# # ChangeLog for common in rtems-docs # # Generated by Trac 1.2.1.dev0 # 05/18/24 07:09:26 Fri, 03 Apr 2020 00:09:47 GMT Chris Johns [d514e33] * common/waf.py (modified) waf: User friendly message when no sphinx is installed Thu, 12 Mar 2020 05:34:16 GMT Chris Johns [19af6b4] * common/conf.py (modified) * common/version.py (modified) * common/waf.py (modified) * wscript (modified) waf: Get the version numbers from the version file. Thu, 12 Mar 2020 05:28:15 GMT Chris Johns [5bd9f4d] * common/_static/my-styles.css (modified) sphinx: Add a custom highlight colour Update #2998 Sun, 23 Feb 2020 00:32:07 GMT Amar Takhar [9845183] * common/sphinx_rtd_theme_rtems/__init__.py (modified) * common/sphinx_rtd_theme_rtems/breadcrumbs.html (modified) * common/sphinx_rtd_theme_rtems/footer.html (modified) * common/sphinx_rtd_theme_rtems/layout.html (modified) * common/sphinx_rtd_theme_rtems/layout_old.html (deleted) * common/sphinx_rtd_theme_rtems/locale/en/LC_MESSAGES/sphinx.mo (added) * common/sphinx_rtd_theme_rtems/locale/en/LC_MESSAGES/sphinx.po (added) * common/sphinx_rtd_theme_rtems/locale/es/LC_MESSAGES/sphinx.mo (added) * common/sphinx_rtd_theme_rtems/locale/es/LC_MESSAGES/sphinx.po (added) * common/sphinx_rtd_theme_rtems/locale/nl/LC_MESSAGES/sphinx.mo (added) * common/sphinx_rtd_theme_rtems/locale/nl/LC_MESSAGES/sphinx.po (added) * common/sphinx_rtd_theme_rtems/locale/ru/LC_MESSAGES/sphinx.mo (added) * common/sphinx_rtd_theme_rtems/locale/ru/LC_MESSAGES/sphinx.po (added) * common/sphinx_rtd_theme_rtems/locale/sphinx.pot (added) * common/sphinx_rtd_theme_rtems/search.html (modified) * common/sphinx_rtd_theme_rtems/searchbox.html (modified) * common/sphinx_rtd_theme_rtems/static/css/badge_only.css (modified) * common/sphinx_rtd_theme_rtems/static/css/badge_only.css.map (deleted) * common/sphinx_rtd_theme_rtems/static/css/fonts/Roboto-Slab-Bold.woff (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/Roboto-Slab-Bold.woff2 (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/Roboto-Slab-Regular.woff (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/Roboto-Slab-Regular.woff2 (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/fontawesome-webfont.eot (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/fontawesome-webfont.svg (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/fontawesome-webfont.ttf (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/fontawesome-webfont.woff (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/fontawesome-webfont.woff2 (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/lato-bold-italic.woff (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/lato-bold-italic.woff2 (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/lato-bold.woff (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/lato-bold.woff2 (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/lato-normal-italic.woff (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/lato-normal-italic.woff2 (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/lato-normal.woff (added) * common/sphinx_rtd_theme_rtems/static/css/fonts/lato-normal.woff2 (added) * common/sphinx_rtd_theme_rtems/static/css/theme.css (modified) * common/sphinx_rtd_theme_rtems/static/css/theme.css.map (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/FontAwesome.otf (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/Inconsolata-Bold.ttf (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/Inconsolata-Regular.ttf (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/Lato-Bold.ttf (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/Lato-Regular.ttf (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/RobotoSlab-Bold.ttf (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/RobotoSlab-Regular.ttf (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/fontawesome-webfont.eot (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/fontawesome-webfont.svg (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/fontawesome-webfont.ttf (deleted) * common/sphinx_rtd_theme_rtems/static/fonts/fontawesome-webfont.woff (deleted) * common/sphinx_rtd_theme_rtems/static/js/badge_only.js (added) * common/sphinx_rtd_theme_rtems/static/js/html5shiv-printshiv.min.js (added) * common/sphinx_rtd_theme_rtems/static/js/html5shiv.min.js (added) * common/sphinx_rtd_theme_rtems/static/js/modernizr.min.js (deleted) * common/sphinx_rtd_theme_rtems/static/js/theme.js (modified) * common/sphinx_rtd_theme_rtems/theme.conf (modified) * common/sphinx_rtd_theme_rtems/versions.html (modified) Update sphinx_rtd_theme to ... Tue, 04 Feb 2020 04:43:01 GMT Sebastian Huber [d9d9c70] * common/rtemsdomain.py (modified) * eng/preface.rst (modified) Revert "common: Add URLs to manuals" This reverts commit ... Fri, 03 Jan 2020 08:53:24 GMT Sebastian Huber [1fdd3cf] * common/rtemsdomain.py (modified) common: Add URLs to manuals Tue, 29 Oct 2019 02:37:43 GMT Chris Johns [c576e9b] * common/waf.py (modified) waf/common: Fix UTF-8 encoding of HTML inliner output on Python3. Tue, 13 Aug 2019 05:18:59 GMT Sebastian Huber [5d7921b] * common/conf.py (modified) * common/rtemsext.py (deleted) common: Show page references after internal links The custom RTEMS ... Mon, 05 Aug 2019 13:07:36 GMT Sebastian Huber [8037cbb] * common/rtemsdomain.py (modified) common: Align "Build Logs" with other list names Wed, 24 Jul 2019 08:50:18 GMT Sebastian Huber [7888904] * common/refs.bib (modified) refs: Update EARS references Thu, 11 Jul 2019 07:05:10 GMT Sebastian Huber [d4670fe] * common/refs.bib (modified) refs: Add ECSS standard references Add the ECSS standards in a ... Tue, 23 Jul 2019 07:39:34 GMT Sebastian Huber [e859242] * common/refs.bib (modified) refs: Replace non-ASCII character Thu, 11 Jul 2019 06:55:48 GMT Sebastian Huber [a1d6374] * common/refs.bib (modified) common: Add references Wed, 19 Jun 2019 11:16:45 GMT Sebastian Huber [5a51c73] * c-user/preface.rst (modified) * common/refs.bib (modified) c-user: Add RTEID and ORKID references Fri, 01 Mar 2019 02:06:11 GMT Chris Johns [1393ba0] * common/waf.py (modified) waf: Fix argument bug getting extra source. Wed, 20 Feb 2019 04:40:37 GMT Chris Johns [1a051fc] * common/waf.py (modified) * posix-compliance/wscript (modified) waf: Add support for extra and excluded sources. Tue, 19 Feb 2019 23:11:37 GMT Chris Johns [62efd4c] * README.txt (modified) * common/waf.py (modified) waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit- ... Tue, 19 Feb 2019 23:07:04 GMT Chris Johns [fb72a00] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/unicode.