# # ChangeLog for porting/porting_old_reference_only.rst in rtems-docs # # Generated by Trac 1.2.1.dev0 # 04/23/24 06:02:39 Fri, 20 May 2016 02:47:09 GMT Chris Johns [489740f] * book/index_book.rst (modified) * bsp_howto/ada95_interrupt.rst (modified) * bsp_howto/analog.rst (modified) * bsp_howto/ata.rst (modified) * bsp_howto/bsp_howto_old_reference_only.rst (modified) * bsp_howto/clock.rst (modified) * bsp_howto/command.rst (modified) * bsp_howto/console.rst (modified) * bsp_howto/discrete.rst (modified) * bsp_howto/frame_buffer.rst (modified) * bsp_howto/ide_controller.rst (modified) * bsp_howto/index.rst (modified) * bsp_howto/initilization_code.rst (modified) * bsp_howto/linker_script.rst (modified) * bsp_howto/makefiles.rst (modified) * bsp_howto/miscellanous_support.rst (modified) * bsp_howto/networking.rst (modified) * bsp_howto/non_volatile_memory.rst (modified) * bsp_howto/preface.rst (modified) * bsp_howto/real_time_clock.rst (modified) * bsp_howto/shared_memory_support.rst (modified) * bsp_howto/target_dependant_files.rst (modified) * bsp_howto/timer.rst (modified) * c_user/barrier_manager.rst (modified) * c_user/board_support_packages.rst (modified) * c_user/c_user_old_reference_only.rst (modified) * c_user/chains.rst (modified) * c_user/clock_manager.rst (modified) * c_user/configuring_a_system.rst (modified) * c_user/constant_bandwidth_server.rst (modified) * c_user/cpu_usage_statistics.rst (modified) * c_user/directive_status_codes.rst (modified) * c_user/dual_ports_memory_manager.rst (modified) * c_user/event_manager.rst (modified) * c_user/example_application.rst (modified) * c_user/fatal_error.rst (modified) * c_user/glossary.rst (modified) * c_user/index.rst (modified) * c_user/initialization.rst (modified) * c_user/interrupt_manager.rst (modified) * c_user/io_manager.rst (modified) * c_user/key_concepts.rst (modified) * c_user/linker_sets.rst (modified) * c_user/message_manager.rst (modified) * c_user/multiprocessing.rst (modified) * c_user/object_services.rst (modified) * c_user/overview.rst (modified) * c_user/partition_manager.rst (modified) * c_user/pci_library.rst (modified) * c_user/preface.rst (modified) * c_user/rate_monotonic_manager.rst (modified) * c_user/red_black_trees.rst (modified) * c_user/region_manager.rst (modified) * c_user/rtems_data_types.rst (modified) * c_user/scheduling_concepts.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/signal_manager.rst (modified) * c_user/stack_bounds_checker.rst (modified) * c_user/symmetric_multiprocessing_services.rst (modified) * c_user/task_manager.rst (modified) * c_user/timer_manager.rst (modified) * c_user/timespec_helpers.rst (modified) * c_user/user_extensions.rst (modified) * cpu_supplement/altera_nios_ii.rst (modified) * cpu_supplement/arm.rst (modified) * cpu_supplement/atmel_avr.rst (modified) * cpu_supplement/blackfin.rst (modified) * cpu_supplement/command.rst (modified) * cpu_supplement/cpu_supplement_old_reference_only.rst (modified) * cpu_supplement/ephiphany.rst (modified) * cpu_supplement/index.rst (modified) * cpu_supplement/intel_amd_x86.rst (modified) * cpu_supplement/lattice_micro32.rst (modified) * cpu_supplement/m68xxx_and_coldfire.rst (modified) * cpu_supplement/mips.rst (modified) * cpu_supplement/openrisc_1000.rst (modified) * cpu_supplement/port.rst (modified) * cpu_supplement/powerpc.rst (modified) * cpu_supplement/preface.rst (modified) * cpu_supplement/renesas_m32c.rst (modified) * cpu_supplement/sparc.rst (modified) * cpu_supplement/sparc64.rst (modified) * cpu_supplement/superh.rst (modified) * cpu_supplement/xilinx_microblaze.rst (modified) * develenv/command.rst (modified) * develenv/develenv_old_reference_only.rst (modified) * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/introduction.rst (modified) * develenv/sample.rst (modified) * develenv/utilities.rst (modified) * filesystem/call_development.rst (modified) * filesystem/command_and_variable.rst (modified) * filesystem/filesystem_old_reference_only.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/index.