:41:45 GMT Sebastian Huber [6f110cc] * book/conf.py (modified) * book/wscript (modified) * bsp-howto/conf.py (modified) * bsp-howto/wscript (modified) * c-user/conf.py (modified) * c-user/wscript (modified) * cpu-supplement/conf.py (modified) * cpu-supplement/wscript (modified) * develenv/conf.py (modified) * develenv/wscript (modified) * eclipse/conf.py (modified) * eclipse/wscript (modified) * eng/conf.py (modified) * eng/wscript (modified) * filesystem/conf.py (modified) * filesystem/wscript (modified) * images/wscript (modified) * networking/conf.py (modified) * networking/wscript (modified) * porting/conf.py (modified) * porting/wscript (modified) * posix-compliance/conf.py (modified) * posix-compliance/wscript (modified) * posix-users/conf.py (modified) * posix-users/wscript (modified) * rtemsconfig/conf.py (modified) * rtemsconfig/wscript (modified) * shell/conf.py (modified) * shell/wscript (modified) * user/conf.py (modified) * user/wscript (modified) * wscript (modified) build: Prepend project common path This avoids conflicts with ... Wed, 06 Feb 2019 22:31:33 GMT Chris Johns [98977bf] * wscript (modified) Version change, forgot to add wscript to the commit. Wed, 06 Feb 2019 05:46:42 GMT Chris Johns [2a68e9d] * common/version.py (added) * wscript (modified) Support VERSION file for releasing and deployment - Shorten the GIT ... Fri, 11 Jan 2019 09:20:08 GMT Sebastian Huber [60ed99d] * rsb/conf.py (deleted) * rsb/index.rst (deleted) * rsb/wscript (deleted) * user/index.rst (modified) * user/rsb/bug-reporting.rst (moved) * user/rsb/commands.rst (moved) * user/rsb/configuration.rst (moved) * user/rsb/cross-canadian-cross.rst (moved) * user/rsb/history.rst (moved) * user/rsb/index.rst (moved) * user/rsb/project-sets.rst (moved) * user/rsb/third-party-packages.rst (moved) * user/rsb/why-build-from-source.rst (moved) * wscript (modified) user: Add RSB content as a chapter Remove the separate RSB manual. Fri, 04 Jan 2019 10:02:45 GMT Sebastian Huber [3202e31] * common/conf.py (modified) * common/waf.py (modified) * wscript (modified) Replace build date with Git hash and commit date The usage of a ... Wed, 21 Nov 2018 16:39:04 GMT Joel Sherrill [1ae5e88] * eng/README (added) * eng/appendix-a.rst (added) * eng/change-management.rst (added) * eng/change-reports.rst (added) * eng/coding-80cols.rst (added) * eng/coding-conventions.rst (added) * eng/coding-deprecating.rst (added) * eng/coding-doxygen-bsp.rst (added) * eng/coding-doxygen.rst (added) * eng/coding-file-hdr.rst (added) * eng/coding-gen-patch.rst (added) * eng/coding-naming.rst (added) * eng/coding.rst (added) * eng/conf.py (added) * eng/index.rst (added) * eng/issue-tracking.rst (added) * eng/license-requirements.rst (added) * eng/management.rst (added) * eng/preface.rst (added) * eng/prequalification.rst (added) * eng/release-mgmt.rst (added) * eng/stakeholders.rst (added) * eng/test-plan.rst (added) * eng/test-suites.rst (added) * eng/tester.rst (added) * eng/users-manuals.rst (added) * eng/vc-authors.rst (added) * eng/vc-users.rst (added) * eng/vdd-generation.rst (added) * eng/wscript (added) * wscript (modified) Initial start of converting the Word outline to Rest Thanks to ... Fri, 02 Nov 2018 03:05:51 GMT Chris Johns [21c1a44] * README.txt (modified) * common/waf.py (modified) * images/.gitignore (added) * images/wscript (added) * wscript (modified) waf: Add support to build PlantUML and Ditaa images. Thu, 09 Nov 2017 09:22:24 GMT Sebastian Huber [60a6d6e] * c-user/configuring_a_system.rst (modified) * c-user/key_concepts.