Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems-docs
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @228560f   03/20/17 21:41:41 Chris Johns waf: Create the sphinx rule in one place. 5
(edit) @f97be09   03/20/17 01:18:53 Chris Johns Use a single top level version number. 5
(edit) @1accbe3   03/15/17 01:34:19 Chris Johns user: Add tool commands to the user manual. 5
(edit) @91d6c96   03/15/17 04:03:10 Chris Johns waf: Configure check the inliner only once. 5
(edit) @93e5286   03/08/17 11:11:32 Sebastian Huber c-user: Add note to rtems_task_set_scheduler() 5
(edit) @9260c98   03/07/17 09:36:43 Sebastian Huber c-user: Update rtems_task_set_scheduler() 5
(edit) @ff9d555   02/25/17 04:05:09 Chris Johns Add a check for Sphinx extensions. Minor clean up of the configure … 5
(edit) @c1dddac   02/22/17 06:09:21 Sebastian Huber Move extensions to common conf.py 5
(edit) @7ba0479   02/20/17 06:23:55 Sebastian Huber Render math via JavaScript? in HTML output 5
(edit) @51392ac   02/15/17 14:51:51 Sebastian Huber c-user: Fix linker set code blocks 5
(edit) @3b9b8a0   02/15/17 14:07:14 Sebastian Huber c-user: Document linker set content Close #2770. 5
(edit) @fad46ff   02/14/17 10:14:30 Sebastian Huber shell: Update task command Update #2858. 5
(edit) @1d073c5   02/14/17 09:18:25 Sebastian Huber c-user: CONFIGURE_MAXIMUM_PROCESSORS Update #2894. 5
(edit) @29222e3   02/03/17 13:26:03 Sebastian Huber c-user: Add SMP internal locking 5
(edit) @0874d7d   02/03/17 12:58:19 Sebastian Huber c-user: Add SMP profiling 5
(edit) @138c1ba   02/03/17 12:35:24 Sebastian Huber c-user: Eliminate CONFIGURE_SMP_APPLICATION Update #2893. 5
(edit) @1f3c22e   02/03/17 11:54:44 Sebastian Huber c-user: Update SMP introduction 5
(edit) @b2e56c5   02/03/17 10:57:33 Sebastian Huber c-user: New SMP chapter title 5
(edit) @90a3c41   02/03/17 10:55:29 Sebastian Huber c-user: Add TAS and TTAS terms 5
(edit) @87b4d03   02/03/17 10:52:51 Sebastian Huber c-user: Update scheduler helping protocol 5
(edit) @785c02f   02/02/17 13:07:53 Sebastian Huber c-user: Add SMP low-level synchronization 5
(edit) @3e005fe   02/02/17 10:22:59 Sebastian Huber c-user: Use sphinx glossary support Terms can be referenced via … 5
(edit) @2e0a2a0   02/02/17 09:49:56 Sebastian Huber c-user: Add SMP implementation details section 5
(edit) @b033e39   02/02/17 09:46:05 Sebastian Huber c-user: Add SMP application issues section 5
(edit) @7b1c63c   02/02/17 08:43:47 Sebastian Huber c-user: Update clustered scheduling 5
(edit) @0680bd2   02/02/17 08:14:50 Sebastian Huber Update README due to use of math extension 5
(edit) @a0d2eee   02/01/17 12:38:41 Sebastian Huber Use "in X config..." instead of "on X config..." 5
(edit) @ba781f9   02/01/17 12:32:41 Sebastian Huber c-user: Move scheduler directives 5
(edit) @9de1be6   02/01/17 12:23:56 Sebastian Huber c-user: Remove duplicate thread queue section 5
(edit) @a6a1f72   02/01/17 12:23:14 Sebastian Huber c-user: Update task migration 5
(edit) @a238912   02/01/17 12:07:25 Sebastian Huber c-user: Move some task directives 5
(edit) @3966353   02/01/17 08:48:03 Sebastian Huber Do not show page references after internal links 5
(edit) @5dcebd4   02/01/17 06:50:59 Sebastian Huber Fix refs.bib entries 5
(edit) @8add179   01/31/17 12:27:08 Sebastian Huber c-user: Add Key concept locking protocols Update #2412. Update #2556. 5
