@f6b4337
01/19/21 06:24:45 |
Sebastian Huber |
c-user: Generate interrupt manager documentation
The documentation is …
@de8fe65
04/27/21 08:58:17 |
Sebastian Huber |
c-user: Constify timer fire when directives
Update #4392.
@b5fe4f0
04/23/21 19:09:53 |
Sebastian Huber |
c-user: Fix wording for "home scheduler"
@3fa9ed4
04/26/21 07:56:41 |
Sebastian Huber |
eng: Allow multiple interface references
Update #3715.
@6ee9317
04/22/21 11:45:24 |
Sebastian Huber |
c-user: Use glossary term
@199cc8e
04/15/21 20:28:36 |
vijay |
legacy-networking: Add note with build instructions for rtems-net-legacy
@63a9e0c
01/15/21 13:08:09 |
Sebastian Huber |
c-user: Generate message manager documentation
The documentation is a …
@61cbbd2
01/19/21 06:24:57 |
Sebastian Huber |
c-user: Generate rate-monotonic manager docs
@2ce0fe2
04/10/21 19:15:25 |
niteesh.gs |
user/bsps/arm/beagle: Update i2c initialization instructions
The new …
@f6f3fdc
04/22/21 15:10:45 |
Gedare Bloom |
c-user: fix broken definition in rate-monotonic background.
@eb45e22
04/22/21 11:51:01 |
Sebastian Huber |
c-user: Mention timer server fire directives
A timer may be also …
@29ce290
02/24/21 13:11:21 |
Sebastian Huber |
bsp-howto: Add target hash chapter
Update #4267.
@03fc1d6
04/21/21 12:52:45 |
Sebastian Huber |
c-user: Generate dual-ported memory manager docs
@a995620
04/21/21 11:55:27 |
Sebastian Huber |
c-user: Generate multiprocessing manager docs
@d946f30
04/21/21 08:50:00 |
Sebastian Huber |
c-user: Generate fatal error manager docs
@5a3cb76
04/21/21 08:49:36 |
Sebastian Huber |
c-user: Generate initialization manager docs
@dae5338
04/21/21 11:22:30 |
Sebastian Huber |
c-user: Add user extensions glossary terms
@86b48fb
04/21/21 07:34:24 |
Sebastian Huber |
c-user: Split up multiprocessing manager
This makes it easier to …
@62ca9c1
04/21/21 07:29:29 |
Sebastian Huber |
c-user: Split up fatal error manager
@f3262d4
04/21/21 07:19:27 |
Sebastian Huber |
c-user: Split up initialization manager
@9bf0184
04/16/21 06:57:44 |
Sebastian Huber |
c-user: Document rtems_semaphore_obtain() errors
Update #3993.
@14c9029
04/12/21 09:28:56 |
Sebastian Huber |
c-user: Add scheduler glossary terms
Add glossary terms which …
@ad03db3
04/07/21 20:30:21 |
joel |
posix-compliance: Use constant name for API spreadsheet.
@b43fe70
04/06/21 21:56:01 |
joel |
posix-compliance: Update tracking spreadsheet to v12
The new version …
@241cd06
04/07/21 05:11:46 |
Sebastian Huber |
c-user: Fix rtems_semaphore_release() docs
The directive returns …
@1f7be22
04/05/21 16:02:29 |
joel |
tools/boot-image.rst: Master Boot Record is MBR not MRB
@20893c5
03/19/21 14:27:21 |
christian.mauderer |
user/bsps: Add STM32H7 SDMMC driver
Update #4372
@998f875
03/23/21 20:02:22 |
vijay |
common/latex.py: use distro module for python3.5 and up
@22d213c
03/01/21 16:44:55 |
vijay |
networking: Rename to legacy networking
@6563262
03/29/21 19:12:10 |
oss |
User/BSPs/Beagle: Add JTAG debugger section
@357287c
03/25/21 15:18:10 |
Gedare Bloom |
start: provide more version guidance for gsoc
@cd7318c
03/20/21 18:54:59 |
idadelm |
start: Console output example updates
@1472f30f
03/20/21 18:54:58 |
idadelm |
app: Update command to configure app
@492cbea
03/20/21 18:54:57 |
idadelm |
bsp-build: Update manual bsp build command
@ce49332
03/20/21 18:54:56 |
idadelm |
tools: Update command to install toolsuite
@0a9288c
03/20/21 18:54:55 |
idadelm |
sourses: Update source download command
@ae11bc7
03/20/21 18:54:54 |
idadelm |
prefixes: Update installation prefix
@4476290
03/17/21 13:00:01 |
Sebastian Huber |
eng: Add example to action requirements how-to
Update #3715.
