# # ChangeLog for / in rtems-docs # # Generated by Trac 1.2.1.dev0 # 04/24/24 11:47:58 Fri, 28 Oct 2016 12:56:02 GMT Chris Johns [9aafb39] * c_user/board_support_packages.rst (modified) * c_user/clock_manager.rst (modified) * c_user/configuring_a_system.rst (modified) * c_user/fatal_error.rst (modified) * c_user/glossary.rst (modified) * c_user/key_concepts.rst (modified) * c_user/linker_sets.rst (modified) * c_user/overview.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/symmetric_multiprocessing_services.rst (modified) * c_user/user_extensions.rst (modified) c_user: Remove errors and warnings. Fri, 28 Oct 2016 01:05:32 GMT Chris Johns [4120668] * develenv/directory.rst (modified) Update the file list to the 4.11 directory structure. Fri, 28 Oct 2016 01:01:51 GMT Chris Johns [4cacea0] * filesystem/call_development.rst (modified) * filesystem/command_and_variable.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/index.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * filesystem/trivial_ftp.rst (modified) Fix filesystem formatting. Fri, 28 Oct 2016 01:01:47 GMT Joel Sherrill [b0f2977] * porting/code_tuning.rst (modified) * porting/cpu_init.rst (modified) * porting/idle_thread.rst (modified) * porting/interrupts.rst (modified) * porting/miscellanous.rst (modified) * porting/priority_bitmap.rst (modified) * porting/task_context.rst (modified) porting: Fix code-block markup Fri, 28 Oct 2016 01:01:18 GMT Joel Sherrill [f29b7c1c] * bsp_howto/initilization_code.rst (modified) * bsp_howto/linker_script.rst (modified) * bsp_howto/miscellanous_support.rst (modified) * bsp_howto/real_time_clock.rst (modified) * bsp_howto/target_dependant_files.rst (modified) * bsp_howto/timer.rst (modified) bsp_howto: Fix code-block markup Fri, 28 Oct 2016 00:47:07 GMT Joel Sherrill [36def91] * bsp_howto/console.rst (modified) * bsp_howto/miscellanous_support.rst (modified) * c_user/constant_bandwidth_server.rst (modified) * c_user/semaphore_manager.rst (modified) * networking/testing_the_driver.rst (modified) * porting/cpu_init.rst (modified) * porting/idle_thread.rst (modified) * porting/interrupts.rst (modified) * porting/priority_bitmap.rst (modified) * porting/task_context.rst (modified) * posix_users/input_and_output.rst (modified) * posix_users/process_environment.rst (modified) * posix_users/signal.rst (modified) * shell/file_and_directory.rst (modified) * shell/general_commands.rst (modified) rtems-docs: Fix many unnecessary back slashes Fri, 28 Oct 2016 00:27:02 GMT Joel Sherrill [2b175c3] * bsp_howto/initilization_code.rst (modified) initilization_code.rst: Fix figure formatting Fri, 28 Oct 2016 00:19:27 GMT Joel Sherrill [690643a] * shell/file_and_directory.rst (modified) Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems-docs Fri, 28 Oct 2016 00:19:00 GMT Joel Sherrill [a1c7180] * bsp_howto/ata.rst (modified) * bsp_howto/bsp_howto_old_reference_only.rst (modified) * shell/rtems_specific_commands.rst (modified) * shell/shell_old_reference_only.rst (modified) Misc: Capitalize RTEMS. Fri, 28 Oct 2016 00:13:31 GMT Joel Sherrill [b8a7654] * shell/file_and_directory.rst (modified) shell/file_and_directory.rst: Correct mkdos command. Thu, 27 Oct 2016 23:49:07 GMT Joel Sherrill [f3dbb02] * develenv/sample.rst (modified) develenv/sample.rst: Correct formatting error Thu, 27 Oct 2016 23:35:41 GMT Joel Sherrill [c2cefaa] * develenv/develenv_old_reference_only.rst (modified) * develenv/directory.rst (modified) * develenv/utilities.rst (modified) develenv: Fix build errors for real Thu, 27 Oct 2016 23:26:57 GMT Joel Sherrill [8c75d59] * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/sample.rst (modified) develenv: Fix build errors Thu, 27 Oct 2016 23:11:44 GMT Joel Sherrill [8e59c99] * user/ecosys/index.rst (modified) ecosys/index.rst: Fix complixity spelling Thu, 27 Oct 2016 23:12:50 GMT Chris Johns [9b53679] * develenv/command.rst (modified) * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/introduction.rst (modified) * develenv/sample.rst (modified) * develenv/utilities.rst (modified) Fix develenv. Needs more fixes. Thu, 27 Oct 2016 23:03:34 GMT Joel Sherrill [be428d1] * common/waf.py (modified) common/waf.py: Improve Sphinx version parsing to work with their git ... Thu, 06 Oct 2016 22:13:16 GMT Chris Johns [f233256] * cpu_supplement/altera_nios_ii.rst (modified) * cpu_supplement/arm.rst (modified) * cpu_supplement/atmel_avr.rst (modified) * cpu_supplement/blackfin.rst (modified) * cpu_supplement/ephiphany.rst (modified) * cpu_supplement/index.rst (modified) * cpu_supplement/intel_amd_x86.rst (modified) * cpu_supplement/lattice_micro32.rst (modified) * cpu_supplement/m68xxx_and_coldfire.rst (modified) * cpu_supplement/mips.rst (modified) * cpu_supplement/openrisc_1000.rst (modified) * cpu_supplement/port.rst (modified) * cpu_supplement/powerpc.rst (modified) * cpu_supplement/preface.rst (modified) * cpu_supplement/renesas_m32c.rst (modified) * cpu_supplement/sparc.rst (modified) * cpu_supplement/sparc64.rst (modified) * cpu_supplement/superh.rst (modified) * cpu_supplement/xilinx_microblaze.rst (modified) Clean up the CPU Supplement. Tue, 13 Sep 2016 23:23:27 GMT Chris Johns [e6fe68d] * c_user/rate_monotonic_manager.rst (modified) c_user: Fix minor error. Fri, 09 Sep 2016 04:08:48 GMT Chris Johns [a545490] * common/waf.py (modified) waf: Fix for waf-1.9.3. Wed, 06 Jul 2016 05:03:38 GMT Chris Johns [ba30a48] * user/hardware/tiers.rst (modified) Fix the table and section numbering in the User,Hardware,Tiers section. Wed, 06 Jul 2016 04:59:00 GMT Chris Johns [8da3a62] * user/architecture/index.rst (deleted) * user/conf.py (modified) * user/hardware/architectures.rst (added) * user/hardware/bsps.rst (added) * user/hardware/hw-layers.txt (added) * user/hardware/index.rst (added) * user/hardware/targets.rst (added) * user/hardware/tiers.rst (added) * user/index.rst (modified) Add a Hardware section. Wed, 06 Jul 2016 04:57:47 GMT Chris Johns [b73ba92] * user/glossary/index.rst (modified) Update the glossary. Mon, 04 Jul 2016 02:45:57 GMT Chris Johns [ae7a139] * user/conf.py (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (added) Add the RTEMS Kernel section back in. Mon, 04 Jul 2016 02:30:34 GMT Chris Johns [f92357f] * common/_static/my-styles.css (modified) Make the Warning colours match the theme. Mon, 04 Jul 2016 02:30:09 GMT Chris Johns [86518bd] * user/conf.py (modified) * user/ecosys/index.rst (added) * user/glossary/index.rst (modified) * user/hosts/index.rst (added) * user/hosts/macos.rst (added) * user/hosts/os.rst (added) * user/hosts/posix.rst (added) * user/hosts/windows.rst (moved) * user/index.rst (modified) * user/installation/developer.rst (moved) * user/installation/index.rst (added) * user/installation/prefixes-sandboxing.rst (moved) * user/installation/releases.rst (moved) * user/overview/index.rst (modified) * user/start/development.rst (deleted) * user/start/index.rst (modified) * user/start/quick.rst (added) * user/support/index.rst (modified) * user/tools/index.rst (modified) Reorganisse the User Manual to make it easier to navigate. Fri, 17 Jun 2016 05:05:41 GMT Chris Johns [6d7a4d2] * bsp_howto/ada95_interrupt.rst (modified) * bsp_howto/analog.rst (modified) * bsp_howto/ata.rst (modified) * bsp_howto/clock.rst (modified) * bsp_howto/conf.py (modified) * bsp_howto/console.rst (modified) * bsp_howto/discrete.rst (modified) * bsp_howto/frame_buffer.rst (modified) * bsp_howto/ide_controller.rst (modified) * bsp_howto/index.rst (modified) * bsp_howto/initilization_code.rst (modified) * bsp_howto/linker_script.rst (modified) * bsp_howto/makefiles.rst (modified) * bsp_howto/miscellanous_support.rst (modified) * bsp_howto/networking.rst (modified) * bsp_howto/non_volatile_memory.rst (modified) * bsp_howto/preface.rst (modified) * bsp_howto/real_time_clock.rst (modified) * bsp_howto/shared_memory_support.rst (modified) * bsp_howto/target_dependant_files.rst (modified) * bsp_howto/timer.rst (modified) Update the BSP howto. Closes #2590. Fri, 20 May 2016 03:03:46 GMT Chris Johns [54514fe] * eclipse/conf.py (added) * eclipse/glossary.rst (added) * eclipse/index.rst (added) * eclipse/overview.rst (added) * eclipse/rtems.rst (added) * eclipse/wscript (added) * images/eclipse/eclipse-autotools.png (added) * images/eclipse/eclipse-cdt.png (added) * images/eclipse/eclipse-gcc-cross.png (added) * images/eclipse/eclipse-help-installation.png (added) * images/eclipse/eclipse-install-new-software.png (added) * images/eclipse/eclipse-new-project.png (added) * images/eclipse/eclipse-project-import-existing-code.png (added) * images/eclipse/eclipse-project-makefile-existing-code.png (added) * images/eclipse/eclipse-rtems-git-build-project-building.png (added) * images/eclipse/eclipse-rtems-git-build-project.png (added) * images/eclipse/eclipse-rtems-git-built.png (added) * images/eclipse/eclipse-rtems-git-convert-autotools-dialog.png (added) * images/eclipse/eclipse-rtems-git-convert-autotools.png (added) * images/eclipse/eclipse-rtems-git-files.png (added) * images/eclipse/eclipse-rtems-git-prop-at-add-opts.png (added) * images/eclipse/eclipse-rtems-git-prop-at-prefix.png (added) * images/eclipse/eclipse-rtems-git-prop-at-target.png (added) * images/eclipse/eclipse-rtems-git-prop-cdt-build.png (added) * images/eclipse/eclipse-rtems-git-prop-cdt-env-replace.png (added) * images/eclipse/eclipse-rtems-git-prop-cdt-env-var-path-add.png (added) * images/eclipse/eclipse-rtems-git-prop-cdt-env-var-path.png (added) * images/eclipse/eclipse-rtems-git-prop-cdt-env-var.png (added) * images/eclipse/eclipse-rtems-git-prop-cdt-env.png (added) * images/eclipse/eclipse-rtems-git-prop-cdt-settings.png (added) * images/eclipse/eclipse-rtems-git-properties-menu.png (added) * images/eclipse/eclipse-rtems-git-reconfigure-console.png (added) * images/eclipse/eclipse-rtems-git-reconfigure.png (added) * images/eclipse/eclipse-sdk-details.png (added) Add Eclipse user manual for RTEMS. Fri, 20 May 2016 02:47:09 GMT Chris Johns [489740f] * book/index_book.rst (modified) * bsp_howto/ada95_interrupt.rst (modified) * bsp_howto/analog.rst (modified) * bsp_howto/ata.rst (modified) * bsp_howto/bsp_howto_old_reference_only.rst (modified) * bsp_howto/clock.rst (modified) * bsp_howto/command.rst (modified) * bsp_howto/console.rst (modified) * bsp_howto/discrete.rst (modified) * bsp_howto/frame_buffer.rst (modified) * bsp_howto/ide_controller.rst (modified) * bsp_howto/index.rst (modified) * bsp_howto/initilization_code.rst (modified) * bsp_howto/linker_script.rst (modified) * bsp_howto/makefiles.rst (modified) * bsp_howto/miscellanous_support.rst (modified) * bsp_howto/networking.rst (modified) * bsp_howto/non_volatile_memory.rst (modified) * bsp_howto/preface.rst (modified) * bsp_howto/real_time_clock.rst (modified) * bsp_howto/shared_memory_support.rst (modified) * bsp_howto/target_dependant_files.rst (modified) * bsp_howto/timer.rst (modified) * c_user/barrier_manager.rst (modified) * c_user/board_support_packages.rst (modified) * c_user/c_user_old_reference_only.rst (modified) * c_user/chains.rst (modified) * c_user/clock_manager.rst (modified) * c_user/configuring_a_system.rst (modified) * c_user/constant_bandwidth_server.rst (modified) * c_user/cpu_usage_statistics.rst (modified) * c_user/directive_status_codes.rst (modified) * c_user/dual_ports_memory_manager.rst (modified) * c_user/event_manager.rst (modified) * c_user/example_application.rst (modified) * c_user/fatal_error.rst (modified) * c_user/glossary.rst (modified) * c_user/index.rst (modified) * c_user/initialization.rst (modified) * c_user/interrupt_manager.rst (modified) * c_user/io_manager.rst (modified) * c_user/key_concepts.rst (modified) * c_user/linker_sets.rst (modified) * c_user/message_manager.rst (modified) * c_user/multiprocessing.rst (modified) * c_user/object_services.rst (modified) * c_user/overview.rst (modified) * c_user/partition_manager.rst (modified) * c_user/pci_library.rst (modified) * c_user/preface.rst (modified) * c_user/rate_monotonic_manager.rst (modified) * c_user/red_black_trees.rst (modified) * c_user/region_manager.rst (modified) * c_user/rtems_data_types.rst (modified) * c_user/scheduling_concepts.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/signal_manager.rst (modified) * c_user/stack_bounds_checker.rst (modified) * c_user/symmetric_multiprocessing_services.rst (modified) * c_user/task_manager.rst (modified) * c_user/timer_manager.rst (modified) * c_user/timespec_helpers.rst (modified) * c_user/user_extensions.rst (modified) * cpu_supplement/altera_nios_ii.rst (modified) * cpu_supplement/arm.rst (modified) * cpu_supplement/atmel_avr.rst (modified) * cpu_supplement/blackfin.rst (modified) * cpu_supplement/command.rst (modified) * cpu_supplement/cpu_supplement_old_reference_only.rst (modified) * cpu_supplement/ephiphany.rst (modified) * cpu_supplement/index.rst (modified) * cpu_supplement/intel_amd_x86.rst (modified) * cpu_supplement/lattice_micro32.rst (modified) * cpu_supplement/m68xxx_and_coldfire.rst (modified) * cpu_supplement/mips.rst (modified) * cpu_supplement/openrisc_1000.rst (modified) * cpu_supplement/port.rst (modified) * cpu_supplement/powerpc.rst (modified) * cpu_supplement/preface.rst (modified) * cpu_supplement/renesas_m32c.rst (modified) * cpu_supplement/sparc.rst (modified) * cpu_supplement/sparc64.rst (modified) * cpu_supplement/superh.rst (modified) * cpu_supplement/xilinx_microblaze.rst (modified) * develenv/command.rst (modified) * develenv/develenv_old_reference_only.rst (modified) * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/introduction.rst (modified) * develenv/sample.rst (modified) * develenv/utilities.rst (modified) * filesystem/call_development.rst (modified) * filesystem/command_and_variable.rst (modified) * filesystem/filesystem_old_reference_only.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/index.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * filesystem/trivial_ftp.rst (modified) * networking/command.rst (modified) * networking/dec_21140.rst (modified) * networking/index.rst (modified) * networking/network_servers.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/networking_old_reference_only.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/command.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/index.rst (modified) * porting/interrupts.rst (modified) * porting/miscellanous.rst (modified) * porting/porting_old_reference_only.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix1003_1/clocks_and_timers.rst (modified) * posix1003_1/command.rst (modified) * posix1003_1/compliance_summary.rst (modified) * posix1003_1/data_interchange_format.rst (modified) * posix1003_1/device_and_class_specific.rst (modified) * posix1003_1/execution_scheduling.rst (modified) * posix1003_1/files_and_directories.rst (modified) * posix1003_1/general.rst (modified) * posix1003_1/index.rst (modified) * posix1003_1/input_and_output.rst (modified) * posix1003_1/language_specific_services.rst (modified) * posix1003_1/memory_managment.rst (modified) * posix1003_1/message_passing.rst (modified) * posix1003_1/posix1003_1.rst (modified) * posix1003_1/preface.rst (modified) * posix1003_1/process_environment.rst (modified) * posix1003_1/process_primitives.rst (modified) * posix1003_1/synchronization.rst (modified) * posix1003_1/system_database.rst (modified) * posix1003_1/terminology.rst (modified) * posix1003_1/thread_cancellation.rst (modified) * posix1003_1/thread_managment.rst (modified) * posix1003_1/thread_specific_data.rst (modified) * posix_users/clock.rst (modified) * posix_users/command.rst (modified) * posix_users/condition_variable.rst (modified) * posix_users/device_and_class_specific.rst (modified) * posix_users/files_and_directory.rst (modified) * posix_users/index.rst (modified) * posix_users/input_and_output.rst (modified) * posix_users/key.rst (modified) * posix_users/language_specific_services.rst (modified) * posix_users/memory_managment.rst (modified) * posix_users/message_passing.rst (modified) * posix_users/mutex.rst (modified) * posix_users/posix_users_old_reference_only.rst (modified) * posix_users/preface.rst (modified) * posix_users/process_creation_and_execution.rst (modified) * posix_users/process_environment.rst (modified) * posix_users/scheduler.rst (modified) * posix_users/semaphore.rst (modified) * posix_users/services_provided_by_c.rst (modified) * posix_users/services_provided_by_math.rst (modified) * posix_users/signal.rst (modified) * posix_users/status_of_implementation.rst (modified) * posix_users/system_database.rst (modified) * posix_users/thread.rst (modified) * posix_users/thread_cancellation.rst (modified) * posix_users/timer.rst (modified) * rtemsconfig/index.rst (modified) * rtemsconfig/option.rst (modified) * rtemsconfig/rtemsconfig.