# # ChangeLog for eng in rtems-docs # # Generated by Trac 1.2.1.dev0 # 04/20/24 03:38:38 Tue, 19 Feb 2019 23:07:04 GMT Chris Johns [fb72a00] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/unicode.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Add unicode support for commonly used characters like copyright. - ... Thu, 14 Feb 2019 09:04:28 GMT Chris Johns [f7384cc] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/_templates/layout.html (modified) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * rtemsconfig/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Use pathto() on the genindex URL to make it relative. Tue, 12 Feb 2019 23:18:43 GMT Chris Johns [5d8b0dd] * bsp-howto/wscript (modified) * c-user/wscript (modified) * cpu-supplement/wscript (modified) * develenv/wscript (modified) * eclipse/wscript (modified) * eng/wscript (modified) * filesystem/wscript (modified) * images/wscript (modified) * networking/wscript (modified) * porting/wscript (modified) * posix-compliance/wscript (modified) * posix-users/wscript (modified) * rtemsconfig/wscript (modified) * shell/wscript (modified) * user/wscript (modified) * wscript (modified) waf: Remove as many sys path hacks as we can. There are still ... Fri, 08 Feb 2019 08:41:45 GMT Sebastian Huber [6f110cc] * book/conf.py (modified) * book/wscript (modified) * bsp-howto/conf.py (modified) * bsp-howto/wscript (modified) * c-user/conf.py (modified) * c-user/wscript (modified) * cpu-supplement/conf.py (modified) * cpu-supplement/wscript (modified) * develenv/conf.py (modified) * develenv/wscript (modified) * eclipse/conf.py (modified) * eclipse/wscript (modified) * eng/conf.py (modified) * eng/wscript (modified) * filesystem/conf.py (modified) * filesystem/wscript (modified) * images/wscript (modified) * networking/conf.py (modified) * networking/wscript (modified) * porting/conf.py (modified) * porting/wscript (modified) * posix-compliance/conf.py (modified) * posix-compliance/wscript (modified) * posix-users/conf.py (modified) * posix-users/wscript (modified) * rtemsconfig/conf.py (modified) * rtemsconfig/wscript (modified) * shell/conf.py (modified) * shell/wscript (modified) * user/conf.py (modified) * user/wscript (modified) * wscript (modified) build: Prepend project common path This avoids conflicts with ... Fri, 11 Jan 2019 09:39:19 GMT Sebastian Huber [b5014fe] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/license.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Reformat and update copyright and license notices For everything ... Wed, 09 Jan 2019 15:14:06 GMT Sebastian Huber [e52906b] * book/index_book.rst (modified) * bsp-howto/ada95_interrupt.rst (modified) * bsp-howto/ata.rst (modified) * bsp-howto/clock.rst (modified) * bsp-howto/command.rst (modified) * bsp-howto/console.rst (modified) * bsp-howto/frame_buffer.rst (modified) * bsp-howto/getentropy.rst (modified) * bsp-howto/i2c.rst (modified) * bsp-howto/ide_controller.rst (modified) * bsp-howto/index.rst (modified) * bsp-howto/initilization_code.rst (modified) * bsp-howto/linker_script.rst (modified) * bsp-howto/miscellanous_support.rst (modified) * bsp-howto/networking.rst (modified) * bsp-howto/preface.rst (modified) * bsp-howto/real_time_clock.rst (modified) * bsp-howto/shared_memory_support.rst (modified) * bsp-howto/spi.rst (modified) * bsp-howto/target_dependant_files.rst (modified) * bsp-howto/timer.rst (modified) * c-user/ada_support.rst (modified) * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/example_application.rst (modified) * c-user/fatal_error.rst (modified) * c-user/glossary.rst (modified) * c-user/index.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/preface.