# # ChangeLog for user in rtems-docs # # Generated by Trac 1.2.1.dev0 # 05/19/24 18:20:13 Wed, 21 Dec 2016 10:29:35 GMT Sebastian Huber [45dc7c7] * bsp-howto/conf.py (modified) * c-user/conf.py (modified) * cpu-supplement/conf.py (modified) * develenv/conf.py (modified) * eclipse/conf.py (modified) * filesystem/conf.py (modified) * networking/conf.py (modified) * posix-users/conf.py (modified) * rsb/conf.py (modified) * shell/conf.py (modified) * user/conf.py (modified) Update version/revision to 4.11.99 Wed, 09 Nov 2016 01:20:46 GMT Chris Johns [aa1c010] * user/additional/index.rst (modified) * user/apps/index.rst (added) * user/bsp/index.rst (modified) * user/config/index.rst (modified) * user/ecosys/index.rst (modified) * user/glossary/index.rst (modified) * user/hardware/architectures.rst (modified) * user/hardware/bsps.rst (modified) * user/hardware/index.rst (modified) * user/hardware/targets.rst (modified) * user/hardware/tiers.rst (modified) * user/hosts/index.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/index.rst (modified) * user/installation/developer.rst (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (modified) * user/installation/prefixes-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/overview/index.rst (modified) * user/start/index.rst (modified) * user/support/index.rst (modified) * user/test/index.rst (modified) * user/tools/build.rst (modified) * user/tools/index.rst (modified) user: Fix header levels. Wed, 02 Nov 2016 04:19:42 GMT Chris Johns [005f0e8] * user/index.rst (modified) Fix spelling. Sun, 30 Oct 2016 21:48:21 GMT Chris Johns [dd43d0b] * common/waf.py (modified) * user/wscript (modified) * wscript (modified) waf: Add an install command. Sun, 30 Oct 2016 01:33:23 GMT Chris Johns [9dd79f2] * user/wscript (modified) waf: Formatting. Fri, 28 Oct 2016 19:30:24 GMT Chris Johns [706a1e2] * user/installation/index.rst (modified) * user/installation/kernel.rst (modified) user: Add comments about warnings we cannot remove. Fri, 28 Oct 2016 18:32:30 GMT Chris Johns [9fd14dd] * user/installation/releases.rst (modified) user: Add comment to move to packages. Thu, 27 Oct 2016 23:11:44 GMT Joel Sherrill [8e59c99] * user/ecosys/index.rst (modified) ecosys/index.rst: Fix complixity spelling Wed, 06 Jul 2016 05:03:38 GMT Chris Johns [ba30a48] * user/hardware/tiers.rst (modified) Fix the table and section numbering in the User,Hardware,Tiers section. Wed, 06 Jul 2016 04:59:00 GMT Chris Johns [8da3a62] * user/architecture/index.rst (deleted) * user/conf.py (modified) * user/hardware/architectures.rst (added) * user/hardware/bsps.rst (added) * user/hardware/hw-layers.txt (added) * user/hardware/index.rst (added) * user/hardware/targets.rst (added) * user/hardware/tiers.rst (added) * user/index.rst (modified) Add a Hardware section. Wed, 06 Jul 2016 04:57:47 GMT Chris Johns [b73ba92] * user/glossary/index.rst (modified) Update the glossary. Mon, 04 Jul 2016 02:45:57 GMT Chris Johns [ae7a139] * user/conf.py (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (added) Add the RTEMS Kernel section back in. Mon, 04 Jul 2016 02:30:09 GMT Chris Johns [86518bd] * user/conf.py (modified) * user/ecosys/index.rst (added) * user/glossary/index.rst (modified) * user/hosts/index.rst (added) * user/hosts/macos.rst (added) * user/hosts/os.rst (added) * user/hosts/posix.rst (added) * user/hosts/windows.rst (moved) * user/index.rst (modified) * user/installation/developer.rst (moved) * user/installation/index.rst (added) * user/installation/prefixes-sandboxing.rst (moved) * user/installation/releases.rst (moved) * user/overview/index.rst (modified) * user/start/development.rst (deleted) * user/start/index.rst (modified) * user/start/quick.rst (added) * user/support/index.rst (modified) * user/tools/index.rst (modified) Reorganisse the User Manual to make it easier to navigate. Fri, 20 May 2016 02:47:09 GMT Chris Johns [489740f] * book/index_book.rst (modified) * bsp_howto/ada95_interrupt.rst (modified) * bsp_howto/analog.rst (modified) * bsp_howto/ata.rst (modified) * bsp_howto/bsp_howto_old_reference_only.rst (modified) * bsp_howto/clock.rst (modified) * bsp_howto/command.rst (modified) * bsp_howto/console.rst (modified) * bsp_howto/discrete.rst (modified) * bsp_howto/frame_buffer.rst (modified) * bsp_howto/ide_controller.rst (modified) * bsp_howto/index.rst (modified) * bsp_howto/initilization_code.rst (modified) * bsp_howto/linker_script.rst (modified) * bsp_howto/makefiles.rst (modified) * bsp_howto/miscellanous_support.rst (modified) * bsp_howto/networking.rst (modified) * bsp_howto/non_volatile_memory.rst (modified) * bsp_howto/preface.rst (modified) * bsp_howto/real_time_clock.rst (modified) * bsp_howto/shared_memory_support.rst (modified) * bsp_howto/target_dependant_files.rst (modified) * bsp_howto/timer.rst (modified) * c_user/barrier_manager.rst (modified) * c_user/board_support_packages.rst (modified) * c_user/c_user_old_reference_only.rst (modified) * c_user/chains.rst (modified) * c_user/clock_manager.rst (modified) * c_user/configuring_a_system.rst (modified) * c_user/constant_bandwidth_server.rst (modified) * c_user/cpu_usage_statistics.rst (modified) * c_user/directive_status_codes.rst (modified) * c_user/dual_ports_memory_manager.rst (modified) * c_user/event_manager.rst (modified) * c_user/example_application.rst (modified) * c_user/fatal_error.rst (modified) * c_user/glossary.rst (modified) * c_user/index.rst (modified) * c_user/initialization.rst (modified) * c_user/interrupt_manager.rst (modified) * c_user/io_manager.rst (modified) * c_user/key_concepts.rst (modified) * c_user/linker_sets.rst (modified) * c_user/message_manager.rst (modified) * c_user/multiprocessing.rst (modified) * c_user/object_services.rst (modified) * c_user/overview.rst (modified) * c_user/partition_manager.rst (modified) * c_user/pci_library.rst (modified) * c_user/preface.rst (modified) * c_user/rate_monotonic_manager.rst (modified) * c_user/red_black_trees.rst (modified) * c_user/region_manager.rst (modified) * c_user/rtems_data_types.rst (modified) * c_user/scheduling_concepts.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/signal_manager.rst (modified) * c_user/stack_bounds_checker.rst (modified) * c_user/symmetric_multiprocessing_services.rst (modified) * c_user/task_manager.rst (modified) * c_user/timer_manager.rst (modified) * c_user/timespec_helpers.rst (modified) * c_user/user_extensions.rst (modified) * cpu_supplement/altera_nios_ii.rst (modified) * cpu_supplement/arm.rst (modified) * cpu_supplement/atmel_avr.rst (modified) * cpu_supplement/blackfin.rst (modified) * cpu_supplement/command.rst (modified) * cpu_supplement/cpu_supplement_old_reference_only.rst (modified) * cpu_supplement/ephiphany.rst (modified) * cpu_supplement/index.rst (modified) * cpu_supplement/intel_amd_x86.rst (modified) * cpu_supplement/lattice_micro32.rst (modified) * cpu_supplement/m68xxx_and_coldfire.rst (modified) * cpu_supplement/mips.rst (modified) * cpu_supplement/openrisc_1000.rst (modified) * cpu_supplement/port.rst (modified) * cpu_supplement/powerpc.rst (modified) * cpu_supplement/preface.rst (modified) * cpu_supplement/renesas_m32c.rst (modified) * cpu_supplement/sparc.rst (modified) * cpu_supplement/sparc64.rst (modified) * cpu_supplement/superh.rst (modified) * cpu_supplement/xilinx_microblaze.rst (modified) * develenv/command.rst (modified) * develenv/develenv_old_reference_only.rst (modified) * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/introduction.rst (modified) * develenv/sample.rst (modified) * develenv/utilities.rst (modified) * filesystem/call_development.rst (modified) * filesystem/command_and_variable.rst (modified) * filesystem/filesystem_old_reference_only.