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * shell/shell_old_reference_only.rst (modified) * user/additional/index.rst (modified) * user/architecture/index.rst (modified) * user/bsp/index.rst (modified) * user/config/build.rst (modified) * user/config/index.rst (modified) * user/config/runtime.rst (modified) * user/glossary/index.rst (modified) * user/index.rst (modified) * user/overview/index.rst (modified) * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/development.rst (modified) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/releases.rst (modified) * user/start/transition.rst (modified) * user/start/windows.rst (modified) * user/support/index.rst (modified) * user/test/create.rst (modified) * user/test/index.rst (modified) * user/test/running.rst (modified) * user/tools/build.rst (modified) * user/tools/index.rst (modified) * user/tools/simulation.rst (modified) * user/waf/build.rst (modified) * user/waf/config.rst (modified) * user/waf/index.rst (modified) * user/waf/install.rst (modified) Set SPDX License Identifier in each source file. Wed, 18 May 2016 17:47:42 GMT Amar Takhar [170418a] * c_user/overview.rst (modified) * c_user/scheduling_concepts.rst (modified) * c_user/semaphore_manager.rst (modified) * common/waf.py (modified) * images/c_user/rtemsarc.png (moved) * images/c_user/rtemspie.png (moved) * images/c_user/semaphore_attributes.png (moved) * images/c_user/states.png (moved) * images/msys2-minw64-start-menu.png (moved) * images/networking/PCIreg.jpg (moved) * images/networking/networkflow.jpg (moved) * images/networking/recvbd.jpg (moved) * networking/dec_21140.rst (modified) * networking/network_task_structure.rst (modified) * user/start/depend.rst (modified) Move images to a common directory. Mon, 11 Apr 2016 06:32:30 GMT Chris Johns [bc37517] * networking/using_networking_rtems_app.rst (modified) Fix indenting. Mon, 11 Apr 2016 03:53:58 GMT Chris Johns [b412038] * networking/conf.py (modified) * networking/dec_21140.rst (modified) * networking/index.rst (modified) * networking/network_servers.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) Clean up and review of Networking User Guide. Fri, 01 Apr 2016 01:20:13 GMT Chris Johns [ea0777e] * user/overview/index.rst (modified) * user/start/basics.rst (modified) * user/start/index.rst (modified) Review changes from Chris Mayfield. Thu, 24 Mar 2016 02:28:36 GMT Chris Johns [aae09e2] * user/start/depend.rst (modified) * user/support/index.rst (modified) Corrections from Worth Burruss. Many thanks. Wed, 23 Mar 2016 22:33:29 GMT Chris Johns [a34c157] * user/glossary/index.rst (modified) * user/overview/index.rst (modified) * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/development.rst (modified) * user/start/index.rst (modified) * user/start/releases.rst (modified) * user/start/windows.rst (modified) * user/support/index.rst (modified) Corrections from Worth Burruss. Many thanks. Wed, 23 Mar 2016 20:35:44 GMT Chris Johns [6958370] * user/start/depend.rst (modified) Fix bad formatting that somehow went into the doco. Wed, 23 Mar 2016 02:57:56 GMT Chris Johns [dc234b5] * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/releases.rst (modified) Corrections from a review. Wed, 23 Mar 2016 02:18:56 GMT Chris Johns [c075916] * user/start/depend.rst (modified) * user/start/windows.rst (modified) Corrections and improvements from Worth Burruss (thanks so much). Tue, 22 Mar 2016 02:42:02 GMT Chris Johns [2151927] * user/start/basics.rst (modified) * user/start/depend.rst (modified) * user/start/releases.rst (modified) Corrections. Tue, 22 Mar 2016 01:54:39 GMT Chris Johns [27bcdfb] * user/conf.py (modified) * user/start/basics.rst (added) * user/start/depend.rst (modified) * user/start/development.rst (modified) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/releases.rst (modified) * user/start/windows.rst (modified) Add a basics section to Getting Started. Rearrange the content. Mon, 21 Mar 2016 01:19:59 GMT Chris Johns [024e040] * user/start/releases.rst (modified) Start adding Getting Started guide's Released Version. Sun, 20 Mar 2016 23:27:52 GMT Chris Johns [5353914] * common/rtemsstyle.sty (modified) * user/start/development.rst (modified) * user/start/windows.rst (modified) Updates from user reviews. Wed, 16 Mar 2016 23:45:43 GMT Chris Johns [924c542] * c_user/symmetric_multiprocessing_services.rst (modified) Fix SMP warning. Wed, 16 Mar 2016 23:33:42 GMT Chris Johns [ad42291] * common/rtemsstyle.sty (modified) Remove the minted gobble. Wed, 16 Mar 2016 23:30:29 GMT Chris Johns [e9c2b7a] * c_user/conf.py (modified) * posix_users/conf.py (modified) * shell/conf.py (modified) Update version numbers and the titles. Wed, 16 Mar 2016 23:30:09 GMT Chris Johns [1a5e1d7] * c_user/rate_monotonic_manager.rst (modified) Fix formatting. Thu, 10 Mar 2016 16:48:15 GMT Amar Takhar [2bcd424] * common/conf.py (modified) * common/rtemsstyle.sty (modified) * common/waf.py (modified) Switch to using Minted and splitting long lines in verbatim. Thu, 10 Mar 2016 16:34:19 GMT Amar Takhar [63eaa6f] * common/minted.sty (added) Add Minted 2015/12/21 v2.2dev (ce7a111) Thu, 10 Mar 2016 02:25:27 GMT Chris Johns [4e3cf2b] * user/conf.py (modified) * user/start/development.rst (added) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/releases.rst (added) * user/start/windows.rst (modified) Split installation into separate files. Wed, 09 Mar 2016 04:37:31 GMT Chris Johns [c05e43b] * user/additional/index.rst (modified) * user/conf.py (modified) * user/config/build.rst (modified) * user/config/runtime.rst (modified) * user/glossary/index.rst (modified) * user/index.rst (modified) * user/overview/index.rst (modified) * user/start/depend.rst (modified) * user/start/index.rst (modified) * user/start/installation.rst (modified) * user/start/msys2-minw64-start-menu.png (added) * user/start/transition.rst (modified) * user/start/windows.rst (added) * user/test/create.rst (modified) * user/test/running.rst (modified) * user/tools/build.rst (modified) * user/tools/simulation.rst (modified) User manual, devel install and windows install. Wed, 09 Mar 2016 04:36:32 GMT Chris Johns [cec0d2b] * posix_users/conf.py (modified) Update the POSIX user manual version number. Wed, 09 Mar 2016 04:35:21 GMT Chris Johns [c21e8e9] * common/rtemsdomain.py (modified) Better error message, add FTP to the URL list. Wed, 09 Mar 2016 04:35:00 GMT Chris Johns [867016d] * common/rtemsstyle.sty (modified) Format the index for PDF output. Tue, 08 Mar 2016 09:16:37 GMT Chris Johns [0858375] * common/waf.py (modified) Run through 2to3. Tue, 01 Mar 2016 03:46:08 GMT Amar Takhar [1ea5fb7] * common/rtemsstyle.sty (modified) Wrap \tabulary environment to allow breaking underscores. * This ... Fri, 26 Feb 2016 07:22:07 GMT Chris Johns [fa70fd2] * posix_users/clock.rst (modified) * posix_users/condition_variable.rst (modified) * posix_users/device_and_class_specific.rst (modified) * posix_users/files_and_directory.rst (modified) * posix_users/index.rst (modified) * posix_users/input_and_output.rst (modified) * posix_users/key.rst (modified) * posix_users/language_specific_services.rst (modified) * posix_users/memory_managment.rst (modified) * posix_users/message_passing.rst (modified) * posix_users/mutex.rst (modified) * posix_users/preface.rst (modified) * posix_users/process_creation_and_execution.rst (modified) * posix_users/process_environment.rst (modified) * posix_users/scheduler.rst (modified) * posix_users/semaphore.rst (modified) * posix_users/services_provided_by_c.rst (modified) * posix_users/signal.rst (modified) * posix_users/status_of_implementation.rst (modified) * posix_users/system_database.rst (modified) * posix_users/thread.rst (modified) * posix_users/thread_cancellation.rst (modified) * posix_users/timer.rst (modified) POSIX User clean up. Fri, 19 Feb 2016 04:45:57 GMT Chris Johns [238bf991] * shell/index.rst (modified) Update the shell user's guide top level. Thu, 18 Feb 2016 05:22:28 GMT Chris Johns [bcd64c6] * c_user/configuring_a_system.rst (modified) * c_user/dual_ports_memory_manager.rst (modified) * c_user/linker_sets.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/timer_manager.rst (modified) Minor fixes. Thu, 18 Feb 2016 05:22:15 GMT Chris Johns [f29b7faf] * c_user/glossary.rst (modified) Clean up. Thu, 18 Feb 2016 04:41:28 GMT Chris Johns [25d55d4] * c_user/barrier_manager.rst (modified) * c_user/clock_manager.rst (modified) * c_user/configuring_a_system.rst (modified) * c_user/cpu_usage_statistics.rst (modified) * c_user/dual_ports_memory_manager.rst (modified) * c_user/event_manager.rst (modified) * c_user/fatal_error.rst (modified) * c_user/initialization.rst (modified) * c_user/interrupt_manager.rst (modified) * c_user/io_manager.rst (modified) * c_user/key_concepts.rst (modified) * c_user/message_manager.rst (modified) * c_user/multiprocessing.rst (modified) * c_user/object_services.rst (modified) * c_user/overview.rst (modified) * c_user/partition_manager.rst (modified) * c_user/pci_library.rst (modified) * c_user/rate_monotonic_manager.rst (modified) * c_user/region_manager.rst (modified) * c_user/scheduling_concepts.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/signal_manager.rst (modified) * c_user/stack_bounds_checker.rst (modified) * c_user/symmetric_multiprocessing_services.rst (modified) * c_user/task_manager.rst (modified) * c_user/timer_manager.rst (modified) * c_user/user_extensions.rst (modified) Change code to code-block. Thu, 18 Feb 2016 04:31:34 GMT Chris Johns [00d1a0a] * c_user/timespec_helpers.rst (modified) Fix double quotes. Thu, 18 Feb 2016 04:29:28 GMT Chris Johns [0d86b71] * c_user/chains.rst (modified) * c_user/constant_bandwidth_server.rst (modified) * c_user/cpu_usage_statistics.rst (modified) * c_user/directive_status_codes.rst (modified) * c_user/example_application.rst (modified) * c_user/linker_sets.rst (modified) * c_user/object_services.rst (modified) * c_user/red_black_trees.rst (modified) * c_user/stack_bounds_checker.rst (modified) * c_user/timespec_helpers.rst (modified) Clean up. Thu, 18 Feb 2016 04:29:17 GMT Chris Johns [1762611] * c_user/semaphore_attributes.png (added) * c_user/semaphore_manager.rst (modified) Add semaphore attributes figure. Wed, 17 Feb 2016 23:32:05 GMT Chris Johns [f02e872] * c_user/barrier_manager.rst (modified) * c_user/clock_manager.rst (modified) * c_user/configuring_a_system.rst (modified) * c_user/dual_ports_memory_manager.rst (modified) * c_user/interrupt_manager.rst (modified) * c_user/key_concepts.rst (modified) * c_user/multiprocessing.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/task_manager.rst (modified) Fix the double quotes. Wed, 17 Feb 2016 00:49:55 GMT Chris Johns [080608f] * c_user/key_concepts.rst (modified) Manually apply patch from textinfo dooc. Patch ... Wed, 03 Feb 2016 21:19:13 GMT Chris Johns [c9aaf31] * c_user/configuring_a_system.rst (modified) * c_user/initialization.rst (modified) * c_user/key_concepts.rst (modified) * c_user/multiprocessing.rst (modified) * c_user/pci_library.rst (modified) * c_user/symmetric_multiprocessing_services.rst (modified) Clean up Wed, 27 Jan 2016 06:50:19 GMT Chris Johns [8ef6ea8] * c_user/barrier_manager.rst (modified) * c_user/board_support_packages.rst (modified) * c_user/dual_ports_memory_manager.rst (modified) * c_user/event_manager.rst (modified) * c_user/fatal_error.rst (modified) * c_user/io_manager.rst (modified) * c_user/message_manager.rst (modified) * c_user/partition_manager.rst (modified) * c_user/region_manager.