# # ChangeLog for eng in rtems-docs # # Generated by Trac 1.2.1.dev0 # 05/19/24 05:06:58 Wed, 10 Aug 2022 20:40:49 GMT Joel Sherrill [7757c19] * eng/req/howto.rst (modified) eng/req/howto.rst: Fix ./spec2dmodules.py to ./spec2modules.py typo Wed, 15 Jun 2022 15:53:21 GMT Joel Sherrill [582141e] * eng/coding-conventions.rst (modified) eng/coding-conventions.rst: Fix duplicate periods Thu, 24 Mar 2022 19:18:12 GMT Joel Sherrill [9b6583d] * eng/tester.rst (modified) eng/tester.rst: Reference User Manual for rtems-test This was just ... Fri, 28 Jan 2022 13:58:58 GMT Sebastian Huber [383b600] * eng/release-process.rst (modified) eng: Add rtems-central.git post branch procedures Fri, 28 Jan 2022 13:58:01 GMT Sebastian Huber [fff7d6a] * eng/release-process.rst (modified) eng: Fix indentation Fri, 28 Jan 2022 13:35:37 GMT Sebastian Huber [2924bf7] * eng/release-process.rst (modified) eng: Update version number handling Fri, 21 Jan 2022 16:02:27 GMT Sebastian Huber [dd60a4a] * eng/req/howto.rst (modified) eng: Add script usage to how-to Update #3715. Tue, 11 Jan 2022 16:00:49 GMT Sebastian Huber [1ba0f41] * eng/req/items.rst (modified) eng: Document get-string-command-line action Update #4548. Tue, 11 Jan 2022 15:54:01 GMT Sebastian Huber [9fecafa] * eng/req/items.rst (modified) eng: Add runtime performance kinds Tue, 11 Jan 2022 15:51:16 GMT Sebastian Huber [fa1c18e] * eng/req/items.rst (modified) eng: Document get-string-command-line action Close #4548. Tue, 11 Jan 2022 15:50:41 GMT Sebastian Huber [ffcf9dc] * eng/req/items.rst (modified) eng: Fix action requirement patterns Mon, 13 Sep 2021 06:27:45 GMT Sebastian Huber [04bf6a7] * eng/req/items.rst (modified) eng: Fix wording in specification items Fri, 10 Sep 2021 14:22:31 GMT Sebastian Huber [2df0d64] * eng/req/items.rst (modified) eng: Add hidden interface group membership Update #3715. Fri, 10 Sep 2021 14:21:25 GMT Sebastian Huber [60e08fd] * eng/req/items.rst (modified) eng: Make interface definitions optional Update #3715. Fri, 10 Sep 2021 14:26:18 GMT Sebastian Huber [9dd6135] * eng/req/items.rst (modified) eng: Add interface params/return to typedefs Update #3715. Fri, 10 Sep 2021 14:25:59 GMT Sebastian Huber [7b2b1b4] * eng/req/items.rst (modified) eng: Simplify interface return specification Update #3715. Thu, 02 Sep 2021 09:18:48 GMT Sebastian Huber [8edb899] * eng/coding-conventions.rst (modified) eng: Remove bogus coding rule Declaring functions used only through ... Wed, 18 Aug 2021 09:27:56 GMT Sebastian Huber [d223ec9] * eng/build-system.rst (modified) * eng/req/items.rst (modified) eng: Document use of BSP family for defaults Update #4468. Mon, 02 Aug 2021 05:16:38 GMT Sebastian Huber [76b5b81] * eng/req/items.rst (modified) eng: Add freestanding test cases Update #3715. Sun, 30 May 2021 21:06:56 GMT Vijay Kumar Banerjee [2295c88] * eng/vc-authors.rst (modified) eng/vc-authors: Add section on migrating personal repo to top-level Sat, 08 May 2021 08:21:06 GMT Sebastian Huber [b797009] * eng/req/items.rst (modified) eng: Add unspecified interface groups Update #3715. Fri, 30 Apr 2021 05:05:15 GMT Sebastian Huber [aa0c495] * eng/req/items.rst (modified) eng: Remove text attribute from acfg options Update #3715. Thu, 29 Apr 2021 09:04:38 GMT Sebastian Huber [a95c968] * eng/req/items.rst (modified) eng: Add test suite name Update #3715. Thu, 29 Apr 2021 09:03:57 GMT Sebastian Huber [b6cb057] * eng/req/items.rst (modified) eng: Remove scope from constraints Use links instead of this ... Thu, 29 Apr 2021 05:22:28 GMT Sebastian