(edit) @aaff696   01/31/17 10:15:56 Sebastian Huber c-user: Add key concept thread queues Update #2556. 5
(edit) @938c49e   01/31/17 11:59:08 Sebastian Huber Fix refs.bib entry 5
(edit) @e6cb6b7   01/31/17 09:33:14 Sebastian Huber shell: Update task command Update #2858. 5
(edit) @40a1e80   01/31/17 09:10:13 Sebastian Huber c-user: Task names Update #2858. 5
(edit) @e07e376   01/30/17 13:44:01 Sebastian Huber c-user: Update initialization Update #2692. 5
(edit) @1161ed1   01/30/17 13:22:14 Sebastian Huber c-user: Update timer manager Update #2554. 5
(edit) @a17535d   01/30/17 12:51:57 Sebastian Huber c-user: Add timer and timeouts key concept Update #2554. 5
(edit) @e23f46c   01/30/17 10:31:45 Sebastian Huber c-user: Update key concepts time 5
(edit) @73ad65d   01/30/17 07:11:37 Sebastian Huber refs.bib: Add URL 5
(edit) @c660173   01/26/17 13:48:33 c0066c c-user: Update overrun handling related functions and structure State … 5
(edit) @9889463   01/27/17 07:06:56 Sebastian Huber c-user: Clarify rtems_heap_extend() Update #1747. 5
(edit) @dc3ef53   01/27/17 06:58:48 Sebastian Huber c-user: Region directives use the allocator mutex 5
(edit) @166d17b   01/27/17 06:49:01 Sebastian Huber c-user: Fix region directive prototypes 5
(edit) @b1e3b75   01/26/17 14:10:49 Sebastian Huber c-user: Rework user extensions chapter Update #2692. Update #2752. 5
(edit) @0456ee7   01/25/17 07:36:23 Sebastian Huber Fix some reference titles 5
(edit) @f5e8e80   01/25/17 07:26:39 Sebastian Huber Sort references 5
(edit) @ffe8197   01/24/17 07:59:37 Sebastian Huber c-user: SMP thread dispatching Close #2809. 5
(edit) @31157bc   01/23/17 12:44:43 Sebastian Huber c-user: Clarify simple binary semaphore release Close #2725. 5
(edit) @7b52e8f   01/20/17 06:16:38 Sebastian Huber Mention sphinxcontrib-bibtex in README 5
(edit) @418dee8   01/19/17 19:02:38 joel c-user/ada_support.rst: Discuss timer server and interrupt threads 5
(edit) @97e1553   01/17/17 09:39:08 Sebastian Huber c-user: Add support for references via bibtex … 5
(edit) @7d78d31   01/18/17 00:27:00 joel c-user: Add Ada support chapter closes #2589. 5
(edit) @23b1c10   01/17/17 13:17:33 Sebastian Huber c-user: Fix typo 5
(edit) @69d6622   01/13/17 22:03:09 c0066c Update documentation to reflect EDF scheduler overrun handling Update … 5
(edit) @fde6ac6   01/13/17 08:08:11 Sebastian Huber Document CONFIGURE_MAXIMUM_THREAD_NAME_SIZE Update #2858. 5
(edit) @8363c3d   01/13/17 07:54:10 Sebastian Huber shell: Update cpuuse and stackuse sample output 5
(edit) @6705e5e   01/13/17 05:05:04 Chris Johns waf: Correct the branch version number. 5
(edit) @7956bbf   01/12/17 02:20:48 Chris Johns coverpage: Remove used function. 5
(edit) @321d20a   01/12/17 02:18:43 Chris Johns coverpage: Make showing the table conditional. 5
(edit) @bceb286   01/12/17 02:11:34 Chris Johns coverpage: Rename the static images directory to match bootstrap. 5
(edit) @9eb8a43   01/12/17 02:07:13 Chris Johns coverpage: Fix the catalogue table id. 5
(edit) @049097f   01/12/17 01:55:15 Chris Johns coverpage: Update the coverpage to have the table collapse. Add each … 5
(edit) @876035b   01/12/17 01:24:46 mrmoolovesu conf.py: Fix build_date() to append correct suffix on all days. 5
(edit) @7193f09   01/12/17 01:01:20 joel Update document titles for consistency 5
