# # ChangeLog for c-user/glossary.rst in rtems-docs # # Generated by Trac 1.2.1.dev0 # 05/20/24 06:49:40 Tue, 25 Feb 2020 09:55:31 GMT Sebastian Huber [732c570] * c-user/glossary.rst (modified) c-user: Canonicalize two glossary acronyms Add :term: text roles to ... Thu, 09 Jan 2020 12:22:06 GMT Sebastian Huber [03facda] * c-user/glossary.rst (modified) c-user: Rework glossary Define exactly one term per definition. ... Wed, 09 Jan 2019 15:14:06 GMT Sebastian Huber [e52906b] * book/index_book.rst (modified) * bsp-howto/ada95_interrupt.rst (modified) * bsp-howto/ata.rst (modified) * bsp-howto/clock.rst (modified) * bsp-howto/command.rst (modified) * bsp-howto/console.rst (modified) * bsp-howto/frame_buffer.rst (modified) * bsp-howto/getentropy.rst (modified) * bsp-howto/i2c.rst (modified) * bsp-howto/ide_controller.rst (modified) * bsp-howto/index.rst (modified) * bsp-howto/initilization_code.rst (modified) * bsp-howto/linker_script.rst (modified) * bsp-howto/miscellanous_support.rst (modified) * bsp-howto/networking.rst (modified) * bsp-howto/preface.rst (modified) * bsp-howto/real_time_clock.rst (modified) * bsp-howto/shared_memory_support.rst (modified) * bsp-howto/spi.rst (modified) * bsp-howto/target_dependant_files.rst (modified) * bsp-howto/timer.rst (modified) * c-user/ada_support.rst (modified) * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/example_application.rst (modified) * c-user/fatal_error.rst (modified) * c-user/glossary.rst (modified) * c-user/index.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/preface.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/self_contained_objects.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) * cpu-supplement/altera_nios_ii.rst (modified) * cpu-supplement/arm.rst (modified) * cpu-supplement/atmel_avr.rst (modified) * cpu-supplement/blackfin.rst (modified) * cpu-supplement/ephiphany.rst (modified) * cpu-supplement/index.rst (modified) * cpu-supplement/intel_amd_x86.rst (modified) * cpu-supplement/lattice_micro32.rst (modified) * cpu-supplement/m68xxx_and_coldfire.rst (modified) * cpu-supplement/mips.rst (modified) * cpu-supplement/openrisc_1000.rst (modified) * cpu-supplement/port.rst (modified) * cpu-supplement/powerpc.rst (modified) * cpu-supplement/preface.rst (modified) * cpu-supplement/renesas_m32c.rst (modified) * cpu-supplement/riscv.rst (modified) * cpu-supplement/sparc.rst (modified) * cpu-supplement/sparc64.rst (modified) * cpu-supplement/sparc_v8_stacks_regwin.rst (modified) * cpu-supplement/superh.rst (modified) * cpu-supplement/xilinx_microblaze.rst (modified) * develenv/command.rst (modified) * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/introduction.rst (modified) * develenv/sample.rst (modified) * develenv/utilities.rst (modified) * eclipse/glossary.rst (modified) * eclipse/index.rst (modified) * eclipse/overview.rst (modified) * eclipse/rtems.rst (modified) * eng/appendix-a.rst (modified) * eng/change-management.rst (modified) * eng/change-reports.rst (modified) * eng/coding-80cols.rst (modified) * eng/coding-conventions.rst (modified) * eng/coding-deprecating.rst (modified) * eng/coding-doxygen-bsp.rst (modified) * eng/coding-doxygen.rst (modified) * eng/coding-file-hdr.rst (modified) * eng/coding-gen-patch.rst (modified) * eng/coding-naming.rst (modified) * eng/coding.rst (modified) * eng/index.rst (modified) * eng/issue-tracking.rst (modified) * eng/license-requirements.rst (modified) * eng/management.rst (modified) * eng/preface.rst (modified) * eng/prequalification.rst (modified) * eng/release-mgmt.rst (modified) * eng/stakeholders.rst (modified) * eng/test-plan.rst (modified) * eng/test-suites.rst (modified) * eng/tester.rst (modified) * eng/users-manuals.rst (modified) * eng/vc-authors.rst (modified) * eng/vc-users.rst (modified) * eng/vdd-generation.rst (modified) * eng/why-contribute.rst (modified) * filesystem/call_development.rst (modified) * filesystem/command_and_variable.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/index.