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * eclipse/rtems.rst (modified) * posix-compliance/probe_rtems (modified) * user/installation/developer.rst (modified) * user/installation/kernel.rst (modified) * user/installation/releases.rst (modified) * user/start/index.rst (modified) * user/start/quick.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * wscript (modified) Change RTEMS version to 5 Update #3220. Mon, 28 Aug 2017 18:03:40 GMT Joel Sherrill [2c3cf21] * posix-compliance/README-csv.txt (added) * posix-compliance/RTEMS-Standards-Compliance-v1.csv (added) * posix-compliance/conf.py (moved) * posix-compliance/index.rst (added) * posix-compliance/preface.rst (added) * posix-compliance/probe_misses.txt (added) * posix-compliance/probe_rtems (added) * posix-compliance/wscript (moved) * posix1003-1/clocks_and_timers.rst (deleted) * posix1003-1/command.rst (deleted) * posix1003-1/compliance_summary.rst (deleted) * posix1003-1/data_interchange_format.rst (deleted) * posix1003-1/device_and_class_specific.rst (deleted) * posix1003-1/execution_scheduling.rst (deleted) * posix1003-1/files_and_directories.rst (deleted) * posix1003-1/general.rst (deleted) * posix1003-1/index.rst (deleted) * posix1003-1/input_and_output.rst (deleted) * posix1003-1/language_specific_services.rst (deleted) * posix1003-1/memory_managment.rst (deleted) * posix1003-1/message_passing.rst (deleted) * posix1003-1/posix1003_1.rst (deleted) * posix1003-1/preface.rst (deleted) * posix1003-1/process_environment.rst (deleted) * posix1003-1/process_primitives.rst (deleted) * posix1003-1/synchronization.rst (deleted) * posix1003-1/system_database.rst (deleted) * posix1003-1/terminology.rst (deleted) * posix1003-1/thread_cancellation.rst (deleted) * posix1003-1/thread_managment.rst (deleted) * posix1003-1/thread_specific_data.rst (deleted) * wscript (modified) New version of POSIX Compliance Guide This is a replacement of the ... Sun, 26 Mar 2017 23:27:29 GMT Chris Johns [0263581] * common/waf.py (modified) * wscript (modified) waf: Fix linkcheck and spell commands. Clean up and remove code ... Mon, 20 Mar 2017 01:18:53 GMT Chris Johns [f97be09] * bsp-howto/conf.py (modified) * c-user/conf.py (modified) * common/conf.py (modified) * common/waf.py (modified) * cpu-supplement/conf.py (modified) * develenv/conf.py (modified) * eclipse/conf.py (modified) * filesystem/conf.py (modified) * networking/conf.py (modified) * porting/conf.py (modified) * posix-users/conf.py (modified) * posix1003-1/conf.py (modified) * rsb/conf.py (modified) * rtemsconfig/conf.py (modified) * shell/conf.py (modified) * user/conf.py (modified) * wscript (modified) Use a single top level version number. Fri, 13 Jan 2017 05:05:04 GMT Chris Johns [6705e5e] * wscript (modified) waf: Correct the branch version number. Thu, 12 Jan 2017 01:55:15 GMT Chris Johns [049097f] * common/coverpage/coverpage.html (moved) * common/coverpage/coverpage.js (moved) * common/coverpage/static/css/bootstrap.min.css (moved) * common/coverpage/static/css/bootstrap.min.css.map (added) * common/coverpage/static/fonts/glyphicons-halflings-regular.woff (added) * common/coverpage/static/images/Adobe_PDF_file_icon_32x32.png (moved) * common/coverpage/static/images/html-xxl.png (moved) * common/coverpage/static/js/bloodhound.js (moved) * common/coverpage/static/js/bootstrap.min.js (moved) * common/coverpage/static/js/jquery.min.js (moved) * common/coverpage/static/rtems/css/rtems.css (moved) * common/coverpage/static/rtems/image/rtemslogo.png (moved) * common/coverpage/static/rtems/js/catalogue.js (moved) * wscript (modified) coverpage: Update the coverpage to have the table collapse. Add ... Wed, 11 Jan 2017 06:04:02 GMT Chris Johns [2591ca6] * common/html-coverpage/coverpage.html (moved) * common/html-coverpage/coverpage.js (added) * common/html-coverpage/static/rtems/js/catalogue.js (modified) * wscript (modified) html: Embed the catalogue XML in JS. The is to work around a ... Wed, 11 Jan 2017 04:50:59 GMT Chris Johns [ecf82d1] * common/html-coverpage/index.html (added) * common/html-coverpage/static/css/bootstrap.min.css (added) * common/html-coverpage/static/images/Adobe_PDF_file_icon_32x32.png (added) * common/html-coverpage/static/images/html-xxl.png (added) * common/html-coverpage/static/js/bloodhound.js (added) * common/html-coverpage/static/js/bootstrap.min.js (added) * common/html-coverpage/static/js/jquery.min.js (added) * common/html-coverpage/static/rtems/css/rtems.css (added) * common/html-coverpage/static/rtems/image/rtemslogo.png (added) * common/html-coverpage/static/rtems/js/catalogue.js (added) * wscript (modified) html: Add support for an HTML cover page for releases. Tue, 10 Jan 2017 11:34:47 GMT Chris Johns [9aa52b9] * common/waf.py (modified) * wscript (modified) waf: Add a title to the XML Catalogue. Mon, 09 Jan 2017 23:11:05 GMT Chris Johns [782b4fe] * common/waf.py (modified) * wscript (modified) waf: Improved XML Catalogue generator. Mon, 09 Jan 2017 12:13:02 GMT Chris Johns [1a9b02e] * common/waf.py (modified) * wscript (modified) waf: Create an XML Catalogue. Mon, 14 Nov 2016 21:12:02 GMT Chris Johns [6345b2d] * wscript (modified) waf: Add networking to the manual built. Thu, 03 Nov 2016 05:58:08 GMT Chris Johns [72a62ad] * bsp-howto/ada95_interrupt.rst (moved) * bsp-howto/analog.rst (moved) * bsp-howto/ata.rst (moved) * bsp-howto/clock.rst (moved) * bsp-howto/command.rst (moved) * bsp-howto/conf.py (moved) * bsp-howto/console.rst (moved) * bsp-howto/discrete.rst (moved) * bsp-howto/frame_buffer.rst (moved) * bsp-howto/ide_controller.rst (moved) * bsp-howto/index.rst (moved) * bsp-howto/initilization_code.rst (moved) * bsp-howto/linker_script.rst (moved) * bsp-howto/makefiles.rst (moved) * bsp-howto/miscellanous_support.rst (moved) * bsp-howto/networking.rst (moved) * bsp-howto/non_volatile_memory.rst (moved) * bsp-howto/preface.rst (moved) * bsp-howto/real_time_clock.rst (moved) * bsp-howto/shared_memory_support.rst (moved) * bsp-howto/target_dependant_files.rst (moved) * bsp-howto/timer.rst (moved) * bsp-howto/wscript (moved) * c-user/barrier_manager.rst (moved) * c-user/board_support_packages.rst (moved) * c-user/chains.rst (moved) * c-user/clock_manager.rst (moved) * c-user/conf.py (moved) * c-user/configuring_a_system.rst (moved) * c-user/constant_bandwidth_server.rst (moved) * c-user/cpu_usage_statistics.rst (moved) * c-user/directive_status_codes.rst (moved) * c-user/dual_ports_memory_manager.rst (moved) * c-user/event_manager.rst (moved) * c-user/example_application.rst (moved) * c-user/fatal_error.rst (moved) * c-user/glossary.rst (moved) * c-user/index.rst (moved) * c-user/initialization.rst (moved) * c-user/interrupt_manager.rst (moved) * c-user/io_manager.rst (moved) * c-user/key_concepts.rst (moved) * c-user/linker_sets.rst (moved) * c-user/message_manager.rst (moved) * c-user/multiprocessing.rst (moved) * c-user/object_services.rst (moved) * c-user/overview.rst (moved) * c-user/partition_manager.rst (moved) * c-user/pci_library.rst (moved) * c-user/preface.rst (moved) * c-user/rate_monotonic_manager.rst (moved) * c-user/red_black_trees.rst (moved) * c-user/region_manager.rst (moved) * c-user/rtems_data_types.rst (moved) * c-user/scheduling_concepts.rst (moved) * c-user/semaphore_manager.rst (moved) * c-user/signal_manager.rst (moved) * c-user/stack_bounds_checker.rst (moved) * c-user/symmetric_multiprocessing_services.rst (moved) * c-user/task_manager.rst (moved) * c-user/timer_manager.rst (moved) * c-user/timespec_helpers.rst (moved) * c-user/user_extensions.rst (moved) * c-user/wscript (moved) * cpu-supplement/altera_nios_ii.rst (moved) * cpu-supplement/arm.rst (moved) * cpu-supplement/atmel_avr.rst (moved) * cpu-supplement/blackfin.rst (moved) * cpu-supplement/command.rst (moved) * cpu-supplement/conf.py (moved) * cpu-supplement/ephiphany.rst (moved) * cpu-supplement/index.rst (moved) * cpu-supplement/intel_amd_x86.rst (moved) * cpu-supplement/lattice_micro32.rst (moved) * cpu-supplement/m68xxx_and_coldfire.rst (moved) * cpu-supplement/mips.rst (moved) * cpu-supplement/openrisc_1000.rst (moved) * cpu-supplement/port.rst (moved) * cpu-supplement/powerpc.rst (moved) * cpu-supplement/preface.rst (moved) * cpu-supplement/renesas_m32c.rst (moved) * cpu-supplement/sparc.rst (moved) * cpu-supplement/sparc64.rst (moved) * cpu-supplement/superh.rst (moved) * cpu-supplement/wscript (moved) * cpu-supplement/xilinx_microblaze.rst (moved) * posix-users/clock.rst (moved) * posix-users/command.rst (moved) * posix-users/condition_variable.rst (moved) * posix-users/conf.py (moved) * posix-users/device_and_class_specific.rst (moved) * posix-users/files_and_directory.rst (moved) * posix-users/index.rst (moved) * posix-users/input_and_output.rst (moved) * posix-users/key.rst (moved) * posix-users/language_specific_services.rst (moved) * posix-users/memory_managment.rst (moved) * posix-users/message_passing.rst (moved) * posix-users/mutex.rst (moved) * posix-users/preface.rst (moved) * posix-users/process_creation_and_execution.rst (moved) * posix-users/process_environment.rst (moved) * posix-users/scheduler.rst (moved) * posix-users/semaphore.rst (moved) * posix-users/services_provided_by_c.rst (moved) * posix-users/services_provided_by_math.rst (moved) * posix-users/signal.rst (moved) * posix-users/status_of_implementation.rst (moved) * posix-users/system_database.rst (moved) * posix-users/thread.rst (moved) * posix-users/thread_cancellation.rst (moved) * posix-users/timer.rst (moved) * posix-users/wscript (moved) * posix1003-1/clocks_and_timers.rst (moved) * posix1003-1/command.rst (moved) * posix1003-1/compliance_summary.rst (moved) * posix1003-1/conf.py (moved) * posix1003-1/data_interchange_format.rst (moved) * posix1003-1/device_and_class_specific.rst (moved) * posix1003-1/execution_scheduling.rst (moved) * posix1003-1/files_and_directories.rst (moved) * posix1003-1/general.rst (moved) * posix1003-1/index.rst (moved) * posix1003-1/input_and_output.rst (moved) * posix1003-1/language_specific_services.rst (moved) * posix1003-1/memory_managment.rst (moved) * posix1003-1/message_passing.rst (moved) * posix1003-1/posix1003_1.rst (moved) * posix1003-1/preface.rst (moved) * posix1003-1/process_environment.rst (moved) * posix1003-1/process_primitives.rst (moved) * posix1003-1/synchronization.rst (moved) * posix1003-1/system_database.rst (moved) * posix1003-1/terminology.rst (moved) * posix1003-1/thread_cancellation.rst (moved) * posix1003-1/thread_managment.rst (moved) * posix1003-1/thread_specific_data.rst (moved) * posix1003-1/wscript (moved) * wscript (modified) Rename all manuals with an _ to have a -. It helps released naming of ... Sun, 30 Oct 2016 21:48:21 GMT Chris Johns [dd43d0b] * common/waf.py (modified) * user/wscript (modified) * wscript (modified) waf: Add an install command. Fri, 28 Oct 2016 21:40:44 GMT Joel Sherrill [cddb06c] * rsb/conf.py (added) * rsb/index.rst (added) * rsb/source-builder.rst (added) * rsb/wscript (added) * wscript (modified) RSB: Initial addition The content was manually converted from ... Sun, 30 Oct 2016 01:36:15 GMT Chris Johns [f529417] * common/waf.py (modified) * waf (added) * wscript (added) waf: Add top build support.