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/index.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * filesystem/trivial_ftp.rst (modified) * networking/command.rst (modified) * networking/dec_21140.rst (modified) * networking/index.rst (modified) * networking/network_servers.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/networking_old_reference_only.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/command.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/index.rst (modified) * porting/interrupts.rst (modified) * porting/miscellanous.rst (modified) * porting/porting_old_reference_only.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix1003_1/clocks_and_timers.rst (modified) * posix1003_1/command.rst (modified) * posix1003_1/compliance_summary.rst (modified) * posix1003_1/data_interchange_format.rst (modified) * posix1003_1/device_and_class_specific.rst (modified) * posix1003_1/execution_scheduling.rst (modified) * posix1003_1/files_and_directories.rst (modified) * posix1003_1/general.rst (modified) * posix1003_1/index.rst (modified) * posix1003_1/input_and_output.rst (modified) * posix1003_1/language_specific_services.rst (modified) * posix1003_1/memory_managment.rst (modified) * posix1003_1/message_passing.rst (modified) * posix1003_1/posix1003_1.rst (modified) * posix1003_1/preface.rst (modified) * posix1003_1/process_environment.rst (modified) * posix1003_1/process_primitives.rst (modified) * posix1003_1/synchronization.rst (modified) * posix1003_1/system_database.rst (modified) * posix1003_1/terminology.rst (modified) * posix1003_1/thread_cancellation.rst (modified) * posix1003_1/thread_managment.rst (modified) * posix1003_1/thread_specific_data.rst (modified) * posix_users/clock.rst (modified) * posix_users/command.rst (modified) * posix_users/condition_variable.rst (modified) * posix_users/device_and_class_specific.rst (modified) * posix_users/files_and_directory.rst (modified) * posix_users/index.rst (modified) * posix_users/input_and_output.rst (modified) * posix_users/key.rst (modified) * posix_users/language_specific_services.rst (modified) * posix_users/memory_managment.rst (modified) * posix_users/message_passing.rst (modified) * posix_users/mutex.rst (modified) * posix_users/posix_users_old_reference_only.rst (modified) * posix_users/preface.rst (modified) * posix_users/process_creation_and_execution.rst (modified) * posix_users/process_environment.rst (modified) * posix_users/scheduler.rst (modified) * posix_users/semaphore.rst (modified) * posix_users/services_provided_by_c.rst (modified) * posix_users/services_provided_by_math.rst (modified) * posix_users/signal.rst (modified) * posix_users/status_of_implementation.rst (modified) * posix_users/system_database.rst (modified) * posix_users/thread.rst (modified) * posix_users/thread_cancellation.rst (modified) * posix_users/timer.rst (modified) * rtemsconfig/index.rst (modified) * rtemsconfig/option.rst (modified) * rtemsconfig/rtemsconfig.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * shell/shell_old_reference_only.rst (modified) * user/additional/index.rst (modified) * user/architecture/index.rst (modified) * user/bsp/index.rst (modified) * user/config/build.rst (modified) * user/config/index.rst (modified) * user/config/runtime.rst (modified) * user/glossary/index.rst (modified) * user/index.rst (modified) * user/overview/index.rst (modified) * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/development.rst (modified) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/releases.rst (modified) * user/start/transition.rst (modified) * user/start/windows.rst (modified) * user/support/index.rst (modified) * user/test/create.rst (modified) * user/test/index.rst (modified) * user/test/running.rst (modified) * user/tools/build.rst (modified) * user/tools/index.rst (modified) * user/tools/simulation.rst (modified) * user/waf/build.rst (modified) * user/waf/config.rst (modified) * user/waf/index.rst (modified) * user/waf/install.rst (modified) Set SPDX License Identifier in each source file. Wed, 18 May 2016 17:47:42 GMT Amar Takhar [170418a] * c_user/overview.rst (modified) * c_user/scheduling_concepts.rst (modified) * c_user/semaphore_manager.rst (modified) * common/waf.py (modified) * images/c_user/rtemsarc.png (moved) * images/c_user/rtemspie.png (moved) * images/c_user/semaphore_attributes.png (moved) * images/c_user/states.png (moved) * images/msys2-minw64-start-menu.png (moved) * images/networking/PCIreg.jpg (moved) * images/networking/networkflow.jpg (moved) * images/networking/recvbd.jpg (moved) * networking/dec_21140.rst (modified) * networking/network_task_structure.rst (modified) * user/start/depend.rst (modified) Move images to a common directory. Fri, 01 Apr 2016 01:20:13 GMT Chris Johns [ea0777e] * user/overview/index.rst (modified) * user/start/basics.rst (modified) * user/start/index.rst (modified) Review changes from Chris Mayfield. Thu, 24 Mar 2016 02:28:36 GMT Chris Johns [aae09e2] * user/start/depend.rst (modified) * user/support/index.rst (modified) Corrections from Worth Burruss. Many thanks. Wed, 23 Mar 2016 22:33:29 GMT Chris Johns [a34c157] * user/glossary/index.rst (modified) * user/overview/index.rst (modified) * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/development.rst (modified) * user/start/index.rst (modified) * user/start/releases.rst (modified) * user/start/windows.rst (modified) * user/support/index.rst (modified) Corrections from Worth Burruss. Many thanks. Wed, 23 Mar 2016 20:35:44 GMT Chris Johns [6958370] * user/start/depend.rst (modified) Fix bad formatting that somehow went into the doco. Wed, 23 Mar 2016 02:57:56 GMT Chris Johns [dc234b5] * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/releases.rst (modified) Corrections from a review. Wed, 23 Mar 2016 02:18:56 GMT Chris Johns [c075916] * user/start/depend.rst (modified) * user/start/windows.rst (modified) Corrections and improvements from Worth Burruss (thanks so much). Tue, 22 Mar 2016 02:42:02 GMT Chris Johns [2151927] * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/releases.rst (modified) Corrections. Tue, 22 Mar 2016 01:54:39 GMT Chris Johns [27bcdfb] * user/conf.py (modified) * user/start/basics.rst (added) * user/start/depend.rst (modified) * user/start/development.rst (modified) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/releases.rst (modified) * user/start/windows.rst (modified) Add a basics section to Getting Started. Rearrange the content. Mon, 21 Mar 2016 01:19:59 GMT Chris Johns [024e040] * user/start/releases.rst (modified) Start adding Getting Started guide's Released Version. Sun, 20 Mar 2016 23:27:52 GMT Chris Johns [5353914] * common/rtemsstyle.sty (modified) * user/start/development.rst (modified) * user/start/windows.rst (modified) Updates from user reviews. Thu, 10 Mar 2016 02:25:27 GMT Chris Johns [4e3cf2b] * user/conf.py (modified) * user/start/development.rst (added) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/releases.rst (added) * user/start/windows.rst (modified) Split installation into separate files. Wed, 09 Mar 2016 04:37:31 GMT Chris Johns [c05e43b] * user/additional/index.rst (modified) * user/conf.py (modified) * user/config/build.rst (modified) * user/config/runtime.rst (modified) * user/glossary/index.rst (modified) * user/index.rst (modified) * user/overview/index.rst (modified) * user/start/depend.rst (modified) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/msys2-minw64-start-menu.png (added) * user/start/transition.rst (modified) * user/start/windows.rst (added) * user/test/create.rst (modified) * user/test/running.rst (modified) * user/tools/build.rst (modified) * user/tools/simulation.rst (modified) User manual, devel install and windows install. Wed, 20 Jan 2016 04:00:32 GMT Amar Takhar [ed3794e] * bsp_howto/wscript (modified) * c_user/wscript (modified) * common/waf.py (modified) * cpu_supplement/wscript (modified) * develenv/wscript (modified) * filesystem/wscript (modified) * networking/wscript (modified) * posix1003_1/wscript (modified) * posix_users/wscript (modified) * shell/wscript (modified) * user/wscript (modified) Add 'waf linkcheck' to check external references. Tue, 19 Jan 2016 05:27:45 GMT Amar Takhar [9b5801a] * book/conf.py (modified) * bsp_howto/conf.py (modified) * bsp_howto/wscript (modified) * c_user/conf.py (added) * c_user/wscript (modified) * common/conf.py (modified) * common/rtemsstyle.sty (moved) * common/waf.py (modified) * cpu_supplement/conf.py (modified) * cpu_supplement/wscript (modified) * develenv/conf.py (modified) * develenv/wscript (modified) * filesystem/conf.py (modified) * filesystem/wscript (modified) * networking/conf.py (modified) * networking/wscript (modified) * porting/conf.py (modified) * porting/wscript (modified) * posix1003_1/conf.py (modified) * posix1003_1/wscript (modified) * posix_users/conf.py (modified) * posix_users/wscript (modified) * rtemsconfig/conf.py (modified) * shell/conf.py (modified) * shell/wscript (modified) * user/conf.py (modified) * user/wscript (modified) Add PDF generation support use with --pdf Mon, 18 Jan 2016 22:53:44 GMT Amar Takhar [f916fca] * book/wscript (modified) * bsp_howto/wscript (modified) * c_user/wscript (modified) * common/spell/dict/rtems (added) * common/spell/en_GB-ise-w_accents-only.rws (added) * common/spell/en_GB-ise-w_accents.multi (added) * common/waf.py (modified) * cpu_supplement/wscript (modified) * develenv/wscript (modified) * filesystem/wscript (modified) * networking/wscript (modified) * porting/wscript (modified) * posix1003_1/wscript (modified) * posix_users/wscript (modified) * rtemsconfig/wscript (modified) * shell/wscript (modified) * user/wscript (modified) Add support for spellchecking with a custom dictionary. To use: ... Mon, 18 Jan 2016 05:05:50 GMT Amar Takhar [3a71759] * ada_user/conf.py (added) * ada_user/wscript (modified) * book/conf.py (added) * book/wscript (modified) * bsp_howto/conf.py (added) * bsp_howto/wscript (modified) * c_user/wscript (modified) * common/__init__.py (added) * common/conf.py (modified) * common/waf.py (modified) * cpu_supplement/conf.py (added) * cpu_supplement/wscript (modified) * develenv/conf.py (added) * develenv/wscript (modified) * filesystem/conf.py (added) * filesystem/wscript (modified) * networking/conf.py (added) * networking/wscript (modified) * porting/conf.py (added) * porting/wscript (modified) * posix1003_1/conf.py (added) * posix1003_1/wscript (modified) * posix_users/conf.py (added) * posix_users/wscript (modified) * rtemsconfig/conf.py (added) * rtemsconfig/wscript (modified) * shell/wscript (modified) * user/conf.py (added) * user/wscript (modified) Rework how conf.py is handled. Needed to switch due to increasing ... Sat, 16 Jan 2016 04:41:06 GMT Amar Takhar [5daabd2] * .gitignore (added) * LICENSE (added) * ada_user/ada_user.rst (added) * ada_user/index.rst (added) * ada_user/wscript (added) * book/index_book.rst (added) * book/wscript (added) * bsp_howto/bsp_howto.rst (added) * bsp_howto/index.rst (added) * bsp_howto/wscript (added) * c_user/c_user.rst (added) * c_user/index.rst (added) * c_user/wscript (added) * common/_static/favicon.ico (added) * common/_static/logo.png (added) * common/_static/my-styles.css (added) * common/_static/style.css (added) * common/_templates/layout.html (added) * common/conf.py (added) * common/rtems.sty (added) * common/rtemsdomain.py (added) * common/rtemsext.py (added) * common/rtemsref.py (added) * common/sphinx_rtd_theme/__init__.py (added) * common/sphinx_rtd_theme/breadcrumbs.html (added) * common/sphinx_rtd_theme/footer.html (added) * common/sphinx_rtd_theme/layout.html (added) * common/sphinx_rtd_theme/layout_old.html (added) * common/sphinx_rtd_theme/search.html (added) * common/sphinx_rtd_theme/searchbox.html (added) * common/sphinx_rtd_theme/static/css/badge_only.css (added) * common/sphinx_rtd_theme/static/css/badge_only.css.map (added) * common/sphinx_rtd_theme/static/css/theme.css (added) * common/sphinx_rtd_theme/static/css/theme.css.map (added) * common/sphinx_rtd_theme/static/fonts/FontAwesome.otf (added) * common/sphinx_rtd_theme/static/fonts/Inconsolata-Bold.ttf (added) * common/sphinx_rtd_theme/static/fonts/Inconsolata-Regular.ttf (added) * common/sphinx_rtd_theme/static/fonts/Lato-Bold.ttf (added) * common/sphinx_rtd_theme/static/fonts/Lato-Regular.ttf (added) * common/sphinx_rtd_theme/static/fonts/RobotoSlab-Bold.ttf (added) * common/sphinx_rtd_theme/static/fonts/RobotoSlab-Regular.ttf (added) * common/sphinx_rtd_theme/static/fonts/fontawesome-webfont.eot (added) * common/sphinx_rtd_theme/static/fonts/fontawesome-webfont.svg (added) * common/sphinx_rtd_theme/static/fonts/fontawesome-webfont.ttf (added) * common/sphinx_rtd_theme/static/fonts/fontawesome-webfont.woff (added) * common/sphinx_rtd_theme/static/js/modernizr.min.js (added) * common/sphinx_rtd_theme/static/js/theme.js (added) * common/sphinx_rtd_theme/theme.conf (added) * common/sphinx_rtd_theme/versions.html (added) * common/waf.py (added) * cpu_supplement/cpu_supplement.rst (added) * cpu_supplement/index.rst (added) * cpu_supplement/wscript (added) * develenv/develenv.rst (added) * develenv/index.rst (added) * develenv/wscript (added) * filesystem/filesystem.rst (added) * filesystem/index.rst (added) * filesystem/wscript (added) * networking/index.rst (added) * networking/networking.rst (added) * networking/wscript (added) * new_chapters/index.rst (added) * new_chapters/new_chapters.rst (added) * new_chapters/wscript (added) * porting/index.rst (added) * porting/porting.rst (added) * porting/wscript (added) * posix1003_1/index.rst (added) * posix1003_1/posix1003_1.rst (added) * posix1003_1/wscript (added) * posix_users/index.rst (added) * posix_users/posix_users.rst (added) * posix_users/wscript (added) * relnotes/index.rst (added) * relnotes/relnotes.rst (added) * relnotes/wscript (added) * rtemsconfig/index.rst (added) * rtemsconfig/option.rst (added) * rtemsconfig/rtemsconfig.rst (added) * rtemsconfig/wscript (added) * shell/index.rst (added) * shell/shell.rst (added) * shell/wscript (added) * user/additional/index.rst (added) * user/architecture/index.rst (added) * user/bsp/index.rst (added) * user/config/build.rst (added) * user/config/index.rst (added) * user/config/runtime.rst (added) * user/glossary/index.rst (added) * user/index.rst (added) * user/overview/index.rst (added) * user/start/depend.rst (added) * user/start/index.rst (added) * user/start/installation.rst (added) * user/start/transition.rst (added) * user/support/index.rst (added) * user/test/create.rst (added) * user/test/index.rst (added) * user/test/running.rst (added) * user/tools/build.rst (added) * user/tools/index.rst (added) * user/tools/simulation.rst (added) * user/waf/build.rst (added) * user/waf/config.rst (added) * user/waf/index.rst (added) * user/waf/install.rst (added) * user/wscript (added) Initial reST documentation using Sphinx.