Huber [e263e84] * eng/req/items.rst (modified) eng: Add unit test link role Update #3715. Wed, 28 Apr 2021 11:22:48 GMT Sebastian Huber [889a5ffc] * eng/req/items.rst (modified) eng: Remove embedded constraints Update #3715. Mon, 26 Apr 2021 07:56:41 GMT Sebastian Huber [3fa9ed4] * eng/req/items.rst (modified) eng: Allow multiple interface references Update #3715. Wed, 17 Mar 2021 13:00:01 GMT Sebastian Huber [4476290] * eng/req/howto.rst (modified) * eng/test-framework.rst (modified) eng: Add example to action requirements how-to Update #3715. Tue, 16 Mar 2021 14:45:29 GMT Sebastian Huber [b40e043] * eng/req/items.rst (modified) eng: Document expressions in action requirements Update #3715. Tue, 16 Mar 2021 15:02:53 GMT Sebastian Huber [b580a6d] * eng/req/howto.rst (modified) eng: Add build/appl config clauses to how-to Update #3715. Wed, 17 Mar 2021 09:29:48 GMT Sebastian Huber [239644b] * eng/req/howto.rst (modified) * eng/req/req-for-req.rst (modified) eng: Update EARS syntax The document used the EARS syntax from 2009 ... Tue, 16 Mar 2021 18:30:59 GMT Meh Mbeh Ida Delphine [a4755f6] * eng/vc-users.rst (modified) eng/vc-users: Set up patch message with repo name Added ... Thu, 11 Mar 2021 06:52:27 GMT Sebastian Huber [bc0a857] * eng/req/howto.rst (modified) eng: Clarify how-to for action requirements Bring how-to in line ... Wed, 10 Mar 2021 11:52:28 GMT Sebastian Huber [0518d94] * eng/req/howto.rst (modified) eng: Clarify how-to for action requirements Update #3715. Mon, 08 Mar 2021 09:19:07 GMT Sebastian Huber [e05df28] * eng/req/howto.rst (modified) eng: Clarify how-to for action requirements Update #3715. Mon, 08 Mar 2021 07:15:54 GMT Sebastian Huber [a4b3019] * eng/req/howto.rst (modified) eng: Add how-to for action requirements Update #3715. Tue, 02 Mar 2021 07:28:48 GMT Sebastian Huber [fcac22e] * eng/req/items.rst (modified) eng: Fix typo Update #3715. Mon, 08 Feb 2021 14:01:50 GMT Sebastian Huber [174444f] * eng/req/items.rst (modified) eng: Update test case item Update #3715. Mon, 25 Jan 2021 05:58:10 GMT Sebastian Huber [ba633ec] * c-user/config/bdbuf.rst (modified) * c-user/config/bsp-related.rst (modified) * c-user/config/classic-api.rst (modified) * c-user/config/classic-init-task.rst (modified) * c-user/config/device-driver.rst (modified) * c-user/config/event-record.rst (modified) * c-user/config/filesystem.rst (modified) * c-user/config/general.rst (modified) * c-user/config/idle-task.rst (modified) * c-user/config/mpci.rst (modified) * c-user/config/posix-api.rst (modified) * c-user/config/posix-init-thread.rst (modified) * c-user/config/scheduler-general.rst (modified) * c-user/config/task-stack-alloc.rst (modified) * c-user/event/directives.rst (modified) * c-user/event/introduction.rst (modified) * c-user/io/directives.rst (modified) * c-user/io/introduction.rst (modified) * c-user/object-services/directives.rst (modified) * c-user/object-services/introduction.rst (modified) * c-user/partition/directives.rst (modified) * c-user/partition/introduction.rst (modified) * c-user/timer/directives.rst (modified) * c-user/timer/introduction.rst (modified) * eng/req/items.rst (modified) Improve file header comment in generated files Fri, 27 Nov 2020 08:13:56 GMT Sebastian Huber [a08e672] * eng/req/items.rst (modified) eng: Add design group requirement item type Update #3715. Thu, 12 Nov 2020 06:41:18 GMT Sebastian Huber [4b03ff7] * eng/req/items.rst (modified) eng: Add performance specification items Add items to specify ... Fri, 06 Nov 2020 10:12:55 GMT Sebastian