(edit) @d8beaab   11/15/16 23:54:47 joel Remove references to SPARC/SIS BSP. Also clean up old ERC32 … 5
(edit) @2591ca6   01/11/17 06:04:02 Chris Johns html: Embed the catalogue XML in JS. The is to work around a security … 5
(edit) @ecf82d1   01/11/17 04:50:59 Chris Johns html: Add support for an HTML cover page for releases. 5
(edit) @9aa52b9   01/10/17 11:34:47 Chris Johns waf: Add a title to the XML Catalogue. 5
(edit) @782b4fe   01/09/17 23:11:05 Chris Johns waf: Improved XML Catalogue generator. 5
(edit) @1a9b02e   01/09/17 12:13:02 Chris Johns waf: Create an XML Catalogue. 5
(edit) @5ef17b7   01/05/17 00:37:10 Chris Johns waf: Update to waf-1.9.7 5
(edit) @5bb51a4   12/23/16 13:38:35 Sebastian Huber Update Console Driver chapter Close #2785. Close #2838. 5
(edit) @3b42c96   12/21/16 07:51:28 Sebastian Huber Strip down BSP Introduction Update #2852. 5
(edit) @c8aecf9   12/20/16 12:17:04 Sebastian Huber Add warnings to basic BSP chapters Update #2852. 5
(edit) @02d1702   12/20/16 12:10:37 Sebastian Huber Move Shared Memory Support Driver chapter This chapter is very … 5
(edit) @b0513c8   12/20/16 12:06:24 Sebastian Huber Move Ada95 Interrupt Support chapter This chapter is very specific. … 5
(edit) @9038b99   12/20/16 12:04:59 Sebastian Huber Add warning to Timer Driver chapter Move Timer Driver chapter. … 5
(edit) @4af69ea   12/20/16 10:53:48 Sebastian Huber Add warning to ATA/IDE driver chapter Close #2849. 5
(edit) @003ee4d   12/20/16 10:38:36 Sebastian Huber Remove Non-Volatile Memory Driver chapter There exists no standard … 5
(edit) @5b8d5d0   12/20/16 10:30:49 Sebastian Huber Remove Discrete Driver chapter There exists no standard Discrete … 5
(edit) @4b5b499   12/20/16 10:23:57 Sebastian Huber Remove Analog Driver chapter There exists no standard Analog Driver … 5
(edit) @7351405   12/20/16 10:18:06 Sebastian Huber Document I2C framework Update #2845. 5
(edit) @0cb2748   12/20/16 10:07:29 Sebastian Huber Document SPI framework Update #2776. 5
(edit) @45dc7c7   12/21/16 10:29:35 Sebastian Huber Update version/revision to 4.11.99 5
(edit) @2c780bf   12/21/16 10:28:56 Sebastian Huber Add script to update the version/revision 5
(edit) @e7f40f0   12/21/16 09:55:46 Sebastian Huber Rework Clock Driver chapter Update #2737. 5
(edit) @f517010   12/19/16 14:06:37 Sebastian Huber Document CPUINFO Close #2723. 5
(edit) @7b0db6a   12/19/16 13:51:08 Sebastian Huber CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS Do not mention … 5
(edit) @09078e0   12/19/16 13:46:33 Sebastian Huber Do not mention obsolete Giant lock Close #2555. 5
(edit) @117f98c   12/19/16 13:37:43 Sebastian Huber Update rtems_interrupt_frame description Close #2808. 5
(edit) @3be5dd6   12/19/16 13:33:05 Sebastian Huber Document rtems_task_get_priority() Close #2784. 5
(edit) @c4825f4   12/13/16 09:03:27 Sebastian Huber Update Task Manager chapter Introduce "Deprecated and Removed … 5
(edit) @6fa32c0   12/09/16 12:01:57 Sebastian Huber Update Initialization Manager chapter Update #2408. 5
(edit) @00ffe1f   12/09/16 09:55:29 Sebastian Huber Improve fatal error chapter Update #2825. 5
(edit) @2ff4255   12/06/16 11:03:54 Sebastian Huber Update linker set documentation Update #2408. Update #2790. 5
(edit) @1727e62   11/23/16 12:45:55 Sebastian Huber Improve fatal error chapter Update #2825. 5
