# # ChangeLog for user in rtems-docs # # Generated by Trac 1.2.1.dev0 # 05/18/24 10:34:34 Thu, 14 Jan 2021 15:18:00 GMT Kinsey Moore [c3b4e18] * user/bsps/aarch64/xilinx-zynqmp.rst (modified) user: Update aarch64/xilinx-zynqmp Qemu command The Xilinx ZynqMP ... Tue, 22 Dec 2020 06:17:43 GMT Sebastian Huber [58bf83e] * user/tracing/eventrecording.rst (modified) user: Mention use of LLVM Mon, 14 Dec 2020 10:22:39 GMT Christian Mauderer [2cf3076] * user/bsps/arm/imxrt.rst (modified) user/bsp/imxrt: Information for custom FDT Update #4180 Mon, 07 Dec 2020 17:01:47 GMT Kinsey Moore [265bee7] * user/bsps/aarch64/xilinx-zynqmp.rst (added) * user/bsps/bsps-aarch64.rst (modified) user: Add aarch64/xilinx-zynqmp Mon, 07 Dec 2020 18:10:50 GMT Kinsey Moore [94abaa3] * user/bsps/aarch64/a53.rst (modified) user: Add A53 Qemu run instructions Mon, 07 Dec 2020 18:10:26 GMT Kinsey Moore [9c40761] * cpu-supplement/aarch64.rst (modified) * user/bsps/aarch64/a53.rst (modified) aarch64: Update interrupt details Tue, 17 Nov 2020 10:56:31 GMT Christian Mauderer [f501682] * user/bsps/bsps-arm.rst (modified) user/bsps: Fix list in bsps-arm Seems that some filenames haven't ... Tue, 17 Nov 2020 10:35:43 GMT Christian Mauderer [e95d992] * user/bsps/arm/imxrt.rst (added) * user/bsps/bsps-arm.rst (modified) user/bsps: Add imxrt Update #4180 Tue, 27 Oct 2020 06:50:27 GMT Sebastian Huber [8fe0da2] * user/bsps/arm/bsp-stm32h7.rst (added) * user/bsps/arm/stm32h7.rst (added) * user/bsps/bsps-arm.rst (modified) user: Add arm/stm32h7 Close #3910. Tue, 27 Oct 2020 06:49:40 GMT Sebastian Huber [1736aea] * user/bsps/arm/csb337.rst (moved) * user/bsps/arm/stm32f4.rst (moved) user: Rename files to match the chapter index Mon, 19 Oct 2020 01:15:01 GMT Chris Johns [25525dc] * images/user/bbb-p2-debug-mod.jpg (added) * user/bsps/arm/beagle.rst (modified) user/beagle: Add debug hardware mod Tue, 06 Oct 2020 09:10:11 GMT Sebastian Huber [9555e7c] * user/start/sources.rst (modified) user: Fix RTEMS release URLs Fri, 25 Sep 2020 13:57:07 GMT Kinsey Moore [281be0c] * cpu-supplement/aarch64.rst (added) * user/bsps/aarch64/a53.rst (added) * user/bsps/bsps-aarch64.rst (modified) Add AArch64 documentation Fri, 25 Sep 2020 05:43:08 GMT Sebastian Huber [2fb86e2] * user/bld/index.rst (modified) user: Add migration hints from old build system Update #3818. Mon, 21 Sep 2020 17:37:38 GMT Gedare Bloom [5a20671] * user/bsps/bsps-i386.rst (modified) i386: tweak grammar and style Sat, 19 Sep 2020 20:12:45 GMT Karel Gardas [b7a4d93] * user/bsps/bsps-i386.rst (modified) pc386 BSP: add runtime options for debugging and move few lines ... Sat, 19 Sep 2020 19:23:03 GMT Karel Gardas [9b5b17d] * user/bsps/bsps-i386.rst (modified) pc386 BSP: add a note about default baud rate for console over UART/COM. Fri, 22 Nov 2019 14:32:28 GMT Sebastian Huber [4ea43e3] * user/bld/index.rst (added) * user/index.rst (modified) * user/start/bootstrap.rst (deleted) * user/start/bsp-build.rst (modified) * user/start/bsp-test.rst (modified) * user/start/index.rst (modified) * user/start/preparation.rst (modified) user: Document BSP new build system Update #3818. Tue, 25 Aug 2020 10:28:19 GMT Karel Gardas [aba4c6b] * user/bsps/bsps-i386.rst (modified) user/pc386 BSP: add documentation. The content is compiled from TBR ... Tue, 08 Sep 2020 03:29:42 GMT Chris Johns [75f51d6] * user/bsps/arm/xilinx-zynq.rst (modified) user: Add xilinx-zynq BSP details Tue, 01 Sep 2020 05:03:49 GMT Sebastian Huber [bd8185a] * user/migration/v4_11-to-v5.rst (modified) user: Mention file descriptor changes Tue, 01 Sep 2020 01:44:48 GMT Chris Johns [5528b17] * user/start/rsb-packages.rst (modified) user: Change the BSP build set path Updates #4048 Thu, 13 Aug 2020 09:37:30 GMT Sebastian Huber [3d22529] * user/migration/v4_11-to-v5.rst (modified) user: Fix format Tue, 11 Aug 2020 03:40:41 GMT Chris Johns [967999b] * user/rsb/commands.rst (modified) user: Add the RSB sb-track command Updates #4036 Tue, 11 Aug 2020 02:33:03 GMT Chris Johns [b71f7f69] * README.txt (modified) * user/hosts/index.rst (modified) * user/hosts/python.rst (added) user, README: Add Python script host set up information - Add ... Tue, 11 Aug 2020 02:50:45 GMT Chris Johns [441d2e1] * eclipse/rtems.rst (modified) * user/installation/developer.rst (modified) * user/installation/kernel.rst (modified) user, eclipse: Remove RSB sb-bootstrap command Update #4046 Tue, 11 Aug 2020 02:41:57 GMT Chris Johns [089f619] * user/rsb/commands.rst (modified) * user/rsb/configuration.rst (modified) user: Remove RSB sb-builder command Updates #4045 Thu, 06 Aug 2020 11:30:25 GMT Sebastian Huber [5158395] * user/migration/v4_11-to-v5.rst (modified) user: Add shell environment migration aid Tue, 14 Jul 2020 07:37:50 GMT Sebastian Huber [31b1d88] * user/migration/v5-to-v6.rst (modified) user: Mention replacements for removed APIs Tue, 07 Jul 2020 13:05:21 GMT Sebastian Huber [b6a1d39] * user/migration/index.rst (modified) * user/migration/v5-to-v6.rst (added) user: Add v5 to v6 migration help Fri, 03 Jul 2020 05:33:38 GMT Sebastian Huber [2df6f90] * cpu-supplement/epiphany.rst (modified) * user/bsps/bsps-epiphany.rst (deleted) * user/bsps/index.rst (modified) Reflect removal of the epiphany target Update #3941. Wed, 01 Jul 2020 11:31:51 GMT Sebastian Huber [a783144] * user/bsps/arm/realview-pbx-a9.rst (modified) user: Document arm/realview-pbx-a9 BSP Tue, 28 Apr 2020 06:25:51 GMT Chris Johns [ccc473b] * user/rsb/configuration.rst (modified) user/rsb: Update the configuration documentation Closes #3945 Tue, 28 Apr 2020 05:27:11 GMT Chris Johns [8bf866b] * user/tools/tester.rst (modified) user/tester: Remove command line help as output Closes #3381 Tue, 28 Apr 2020 01:30:48 GMT Chris Johns [b42e051] * user/start/bsp-build.rst (modified) user: Update the RSB BSP quick start to say where the tests are ... Mon, 27 Apr 2020 00:03:13 GMT Chris Johns [7fab12c] * user/hosts/posix.rst (modified) freebsd: Update to reflect the current release 12 requirements ... Wed, 01 Apr 2020 13:14:57 GMT Christian Mauderer [01b1f47] * user/bsps/arm/imx.rst (modified) user/imx: Add i.MX6UL/ULL. Update #3869 Tue, 14 Apr 2020 14:39:14 GMT Sebastian Huber [02bded3] * user/migration/v4_11-to-v5.rst (modified) user: Update migration guide Update #3895. Tue, 14 Apr 2020 00:44:15 GMT Chris Johns [ca66112] * user/start/app.rst (modified) user: Fix start app chmod execute of waf. Sat, 11 Apr 2020 10:28:42 GMT Sebastian Huber [ea4c098] * user/tracing/eventrecording.rst (modified) user: Document event recording Close #3904. Thu, 09 Apr 2020 14:34:13 GMT Cláudio Maia [c8ee17a] * user/tools/tester.rst (modified) user/tools/tester.rst: Removes text references to 'erc32-run' and ... Thu, 09 Apr 2020 14:34:12 GMT Cláudio Maia [8a83c43] * user/tools/tester.rst (modified) user/tools/tester.rst: Removes example using 'sparc-rtems5-run' Thu, 09 Apr 2020 14:34:11 GMT Cláudio Maia [6566e76] * user/tools/tester.rst (modified) user/tools/tester.rst: Clarifies the need of --rtems-tools in rtems- ... Thu, 09 Apr 2020 14:34:10 GMT Cláudio Maia [5640072] * user/tools/tester.rst (modified) user/tools/tester.rst: Removes wrong reference to GDB Thu, 09 Apr 2020 14:34:09 GMT Cláudio Maia [8d914b3] * user/tools/tester.rst (modified) user/tools/tester.rst: Cleans up text Sun, 05 Apr 2020 20:56:38 GMT Gedare Bloom [e94ed6d] * user/rsb/configuration.rst (modified) rsb/configuration: add my copyright Sun, 05 Apr 2020 04:39:13 GMT Gedare Bloom [cbdfde0] * user/rsb/configuration.rst (modified) user/rsb: describe how to create configuration reports Closes #3629. Sun, 05 Apr 2020 20:47:27 GMT Gedare Bloom [c9cb173] * user/rsb/commands.rst (modified) * user/rsb/configuration.rst (modified) rsb: replace asciidoc with rst formatting Sun, 05 Apr 2020 20:38:41 GMT Gedare Bloom [79c37d2] * user/rsb/configuration.rst (modified) user/rsb/configuration: fix typo xy to xz Sun, 05 Apr 2020 20:25:52 GMT Gedare Bloom [7a1bb48] * user/rsb/configuration.rst (modified) rsb/configuration: fix broken link to _configdir Sun, 05 Apr 2020 04:22:40 GMT Gedare Bloom [cae8b6d] * user/index.rst (modified) * user/start/tools.rst (modified) user: update copyright and minor typo Sat, 04 Apr 2020 03:46:22 GMT Utkarsh Rai [b22c1e1] * user/start/tools.rst (modified) Chapter-on-need-for-RTEMS-specific-cross-compiler Removed '-' ... Fri, 03 Apr 2020 18:44:31 GMT Gedare Bloom [44fde6c] * user/index.rst (modified) Update top-level copyrights Thu, 02 Apr 2020 08:49:45 GMT Mritunjay [edfc902] * user/bsps/bsps-m68k.rst (modified) doc: Moving M68K BSP Content to User Manual (#3905) Fixed trailing ... Thu, 02 Apr 2020 18:14:51 GMT Gedare Bloom [d4d3067] * user/start/gsoc.rst (modified) user/start/gsoc: fix unicode error and grammar typo Thu, 02 Apr 2020 15:35:31 GMT Gedare Bloom [3a19619] * user/start/index.rst (modified) start/index: relocate gsoc section Thu, 02 Apr 2020 14:05:00 GMT G S Niteesh Babu [94697e1] * user/index.rst (modified) * user/start/gsoc.rst (added) * user/start/index.rst (modified) start/gsoc: GSoC Getting started instructions. Added instructions ... Thu, 02 Apr 2020 11:06:34 GMT G S Niteesh Babu [7fd137e] * user/start/bsp-build.rst (modified) user/bsp-build: Fix broken cross references. The ... Thu, 02 Apr 2020 03:28:37 GMT Gedare Bloom [7a0834d] * user/start/preparation.rst (modified) start/user: describe version numbers and releases Closes #2562. Thu, 02 Apr 2020 08:18:10 GMT Mritunjay [f682984] * user/rsb/configuration.rst (modified) * user/rsb/cross-canadian-cross.rst (modified) * user/rsb/project-sets.rst (modified) * user/rsb/third-party-packages.rst (modified) user/rsb: Fix typos (#3922) Closes #3922 Fri, 27 Mar 2020 08:02:16 GMT Sebastian Huber [ae84edd] * user/exe/initialization.rst (modified) * user/start/app.rst (modified) * user/tools/boot-image.rst (modified) * user/tools/tester.rst (modified) user: Use consistent Hello World spelling Fri, 27 Mar 2020 08:00:58 GMT Sebastian Huber [03e61e9] * user/start/app.rst (modified) user: Provide a user friendly configuration Fri, 20 Mar 2020 14:22:29 GMT Joel Sherrill [87e49d4] * bsp-howto/coding-doxygen-bsp.rst (modified) * user/bsps/arm/gdbarmsim.rst (deleted) * user/bsps/bsps-arm.rst (modified) * user/installation/developer.rst (modified) gdbarmsim: Remove all references to this deleted BSP family Updates ... Fri, 28 Feb 2020 23:16:26 GMT Joel Sherrill [4dc93a1] * user/hosts/posix.rst (modified) user/hosts/posix.rst: Add CentOS 8 information Mon, 16 Mar 2020 14:42:06 GMT G S Niteesh Babu [979c5b2] * user/bsps/arm/raspberrypi.rst (modified) user/raspberrypi: Fix typo enable-uart should be enable_uart in ... Thu, 12 Mar 2020 07:04:25 GMT Chris Johns [4726207] * user/index.rst (modified) * user/migration/index.rst (added) * user/migration/v4_11-to-v5.rst (added) user: Add a migration chapter This is a start with the hope we ... Thu, 12 Mar 2020 21:19:20 GMT Chris Johns [1b2a7c8] * user/rsb/index.rst (modified) user: Update Quick Start Guide reference. Thu, 12 Mar 2020 05:29:58 GMT Chris Johns [7b53b60] * user/bsps/arm/beagle.rst (modified) * user/bsps/bsps-sparc.rst (modified) user: Add anchors to some BSPs. Thu, 12 Mar 2020 04:13:39 GMT Chris Johns [f672026] * user/index.rst (modified) * user/start/app.rst (modified) * user/start/bootstrap.rst (modified) * user/start/bsp-build.rst (modified) * user/start/bsp-test.rst (modified) * user/start/host.rst (deleted) * user/start/index.rst (modified) * user/start/prefixes.rst (modified) * user/start/preparation.rst (added) * user/start/rsb-packages.rst (added) * user/start/sources.rst (modified) * user/start/tools.rst (modified) user: Update Quick Start Guide - Add support for release source ... Tue, 18 Feb 2020 00:09:00 GMT Chris Johns [2c37918] * images/user/tftp-proxy-1.png (added) * images/user/tftp-proxy-1.puml (added) * user/testing/tftp.rst (modified) * user/tools/boot-image.rst (modified) * user/tools/index.rst (modified) * user/tools/tftp-proxy.rst (added) user/tools: Add RTEMS TFTP Proxy command documentation Sat, 25 Jan 2020 17:14:14 GMT G S Niteesh [5763454] * user/bsps/arm/raspberrypi.rst (modified) doc/raspberrypi: Added instructions for raspberrypi Added ... Mon, 03 Feb 2020 10:05:58 GMT Vijay Kumar Banerjee [d45c51a] * user/testing/coverage.rst (added) * user/testing/index.rst (modified) user/testing: Add coverage analysis instructions Fri, 27 Dec 2019 12:01:46 GMT G S Niteesh [55d69ad] * user/start/bsp-test.rst (modified) * user/tools/tester.rst (modified) Updated docs to use the standalone SIS simulator, instead of GDB ... Wed, 04 Dec 2019 14:53:29 GMT Jeff Kubascik [304c17c] * user/bsps/arm/xen.rst (added) * user/bsps/bsps-arm.rst (modified) bsp/xen: Add information on Xen/ARM BSP Add a README for the new ... Thu, 19 Dec 2019 08:04:23 GMT Sebastian Huber [c9f5e20] * user/bsps/arm/xilinx-zynqmp.rst (added) * user/bsps/bsps-arm.rst (modified) user: Mention xilinx-zynqmp BSP Close #3682. Thu, 12 Dec 2019 22:20:37 GMT Joel Sherrill [9316722] * user/hosts/posix.rst (modified) user/hosts/posix.rst: Update Ubuntu instructions. Note that the ... Mon, 09 Dec 2019 20:59:49 GMT Joel Sherrill [01be513] * user/hardware/tiers.rst (modified) user/hardware/tiers.rst: Merge info from Wiki. Tiers had a write up ... Fri, 29 Nov 2019 07:42:46 GMT Pragnesh Patel [f0864b3] * user/bsps/bsps-riscv.rst (modified) user: Add frdme310arty BSP varient Signed-off-by: Pragnesh Patel ... Thu, 07 Nov 2019 08:49:06 GMT Sebastian Huber [d5acae4] * user/hosts/macos.rst (modified) user: Add hints for macOS Catalina Use macOS throughout. Order ... Mon, 30 Sep 2019 10:18:57 GMT Sebastian Huber [13ed966] * images/user/patch-review.png (added) * images/user/patch-review.puml (added) * user/support/contrib.rst (modified) user: Document patch review process Mon, 30 Sep 2019 08:58:00 GMT Sebastian Huber [6ca5dfc] * user/support/contrib.rst (modified) user: Update contributing section Mon, 30 Sep 