Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems-docs
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @03fc1d6   04/21/21 12:52:45 Sebastian Huber c-user: Generate dual-ported memory manager docs The documentation is …
(edit) @a995620   04/21/21 11:55:27 Sebastian Huber c-user: Generate multiprocessing manager docs The documentation is a …
(edit) @d946f30   04/21/21 08:50:00 Sebastian Huber c-user: Generate fatal error manager docs The documentation is a …
(edit) @5a3cb76   04/21/21 08:49:36 Sebastian Huber c-user: Generate initialization manager docs The documentation is a …
(edit) @dae5338   04/21/21 11:22:30 Sebastian Huber c-user: Add user extensions glossary terms
(edit) @86b48fb   04/21/21 07:34:24 Sebastian Huber c-user: Split up multiprocessing manager This makes it easier to …
(edit) @62ca9c1   04/21/21 07:29:29 Sebastian Huber c-user: Split up fatal error manager This makes it easier to …
(edit) @f3262d4   04/21/21 07:19:27 Sebastian Huber c-user: Split up initialization manager This makes it easier to …
(edit) @9bf0184   04/16/21 06:57:44 Sebastian Huber c-user: Document rtems_semaphore_obtain() errors Update #3993.
(edit) @14c9029   04/12/21 09:28:56 Sebastian Huber c-user: Add scheduler glossary terms Add glossary terms which …
(edit) @ad03db3   04/07/21 20:30:21 joel posix-compliance: Use constant name for API spreadsheet. …
(edit) @b43fe70   04/06/21 21:56:01 joel posix-compliance: Update tracking spreadsheet to v12 The new version …
(edit) @241cd06   04/07/21 05:11:46 Sebastian Huber c-user: Fix rtems_semaphore_release() docs The directive returns …
(edit) @1f7be22   04/05/21 16:02:29 joel tools/boot-image.rst: Master Boot Record is MBR not MRB
(edit) @20893c5   03/19/21 14:27:21 christian.mauderer user/bsps: Add STM32H7 SDMMC driver Update #4372
(edit) @998f875   03/23/21 20:02:22 vijay common/latex.py: use distro module for python3.5 and up
(edit) @22d213c   03/01/21 16:44:55 vijay networking: Rename to legacy networking
(edit) @6563262   03/29/21 19:12:10 oss User/BSPs/Beagle: Add JTAG debugger section
(edit) @357287c   03/25/21 15:18:10 Gedare Bloom start: provide more version guidance for gsoc
(edit) @cd7318c   03/20/21 18:54:59 idadelm start: Console output example updates
(edit) @1472f30f   03/20/21 18:54:58 idadelm app: Update command to configure app
(edit) @492cbea   03/20/21 18:54:57 idadelm bsp-build: Update manual bsp build command
(edit) @ce49332   03/20/21 18:54:56 idadelm tools: Update command to install toolsuite
(edit) @0a9288c   03/20/21 18:54:55 idadelm sourses: Update source download command
(edit) @ae11bc7   03/20/21 18:54:54 idadelm prefixes: Update installation prefix
(edit) @4476290   03/17/21 13:00:01 Sebastian Huber eng: Add example to action requirements how-to Update #3715.
(edit) @b40e043   03/16/21 14:45:29 Sebastian Huber eng: Document expressions in action requirements Update #3715.
(edit) @b580a6d   03/16/21 15:02:53 Sebastian Huber eng: Add build/appl config clauses to how-to Update #3715.
(edit) @239644b   03/17/21 09:29:48 Sebastian Huber eng: Update EARS syntax The document used the EARS syntax from 2009 …
(edit) @6659131   03/16/21 14:42:55 Sebastian Huber c-user: Remove obsolete constraint
(edit) @f2bbea6   03/16/21 14:42:31 Sebastian Huber c-user: Update semaphore example Update #4346.
(edit) @a4755f6   03/16/21 18:30:59 idadelm eng/vc-users: Set up patch message with repo name Added instructions …
(edit) @2c2c7de3   02/19/21 08:16:17 jan.sommer user/bsps: Mention fixed console baud rate for zynq
(edit) @bc0a857   03/11/21 06:52:27 Sebastian Huber eng: Clarify how-to for action requirements Bring how-to in line with …
(edit) @0518d94   03/10/21 11:52:28 Sebastian Huber eng: Clarify how-to for action requirements Update #3715.