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/self_contained_objects.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) * cpu-supplement/altera_nios_ii.rst (modified) * cpu-supplement/arm.rst (modified) * cpu-supplement/atmel_avr.rst (modified) * cpu-supplement/blackfin.rst (modified) * cpu-supplement/ephiphany.rst (modified) * cpu-supplement/index.rst (modified) * cpu-supplement/intel_amd_x86.rst (modified) * cpu-supplement/lattice_micro32.rst (modified) * cpu-supplement/m68xxx_and_coldfire.rst (modified) * cpu-supplement/mips.rst (modified) * cpu-supplement/openrisc_1000.rst (modified) * cpu-supplement/port.rst (modified) * cpu-supplement/powerpc.rst (modified) * cpu-supplement/preface.rst (modified) * cpu-supplement/renesas_m32c.rst (modified) * cpu-supplement/riscv.rst (modified) * cpu-supplement/sparc.rst (modified) * cpu-supplement/sparc64.rst (modified) * cpu-supplement/sparc_v8_stacks_regwin.rst (modified) * cpu-supplement/superh.rst (modified) * cpu-supplement/xilinx_microblaze.rst (modified) * develenv/command.rst (modified) * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/introduction.rst (modified) * develenv/sample.rst (modified) * develenv/utilities.rst (modified) * eclipse/glossary.rst (modified) * eclipse/index.rst (modified) * eclipse/overview.rst (modified) * eclipse/rtems.rst (modified) * eng/appendix-a.rst (modified) * eng/change-management.rst (modified) * eng/change-reports.rst (modified) * eng/coding-80cols.rst (modified) * eng/coding-conventions.rst (modified) * eng/coding-deprecating.rst (modified) * eng/coding-doxygen-bsp.rst (modified) * eng/coding-doxygen.rst (modified) * eng/coding-file-hdr.rst (modified) * eng/coding-gen-patch.rst (modified) * eng/coding-naming.rst (modified) * eng/coding.rst (modified) * eng/index.rst (modified) * eng/issue-tracking.rst (modified) * eng/license-requirements.rst (modified) * eng/management.rst (modified) * eng/preface.rst (modified) * eng/prequalification.rst (modified) * eng/release-mgmt.rst (modified) * eng/stakeholders.rst (modified) * eng/test-plan.rst (modified) * eng/test-suites.rst (modified) * eng/tester.rst (modified) * eng/users-manuals.rst (modified) * eng/vc-authors.rst (modified) * eng/vc-users.rst (modified) * eng/vdd-generation.rst (modified) * eng/why-contribute.rst (modified) * filesystem/call_development.rst (modified) * filesystem/command_and_variable.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/index.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * filesystem/trivial_ftp.rst (modified) * networking/command.rst (modified) * networking/dec_21140.rst (modified) * networking/index.rst (modified) * networking/network_servers.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/command.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/index.rst (modified) * porting/interrupts.rst (modified) * porting/miscellanous.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix-compliance/glossary.rst (modified) * posix-compliance/index.rst (modified) * posix-compliance/preface.rst (modified) * posix-compliance/standards.rst (modified) * posix-users/clock.rst (modified) * posix-users/command.rst (modified) * posix-users/condition_variable.rst (modified) * posix-users/devctl.rst (modified) * posix-users/device_and_class_specific.rst (modified) * posix-users/files_and_directory.rst (modified) * posix-users/index.rst (modified) * posix-users/input_and_output.rst (modified) * posix-users/key.rst (modified) * posix-users/language_specific_services.rst (modified) * posix-users/memory_managment.rst (modified) * posix-users/message_passing.rst (modified) * posix-users/mutex.rst (modified) * posix-users/preface.rst (modified) * posix-users/process_creation_and_execution.rst (modified) * posix-users/process_environment.rst (modified) * posix-users/scheduler.rst (modified) * posix-users/semaphore.rst (modified) * posix-users/services_provided_by_c.rst (modified) * posix-users/services_provided_by_math.rst (modified) * posix-users/signal.rst (modified) * posix-users/status_of_implementation.rst (modified) * posix-users/system_database.rst (modified) * posix-users/thread.rst (modified) * posix-users/thread_cancellation.rst (modified) * posix-users/timer.rst (modified) * rsb/bug-reporting.rst (modified) * rsb/building-tools-and-rtems.rst (modified) * rsb/commands.rst (modified) * rsb/configuration.rst (modified) * rsb/cross-canadian-cross.rst (modified) * rsb/index.rst (modified) * rsb/project-sets.rst (modified) * rsb/source-builder.rst (modified) * rsb/third-party-packages.rst (modified) * rtemsconfig/index.rst (modified) * rtemsconfig/option.rst (modified) * rtemsconfig/rtemsconfig.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * user/apps/index.rst (modified) * user/bsp/index.rst (modified) * user/bsps/bsps-aarch64.rst (modified) * user/bsps/bsps-arm.rst (modified) * user/bsps/bsps-bfin.rst (modified) * user/bsps/bsps-epiphany.rst (modified) * user/bsps/bsps-i386.rst (modified) * user/bsps/bsps-lm32.rst (modified) * user/bsps/bsps-m68k.rst (modified) * user/bsps/bsps-microblaze.rst (modified) * user/bsps/bsps-mips.rst (modified) * user/bsps/bsps-moxie.rst (modified) * user/bsps/bsps-nios2.rst (modified) * user/bsps/bsps-or1k.rst (modified) * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-riscv.rst (modified) * user/bsps/bsps-sh.rst (modified) * user/bsps/bsps-sparc.rst (modified) * user/bsps/bsps-sparc64.rst (modified) * user/bsps/bsps-v850.rst (modified) * user/bsps/bsps-x86_64.rst (modified) * user/bsps/index.rst (modified) * user/ecosys/index.rst (modified) * user/exe/debugging.rst (modified) * user/exe/executables.rst (modified) * user/exe/execution.rst (modified) * user/exe/index.rst (modified) * user/exe/initialization.rst (modified) * user/glossary/index.rst (modified) * user/hardware/architectures.rst (modified) * user/hardware/bsps.rst (modified) * user/hardware/index.rst (modified) * user/hardware/targets.rst (modified) * user/hardware/tiers.rst (modified) * user/hosts/index.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/index.rst (modified) * user/installation/developer.rst (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (modified) * user/installation/prefixes-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/overview/index.rst (modified) * user/start/index.rst (modified) * user/support/index.rst (modified) * user/testing/configuration.rst (modified) * user/testing/consoles.rst (modified) * user/testing/gdb-jtag.rst (modified) * user/testing/index.rst (modified) * user/testing/simulation.rst (modified) * user/testing/tests.rst (modified) * user/testing/tftp.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/index.rst (modified) * user/tools/linker.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * user/tracing/captureengine.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/index.rst (modified) * user/tracing/introduction.rst (modified) * user/tracing/tracelinker.rst (modified) Simplify SPDX-License-Identifier comment Wed, 09 Jan 2019 15:14:04 GMT Sebastian Huber [4886d60] * bsp-howto/ada95_interrupt.rst (modified) * bsp-howto/ata.rst (modified) * bsp-howto/clock.rst (modified) * bsp-howto/console.rst (modified) * bsp-howto/frame_buffer.rst (modified) * bsp-howto/getentropy.rst (modified) * bsp-howto/i2c.rst (modified) * bsp-howto/ide_controller.rst (modified) * bsp-howto/initilization_code.rst (modified) * bsp-howto/linker_script.rst (modified) * bsp-howto/miscellanous_support.rst (modified) * bsp-howto/networking.rst (modified) * bsp-howto/preface.rst (modified) * bsp-howto/real_time_clock.rst (modified) * bsp-howto/shared_memory_support.rst (modified) * bsp-howto/spi.rst (modified) * bsp-howto/target_dependant_files.rst (modified) * bsp-howto/timer.rst (modified) * c-user/ada_support.rst (modified) * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/example_application.rst (modified) * c-user/fatal_error.