# # ChangeLog for / in rtems-docs # # Generated by Trac 1.2.1.dev0 # 05/12/24 14:16:57 Tue, 06 Mar 2018 06:38:52 GMT Sebastian Huber [f6c6c8b] * c-user/configuring_a_system.rst (modified) CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER Update #3320. Mon, 06 Nov 2017 12:01:43 GMT Sebastian Huber [d078405] * c-user/configuring_a_system.rst (modified) CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER Close #3170. ... Mon, 05 Feb 2018 09:43:23 GMT Sebastian Huber [13debfb] * c-user/configuring_a_system.rst (modified) c-user: Fix index directives Update #3229. Mon, 06 Nov 2017 10:44:27 GMT Sebastian Huber [0e8f08d] * c-user/configuring_a_system.rst (modified) c-user: Use configuration option as section name This makes it ... Mon, 05 Feb 2018 08:58:53 GMT Sebastian Huber [0851404] * c-user/configuring_a_system.rst (modified) c-user: Document obsolete termios config options Update #2843. Wed, 01 Feb 2017 06:51:45 GMT Sebastian Huber [1472f841] * c-user/index.rst (modified) * c-user/self_contained_objects.rst (added) c-user: Add self-contained objects chapter Update #2843. Fri, 05 Jan 2018 10:05:55 GMT Sebastian Huber [3a594a9] * c-user/user_extensions.rst (modified) c-user: Clarify user extensions Fri, 15 Dec 2017 06:12:46 GMT Sebastian Huber [ba64982] * c-user/configuring_a_system.rst (modified) c-user: Update unlimites objects configuration Tue, 05 Dec 2017 16:16:11 GMT Joel Sherrill [3079455] * c-user/directive_status_codes.rst (modified) * c-user/task_manager.rst (modified) Account for non-preemption and interrupt level not supported on SMP ... Fri, 01 Dec 2017 08:31:57 GMT Sebastian Huber [0ef3449] * c-user/interrupt_manager.rst (modified) c-user: Clarify local interrupt disable Wed, 29 Nov 2017 10:02:47 GMT Sebastian Huber [b2c766b] * c-user/interrupt_manager.rst (modified) c-user: Clarify interrupt manager directives Use RTEMS coding style ... Wed, 22 Nov 2017 12:42:18 GMT Sebastian Huber [674b714] * c-user/fatal_error.rst (modified) * c-user/initialization.rst (modified) c-user: Document global construction Close #3243. Wed, 22 Nov 2017 13:09:28 GMT Sebastian Huber [97c51c8] * c-user/fatal_error.rst (modified) c-user: Document rtems_panic() Close #3244. Wed, 22 Nov 2017 12:50:11 GMT Sebastian Huber [d1a824f] * c-user/initialization.rst (modified) c-user: Remove RTEMS_SYSINIT_POSIX_RWLOCK Update #3115. Wed, 22 Nov 2017 12:49:25 GMT Sebastian Huber [6c1bf7e] * c-user/initialization.rst (modified) c-user: Remove RTEMS_SYSINIT_POSIX_BARRIER Update #3114. Wed, 22 Nov 2017 12:47:30 GMT Sebastian Huber [7188bd5] * c-user/initialization.rst (modified) c-user: Remove RTEMS_SYSINIT_POSIX_MUTEX Update #3112. Wed, 22 Nov 2017 12:46:19 GMT Sebastian Huber [5680ec5] * c-user/initialization.rst (modified) c-user: RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE Update #3113. Mon, 20 Nov 2017 07:25:26 GMT Sebastian Huber [0acf49e] * c-user/barrier_manager.rst (modified) * c-user/semaphore_manager.rst (modified) Mention barrier manager in rtems_semaphore_flush() Mon, 20 Nov 2017 07:08:30 GMT Sebastian Huber [70f23e4] * bsp-howto/getentropy.rst (modified) * c-user/fatal_error.rst (modified) Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL Update #3239. Fri, 17 Nov 2017 12:46:52 GMT Sebastian Huber [e2a1a3a] * c-user/interrupt_manager.rst (modified) c-user: Clarify rtems_interrupt_flash() Fri, 17 Nov 2017 12:32:50 GMT Sebastian Huber [6efb6fa] * c-user/interrupt_manager.rst (modified) c-user: Remove clock driver specific functions Do not mention ... Fri, 17 Nov 2017 06:58:10 GMT Sebastian Huber [baf9824] * c-user/fatal_error.rst (modified) Document INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL Close #3239. Fri, 17 Nov 2017 06:57:51 GMT Sebastian Huber [5531f02] * c-user/fatal_error.rst (modified) INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT Thu, 16 Nov 2017 15:01:16 GMT Christian Mauderer [d0b961a] * bsp-howto/getentropy.rst (added) * bsp-howto/index.rst (modified) bsp-howto: Add getentropy. Update #3239. Thu, 16 Nov 2017 09:29:43 GMT Sebastian Huber [d9ecff1] * c-user/semaphore_manager.rst (modified) c-users: Clarify semaphore obtain/flush Thu, 16 Nov 2017 01:04:57 GMT Martin Erik Werner [c6066d4] * bsp-howto/console.rst (modified) bsp-howto/console: Move misplaced var. in example Signed-off-by: ... Mon, 13 Nov 2017 02:25:18 GMT Chris Johns [3384994] * c-user/ada_support.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/fatal_error.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/partition_manager.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/region_manager.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) * user/additional/index.rst (deleted) * user/installation/prefixes-sandboxing.rst (modified) * user/start/index.rst (modified) * user/tools/index.rst (modified) * user/tools/simulation.rst (deleted) * user/tools/tester.rst (modified) Clean up sphinx warnings. - Fix minor formatting issues. - Fix ... Mon, 13 Nov 2017 00:51:23 GMT Chris Johns [ac0eaff] * user/conf.py (modified) * user/config/build.rst (deleted) * user/config/index.rst (deleted) * user/config/runtime.rst (deleted) * user/hardware/index.rst (modified) * user/hosts/index.rst (modified) * user/index.rst (modified) * user/installation/index.rst (modified) * user/installation/prefixes-sandboxing.rst (modified) * user/start/installation.rst (deleted) * user/start/quick.rst (deleted) * user/start/transition.rst (deleted) * user/tools/index.rst (modified) * user/waf/build.rst (deleted) * user/waf/config.rst (deleted) * user/waf/index.rst (deleted) * user/waf/install.rst (deleted) Use '.. toctree::' and not '.. include::' in the User Manual. - ... Sun, 12 Nov 2017 03:34:48 GMT Chris Johns [6c56401] * c-user/ada_support.rst (modified) * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/fatal_error.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) c-user: Fix index locations. Update #3229. Sat, 11 Nov 2017 23:32:39 GMT Chris Johns [42d50d7] * bsp-howto/genindex.rst (added) * bsp-howto/index.rst (modified) * c-user/genindex.rst (added) * c-user/index.rst (modified) * cpu-supplement/genindex.rst (added) * cpu-supplement/index.rst (modified) * develenv/genindex.rst (added) * develenv/index.rst (modified) * eclipse/genindex.rst (added) * eclipse/index.rst (modified) * filesystem/genindex.rst (added) * filesystem/index.rst (modified) * networking/genindex.rst (added) * networking/index.rst (modified) * porting/genindex.rst (added) * porting/index.rst (modified) * posix-compliance/genindex.rst (added) * posix-compliance/index.rst (modified) * posix-users/genindex.rst (added) * posix-users/index.rst (modified) * rsb/genindex.rst (added) * rsb/index.rst (modified) * shell/genindex.rst (added) * shell/index.rst (modified) * user/genindex.rst (added) * user/index.rst (modified) Add indexes to all documents. Update #3229. Thu, 09 Nov 2017 09:22:24 GMT Sebastian Huber [60a6d6e] * c-user/configuring_a_system.rst (modified) * c-user/key_concepts.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * eclipse/rtems.rst (modified) * posix-compliance/probe_rtems (modified) * user/installation/developer.rst (modified) * user/installation/kernel.rst (modified) * user/installation/releases.rst (modified) * user/start/index.rst (modified) * user/start/quick.