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/signal_manager.rst (modified) * c_user/user_extensions.rst (modified) Clean ups. Wed, 27 Jan 2016 06:50:07 GMT Chris Johns [eccd84e] * common/_static/my-styles.css (modified) Add wrap support to long table entries. Wed, 27 Jan 2016 00:27:31 GMT Chris Johns [859f0b7] * c_user/interrupt_manager.rst (modified) * c_user/rate_monotonic_manager.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/task_manager.rst (modified) * c_user/timer_manager.rst (modified) * common/_static/my-styles.css (modified) Add an rtems-table class to wrap and align HTML tables. Tue, 26 Jan 2016 22:38:16 GMT Chris Johns [1a72a98] * c_user/interrupt_manager.rst (modified) * c_user/key_concepts.rst (modified) * c_user/rate_monotonic_manager.rst (modified) * c_user/rtems_data_types.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/timer_manager.rst (modified) Cleanups. Tue, 26 Jan 2016 10:49:59 GMT Chris Johns [66220bc] * c_user/key_concepts.rst (modified) Fix index error. Tue, 26 Jan 2016 10:49:19 GMT Chris Johns [0ddfd93] * c_user/task_manager.rst (modified) Remove widths from tables for the PDF. Tue, 26 Jan 2016 10:48:15 GMT Chris Johns [7130ed3] * c_user/index.rst (modified) * common/conf.py (modified) * common/rtemsstyle.sty (modified) Fix PDF layout. Tue, 26 Jan 2016 01:29:49 GMT Chris Johns [8083970] * c_user/task_manager.rst (modified) Switch the task manager to tables for status codes. Tue, 26 Jan 2016 01:29:27 GMT Chris Johns [36745eb] * c_user/command.rst (deleted) * c_user/index.rst (modified) Remove command.rst and clean up the index page. Tue, 26 Jan 2016 01:26:11 GMT Chris Johns [c18d76a] * common/_static/my-styles.css (modified) * common/conf.py (modified) * common/sphinx_rtd_theme_rtems/layout.html (modified) * common/sphinx_rtd_theme_rtems/theme.conf (modified) Add my-style.css support and add RTEMS to that CSS. Sun, 24 Jan 2016 10:37:53 GMT Chris Johns [b8d3f6b] * c_user/clock_manager.rst (modified) * c_user/initialization.rst (modified) * c_user/interrupt_manager.rst (modified) * c_user/key_concepts.rst (modified) * c_user/overview.rst (modified) * c_user/preface.rst (modified) * c_user/rate_monotonic_manager.rst (modified) * c_user/rtems_data_types.rst (modified) * c_user/rtemsarc.png (added) * c_user/rtemspie.png (added) * c_user/scheduling_concepts.rst (modified) * c_user/states.png (added) * c_user/task_manager.rst (modified) * c_user/timer_manager.rst (modified) C user guide clean up. Up to timer manager. Sat, 23 Jan 2016 05:01:45 GMT Chris Johns [0f5ccd4] * common/waf.py (modified) Generate a fatal error on a Sphinx beta version that cannot be parsed. Sat, 23 Jan 2016 03:24:32 GMT Chris Johns [e5afcaa] * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/index.rst (modified) * shell/preface.rst (modified) Add OAR copyright to each file. Sat, 23 Jan 2016 03:24:10 GMT Chris Johns [35bcd00] * shell/rtems_specific_commands.rst (modified) Clean up. Sat, 23 Jan 2016 03:24:00 GMT Chris Johns [bcfdcef] * shell/network_commands.rst (modified) Clean up. Fri, 22 Jan 2016 23:14:53 GMT Chris Johns [fabe6d0] * shell/memory_commands.rst (modified) Clean up the memory commands. Fri, 22 Jan 2016 23:14:42 GMT Chris Johns [df77336] * shell/file_and_directory.rst (modified) * shell/general_commands.rst (modified) Add links from the command list to the commands. Wed, 20 Jan 2016 04:00:32 GMT Amar Takhar [ed3794e] * bsp_howto/wscript (modified) * c_user/wscript (modified) * common/waf.py (modified) * cpu_supplement/wscript (modified) * develenv/wscript (modified) * filesystem/wscript (modified) * networking/wscript (modified) * posix1003_1/wscript (modified) * posix_users/wscript (modified) * shell/wscript (modified) * user/wscript (modified) Add 'waf linkcheck' to check external references. Wed, 20 Jan 2016 02:48:37 GMT Amar Takhar [9b495a2] * common/waf.py (modified) Remove incorrect pdflatex/makeindex check. Wed, 20 Jan 2016 02:03:57 GMT Amar Takhar [7c1f215] * common/waf.py (modified) Only require makeindex and pdflatex when trying to build PDF. Wed, 20 Jan 2016 01:37:04 GMT Amar Takhar [a316b1f] * common/conf.py (modified) * common/rtemsstyle.sty (modified) * common/sphinx_rtd_theme/static/css/theme.css (deleted) * common/sphinx_rtd_theme_rtems/__init__.py (moved) * common/sphinx_rtd_theme_rtems/breadcrumbs.html (moved) * common/sphinx_rtd_theme_rtems/footer.html (moved) * common/sphinx_rtd_theme_rtems/layout.html (moved) * common/sphinx_rtd_theme_rtems/layout_old.html (moved) * common/sphinx_rtd_theme_rtems/search.html (moved) * common/sphinx_rtd_theme_rtems/searchbox.html (moved) * common/sphinx_rtd_theme_rtems/static/css/badge_only.css (moved) * common/sphinx_rtd_theme_rtems/static/css/badge_only.css.map (moved) * common/sphinx_rtd_theme_rtems/static/css/theme.css (added) * common/sphinx_rtd_theme_rtems/static/css/theme.css.map (moved) * common/sphinx_rtd_theme_rtems/static/fonts/FontAwesome.otf (moved) * common/sphinx_rtd_theme_rtems/static/fonts/Inconsolata-Bold.ttf (moved) * common/sphinx_rtd_theme_rtems/static/fonts/Inconsolata-Regular.ttf (moved) * common/sphinx_rtd_theme_rtems/static/fonts/Lato-Bold.ttf (moved) * common/sphinx_rtd_theme_rtems/static/fonts/Lato-Regular.ttf (moved) * common/sphinx_rtd_theme_rtems/static/fonts/RobotoSlab-Bold.ttf (moved) * common/sphinx_rtd_theme_rtems/static/fonts/RobotoSlab-Regular.ttf (moved) * common/sphinx_rtd_theme_rtems/static/fonts/fontawesome-webfont.eot (moved) * common/sphinx_rtd_theme_rtems/static/fonts/fontawesome-webfont.svg (moved) * common/sphinx_rtd_theme_rtems/static/fonts/fontawesome-webfont.ttf (moved) * common/sphinx_rtd_theme_rtems/static/fonts/fontawesome-webfont.woff (moved) * common/sphinx_rtd_theme_rtems/static/js/modernizr.min.js (moved) * common/sphinx_rtd_theme_rtems/static/js/theme.js (moved) * common/sphinx_rtd_theme_rtems/theme.conf (moved) * common/sphinx_rtd_theme_rtems/versions.html (moved) * common/waf.py (modified) * filesystem/conf.py (modified) Add support for singlehtml (inlined) HTML file, plus some other ... Wed, 20 Jan 2016 00:33:59 GMT Amar Takhar [89f2347] * common/waf.py (modified) Fix typo and add another dependency. Tue, 19 Jan 2016 14:55:57 GMT Amar Takhar [14bbcb1] * common/waf.py (modified) Add minimum version check for Sphinx. Some distributions have ... Tue, 19 Jan 2016 05:27:45 GMT Amar Takhar [9b5801a] * book/conf.py (modified) * bsp_howto/conf.py (modified) * bsp_howto/wscript (modified) * c_user/conf.py (added) * c_user/wscript (modified) * common/conf.py (modified) * common/rtemsstyle.sty (moved) * common/waf.py (modified) * cpu_supplement/conf.py (modified) * cpu_supplement/wscript (modified) * develenv/conf.py (modified) * develenv/wscript (modified) * filesystem/conf.py (modified) * filesystem/wscript (modified) * networking/conf.py (modified) * networking/wscript (modified) * porting/conf.py (modified) * porting/wscript (modified) * posix1003_1/conf.py (modified) * posix1003_1/wscript (modified) * posix_users/conf.py (modified) * posix_users/wscript (modified) * rtemsconfig/conf.py (modified) * shell/conf.py (modified) * shell/wscript (modified) * user/conf.py (modified) * user/wscript (modified) Add PDF generation support use with --pdf Tue, 19 Jan 2016 04:30:27 GMT Amar Takhar [0abc59d] * common/logo.svg (added) * common/logo_inkscape.svg (added) Add .svg logos for RTEMS that I made myself. One is plain SVG the ... Tue, 19 Jan 2016 04:30:17 GMT Amar Takhar [2643223] * common/logo.pdf (added) Add logo.pdf for PDF documents. Tue, 19 Jan 2016 00:34:03 GMT Amar Takhar [b990440] * shell/conf.py (added) Add missed conf.py. No idea how this happened. Tue, 19 Jan 2016 00:29:54 GMT Chris Johns [4f81ff1] * shell/file_and_directory.rst (modified) Clean up of file and directory commands. Mon, 18 Jan 2016 22:53:44 GMT Amar Takhar [f916fca] * book/wscript (modified) * bsp_howto/wscript (modified) * c_user/wscript (modified) * common/spell/dict/rtems (added) * common/spell/en_GB-ise-w_accents-only.rws (added) * common/spell/en_GB-ise-w_accents.multi (added) * common/waf.py (modified) * cpu_supplement/wscript (modified) * develenv/wscript (modified) * filesystem/wscript (modified) * networking/wscript (modified) * porting/wscript (modified) * posix1003_1/wscript (modified) * posix_users/wscript (modified) * rtemsconfig/wscript (modified) * shell/wscript (modified) * user/wscript (modified) Add support for spellchecking with a custom dictionary. To use: ... Mon, 18 Jan 2016 05:37:40 GMT Amar Takhar [d389819] * bsp_howto/analog.rst (modified) * bsp_howto/ata.rst (modified) * bsp_howto/clock.rst (modified) * bsp_howto/console.rst (modified) * bsp_howto/discrete.rst (modified) * bsp_howto/index.rst (modified) * bsp_howto/initilization_code.rst (modified) * bsp_howto/linker_script.rst (modified) * bsp_howto/makefiles.rst (modified) * bsp_howto/miscellanous_support.rst (modified) * bsp_howto/networking.rst (modified) * bsp_howto/non_volatile_memory.rst (modified) * bsp_howto/real_time_clock.rst (modified) * bsp_howto/shared_memory_support.rst (modified) * bsp_howto/target_dependant_files.rst (modified) * bsp_howto/timer.rst (modified) * c_user/barrier_manager.rst (modified) * c_user/board_support_packages.rst (modified) * c_user/chains.rst (modified) * c_user/clock_manager.rst (modified) * c_user/configuring_a_system.rst (modified) * c_user/constant_bandwidth_server.rst (modified) * c_user/cpu_usage_statistics.rst (modified) * c_user/dual_ports_memory_manager.rst (modified) * c_user/event_manager.rst (modified) * c_user/fatal_error.rst (modified) * c_user/glossary.rst (modified) * c_user/index.rst (modified) * c_user/initialization.rst (modified) * c_user/interrupt_manager.rst (modified) * c_user/io_manager.rst (modified) * c_user/key_concepts.rst (modified) * c_user/message_manager.rst (modified) * c_user/multiprocessing.rst (modified) * c_user/overview.rst (modified) * c_user/partition_manager.rst (modified) * c_user/pci_library.rst (modified) * c_user/preface.rst (modified) * c_user/rate_monotonic_manager.rst (modified) * c_user/red_black_trees.rst (modified) * c_user/region_manager.rst (modified) * c_user/rtems_data_types.rst (modified) * c_user/scheduling_concepts.rst (modified) * c_user/semaphore_manager.rst (modified) * c_user/signal_manager.rst (modified) * c_user/stack_bounds_checker.rst (modified) * c_user/symmetric_multiprocessing_services.rst (modified) * c_user/task_manager.rst (modified) * c_user/timer_manager.rst (modified) * c_user/timespec_helpers.rst (modified) * c_user/user_extensions.rst (modified) * cpu_supplement/atmel_avr.rst (modified) * cpu_supplement/blackfin.rst (modified) * cpu_supplement/index.rst (modified) * cpu_supplement/intel_amd_x86.rst (modified) * cpu_supplement/lattice_micro32.rst (modified) * cpu_supplement/m68xxx_and_coldfire.rst (modified) * cpu_supplement/mips.rst (modified) * cpu_supplement/port.rst (modified) * cpu_supplement/powerpc.rst (modified) * cpu_supplement/sparc.rst (modified) * cpu_supplement/sparc64.rst (modified) * cpu_supplement/superh.rst (modified) * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/sample.rst (modified) * develenv/utilities.rst (modified) * filesystem/call_development.