# # ChangeLog for c-user/initialization.rst in rtems-docs # # Generated by Trac 1.2.1.dev0 # 06/02/24 09:38:54 Mon, 30 Jan 2017 13:44:01 GMT Sebastian Huber [e07e376] * c-user/initialization.rst (modified) c-user: Update initialization Update #2692. Fri, 09 Dec 2016 12:01:57 GMT Sebastian Huber [6fa32c0] * c-user/fatal_error.rst (modified) * c-user/initialization.rst (modified) * c-user/linker_sets.rst (modified) Update Initialization Manager chapter Update #2408. Fri, 09 Dec 2016 09:55:29 GMT Sebastian Huber [00ffe1f] * c-user/fatal_error.rst (modified) * c-user/initialization.rst (modified) * c-user/user_extensions.rst (modified) Improve fatal error chapter Update #2825. Wed, 09 Nov 2016 00:42:10 GMT Chris Johns [4da4a15] * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/example_application.rst (modified) * c-user/fatal_error.rst (modified) * c-user/glossary.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/preface.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) c-user: Fix header levels. Minor fixes. Tue, 08 Nov 2016 04:26:50 GMT Chris Johns [53bb72e] * c-user/barrier_manager.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/fatal_error.rst (modified) * c-user/index.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/partition_manager.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) c-user: Format the directives as descriptions. This change combined ... Thu, 03 Nov 2016 05:58:08 GMT Chris Johns [72a62ad] * bsp-howto/ada95_interrupt.rst (moved) * bsp-howto/analog.rst (moved) * bsp-howto/ata.rst (moved) * bsp-howto/clock.rst (moved) * bsp-howto/command.rst (moved) * bsp-howto/conf.py (moved) * bsp-howto/console.rst (moved) * bsp-howto/discrete.rst (moved) * bsp-howto/frame_buffer.rst (moved) * bsp-howto/ide_controller.rst (moved) * bsp-howto/index.rst (moved) * bsp-howto/initilization_code.rst (moved) * bsp-howto/linker_script.rst (moved) * bsp-howto/makefiles.rst (moved) * bsp-howto/miscellanous_support.rst (moved) * bsp-howto/networking.rst (moved) * bsp-howto/non_volatile_memory.rst (moved) * bsp-howto/preface.rst (moved) * bsp-howto/real_time_clock.rst (moved) * bsp-howto/shared_memory_support.rst (moved) * bsp-howto/target_dependant_files.rst (moved) * bsp-howto/timer.rst (moved) * bsp-howto/wscript (moved) * c-user/barrier_manager.rst (moved) * c-user/board_support_packages.rst (moved) * c-user/chains.rst (moved) * c-user/clock_manager.rst (moved) * c-user/conf.py (moved) * c-user/configuring_a_system.rst (moved) * c-user/constant_bandwidth_server.rst (moved) * c-user/cpu_usage_statistics.rst (moved) * c-user/directive_status_codes.rst (moved) * c-user/dual_ports_memory_manager.rst (moved) * c-user/event_manager.rst (moved) * c-user/example_application.rst (moved) * c-user/fatal_error.rst (moved) * c-user/glossary.rst (moved) * c-user/index.rst (moved) * c-user/initialization.rst (moved) * c-user/interrupt_manager.rst (moved) * c-user/io_manager.rst (moved) * c-user/key_concepts.rst (moved) * c-user/linker_sets.rst (moved) * c-user/message_manager.rst (moved) * c-user/multiprocessing.rst (moved) * c-user/object_services.rst (moved) * c-user/overview.rst (moved) * c-user/partition_manager.rst (moved) * c-user/pci_library.rst (moved) * c-user/preface.rst (moved) * c-user/rate_monotonic_manager.rst (moved) * c-user/red_black_trees.rst (moved) * c-user/region_manager.rst (moved) * c-user/rtems_data_types.rst (moved) * c-user/scheduling_concepts.rst (moved) * c-user/semaphore_manager.rst (moved) * c-user/signal_manager.rst (moved) * c-user/stack_bounds_checker.rst (moved) * c-user/symmetric_multiprocessing_services.rst (moved) * c-user/task_manager.rst (moved) * c-user/timer_manager.rst (moved) * c-user/timespec_helpers.rst (moved) * c-user/user_extensions.rst (moved) * c-user/wscript (moved) * cpu-supplement/altera_nios_ii.rst (moved) * cpu-supplement/arm.rst (moved) * cpu-supplement/atmel_avr.rst (moved) * cpu-supplement/blackfin.rst (moved) * cpu-supplement/command.rst (moved) * cpu-supplement/conf.py (moved) * cpu-supplement/ephiphany.rst (moved) * cpu-supplement/index.rst (moved) * cpu-supplement/intel_amd_x86.rst (moved) * cpu-supplement/lattice_micro32.rst (moved) * cpu-supplement/m68xxx_and_coldfire.rst (moved) * cpu-supplement/mips.rst (moved) * cpu-supplement/openrisc_1000.rst (moved) * cpu-supplement/port.rst (moved) * cpu-supplement/powerpc.rst (moved) * cpu-supplement/preface.rst (moved) * cpu-supplement/renesas_m32c.rst (moved) * cpu-supplement/sparc.rst (moved) * cpu-supplement/sparc64.rst (moved) * cpu-supplement/superh.rst (moved) * cpu-supplement/wscript (moved) * cpu-supplement/xilinx_microblaze.rst (moved) * posix-users/clock.rst (moved) * posix-users/command.rst (moved) * posix-users/condition_variable.rst (moved) * posix-users/conf.py (moved) * posix-users/device_and_class_specific.rst (moved) * posix-users/files_and_directory.rst (moved) * posix-users/index.rst (moved) * posix-users/input_and_output.rst (moved) * posix-users/key.rst (moved) * posix-users/language_specific_services.rst (moved) * posix-users/memory_managment.rst (moved) * posix-users/message_passing.rst (moved) * posix-users/mutex.rst (moved) * posix-users/preface.rst (moved) * posix-users/process_creation_and_execution.rst (moved) * posix-users/process_environment.rst (moved) * posix-users/scheduler.rst (moved) * posix-users/semaphore.rst (moved) * posix-users/services_provided_by_c.rst (moved) * posix-users/services_provided_by_math.rst (moved) * posix-users/signal.rst (moved) * posix-users/status_of_implementation.rst (moved) * posix-users/system_database.rst (moved) * posix-users/thread.rst (moved) * posix-users/thread_cancellation.rst (moved) * posix-users/timer.rst (moved) * posix-users/wscript (moved) * posix1003-1/clocks_and_timers.rst (moved) * posix1003-1/command.rst (moved) * posix1003-1/compliance_summary.rst (moved) * posix1003-1/conf.py (moved) * posix1003-1/data_interchange_format.rst (moved) * posix1003-1/device_and_class_specific.rst (moved) * posix1003-1/execution_scheduling.rst (moved) * posix1003-1/files_and_directories.rst (moved) * posix1003-1/general.rst (moved) * posix1003-1/index.rst (moved) * posix1003-1/input_and_output.rst (moved) * posix1003-1/language_specific_services.rst (moved) * posix1003-1/memory_managment.rst (moved) * posix1003-1/message_passing.rst (moved) * posix1003-1/posix1003_1.rst (moved) * posix1003-1/preface.rst (moved) * posix1003-1/process_environment.rst (moved) * posix1003-1/process_primitives.rst (moved) * posix1003-1/synchronization.rst (moved) * posix1003-1/system_database.rst (moved) * posix1003-1/terminology.rst (moved) * posix1003-1/thread_cancellation.rst (moved) * posix1003-1/thread_managment.rst (moved) * posix1003-1/thread_specific_data.rst (moved) * posix1003-1/wscript (moved) * wscript (modified) Rename all manuals with an _ to have a -. It helps released naming of ...