@b40e043
03/16/21 14:45:29 |
Sebastian Huber |
eng: Document expressions in action requirements
Update #3715.
@b580a6d
03/16/21 15:02:53 |
Sebastian Huber |
eng: Add build/appl config clauses to how-to
Update #3715.
@239644b
03/17/21 09:29:48 |
Sebastian Huber |
eng: Update EARS syntax
The document used the EARS syntax from 2009 …
@6659131
03/16/21 14:42:55 |
Sebastian Huber |
c-user: Remove obsolete constraint
@f2bbea6
03/16/21 14:42:31 |
Sebastian Huber |
c-user: Update semaphore example
Update #4346.
@a4755f6
03/16/21 18:30:59 |
idadelm |
eng/vc-users: Set up patch message with repo name
Added instructions …
@2c2c7de3
02/19/21 08:16:17 |
jan.sommer |
user/bsps: Mention fixed console baud rate for zynq
@bc0a857
03/11/21 06:52:27 |
Sebastian Huber |
eng: Clarify how-to for action requirements
Bring how-to in line with …
@0518d94
03/10/21 11:52:28 |
Sebastian Huber |
Update #3715.
@e05df28
03/08/21 09:19:07 |
Sebastian Huber |
Update #3715.
@a4b3019
03/08/21 07:15:54 |
Sebastian Huber |
eng: Add how-to for action requirements
Update #3715.
@7918ef8
03/08/21 07:15:24 |
Sebastian Huber |
c-user: Clarify constraints
@084a564
03/04/21 16:53:54 |
kinsey.moore |
user: Update ZynqMP QEMU BSP name
The ZynqMP QEMU BSPs have had _qemu …
@fcac22e
03/02/21 07:28:48 |
Sebastian Huber |
eng: Fix typo
Update #3715.
@c87d8c2
02/17/21 17:34:23 |
Sebastian Huber |
c-user: Generate signal manager documentation
@3afdebd
01/12/21 11:35:58 |
robin.mueller.m |
STM32H7 doc update
@2032382
02/03/21 17:31:34 |
Gedare Bloom |
common/waf: fix some typos
@4563bb6
02/03/21 17:24:09 |
Gedare Bloom |
common: use bibtex_bibfiles for newer bibtex
Closes #4229.
@a60c5b4
01/19/21 06:24:35 |
Sebastian Huber |
c-user: Generate clock manager documentation
@4aead84
01/19/21 06:25:27 |
Sebastian Huber |
c-user: Generate user extensions manager docs
@62718ad
01/18/21 07:51:42 |
Sebastian Huber |
c-user: Generate barrier manager documentation
@fd56f7e
09/29/20 14:44:14 |
Sebastian Huber |
c-user: Generate semaphore manager documentation
@6985800
02/10/21 15:51:25 |
Sebastian Huber |
c-user: Move deprecated/removed directives
@a1c5d68
01/15/21 13:08:16 |
Sebastian Huber |
c-user: Add control block acronyms
Update #3993.
@4e09c09
01/19/21 11:34:43 |
Sebastian Huber |
c-user: Add labels to the manager chapters
Update #3993.
@261491f
02/10/21 15:41:02 |
Sebastian Huber |
c-user: Clarify object services documentation
Unify the wording …
@e357ccf
02/10/21 15:41:02 |
Sebastian Huber |
c-user: Clarify IO manager documentation
Unify the wording across …
@45d3811
02/09/21 09:35:37 |
Sebastian Huber |
c-user: Clarify partition manager documentation
@775380c
01/20/21 12:58:28 |
Sebastian Huber |
c-user: Clarify event manager documentation
@4d9b0b4
02/03/21 05:31:29 |
Sebastian Huber |
c-user: Clarify timer manager documentation
@174444f
02/08/21 14:01:50 |
Sebastian Huber |
eng: Update test case item
Update #3715.