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Add unicode support for commonly used characters like copyright. - ... Tue, 19 Feb 2019 22:16:19 GMT Chris Johns [4407039] * common/waf.py (modified) waf: Fix building the images in the src path. Thu, 14 Feb 2019 09:04:28 GMT Chris Johns [f7384cc] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/_templates/layout.html (modified) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * rtemsconfig/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Use pathto() on the genindex URL to make it relative. Wed, 13 Feb 2019 22:16:38 GMT Joel Sherrill [603731c] * common/latex.py (modified) common/latex.py: Remove hack for CentOS. Use Texlive per instructions. Tue, 12 Feb 2019 23:57:10 GMT Chris Johns [7b36a6b] * common/coverpage/coverpage.html (modified) * wscript (modified) waf: Use the release date in the coverpage Tue, 12 Feb 2019 23:50:50 GMT Chris Johns [d721375] * common/version.py (modified) * wscript (modified) waf: Fix version.py to support older versions of git. Thu, 07 Feb 2019 19:03:43 GMT Chris Johns [ec95748] * common/conf.py (modified) * common/minted.sty (deleted) * common/rtemsstyle.sty (modified) Remove minted from the PDF builds. This is feedback from the Sphinx ... Wed, 06 Feb 2019 21:46:53 GMT Chris Johns [6f18d69] * common/version.py (modified) Fix the version logic to make it more robust. Wed, 06 Feb 2019 06:02:18 GMT Chris Johns [a3b0a40] * common/conf.py (modified) * common/waf.py (modified) Fix building with Sphinx 1.8 and later. - Provide the pytnon.ist ... Wed, 06 Feb 2019 05:46:42 GMT Chris Johns [2a68e9d] * common/version.py (added) * wscript (modified) Support VERSION file for releasing and deployment - Shorten the GIT ... Thu, 17 Jan 2019 08:44:07 GMT Sebastian Huber [d9eb36b] * common/conf.py (modified) Change first copyright year to 1988 The OAR copyright goes back to 1988. Fri, 11 Jan 2019 09:39:19 GMT Sebastian Huber [b5014fe] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/license.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Reformat and update copyright and license notices For everything ... Fri, 11 Jan 2019 09:38:34 GMT Sebastian Huber [dec664b] * common/header.rst (modified) common/header: Add missing copyright notice Mon, 07 Jan 2019 06:45:30 GMT Sebastian Huber [65f54a9] * common/header.rst (modified) Update header.rst Remove trailing slashes in URLs. Fix bug ... Fri, 04 Jan 2019 11:01:41 GMT Sebastian Huber [50fbe0d] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/header.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * rsb/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Add common header.rst to reduce copy and paste Fri, 04 Jan 2019 10:18:57 GMT Sebastian Huber [5631d58] * common/rtemsstyle.sty (modified) Remove superfluous word "Copyright" The © symbol is sufficient. Fri, 04 Jan 2019 10:09:23 GMT Sebastian Huber [cd408b5] * common/conf.py (modified) Update general copyright notice Update year and add "and contributors". Fri, 04 Jan 2019 10:02:45 GMT Sebastian Huber [3202e31] * common/conf.py (modified) * common/waf.py (modified) * wscript (modified) Replace build date with Git hash and commit date The usage of a ... Tue, 18 Dec 2018 17:45:00 GMT Christian Mauderer [a7dc083] * common/waf.py (modified) common/waf.py: Fix indentation. Python 3 produces an error if ... Wed, 05 Dec 2018 19:31:53 GMT Amar Takhar [a46b025] * common/waf.py (modified) Fix error messages when Sphinx version cannot be checked. This is ... Fri, 02 Nov 2018 03:05:51 GMT Chris Johns [21c1a44] * README.txt (modified) * common/waf.py (modified) * images/.gitignore (added) * images/wscript (added) * wscript (modified) waf: Add support to build PlantUML and Ditaa images. Wed, 24 Oct 2018 17:41:04 GMT Amar Takhar [ab83940] * common/README_logo.txt (added) Add a README file containing the colours used in the RTEMS logo. Fri, 19 Oct 2018 03:42:12 GMT Chris Johns [969e60e] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/conf.py (modified) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * rsb/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Update the copyright year. Tue, 21 Aug 2018 04:54:41 GMT Chris Johns [859096b] * common/waf.py (modified) waf: Fix type in single html build. Tue, 21 Aug 2018 03:55:03 GMT Chris Johns [471c5e3] * common/conf.py (modified) * common/rtemsstyle.sty (modified) pdf: Revert the changes to the Latex index formatting. I removed ... Tue, 21 Aug 2018 03:41:51 GMT Chris Johns [5ce8e43] * bsp-howto/genindex.rst (deleted) * bsp-howto/index.rst (modified) * c-user/genindex.rst (deleted) * c-user/index.rst (modified) * common/_templates/layout.html (modified) * common/conf.py (modified) * common/rtemsstyle.sty (modified) * common/sphinx_rtd_theme_rtems/layout.html (modified) * common/waf.py (modified) * cpu-supplement/index.rst (modified) * develenv/genindex.rst (deleted) * develenv/index.rst (modified) * eclipse/genindex.rst (deleted) * eclipse/index.rst (modified) * filesystem/genindex.rst (deleted) * filesystem/index.rst (modified) * networking/genindex.rst (deleted) * networking/index.rst (modified) * porting/genindex.rst (deleted) * porting/index.rst (modified) * posix-compliance/genindex.rst (deleted) * posix-compliance/index.rst (modified) * posix-users/genindex.rst (deleted) * posix-users/index.rst (modified) * rsb/genindex.rst (deleted) * rsb/index.rst (modified) * shell/genindex.rst (deleted) * shell/index.rst (modified) * user/genindex.rst (deleted) * user/index.rst (modified) build: Fix indexing so it works on HTML and PDF. - Remove all ... Thu, 22 Feb 2018 16:23:08 GMT Richard Campbell [2a06644] * common/rtemsdomain.py (modified) * common/waf.py (modified) RTEMS Docs: Check sphinx version Sphinx.util.compat module was ... Fri, 13 Oct 2017 00:46:00 GMT Chris Johns [8e8094a] * common/waf.py (modified) build: Add extra source to the sphinx build. Updates #3177. Thu, 14 Sep 2017 11:50:35 GMT Chris Johns [5c3683e] * common/_static/my-styles.css (modified) Improve the line spaces for directives and notes. Thu, 24 Aug 2017 05:24:28 GMT Sebastian Huber [5fc9f8b] * common/conf.py (modified) common: Remove obsolete latex_use_parts This configuration is ... Fri, 11 Aug 2017 03:42:55 GMT Chris Johns [feb6832] * common/waf.py (modified) * develenv/conf.py (modified) coverpage: Fix repeated entries. Closes #2865. Fri, 11 Aug 2017 03:09:50 GMT Chris Johns [efc29ff] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/rtemsstyle.sty (modified) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-users/index.rst (modified) * rsb/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) * user/overview/index.rst (modified) * user/support/index.rst (modified) Update copyright notices. Fri, 11 Aug 2017 00:32:18 GMT Chris Johns [c684611] * common/rtemsstyle.sty (modified) pdf: Update the RTEMS style to work recent Sphinx versions. Fri, 11 Aug 2017 00:31:39 GMT Chris Johns [7464b71] * common/conf.py (modified) common/conf: Clean up. Wed, 09 Aug 2017 10:19:22 GMT Chris Johns [58de62d] * common/sphinxcontrib/__init__.py (deleted) * common/sphinxcontrib/bibtex/__init__.py (deleted) * common/sphinxcontrib/bibtex/cache.py (deleted) * common/sphinxcontrib/bibtex/directives.py (deleted) * common/sphinxcontrib/bibtex/nodes.py (deleted) * common/sphinxcontrib/bibtex/roles.py (deleted) * common/sphinxcontrib/bibtex/transforms.py (deleted) * common/waf.py (modified) Revert "Add the sphinxcontrib.bibtex extension to the repo." This ... Mon, 07 