2019 08:20:11 GMT Sebastian Huber [1d3114d] * eng/management.rst (modified) * eng/why-contribute.rst (deleted) * user/support/contrib.rst (modified) Move contributing content from eng to user Sun, 13 Oct 2019 08:51:25 GMT Chris Johns [bb47f89] * user/rsb/configuration.rst (modified) * user/rsb/cross-canadian-cross.rst (modified) * user/rsb/index.rst (modified) * user/rsb/project-sets.rst (modified) * user/rsb/third-party-packages.rst (modified) * user/start/prefixes.rst (modified) user/rsb: Update 3rd party package build and add packaging details. Tue, 24 Sep 2019 18:44:32 GMT Vijay Kumar Banerjee [6185f6e] * user/bsps/arm/beagle.rst (modified) bsps/beagle: update i2c section Thu, 05 Sep 2019 07:58:57 GMT Chris Johns [4007591] * user/hosts/posix.rst (modified) FreeBSDL: Add command to improve waf's performance with Python3. Thu, 22 Aug 2019 01:41:43 GMT Kinsey Moore [b836c43] * user/tools/tester.rst (modified) Update docs for log mode change and JSON reporting The option ... Mon, 12 Aug 2019 06:55:17 GMT Vaibhav Gupta [3605600] * user/rsb/project-sets.rst (modified) Add steps to test Newlib patch. Update the checksum to be used for ... Thu, 15 Aug 2019 21:03:46 GMT Joel Sherrill [4cc36ed] * user/hosts/posix.rst (modified) user/hosts/posix.rst: Improve Ubuntu python 2 devel package instructions Mon, 03 Jun 2019 18:56:50 GMT Joel Sherrill [13baaca] * user/hosts/posix.rst (modified) hosts/posix.rst: Fix typo of sudu to sudo Closes #3754. Mon, 03 Jun 2019 16:23:01 GMT Joel Sherrill [16ba6ca] * user/hosts/windows.rst (modified) hosts/windows.rst: Add warning for spaces in PATH Mon, 20 May 2019 18:12:33 GMT Joel Sherrill [bacecbb] * user/rsb/deployment.rst (modified) user/rsb/deployment.rst: Fix typo. Tue, 13 Aug 2019 08:15:15 GMT Vijay Kumar Banerjee [8fd1d45] * user/index.rst (modified) user/index: Add myself to the list of copyrights Mon, 12 Aug 2019 13:43:39 GMT Sebastian Huber [29e0ac3] * user/support/bugs.rst (modified) user: Update bug reporting section Include information from ... Fri, 09 Aug 2019 08:06:22 GMT Vijay Kumar Banerjee [926a622] * user/bsps/arm/beagle.rst (modified) * user/exe/device-tree.rst (modified) user/exe: Add link reference in device-tree Wed, 07 Aug 2019 22:11:16 GMT Vijay Kumar Banerjee [605ba77] * user/bsps/arm/beagle.rst (modified) user/bsps: Fix typo in beagle Tue, 06 Aug 2019 09:58:05 GMT Sebastian Huber [e21c413] * user/index.rst (modified) * user/support/bugs.rst (modified) * user/support/contrib.rst (modified) * user/support/support-commercial.rst (modified) user: Improve bug report section The new content is based on the ... Sat, 03 Aug 2019 20:30:57 GMT Vijay Kumar Banerjee [7c89bd6] * user/bsps/arm/beagle.rst (modified) * user/exe/device-tree.rst (added) * user/exe/index.rst (modified) user/exe: Add Device Tree section Mon, 05 Aug 2019 13:06:01 GMT Sebastian Huber [f170947] * user/index.rst (modified) * user/overview/index.rst (modified) * user/support/bugs.rst (added) * user/support/contrib.rst (added) * user/support/index.rst (added) * user/support/support-commercial.rst (added) * user/support/support-project.rst (added) user: Move support sections to top level This is a preparation step ... Mon, 22 Jul 2019 04:12:32 GMT Vijay Kumar Banerjee [8b203e2] * user/bsps/arm/beagle.rst (modified) user/bsps : Fix formatting and typo in arm/beagle Thu, 18 Jul 2019 14:24:30 GMT Vijay Kumar Banerjee [d8d5876] * user/bsps/arm/beagle.rst (modified) user/bsps : Add documentation for Beagle