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/preface.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/self_contained_objects.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) * cpu-supplement/altera_nios_ii.rst (modified) * cpu-supplement/arm.rst (modified) * cpu-supplement/atmel_avr.rst (modified) * cpu-supplement/blackfin.rst (modified) * cpu-supplement/ephiphany.rst (modified) * cpu-supplement/intel_amd_x86.rst (modified) * cpu-supplement/lattice_micro32.rst (modified) * cpu-supplement/m68xxx_and_coldfire.rst (modified) * cpu-supplement/mips.rst (modified) * cpu-supplement/openrisc_1000.rst (modified) * cpu-supplement/port.rst (modified) * cpu-supplement/powerpc.rst (modified) * cpu-supplement/preface.rst (modified) * cpu-supplement/renesas_m32c.rst (modified) * cpu-supplement/riscv.rst (modified) * cpu-supplement/sparc.rst (modified) * cpu-supplement/sparc64.rst (modified) * cpu-supplement/superh.rst (modified) * cpu-supplement/xilinx_microblaze.rst (modified) * develenv/directory.rst (modified) * develenv/introduction.rst (modified) * eclipse/index.rst (modified) * eclipse/overview.rst (modified) * eclipse/rtems.rst (modified) * eng/appendix-a.rst (modified) * eng/change-management.rst (modified) * eng/change-reports.rst (modified) * eng/coding-80cols.rst (modified) * eng/coding-conventions.rst (modified) * eng/coding-deprecating.rst (modified) * eng/coding-doxygen-bsp.rst (modified) * eng/coding-doxygen.rst (modified) * eng/coding-file-hdr.rst (modified) * eng/coding-gen-patch.rst (modified) * eng/coding-naming.rst (modified) * eng/coding.rst (modified) * eng/index.rst (modified) * eng/issue-tracking.rst (modified) * eng/license-requirements.rst (modified) * eng/management.rst (modified) * eng/preface.rst (modified) * eng/prequalification.rst (modified) * eng/release-mgmt.rst (modified) * eng/stakeholders.rst (modified) * eng/test-plan.rst (modified) * eng/test-suites.rst (modified) * eng/tester.rst (modified) * eng/users-manuals.rst (modified) * eng/vc-authors.rst (modified) * eng/vc-users.rst (modified) * eng/vdd-generation.rst (modified) * eng/why-contribute.rst (modified) * filesystem/call_development.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/interrupts.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix-compliance/preface.rst (modified) * posix-compliance/standards.rst (modified) * posix-users/condition_variable.rst (modified) * posix-users/devctl.rst (modified) * posix-users/device_and_class_specific.rst (modified) * posix-users/files_and_directory.rst (modified) * posix-users/input_and_output.rst (modified) * posix-users/key.rst (modified) * posix-users/language_specific_services.rst (modified) * posix-users/memory_managment.rst (modified) * posix-users/message_passing.rst (modified) * posix-users/mutex.rst (modified) * posix-users/preface.rst (modified) * posix-users/process_creation_and_execution.rst (modified) * posix-users/process_environment.rst (modified) * posix-users/scheduler.rst (modified) * posix-users/semaphore.rst (modified) * posix-users/services_provided_by_c.rst (modified) * posix-users/services_provided_by_math.rst (modified) * posix-users/signal.rst (modified) * posix-users/system_database.rst (modified) * posix-users/thread.rst (modified) * posix-users/thread_cancellation.rst (modified) * posix-users/timer.rst (modified) * rsb/bug-reporting.rst (modified) * rsb/building-tools-and-rtems.rst (modified) * rsb/commands.rst (modified) * rsb/configuration.rst (modified) * rsb/cross-canadian-cross.rst (modified) * rsb/project-sets.rst (modified) * rsb/source-builder.rst (modified) * rsb/third-party-packages.