Huber [238789d] * eng/coding-doxygen.rst (modified) * eng/coding-file-hdr.rst (modified) eng: Rework and clarify Doxygen Guidelines Thu, 19 Nov 2020 10:22:46 GMT Sebastian Huber [bbd8d4a] * eng/req/items.rst (modified) eng: Fix typo Update #3715. Thu, 12 Nov 2020 09:36:32 GMT Sebastian Huber [0454ad7] * eng/test-framework.rst (modified) eng: Simplify "Load" environment reporting Report all runtime ... Thu, 12 Nov 2020 09:27:12 GMT Sebastian Huber [cdbd72d] * eng/test-framework.rst (modified) eng: Rename ValidCache environment in FullCache This name better ... Wed, 11 Nov 2020 07:20:04 GMT Sebastian Huber [ad64ea0] * c-user/config/bdbuf.rst (modified) * c-user/config/bsp-related.rst (modified) * c-user/config/classic-api.rst (modified) * c-user/config/classic-init-task.rst (modified) * c-user/config/device-driver.rst (modified) * c-user/config/event-record.rst (modified) * c-user/config/filesystem.rst (modified) * c-user/config/general.rst (modified) * c-user/config/idle-task.rst (modified) * c-user/config/mpci.rst (modified) * c-user/config/posix-api.rst (modified) * c-user/config/posix-init-thread.rst (modified) * c-user/config/scheduler-general.rst (modified) * c-user/config/task-stack-alloc.rst (modified) * c-user/io/directives.rst (modified) * c-user/io/introduction.rst (modified) * eng/req/items.rst (modified) Improve automatically generated warning Fri, 06 Nov 2020 08:21:31 GMT Sebastian Huber [64323c3] * eng/coding-80cols.rst (deleted) * eng/coding-conventions.rst (modified) * eng/coding-formatting.rst (added) * eng/coding.rst (modified) eng: Move code formatting rules into one section Clarify the 80 ... Thu, 05 Nov 2020 18:39:57 GMT Sebastian Huber [b0b6c0c] * eng/coding-conventions.rst (modified) eng: Clarify "Coding Conventions" introduction Thu, 05 Nov 2020 18:38:12 GMT Sebastian Huber [dc345cf] * eng/coding-conventions.rst (modified) * eng/coding-file-hdr.rst (modified) eng: Clarify "Source Documentation" section Thu, 05 Nov 2020 18:24:24 GMT Sebastian Huber [c694df1] * eng/coding-conventions.rst (modified) * eng/coding-doxygen.rst (modified) * eng/coding-file-hdr.rst (modified) eng: Add header file conventions Thu, 05 Nov 2020 15:27:23 GMT Sebastian Huber [3c896b9] * eng/coding-gen-patch.rst (deleted) * eng/coding.rst (modified) eng: Remove "Generating a Tools Patch" This section is probably ... Mon, 12 Oct 2020 13:52:13 GMT Sebastian Huber [f610291] * eng/req/items.rst (modified) eng: Add function attributes Update #3715. Sat, 24 Oct 2020 10:12:31 GMT Sebastian Huber [abc9c44] * eng/req/howto.rst (modified) eng: Replace spec2doc.py with spec2modules.py Update #3715. Sun, 11 Oct 2020 13:18:59 GMT Sebastian Huber [bcf4a95] * eng/req/items.rst (modified) eng: Add placement link role Update #3715. Sun, 11 Oct 2020 13:18:36 GMT Sebastian Huber [c18215c] * eng/req/items.rst (modified) eng: Move index-entries to all interfaces Update #3715. Sun, 11 Oct 2020 13:17:39 GMT Sebastian Huber [dd97e25] * c-user/config/bdbuf.rst (modified) * c-user/config/bsp-related.rst (modified) * c-user/config/classic-api.rst (modified) * c-user/config/classic-init-task.rst (modified) * c-user/config/device-driver.rst (modified) * c-user/config/event-record.rst (modified) * c-user/config/filesystem.rst (modified) * c-user/config/general.rst (modified) * c-user/config/idle-task.rst (modified) * c-user/config/mpci.rst (modified) * c-user/config/posix-api.rst (modified) * c-user/config/posix-init-thread.rst (modified) * c-user/config/scheduler-general.rst (modified) * c-user/config/task-stack-alloc.rst (modified) * eng/req/items.rst (modified) Improve file header comment in generated files Fri, 09 Oct 2020 05:59:47 GMT Sebastian Huber [400d513] * eng/build-system.rst (modified) eng: Remove explicit figure class This makes the legend left justified. Thu, 08 Oct 2020 05:53:47 GMT Sebastian Huber [8c6414a] * eng/build-system.rst (modified) eng: Add proper figure titles The first paragraph of a figure ... Thu, 01 Oct 2020 05:37:04 GMT Sebastian Huber [9628dfd] * eng/req/items.rst (modified) eng: Clarify stlib build attribute Update #4107. Mon, 28 Sep 2020 07:11:24 GMT Sebastian Huber [e70aebd] * eng/req/items.rst (modified) eng: Fix typo Fri, 18 Sep 2020 11:09:59 GMT Frank Kühndel [bacc559] * eng/test-framework.rst (modified) eng/test-framework.rst -- Fix typo Fri, 18 Sep 2020 12:37:09 GMT Sebastian Huber [103a96e] * eng/req/items.rst (modified) eng: Remove double blank line Fri, 18 Sep 2020 06:23:26 GMT Sebastian Huber [972f208] * eng/release-process.rst (modified) eng: Update release process Thu, 07 Nov 2019 10:18:01 GMT Sebastian Huber [449fc74] * eng/build-system.rst (added) * eng/index.rst (modified) * images/eng/bld-bsp.dot (added) * images/eng/bld-bsp.pdf (added) * images/eng/bld-bsp.png (added) * images/eng/bld-bsp2.dot (added) * images/eng/bld-bsp2.pdf (added) * images/eng/bld-bsp2.png (added) * images/eng/bld-deps.dot (added) * images/eng/bld-deps.pdf (added) * images/eng/bld-deps.png (added) * images/eng/bld-deps2.dot (added) * images/eng/bld-deps2.pdf (added) * images/eng/bld-deps2.png (added) eng: Add BSP build system chapter Update #3818. Tue, 01 Sep 2020 02:09:41 GMT Chris Johns [415b072] * eng/coding-file-hdr.rst (modified) eng: Update the python template, add a shell template Wed, 19 Aug 2020 09:09:44 GMT Sebastian Huber [57fb30d] * eng/req/items.rst (modified) eng: Add automatically generated warning Update #3715. Wed, 19 Aug 2020 09:09:00 GMT Sebastian Huber [93938c7] * eng/req/items.rst (modified) eng: Unify test attribute keys Update #3715. Fri, 14 Aug 2020 05:46:11 GMT Sebastian Huber [83a3522] * eng/req/items.rst (modified) eng: Add test header to test case Update #3715. Fri, 14 Aug 2020 05:42:26 GMT Sebastian Huber [1a48655] * eng/req/items.rst (modified) eng: Remove test name attribute Derive the test name from the item ... Thu, 06 Aug 2020 07:15:13 GMT Sebastian Huber [9633e98] * eng/req/items.rst (modified) eng: Add test case attributes Update #3715. Fri, 07 Aug 2020 05:32:58 GMT Sebastian Huber [7811c76] * eng/release-process.rst (modified) eng: Add Doxyfile update to release process Fri, 07 Aug 2020 05:10:58 GMT Sebastian Huber [5cb493e] * eng/req/items.rst (modified) eng: Add reference to unspecified interfaces Update #3715. Thu, 06 Aug 2020 07:58:49 GMT Sebastian Huber [3e8e301] * eng/req/items.rst (modified) eng: Add more variants of unspecified interfaces Update #3715. Wed, 05 Aug 2020 17:48:43 GMT Sebastian Huber [83e13b7] * eng/req/howto.rst (modified) eng: Add application config options how-to Update #3715. Wed, 05 Aug 2020 12:24:58 GMT Sebastian Huber [e2abac7] * eng/req/howto.rst (modified) eng: Refer to the rtems-central repository Close #4043. Thu, 06 Aug 2020 07:16:11 GMT Sebastian Huber [e1e0408] * eng/req/items.rst (modified) eng: Partially revert previous commit The previous commit contained ... Thu, 06 Aug 2020 07:11:07 GMT Sebastian Huber [bac4398] * eng/req/items.rst (modified) eng: Fix typo Update #3715. Wed, 29 Jul 2020 09:13:28 GMT Christian Mauderer [5bd15a0] * eng/release-process.rst (modified) eng/release: Add libbsd version