Aug 2017 11:58:52 GMT Chris Johns [aa4f8e2] * common/sphinxcontrib/__init__.py (added) * common/sphinxcontrib/bibtex/__init__.py (added) * common/sphinxcontrib/bibtex/cache.py (added) * common/sphinxcontrib/bibtex/directives.py (added) * common/sphinxcontrib/bibtex/nodes.py (added) * common/sphinxcontrib/bibtex/roles.py (added) * common/sphinxcontrib/bibtex/transforms.py (added) * common/waf.py (modified) Add the sphinxcontrib.bibtex extension to the repo. Sun, 26 Mar 2017 23:31:13 GMT Chris Johns [33989b6] * README.txt (modified) * common/waf.py (modified) Add Windows build details. Actually include the quoting fix for Windows. Sun, 26 Mar 2017 23:27:29 GMT Chris Johns [0263581] * common/waf.py (modified) * wscript (modified) waf: Fix linkcheck and spell commands. Clean up and remove code ... Mon, 20 Mar 2017 21:41:55 GMT Chris Johns [e7f009e] * common/conf.py (modified) conf: Update the copyright year. Mon, 20 Mar 2017 21:41:41 GMT Chris Johns [228560f] * common/waf.py (modified) waf: Create the sphinx rule in one place. Mon, 20 Mar 2017 01:18:53 GMT Chris Johns [f97be09] * bsp-howto/conf.py (modified) * c-user/conf.py (modified) * common/conf.py (modified) * common/waf.py (modified) * cpu-supplement/conf.py (modified) * develenv/conf.py (modified) * eclipse/conf.py (modified) * filesystem/conf.py (modified) * networking/conf.py (modified) * porting/conf.py (modified) * posix-users/conf.py (modified) * posix1003-1/conf.py (modified) * rsb/conf.py (modified) * rtemsconfig/conf.py (modified) * shell/conf.py (modified) * user/conf.py (modified) * wscript (modified) Use a single top level version number. Wed, 15 Mar 2017 01:34:19 GMT Chris Johns [1accbe3] * common/_static/my-styles.css (modified) * user/index.rst (modified) * user/tools/bsp-builder.rst (added) * user/tools/build.rst (deleted) * user/tools/exeinfo.rst (added) * user/tools/index.rst (modified) * user/tools/linker.rst (added) * user/tools/symbols.rst (added) user: Add tool commands to the user manual. Wed, 15 Mar 2017 04:03:10 GMT Chris Johns [91d6c96] * common/waf.py (modified) waf: Configure check the inliner only once. Sat, 25 Feb 2017 04:05:09 GMT Chris Johns [ff9d555] * common/waf.py (modified) Add a check for Sphinx extensions. Minor clean up of the configure ... Wed, 22 Feb 2017 06:09:21 GMT Sebastian Huber [c1dddac] * c-user/conf.py (modified) * common/conf.py (modified) Move extensions to common conf.py Thu, 02 Feb 2017 09:46:05 GMT Sebastian Huber [b033e39] * c-user/glossary.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * common/refs.bib (modified) c-user: Add SMP application issues section Thu, 02 Feb 2017 08:43:47 GMT Sebastian Huber [7b1c63c] * c-user/symmetric_multiprocessing_services.rst (modified) * common/refs.bib (modified) c-user: Update clustered scheduling Wed, 01 Feb 2017 08:48:03 GMT Sebastian Huber [3966353] * common/conf.py (modified) Do not show page references after internal links Wed, 01 Feb 2017 06:50:59 GMT Sebastian Huber [5dcebd4] * common/refs.bib (modified) Fix refs.bib entries Tue, 31 Jan 2017 12:27:08 GMT Sebastian Huber [8add179] * c-user/key_concepts.rst (modified) * c-user/semaphore_manager.rst (modified) * common/refs.bib (modified) c-user: Add Key concept locking protocols Update #2412. Update #2556. Tue, 31 Jan 2017 11:59:08 GMT Sebastian Huber [938c49e] * c-user/rate_monotonic_manager.rst (modified) * common/refs.bib (modified) Fix refs.bib entry Mon, 30 Jan 2017 12:51:57 GMT Sebastian Huber [a17535d] * c-user/conf.py (modified) * c-user/key_concepts.rst (modified) * common/latex.py (modified) c-user: Add timer and timeouts key concept Update #2554. Mon, 30 Jan 2017 07:11:37 GMT Sebastian Huber [73ad65d] * common/refs.bib (modified) refs.bib: Add URL Thu, 26 Jan 2017 13:48:33 GMT Kuan-Hsun Chen [c660173] * c-user/rate_monotonic_manager.rst (modified) * common/refs.bib (modified) c-user: Update overrun handling related functions and structure ... Wed, 25 Jan 2017 07:36:23 GMT Sebastian Huber [0456ee7] * common/refs.bib (modified) Fix some reference titles Wed, 25 Jan 2017 07:26:39 GMT Sebastian Huber [f5e8e80] * common/refs.bib (modified) Sort references Tue, 17 Jan 2017 09:39:08 GMT Sebastian Huber [97e1553] * c-user/conf.py (modified) * c-user/index.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/zreferences.rst (added) * common/refs.bib (added) * cpu-supplement/conf.py (modified) * cpu-supplement/index.rst (modified) * cpu-supplement/port.rst (modified) * cpu-supplement/zreferences.rst (added) c-user: Add support for references via bibtex ... Thu, 12 Jan 2017 02:20:48 GMT Chris Johns [7956bbf] * common/coverpage/static/rtems/js/catalogue.js (modified) coverpage: Remove used function. Thu, 12 Jan 2017 02:18:43 GMT Chris Johns [321d20a] * common/coverpage/coverpage.js (modified) * common/coverpage/static/rtems/js/catalogue.js (modified) coverpage: Make showing the table conditional. Thu, 12 Jan 2017 02:11:34 GMT Chris Johns [bceb286] * common/coverpage/static/img/Adobe_PDF_file_icon_32x32.png (moved) * common/coverpage/static/img/html-xxl.png (moved) * common/coverpage/static/rtems/js/catalogue.js (modified) coverpage: Rename the static images directory to match bootstrap. Thu, 12 Jan 2017 02:07:13 GMT Chris Johns [9eb8a43] * common/coverpage/static/rtems/js/catalogue.js (modified) coverpage: Fix the catalogue table id. Thu, 12 Jan 2017 01:55:15 GMT Chris Johns [049097f] * common/coverpage/coverpage.html (moved) * common/coverpage/coverpage.js (moved) * common/coverpage/static/css/bootstrap.min.css (moved) * common/coverpage/static/css/bootstrap.min.css.map (added) * common/coverpage/static/fonts/glyphicons-halflings-regular.woff (added) * common/coverpage/static/images/Adobe_PDF_file_icon_32x32.png (moved) * common/coverpage/static/images/html-xxl.png (moved) * common/coverpage/static/js/bloodhound.js (moved) * common/coverpage/static/js/bootstrap.min.js (moved) * common/coverpage/static/js/jquery.min.js (moved) * common/coverpage/static/rtems/css/rtems.css (moved) * common/coverpage/static/rtems/image/rtemslogo.png (moved) * common/coverpage/static/rtems/js/catalogue.js (moved) * wscript (modified) coverpage: Update the coverpage to have the table collapse. Add ... Thu, 12 Jan 2017 01:24:46 GMT Justin Powell [876035b] * common/conf.py (modified) conf.py: Fix build_date() to append correct suffix on all days. Wed, 11 Jan 2017 06:04:02 GMT Chris Johns [2591ca6] * common/html-coverpage/coverpage.html (moved) * common/html-coverpage/coverpage.js (added) * common/html-coverpage/static/rtems/js/catalogue.js (modified) * wscript (modified) html: Embed the catalogue XML in JS. The is to work around a ... Wed, 11 Jan 2017 04:50:59 GMT Chris Johns [ecf82d1] * common/html-coverpage/index.html (added) * common/html-coverpage/static/css/bootstrap.min.css (added) * common/html-coverpage/static/images/Adobe_PDF_file_icon_32x32.png (added) * common/html-coverpage/static/images/html-xxl.png (added) * common/html-coverpage/static/js/bloodhound.js (added) * common/html-coverpage/static/js/bootstrap.min.js (added) * common/html-coverpage/static/js/jquery.min.js (added) * common/html-coverpage/static/rtems/css/rtems.css (added) * common/html-coverpage/static/rtems/image/rtemslogo.png (added) * common/html-coverpage/static/rtems/js/catalogue.js (added) * wscript (modified) html: Add support for an HTML cover page for releases. Tue, 10 Jan 2017 11:34:47 GMT Chris Johns [9aa52b9] * common/waf.py (modified) * wscript (modified) waf: Add a title to the XML Catalogue. Mon, 09 Jan 2017 23:11:05 GMT Chris Johns [782b4fe] * common/waf.py (modified) * wscript (modified) waf: Improved XML Catalogue generator. Mon, 09 Jan 2017 12:13:02 GMT Chris Johns [1a9b02e] * common/waf.py (modified) * wscript (modified) waf: Create an XML Catalogue. Wed, 09 Nov 2016 06:08:05 GMT Chris Johns [9330bfb] * README.txt (modified) * common/latex.py (modified) * common/waf.py (modified) waf: Users without the extra fonts need to use '--disable-extra- ... Wed, 09 Nov 2016 00:41:32 GMT Chris Johns [a91dd5c] * common/rtemsstyle.sty (modified) latex: Increase the depth of subsections. Tue, 08 Nov 2016 05:08:54 GMT Chris Johns [227aaea] * common/latex.py (modified) waf: Get a copy of the optional packages. Tue, 08 Nov 2016 04:58:58 GMT Chris Johns [2fdbc98] * common/latex.py (modified) * common/latex/rtemsextrafonts-null.sty (added) * common/latex/rtemsextrafonts.sty (added) * common/rtemsstyle.sty (modified) * common/waf.py (modified) waf: Use the good fonts if installed. Tue, 08 Nov 2016 04:26:25 GMT Chris Johns [daea85e] * common/conf.py (modified) * common/latex.py (modified) * common/rtemsstyle.sty (modified) pdf: Format lists for directives to sit on the next line. Mon, 07 Nov 2016 00:18:04 GMT Chris Johns [5a7280a] * common/latex.py (modified) * common/latex/inconsolata.sty (deleted) * common/latex/lato.sty (deleted) * common/rtemsstyle.sty (modified) PDF: Do not use lato and inconsolata fonts. Not widely supported. Sun, 06 Nov 2016 23:33:17 GMT Chris Johns [ea91103] * common/latex.py (modified) waf: Add a program test for pygmentize. Sun, 06 Nov 2016 22:25:24 GMT Christian Mauderer [b6272bb] * common/latex.py (modified) waf: Fix ''NoneType' object is not iterable' Sun, 06 Nov 2016 01:40:41 GMT Chris Johns [25c0a23] * common/latex.py (modified) waf: Fix the host version check. Sun, 06 Nov 2016 01:02:47 GMT Chris Johns [8330198] * common/latex.py (added) * common/latex/capt-of.sty (added) * common/latex/environ.sty (added) * common/latex/eqparbox.sty (added) * common/latex/ifplatform.sty (added) * common/latex/inconsolata.sty (added) * common/latex/lato.sty (added) * common/latex/slantsc.sty (added) * common/latex/trimspaces.sty (added) * common/latex/upquote.sty (added) * common/waf.py (modified) waf: Add support to handle missing Latex packages on hosts they are ... Fri, 04 Nov 2016 05:22:42 GMT Chris Johns [74194f7] * README.txt (modified) * common/waf.py (modified) waf: Check for texlive packages and report an error is not found. Thu, 03 Nov 2016 21:44:37 GMT Chris Johns [9024cfb] * common/waf.py (modified) waf: Fix the bnode issue when building in a manual directory. Thu, 03 Nov 2016 04:22:49 GMT Chris Johns [6207c37] * common/waf.py (modified) waf: Use separate doctrees so avoid sphinx clashes. Thu, 03 Nov 2016 03:42:34 GMT Chris Johns [d3226d3] * common/rtemsstyle.sty (modified) pdf: Make the copyright the same as the html. Thu, 03 Nov 2016 03:41:39 GMT Chris Johns [64a3db7] * common/conf.py (modified) conf: Make the build date use a nicer day format.