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * user/apps/index.rst (modified) * user/bsps/bsps-aarch64.rst (modified) * user/bsps/bsps-arm.rst (modified) * user/bsps/bsps-bfin.rst (modified) * user/bsps/bsps-epiphany.rst (modified) * user/bsps/bsps-i386.rst (modified) * user/bsps/bsps-lm32.rst (modified) * user/bsps/bsps-m68k.rst (modified) * user/bsps/bsps-microblaze.rst (modified) * user/bsps/bsps-mips.rst (modified) * user/bsps/bsps-moxie.rst (modified) * user/bsps/bsps-nios2.rst (modified) * user/bsps/bsps-or1k.rst (modified) * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-riscv.rst (modified) * user/bsps/bsps-sh.rst (modified) * user/bsps/bsps-sparc.rst (modified) * user/bsps/bsps-sparc64.rst (modified) * user/bsps/bsps-v850.rst (modified) * user/bsps/bsps-x86_64.rst (modified) * user/bsps/index.rst (modified) * user/ecosys/index.rst (modified) * user/exe/debugging.rst (modified) * user/exe/executables.rst (modified) * user/exe/execution.rst (modified) * user/exe/index.rst (modified) * user/exe/initialization.rst (modified) * user/hardware/architectures.rst (modified) * user/hardware/bsps.rst (modified) * user/hardware/index.rst (modified) * user/hardware/targets.rst (modified) * user/hardware/tiers.rst (modified) * user/hosts/index.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/installation/developer.rst (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (modified) * user/installation/prefixes-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/start/index.rst (modified) * user/testing/configuration.rst (modified) * user/testing/consoles.rst (modified) * user/testing/gdb-jtag.rst (modified) * user/testing/index.rst (modified) * user/testing/simulation.rst (modified) * user/testing/tests.rst (modified) * user/testing/tftp.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/index.rst (modified) * user/tools/linker.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * user/tracing/captureengine.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/index.rst (modified) * user/tracing/introduction.rst (modified) * user/tracing/tracelinker.rst (modified) Use standard format for copyright lines Fri, 04 Jan 2019 11:01:41 GMT Sebastian Huber [50fbe0d] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/header.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * rsb/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Add common header.rst to reduce copy and paste Thu, 20 Dec 2018 15:17:09 GMT Joel Sherrill [6682434] * eng/appendix-a.rst (modified) * eng/license-requirements.rst (modified) * eng/prequalification.rst (modified) * eng/test-plan.rst (modified) * eng/users-manuals.rst (modified) * eng/vc-authors.rst (modified) * eng/vc-users.