update Tue, 28 Jul 2020 04:58:20 GMT Sebastian Huber [1bb6947] * eng/req/items.rst (modified) eng: Fix format of regular expressions Update #3715. Mon, 27 Jul 2020 13:44:04 GMT Sebastian Huber [3f9fa47] * eng/req/items.rst (modified) eng: Add ability to skip action transitions Sometimes the ... Mon, 27 Jul 2020 13:38:30 GMT Sebastian Huber [c259563] * eng/req/items.rst (modified) eng: Support N/A in the action transitions Sometimes the ... Mon, 27 Jul 2020 13:37:47 GMT Sebastian Huber [f12cae1] * eng/req/items.rst (modified) eng: Add brief description to header file items Update #3715. Mon, 27 Jul 2020 13:36:50 GMT Sebastian Huber [fd2fc50] * eng/req/items.rst (modified) eng: Add requirement text to interface groups This allows to state ... Fri, 24 Jul 2020 05:10:51 GMT Sebastian Huber [ba3f265] * eng/coding-conventions.rst (modified) eng: Add recommendations for attributes Fix formatting. Tue, 21 Jul 2020 14:38:49 GMT Sebastian Huber [21fa28c] * eng/index.rst (modified) * eng/test-framework.rst (modified) * images/eng/interrupt-test.odg (added) * images/eng/interrupt-test.pdf (added) * images/eng/interrupt-test.png (added) eng: Update test framework chapter Document the dynamic text ... Thu, 02 Jul 2020 21:19:13 GMT G S Niteesh Babu [b82e7d6] * eng/coding-file-hdr.rst (modified) eng: fix typo in coding-file-hdr.rst Fri, 03 Jul 2020 08:32:58 GMT Sebastian Huber [0c13e94] * eng/req/items.rst (modified) eng: Fix typo Update #3715. Fri, 03 Jul 2020 08:31:29 GMT Sebastian Huber [1bd14cd] * eng/req/items.rst (modified) eng: Reformat to maximize the text width Remove extra "X" character ... Tue, 30 Jun 2020 07:27:26 GMT Sebastian Huber [d07eeca] * eng/release-process.rst (modified) eng: Update release process Fri, 26 Jun 2020 05:16:13 GMT Chris Johns [06a8f10] * eng/release-process.rst (modified) eng: Update the release procedure. Wed, 17 Jun 2020 07:06:37 GMT Sebastian Huber [87a9478] * eng/req/items.rst (modified) eng: Clarify action requirement specification Update #3715. Wed, 10 Jun 2020 08:12:00 GMT Sebastian Huber [db3892b] * eng/req/items.rst (modified) eng: Update action requirement specification Update #3715. Thu, 04 Jun 2020 11:55:17 GMT Sebastian Huber [ca2f5e6] * eng/req/howto.rst (modified) eng: Update specification how-to section Update #3715. Thu, 04 Jun 2020 10:53:02 GMT Sebastian Huber [0213e8ef] * eng/req/items.rst (modified) eng: Add a specification type for actions Add support to specify ... Thu, 04 Jun 2020 09:22:39 GMT Sebastian Huber [0c43c52] * eng/req/items.rst (modified) eng: Add generic attribute key types Update #3715. Thu, 04 Jun 2020 08:38:11 GMT Sebastian Huber [f547988] * eng/req/items.rst (modified) eng: Simplify wording for specification items Update #3715. Thu, 04 Jun 2020 13:00:40 GMT Sebastian Huber [b35f3ef] * c-user/glossary.rst (modified) * eng/glossary.rst (modified) Use a complete sentence for acronym definitions Mon, 01 Jun 2020 10:49:49 GMT Sebastian Huber [9b269ad] * eng/req/howto.rst (added) * eng/req/index.rst (modified) eng: Add interface specification how-to Update #3715. Fri, 29 May 2020 06:57:57 GMT Sebastian Huber [459326c] * eng/req/tooling.rst (modified) eng: Update requirements tooling section Update #3715. Thu, 28 May 2020 07:21:38 GMT Sebastian Huber [23ab40d] * eng/glossary.rst (modified) * eng/req/index.rst (modified) * eng/req/items.rst (modified) * eng/req/req-for-req.rst (modified) * eng/req/traceability.rst (modified) * eng/req/validation.rst (deleted) eng: Add generated documentation of spec items The documentation of ...