(edit) @e05df28   03/08/21 09:19:07 Sebastian Huber eng: Clarify how-to for action requirements Update #3715.
(edit) @a4b3019   03/08/21 07:15:54 Sebastian Huber eng: Add how-to for action requirements Update #3715.
(edit) @7918ef8   03/08/21 07:15:24 Sebastian Huber c-user: Clarify constraints
(edit) @084a564   03/04/21 16:53:54 kinsey.moore user: Update ZynqMP QEMU BSP name The ZynqMP QEMU BSPs have had _qemu …
(edit) @fcac22e   03/02/21 07:28:48 Sebastian Huber eng: Fix typo Update #3715.
(edit) @c87d8c2   02/17/21 17:34:23 Sebastian Huber c-user: Generate signal manager documentation The documentation is a …
(edit) @3afdebd   01/12/21 11:35:58 robin.mueller.m STM32H7 doc update
(edit) @2032382   02/03/21 17:31:34 Gedare Bloom common/waf: fix some typos
(edit) @4563bb6   02/03/21 17:24:09 Gedare Bloom common: use bibtex_bibfiles for newer bibtex Closes #4229.
(edit) @a60c5b4   01/19/21 06:24:35 Sebastian Huber c-user: Generate clock manager documentation The documentation is a …
(edit) @4aead84   01/19/21 06:25:27 Sebastian Huber c-user: Generate user extensions manager docs The documentation is a …
(edit) @62718ad   01/18/21 07:51:42 Sebastian Huber c-user: Generate barrier manager documentation The documentation is a …
(edit) @fd56f7e   09/29/20 14:44:14 Sebastian Huber c-user: Generate semaphore manager documentation The documentation is …
(edit) @6985800   02/10/21 15:51:25 Sebastian Huber c-user: Move deprecated/removed directives This makes it easier to …
(edit) @a1c5d68   01/15/21 13:08:16 Sebastian Huber c-user: Add control block acronyms Update #3993.
(edit) @4e09c09   01/19/21 11:34:43 Sebastian Huber c-user: Add labels to the manager chapters Update #3993.
(edit) @261491f   02/10/21 15:41:02 Sebastian Huber c-user: Clarify object services documentation Unify the wording …
(edit) @e357ccf   02/10/21 15:41:02 Sebastian Huber c-user: Clarify IO manager documentation Unify the wording across …
(edit) @45d3811   02/09/21 09:35:37 Sebastian Huber c-user: Clarify partition manager documentation
(edit) @775380c   01/20/21 12:58:28 Sebastian Huber c-user: Clarify event manager documentation Unify the wording across …
(edit) @4d9b0b4   02/03/21 05:31:29 Sebastian Huber c-user: Clarify timer manager documentation Unify the wording across …
(edit) @174444f   02/08/21 14:01:50 Sebastian Huber eng: Update test case item Update #3715.
(edit) @3e1ac91   02/03/21 17:27:10 niteesh.gs user: remove old build system cmd
(edit) @66c9808   01/15/21 05:37:22 Sebastian Huber c-user: Clarify partition manager documentation Unify the wording …
(edit) @95e2f93   02/02/21 13:42:21 Sebastian Huber c-user: Clarify object services Add a "Constraints" paragraph to the …
(edit) @221b61a   02/01/21 20:28:36 Gedare Bloom user: add guidance on version numbers to GSoC guide.
(edit) @ba633ec   01/25/21 05:58:10 Sebastian Huber Improve file header comment in generated files
(edit) @a08e672   11/27/20 08:13:56 Sebastian Huber eng: Add design group requirement item type Update #3715.
(edit) @c3b4e18   01/14/21 15:18:00 kinsey.moore user: Update aarch64/xilinx-zynqmp Qemu command The Xilinx ZynqMP BSP …
(edit) @58bf83e   12/22/20 06:17:43 Sebastian Huber user: Mention use of LLVM
(edit) @2cf3076   12/14/20 10:22:39 christian.mauderer user/bsp/imxrt: Information for custom FDT Update #4180
(edit) @171bbe0   12/01/20 09:58:51 christian.mauderer shell: Document i2c and spi commands.