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * wscript (modified) Change RTEMS version to 5 Update #3220. Thu, 02 Nov 2017 15:09:40 GMT Joel Sherrill [120c8a0] * c-user/configuring_a_system.rst (modified) c-user/configuring_a_system.rst: Delete notepads section closes #3215. Tue, 24 Oct 2017 08:50:45 GMT Sebastian Huber [c5161ee] * posix-users/condition_variable.rst (modified) * posix-users/semaphore.rst (modified) posix-users: Clarify timed operation errors Close #3182. Fri, 13 Oct 2017 15:52:14 GMT Chris Johns [bf900c7] * posix-compliance/glossary.rst (modified) posix-compliance: Latex does not like an empty glossary. Fri, 13 Oct 2017 14:37:40 GMT Chris Johns [b252753] * posix-compliance/glossary.rst (added) * posix-compliance/index.rst (modified) * posix-compliance/posix_rst.py (modified) * posix-compliance/wscript (modified) * posix-compliance/zreferences.rst (added) posix-compliance: Reference the generated content via the include ... Fri, 13 Oct 2017 04:31:50 GMT Chris Johns [55fcfaa] * posix-compliance/conf.py (modified) posix-compliance: Fix the pdflatex file created by Sphinx. Fri, 13 Oct 2017 01:30:32 GMT Chris Johns [4401dc5] * posix-compliance/wscript (modified) build: Remove the grouping in posix-compliance. Fri, 13 Oct 2017 00:47:23 GMT Chris Johns [2804294] * posix-compliance/posix-compliance.rst (added) * posix-compliance/posix_rst.py (added) * posix-compliance/wscript (modified) posix-compliance: Add automatic generation of the ReST file from CSV ... Fri, 13 Oct 2017 00:46:00 GMT Chris Johns [8e8094a] * common/waf.py (modified) build: Add extra source to the sphinx build. Updates #3177. Mon, 28 Aug 2017 18:03:40 GMT Joel Sherrill [2c3cf21] * posix-compliance/README-csv.txt (added) * posix-compliance/RTEMS-Standards-Compliance-v1.csv (added) * posix-compliance/conf.py (moved) * posix-compliance/index.rst (added) * posix-compliance/preface.rst (added) * posix-compliance/probe_misses.txt (added) * posix-compliance/probe_rtems (added) * posix-compliance/wscript (moved) * posix1003-1/clocks_and_timers.rst (deleted) * posix1003-1/command.rst (deleted) * posix1003-1/compliance_summary.rst (deleted) * posix1003-1/data_interchange_format.rst (deleted) * posix1003-1/device_and_class_specific.rst (deleted) * posix1003-1/execution_scheduling.rst (deleted) * posix1003-1/files_and_directories.rst (deleted) * posix1003-1/general.rst (deleted) * posix1003-1/index.rst (deleted) * posix1003-1/input_and_output.rst (deleted) * posix1003-1/language_specific_services.rst (deleted) * posix1003-1/memory_managment.rst (deleted) * posix1003-1/message_passing.rst (deleted) * posix1003-1/posix1003_1.rst (deleted) * posix1003-1/preface.rst (deleted) * posix1003-1/process_environment.rst (deleted) * posix1003-1/process_primitives.rst (deleted) * posix1003-1/synchronization.rst (deleted) * posix1003-1/system_database.rst (deleted) * posix1003-1/terminology.rst (deleted) * posix1003-1/thread_cancellation.rst (deleted) * posix1003-1/thread_managment.rst (deleted) * posix1003-1/thread_specific_data.rst (deleted) * wscript (modified) New version of POSIX Compliance Guide This is a replacement of the ... Fri, 13 Oct 2017 00:02:11 GMT Joel Sherrill [13a15f9] * bsp-howto/conf.py (modified) Shorten BSP and Driver Guide name (missed commit) Updates #3141. Thu, 12 Oct 2017 23:50:59 GMT Joel Sherrill [c6f8e51] * bsp-howto/conf.py (modified) * bsp-howto/index.rst (modified) * cpu-supplement/lattice_micro32.rst (modified) * cpu-supplement/port.rst (modified) * develenv/directory.rst (modified) Shorten the name of the BSP and Device Driver Development Guide Old ... Wed, 11 Oct 2017 05:58:39 GMT Sebastian Huber [64564df] * c-user/configuring_a_system.rst (modified) c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES This configuration is ... Thu, 12 Oct 2017 00:56:20 GMT Joel Sherrill [d36d685] * posix-users/thread.rst (modified) posix-users/thread.rst: Add pthread_getconcurrency and ... Wed, 11 Oct 2017 23:41:41 GMT Joel Sherrill [21e0fcd] * c-user/clock_manager.rst (modified) * c-user/interrupt_manager.rst (modified) c-user: Update to reflect rtems_clock_get() being obsoleted. Closes ... Fri, 06 Oct 2017 12:29:00 GMT Sebastian Huber [d8f7bdc] * c-user/configuring_a_system.rst (modified) c-user: Add obsolete configuration options section Update #2493. ... Fri, 06 Oct 2017 12:00:18 GMT Sebastian Huber [265cc70] * c-user/configuring_a_system.rst (modified) c-user: Clarify that confdefs.h is mandatory Wed, 27 Sep 2017 12:55:45 GMT Sebastian Huber [87e1929] * cpu-supplement/arm.rst (modified) Mention i.MX 7 SMP support Update #3090. Mon, 18 Sep 2017 06:26:50 GMT Sebastian Huber [27515ec] * bsp-howto/clock.rst (modified) bsp-howto: Clock_driver_support_install_isr() Close #3139. Thu, 14 Sep 2017 11:50:35 GMT Chris Johns [5c3683e] * common/_static/my-styles.css (modified) Improve the line spaces for directives and notes. Thu, 14 Sep 2017 08:52:44 GMT Sebastian Huber [56cccd6] * c-user/task_manager.rst (modified) c-user: Fix task create notes Thu, 14 Sep 2017 00:32:28 GMT Chris Johns [794eb1b] * c-user/symmetric_multiprocessing_services.rst (modified) c-user: Clarify SMP's rtems_get_processor_count. Mon, 04 Sep 2017 03:32:55 GMT Chris Johns [2cc9e2a] * rsb/hosts.rst (modified) Add PAX to the Ubuntu packages to install. Closes #3008. Sun, 03 Sep 2017 23:57:03 GMT Chris Johns [46ea92b] * eclipse/glossary.rst (modified) * eclipse/index.rst (modified) Eclipse: Fix TOC and glossary licence comment. Thu, 24 Aug 2017 05:24:28 GMT Sebastian Huber [5fc9f8b] * common/conf.py (modified) common: Remove obsolete latex_use_parts This configuration is ... Fri, 25 Aug 2017 08:35:14 GMT Sebastian Huber [3fdea2d] * cpu-supplement/powerpc.rst (modified) cpu-supplement: Use literal instead of emphasis Update #3082. Thu, 24 Aug 2017 13:54:41 GMT Sebastian Huber [873ba80] * cpu-supplement/powerpc.rst (modified) cpu-supplement: Fix PowerPC TOC limitation Update #3082. Thu, 24 Aug 2017 07:56:37 GMT Sebastian Huber [6eef7a4] * c-user/user_extensions.rst (modified) c-user: Clarify user extensions Close #2367. Wed, 23 Aug 2017 07:23:23 GMT Sebastian Huber [b6977f7] * cpu-supplement/powerpc.rst (modified) cpu-supplement/powerpc: Rewrite Remove obsolete and duplicated ... Fri, 11 Aug 2017 03:42:55 GMT Chris Johns [feb6832] * common/waf.py (modified) * develenv/conf.py (modified) coverpage: Fix repeated entries. Closes #2865. Fri, 11 Aug 2017 03:09:50 GMT Chris Johns [efc29ff] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/rtemsstyle.sty (modified) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-users/index.rst (modified) * rsb/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) * user/overview/index.rst (modified) * user/support/index.rst (modified) Update copyright notices. Fri, 11 Aug 2017 00:32:18 GMT Chris Johns [c684611] * common/rtemsstyle.sty (modified) pdf: Update the RTEMS style to work recent Sphinx versions. Fri, 11 Aug 2017 00:31:39 GMT Chris Johns [7464b71] * common/conf.py (modified) common/conf: Clean up. Wed, 09 Aug 2017 10:19:22 GMT Chris Johns [58de62d] * common/sphinxcontrib/__init__.py (deleted) * common/sphinxcontrib/bibtex/__init__.py (deleted) * common/sphinxcontrib/bibtex/cache.py (deleted) * common/sphinxcontrib/bibtex/directives.py (deleted) * common/sphinxcontrib/bibtex/nodes.py (deleted) * common/sphinxcontrib/bibtex/roles.py (deleted) * common/sphinxcontrib/bibtex/transforms.py (deleted) * common/waf.py (modified) Revert "Add the sphinxcontrib.bibtex extension to the repo." This ... Mon, 07 Aug 2017 11:58:52 GMT Chris Johns [aa4f8e2] * common/sphinxcontrib/__init__.py (added) * common/sphinxcontrib/bibtex/__init__.py (added) * common/sphinxcontrib/bibtex/cache.py (added) * common/sphinxcontrib/bibtex/directives.py (added) * common/sphinxcontrib/bibtex/nodes.py (added) * common/sphinxcontrib/bibtex/roles.py (added) * common/sphinxcontrib/bibtex/transforms.py (added) * common/waf.py (modified) Add the sphinxcontrib.bibtex extension to the repo. Fri, 04 Aug 2017 12:26:36 GMT Sebastian Huber [bbdf66c] * bsp-howto/clock.rst (modified) bsp: Optional clock driver shutdown Fri, 28 Jul 2017 18:45:01 GMT Gedare Bloom [1ab6d59] * posix-users/memory_managment.rst (modified) memory_management: update mmap, munmap, shm_open, shm_unlink Close ... Wed, 26 Jul 2017 15:50:10 GMT Gedare Bloom [6543b90] * posix-users/status_of_implementation.rst (modified) * posix1003-1/memory_managment.rst (modified) * posix1003-1/posix1003_1.rst (modified) posix1003-1, posix_users: mark mmap and shm functions implemented ... Wed, 26 Jul 2017 15:44:44 GMT Gedare Bloom [5ffa072] * README.txt (modified) README: fix typos Fri, 14 Jul 2017 05:52:21 GMT Sebastian Huber [f776fe6] * c-user/interrupt_manager.rst (modified) c-user: Fix interrupt lock documentation Update #3075. Wed, 12 Jul 2017 06:28:06 GMT Sebastian Huber [a31dbcb] * c-user/scheduling_concepts.rst (modified) c-user: Document new scheduler ident routines Close #3069. Close #3070. Fri, 07 Jul 2017 13:50:51 GMT Sebastian Huber [9037998] * c-user/scheduling_concepts.rst (modified) * c-user/task_manager.rst (modified) c-user: Update scheduler/task chapter Reflect EDF SMP scheduler ... Fri, 30 Jun 2017 13:06:21 GMT Sebastian Huber [8cf3d75] * c-user/configuring_a_system.rst (modified) * c-user/scheduling_concepts.rst (modified) c-user: Document EDF SMP Close #3056. Fri, 16 Jun 2017 04:19:16 GMT Sebastian Huber [4e85468] * shell/rtems_specific_commands.rst (modified) shell: Update task command Thu, 01 Jun 2017 22:39:52 GMT Tanu Hari Dixit [c475eef] * user/tools/index.rst (modified) * user/tools/tester.rst (added) User Manual: Added rtems-tester in the docs Added as part of Tools. ... Tue, 13 Jun 2017 18:17:48 GMT Cillian O'Donnell [c41810b] * rsb/configuration.rst (modified) docs/rsb/configuration.rst: Fix typos, grammar. Mon, 12 Jun 2017 09:09:06 GMT Sebastian Huber [44c9e33] * cpu-supplement/intel_amd_x86.rst (modified) cpu-supplement: Update TLS support status Close #2468. Thu, 08 Jun 2017 07:38:26 GMT Sebastian Huber [f7a2dcf] * bsp-howto/console.rst (modified) bsp-howto: Warn about TERMIOS_TASK_DRIVEN Update #2935. Tue, 06 Jun 2017 04:42:50 GMT Sebastian Huber [8d94ba1] * rsb/quick-start.rst (modified) rsb: Mention Ada language option Thu, 01 Jun 2017 01:44:34 GMT Chris Johns [eb934d0] * user/tools/index.rst (modified) User: Remove conflict marker. Wed, 31 May 2017 11:11:01 GMT Chris Johns [3240078] * user/tools/symbols.rst (modified) User: Remove the stash conflict markers. Wed, 31 May 2017 10:22:06 GMT Tanu Hari Dixit [737092f] * README.txt (modified) Fixes typos in README.txt 2 typos fixed Wed, 31 May 2017 10:59:36 GMT Chris Johns [d224b11] * user/tools/exeinfo.rst (modified) * user/tools/index.rst (modified) * user/tools/symbols.rst (modified) User: Improvements to some of the tools commands. Wed, 24 May 2017 03:07:21 GMT Chris Johns [7f89df8] * user/tools/bsp-builder.rst (modified) User Manual: Update the rtems-bsp-builder command. Thu, 11 May 2017 07:25:04 GMT Sebastian Huber [39773ce] * c-user/key_concepts.