@3e1ac91
02/03/21 17:27:10 |
niteesh.gs |
user: remove old build system cmd
@66c9808
01/15/21 05:37:22 |
Sebastian Huber |
Unify the wording …
@95e2f93
02/02/21 13:42:21 |
Sebastian Huber |
Add a "Constraints" paragraph to the …
@221b61a
02/01/21 20:28:36 |
Gedare Bloom |
user: add guidance on version numbers to GSoC guide.
@ba633ec
01/25/21 05:58:10 |
Sebastian Huber |
Improve file header comment in generated files
@a08e672
11/27/20 08:13:56 |
Sebastian Huber |
eng: Add design group requirement item type
Update #3715.
@c3b4e18
01/14/21 15:18:00 |
kinsey.moore |
user: Update aarch64/xilinx-zynqmp Qemu command
The Xilinx ZynqMP BSP …
@58bf83e
12/22/20 06:17:43 |
Sebastian Huber |
user: Mention use of LLVM
@2cf3076
12/14/20 10:22:39 |
user/bsp/imxrt: Information for custom FDT
Update #4180
@171bbe0
12/01/20 09:58:51 |
shell: Document i2c and spi commands.
@265bee7
12/07/20 17:01:47 |
kinsey.moore |
user: Add aarch64/xilinx-zynqmp
@94abaa3
12/07/20 18:10:50 |
kinsey.moore |
user: Add A53 Qemu run instructions
@9c40761
12/07/20 18:10:26 |
kinsey.moore |
aarch64: Update interrupt details
@d716c79
12/02/20 07:17:12 |
Sebastian Huber |
c-user: Generate Timer Manager documentation
@dad89ce
11/24/20 12:41:35 |
Sebastian Huber |
c-user: Generate Object Services documentation
@66bcecf
12/02/20 07:29:56 |
Sebastian Huber |
c-user: Clarify invalid identifier descriptions
Update #3993.
@346bbe6
12/01/20 15:50:01 |
Sebastian Huber |
c-user: Clarify rtems_partition_delete()
Move the PTCB sentence to …
@29e6caa
12/01/20 15:33:33 |
Sebastian Huber |
c-user: Clarify rtems_partition_create()
The rtems_partition_create() …
@284e8d0
12/01/20 13:43:11 |
Sebastian Huber |
c-user: Fix format in Partition Manager
Update #3993.
@4b03ff7
11/12/20 06:41:18 |
Sebastian Huber |
eng: Add performance specification items
Add items to specify runtime …
@00b3444
11/20/20 09:35:46 |
Sebastian Huber |
c-user: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Document new …
@05f06aa
11/20/20 13:22:44 |
Sebastian Huber |
c-user: Split up object services
@f501682
11/17/20 10:56:31 |
user/bsps: Fix list in bsps-arm
Seems that some filenames haven't …
@e95d992
11/17/20 10:35:43 |
user/bsps: Add imxrt
Update #4180
@9291bbb
11/19/20 07:54:47 |
Sebastian Huber |
c-user: Update internal error list
@238789d
11/06/20 10:12:55 |
Sebastian Huber |
eng: Rework and clarify Doxygen Guidelines
@bbd8d4a
11/19/20 10:22:46 |
Sebastian Huber |
eng: Fix typo
Update #3715.
@0454ad7
11/12/20 09:36:32 |
Sebastian Huber |
eng: Simplify "Load" environment reporting
Report all runtime …
@cdbd72d
11/12/20 09:27:12 |
Sebastian Huber |
eng: Rename ValidCache? environment in FullCache?
This name better …
@530bc2b
10/12/20 13:53:05 |
Sebastian Huber |
c-user: Generate Partition Manager documentation
The manager …
@ec4dcc0
09/29/20 14:44:03 |
Sebastian Huber |
c-user: Generate Event Manager documentation
The manager …