(edit) @265bee7   12/07/20 17:01:47 kinsey.moore user: Add aarch64/xilinx-zynqmp
(edit) @94abaa3   12/07/20 18:10:50 kinsey.moore user: Add A53 Qemu run instructions
(edit) @9c40761   12/07/20 18:10:26 kinsey.moore aarch64: Update interrupt details
(edit) @d716c79   12/02/20 07:17:12 Sebastian Huber c-user: Generate Timer Manager documentation The documentation is a …
(edit) @dad89ce   11/24/20 12:41:35 Sebastian Huber c-user: Generate Object Services documentation The documentation is a …
(edit) @66bcecf   12/02/20 07:29:56 Sebastian Huber c-user: Clarify invalid identifier descriptions Update #3993.
(edit) @346bbe6   12/01/20 15:50:01 Sebastian Huber c-user: Clarify rtems_partition_delete() Move the PTCB sentence to …
(edit) @29e6caa   12/01/20 15:33:33 Sebastian Huber c-user: Clarify rtems_partition_create() The rtems_partition_create() …
(edit) @284e8d0   12/01/20 13:43:11 Sebastian Huber c-user: Fix format in Partition Manager Update #3993.
(edit) @4b03ff7   11/12/20 06:41:18 Sebastian Huber eng: Add performance specification items Add items to specify runtime …
(edit) @00b3444   11/20/20 09:35:46 Sebastian Huber c-user: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE Document new …
(edit) @05f06aa   11/20/20 13:22:44 Sebastian Huber c-user: Split up object services This makes it easier to …
(edit) @f501682   11/17/20 10:56:31 christian.mauderer user/bsps: Fix list in bsps-arm Seems that some filenames haven't …
(edit) @e95d992   11/17/20 10:35:43 christian.mauderer user/bsps: Add imxrt Update #4180
(edit) @9291bbb   11/19/20 07:54:47 Sebastian Huber c-user: Update internal error list
(edit) @238789d   11/06/20 10:12:55 Sebastian Huber eng: Rework and clarify Doxygen Guidelines
(edit) @bbd8d4a   11/19/20 10:22:46 Sebastian Huber eng: Fix typo Update #3715.
(edit) @0454ad7   11/12/20 09:36:32 Sebastian Huber eng: Simplify "Load" environment reporting Report all runtime …
(edit) @cdbd72d   11/12/20 09:27:12 Sebastian Huber eng: Rename ValidCache? environment in FullCache? This name better …
(edit) @530bc2b   10/12/20 13:53:05 Sebastian Huber c-user: Generate Partition Manager documentation The manager …
(edit) @ec4dcc0   09/29/20 14:44:03 Sebastian Huber c-user: Generate Event Manager documentation The manager …
(edit) @ad64ea0   11/11/20 07:20:04 Sebastian Huber Improve automatically generated warning
(edit) @64323c3   11/06/20 08:21:31 Sebastian Huber eng: Move code formatting rules into one section Clarify the 80 …
(edit) @b0b6c0c   11/05/20 18:39:57 Sebastian Huber eng: Clarify "Coding Conventions" introduction
(edit) @dc345cf   11/05/20 18:38:12 Sebastian Huber eng: Clarify "Source Documentation" section
(edit) @c694df1   11/05/20 18:24:24 Sebastian Huber eng: Add header file conventions
(edit) @3c896b9   11/05/20 15:27:23 Sebastian Huber eng: Remove "Generating a Tools Patch" This section is probably some …
(edit) @51a5138   10/12/20 13:51:24 Sebastian Huber c-user: Add "Generated from ..." comments
(edit) @f610291   10/12/20 13:52:13 Sebastian Huber eng: Add function attributes Update #3715.
(edit) @8fe0da2   10/27/20 06:50:27 Sebastian Huber user: Add arm/stm32h7 Close #3910.
(edit) @1736aea   10/27/20 06:49:40 Sebastian Huber user: Rename files to match the chapter index
(edit) @abc9c44   10/24/20 10:12:31 Sebastian Huber eng: Replace spec2doc.py with spec2modules.py Update #3715.
(edit) @25525dc   10/19/20 01:15:01 Chris Johns user/beagle: Add debug hardware mod