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * filesystem/trivial_ftp.rst (modified) * networking/command.rst (modified) * networking/dec_21140.rst (modified) * networking/index.rst (modified) * networking/network_servers.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/command.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/index.rst (modified) * porting/interrupts.rst (modified) * porting/miscellanous.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix-compliance/glossary.rst (modified) * posix-compliance/index.rst (modified) * posix-compliance/preface.rst (modified) * posix-compliance/standards.rst (modified) * posix-users/clock.rst (modified) * posix-users/command.rst (modified) * posix-users/condition_variable.rst (modified) * posix-users/devctl.rst (modified) * posix-users/device_and_class_specific.rst (modified) * posix-users/files_and_directory.rst (modified) * posix-users/index.rst (modified) * posix-users/input_and_output.rst (modified) * posix-users/key.rst (modified) * posix-users/language_specific_services.rst (modified) * posix-users/memory_managment.rst (modified) * posix-users/message_passing.rst (modified) * posix-users/mutex.rst (modified) * posix-users/preface.rst (modified) * posix-users/process_creation_and_execution.rst (modified) * posix-users/process_environment.rst (modified) * posix-users/scheduler.rst (modified) * posix-users/semaphore.rst (modified) * posix-users/services_provided_by_c.rst (modified) * posix-users/services_provided_by_math.rst (modified) * posix-users/signal.rst (modified) * posix-users/status_of_implementation.rst (modified) * posix-users/system_database.rst (modified) * posix-users/thread.rst (modified) * posix-users/thread_cancellation.rst (modified) * posix-users/timer.rst (modified) * rsb/bug-reporting.rst (modified) * rsb/building-tools-and-rtems.rst (modified) * rsb/commands.rst (modified) * rsb/configuration.rst (modified) * rsb/cross-canadian-cross.rst (modified) * rsb/index.rst (modified) * rsb/project-sets.rst (modified) * rsb/source-builder.rst (modified) * rsb/third-party-packages.rst (modified) * rtemsconfig/index.rst (modified) * rtemsconfig/option.rst (modified) * rtemsconfig/rtemsconfig.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * user/apps/index.rst (modified) * user/bsp/index.rst (modified) * user/bsps/bsps-aarch64.rst (modified) * user/bsps/bsps-arm.rst (modified) * user/bsps/bsps-bfin.rst (modified) * user/bsps/bsps-epiphany.rst (modified) * user/bsps/bsps-i386.rst (modified) * user/bsps/bsps-lm32.rst (modified) * user/bsps/bsps-m68k.rst (modified) * user/bsps/bsps-microblaze.rst (modified) * user/bsps/bsps-mips.rst (modified) * user/bsps/bsps-moxie.rst (modified) * user/bsps/bsps-nios2.rst (modified) * user/bsps/bsps-or1k.rst (modified) * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-riscv.rst (modified) * user/bsps/bsps-sh.rst (modified) * user/bsps/bsps-sparc.rst (modified) * user/bsps/bsps-sparc64.rst (modified) * user/bsps/bsps-v850.rst (modified) * user/bsps/bsps-x86_64.rst (modified) * user/bsps/index.rst (modified) * user/ecosys/index.rst (modified) * user/exe/debugging.rst (modified) * user/exe/executables.rst (modified) * user/exe/execution.rst (modified) * user/exe/index.rst (modified) * user/exe/initialization.rst (modified) * user/glossary/index.rst (modified) * user/hardware/architectures.rst (modified) * user/hardware/bsps.rst (modified) * user/hardware/index.rst (modified) * user/hardware/targets.rst (modified) * user/hardware/tiers.rst (modified) * user/hosts/index.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/index.rst (modified) * user/installation/developer.rst (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (modified) * user/installation/prefixes-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/overview/index.rst (modified) * user/start/index.rst (modified) * user/support/index.rst (modified) * user/testing/configuration.rst (modified) * user/testing/consoles.rst (modified) * user/testing/gdb-jtag.rst (modified) * user/testing/index.rst (modified) * user/testing/simulation.rst (modified) * user/testing/tests.rst (modified) * user/testing/tftp.