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * filesystem/trivial_ftp.rst (modified) * networking/command.rst (modified) * networking/dec_21140.rst (modified) * networking/index.rst (modified) * networking/network_servers.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/networking_old_reference_only.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/command.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/index.rst (modified) * porting/interrupts.rst (modified) * porting/miscellanous.rst (modified) * porting/porting_old_reference_only.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix1003_1/clocks_and_timers.rst (modified) * posix1003_1/command.rst (modified) * posix1003_1/compliance_summary.rst (modified) * posix1003_1/data_interchange_format.rst (modified) * posix1003_1/device_and_class_specific.rst (modified) * posix1003_1/execution_scheduling.rst (modified) * posix1003_1/files_and_directories.rst (modified) * posix1003_1/general.rst (modified) * posix1003_1/index.rst (modified) * posix1003_1/input_and_output.rst (modified) * posix1003_1/language_specific_services.rst (modified) * posix1003_1/memory_managment.rst (modified) * posix1003_1/message_passing.rst (modified) * posix1003_1/posix1003_1.rst (modified) * posix1003_1/preface.rst (modified) * posix1003_1/process_environment.rst (modified) * posix1003_1/process_primitives.rst (modified) * posix1003_1/synchronization.rst (modified) * posix1003_1/system_database.rst (modified) * posix1003_1/terminology.rst (modified) * posix1003_1/thread_cancellation.rst (modified) * posix1003_1/thread_managment.rst (modified) * posix1003_1/thread_specific_data.rst (modified) * posix_users/clock.rst (modified) * posix_users/command.rst (modified) * posix_users/condition_variable.rst (modified) * posix_users/device_and_class_specific.rst (modified) * posix_users/files_and_directory.rst (modified) * posix_users/index.rst (modified) * posix_users/input_and_output.rst (modified) * posix_users/key.rst (modified) * posix_users/language_specific_services.rst (modified) * posix_users/memory_managment.rst (modified) * posix_users/message_passing.rst (modified) * posix_users/mutex.rst (modified) * posix_users/posix_users_old_reference_only.rst (modified) * posix_users/preface.rst (modified) * posix_users/process_creation_and_execution.rst (modified) * posix_users/process_environment.rst (modified) * posix_users/scheduler.rst (modified) * posix_users/semaphore.rst (modified) * posix_users/services_provided_by_c.rst (modified) * posix_users/services_provided_by_math.rst (modified) * posix_users/signal.rst (modified) * posix_users/status_of_implementation.rst (modified) * posix_users/system_database.rst (modified) * posix_users/thread.rst (modified) * posix_users/thread_cancellation.rst (modified) * posix_users/timer.rst (modified) * rtemsconfig/index.rst (modified) * rtemsconfig/option.rst (modified) * rtemsconfig/rtemsconfig.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * shell/shell_old_reference_only.rst (modified) * user/additional/index.rst (modified) * user/architecture/index.rst (modified) * user/bsp/index.rst (modified) * user/config/build.rst (modified) * user/config/index.rst (modified) * user/config/runtime.rst (modified) * user/glossary/index.rst (modified) * user/index.rst (modified) * user/overview/index.rst (modified) * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/development.rst (modified) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/releases.rst (modified) * user/start/transition.rst (modified) * user/start/windows.rst (modified) * user/support/index.rst (modified) * user/test/create.rst (modified) * user/test/index.rst (modified) * user/test/running.rst (modified) * user/tools/build.rst (modified) * user/tools/index.rst (modified) * user/tools/simulation.rst (modified) * user/waf/build.rst (modified) * user/waf/config.rst (modified) * user/waf/index.rst (modified) * user/waf/install.rst (modified) Set SPDX License Identifier in each source file. Sun, 17 Jan 2016 00:09:22 GMT Amar Takhar [0aa6200] * porting/porting_old_reference_only.rst (moved) Rename old document for reference only.