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/introduction.rst (modified) Eliminate UTF-8 characters except superscripted 2 in i2c Thu, 20 Dec 2018 07:19:05 GMT Sebastian Huber [e24c5e9] * eng/vc-users.rst (modified) eng: Unicode char (U+200B) Sun, 09 Dec 2018 15:50:04 GMT Pritish Jain [75f2463] * eng/coding-conventions.rst (modified) eng/coding-conventions.rst: Convert TBD to Rest Format (GCI 2018) Wed, 05 Dec 2018 14:43:00 GMT Marçal Comajoan Cara [cc826d7] * eng/coding-doxygen.rst (modified) eng/coding-doxygen: Fix errors This work was part of GCI 2018. Tue, 04 Dec 2018 19:29:43 GMT Sal [b8b4f14] * eng/coding-file-hdr.rst (modified) eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) Tue, 04 Dec 2018 19:21:54 GMT Joel Sherrill [f5c20a6] * eng/coding-doxygen.rst (modified) eng/coding-doxygen.rst: Clean up and make subsubsections Mon, 03 Dec 2018 09:40:15 GMT zehata [cd6ac10] * eng/coding-doxygen.rst (modified) Converted Doxygen Best Practices Documentation to Rest format (GCI 2018) Mon, 03 Dec 2018 23:40:47 GMT Pritish Jain [edde29e] * eng/coding-naming.rst (modified) coding-naming: Convert TBD to Rest format (GCI 2018) Mon, 03 Dec 2018 17:01:40 GMT Marçal Comajoan Cara [7e91a8f] * eng/vc-users.rst (modified) eng/vc-users: Convert wiki page to Rest (GCI 2018) Converted ... Mon, 03 Dec 2018 05:33:31 GMT Marçal Comajoan Cara [f4782c9] * eng/vc-authors.rst (modified) * images/eng/Git-personalrepo.png (added) eng/vc-authors: Convert wiki page to Rest (GCI 2018) Converted ... Sun, 02 Dec 2018 21:13:01 GMT Pritiah Jain [32a4a0a] * eng/management.rst (modified) * eng/why-contribute.rst (added) management: Convert TBD to rest Format (GCI 2018) Sun, 02 Dec 2018 23:02:40 GMT Marçal Comajoan Cara [4ff3787] * eng/conf.py (modified) eng/conf.py: Use new short name of SW Eng Handbook Sun, 02 Dec 2018 17:35:41 GMT Joel Sherrill [ccbaea6] * eng/license-requirements.rst (modified) eng/license-requirements.rst: Add a TBD for BSD info Sun, 02 Dec 2018 17:29:33 GMT Joel Sherrill [9c75517] * eng/coding-doxygen-bsp.rst (modified) * eng/coding-file-hdr.rst (modified) coding-doxygen-bsp.rst, coding-file-hdr.rst: Fix formatting Sat, 01 Dec 2018 20:16:35 GMT Pritish Jain [e55248d] * eng/coding-file-hdr.rst (modified) coding-file-hdr: Convert TBD to Rest Format (GCI 2018) Sun, 02 Dec 2018 08:44:29 GMT Pritish Jain [0184167] * eng/coding-doxygen-bsp.rst (modified) coding-doxygen-bsp: Convert TBD to rest Format(GCI 2018) Sat, 01 Dec 2018 09:27:48 GMT Pritish Jain [65476b4] * eng/coding-gen-patch.rst (modified) coding-gen-patch:Convert TBD to rest Format(GCI 2018) Sat, 01 Dec 2018 17:11:15 GMT Marçal Comajoan Cara [8059b68] * eng/coding-80cols.rst (modified) eng/coding-80cols: Convert wiki page to Rest Converted ... Sat, 01 Dec 2018 14:17:11 GMT Marçal Comajoan Cara [49453ec] * eng/appendix-a.rst (modified) eng/appendix-a: convert to a table Convert text to a table, TBDs ... Sat, 01 Dec 2018 16:08:49 GMT Joel Sherrill [602561f] * eng/test-suites.rst (modified) eng/test-suites.rst: Update to reflect current reality Fri, 30 Nov 2018 21:59:01 GMT Pritish Jain [b0646e4] * eng/test-suites.rst (modified) test-suites:Convert TBD to rest Format(GCI 2018) Wed, 21 Nov 2018 16:39:04 GMT Joel Sherrill [1ae5e88] * eng/README (added) * eng/appendix-a.rst (added) * eng/change-management.rst (added) * eng/change-reports.rst (added) * eng/coding-80cols.rst (added) * eng/coding-conventions.rst (added) * eng/coding-deprecating.rst (added) * eng/coding-doxygen-bsp.rst (added) * eng/coding-doxygen.rst (added) * eng/coding-file-hdr.rst (added) * eng/coding-gen-patch.rst (added) * eng/coding-naming.rst (added) * eng/coding.rst (added) * eng/conf.py (added) * eng/index.rst (added) * eng/issue-tracking.rst (added) * eng/license-requirements.rst (added) * eng/management.rst (added) * eng/preface.rst (added) * eng/prequalification.rst (added) * eng/release-mgmt.rst (added) * eng/stakeholders.rst (added) * eng/test-plan.rst (added) * eng/test-suites.rst (added) * eng/tester.rst (added) * eng/users-manuals.rst (added) * eng/vc-authors.rst (added) * eng/vc-users.rst (added) * eng/vdd-generation.rst (added) * eng/wscript (added) * wscript (modified) Initial start of converting the Word outline to Rest Thanks to ...