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/index.rst (modified) * user/tools/linker.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * user/tracing/captureengine.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/index.rst (modified) * user/tracing/introduction.rst (modified) * user/tracing/tracelinker.rst (modified) Simplify SPDX-License-Identifier comment Mon, 30 Apr 2018 13:02:00 GMT Sebastian Huber [06519a5] * c-user/glossary.rst (modified) c-user: Fix typo Fri, 03 Feb 2017 11:54:44 GMT Sebastian Huber [1f3c22e] * c-user/configuring_a_system.rst (modified) * c-user/glossary.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) c-user: Update SMP introduction Fri, 03 Feb 2017 10:55:29 GMT Sebastian Huber [90a3c41] * c-user/glossary.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) c-user: Add TAS and TTAS terms Thu, 02 Feb 2017 13:07:53 GMT Sebastian Huber [785c02f] * c-user/glossary.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * images/c_user/smplock01fair-t4240.pdf (added) * images/c_user/smplock01fair-t4240.png (added) * images/c_user/smplock01perf-t4240.pdf (added) * images/c_user/smplock01perf-t4240.png (added) c-user: Add SMP low-level synchronization Thu, 02 Feb 2017 10:22:59 GMT Sebastian Huber [3e005fe] * c-user/glossary.rst (modified) * c-user/key_concepts.rst (modified) c-user: Use sphinx glossary support Terms can be referenced via ... Thu, 02 Feb 2017 09:46:05 GMT Sebastian Huber [b033e39] * c-user/glossary.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * common/refs.bib (modified) c-user: Add SMP application issues section Wed, 01 Feb 2017 12:38:41 GMT Sebastian Huber [a0d2eee] * c-user/configuring_a_system.rst (modified) * c-user/fatal_error.rst (modified) * c-user/glossary.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) Use "in X config..." instead of "on X config..." Tue, 31 Jan 2017 10:15:56 GMT Sebastian Huber [aaff696] * c-user/glossary.rst (modified) * c-user/key_concepts.rst (modified) c-user: Add key concept thread queues Update #2556. Mon, 19 Dec 2016 13:46:33 GMT Sebastian Huber [09078e0] * c-user/glossary.rst (modified) Do not mention obsolete Giant lock Close #2555. Wed, 09 Nov 2016 00:42:10 GMT Chris Johns [4da4a15] * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/example_application.rst (modified) * c-user/fatal_error.rst (modified) * c-user/glossary.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/preface.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) c-user: Fix header levels. Minor fixes. Wed, 02 Nov 2016 07:13:31 GMT Sebastian Huber [3a58bff] * c-user/board_support_packages.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/glossary.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) Update due to clock manager and driver changes Thu, 03 Nov 2016 05:58:08 GMT Chris Johns [72a62ad] * bsp-howto/ada95_interrupt.rst (moved) * bsp-howto/analog.rst (moved) * bsp-howto/ata.rst (moved) * bsp-howto/clock.rst (moved) * bsp-howto/command.rst (moved) * bsp-howto/conf.py (moved) * bsp-howto/console.rst (moved) * bsp-howto/discrete.rst (moved) * bsp-howto/frame_buffer.rst (moved) * bsp-howto/ide_controller.rst (moved) * bsp-howto/index.rst (moved) * bsp-howto/initilization_code.rst (moved) * bsp-howto/linker_script.rst (moved) * bsp-howto/makefiles.rst (moved) * bsp-howto/miscellanous_support.rst (moved) * bsp-howto/networking.rst (moved) * bsp-howto/non_volatile_memory.rst (moved) * bsp-howto/preface.rst (moved) * bsp-howto/real_time_clock.rst (moved) * bsp-howto/shared_memory_support.rst (moved) * bsp-howto/target_dependant_files.rst (moved) * bsp-howto/timer.rst (moved) * bsp-howto/wscript (moved) * c-user/barrier_manager.rst (moved) * c-user/board_support_packages.rst (moved) * c-user/chains.rst (moved) * c-user/clock_manager.rst (moved) * c-user/conf.py (moved) * c-user/configuring_a_system.rst (moved) * c-user/constant_bandwidth_server.rst (moved) * c-user/cpu_usage_statistics.rst (moved) * c-user/directive_status_codes.rst (moved) * c-user/dual_ports_memory_manager.rst (moved) * c-user/event_manager.rst (moved) * c-user/example_application.rst (moved) * c-user/fatal_error.rst (moved) * c-user/glossary.rst (moved) * c-user/index.rst (moved) * c-user/initialization.rst (moved) * c-user/interrupt_manager.rst (moved) * c-user/io_manager.rst (moved) * c-user/key_concepts.rst (moved) * c-user/linker_sets.rst (moved) * c-user/message_manager.rst (moved) * c-user/multiprocessing.rst (moved) * c-user/object_services.rst (moved) * c-user/overview.rst (moved) * c-user/partition_manager.rst (moved) * c-user/pci_library.rst (moved) * c-user/preface.rst (moved) * c-user/rate_monotonic_manager.rst (moved) * c-user/red_black_trees.rst (moved) * c-user/region_manager.rst (moved) * c-user/rtems_data_types.rst (moved) * c-user/scheduling_concepts.rst (moved) * c-user/semaphore_manager.rst (moved) * c-user/signal_manager.rst (moved) * c-user/stack_bounds_checker.rst (moved) * c-user/symmetric_multiprocessing_services.rst (moved) * c-user/task_manager.rst (moved) * c-user/timer_manager.rst (moved) * c-user/timespec_helpers.rst (moved) * c-user/user_extensions.rst (moved) * c-user/wscript (moved) * cpu-supplement/altera_nios_ii.rst (moved) * cpu-supplement/arm.rst (moved) * cpu-supplement/atmel_avr.rst (moved) * cpu-supplement/blackfin.rst (moved) * cpu-supplement/command.rst (moved) * cpu-supplement/conf.py (moved) * cpu-supplement/ephiphany.rst (moved) * cpu-supplement/index.rst (moved) * cpu-supplement/intel_amd_x86.rst (moved) * cpu-supplement/lattice_micro32.rst (moved) * cpu-supplement/m68xxx_and_coldfire.rst (moved) * cpu-supplement/mips.rst (moved) * cpu-supplement/openrisc_1000.rst (moved) * cpu-supplement/port.rst (moved) * cpu-supplement/powerpc.rst (moved) * cpu-supplement/preface.rst (moved) * cpu-supplement/renesas_m32c.rst (moved) * cpu-supplement/sparc.rst (moved) * cpu-supplement/sparc64.rst (moved) * cpu-supplement/superh.rst (moved) * cpu-supplement/wscript (moved) * cpu-supplement/xilinx_microblaze.rst (moved) * posix-users/clock.rst (moved) * posix-users/command.rst (moved) * posix-users/condition_variable.rst (moved) * posix-users/conf.py (moved) * posix-users/device_and_class_specific.rst (moved) * posix-users/files_and_directory.rst (moved) * posix-users/index.rst (moved) * posix-users/input_and_output.rst (moved) * posix-users/key.rst (moved) * posix-users/language_specific_services.rst (moved) * posix-users/memory_managment.rst (moved) * posix-users/message_passing.rst (moved) * posix-users/mutex.rst (moved) * posix-users/preface.rst (moved) * posix-users/process_creation_and_execution.rst (moved) * posix-users/process_environment.rst (moved) * posix-users/scheduler.rst (moved) * posix-users/semaphore.rst (moved) * posix-users/services_provided_by_c.rst (moved) * posix-users/services_provided_by_math.rst (moved) * posix-users/signal.rst (moved) * posix-users/status_of_implementation.rst (moved) * posix-users/system_database.rst (moved) * posix-users/thread.rst (moved) * posix-users/thread_cancellation.rst (moved) * posix-users/timer.rst (moved) * posix-users/wscript (moved) * posix1003-1/clocks_and_timers.rst (moved) * posix1003-1/command.rst (moved) * posix1003-1/compliance_summary.rst (moved) * posix1003-1/conf.py (moved) * posix1003-1/data_interchange_format.rst (moved) * posix1003-1/device_and_class_specific.rst (moved) * posix1003-1/execution_scheduling.rst (moved) * posix1003-1/files_and_directories.rst (moved) * posix1003-1/general.rst (moved) * posix1003-1/index.rst (moved) * posix1003-1/input_and_output.rst (moved) * posix1003-1/language_specific_services.rst (moved) * posix1003-1/memory_managment.rst (moved) * posix1003-1/message_passing.rst (moved) * posix1003-1/posix1003_1.rst (moved) * posix1003-1/preface.rst (moved) * posix1003-1/process_environment.rst (moved) * posix1003-1/process_primitives.rst (moved) * posix1003-1/synchronization.rst (moved) * posix1003-1/system_database.rst (moved) * posix1003-1/terminology.rst (moved) * posix1003-1/thread_cancellation.rst (moved) * posix1003-1/thread_managment.rst (moved) * posix1003-1/thread_specific_data.rst (moved) * posix1003-1/wscript (moved) * wscript (modified) Rename all manuals with an _ to have a -. It helps released naming of ...