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/index.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/system_init.rst (modified) * networking/dec_21140.rst (modified) * networking/index.rst (modified) * networking/network_servers.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/idle_thread.rst (modified) * porting/index.rst (modified) * porting/interrupts.rst (modified) * porting/miscellanous.rst (modified) * porting/priority_bitmap.rst (modified) * porting/task_context.rst (modified) * posix1003_1/files_and_directories.rst (modified) * posix1003_1/index.rst (modified) * posix1003_1/language_specific_services.rst (modified) * posix1003_1/posix1003_1.rst (modified) * posix1003_1/terminology.rst (modified) * posix_users/clock.rst (modified) * posix_users/condition_variable.rst (modified) * posix_users/device_and_class_specific.rst (modified) * posix_users/files_and_directory.rst (modified) * posix_users/index.rst (modified) * posix_users/input_and_output.rst (modified) * posix_users/key.rst (modified) * posix_users/language_specific_services.rst (modified) * posix_users/memory_managment.rst (modified) * posix_users/message_passing.rst (modified) * posix_users/mutex.rst (modified) * posix_users/preface.rst (modified) * posix_users/process_creation_and_execution.rst (modified) * posix_users/process_environment.rst (modified) * posix_users/scheduler.rst (modified) * posix_users/semaphore.rst (modified) * posix_users/services_provided_by_c.rst (modified) * posix_users/signal.rst (modified) * posix_users/system_database.rst (modified) * posix_users/thread.rst (modified) * posix_users/thread_cancellation.rst (modified) * posix_users/timer.rst (modified) * shell/file_and_directory.rst (modified) * shell/index.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) Convert all Unicode to ASCII(128) Mon, 18 Jan 2016 05:06:41 GMT Amar Takhar [11e1a6f] * ada_user/ada_user_old_reference_only.rst (deleted) * ada_user/barrier_manager.rst (deleted) * ada_user/board_support_packages.rst (deleted) * ada_user/chains.rst (deleted) * ada_user/clock_manager.rst (deleted) * ada_user/command.rst (deleted) * ada_user/conf.py (deleted) * ada_user/configuring_a_system.rst (deleted) * ada_user/constant_bandwidth_server_scheduler_api.rst (deleted) * ada_user/cpu_usage_statistics.rst (deleted) * ada_user/directive_status_codes.rst (deleted) * ada_user/dual_ports_memory_manager.rst (deleted) * ada_user/event_manager.rst (deleted) * ada_user/example_application.rst (deleted) * ada_user/fatal_error_manager.rst (deleted) * ada_user/glossary.rst (deleted) * ada_user/index.rst (deleted) * ada_user/initialization_manager.rst (deleted) * ada_user/interrupt_manager.rst (deleted) * ada_user/io_manager.rst (deleted) * ada_user/key_concepts.rst (deleted) * ada_user/linker_sets.rst (deleted) * ada_user/message_manager.rst (deleted) * ada_user/multiprocessing_manager.rst (deleted) * ada_user/object_services.rst (deleted) * ada_user/overview.rst (deleted) * ada_user/partition_manager.rst (deleted) * ada_user/pci_library.rst (deleted) * ada_user/preface.rst (deleted) * ada_user/rate_monotonic_manager.rst (deleted) * ada_user/red_black_trees.rst (deleted) * ada_user/region_manager.rst (deleted) * ada_user/rtems_data_types.rst (deleted) * ada_user/scheduling_concepts.rst (deleted) * ada_user/semaphore_manager.rst (deleted) * ada_user/signal_manager.rst (deleted) * ada_user/stack_bounds_checker.rst (deleted) * ada_user/symmetric_multiprocessing_services.rst (deleted) * ada_user/task_manager.rst (deleted) * ada_user/timepsec_helpers.rst (deleted) * ada_user/timer_manager.rst (deleted) * ada_user/user_extensions_manager.rst (deleted) * ada_user/wscript (deleted) Remove ada_user document. We are going to make Ada a chapter in the ... Mon, 18 Jan 2016 05:05:50 GMT Amar Takhar [3a71759] * ada_user/conf.py (added) * ada_user/wscript (modified) * book/conf.py (added) * book/wscript (modified) * bsp_howto/conf.py (added) * bsp_howto/wscript (modified) * c_user/wscript (modified) * common/__init__.py (added) * common/conf.py (modified) * common/waf.py (modified) * cpu_supplement/conf.py (added) * cpu_supplement/wscript (modified) * develenv/conf.py (added) * develenv/wscript (modified) * filesystem/conf.py (added) * filesystem/wscript (modified) * networking/conf.py (added) * networking/wscript (modified) * porting/conf.py (added) * porting/wscript (modified) * posix1003_1/conf.py (added) * posix1003_1/wscript (modified) * posix_users/conf.py (added) * posix_users/wscript (modified) * rtemsconfig/conf.py (added) * rtemsconfig/wscript (modified) * shell/wscript (modified) * user/conf.py (added) * user/wscript (modified) Rework how conf.py is handled. Needed to switch due to increasing ... Mon, 18 Jan 2016 03:28:28 GMT Amar Takhar [46498bd] * book/index_book.rst (modified) * book/wscript (modified) * common/conf.py (modified) * rtemsconfig/wscript (modified) Fix rtemsconfig building. I'll probably move to a more pythonic way ... Mon, 18 Jan 2016 00:39:15 GMT Amar Takhar [6c6246c] * new_chapters/index.rst (deleted) * new_chapters/new_chapters.rst (deleted) * new_chapters/wscript (deleted) Delete new_chapters document as it is rarely used. Joel says this ... Mon, 18 Jan 2016 00:21:18 GMT Amar Takhar [d94936a] * relnotes/index.rst (deleted) * relnotes/relnotes.rst (deleted) * relnotes/wscript (deleted) Remove relnotes are per Joel -- it has no use anymore. It is ...
