@b6272bb
11/06/16 22:25:24 |
oss |
waf: Fix NoneType?' object is not iterable'
4.115
@25c0a23
11/06/16 01:40:41 |
Chris Johns |
waf: Fix the host version check.
4.115
@8330198
11/06/16 01:02:47 |
Chris Johns |
waf: Add support to handle missing Latex packages on hosts they are …
4.115
@74194f7
11/04/16 05:22:42 |
Chris Johns |
waf: Check for texlive packages and report an error is not found.
4.115
@9024cfb
11/03/16 21:44:37 |
Chris Johns |
waf: Fix the bnode issue when building in a manual directory.
4.115
@6207c37
11/03/16 04:22:49 |
Chris Johns |
waf: Use separate doctrees so avoid sphinx clashes.
4.115
@d3226d3
11/03/16 03:42:34 |
Chris Johns |
pdf: Make the copyright the same as the html.
4.115
@64a3db7
11/03/16 03:41:39 |
Chris Johns |
conf: Make the build date use a nicer day format.
4.115
@0bc9c6d
11/03/16 03:30:47 |
Chris Johns |
waf: Have configure set building pdf and/or singlehtml.
Move …
4.115
@ce4daf9
11/02/16 05:34:32 |
Chris Johns |
Add a copyright to the PDF front page.
4.115
@75e787d
11/02/16 01:08:27 |
Chris Johns |
html: Update the CSS and add topics.
4.115
@8f2a4f3
11/02/16 01:07:50 |
Chris Johns |
waf: Fix the sphinx verbose option.
4.115
@dd43d0b
10/30/16 21:48:21 |
Chris Johns |
waf: Add an install command.
4.115
@f529417
10/30/16 01:36:15 |
Chris Johns |
waf: Add top build support.
4.115
@761b082
10/30/16 01:35:26 |
Chris Johns |
waf: Add a build date to the copyright.
4.115
@f3a7c96
10/28/16 17:16:08 |
Chris Johns |
waf: Update to support a recent waf.
4.115
@be428d1
10/27/16 23:03:34 |
joel |
common/waf.py: Improve Sphinx version parsing to work with their git master
4.115
@a545490
09/09/16 04:08:48 |
Chris Johns |
waf: Fix for waf-1.9.3.
4.115
@f92357f
07/04/16 02:30:34 |
Chris Johns |
Make the Warning colours match the theme.
4.115
@170418a
05/18/16 17:47:42 |
verm |
Move images to a common directory.
4.115
@5353914
03/20/16 23:27:52 |
Chris Johns |
Updates from user reviews.
4.115
@ad42291
03/16/16 23:33:42 |
Chris Johns |
Remove the minted gobble.
4.115
@2bcd424
03/10/16 16:48:15 |
Amar Takhar |
Switch to using Minted and splitting long lines in verbatim.
4.115
@63eaa6f
03/10/16 16:34:19 |
Amar Takhar |
Add Minted 2015/12/21 v2.2dev (ce7a111)
4.115
@c21e8e9
03/09/16 04:35:21 |
Chris Johns |
Better error message, add FTP to the URL list.
4.115
@867016d
03/09/16 04:35:00 |
Chris Johns |
Format the index for PDF output.
4.115
@0858375
03/08/16 09:16:37 |
Chris Johns |
Run through 2to3.
4.115
@1ea5fb7
03/01/16 03:46:08 |
Amar Takhar |
Wrap \tabulary environment to allow breaking underscores.
* This …
4.115
@eccd84e
01/27/16 06:50:07 |
Chris Johns |
Add wrap support to long table entries.
4.115
@859f0b7
01/27/16 00:27:31 |
Chris Johns |
Add an rtems-table class to wrap and align HTML tables.
4.115
@7130ed3
01/26/16 10:48:15 |
Chris Johns |
Fix PDF layout.
4.115
@c18d76a
01/26/16 01:26:11 |
Chris Johns |
Add my-style.css support and add RTEMS to that CSS.
4.115
@0f5ccd4
01/23/16 05:01:45 |
Chris Johns |
Generate a fatal error on a Sphinx beta version that cannot be parsed.
4.115
@ed3794e
01/20/16 04:00:32 |
Amar Takhar |
Add 'waf linkcheck' to check external references.
4.115
@9b495a2
01/20/16 02:48:37 |
Amar Takhar |
Remove incorrect pdflatex/makeindex check.
4.115
@7c1f215
01/20/16 02:03:57 |
Amar Takhar |
Only require makeindex and pdflatex when trying to build PDF.
4.115
@a316b1f
01/20/16 01:37:04 |
Amar Takhar |
Add support for singlehtml (inlined) HTML file, plus some other fixes. …
4.115
@89f2347
01/20/16 00:33:59 |
Amar Takhar |
Fix typo and add another dependency.
4.115
@14bbcb1
01/19/16 14:55:57 |
Amar Takhar |
Add minimum version check for Sphinx.
Some distributions have ancient …
4.115
@9b5801a
01/19/16 05:27:45 |
Amar Takhar |
Add PDF generation support use with --pdf
4.115
@0abc59d
01/19/16 04:30:27 |
Amar Takhar |
Add .svg logos for RTEMS that I made myself.
One is plain SVG the …
4.115
@2643223
01/19/16 04:30:17 |
Amar Takhar |
Add logo.pdf for PDF documents.
4.115
@f916fca
01/18/16 22:53:44 |
Amar Takhar |
Add support for spellchecking with a custom dictionary.
To use:
1. …
4.115
@3a71759
01/18/16 05:05:50 |
Amar Takhar |
Rework how conf.py is handled.
Needed to switch due to increasing …
4.115
@46498bd
01/18/16 03:28:28 |
Amar Takhar |
Fix rtemsconfig building.
I'll probably move to a more pythonic way …
4.115
@5daabd2
01/16/16 04:41:06 |
Amar Takhar |
Initial reST documentation using Sphinx.
4.115
