# # ChangeLog for wscript in rtems-docs # # Generated by Trac 1.2.1.dev0 # 04/20/24 02:12:12 Sun, 30 Oct 2016 21:48:21 GMT Chris Johns [dd43d0b] * common/waf.py (modified) * user/wscript (modified) * wscript (modified) waf: Add an install command. Fri, 28 Oct 2016 21:40:44 GMT Joel Sherrill [cddb06c] * rsb/conf.py (added) * rsb/index.rst (added) * rsb/source-builder.rst (added) * rsb/wscript (added) * wscript (modified) RSB: Initial addition The content was manually converted from ... Sun, 30 Oct 2016 01:36:15 GMT Chris Johns [f529417] * common/waf.py (modified) * waf (added) * wscript (added) waf: Add top build support.