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) c-user: Replace pre-emption with preemption Tue, 25 Apr 2017 18:14:48 GMT Linda Huxley [4cc5fcf] * rsb/hosts.rst (modified) hosts.rst: Correct Ubuntu instructions closes #3005. Tue, 25 Apr 2017 18:07:17 GMT Joel Sherrill [26b6f84] * README.txt (modified) README.txt: Add info after installing on CentOS 7 Fri, 10 Mar 2017 21:26:35 GMT Joel Sherrill [c8b6745] * c-user/rate_monotonic_manager.rst (modified) c-user/rate_monotonic_manager.rst: Use Latex math for utilization ... Fri, 10 Mar 2017 21:01:36 GMT Joel Sherrill [ca2926f] * posix-users/devctl.rst (added) * posix-users/index.rst (modified) POSIX Users: Add posix_devctl() Sun, 26 Mar 2017 23:31:13 GMT Chris Johns [33989b6] * README.txt (modified) * common/waf.py (modified) Add Windows build details. Actually include the quoting fix for Windows. Sun, 26 Mar 2017 23:27:29 GMT Chris Johns [0263581] * common/waf.py (modified) * wscript (modified) waf: Fix linkcheck and spell commands. Clean up and remove code ... Sun, 26 Mar 2017 23:25:25 GMT Chris Johns [ad5d632] * bsp-howto/wscript (modified) * c-user/wscript (modified) * cpu-supplement/wscript (modified) * develenv/wscript (modified) * eclipse/wscript (modified) * filesystem/wscript (modified) * networking/wscript (modified) * porting/wscript (modified) * posix-users/wscript (modified) * posix1003-1/wscript (modified) * rsb/wscript (modified) * rtemsconfig/wscript (modified) * shell/wscript (modified) * user/wscript (modified) waf: Cleaner formatting to see the importing. Tue, 21 Mar 2017 03:21:15 GMT Chris Johns [d8795ef] * rsb/quick-start.rst (modified) rsb: Fix the path to the tar for the untar with strip option. The ... Tue, 21 Mar 2017 00:41:40 GMT Chris Johns [10874b0] * user/tools/bsp-builder.rst (modified) user: Fix typo. Tue, 21 Mar 2017 00:37:09 GMT Chris Johns [8561c3c] * user/tools/bsp-builder.rst (modified) user: Minor fixes to rtems-bsp-builder. Mon, 20 Mar 2017 23:32:18 GMT Chris Johns [e82055b] * user/tools/bsp-builder.rst (modified) user: Add an example of the rtems-bsp-builder running. Mon, 20 Mar 2017 21:41:55 GMT Chris Johns [e7f009e] * common/conf.py (modified) conf: Update the copyright year. Mon, 20 Mar 2017 21:41:41 GMT Chris Johns [228560f] * common/waf.py (modified) waf: Create the sphinx rule in one place. Mon, 20 Mar 2017 01:18:53 GMT Chris Johns [f97be09] * bsp-howto/conf.py (modified) * c-user/conf.py (modified) * common/conf.py (modified) * common/waf.py (modified) * cpu-supplement/conf.py (modified) * develenv/conf.py (modified) * eclipse/conf.py (modified) * filesystem/conf.py (modified) * networking/conf.py (modified) * porting/conf.py (modified) * posix-users/conf.py (modified) * posix1003-1/conf.py (modified) * rsb/conf.py (modified) * rtemsconfig/conf.py (modified) * shell/conf.py (modified) * user/conf.py (modified) * wscript (modified) Use a single top level version number. Wed, 15 Mar 2017 01:34:19 GMT Chris Johns [1accbe3] * common/_static/my-styles.css (modified) * user/index.rst (modified) * user/tools/bsp-builder.rst (added) * user/tools/build.rst (deleted) * user/tools/exeinfo.rst (added) * user/tools/index.rst (modified) * user/tools/linker.rst (added) * user/tools/symbols.rst (added) user: Add tool commands to the user manual.
